  4. iobroker restore 0 funktioniert nicht
61 Beiträge 4 Kommentatoren 7.0k Aufrufe 3 Beobachtet
    @funkytown
    Nochmal
    for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
    funkytownF Offline
    funkytownF Offline
    funkytown
    markus@rpi:~ $ iobroker upgrade admin --debug
    This upgrade of "admin" will introduce the following changes:
    -> 6.2.22:
    Corrected admin4 adapter settings
    -> 6.2.21:
    Corrected small JSON config issue
    Would you like to upgrade admin from @6.2.20 to @6.2.22 now? [(y)es, (n)o]: y
    Update admin from @6.2.20 to @6.2.22
    NPM version: 8.15.0
    Installing iobroker.admin@6.2.22... (System call)
    npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
    npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
    npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
    npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
    npm WARN deprecated multer@1.4.4: Multer 1.x is affected by CVE-2022-24434. This is fixed in v1.4.4-lts.1 which drops support for versions of Node.js before 6. Please upgrade to at least Node.js 6 and version 1.4.4-lts.1 of Multer. If you need support for older versions of Node.js, we are open to accepting patches that would fix the CVE on the main 1.x release line, whilst maintaining compatibility with Node.js 0.10.
    npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm WARN deprecated axios@0.27.0: Formdata complete broken, incorrect build size
    npm ERR! code ENOTEMPTY
    npm ERR! syscall rename
    npm ERR! path /opt/iobroker/node_modules/node-red-node-email/node_modules/encoding-japanese/src
    npm ERR! dest /opt/iobroker/node_modules/.node-red-node-email-1lk8B7Gi/node_modules/encoding-japanese/src
    npm ERR! errno -39
    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/node-red-node-email/node_modules/encoding-japanese/src' -> '/opt/iobroker/node_modules/.node-red-node-email-1lk8B7Gi/node_modules/encoding-japanese/src'
    npm ERR!     /home/iobroker/.npm/_logs/2022-09-22T20_27_53_207Z-debug-0.log
    host.rpi Cannot install iobroker.admin@6.2.22: 217
    markus@rpi:~ $
    Synology DS218+, Homatic CCU3, FritzBox 7590, Raspberry Pi
    • funkytownF funkytown
      -> 6.2.22:
      -> 6.2.21:
      NPM version: 8.15.0
      npm ERR! errno -39
      markus@rpi:~ $
      @funkytown
      Führst du das nicht aus?
      Das sollte das eigentlich alles bereinigen.
      funkytownF 2 Antworten Letzte Antwort
        @funkytown
        funkytownF Offline
        funkytownF Offline
        funkytown
        Das habe ich jedes mal ausgeführt. Muss das evtl als sudo ausgeführt werden?
          @funkytown sagte in iobroker restore 0 funktioniert nicht:
          Wenn du die Rechte nicht zerschossen hast nicht.
          iobroker stop
          iobroker fix
            @funkytown
            funkytownF Offline
            funkytownF Offline
            funkytown
            schrieb am zuletzt editiert von funkytown
            eben wird das erste mal was ausgegeben! Muss wohl tatsächlich unter sudo ausgeführt werden!
            rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/zconf.h' ist nicht möglich: Keine Berechtigung
            rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/tiff.h' ist nicht möglich: Keine Berechtigung
            rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/expat.h' ist nicht möglich: Keine Berechtigung
            rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/webp/mux.h' ist nicht möglich: Keine Berechtigung
            rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/webp/demux.h' ist nicht möglich: Keine Berechtigung
            rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/webp/decode.h' ist nicht möglich: Keine Berechtigung
            rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/webp/mux_types.h' ist nicht möglich: Keine Berechtigung
            rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/webp/types.h' ist nicht möglich: Keine Berechtigung
            rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/webp/encode.h' ist nicht möglich: Keine Berechtigung
            rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/pnglibconf.h' ist nicht möglich: Keine Berechtigung
            rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/ffi.h' ist nicht möglich: Keine Berechtigung
            rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/lcms2.h' ist nicht möglich: Keine Berechtigung
            rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/lib/libvips-cpp.so.42' ist nicht möglich: Keine Berechtigung
            rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/lib/glib-2.0/include/glibconfig.h' ist nicht möglich: Keine Berechtigung
              Da dürftest du mal als root / mit sudo hantiert haben.
              iobroker fix ausgeführt?
              funkytownF 1 Antwort Letzte Antwort
                funkytownF Offline
                funkytownF Offline
                funkytown
                kann ich jetzt mit Sicherheit nicht mehr sagen. Aber ja, das könnte schon bei den vielen Versuchen den Fehler zu beheben in der Vergangenheit passiert sein.
