  4. iobroker restore 0 funktioniert nicht
61 Beiträge 4 Kommentatoren 7.0k Aufrufe 3 Beobachtet
    @funkytown Eigentlich sollten Adapter, die auf 'enabled' stehen beim Start des js-controllers auch wieder gestartet werden.
    iobroker list instances
    sagt?
    funkytownF Offline
    funkytownF Offline
    funkytown
    markus@rpi:~ $ iobroker update
    Used repository: stable
    Adapter    "admin"        : 6.2.22   , installed 6.2.20 [Updatable]
    Adapter    "alexa2"       : 3.19.9   , installed 3.19.9
    Adapter    "backitup"     : 2.4.12   , installed 2.4.10 [Updatable]
    Adapter    "cloud"        : 4.2.2    , installed 4.2.2
    Adapter    "cul"          : 2.0.2    , installed 2.0.2
    Adapter    "discovery"    : 3.0.5    , installed 3.0.5
    Adapter    "dwd"          : 2.8.3    , installed 2.8.3
    Adapter    "email"        : 1.1.3    , installed 1.1.3
    Adapter    "history"      : 2.2.0    , installed 2.2.0
    Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
    Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "iot"          : 1.11.9   , installed 1.11.8 [Updatable]
    Adapter    "javascript"   : 6.0.3    , installed 6.0.0  [Updatable]
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "linux-control": 1.1.3    , installed 1.1.5
    Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
    Adapter    "node-red"     : 4.0.0    , installed 3.3.1  [Updatable]
    Adapter    "openweathermap": 0.3.0   , installed 0.3.0
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "pushover"     : 3.0.3    , installed 3.0.2  [Updatable]
    Adapter    "radar2"       : 2.0.3    , installed 2.0.3
    Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
    Adapter    "synology"     : 2.1.9    , installed 2.1.9
    Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
    Adapter    "telegram"     : 1.14.1   , installed 1.14.1
    Adapter    "text2command" : 2.2.2    , installed 2.2.2
    Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
    Adapter    "trashschedule": 2.0.3    , installed 2.0.3
    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
    Adapter    "withings"     : 0.0.9    , installed 0.0.9
    Adapter    "yahka"        : 0.13.1   , installed 0.13.1
    markus@rpi:~ $
    markus@rpi:~ $ iobroker list instances
    + system.adapter.admin.0                  : admin                 : rpi                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : rpi                                      -  enabled
    + system.adapter.alexa2.1                 : alexa2                : rpi                                      -  enabled
    + system.adapter.backitup.0               : backitup              : rpi                                      -  enabled
    + system.adapter.discovery.0              : discovery             : rpi                                      -  enabled
      system.adapter.dwd.0                    : dwd                   : rpi                                      - disabled
    + system.adapter.email.0                  : email                 : rpi                                      -  enabled
    + system.adapter.history.0                : history               : rpi                                      -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : rpi                                      -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : rpi                                      -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : rpi                                      -  enabled, port: 0
    + system.adapter.hm-rpc.2                 : hm-rpc                : rpi                                      -  enabled, port: 0
    + system.adapter.hm-rpc.3                 : hm-rpc                : rpi                                      -  enabled, port: 0
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : rpi                                      - disabled
    + system.adapter.info.0                   : info                  : rpi                                      -  enabled
    + system.adapter.iot.0                    : iot                   : rpi                                      -  enabled
    + system.adapter.javascript.0             : javascript            : rpi                                      -  enabled
    + system.adapter.linux-control.0          : linux-control         : rpi                                      -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : rpi                                      -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.ping.0                   : ping                  : rpi                                      -  enabled
      system.adapter.pollenflug.0             : pollenflug            : rpi                                      - disabled
    + system.adapter.pushover.0               : pushover              : rpi                                      -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : rpi                                      -  enabled
    + system.adapter.scenes.0                 : scenes                : rpi                                      -  enabled
      system.adapter.synology.0               : synology              : rpi                                      - disabled, port: 5000
    + system.adapter.tankerkoenig.0           : tankerkoenig          : rpi                                      -  enabled
      system.adapter.telegram.0               : telegram              : rpi                                      - disabled, port: 8443, bind: 0.0.0.0
      system.adapter.text2command.0           : text2command          : rpi                                      - disabled
    + system.adapter.tr-064.0                 : tr-064                : rpi                                      -  enabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : rpi                                      - disabled
      system.adapter.vis.0                    : vis                   : rpi                                      - disabled
    + system.adapter.web.0                    : web                   : rpi                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.withings.0               : withings              : rpi                                      - disabled
      system.adapter.yahka.0                  : yahka                 : rpi                                      - disabled
    + system.adapter.yahka.1                  : yahka                 : rpi                                      -  enabled
    + instance is alive
    markus@rpi:~ $
    Synology DS218+, Homatic CCU3, FritzBox 7590, Raspberry Pi
    • funkytownF funkytown
      markus@rpi:~ $
      + instance is alive
      markus@rpi:~ $
      @funkytown
      Kann es sein, dass du da zwei Systeme parallel installiert hast und mal in das eine und mal in das andere bootest?
