  4. iobroker restore 0 funktioniert nicht
61 Beiträge 4 Kommentatoren 7.0k Aufrufe 3 Beobachtet
  • funkytownF funkytown
    Da stimmt schon was nicht!
    markus@rpi:~ $ iobroker upgrade
    This upgrade of "alexa2" will introduce the following changes:
    -> 3.19.9:
    Receive the correct player status again when musik is stopped
    -> 3.19.8:
    Add safeguard for too high intervals
    Would you like to upgrade alexa2 from @3.19.7 to @3.19.9 now? [(y)es, (n)o]: y
    Update alexa2 from @3.19.7 to @3.19.9
    NPM version: 8.15.0
    Installing iobroker.alexa2@3.19.9... (System call)
    host.rpi Cannot install iobroker.alexa2@3.19.9: 217
    @funkytown
    for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
      @funkytown
      iobroker upgrade
      iobroker del admin.1
      iobroker start admin.0
      Warum 2 Instanzen vom Admin?
      funkytownF Offline
      funkytownF Offline
      funkytown
      This upgrade of "openweathermap" will introduce the following changes:
      -> 0.3.0:
      Added new widget for vis2.0
      Would you like to upgrade openweathermap from @0.2.5 to @0.3.0 now? [(y)es, (n)o]: n
      No upgrade of "openweathermap" desired.
      This upgrade of "admin" will introduce the following changes:
      -> 6.2.22:
      Corrected admin4 adapter settings
      -> 6.2.21:
      Corrected small JSON config issue
      Would you like to upgrade admin from @6.2.20 to @6.2.22 now? [(y)es, (n)o]: y
      Update admin from @6.2.20 to @6.2.22
      host.rpi Adapter "system.adapter.admin.0" is stopped.
      NPM version: 8.15.0
      Installing iobroker.admin@6.2.22... (System call)
      host.rpi Cannot install iobroker.admin@6.2.22: 217
      Synology DS218+, Homatic CCU3, FritzBox 7590, Raspberry Pi
        -> 0.3.0:
        -> 6.2.22:
        -> 6.2.21:
        NPM version: 8.15.0
        @funkytown sagte in iobroker restore 0 funktioniert nicht:
        iobroker upgrade admin --debug
        funkytownF 1 Antwort Letzte Antwort
          funkytownF Offline
          funkytownF Offline
          funkytown
          markus@rpi:~ $ iobroker upgrade admin --debug
          -> 6.2.22:
          -> 6.2.21:
          NPM version: 8.15.0
          npm ERR! code ENOTEMPTY
          npm ERR! syscall rename
          npm ERR! path /opt/iobroker/node_modules/addressparser
          npm ERR! dest /opt/iobroker/node_modules/.addressparser-qF9vtHFg
          npm ERR! errno -39
          npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/addressparser' -> '/opt/iobroker/node_modules/.addressparser-qF9vtHFg'
          npm ERR!     /home/iobroker/.npm/_logs/2022-09-22T20_14_23_357Z-debug-0.log
            -> 6.2.22:
            -> 6.2.21:
            NPM version: 8.15.0
            npm ERR! errno -39
            @funkytown
            Nochmal
            funkytownF 2 Antworten Letzte Antwort
              @funkytown
              Nochmal
              funkytownF Offline
              funkytownF Offline
              funkytown
              Zwischendurch einmal ein DANKE an dich!
                @funkytown
                Nochmal
                funkytownF Offline
                funkytownF Offline
                funkytown
                -> 6.2.22:
                -> 6.2.21:
                NPM version: 8.15.0
                npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
                npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                npm WARN deprecated multer@1.4.4: Multer 1.x is affected by CVE-2022-24434. This is fixed in v1.4.4-lts.1 which drops support for versions of Node.js before 6. Please upgrade to at least Node.js 6 and version 1.4.4-lts.1 of Multer. If you need support for older versions of Node.js, we are open to accepting patches that would fix the CVE on the main 1.x release line, whilst maintaining compatibility with Node.js 0.10.
                npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                npm WARN deprecated axios@0.27.0: Formdata complete broken, incorrect build size
                npm ERR! path /opt/iobroker/node_modules/node-red-node-email/node_modules/encoding-japanese/src
                npm ERR! dest /opt/iobroker/node_modules/.node-red-node-email-1lk8B7Gi/node_modules/encoding-japanese/src
                npm ERR! errno -39
                npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/node-red-node-email/node_modules/encoding-japanese/src' -> '/opt/iobroker/node_modules/.node-red-node-email-1lk8B7Gi/node_modules/encoding-japanese/src'
                npm ERR!     /home/iobroker/.npm/_logs/2022-09-22T20_27_53_207Z-debug-0.log
                markus@rpi:~ $
                  -> 6.2.22:
                  -> 6.2.21:
                  NPM version: 8.15.0
                  npm ERR! errno -39
                  markus@rpi:~ $
                  @funkytown
                  Führst du das nicht aus?
