  4. Keine Verbindung zu Shelly
    5.7k
36 Beiträge 7 Kommentatoren 4.8k Aufrufe 6 Beobachtet
  • P Phinix
    @djmarc75 Ja, ich habe zum Testen gerade eine zweite Instanz installiert. Die Shelly.0 habe ich auf MQTT umgestellt damit die anderen Shellys im Netzwerk funktionieren.
    Shelly.1-Instanz läuft auf COaP.
    mcast und http-Kennwort habe ich geändert, klappt aber leider noch immer nicht.
    shelly.1
    2022-08-15 21:04:57.506	debug	CoAP device description request for SHSW-1#E8DB84D253EC#2 to 192.168.1.200(1)
    shelly.1
    2022-08-15 21:04:55.505	debug	CoAP device description request for SHSW-1#E8DB84D253EC#2 to 192.168.1.200(0)
    shelly.1
    2022-08-15 21:04:55.505	debug	[CoAP Server] Status update received for SHSW-1#E8DB84D253EC#2: {"G":[[0,9103,0],[0,1101,0],[0,2101,0],[0,2102,""],[0,2103,0]]}
    shelly.1
    2022-08-15 21:04:55.504	debug	CoAP status package received: {"3332":"SHSW-1#E8DB84D253EC#2","3412":38400,"3420":256,"Uri-Path":"cit/s"} / {"G":[[0,9103,0],[0,1101,0],[0,2101,0],[0,2102,""],[0,2103,0]]}
    shelly.1
    2022-08-15 21:04:49.549	debug	[CoAP Server] Error - handling data: Error: No reply in 247 seconds.
    shelly.1
    2022-08-15 21:04:47.548	debug	[CoAP Server] Error - handling data: Error: No reply in 247 seconds.
    shelly.1
    2022-08-15 21:04:45.547	debug	[CoAP Server] Error - handling data: Error: No reply in 247 seconds.
    shelly.1
    2022-08-15 21:04:44.327	debug	CoAP device description request for SHSW-1#E8DB84D253EC#2 to 192.168.1.200(2)
    shelly.1
    2022-08-15 21:04:42.326	debug	CoAP device description request for SHSW-1#E8DB84D253EC#2 to 192.168.1.200(1)
    shelly.1
    2022-08-15 21:04:40.324	debug	CoAP device description request for SHSW-1#E8DB84D253EC#2 to 192.168.1.200(0)
    shelly.1
    2022-08-15 21:04:40.324	debug	[CoAP Server] Status update received for SHSW-1#E8DB84D253EC#2: {"G":[[0,9103,0],[0,1101,0],[0,2101,0],[0,2102,""],[0,2103,0]]}
    shelly.1
    2022-08-15 21:04:40.323	debug	CoAP status package received: {"3332":"SHSW-1#E8DB84D253EC#2","3412":38400,"3420":256,"Uri-Path":"cit/s"} / {"G":[[0,9103,0],[0,1101,0],[0,2101,0],[0,2102,""],[0,2103,0]]}
    DJMarc75D Offline
    DJMarc75D Offline
    DJMarc75
    @phinix
    Der zweite Adapter ist sicher auch nicht grün, oder ?
    Geht es da eigentlich um ALLE Shellys welche keine Verbindung mehr haben oder nur um einen speziellen ?
    Lehrling seit 1975 !!!
    P 1 Antwort Letzte Antwort
    • P Phinix
      shelly.1
      shelly.1
      shelly.1
      shelly.1
      shelly.1
      shelly.1
      shelly.1
      shelly.1
      shelly.1
      shelly.1
      shelly.1
      shelly.1
      crunchipC Abwesend
      crunchipC Abwesend
      @phinix multicast wird doch gar nicht mehr unterstützt wenn ich mich nicht irre, also bleibt nur unicast oder mqtt
      vllt liegt es auch an deiner Netzwerkeinstellung(Router)
      • DJMarc75D DJMarc75
        @phinix
        Phinix
        @djmarc75
        Nein, der Adapter ist gelb "Verbunden mit Gerät oder Dienst" ist nicht da.
        Es geht um alle Shellys.
