  4. *gelöst* Docker: Updates verschwinden immer wieder
    2.7k
    4.7k
    4.0k
49 Beiträge 5 Kommentatoren 5.3k Aufrufe 5 Beobachtet
  • GlasfaserG Glasfaser
    @glasfaser
    Stop Fehler gefunden !
    Dominic151617
    @glasfaser
    Fehler kommt schon früher
    root@iobroker:/opt/iobroker# iobroker upgrade rssfeed@2.6.1 --debug
    This upgrade of "rssfeed" will at least introduce the following changes:
    -> 2.6.1:
    add more informations to sentry
    -> 2.6.0:
    add sentry
    -> 2.5.0:
    add name option to widget marquee
    -> 2.0.0:
    Basic overhaul
    BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
    Would you like to upgrade rssfeed from @1.0.0 to @2.6.1 now? [(y)es, (n)o]: y
    Update rssfeed from @1.0.0 to @2.6.1
    NPM version: 6.14.17
    Installing iobroker.rssfeed@2.6.1... (System call)
    npm WARN saveError EACCES: permission denied, open '/opt/iobroker/package.json.1120760129'
    npm WARN saveError EACCES: permission denied, open '/opt/iobroker/package-lock.json.770259360'
    npm WARN crc@4.1.1 requires a peer of buffer@>=6.0.3 but none is installed. You must install peer dependencies yourself.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    + iobroker.rssfeed@2.6.1
    added 6 packages from 4 contributors, removed 31 packages and updated 8 packages in 48.816s
    179 packages are looking for funding
      run `npm fund` for details
    upload [13] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/build/index.css build/index.css text/css
    upload [12] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/build/index.js build/index.js application/javascript
    upload [11] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/i18n/de.json i18n/de.json application/json
    upload [10] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/i18n/en.json i18n/en.json application/json
    upload [9] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/i18n/es.json i18n/es.json application/json
    upload [8] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/i18n/fr.json i18n/fr.json application/json
    upload [7] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/i18n/it.json i18n/it.json application/json
    upload [6] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/i18n/nl.json i18n/nl.json application/json
    upload [5] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/i18n/pl.json i18n/pl.json application/json
    upload [4] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/i18n/pt.json i18n/pt.json application/json
    upload [3] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/i18n/ru.json i18n/ru.json application/json
    upload [2] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/i18n/zh-cn.json i18n/zh-cn.json application/json
    upload [1] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/jsonConfig.json jsonConfig.json application/json
    upload [0] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/rssfeed-logo.png rssfeed-logo.png image/png
    root@iobroker:/opt/iobroker# iobroker update -i
    Adapter    "admin"        : 6.2.17   , installed 5.3.8  [Updatable]
    Adapter    "artnet"       : 1.2.2    , installed 1.2.2
    Adapter    "backitup"     : 2.4.10   , installed 2.4.10
    Adapter    "bring"        : 1.8.1    , installed 1.8.1
    Adapter    "daswetter"    : 3.1.2    , installed 3.1.2
    Adapter    "devices"      : 1.0.12   , installed 1.0.12
    Adapter    "discovery"    : 3.0.5    , installed 3.0.5
    Adapter    "dwd"          : 2.8.3    , installed 2.8.3
    Adapter    "flot"         : 1.11.0   , installed 1.11.0
    Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
    Adapter    "ical"         : 1.13.1   , installed 1.13.1
    Adapter    "influxdb"     : 3.1.7    , installed 3.1.7
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "iogopro"      : 0.2.6    , installed 0.2.6
    Adapter    "jarvis"       : 3.0.11   , installed 3.0.11
    Adapter    "javascript"   : 6.0.0    , installed 5.7.0  [Updatable]