                  @funkytown
                  Dann die Version für Erwachsene:
                  for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do sudo rm -rf ${i%%/}; done
                    @funkytown
                    funkytownF Offline
                    funkytownF Offline
                    funkytown
                    kann immer noch nicht zugreifen!
                    markus@rpi:~ $ iobroker fix
                    library: loaded
                    Library version=2022-06-15
                        Welcome to the ioBroker installation fixer!
                        Script version: 2022-06-03
                        You might need to enter your password a couple of times.
                        Installing prerequisites (1/3)
                    [sudo] Passwort für markus:
                    OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                    OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
                    OK:3 https://dl.yarnpkg.com/debian stable InRelease
                    OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease
                    Installed gcc-c++
                        Checking ioBroker user and directory permissions (2/3)
                        Checking autostart (3/3)
                    Enabling autostart...
                    Autostart enabled!
                        Your installation was fixed successfully
                        Run iobroker start to start ioBroker again!
                    markus@rpi:~ $ iobroker start
                    markus@rpi:~ $ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
                    Adapter "admin"          is up to date.
                    markus@rpi:~ $
                      library: loaded
                      Installed gcc-c++
                      Autostart enabled!
                      markus@rpi:~ $
                      @funkytown
                      iobroker update
                      iobroker list instances
                      GlasfaserG funkytownF 2 Antworten Letzte Antwort
                        @funkytown
                        iobroker update
                        GlasfaserG Offline
                        GlasfaserG Offline
                        habe hier nur kurz reingeschaut ... sehe immer stop .. start.
                        Wurde mal ein Reboot durchgeführt.
                          @funkytown
                          iobroker update
                          funkytownF Offline
                          funkytownF Offline
                          funkytown
                          markus@rpi:~ $ iobroker update
                          #Used repository: stable
                          Adapter    "admin"        : 6.2.22   , installed 6.2.22
                          Adapter    "alexa2"       : 3.19.9   , installed 3.19.9
                          Adapter    "backitup"     : 2.4.12   , installed 2.4.10 [Updatable]
                          Adapter    "cloud"        : 4.2.2    , installed 4.2.2
                          Adapter    "cul"          : 2.0.2    , installed 2.0.2
                          Adapter    "discovery"    : 3.0.5    , installed 3.0.5
                          Adapter    "dwd"          : 2.8.3    , installed 2.8.3
                          Adapter    "email"        : 1.1.3    , installed 1.1.3
                          Adapter    "history"      : 2.2.0    , installed 2.2.0
                          Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
                          Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
                          Adapter    "info"         : 1.9.19   , installed 1.9.19
                          Adapter    "iot"          : 1.11.9   , installed 1.11.8 [Updatable]
                          Adapter    "javascript"   : 6.0.3    , installed 6.0.0  [Updatable]
                          Controller "js-controller": 4.0.23   , installed 4.0.23
                          Adapter    "linux-control": 1.1.3    , installed 1.1.5
                          Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
                          Adapter    "node-red"     : 4.0.0    , installed 3.3.1  [Updatable]
                          Adapter    "openweathermap": 0.3.0   , installed 0.2.5  [Updatable]
                          Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                          Adapter    "pushover"     : 3.0.3    , installed 3.0.2  [Updatable]
                          Adapter    "radar2"       : 2.0.3    , installed 2.0.3
                          Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
                          Adapter    "synology"     : 2.1.9    , installed 2.1.9
                          Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
                          Adapter    "telegram"     : 1.14.1   , installed 1.13.0 [Updatable]
                          Adapter    "text2command" : 2.2.2    , installed 2.2.2
                          Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
                          Adapter    "trashschedule": 2.0.3    , installed 2.0.3
                          Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
                          Adapter    "withings"     : 0.0.9    , installed 0.0.9
                          Adapter    "yahka"        : 0.13.1   , installed 0.13.1
                          markus@rpi:~ $ iobroker list instances
                          + system.adapter.admin.0                  : admin                 : rpi                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                          + system.adapter.alexa2.0                 : alexa2                : rpi                                      -  enabled
                          + system.adapter.alexa2.1                 : alexa2                : rpi                                      -  enabled
                          + system.adapter.backitup.0               : backitup              : rpi                                      -  enabled
                          + system.adapter.discovery.0              : discovery             : rpi                                      -  enabled
                            system.adapter.dwd.0                    : dwd                   : rpi                                      - disabled
                          + system.adapter.email.0                  : email                 : rpi                                      -  enabled
                          + system.adapter.history.0                : history               : rpi                                      -  enabled
                          + system.adapter.hm-rega.0                : hm-rega               : rpi                                      -  enabled