        • P Phinix
          @djmarc75
          DJMarc75D Offline
          DJMarc75D Offline
          DJMarc75
          @phinix sagte in Keine Verbindung zu Shelly:
          Dann wird es u.U. an Deinem Netzwerk liegen.
          Router schonmal neu gestartet?
            Phinix
            @djmarc75
            das hatte ich befürchtet, nur in welche Richtung könnte ich da schauen?
            Ja, die Fritzbox hab ich bereits neu gestartet...
            • P Phinix
              @djmarc75
              DJMarc75D Offline
              DJMarc75D Offline
              DJMarc75
              mit Ubuntu und VMs kenn ich mich zu wenig aus aber ich halte es für möglich dass Du da wohl iwo etwas geändert haben könntest - bevor das Problem mit den Shellys aufgetaucht ist ?!
                Phinix
                @djmarc75
                Also geändert habe ich die letzten Wochen nichts, dafür war das Wetter zu schön :D Windows Server und Ubuntu Updates waren das einzige was ich gemacht habe...
                • DJMarc75D Offline
                  DJMarc75D Offline
                  DJMarc75
                  Ja das meinte ich mit "geändert" ... ich tippe da auf Windows - da wird ja öfters mal was geändert (durch updates).
                  Wie gesagt bei Ubuntu bin ich da raus und, naja, Windows Server ist auch nicht ganz so meins.
                  Muss mal eine Denkpause machen - Kopf qualmt
                    Phinix
                    @djmarc75
                    Ich denke ich werde einfach bei MQTT bleiben, den Fehler bei einem Update zu suchen wird recht schwierig.
                    Danke dir für deine Hilfe!
                    Max MeyerM 1 Antwort Letzte Antwort
                    • P Phinix
                      @djmarc75
                      Max MeyerM Offline
                      Max MeyerM Offline
                      Max Meyer
                      @phinix Ich hatte auch das Problem das Plötzlich keine Werte in den Objekten aktualisiert wurden obwohl ich nichts geändert habe. Ich hab dann alles upgedated und shelly Adapter 6 installiert. Hab auch in den shellys den Server eingetragen wie es bei Matthias in der Doku steht und npm install xml2js@0.4.19 in den beiden Verzeichnissen installiert. Hat alles nichts geholfen. Dann habe ich eine neue iobroker VM im Windows 10 Hyper-V nur mit dem shelly Adapter installiert, ging auch nicht obwohl ich eingehende udp Pakete von allen shellys sehen konnte. Dan hab ich aus Verzweiflung iobroker auf einem anderen PC installiert und schwupp alle shellys gehen. Auch wenn in den shellys multicast drin ist und nicht die IP des iobrokers. Dann hab ich in die Updates des Windows systems geguckt und dort wurden 2 Updates angezeigt die an dem Tag installiert wurden als die shellys nicht mehr funktionierten. Das deinstallieren der Updates hat aber auch nichts geholfen.
                      Ich habe dann proxmox auf einem alten NUC installiert und die iobroker VM die auf meinem Hyper-V lief und keine shelly Daten angenommen hat exportiert unf auf dem proxmox zum laufen gebracht. Siehe da die shelly Objekte wurden wieder aktualisiert. Wahrscheinlich hast du im iobroker alles richtig gemacht aber der Hyper-V haut uns dazwischen.
                      Ich wollte proxmox schon immer mal ausprobieren und das war jetzt die Gelegenheit.
                      LG Max
                      da_WoodyD P 2 Antworten Letzte Antwort
                      • Max MeyerM Max Meyer
                        LG Max
                        da_WoodyD Online
                        da_WoodyD Online
                        da_Woody
                        @max-meyer sagte in Keine Verbindung zu Shelly:
                        genau das find ich seltsam. mcast dürfte nicht mehr funktionieren.
                        das ganze wird echt seltsam. 😵
                        gruß vom Woody
                          LG Max
                          Phinix
                          @max-meyer hm sehr komisch das Hyper-V dazwischen funkt. Ich hätte jetzt eher in Richtung Fritzbox gedacht. Da die shellys aber über MQTT funktionieren, habe ich das mal so belassen.
                          Eine andere Serverhardware zum Testen habe ich allerdings nicht, bei mir läuft mein Windows Server mit allen VMs in Hyper-V. Da mir Proxmox anzufangen wäre enorm viel Arbeit.
