  4. *gelöst* Docker: Updates verschwinden immer wieder
    6.8k
49 Beiträge 5 Kommentatoren 5.6k Aufrufe 5 Beobachtet
  • D Dominic151617
    @glasfaser Vorweg Danke!
    root@iobroker:/opt/iobroker# npm ls | grep -E 'github.com|ERR'
    npm ERR! missing: iobroker.rssfeed@1.0.0, required by iobroker.inst@3.0.0
    npm ERR! peer dep missing: buffer@>=6.0.3, required by crc@4.1.1
    npm ERR! missing: ejs@3.1.6, required by iobroker.rssfeed@1.0.0
    npm ERR! missing: iconv-lite@0.5.2, required by iobroker.rssfeed@1.0.0
    npm ERR! missing: jake@10.8.2, required by ejs@3.1.6
    npm ERR! missing: filelist@1.0.2, required by jake@10.8.2
    npm ERR! missing: async@0.9.2, required by jake@10.8.2
    │ └─┬ syno@3.0.0 (git+https://github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
    root@iobroker:/opt/iobroker# iobroker update -i
    Adapter    "admin"        : 6.2.17   , installed 5.3.8  [Updatable]
    Adapter    "artnet"       : 1.2.2    , installed 1.2.2
    Adapter    "backitup"     : 2.4.10   , installed 2.4.10
    Adapter    "bring"        : 1.8.1    , installed 1.8.1
    Adapter    "daswetter"    : 3.1.2    , installed 3.1.2
    Adapter    "devices"      : 1.0.12   , installed 1.0.12
    Adapter    "discovery"    : 3.0.5    , installed 3.0.5
    Adapter    "dwd"          : 2.8.3    , installed 2.8.3
    Adapter    "flot"         : 1.11.0   , installed 1.11.0
    Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
    Adapter    "ical"         : 1.13.1   , installed 1.13.1
    Adapter    "influxdb"     : 3.1.7    , installed 3.1.7
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "iogopro"      : 0.2.6    , installed 0.2.6
    Adapter    "jarvis"       : 3.0.11   , installed 3.0.11
    Adapter    "javascript"   : 6.0.0    , installed 5.7.0  [Updatable]
    Controller "js-controller": 4.0.23   , installed 4.0.21 [Updatable]
    Adapter    "kodi"         : 2.0.8    , installed 2.0.8
    Adapter    "lovelace"     : 2.2.0    , installed 2.2.0
    Adapter    "modbus"       : 5.0.4    , installed 5.0.4
    Adapter    "node-red"     : 3.3.1    , installed 3.3.1
    Adapter    "onvif"        : 0.4.4    , installed 0.4.4
    Adapter    "paw"          : 0.3.2    , installed 0.3.2
    Adapter    "pushover"     : 3.0.2    , installed 3.0.2
    Adapter    "rssfeed"      : 2.6.1    , installed 2.6.1
    Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
    Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
    Adapter    "snmp"         : 1.0.0    , installed 1.0.0
    Adapter    "sql"          : 2.1.7    , installed 2.1.7
    Adapter    "synology"     : 2.1.9    , installed 2.1.9
    Adapter    "terminal"     : 0.2.6    , installed 0.2.6
    Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
    Adapter    "vis-lcars"    : 1.0.4    , installed 1.0.4
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-timeandweather": 1.2.2, installed 1.1.7 [Updatable]
    Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
    Adapter    "yr"           : 5.3.0    , installed 5.3.0
    Adapter    "zigbee"       : 1.7.5    , installed 1.7.5
    root@iobroker:/opt/iobroker# sudo ln -s /usr/bin/node /usr/bin/nodejs
    Sprich, da kommt keine Ausgabe.
    root@iobroker:/opt/iobroker# uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    x86_64
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v14.20.0
    v14.20.0
    6.14.17
    root
    /opt/iobroker
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 https://deb.nodesource.com/node_14.x bullseye InRelease
    Reading package lists... Done
    All packages are up to date.
    nodejs:
      Installed: 14.20.0-deb-1nodesource1
      Candidate: 14.20.0-deb-1nodesource1
      Version table:
     *** 14.20.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_14.x bullseye/main amd64 Packages
         12.22.12~dfsg-1~deb11u1 500
            500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
         12.22.5~dfsg-2~11u1 500
            500 http://deb.debian.org/debian bullseye/main amd64 Packages
    GlasfaserG Offline
    GlasfaserG Offline
    @dominic151617
    mache mal .. und auch zeigen
    iobroker upgrade admin@6.2.17 --debug
    dann
    iobroker update -i
      @dominic151617 sagte in Docker: Updates verschwinden immer wieder:
      Irgendwer ne Idee? Lösungsvorschläge?
      und was siehst du wenn du das machst was in der Meldung steht?