    Controller "js-controller": 4.0.23   , installed 4.0.21 [Updatable]
    Adapter    "kodi"         : 2.0.8    , installed 2.0.8
    Adapter    "lovelace"     : 2.2.0    , installed 2.2.0
    Adapter    "modbus"       : 5.0.4    , installed 5.0.4
    Adapter    "node-red"     : 3.3.1    , installed 3.3.1
    Adapter    "onvif"        : 0.4.4    , installed 0.4.4
    Adapter    "paw"          : 0.3.2    , installed 0.3.2
    Adapter    "ping"         : 1.5.3    , installed 1.5.3
    Adapter    "pushover"     : 3.0.2    , installed 3.0.2
    Adapter    "rssfeed"      : 2.6.1    , installed 2.6.1
    Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
    Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
    Adapter    "snmp"         : 1.0.0    , installed 1.0.0
    Adapter    "socketio"     : 4.2.0    , installed 4.2.0
    Adapter    "sql"          : 2.1.7    , installed 2.1.7
    Adapter    "synology"     : 2.1.9    , installed 2.1.9
    Adapter    "terminal"     : 0.2.6    , installed 0.2.6
    Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
    Adapter    "vis-lcars"    : 1.0.4    , installed 1.0.4
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.2
    Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
    Adapter    "vis-timeandweather": 1.2.2, installed 1.1.7 [Updatable]
    Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
    Adapter    "web"          : 4.3.0    , installed 4.3.0
    Adapter    "ws"           : 1.3.0    , installed 1.3.0
    Adapter    "yr"           : 5.3.0    , installed 5.3.0
    Adapter    "zigbee"       : 1.7.5    , installed 1.7.5
    GlasfaserG 2 Antworten Letzte Antwort
    • D Dominic151617
      @glasfaser
      -> 2.6.1:
      -> 2.6.0:
      add sentry
      -> 2.5.0:
      -> 2.0.0:
      Basic overhaul
      GlasfaserG Offline
      GlasfaserG Offline
      Glasfaser
      @dominic151617 sagte in Docker: Updates verschwinden immer wieder:
      Warte auf mich ... nicht quer installieren
      bitte das oben machen !
      • D Dominic151617
        @glasfaser
        -> 2.6.1:
        -> 2.6.0:
        add sentry
        -> 2.5.0:
        -> 2.0.0:
        Basic overhaul
        GlasfaserG Offline
        GlasfaserG Offline
        Glasfaser
        @dominic151617
        hier ist der Fehler :
        npm WARN saveError EACCES: permission denied, open '/opt/iobroker/package.json.1595669206'
        npm WARN saveError EACCES: permission denied, open '/opt/iobroker/package-lock.json.1033087263'
          Dominic151617
          @glasfaser sagte in Docker: Updates verschwinden immer wieder:
          Sorry, ich bin langsamer als Du. Daher hängen meine Nachrichten nach🤦‍♂️ Arbeite grade deine letzten Anweisungen ab.
            @dominic151617
            pkill -u iobroker
            rm /opt/iobroker/package*
            Wichtig dann Container neustarten
            iobroker update -i
            iobroker upgrade all
            Dominic151617
            @glasfaser Vielen, Vielen Dank! Scheint wieder zu funktionieren. Wenn man Ahnung hat, hilft das wohl eindeutig weiter😉
            Ich nehme dann auch noch mit: Die Datei /opt/iobroker/package.json existiert reguläre nicht. Zumindest gibt es sie jetzt nicht mehr.
            Die Logs spare ich mir dann in diesem Auszug mal.
            • D Dominic151617
              GlasfaserG Offline
              GlasfaserG Offline
              Glasfaser
              sie wurde neu erstellt .
              package.json
              inkl.
              package-lock.json
              ohne den gedöns dahinter und permission denied
              • A AndyGR42
                @dominic151617 Könnte helfen:
                https://docs.docker.com/engine/reference/commandline/commit/
                GlasfaserG Offline
                GlasfaserG Offline
                Glasfaser
                @andygr42 sagte in Docker: Updates verschwinden immer wieder:
                Es hatte sich die Datei /opt/iobroker/packages.json eingenistet und blockierte anscheinend die updates.