                  Das sollte das eigentlich alles bereinigen.
                    @funkytown
                    funkytownF Offline
                    funkytownF Offline
                    funkytown
                    Das habe ich jedes mal ausgeführt. Muss das evtl als sudo ausgeführt werden?
                      Wenn du die Rechte nicht zerschossen hast nicht.
                      iobroker stop
                      iobroker fix
                        @funkytown
                        funkytownF Offline
                        funkytownF Offline
                        funkytown
                        schrieb am zuletzt editiert von funkytown
                        eben wird das erste mal was ausgegeben! Muss wohl tatsächlich unter sudo ausgeführt werden!
                        rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/zconf.h' ist nicht möglich: Keine Berechtigung
                        rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/tiff.h' ist nicht möglich: Keine Berechtigung
                        rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/expat.h' ist nicht möglich: Keine Berechtigung
                        rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/webp/mux.h' ist nicht möglich: Keine Berechtigung
                        rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/webp/demux.h' ist nicht möglich: Keine Berechtigung
                        rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/webp/decode.h' ist nicht möglich: Keine Berechtigung
                        rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/webp/mux_types.h' ist nicht möglich: Keine Berechtigung
                        rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/webp/types.h' ist nicht möglich: Keine Berechtigung
                        rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/webp/encode.h' ist nicht möglich: Keine Berechtigung
                        rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/pnglibconf.h' ist nicht möglich: Keine Berechtigung
                        rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/ffi.h' ist nicht möglich: Keine Berechtigung
                        rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/lcms2.h' ist nicht möglich: Keine Berechtigung
                        rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/lib/libvips-cpp.so.42' ist nicht möglich: Keine Berechtigung
                        rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/lib/glib-2.0/include/glibconfig.h' ist nicht möglich: Keine Berechtigung
                          Da dürftest du mal als root / mit sudo hantiert haben.
                          iobroker fix ausgeführt?
                            funkytownF Offline
                            funkytownF Offline
                            funkytown
                            kann ich jetzt mit Sicherheit nicht mehr sagen. Aber ja, das könnte schon bei den vielen Versuchen den Fehler zu beheben in der Vergangenheit passiert sein.
                              @funkytown
                              Dann die Version für Erwachsene:
                              for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do sudo rm -rf ${i%%/}; done
                                @funkytown
                                funkytownF Offline
                                funkytownF Offline
                                funkytown
                                kann immer noch nicht zugreifen!
                                markus@rpi:~ $ iobroker fix
                                library: loaded
                                Library version=2022-06-15
                                    Welcome to the ioBroker installation fixer!
                                    Script version: 2022-06-03
                                    You might need to enter your password a couple of times.
                                    Installing prerequisites (1/3)
                                [sudo] Passwort für markus:
                                OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
                                OK:3 https://dl.yarnpkg.com/debian stable InRelease
                                OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease
                                Installed gcc-c++
                                    Checking ioBroker user and directory permissions (2/3)
                                    Checking autostart (3/3)
                                Enabling autostart...
                                Autostart enabled!
                                    Your installation was fixed successfully
                                    Run iobroker start to start ioBroker again!
                                markus@rpi:~ $ iobroker start
                                markus@rpi:~ $ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
                                Adapter "admin"          is up to date.
                                markus@rpi:~ $
                                  library: loaded
                                  Installed gcc-c++
                                  Autostart enabled!
                                  markus@rpi:~ $
                                  @funkytown
                                  iobroker update
                                  iobroker list instances
                                  GlasfaserG funkytownF 2 Antworten Letzte Antwort
                                    @funkytown
                                    iobroker update
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    habe hier nur kurz reingeschaut ... sehe immer stop .. start.
                                    Wurde mal ein Reboot durchgeführt.
