  4. Kein Update mehr möglich mit Node.js 16
node js
335 Beiträge 16 Kommentatoren 64.0k Aufrufe 16 Beobachtet
    @kimukao sagte in Kein Update mehr möglich mit Node.js 16:
    Hat leider auch nicht funktioniert:
    Da war auch nicht zu erwarten. Immerhin gibt es mehr Meldungen:
    npm ERR! builtins is not a function
    npm ERR!     /home/iobroker/.npm/_logs/2022-09-06T11_28_01_889Z-debug-0.log
    Was steht denn in dem genannten log drin?
    kimukao
    #221
    @thomas-braun said in Kein Update mehr möglich mit Node.js 16:
    Kenne mich zu wenig aus. Wie liest man das denn aus?
    • K kimukao
      #222
      Mit einem pager z. B.
      less -R /home/iobroker/.npm/_logs/2022-09-06T11_28_01_889Z-debug-0.log
      K 1 Antwort Letzte Antwort
        kimukao
        #223
        0 verbose cli /usr/bin/node /usr/bin/npm
        1 info using npm@8.15.0
        2 info using node@v16.17.0
        3 timing npm:load:whichnode Completed in 1ms
        4 timing config:load:defaults Completed in 4ms
        5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 2ms
        6 timing config:load:builtin Completed in 4ms
        7 timing config:load:cli Completed in 6ms
        8 timing config:load:env Completed in 1ms
        9 timing config:load:file:/opt/iobroker/.npmrc Completed in 1ms
        10 timing config:load:project Completed in 4ms
        11 timing config:load:file:/home/iobroker/.npmrc Completed in 0ms
        12 timing config:load:user Completed in 1ms
        13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
        14 timing config:load:global Completed in 1ms
        15 timing config:load:validate Completed in 0ms
        16 timing config:load:credentials Completed in 3ms
        17 timing config:load:setEnvs Completed in 3ms
        18 timing config:load Completed in 28ms
        19 timing npm:load:configload Completed in 29ms
        20 timing npm:load:mkdirpcache Completed in 2ms
        21 timing npm:load:mkdirplogs Completed in 1ms
        22 verbose title npm install iobroker.backitup@2.4.10
        23 verbose argv "install" "--save-exact" "iobroker.backitup@2.4.10"
        24 timing npm:load:setTitle Completed in 4ms
        25 timing config:load:flatten Completed in 9ms
        26 timing npm:load:display Completed in 11ms
        27 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs
        28 verbose logfile /home/iobroker/.npm/_logs/2022-09-06T11_28_01_889Z-debug-0.log
        29 timing npm:load:logFile Completed in 13ms
        30 timing npm:load:timers Completed in 1ms
        31 timing npm:load:configScope Completed in 0ms
        32 timing npm:load Completed in 63ms
        33 timing arborist:ctor Completed in 2ms
        34 silly logfile start cleaning logs, removing 2 files
        35 silly logfile done cleaning log files
        36 timing idealTree:init Completed in 3489ms
        37 timing idealTree Completed in 3494ms
        38 timing command:install Completed in 3530ms
        39 verbose stack TypeError: builtins is not a function
        39 verbose stack     at validate (/usr/lib/node_modules/npm/node_modules/validate-npm-package-name/lib/index.js:55:3)
        39 verbose stack     at Result.setName (/usr/lib/node_modules/npm/node_modules/npm-package-arg/lib/npa.js:129:17)
        39 verbose stack     at new Result (/usr/lib/node_modules/npm/node_modules/npm-package-arg/lib/npa.js:120:10)
        39 verbose stack     at resolve (/usr/lib/node_modules/npm/node_modules/npm-package-arg/lib/npa.js:57:15)
        39 verbose stack     at npa (/usr/lib/node_modules/npm/node_modules/npm-package-arg/lib/npa.js:51:10)
        39 verbose stack     at /usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:542:50
        • K kimukao
          #224
          @kimukao
          Das geht noch weiter.
          'Bild Runter'-Taste
            @kimukao
            'Bild Runter'-Taste
            kimukao
            #225
            @thomas-braun ah.. ok.. so sieht's im weiteren Verlauf aus:
            39 verbose stack     at Array.map (<anonymous>)
            39 verbose stack     at Arborist.[add] (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:539:28)
            39 verbose stack     at Arborist.[applyUserRequestsToNode] (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:510:23)
            39 verbose stack     at Arborist.[applyUserRequests] (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:447:43)
            40 verbose cwd /opt/iobroker
            41 verbose Linux 5.15.61-v7l+
            42 verbose node v16.17.0
            43 verbose npm  v8.15.0
            44 error builtins is not a function
            45 verbose exit 1
            46 timing npm Completed in 3800ms
            47 verbose unfinished npm timer reify 1662463682151
            48 verbose unfinished npm timer reify:loadTrees 1662463682178
            49 verbose unfinished npm timer idealTree:userRequests 1662463685671
            50 verbose code 1
            51 error A complete log of this run can be found in:
            51 error     /home/iobroker/.npm/_logs/2022-09-06T11_28_01_889Z-debug-0.log
            (END)
            • K kimukao
              45 verbose exit 1
              50 verbose code 1
              (END)
              #226
              Keine Ahnung was das für ein Fehler ist und wo man den beheben könnte.
                kimukao
                #227
                @thomas-braun Oje. Würde dann nur eine Neuinstallation des iobrokers samt Einspielung eines Backups helfen? Oder liegt der Hund woanders begraben?