                FALSCH
                siehe über meinen Beitrag .
                  FALSCH
                  Dominic151617
                  FALSCH
                  OK. Ich korrigiere das. Dummerweise:
                  root@iobroker:/opt/iobroker# ls
                  backups  INSTALLER_INFO.txt  iob  iobroker  iobroker.bak  iobroker-data  log  node_modules
                  die Dateien wurden nicht neu erstellt. Die sind jetzt einfach nicht mehr da🤪 Ich vermute, da scheinen sich die Ordnerberechtigungen irgendwie quer gelegt zu haben. Mist
                  • D Dominic151617
                    FALSCH
                    GlasfaserG Offline
                    GlasfaserG Offline
                    Glasfaser
                    @dominic151617 sagte in *gelöst* Docker: Updates verschwinden immer wieder:
                    Dann stimmt etwas nicht .. beide Dateien sollten sichtbar / erstellt sein .
                    Hast du den Container nochmal neu gestartet bzw. starte Ihn neu
                    und zeige nochmal mit :
                    ls -la
                    deine gesamte Ausgabe davon.
                    sollte so dann "gekürzt" so aussehen
                    -rw-rwxr-- 1 iobroker iobroker 3,2K Aug 21 18:11 package.json
                    -rw-rwxr-- 1 iobroker iobroker 1,4M Aug 21 18:11 package-lock.json
                    Was mich auch Wundert an deiner Angabe :
                    Hast du mal was dazu selber geändert !?
                      ls -la
                      Dominic151617
                      Ich, nein. Das kann gar nicht sein. Ich tut sowas doch nicht😤 Ne, jetzt mal im ernst. Bewusst habe ich das nicht getan. Ich würde aber lügen, wenn ich es ausschließen würde.
                      Zumindest jetzt kann ich es auch nicht mehr verneinen, da ich aus der Synology raus den User iobroker mit Rechten ausgestattet habe. Jetzt geht es zumindest:
                      -rwxrwxr-x 1 iobroker iobroker    133 Aug 25 15:43 package.json
                      -rwxrwxr-x 1 iobroker iobroker 129372 Aug 25 15:43 package-lock.json
                      Allerdings sehe ich da zwei "x"e mehr als bei Dir. Ich hoffe mal, dass fällt mir nicht irgendwann auf die Füße...
                      • D Dominic151617
                        @dominic151617
                        x als Recht macht bei json-Dateien keinen Sinn, die kann man nicht ausführen.
                        iobroker fix
                        mal ausgeführt?
                          @dominic151617
                          iobroker fix
                          mal ausgeführt?
                          Dominic151617
                          @thomas-braun OK, ich glaub ich muss den das ganze Ding neu aufsetzen. Vor einer Stunde war noch alles gut. Die package-lock.json war allerdings nicht da, also dachte ich mir, ich aktualisiere einfach mal nen "unwichtigen" Beta Adapter, um zu sehen, ob die Datei wieder auftaucht. Tat sie dann ja auch. In den Admin hatte ich dann nicht mehr geschaut, da ich kurz weg musste. Jetzt wollte ich kurz noch mal den fix anstoßen und bekomme
                          root@iobroker:/opt/iobroker# iobroker fix
                          library: loaded
                          Library version=2022-06-15
                          ioBroker is not installed in /opt/iobroker! Cannot fix anything...
                          Der Admin reagiert nicht mehr:
                          Das Log sagt
                          -----                    Step 5 of 5: ioBroker startup                     -----
                          Starting ioBroker...
                          internal/modules/cjs/loader.js:905
                            throw err;
                          Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/controller.js'
                              at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
                              at Function.Module._load (internal/modules/cjs/loader.js:746:27)
                              at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
                              at internal/main/run_main_module.js:17:47 {
                            code: 'MODULE_NOT_FOUND',
                            requireStack: []
                          • D Dominic151617
                            library: loaded
                            Das Log sagt
                              throw err;
                              requireStack: []
                            GlasfaserG Offline
                            GlasfaserG Offline
                            Glasfaser
                            Hast du ioBroker vorher gestopp mit :
                            pkill -u iobroker
                            • D Dominic151617
                              library: loaded
                              Das Log sagt
                                throw err;
                                requireStack: []
                              GlasfaserG Offline
                              GlasfaserG Offline
                              Glasfaser
                              Dann nimm die neuste latest .