      Dominic151617
      @homoran sagte in Docker: Updates verschwinden immer wieder:
      Dann sehen ich, dass ich überfordert bin😂 Da gibt es unter Firefox diverse Tabs mit Diversen Infos. Hast Du nen Tipp, in welche Richtung ich suchen muss?
      Ich würde aber mittlerweile Darauf tippen, dass die Fehlermeldung ein Symptom ist. Es läuft ja der Admin 6 Adapter aber unter iobroker/node_modules/iobroker.admin liegen wieder die Dateien vom Admin 5 Adapter.
      • D Dominic151617
        GlasfaserG Offline
        GlasfaserG Offline
        @dominic151617
        Zeige erstmal was kommt mit meiner Anfrage oben .
        dann machen wir weiter
        • D Dominic151617
          GlasfaserG Offline
          GlasfaserG Offline
          Dann passt das aber nicht !
          Und danach war Admin 5.3.8 zurück.
          • GlasfaserG Glasfaser
            @dominic151617
            Dominic151617
            @glasfaser
            root@iobroker:/opt/iobroker# iobroker upgrade admin@6.2.17 --debug
            This upgrade of "admin" will at least introduce the following changes:
            -> 6.2.17:
            Corrected GUI bug on intro tab
            -> 6.2.16:
            Corrected many GUI issues
            Added `stable` flag for repositories
            Added reset button for repositories
            Improved `writeFile` function for socket communication
            -> 6.2.14:
            Fix for OAuth2 authentication response success page
            -> 6.2.13:
            Corrected JSON config
            -> 6.2.12:
            Corrected the Text input field in JSON configuration
            -> 6.2.6:
            Implemented Oauth2 workflow for adapters
            Corrected encrypt/decrypt functions
            -> 6.2.4:
            Corrected yahka settings
            BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
            Would you like to upgrade admin from @5.3.8 to @6.2.17 now? [(y)es, (n)o]: y
            Update admin from @5.3.8 to @6.2.17
            host.iobroker Adapter "system.adapter.admin.0" is stopped.
            NPM version: 6.14.17
            Installing iobroker.admin@6.2.17... (System call)
            npm WARN saveError EACCES: permission denied, open '/opt/iobroker/package.json.1595669206'
            npm WARN saveError EACCES: permission denied, open '/opt/iobroker/package-lock.json.1033087263'
            npm WARN crc@4.1.1 requires a peer of buffer@>=6.0.3 but none is installed. You must install peer dependencies yourself.
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
            + iobroker.admin@6.2.17
            added 31 packages from 27 contributors, removed 6 packages and updated 8 packages in 81.994s
            180 packages are looking for funding
              run `npm fund` for details
            upload [51] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
            upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js custom/customComponents.js application/javascript
            upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/ru.json custom/i18n/ru.json application/json
            upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js application/javascript
            upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js application/javascript
            upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map application/json
            upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js application/javascript
            upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map application/json
            upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js application/javascript
            upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map application/json
            upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js application/javascript
            upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map application/json
            upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js application/javascript
            upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
            upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
            upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
            upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
            upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
            upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
            upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
            upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
            upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
            upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
            upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
            upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
            host.iobroker Adapter "system.adapter.admin.0" is started
            Adapter    "admin"        : 6.2.17   , installed 6.2.17
            Adapter    "rssfeed"      : 2.6.1    , installed 1.0.0  [Updatable]
            • D Dominic151617
              @glasfaser
              -> 6.2.17:
              -> 6.2.16:
              -> 6.2.14:
              -> 6.2.13:
              -> 6.2.12:
              -> 6.2.6:
              -> 6.2.4:
              GlasfaserG Offline
              GlasfaserG Offline
              Und jetzt sollte nach deinem Container Neustart wieder 5.3.8 kommen !?
              Teste mal
                Teste mal
                GlasfaserG Offline
                GlasfaserG Offline
                @glasfaser
                Stop Fehler gefunden !