                          ... Wie hast du es denn geschafft eine Hyper-V VM zu exportieren und in Proxmox einzubinden?
                          • P Phinix
                            Max MeyerM Offline
                            Max MeyerM Offline
                            Max Meyer
                            @phinix Ich hatte iobroker bestimmt schon mehr als ein Jahr ohne Probleme auf meinem Hyper-V laufen. Backup lief mit Veeam community Edition wunderbar und eigentlich wollte ich nicht umziehen aber ich brauche die cloud Anbindung bei einigen shellys deswegen hilft mir eine Umstellung auf mqtt nicht.
                            Mein Windows hat am Freitag Updates installiert und abends habe ich einen neuen shelly hinzugefügt und mich gewundert warum der nicht im iobroker auftaucht. Erst dann ist mir aufgefallen, dass sich die Werte der anderen shelly Objekte nicht mehr ändern. Ich habe dann die beiden Updates deinstalliert aber das hat nicht geholfen. Dann habe ich von shelly V5.3 die gut lief auf 6 upgegradet und es war einfach nicht zum laufen zu bringen. Dann mein Test mit der neuen iobroker VM im Hyper-V aber da war das gleiche Problem. Dann iobroker auf einem NUC installiert und es funktioniert.
                            Die Installation von proxmox ist n klacks und in 10 Minuten erledigt. Zum Umzug der VM musst Du die im Hyper-V exportieren (vorher alle Prüfpunkte konsolidieren) und die vhdx für den proxmox erreichbar machen. Man kann z.B. eine USB Platte nehmen. Ich habe die Datei per Winscp in das Verzeichnis /var/lib/vz/images/ hochgeladen.
                            Dann legst Du eine neue VM an mit ungefähr der gleichen Konfiguration wie im Hyper-V allerdings ohne Festplatte.
                            Es war gar nicht so leicht eine Anleitung zu finden da sich diese meist auf kleinere Versionsnummern von proxmox beziehen und die sehr viel geändert haben. Wenn Du was suchst, prüfe ob das auch für proxmox 7 ist.
                            Vor Version 7 musste man die vhdx noch konvertieren aber in Version 7 kann man die einfach importieren.
                            Bei der Anlage der VM wird eine Nummer vergeben (bei mir war es 100)
                            Dann wird die Platte einfach wie folgt importiert:
                            qm importdisk 999 /tmp/my-image.vhdx local-lvm
                            Die 999 ist die Nummer der VM dann kommt der Pfad und Name der vhdx und zuletzt der Speicherort. Bei einer Standardinstallation ist local-lvm der Datenträger auf dem die VMs liegen
                            you can directly import the vhdx files, no need to first convert to raw
                            and the <target-storage> is the storage id defined in proxmox (e.g. local or local-lvm)
                            Nach dem Import hast Du an deiner VM eine ungenutzte Festplatte die du noch als bootdevice anbinden musst.
                            Bei meinem Ubuntu musste nach dem booten noch die Netzwerkkonfig unter /etc/netplan neu gemacht werden.
                            Seit dem Umzug funktionieren meine shellys wie gewohnt.
                            Solltest Du rausfinden was beim Hyper-V dazwischen grätscht würde ich mich über eine Info freuen.
                            • Stefan PreißS Offline
                              Stefan Preiß
                              Hallo Runde,
                              ich stehe vor dem gleichen Problem. Hab auch eine VM unter Hyper-V und bekomme bei Shelly und KNX leider keine Werte mehr. Hab aber leider kein Ausweichgerät. Könnt ihr mir weiterhelfen ?
                              crunchipC da_WoodyD 2 Antworten Letzte Antwort
                              • Stefan PreißS Stefan Preiß
                                Hallo Runde,
                                crunchipC Abwesend
                                crunchipC Abwesend
                                @stefan-preiß sagte in Keine Verbindung zu Shelly:
                                • was heisst das genau,
                                • gings vorher,
                                • bist du umgezogen mit der VM?
                                • andere IP?
                                  Hallo Runde,
                                  da_WoodyD Online
                                  da_WoodyD Online
                                  da_Woody
                                  @stefan-preiß sind wir da wieder mal bei IGMP-snooping gelandet?
                                  gruß vom Woody
