  4. *gelöst* Docker: Updates verschwinden immer wieder
    6.8k
49 Beiträge 5 Kommentatoren 5.6k Aufrufe 5 Beobachtet
  • GlasfaserG Glasfaser
    @dominic151617 sagte in Docker: Updates verschwinden immer wieder:
    Adapter "admin" : 6.2.17 , installed 6.2.17
    Und jetzt sollte nach deinem Container Neustart wieder 5.3.8 kommen !?
    Teste mal
    GlasfaserG Offline
    GlasfaserG Offline
    @glasfaser
    Stop Fehler gefunden !
    • D Dominic151617
      @glasfaser
      root@iobroker:/opt/iobroker# iobroker upgrade admin@6.2.17 --debug
      This upgrade of "admin" will at least introduce the following changes:
      -> 6.2.17:
      Corrected GUI bug on intro tab
      -> 6.2.16:
      Corrected many GUI issues
      Added `stable` flag for repositories
      Added reset button for repositories
      Improved `writeFile` function for socket communication
      -> 6.2.14:
      Fix for OAuth2 authentication response success page
      -> 6.2.13:
      Corrected JSON config
      -> 6.2.12:
      Corrected the Text input field in JSON configuration
      -> 6.2.6:
      Implemented Oauth2 workflow for adapters
      Corrected encrypt/decrypt functions
      -> 6.2.4:
      Corrected yahka settings
      BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
      Would you like to upgrade admin from @5.3.8 to @6.2.17 now? [(y)es, (n)o]: y
      Update admin from @5.3.8 to @6.2.17
      host.iobroker Adapter "system.adapter.admin.0" is stopped.
      NPM version: 6.14.17
      Installing iobroker.admin@6.2.17... (System call)
      npm WARN saveError EACCES: permission denied, open '/opt/iobroker/package.json.1595669206'
      npm WARN saveError EACCES: permission denied, open '/opt/iobroker/package-lock.json.1033087263'
      npm WARN crc@4.1.1 requires a peer of buffer@>=6.0.3 but none is installed. You must install peer dependencies yourself.
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      + iobroker.admin@6.2.17
      added 31 packages from 27 contributors, removed 6 packages and updated 8 packages in 81.994s
      180 packages are looking for funding
        run `npm fund` for details
      upload [51] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
      upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js custom/customComponents.js application/javascript
      upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/ru.json custom/i18n/ru.json application/json
      upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js application/javascript
      upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js application/javascript
      upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map application/json
      upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js application/javascript
      upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map application/json
      upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js application/javascript
      upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map application/json
      upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js application/javascript
      upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map application/json
      upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js application/javascript
      upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
      upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
      host.iobroker Adapter "system.adapter.admin.0" is started
      root@iobroker:/opt/iobroker# iobroker update -i
      Adapter    "artnet"       : 1.2.2    , installed 1.2.2
      Adapter    "backitup"     : 2.4.10   , installed 2.4.10
      Adapter    "bring"        : 1.8.1    , installed 1.8.1
      Adapter    "daswetter"    : 3.1.2    , installed 3.1.2
      Adapter    "devices"      : 1.0.12   , installed 1.0.12
      Adapter    "discovery"    : 3.0.5    , installed 3.0.5
      Adapter    "dwd"          : 2.8.3    , installed 2.8.3
      Adapter    "flot"         : 1.11.0   , installed 1.11.0
      Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
      Adapter    "ical"         : 1.13.1   , installed 1.13.1
      Adapter    "influxdb"     : 3.1.7    , installed 3.1.7
      Adapter    "info"         : 1.9.19   , installed 1.9.19
      Adapter    "iogopro"      : 0.2.6    , installed 0.2.6
      Adapter    "jarvis"       : 3.0.11   , installed 3.0.11
      Adapter    "javascript"   : 6.0.0    , installed 5.7.0  [Updatable]
      Controller "js-controller": 4.0.23   , installed 4.0.21 [Updatable]
      Adapter    "kodi"         : 2.0.8    , installed 2.0.8