                          + system.adapter.hm-rpc.0                 : hm-rpc                : rpi                                      -  enabled, port: 0
                          + system.adapter.hm-rpc.1                 : hm-rpc                : rpi                                      -  enabled, port: 0
                          + system.adapter.hm-rpc.2                 : hm-rpc                : rpi                                      -  enabled, port: 0
                          + system.adapter.hm-rpc.3                 : hm-rpc                : rpi                                      -  enabled, port: 0
                            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : rpi                                      - disabled
                          + system.adapter.info.0                   : info                  : rpi                                      -  enabled
                          + system.adapter.iot.0                    : iot                   : rpi                                      -  enabled
                          + system.adapter.javascript.0             : javascript            : rpi                                      -  enabled
                          + system.adapter.linux-control.0          : linux-control         : rpi                                      -  enabled
                          + system.adapter.mqtt.0                   : mqtt                  : rpi                                      -  enabled, port: 1883, bind: 0.0.0.0
                          + system.adapter.ping.0                   : ping                  : rpi                                      -  enabled
                            system.adapter.pollenflug.0             : pollenflug            : rpi                                      - disabled
                          + system.adapter.pushover.0               : pushover              : rpi                                      -  enabled
                          + system.adapter.rpi2.0                   : rpi2                  : rpi                                      -  enabled
                          + system.adapter.scenes.0                 : scenes                : rpi                                      -  enabled
                            system.adapter.synology.0               : synology              : rpi                                      - disabled, port: 5000
                          + system.adapter.tankerkoenig.0           : tankerkoenig          : rpi                                      -  enabled
                            system.adapter.telegram.0               : telegram              : rpi                                      - disabled, port: 8443, bind: 0.0.0.0
                            system.adapter.text2command.0           : text2command          : rpi                                      - disabled
                          + system.adapter.tr-064.0                 : tr-064                : rpi                                      -  enabled
                            system.adapter.vis-material-advanced.0  : vis-material-advanced : rpi                                      - disabled
                            system.adapter.vis.0                    : vis                   : rpi                                      - disabled
                          + system.adapter.web.0                    : web                   : rpi                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                            system.adapter.withings.0               : withings              : rpi                                      - disabled
                            system.adapter.yahka.0                  : yahka                 : rpi                                      - disabled
                          + system.adapter.yahka.1                  : yahka                 : rpi                                      -  enabled
                          + instance is alive
                          markus@rpi:~ $
                            + instance is alive
                            markus@rpi:~ $
                            @funkytown
                            Läuft.
                            Zieh die updates der anderen Adapter noch nach.
                              @funkytown
                              Läuft.
                              funkytownF Offline
                              funkytownF Offline
                              funkytown
                              Der ioBroker ist wieder über Port 8081 erreichbar :-)
                              Ich habe jetzt viel gelernt und hoffe, dass ich beim nächsten Mal selbst ein Problem dieser Tragweite lösen kann.
                              Vielen Dank Thomas Braun!
                                @funkytown
                                Läuft.
                                funkytownF Offline
                                funkytownF Offline
                                funkytown
                                Ein Phänomen ist noch vorhanden. Ich muss admin.0 immer starten. Warum passiert das nicht automatisch?
                                • Thomas BraunT Online
                                  Wann?
                                    Wann?
                                    funkytownF Offline
                                    funkytownF Offline
                                    funkytown
                                    nach einem reboot des System. War auf 8081 nicht erreichbar, und nach einem Start des admin.0 über die command line funktionierte wieder alles.
                                      Wann?
                                      funkytownF Offline
                                      funkytownF Offline
                                      funkytown
                                      ausserdem ist der alte admin 6.2.20 wieder installiert obwohl doch der 6.2.22 bereits installiert wurde!
                                        @funkytown Eigentlich sollten Adapter, die auf 'enabled' stehen beim Start des js-controllers auch wieder gestartet werden.
                                        sagt?
                                          sagt?
                                          funkytownF Offline
                                          funkytownF Offline
                                          funkytown
                                          Adapter    "admin"        : 6.2.22   , installed 6.2.20 [Updatable]
                                          Adapter    "openweathermap": 0.3.0   , installed 0.3.0
                                          Adapter    "telegram"     : 1.14.1   , installed 1.14.1
                                          markus@rpi:~ $
                                          + instance is alive
                                          markus@rpi:~ $
