  4. Canvas Installation mit Node16 auf R4 nicht möglich
    6.1k
22 Beiträge 4 Kommentatoren 2.3k Aufrufe 4 Beobachtet
  • SKBS Offline
    SKBS Offline
    SKB
    schrieb am zuletzt editiert von SKB
    könnte mir jemand bei diesem Fehler weiterhelfen?
    pi@ioBroker:/opt/iobroker $ sudo -u iobroker npm install canvas
    npm WARN skipping integrity check for git dependency ssh://git@github.com/SKB-CGN/ioBroker.wallbox.git
    npm ERR! code 1
    npm ERR! path /opt/iobroker/node_modules/canvas
    npm ERR! command failed
    npm ERR! command sh -c node-pre-gyp install --fallback-to-build --update-binary
    npm ERR! Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js clean' (1)
    npm ERR! node-pre-gyp info it worked if it ends with ok
    npm ERR! node-pre-gyp info using node-pre-gyp@1.0.9
    npm ERR! node-pre-gyp info using node@16.16.0 | linux | arm
    npm ERR! node-pre-gyp http GET https://github.com/Automattic/node-canvas/releases/download/v2.9.3/canvas-v2.9.3-node-v93-linux-glibc-arm.tar.gz
    npm ERR! node-pre-gyp ERR! install response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.9.3/canvas-v2.9.3-node-v93-linux-glibc-arm.tar.gz
    npm ERR! node-pre-gyp WARN Pre-built binaries not installable for canvas@2.9.3 and node@16.16.0 (node-v93 ABI, glibc) (falling back to source compile with node-gyp)
    npm ERR! node-pre-gyp WARN Hit error response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.9.3/canvas-v2.9.3-node-v93-linux-glibc-arm.tar.gz
    npm ERR! node:internal/modules/cjs/loader:936
    npm ERR!   throw err;
    npm ERR!   ^
    npm ERR!
    npm ERR! Error: Cannot find module 'object-assign'
    npm ERR! Require stack:
    npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/render-template.js
    npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/plumbing.js
    npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/index.js
    npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/npmlog/log.js
    npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/lib/node-gyp.js
    npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js
    npm ERR!     at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
    npm ERR!     at Function.Module._load (node:internal/modules/cjs/loader:778:27)
    npm ERR!     at Module.require (node:internal/modules/cjs/loader:1005:19)
    npm ERR!     at require (node:internal/modules/cjs/helpers:102:18)
    npm ERR!     at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/render-template.js:4:20)
    npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1105:14)
    npm ERR!     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10)
    npm ERR!     at Module.load (node:internal/modules/cjs/loader:981:32)
    npm ERR!     at Function.Module._load (node:internal/modules/cjs/loader:822:12)
    npm ERR!     at Module.require (node:internal/modules/cjs/loader:1005:19) {
    npm ERR!   code: 'MODULE_NOT_FOUND',
    npm ERR!   requireStack: [
    npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/render-template.js',
    npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/plumbing.js',
    npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/index.js',
    npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/npmlog/log.js',
    npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/lib/node-gyp.js',
    npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js'
    npm ERR!   ]
    npm ERR! }
    npm ERR! node-pre-gyp ERR! build error
    npm ERR! node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js clean' (1)
    npm ERR! node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/@mapbox/node-pre-gyp/lib/util/compile.js:89:23)
    npm ERR! node-pre-gyp ERR! stack     at ChildProcess.emit (node:events:527:28)
    npm ERR! node-pre-gyp ERR! stack     at maybeClose (node:internal/child_process:1092:16)
    npm ERR! node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (node:internal/child_process:302:5)
    npm ERR! node-pre-gyp ERR! System Linux 5.10.103-v7l+
    npm ERR! node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build" "--update-binary"
    npm ERR! node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
    npm ERR! node-pre-gyp ERR! node -v v16.16.0
    npm ERR! node-pre-gyp ERR! node-pre-gyp -v v1.0.9
    npm ERR! node-pre-gyp ERR! not ok
    npm ERR!     /home/iobroker/.npm/_logs/2022-07-23T12_17_13_264Z-debug-0.log
    Vielen Dank!
    • SKBS SKB
      npm ERR! code 1
      npm ERR!   throw err;
      npm ERR!   ^
      npm ERR!
      npm ERR!   ]
      npm ERR! }
      Vielen Dank!
      @skb sagte in Canvas Installation mit Node16 auf R4 nicht möglich:
      /root/.npm/
      Dir fehlt die Option -H beim sudo -u iobroker
      cd /opt/iobroker
      npm ls object-assign
      sagt?
      SKBS 1 Antwort Letzte Antwort
        /root/.npm/
        cd /opt/iobroker
        sagt?
