  4. Nach Update starten Adapter nicht mehr
    5.8k
120 Beiträge 9 Kommentatoren 10.6k Aufrufe 6 Beobachtet
  • T tobiasp
    @thomas-braun said in Nach Update starten Adapter nicht mehr:
    npm ls | grep -E 'github|ERR'
    pi@raspberrypi:~ $ cd /opt/iobroker
    pi@raspberrypi:/opt/iobroker $ npm ls | grep -E 'github|ERR'
    npm ERR! code ELSPROBLEMS
    npm ERR! extraneous: @types/node-cron@2.0.5 /opt/iobroker/node_modules/@types/node-cron
    npm ERR! extraneous: @types/tz-offset@0.0.0 /opt/iobroker/node_modules/@types/tz-offset
    npm ERR! extraneous: cron@1.8.2 /opt/iobroker/node_modules/cron
    npm ERR! invalid: iobroker.admin@5.3.8 /opt/iobroker/node_modules/iobroker.admin
    npm ERR! invalid: iobroker.backitup@2.4.9 /opt/iobroker/node_modules/iobroker.backitup
    npm ERR! invalid: iobroker.discovery@3.0.3 /opt/iobroker/node_modules/iobroker.discovery
    npm ERR! invalid: iobroker.js-controller@4.0.23 /opt/iobroker/node_modules/iobroker.js-controller
    npm ERR! extraneous: iobroker.virtualpowermeter@1.4.6 /opt/iobroker/node_modules/iobroker.virtualpowermeter
    npm ERR! extraneous: moment-timezone@0.5.34 /opt/iobroker/node_modules/moment-timezone
    npm ERR! extraneous: node-cron@2.0.3 /opt/iobroker/node_modules/node-cron
    npm ERR! extraneous: opencollective-postinstall@2.0.3 /opt/iobroker/node_modules/opencollective-postinstall
    npm ERR! extraneous: tz-offset@0.0.1 /opt/iobroker/node_modules/tz-offset
    npm ERR!     /home/iobroker/.npm/_logs/2022-07-21T10_27_50_949Z-debug-0.log
    @tobiasp Hattest du dein System nicht vorher auf Stand gebracht?
    discovery z. B.:
    github:	3.0.5
    latest:	3.0.5 for 34 days
    stable:	3.0.5 for 34 days
    Du schleppst da eine 3.0.3 an.
      discovery z. B.:
      github:	3.0.5
      tobiasp
      Lässst sich nicht updaten
      $ iobroker upgrade discovery@3.0.5
      Update discovery from @3.0.3 to @3.0.5
      NPM version: 8.11.0Installing iobroker.discovery@3.0.5... (System call)
      host.raspberrypi Cannot install iobroker.discovery@3.0.5: 217
      ERROR: Process exited with code 25
      • T tobiasp
        @tobiasp und mit --debug hintendran?
        da sollte die Konsole gesprächiger werden
          tobiasp
          i@raspberrypi:/opt/iobroker $ iobroker upgrade --debug
          This upgrade of "discovery" will introduce the following changes:
          -> 3.0.5:
          Fix potential crash cases reported by Sentry
          -> 3.0.4:
          Disable configuration settings for this adapter
          Would you like to upgrade discovery from @3.0.3 to @3.0.5 now? [(y)es, (n)o]: y
          NPM version: 8.11.0
          npm ERR! code ENOTEMPTY
          npm ERR! syscall rename
          npm ERR! path /opt/iobroker/node_modules/abort-controller
          npm ERR! dest /opt/iobroker/node_modules/.abort-controller-x3pdLVqa
          npm ERR! errno -39
          npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/abort-controller' -> '/opt/iobroker/node_modules/.abort-controller-x3pdLVqa'
          npm ERR!     /home/iobroker/.npm/_logs/2022-07-21T12_47_36_083Z-debug-0.log
          • T tobiasp
            -> 3.0.5:
            -> 3.0.4:
            NPM version: 8.11.0
            npm ERR! errno -39
            @tobiasp sagte in Nach Update starten Adapter nicht mehr:
            sudo rm /opt/iobroker/node_modules/.abort-controller-x3pdLVqa
            Das dann für evtl. weitere Verzeichnisse analog machen. Also die Verzeichnisse mit den kryptischen Endungen löschen.
              tobiasp
              @thomas-braun @tobiasp
              Da mussst du miir bitte helfen was du da genau meinst.
              pi@raspberrypi:~ $ sudo rm /opt/iobroker/node_modules/.abort-controller-x3pdLVqa
              rm: das Entfernen von '/opt/iobroker/node_modules/.abort-controller-x3pdLVqa' ist nicht möglich: Ist ein Verzeichnis
              pi@raspberrypi:~ $
              • T tobiasp
                pi@raspberrypi:~ $
                @tobiasp
                Sorry, mein Fehler.