      Adapter    "lovelace"     : 2.2.0    , installed 2.2.0
      Adapter    "modbus"       : 5.0.4    , installed 5.0.4
      Adapter    "node-red"     : 3.3.1    , installed 3.3.1
      Adapter    "onvif"        : 0.4.4    , installed 0.4.4
      Adapter    "paw"          : 0.3.2    , installed 0.3.2
      Adapter    "pushover"     : 3.0.2    , installed 3.0.2
      Adapter    "rssfeed"      : 2.6.1    , installed 1.0.0  [Updatable]
      Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
      Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
      Adapter    "snmp"         : 1.0.0    , installed 1.0.0
      Adapter    "sql"          : 2.1.7    , installed 2.1.7
      Adapter    "synology"     : 2.1.9    , installed 2.1.9
      Adapter    "terminal"     : 0.2.6    , installed 0.2.6
      Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
      Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
      Adapter    "vis-lcars"    : 1.0.4    , installed 1.0.4
      Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
      Adapter    "vis-timeandweather": 1.2.2, installed 1.1.7 [Updatable]
      Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
      Adapter    "yr"           : 5.3.0    , installed 5.3.0
      Adapter    "zigbee"       : 1.7.5    , installed 1.7.5
      GlasfaserG Offline
      GlasfaserG Offline
      @dominic151617
      pkill -u iobroker
      rm /opt/iobroker/package*
      Wichtig dann Container neustarten
      iobroker update -i
      iobroker upgrade all
        @glasfaser
        Dominic151617
        @glasfaser
        Fehler kommt schon früher
        root@iobroker:/opt/iobroker# iobroker upgrade rssfeed@2.6.1 --debug
        This upgrade of "rssfeed" will at least introduce the following changes:
        -> 2.6.1:
        add more informations to sentry
        -> 2.6.0:
        add sentry
        -> 2.5.0:
        add name option to widget marquee
        -> 2.0.0:
        Basic overhaul
        Would you like to upgrade rssfeed from @1.0.0 to @2.6.1 now? [(y)es, (n)o]: y
        Update rssfeed from @1.0.0 to @2.6.1
        Installing iobroker.rssfeed@2.6.1... (System call)
        npm WARN saveError EACCES: permission denied, open '/opt/iobroker/package.json.1120760129'
        npm WARN saveError EACCES: permission denied, open '/opt/iobroker/package-lock.json.770259360'
        + iobroker.rssfeed@2.6.1
        added 6 packages from 4 contributors, removed 31 packages and updated 8 packages in 48.816s
        179 packages are looking for funding
        upload [13] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/build/index.css build/index.css text/css
        upload [12] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/build/index.js build/index.js application/javascript
        upload [11] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/i18n/de.json i18n/de.json application/json
        upload [10] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/i18n/en.json i18n/en.json application/json
        upload [9] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/i18n/es.json i18n/es.json application/json
        upload [8] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/i18n/fr.json i18n/fr.json application/json
        upload [7] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/i18n/it.json i18n/it.json application/json
        upload [6] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/i18n/nl.json i18n/nl.json application/json
        upload [5] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/i18n/pl.json i18n/pl.json application/json
        upload [4] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/i18n/pt.json i18n/pt.json application/json
        upload [3] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/i18n/ru.json i18n/ru.json application/json
        upload [2] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/i18n/zh-cn.json i18n/zh-cn.json application/json
        upload [1] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/jsonConfig.json jsonConfig.json application/json
        upload [0] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/rssfeed-logo.png rssfeed-logo.png image/png
        Adapter    "admin"        : 6.2.17   , installed 5.3.8  [Updatable]
        Adapter    "rssfeed"      : 2.6.1    , installed 2.6.1
        • D Dominic151617
          @glasfaser
          -> 2.6.1:
          -> 2.6.0:
          add sentry
          -> 2.5.0:
          -> 2.0.0:
          Basic overhaul
          GlasfaserG Offline
          GlasfaserG Offline
          Warte auf mich ... nicht quer installieren
          bitte das oben machen !