                • D Dominic151617
                  @glasfaser
                  -> 6.2.17:
                  -> 6.2.16:
                  -> 6.2.14:
                  -> 6.2.13:
                  -> 6.2.12:
                  -> 6.2.6:
                  -> 6.2.4:
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @dominic151617
                  pkill -u iobroker
                  rm /opt/iobroker/package*
                  Wichtig dann Container neustarten
                  iobroker update -i
                  iobroker upgrade all
                    @glasfaser
                    Dominic151617
                    @glasfaser
                    Fehler kommt schon früher
                    root@iobroker:/opt/iobroker# iobroker upgrade rssfeed@2.6.1 --debug
                    This upgrade of "rssfeed" will at least introduce the following changes:
                    -> 2.6.1:
                    add more informations to sentry
                    -> 2.6.0:
                    add sentry
                    -> 2.5.0:
                    add name option to widget marquee
                    -> 2.0.0:
                    Basic overhaul
                    Would you like to upgrade rssfeed from @1.0.0 to @2.6.1 now? [(y)es, (n)o]: y
                    Update rssfeed from @1.0.0 to @2.6.1
                    Installing iobroker.rssfeed@2.6.1... (System call)
                    npm WARN saveError EACCES: permission denied, open '/opt/iobroker/package.json.1120760129'
                    npm WARN saveError EACCES: permission denied, open '/opt/iobroker/package-lock.json.770259360'
                    + iobroker.rssfeed@2.6.1
                    added 6 packages from 4 contributors, removed 31 packages and updated 8 packages in 48.816s
                    179 packages are looking for funding
                    upload [13] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/build/index.css build/index.css text/css
                    upload [12] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/build/index.js build/index.js application/javascript
                    upload [11] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/i18n/de.json i18n/de.json application/json
                    upload [10] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/i18n/en.json i18n/en.json application/json
                    upload [9] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/i18n/es.json i18n/es.json application/json
                    upload [8] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/i18n/fr.json i18n/fr.json application/json
                    upload [7] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/i18n/it.json i18n/it.json application/json
                    upload [6] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/i18n/nl.json i18n/nl.json application/json
                    upload [5] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/i18n/pl.json i18n/pl.json application/json
                    upload [4] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/i18n/pt.json i18n/pt.json application/json
                    upload [3] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/i18n/ru.json i18n/ru.json application/json
                    upload [2] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/i18n/zh-cn.json i18n/zh-cn.json application/json
                    upload [1] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/jsonConfig.json jsonConfig.json application/json
                    upload [0] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/rssfeed-logo.png rssfeed-logo.png image/png
                    • D Dominic151617
                      @glasfaser
                      -> 2.6.1:
                      -> 2.6.0:
                      add sentry
                      -> 2.5.0:
                      -> 2.0.0:
                      Basic overhaul
                      GlasfaserG Offline
                      GlasfaserG Offline
                      Warte auf mich ... nicht quer installieren
                      bitte das oben machen !
                      • D Dominic151617
                        @glasfaser
                        -> 2.6.1:
                        -> 2.6.0:
                        add sentry
                        -> 2.5.0:
                        -> 2.0.0:
                        Basic overhaul
                        GlasfaserG Offline
                        GlasfaserG Offline
                        @dominic151617
                        hier ist der Fehler :
                          Dominic151617
                          @glasfaser sagte in Docker: Updates verschwinden immer wieder:
                          Sorry, ich bin langsamer als Du. Daher hängen meine Nachrichten nach🤦‍♂️ Arbeite grade deine letzten Anweisungen ab.
                            @dominic151617
                            pkill -u iobroker
                            iobroker update -i
                            Dominic151617
                            @glasfaser Vielen, Vielen Dank! Scheint wieder zu funktionieren. Wenn man Ahnung hat, hilft das wohl eindeutig weiter😉
                            Ich nehme dann auch noch mit: Die Datei /opt/iobroker/package.json existiert reguläre nicht. Zumindest gibt es sie jetzt nicht mehr.
                            Die Logs spare ich mir dann in diesem Auszug mal.
                            • D Dominic151617
                              GlasfaserG Offline
                              GlasfaserG Offline
                              sie wurde neu erstellt .
                              package.json
                              inkl.