                              https://hub.docker.com/r/buanet/iobroker
                              Enthalten ist schon Nodejs16 , also nicht wie bei dir noch die 14
                                Dominic151617
                                @glasfaser Jup. Das wird nichts mehr. Unter /opt/iobroker/node_modules ist kein einziger iobroker.* Ordner mehr zu finden. Keine Ahnung...
                                Trotzdem allen vielen Dank für die Unterstützung.
                                Ich hoffe jetzt nur, dass der Fehler nicht irgendwie Backup steckt🥴
                                • D Dominic151617
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  Glasfaser
                                  Wird es nicht !
                                  solange du über
                                  iobroker backup
                                  oder dem BackitUp Adapter ein vernünftiges Backup hast .
                                  Und kein Container Full Backup oder sonst was noch nimmst
                                  • D Dominic151617
                                    @andygr42 OK, also den Adapter installieren und dann den Docker mit dem installierten Adapter neu ablegen. Richtig?
                                    Allerdings habe ich ja den Ordner /opt/iobroker auf die Festplatte des NAS umgeleitet. Installiert ist das ganze nach der Anleitung von https://smarthome.buanet.de/. Der Container läuft jetzt auch schon ne ganze Weile ohne Probleme.
                                    Ich habe grad auch noch mal im Filemanager der Synology nachgesehen. Wenn ich Admin update habe ich unter /node_modules/iobroker.admin die Dateien package.json und io-package.json. In beiden ist die Version 6.2.17 angeben. Die Datei package.json im Stammordner (müsste dann ja /opt/iobroker im Container sein) wird aber nicht angepasst.
                                    Jetzt habe ich RssFeed installiert und die package.json wurde wieder überschrieben. Der Timecode passt zur RssFeed Installation. io-package.json hat ein Änderungsdatum aus 1985.
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    Glasfaser
                                    Und bitte ... nicht mit dem Syn Filemanager etwas dazu machen oder ändern .
                                    Schauen kannst du damit , mehr nicht damit machen !
                                      Wird es nicht !
                                      solange du über
                                      iobroker backup
                                      Dominic151617
                                      @glasfaser Ich werde es mit dem automatischen BackitUp Backup von heute Nacht versuchen.
                                      Mein Plan sieht jetzt so aus:
                                      • Container stoppen
                                      • alten Order auf der Synology umbenennen
                                      • Neuen Ordner erstellen
                                      • Im Portainer-Stack das Image von buanet/iobroker:latest-v6 auf buanet/iobroker:latest-v7 ändern
                                      • Deploy
                                      • Update einspielen
                                      • beten😉
                                      • D Dominic151617
                                        • Container stoppen
                                        • Deploy
                                        • Update einspielen
                                        • beten😉
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        Glasfaser
                                        Deploy
                                        Update einspielen
                                        beten
                                        Würde so machen
                                        • Deploy
                                        • ioBroker/Container starten
                                        • ioBroker kurz einrichten und VIS 1.4.15 installieren
                                        • BackitUp Adapter aktualisieren
                                        • dann das Backup über BackitUp einspielen.
                                          Deploy
                                          Update einspielen
                                          beten
                                          Würde so machen
                                          • Deploy
                                          Dominic151617
                                          dann das Backup über Backitup einspielen.
                                          Als kleine Ergänzung für alle Deppen wie mich. Um den Adapter Visualisierung (wird bei der Suche nicht unter vis gefunden) zu installieren, muss man erst den Adapter Web installieren und dann noch mal nach Adapterupdates suchen.