        SKBS Offline
        SKBS Offline
        SKB
        @thomas-braun Auch mit -H klappt es nicht.
        Hab die Ausgabe oben abgeändert. Natürlich hat "root" da nichts verloren :)
        Die Ausgabe ist wie folgt:
        pi@ioBroker:/opt/iobroker $ npm ls object-assign
        iobroker.inst@2.0.3 /opt/iobroker
        ├─┬ @mapbox/node-pre-gyp@1.0.9
        │ └─┬ npmlog@5.0.1
        │   └─┬ gauge@3.0.2
        │     └── object-assign@4.1.1
        ├─┬ iobroker.jarvis@3.0.11
        │ └─┬ socket.io@4.4.1
        │   └─┬ engine.io@6.1.2
        │     └─┬ cors@2.8.5
        │       └── object-assign@4.1.1 deduped
        └─┬ iobroker.zigbee@1.7.5 (git+ssh://git@github.com/ioBroker/ioBroker.zigbee.git#2213603e53c333eee6c37e40914ce7ac59d8eb56)
          └─┬ zigbee-herdsman@0.14.46
            └─┬ mz@2.7.0
        Ich hatte mit dem object-assign auch bei dem Zigbee Adapzter Probleme - du erinnerst Dich vielleicht.
        Dort hatte die Neuinstallation von dem node-pre-gyp geholfen. Hier aber leider nicht ...
        • SKBS SKB
          │ └─┬ npmlog@5.0.1
          │   └─┬ gauge@3.0.2
          │     └─┬ cors@2.8.5
              └─┬ mz@2.7.0
          @skb
          dpkg -L nodejs | grep render-template.js
            @skb
            SKBS Offline
            SKBS Offline
            SKB
            pi@ioBroker:/opt/iobroker $ dpkg -L nodejs | grep render-template.js
            /usr/lib/node_modules/npm/node_modules/gauge/lib/render-template.js
            • SKBS SKB
              @skb
              Hab gerade mal auf meinem System probiert:
              echad@chet:/opt/iobroker $ npm install canvas
              up to date in 8s
              71 packages are looking for funding
                run `npm fund` for details
              echad@chet:/opt/iobroker $ npm ls canvas
              iobroker.inst@3.0.0 /opt/iobroker
              ├── canvas@2.9.3
              ├─┬ iobroker.echarts@1.0.12
              │ ├── canvas@2.9.3 deduped
              │ └─┬ jsdom@19.0.0
              │   └── canvas@2.9.3 deduped
              ├─┬ iobroker.iot@1.11.9
              └─┬ iobroker.mihome-vacuum@3.6.0
                @skb
                up to date in 8s
                ├── canvas@2.9.3
                │ └─┬ jsdom@19.0.0
                SKBS Offline
                SKBS Offline
                SKB
                @thomas-braun Läufst Du auch auf einem Pi?
                Denn da soll es wohl immer mal Probleme geben, weil keine vor-kompilierten Pakete verfügbar sind.
                Ich habe auch die zugehörigen Pakete von apt-get installiert.
                sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
                Leider geht die Installation von Canvas immer noch erfolglos ...
                • SKBS SKB
                  @skb
                  Ja, allerdings die 64bit-Version vom RaspberryOS 'Bullseye'.
                  • SKBS SKB
                    @skb
                    Kann aber auch nicht an 32bit liegen, denn auf meinem Notfallsystem baut canvas auch mit 32 Bit intus:
                    pi@mysterium:~ $ uname -a
                    Linux mysterium 5.15.32-v7l+ #1538 SMP Thu Mar 31 19:39:41 BST 2022 armv7l GNU/Linux
                    pi@mysterium:~ $ cd /opt/iobroker/
                    pi@mysterium:/opt/iobroker $ npm ls canvas
                    │ ├── canvas@2.9.3
                    │ └─┬ jsdom@19.0.0
                    ├─┬ iobroker.iot@1.11.8
                    └─┬ iobroker.mihome-vacuum@3.4.2
                    pi@mysterium:/opt/iobroker $ npm install canvas
                    up to date in 7s
                    68 packages are looking for funding
                    ├── canvas@2.9.3
                    │ └─┬ jsdom@19.0.0
                    • SKBS Offline
                      SKBS Offline
                      SKB
                      @thomas-braun Habe jetzt das System mal auf 64-Bit gezogen - dennoch kommt immer die Meldung, dass das Modul 'object'assign fehlt.
                      Auch denke ich, das Canvas mit Node16 irgendwie nicht so richtig installiert werden kann.
                      • SKBS SKB
                        Hier geht es. Und mit node18 auch.
                          SKBS Offline
                          SKBS Offline
                          SKB
                          @thomas-braun Sollte ich vielleicht von Node 16 auf Node 18 gehen?