          • D Dominic151617
            @glasfaser
            -> 2.6.1:
            -> 2.6.0:
            add sentry
            -> 2.5.0:
            -> 2.0.0:
            Basic overhaul
            GlasfaserG Offline
            GlasfaserG Offline
            @dominic151617
            hier ist der Fehler :
              Dominic151617
              @glasfaser sagte in Docker: Updates verschwinden immer wieder:
              Sorry, ich bin langsamer als Du. Daher hängen meine Nachrichten nach🤦‍♂️ Arbeite grade deine letzten Anweisungen ab.
                @dominic151617
                pkill -u iobroker
                iobroker update -i
                Dominic151617
                @glasfaser Vielen, Vielen Dank! Scheint wieder zu funktionieren. Wenn man Ahnung hat, hilft das wohl eindeutig weiter😉
                Ich nehme dann auch noch mit: Die Datei /opt/iobroker/package.json existiert reguläre nicht. Zumindest gibt es sie jetzt nicht mehr.
                Die Logs spare ich mir dann in diesem Auszug mal.
                • D Dominic151617
                  GlasfaserG Offline
                  GlasfaserG Offline
                  sie wurde neu erstellt .
                  package.json
                  inkl.
                  package-lock.json
                  ohne den gedöns dahinter und permission denied
                  • A AndyGR42
                    @dominic151617 Könnte helfen:
                    https://docs.docker.com/engine/reference/commandline/commit/
                    GlasfaserG Offline
                    GlasfaserG Offline
                    @andygr42 sagte in Docker: Updates verschwinden immer wieder:
                    Es hatte sich die Datei /opt/iobroker/packages.json eingenistet und blockierte anscheinend die updates.
                    FALSCH
                    siehe über meinen Beitrag .
                      FALSCH
                      Dominic151617
                      FALSCH
                      OK. Ich korrigiere das. Dummerweise:
                      root@iobroker:/opt/iobroker# ls
                      backups  INSTALLER_INFO.txt  iob  iobroker  iobroker.bak  iobroker-data  log  node_modules
                      die Dateien wurden nicht neu erstellt. Die sind jetzt einfach nicht mehr da🤪 Ich vermute, da scheinen sich die Ordnerberechtigungen irgendwie quer gelegt zu haben. Mist
                      • D Dominic151617
                        FALSCH
                        GlasfaserG Offline
                        GlasfaserG Offline
                        @dominic151617 sagte in *gelöst* Docker: Updates verschwinden immer wieder:
                        Dann stimmt etwas nicht .. beide Dateien sollten sichtbar / erstellt sein .
                        Hast du den Container nochmal neu gestartet bzw. starte Ihn neu
                        und zeige nochmal mit :
                        ls -la
                        deine gesamte Ausgabe davon.
                        sollte so dann "gekürzt" so aussehen
                        -rw-rwxr-- 1 iobroker iobroker 3,2K Aug 21 18:11 package.json
                        -rw-rwxr-- 1 iobroker iobroker 1,4M Aug 21 18:11 package-lock.json
                        Was mich auch Wundert an deiner Angabe :
                        Hast du mal was dazu selber geändert !?
                          ls -la
                          Dominic151617
                          Ich, nein. Das kann gar nicht sein. Ich tut sowas doch nicht😤 Ne, jetzt mal im ernst. Bewusst habe ich das nicht getan. Ich würde aber lügen, wenn ich es ausschließen würde.
                          Zumindest jetzt kann ich es auch nicht mehr verneinen, da ich aus der Synology raus den User iobroker mit Rechten ausgestattet habe. Jetzt geht es zumindest:
                          -rwxrwxr-x 1 iobroker iobroker    133 Aug 25 15:43 package.json
                          -rwxrwxr-x 1 iobroker iobroker 129372 Aug 25 15:43 package-lock.json
                          Allerdings sehe ich da zwei "x"e mehr als bei Dir. Ich hoffe mal, dass fällt mir nicht irgendwann auf die Füße...
                          • D Dominic151617
                            @dominic151617
                            x als Recht macht bei json-Dateien keinen Sinn, die kann man nicht ausführen.
                            iobroker fix
                            mal ausgeführt?
                              @dominic151617
                              iobroker fix
                              mal ausgeführt?