                • K kimukao
                  #228
                  @kimukao
                  Ich weiß es nicht.
                    @kimukao
                    Ich weiß es nicht.
                    kimukao
                    #229
                    Ich weiß es nicht.
                    Trotzdem vielen Dank für die Hilfe. Dann hoffe ich, dass noch jemand eine Idee hat bevor ich alles platt mache...
                    • Thomas BraunT Online
                      #230
                      @kimukao
                      Ich hab keinen Plan von JavaScript, aber hier:
                      https://flaviocopes.com/is-not-a-function/
                      schreibt jemand, dass da im Code irgendwo ein Semikolon fehlt.
                      Ich weiß nur nicht ob das beim Backitup dann zu suchen wäre oder doch woanders.
                      Andere Adapter lassen sich updaten?
                      K 2 Antworten Letzte Antwort
                        @kimukao
                        kimukao
                        #231
                        @thomas-braun Leider lässt sich kein einziger Adapter updaten
                          @kimukao
                          kimukao
                          schrieb am zuletzt editiert von kimukao
                          #232
                          @thomas-braun Hab's mal durchprobiert. Interessant ist, dass jedes Mal vor dem Hinweis "exited with code 0" eine words.js Datei auftaucht. Hier am Beispiel des Discovery Adapters (lässt sich beliebig auf alle anderen Adapter übertragen):
                          $ iobroker upgrade discovery@3.0.5
                          Update discovery from @3.0.3 to @3.0.5
                          NPM version: 8.15.0
                          Installing iobroker.discovery@3.0.5... (System call)
                          upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
                          upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
                          upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
                          upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
                          upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
                          upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                          upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                          Process exited with code 0
                          Bedeutet das, dass das Einfügen eines Semikolons in die .js Dateien helfen würde? Wenn ja, wie mache ich das denn?
                          • K kimukao
                            NPM version: 8.15.0
                            #233
                            @kimukao
                            Mach es mit --debug-Option.
                            Sonst sieht man da genau gar nichts.
                              @kimukao
                              kimukao
                              #234
                              iobroker upgrade admin@6.2.20 --debug
                              This upgrade of "admin" will at least introduce the following changes:
                              -> 6.2.20:
                              Corrected GUI issues
                              -> 6.2.19:
                              Corrected some issues
                              -> 6.2.18:
                              Corrected GUI bugs on custom settings
                              -> 6.2.17:
                              Corrected GUI bug on intro tab
                              -> 6.2.16:
                              Corrected many GUI issues
                              Added `stable` flag for repositories
                              Added reset button for repositories
                              Improved `writeFile` function for socket communication
                              -> 6.2.14:
                              Fix for OAuth2 authentication response success page
                              -> 6.2.13:
                              Corrected JSON config
                              BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                              Would you like to upgrade admin from @5.3.8 to @6.2.20 now? [(y)es, (n)o]: y
                              Update admin from @5.3.8 to @6.2.20
                              host.raspberrypi Adapter "system.adapter.admin.0" is stopped.
                              NPM version: 8.15.0
                              Installing iobroker.admin@6.2.20... (System call)
                              npm ERR!     /home/iobroker/.npm/_logs/2022-09-06T13_14_32_531Z-debug-0.log
                              upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                              upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
                              upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
                              upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
                              upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                              upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
                              upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                              upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                              upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                              upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                              upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                              upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
                              upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
                              upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json jsonConfig.json application/json
                              upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
                              host.raspberrypi Adapter "system.adapter.admin.0" is started
                              • K kimukao
                                -> 6.2.20:
                                -> 6.2.19:
                                -> 6.2.18:
                                -> 6.2.17:
                                -> 6.2.16:
                                -> 6.2.14:
                                -> 6.2.13:
                                NPM version: 8.15.0
                                #235
                                @kimukao
                                Ich kann dir nicht helfen.
                                  @kimukao
                                  kimukao
                                  #236
                                  @thomas-braun Trotzdem danke, dass Du Dir so viel Zeit für mich genommen hast. Jemand anderes eine Idee?
                                  • mickymM Offline
                                    mickymM Offline
                                    mickym
                                    #237
                                    Wenn gar nichts mehr geht - und bevor ihr neu installiert - dann probiert halt meine Radikalmethode. ;) -
                                    K mickymM 2 Antworten Letzte Antwort
                                    • mickymM mickym
                                      kimukao
                                      #238
                                      @mickym die da wäre..? Machst mich neugierig
                                      • mickymM mickym
                                        mickymM Offline
                                        mickymM Offline
                                        mickym
                                        #239
                                        @mickym Wir können es probieren - aber wie gesagt - erst dann wenn Du sonst eh neu aufbauen müsstest oder wieder zurück kannst. ;) Ich lösche immer das ganze node_modules Verzeichnis und lasse es komplett neu aufbauen. - Können wir zusammen durchgehen, wenn Du meinst dass man Dein System nicht mehr kaputter machen kann.
                                        Poste mal Deine package.json aus dem Verzeichnis: /opt/iobroker hier in code-tags-
                                        • mickymM mickym
                                          kimukao
                                          #240
                                          @mickym ich schätze, das wäre meine einzige Chance.. im Moment läuft zwar alles stabil, ich kann aber nichts updaten, perspektivisch also "suboptimal"