                              package-lock.json
                              ohne den gedöns dahinter und permission denied
                              • A AndyGR42
                                @dominic151617 Könnte helfen:
                                https://docs.docker.com/engine/reference/commandline/commit/
                                GlasfaserG Offline
                                GlasfaserG Offline
                                @andygr42 sagte in Docker: Updates verschwinden immer wieder:
                                Es hatte sich die Datei /opt/iobroker/packages.json eingenistet und blockierte anscheinend die updates.
                                FALSCH
                                siehe über meinen Beitrag .
                                  FALSCH
                                  Dominic151617
                                  FALSCH
                                  OK. Ich korrigiere das. Dummerweise:
                                  root@iobroker:/opt/iobroker# ls
                                  backups  INSTALLER_INFO.txt  iob  iobroker  iobroker.bak  iobroker-data  log  node_modules
                                  die Dateien wurden nicht neu erstellt. Die sind jetzt einfach nicht mehr da🤪 Ich vermute, da scheinen sich die Ordnerberechtigungen irgendwie quer gelegt zu haben. Mist
                                  • D Dominic151617
                                    FALSCH
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    @dominic151617 sagte in *gelöst* Docker: Updates verschwinden immer wieder:
                                    Dann stimmt etwas nicht .. beide Dateien sollten sichtbar / erstellt sein .
                                    Hast du den Container nochmal neu gestartet bzw. starte Ihn neu
                                    und zeige nochmal mit :
                                    ls -la
                                    deine gesamte Ausgabe davon.
                                    sollte so dann "gekürzt" so aussehen
                                    -rw-rwxr-- 1 iobroker iobroker 3,2K Aug 21 18:11 package.json
                                    -rw-rwxr-- 1 iobroker iobroker 1,4M Aug 21 18:11 package-lock.json
                                    Was mich auch Wundert an deiner Angabe :
                                    Hast du mal was dazu selber geändert !?
                                      ls -la
                                      Dominic151617
                                      Ich, nein. Das kann gar nicht sein. Ich tut sowas doch nicht😤 Ne, jetzt mal im ernst. Bewusst habe ich das nicht getan. Ich würde aber lügen, wenn ich es ausschließen würde.
                                      Zumindest jetzt kann ich es auch nicht mehr verneinen, da ich aus der Synology raus den User iobroker mit Rechten ausgestattet habe. Jetzt geht es zumindest:
                                      -rwxrwxr-x 1 iobroker iobroker    133 Aug 25 15:43 package.json
                                      -rwxrwxr-x 1 iobroker iobroker 129372 Aug 25 15:43 package-lock.json
                                      Allerdings sehe ich da zwei "x"e mehr als bei Dir. Ich hoffe mal, dass fällt mir nicht irgendwann auf die Füße...
                                      • D Dominic151617
                                        @dominic151617
                                        x als Recht macht bei json-Dateien keinen Sinn, die kann man nicht ausführen.
                                        iobroker fix
                                        mal ausgeführt?
                                          @dominic151617
                                          iobroker fix
                                          mal ausgeführt?
                                          Dominic151617
                                          @thomas-braun OK, ich glaub ich muss den das ganze Ding neu aufsetzen. Vor einer Stunde war noch alles gut. Die package-lock.json war allerdings nicht da, also dachte ich mir, ich aktualisiere einfach mal nen "unwichtigen" Beta Adapter, um zu sehen, ob die Datei wieder auftaucht. Tat sie dann ja auch. In den Admin hatte ich dann nicht mehr geschaut, da ich kurz weg musste. Jetzt wollte ich kurz noch mal den fix anstoßen und bekomme
                                          root@iobroker:/opt/iobroker# iobroker fix
                                          library: loaded
                                          Library version=2022-06-15
                                          ioBroker is not installed in /opt/iobroker! Cannot fix anything...
                                          Der Admin reagiert nicht mehr:
                                          Das Log sagt
                                          -----                    Step 5 of 5: ioBroker startup                     -----
                                          Starting ioBroker...
                                          internal/modules/cjs/loader.js:905
                                            throw err;
                                          Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/controller.js'
                                              at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
                                              at Function.Module._load (internal/modules/cjs/loader.js:746:27)
                                              at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
                                              at internal/main/run_main_module.js:17:47 {
                                            code: 'MODULE_NOT_FOUND',
                                            requireStack: []