                              Dominic151617
                              @thomas-braun OK, ich glaub ich muss den das ganze Ding neu aufsetzen. Vor einer Stunde war noch alles gut. Die package-lock.json war allerdings nicht da, also dachte ich mir, ich aktualisiere einfach mal nen "unwichtigen" Beta Adapter, um zu sehen, ob die Datei wieder auftaucht. Tat sie dann ja auch. In den Admin hatte ich dann nicht mehr geschaut, da ich kurz weg musste. Jetzt wollte ich kurz noch mal den fix anstoßen und bekomme
                              root@iobroker:/opt/iobroker# iobroker fix
                              library: loaded
                              Library version=2022-06-15
                              ioBroker is not installed in /opt/iobroker! Cannot fix anything...
                              Der Admin reagiert nicht mehr:
                              Das Log sagt
                              -----                    Step 5 of 5: ioBroker startup                     -----
                              Starting ioBroker...
                              internal/modules/cjs/loader.js:905
                                throw err;
                              Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/controller.js'
                                  at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
                                  at Function.Module._load (internal/modules/cjs/loader.js:746:27)
                                  at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
                                  at internal/main/run_main_module.js:17:47 {
                                code: 'MODULE_NOT_FOUND',
                                requireStack: []
                              • D Dominic151617
                                library: loaded
                                Das Log sagt
                                  throw err;
                                  requireStack: []
                                GlasfaserG Offline
                                GlasfaserG Offline
                                Hast du ioBroker vorher gestopp mit :
                                pkill -u iobroker
                                • D Dominic151617
                                  library: loaded
                                  Das Log sagt
                                    throw err;
                                    requireStack: []
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  Dann nimm die neuste latest .
                                  https://hub.docker.com/r/buanet/iobroker
                                  Enthalten ist schon Nodejs16 , also nicht wie bei dir noch die 14
                                    Dominic151617
                                    @glasfaser Jup. Das wird nichts mehr. Unter /opt/iobroker/node_modules ist kein einziger iobroker.* Ordner mehr zu finden. Keine Ahnung...
                                    Trotzdem allen vielen Dank für die Unterstützung.
                                    Ich hoffe jetzt nur, dass der Fehler nicht irgendwie Backup steckt🥴
                                    • D Dominic151617
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      Wird es nicht !
                                      solange du über
                                      iobroker backup
                                      oder dem BackitUp Adapter ein vernünftiges Backup hast .
                                      Und kein Container Full Backup oder sonst was noch nimmst
                                      • D Dominic151617
                                        @andygr42 OK, also den Adapter installieren und dann den Docker mit dem installierten Adapter neu ablegen. Richtig?
                                        Allerdings habe ich ja den Ordner /opt/iobroker auf die Festplatte des NAS umgeleitet. Installiert ist das ganze nach der Anleitung von https://smarthome.buanet.de/. Der Container läuft jetzt auch schon ne ganze Weile ohne Probleme.
                                        Ich habe grad auch noch mal im Filemanager der Synology nachgesehen. Wenn ich Admin update habe ich unter /node_modules/iobroker.admin die Dateien package.json und io-package.json. In beiden ist die Version 6.2.17 angeben. Die Datei package.json im Stammordner (müsste dann ja /opt/iobroker im Container sein) wird aber nicht angepasst.
                                        Jetzt habe ich RssFeed installiert und die package.json wurde wieder überschrieben. Der Timecode passt zur RssFeed Installation. io-package.json hat ein Änderungsdatum aus 1985.
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        Und bitte ... nicht mit dem Syn Filemanager etwas dazu machen oder ändern .
                                        Schauen kannst du damit , mehr nicht damit machen !
                                          Wird es nicht !
                                          solange du über
                                          iobroker backup
                                          Dominic151617
                                          @glasfaser Ich werde es mit dem automatischen BackitUp Backup von heute Nacht versuchen.
                                          Mein Plan sieht jetzt so aus:
                                          • Container stoppen
                                          • alten Order auf der Synology umbenennen
                                          • Neuen Ordner erstellen
                                          • Im Portainer-Stack das Image von buanet/iobroker:latest-v6 auf buanet/iobroker:latest-v7 ändern
                                          • Deploy
                                          • Update einspielen
                                          • beten😉