                                      @funkytown
                                      iobroker update
                                      funkytownF Offline
                                      funkytownF Offline
                                      funkytown
                                      markus@rpi:~ $ iobroker update
                                      #Used repository: stable
                                      Adapter    "admin"        : 6.2.22   , installed 6.2.22
                                      Adapter    "alexa2"       : 3.19.9   , installed 3.19.9
                                      Adapter    "backitup"     : 2.4.12   , installed 2.4.10 [Updatable]
                                      Adapter    "cloud"        : 4.2.2    , installed 4.2.2
                                      Adapter    "cul"          : 2.0.2    , installed 2.0.2
                                      Adapter    "discovery"    : 3.0.5    , installed 3.0.5
                                      Adapter    "dwd"          : 2.8.3    , installed 2.8.3
                                      Adapter    "email"        : 1.1.3    , installed 1.1.3
                                      Adapter    "history"      : 2.2.0    , installed 2.2.0
                                      Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
                                      Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
                                      Adapter    "info"         : 1.9.19   , installed 1.9.19
                                      Adapter    "iot"          : 1.11.9   , installed 1.11.8 [Updatable]
                                      Adapter    "javascript"   : 6.0.3    , installed 6.0.0  [Updatable]
                                      Controller "js-controller": 4.0.23   , installed 4.0.23
                                      Adapter    "linux-control": 1.1.3    , installed 1.1.5
                                      Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
                                      Adapter    "node-red"     : 4.0.0    , installed 3.3.1  [Updatable]
                                      Adapter    "openweathermap": 0.3.0   , installed 0.2.5  [Updatable]
                                      Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                                      Adapter    "pushover"     : 3.0.3    , installed 3.0.2  [Updatable]
                                      Adapter    "radar2"       : 2.0.3    , installed 2.0.3
                                      Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
                                      Adapter    "synology"     : 2.1.9    , installed 2.1.9
                                      Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
                                      Adapter    "telegram"     : 1.14.1   , installed 1.13.0 [Updatable]
                                      Adapter    "text2command" : 2.2.2    , installed 2.2.2
                                      Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
                                      Adapter    "trashschedule": 2.0.3    , installed 2.0.3
                                      Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
                                      Adapter    "withings"     : 0.0.9    , installed 0.0.9
                                      Adapter    "yahka"        : 0.13.1   , installed 0.13.1
                                      markus@rpi:~ $ iobroker list instances
                                      + system.adapter.admin.0                  : admin                 : rpi                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                      + system.adapter.alexa2.0                 : alexa2                : rpi                                      -  enabled
                                      + system.adapter.alexa2.1                 : alexa2                : rpi                                      -  enabled
                                      + system.adapter.backitup.0               : backitup              : rpi                                      -  enabled
                                      + system.adapter.discovery.0              : discovery             : rpi                                      -  enabled
                                        system.adapter.dwd.0                    : dwd                   : rpi                                      - disabled
                                      + system.adapter.email.0                  : email                 : rpi                                      -  enabled
                                      + system.adapter.history.0                : history               : rpi                                      -  enabled
                                      + system.adapter.hm-rega.0                : hm-rega               : rpi                                      -  enabled
                                      + system.adapter.hm-rpc.0                 : hm-rpc                : rpi                                      -  enabled, port: 0
                                      + system.adapter.hm-rpc.1                 : hm-rpc                : rpi                                      -  enabled, port: 0
                                      + system.adapter.hm-rpc.2                 : hm-rpc                : rpi                                      -  enabled, port: 0
                                      + system.adapter.hm-rpc.3                 : hm-rpc                : rpi                                      -  enabled, port: 0
                                        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : rpi                                      - disabled
                                      + system.adapter.info.0                   : info                  : rpi                                      -  enabled
                                      + system.adapter.iot.0                    : iot                   : rpi                                      -  enabled
                                      + system.adapter.javascript.0             : javascript            : rpi                                      -  enabled
                                      + system.adapter.linux-control.0          : linux-control         : rpi                                      -  enabled
                                      + system.adapter.mqtt.0                   : mqtt                  : rpi                                      -  enabled, port: 1883, bind: 0.0.0.0
                                      + system.adapter.ping.0                   : ping                  : rpi                                      -  enabled
                                        system.adapter.pollenflug.0             : pollenflug            : rpi                                      - disabled
                                      + system.adapter.pushover.0               : pushover              : rpi                                      -  enabled
                                      + system.adapter.rpi2.0                   : rpi2                  : rpi                                      -  enabled
                                      + system.adapter.scenes.0                 : scenes                : rpi                                      -  enabled
                                        system.adapter.synology.0               : synology              : rpi                                      - disabled, port: 5000
                                      + system.adapter.tankerkoenig.0           : tankerkoenig          : rpi                                      -  enabled
                                        system.adapter.telegram.0               : telegram              : rpi                                      - disabled, port: 8443, bind: 0.0.0.0
                                        system.adapter.text2command.0           : text2command          : rpi                                      - disabled
                                      + system.adapter.tr-064.0                 : tr-064                : rpi                                      -  enabled
                                        system.adapter.vis-material-advanced.0  : vis-material-advanced : rpi                                      - disabled
                                        system.adapter.vis.0                    : vis                   : rpi                                      - disabled
                                      + system.adapter.web.0                    : web                   : rpi                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                        system.adapter.withings.0               : withings              : rpi                                      - disabled
                                        system.adapter.yahka.0                  : yahka                 : rpi                                      - disabled
                                      + system.adapter.yahka.1                  : yahka                 : rpi                                      -  enabled
                                      + instance is alive
                                      markus@rpi:~ $
                                        + instance is alive
                                        markus@rpi:~ $
                                        @funkytown
                                        Läuft.
                                        Zieh die updates der anderen Adapter noch nach.
                                          @funkytown
                                          Läuft.
                                          funkytownF Offline
                                          funkytownF Offline
                                          funkytown
                                          Der ioBroker ist wieder über Port 8081 erreichbar :-)
                                          Ich habe jetzt viel gelernt und hoffe, dass ich beim nächsten Mal selbst ein Problem dieser Tragweite lösen kann.
                                          Vielen Dank Thomas Braun!