                sudo rm -rf /opt/iobroker/node_modules/.abort-controller-x3pdLVqa
                  tobiasp
                  @thomas-braun Bringt immer noch FEhler
                  @raspberrypi:~ $ iobroker upgrade --debug
                  -> 3.0.5:
                  -> 3.0.4:
                  NPM version: 8.11.0
                  npm ERR! path /opt/iobroker/node_modules/accepts
                  npm ERR! dest /opt/iobroker/node_modules/.accepts-rBwU1CL7
                  npm ERR! errno -39
                  npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/accepts' -> '/opt/iobroker/node_modules/.accepts-rBwU1CL7'
                  npm ERR!     /home/iobroker/.npm/_logs/2022-07-21T13_21_25_599Z-debug-0.log
                  pi@raspberrypi:~ $
                  -1
                  • T tobiasp
                    -> 3.0.5:
                    -> 3.0.4:
                    NPM version: 8.11.0
                    npm ERR! errno -39
                    pi@raspberrypi:~ $
                    @tobiasp
                    • T tobiasp
                      -> 3.0.5:
                      -> 3.0.4:
                      NPM version: 8.11.0
                      npm ERR! errno -39
                      pi@raspberrypi:~ $
                      @thomas-braun sagte in Nach Update starten Adapter nicht mehr:
                        tobiasp
                        @homoran Ok das dauert dann etwas länger das sind ja ewig viele
                        • T tobiasp
                          Das hängt von der jeweiligen Installation ab, wie viele da sind. Kann von Null bis mehrere Dutzend alles mögliche sein.
                            tobiasp
                            aber herausfinden geht nur wenn man immer wieder startet und dann die DAtei löscht
                            • T tobiasp
                              tobiasp
                              @tobiasp
                              Und die Adapter starten deswegen nicht oder? Was sind dann das für FEhlermedungen noch ?
                              host.raspberrypi
                              	2022-07-21 16:13:54.442	error	iobroker npm-install: host.raspberrypi Cannot install iobroker.vis-icontwo@0.87.0: 217
                              host.raspberrypi
                              	2022-07-21 16:13:21.059	error	iobroker npm-install: host.raspberrypi Cannot install iobroker.icons-open-icon-library-png@0.1.2: 217
                              host.raspberrypi
                              	2022-07-21 16:09:08.447	error	iobroker npm-install: host.raspberrypi Cannot install iobroker.javascript@5.7.0: 217
                              host.raspberrypi
                              	2022-07-21 16:08:46.762	error	iobroker npm-install: host.raspberrypi Cannot install iobroker.terminal@0.2.6: 217
                              host.raspberrypi
                              	2022-07-21 16:06:03.259	error	iobroker npm-install: host.raspberrypi Cannot install iobroker.icons-material-svg@0.1.0: 217
                              host.raspberrypi
                              	2022-07-21 16:05:39.038	error	iobroker npm-install: host.raspberrypi Cannot install iobroker.icons-icons8@0.0.1: 217
                              host.raspberrypi
                              	2022-07-21 16:05:18.094	error	iobroker npm-install: host.raspberrypi Cannot install iobroker.icons-fatcow-hosting@0.1.0: 217
                              web.0
                              	2022-07-21 16:05:14.557	error	Initialization of integrated socket.io failed. Please reinstall the web adapter.
                              host.raspberrypi
                              	2022-07-21 16:04:57.310	error	iobroker npm-install: host.raspberrypi Cannot install iobroker.icons-mfd-svg@1.1.0: 217
                              host.raspberrypi
                              	2022-07-21 16:04:22.238	error	iobroker npm-install: host.raspberrypi Cannot install iobroker.fritzbox@0.2.1: 217
                              host.raspberrypi
                              	2022-07-21 16:03:56.612	error	iobroker npm-install: host.raspberrypi Cannot install iobroker.daswetter@3.1.2: 217
                              host.raspberrypi
                              	2022-07-21 16:03:32.868	error	iobroker npm-install: host.raspberrypi Cannot install iobroker.flot@1.11.0: 217
                              host.raspberrypi
                              	2022-07-21 16:03:07.498	error	iobroker npm-install: host.raspberrypi Cannot install iobroker.devices@1.0.12: 217
                              host.raspberrypi
                              	2022-07-21 16:02:45.696	error	iobroker npm-install: host.raspberrypi Cannot install iobroker.icons-material-png@0.1.0: 217
                              host.raspberrypi
                              	2022-07-21 16:02:25.479	error	iobroker npm-install: host.raspberrypi Cannot install schmupu/ioBroker.pollenflug#4ae37990c9c6bcf9ae5db5bfa0c9fba70b005e7f: 217
                              host.raspberrypi
                              	2022-07-21 16:02:02.520	error	iobroker npm-install: host.raspberrypi Cannot install iobroker.icons-ultimate-png@1.0.1: 217
                              • T tobiasp
                                @tobiasp
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                web.0
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                Du liest aber doch schon was da steht?