      funkytownF 2 Antworten Letzte Antwort
        @funkytown
        funkytownF Offline
        funkytownF Offline
        funkytown
        aber wie soll das denn passieren?
        ABER, das war ja auch mit der cmdline.txt merkwürdig!!! Ich weiß, dass ich den Eintrag mit der UUID geändert hatte, und plötzlich stand wieder was anderes drin.
          @funkytown
          funkytownF Offline
          funkytownF Offline
          funkytown
          Mir ist aber auch aufgefallen, dass das system nach einem reboot mal sehr schnell und dann wiederum sehr lange braucht bis ich drauf zugreifen kann. Ich denke du hast recht mit deiner Vermutung. Verstehen tue ich es aber nicht :-)
            @funkytown
            Du hast doch da eine SD-Karte und noch irgendwas als Speichermedium dran. Nimm halt eins raus.
            funkytownF 1 Antwort Letzte Antwort
              @funkytown
              funkytownF Offline
              funkytownF Offline
              funkytown
              Ich habe eine SSD-Platte und ein USB-Stick dran hängen. Da ich mir sicher bin damals das System umgestellt habe damit es von der SSD-Platte bootet, werde ich jetzt mal den USB-Stick heraus nehmen.
                @funkytown sagte in iobroker restore 0 funktioniert nicht:
                Zuerst umounten. Oder herunterfahren.
                  funkytownF Offline
                  funkytownF Offline
                  funkytown
                  ich fahre das System herunter.
                    @funkytown
                    Da sind drei Speichermedien drin. Eine SD-Karte steckt auch noch drin.
                    Und die ist ebenso bootbar wie der USB_Stock auf /dev/sda1
                      @funkytown
                      funkytownF Offline
                      funkytownF Offline
                      funkytown
                      soweit ich mich erinnern kann boote ich tatsächlich das System von der SD-Karte aber das Root-System liegt auf der SSD-Platte. Die root Partition ist auch nach wie vor auf der SSD-Platte. Ich habe auch nur einmal den iobroker installiert. Wo ist denn vermerkt, dass der admin.0 sofort starten soll?
                      Komisch, in der aktuellen fstab verweist /dev/sdb1 auf root obwohl es sdb1 eigentlich nicht gibt!
                      markus@rpi:/boot $ cat /boot/cmdline.txt
                      dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=PARTUUID=3b18e43a-01 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                      markus@rpi:/boot $ blkid
                      /dev/mmcblk0p1: LABEL_FATBOOT="boot" LABEL="boot" UUID="0C61-73F5" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="02211fe5-01"
                      /dev/mmcblk0p2: LABEL="rootfs" UUID="43f2d0bb-83be-464f-94d0-9a751f376c64" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="02211fe5-02"
                      /dev/sda1: UUID="bbe67a8e-80a1-4c79-992c-a11ebfacecfe" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="3b18e43a-01"
                      /dev/sda2: UUID="c25aeb0d-0033-4d60-a8a9-a914652a27c1" TYPE="swap" PARTUUID="3b18e43a-02"
                      markus@rpi:/opt/iobroker $ cat /etc/fstab
                      proc            /proc           proc    defaults          0       0
                      PARTUUID=02211fe5-01  /boot           vfat    defaults,flush    0       2
                      #PARTUUID=924c1207-02  /               ext4    defaults,noatime  0       1
                      # a swapfile is not a swap partition, no line here
                      #   use  dphys-swapfile swap[on|off]  for that
                      /dev/sdb1       /               ext4    defaults,noatime  0       1
                      /dev/sdb2       swap            swap    defaults          0       0