                          Vielleicht wird das object-assign repariert?
                          • SKBS SKB
                            @skb
                            Vermutlich nicht. Da wird der Fehler woanders liegen. Ich weiß aber nicht wo, tut mir leid.
                              @skb
                              SKBS Offline
                              SKBS Offline
                              SKB
                              @thomas-braun Danke für die Einschätzung.
                              Hättest Du noch eine Idee, wo ich schauen könnte?
                              Wenn es ja bei Anderen geht, muss es ja insgesamt gehen...
                              • SKBS SKB
                                @skb
                                Was passiert denn, wenn du ganz simpel
                                npm install canvas
                                in /opt/iobroker ausführst?
                                  @skb
                                  npm install canvas
                                  SKBS Offline
                                  SKBS Offline
                                  SKB
                                  @thomas-braun Ganz simpel dieses:
                                  pi@ioBroker:/opt/iobroker $ npm install canvas
                                  npm ERR! code 1
                                  npm ERR!   throw err;
                                  npm ERR!   ^
                                  npm ERR!
                                  npm ERR!   ]
                                  npm ERR! }
                                  npm ERR! node-pre-gyp ERR! System Linux 5.10.103-v8+
                                  npm ERR!     /home/iobroker/.npm/_logs/2022-07-23T20_08_48_029Z-debug-0.log
                                  • SKBS SKB
                                    npm ERR! code 1
                                    npm ERR!   throw err;
                                    npm ERR!   ^
                                    npm ERR!
                                    npm ERR!   ]
                                    npm ERR! }
                                    Das sieht ganz ähnlich aus:
                                    https://github.com/Automattic/node-canvas/issues/2078
                                    Da wird das dann --build-from-source gebaut, denn das funktioniert wohl gerade nicht:
                                    By default, binaries for macOS, Linux and Windows will be downloaded. If you want to build from source, use npm install --build-from-source and see the Compiling section below.
                                      SKBS Offline
                                      SKBS Offline
                                      SKB
                                      @thomas-braun Ist dann "einfach":
                                      npm install canvas --build-from-source
                                      Thomas BraunT A 2 Antworten Letzte Antwort
                                      • SKBS SKB
                                        @skb
                                        Ich vermute ja. Ich hab das auch noch nie selber gebastelt.
                                        Die dev-Files hast du?
                                        • SKBS SKB
                                          anno171986
                                          @skb Hallo, ich habe ein ähnliches Problem:
                                          Cannot find required modules: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node' was compiled against a different Node.js version using NODE_MODULE_VERSION 72. This version of Node.js requires NODE_MODULE_VERSION 93. Please try re-compiling or re-installing the module (for instance, using `npm rebuild` or `npm install`).
                                          und wenn ich es versuche neu zu installieren kommen auch Fehler:
                                          pi@raspberrypi:/opt/iobroker$ cd /opt/iobroker/node_modules
                                          pi@raspberrypi:/opt/iobroker/node_modules$ npm install canvas --build-from-source
                                          npm ERR! code 1
                                          npm ERR! command sh /tmp/install-ab819b46.sh
                                          npm ERR! node-pre-gyp info using node-pre-gyp@1.0.10
                                          npm ERR! node-pre-gyp info using node@16.17.1 | linux | arm
                                          npm ERR! node-pre-gyp info build requesting source compile
                                          npm ERR! node:internal/modules/cjs/loader:959
                                          npm ERR!   throw err;
                                          npm ERR!   ^
                                          npm ERR!
                                          npm ERR!     at Function.Module._resolveFilename (node:internal/modules/cjs/loader:956:15)
                                          npm ERR!     at Function.Module._load (node:internal/modules/cjs/loader:804:27)
                                          npm ERR!     at Module.require (node:internal/modules/cjs/loader:1028:19)
                                          npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1126:14)
                                          npm ERR!     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10)
                                          npm ERR!     at Module.load (node:internal/modules/cjs/loader:1004:32)
                                          npm ERR!     at Function.Module._load (node:internal/modules/cjs/loader:839:12)
                                          npm ERR!     at Module.require (node:internal/modules/cjs/loader:1028:19) {
                                          npm ERR!   ]
                                          npm ERR! }
                                          npm ERR! node-pre-gyp ERR! stack     at ChildProcess.emit (node:events:513:28)
                                          npm ERR! node-pre-gyp ERR! stack     at maybeClose (node:internal/child_process:1093:16)
                                          npm ERR! node-pre-gyp ERR! node -v v16.17.1
                                          npm ERR! node-pre-gyp ERR! node-pre-gyp -v v1.0.10
                                          npm ERR!     /home/pi/.npm/_logs/2022-11-17T21_24_58_078Z-debug-0.log
                                          Konntest du dein Problem lösen?