                                • T tobiasp
                                  @tobiasp
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  web.0
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  pollenflug
                                  Ist z. B. eine github-Version. Warum? Unnötig:
                                  pollenflug
                                  github:	1.0.6
                                  latest:	1.0.6 for 26 months
                                  stable:	1.0.6 for 26 months
                                  Die anderen Dinge findest du heraus, indem du die einzeln mit --debug-Option installierst. Dann gibt es mehr Infos. Sind aber bei dir schon recht viele Adapter. Sind die alle in alten Versionen installiert und harren eines Updates?
                                    pollenflug
                                    pollenflug
                                    github:	1.0.6
                                    tobiasp
                                    Wo sehe ich denn das ich habe immer in Iobroker die Updates gemacht! Mache ich was falsch oder wie kann ich imemr die richtige Verison installieren?
                                    • T tobiasp
                                      Ich weiß nicht was du machst. Die Reihenfolge bei Installationen ist: Zuerst aus Stable, dann aus Beta (wenn der Adapter noch nicht stabil verfügbar ist) und erst wenn der gar nicht irgendwie anders aufzutreiben ist, DANN erst verwendet man die räudige 'Katze' für den Adapter. Man muss sich dann aber bewusst sein, das der Code in allen möglichen Zuständen sein kann.
                                        tobiasp
                                        Grüßt euch, so ich habe ein altes Backup gefunden und isntalliert und es läuft sowet eigentlicht alles mit Node 14 aber kurze Frage zur Antort aus
                                        Was muss ich hier machen ? DAnkeschön sorry für meine fragen
                                        +-- ecovacs-deebot@0.6.1 (github:mrbungle64/ecovacs-deebot.js#f6ad821a3e5ea82104be702fd63d2d3db4e1ca7d)
                                        +-- eiscp@0.0.1 (github:tillbaks/node-eiscp#cefa9b53c822cdab823eaae8173b69ab357c8de7)
                                        +-- iobroker.ryd@0.3.3 (github:NemoN/ioBroker.ryd#839d73a9eee3da7ba3d292c8b03b8f98cb2ea329)
                                        | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
                                        +-- iobroker.sourceanalytix@0.4.12-1 (github:DrozmotiX/ioBroker.sourceanalytix#362346b297c0a21c717ec20bd8d16331bca3b22d)
                                        |   +-- github-url-from-git@1.5.0
                                        |   +-- new-github-release-url@1.0.0
                                        +-- new-github-issue-url@1.0.0
                                        npm ERR! extraneous: @types/request@2.48.7 /opt/iobroker/node_modules/@types/request
                                        npm ERR! extraneous: acorn@8.8.0 /opt/iobroker/node_modules/acorn
                                        npm ERR! extraneous: acorn-walk@8.2.0 /opt/iobroker/node_modules/acorn-walk
                                        npm ERR! extraneous: express-fileupload@0.4.1 /opt/iobroker/node_modules/express-fileupload
                                        npm ERR! extraneous: jsonata@1.8.4 /opt/iobroker/node_modules/jsonata
                                        npm ERR! extraneous: node-ssdp@3.3.0 /opt/iobroker/node_modules/node-ssdp
                                        npm ERR! extraneous: passport@0.4.0 /opt/iobroker/node_modules/passport
                                        npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
                                        npm ERR! extraneous: serialport@6.2.2 /opt/iobroker/node_modules/serialport
                                        npm ERR! extraneous: typescript@4.3.5 /opt/iobroker/node_modules/typescript
                                        npm ERR! extraneous: virtual-tsc@0.6.1 /opt/iobroker/node_modules/virtual-tsc
                                        npm ERR! extraneous: vm2@3.9.3 /opt/iobroker/node_modules/vm2
                                        npm ERR! extraneous: gulp-replace /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-replace
                                        npm ERR! error in /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-replace: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-replace/package.json'
                                        npm ERR! peer dep missing: buffer@>=6.0.3, required by crc@4.1.1
                                        • T tobiasp
                                          tobiasp
                                          @tobiasp
                                          Ich glaub ich schreib ggf. die Antwort selkbst rein das sind die Adapter die ich aus Github onstalliert habe ?
                                          Muss man die selbst dann aktualiseiren
