  4. Kein Update mehr möglich mit Node.js 16
node js
335 Beiträge 16 Kommentatoren 64.7k Aufrufe 16 Beobachtet
    @kimukao sagte in Kein Update mehr möglich mit Node.js 16:
    iobroker upgrade backitup@2.4.10
    Mach es mit --debug-Option in der Konsole:
    iobroker upgrade backitup@2.4.10 --debug
    kimukao
    schrieb am zuletzt editiert von kimukao
    #219
    @thomas-braun Hat leider auch nicht funktioniert:
    This upgrade of "backitup" will introduce the following changes:
    -> 2.4.10:
    Code cleaning
    dependencies updated
    Disclaimer added
    Travis Support removed
    Fix backup-download with ssl
    Would you like to upgrade backitup from @2.4.9 to @2.4.10 now? [(y)es, (n)o]: y
    Update backitup from @2.4.9 to @2.4.10
    host.raspberrypi Adapter "system.adapter.backitup.0" is stopped.
    NPM version: 8.15.0
    Installing iobroker.backitup@2.4.10... (System call)
    npm ERR! builtins is not a function
    npm ERR!     /home/iobroker/.npm/_logs/2022-09-06T11_28_01_889Z-debug-0.log
    upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
    upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
    upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
    upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
    upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
    upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
    upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
    upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
    upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
    upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
    upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
    host.raspberrypi Adapter "system.adapter.backitup.0" is started
    • K kimukao
      -> 2.4.10:
      Code cleaning
      Disclaimer added
      NPM version: 8.15.0
      #220
      Da war auch nicht zu erwarten. Immerhin gibt es mehr Meldungen:
      Was steht denn in dem genannten log drin?
        kimukao
        #221
        @thomas-braun said in Kein Update mehr möglich mit Node.js 16:
        Kenne mich zu wenig aus. Wie liest man das denn aus?
        • K kimukao
          #222
          Mit einem pager z. B.
          less -R /home/iobroker/.npm/_logs/2022-09-06T11_28_01_889Z-debug-0.log
            kimukao
            #223
            0 verbose cli /usr/bin/node /usr/bin/npm
            1 info using npm@8.15.0
            2 info using node@v16.17.0
            3 timing npm:load:whichnode Completed in 1ms
            4 timing config:load:defaults Completed in 4ms
            5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 2ms
            6 timing config:load:builtin Completed in 4ms
            7 timing config:load:cli Completed in 6ms
            8 timing config:load:env Completed in 1ms
            9 timing config:load:file:/opt/iobroker/.npmrc Completed in 1ms
            10 timing config:load:project Completed in 4ms
            11 timing config:load:file:/home/iobroker/.npmrc Completed in 0ms
            12 timing config:load:user Completed in 1ms
            13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
            14 timing config:load:global Completed in 1ms
            15 timing config:load:validate Completed in 0ms
            16 timing config:load:credentials Completed in 3ms
            17 timing config:load:setEnvs Completed in 3ms
            18 timing config:load Completed in 28ms
            19 timing npm:load:configload Completed in 29ms
            20 timing npm:load:mkdirpcache Completed in 2ms
            21 timing npm:load:mkdirplogs Completed in 1ms
            22 verbose title npm install iobroker.backitup@2.4.10
            23 verbose argv "install" "--save-exact" "iobroker.backitup@2.4.10"
            24 timing npm:load:setTitle Completed in 4ms
            25 timing config:load:flatten Completed in 9ms
            26 timing npm:load:display Completed in 11ms
            27 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs
            28 verbose logfile /home/iobroker/.npm/_logs/2022-09-06T11_28_01_889Z-debug-0.log
            29 timing npm:load:logFile Completed in 13ms
            30 timing npm:load:timers Completed in 1ms
            31 timing npm:load:configScope Completed in 0ms
            32 timing npm:load Completed in 63ms
            33 timing arborist:ctor Completed in 2ms
            34 silly logfile start cleaning logs, removing 2 files
            35 silly logfile done cleaning log files
            36 timing idealTree:init Completed in 3489ms
            37 timing idealTree Completed in 3494ms
            38 timing command:install Completed in 3530ms
            39 verbose stack TypeError: builtins is not a function
            39 verbose stack     at validate (/usr/lib/node_modules/npm/node_modules/validate-npm-package-name/lib/index.js:55:3)
            39 verbose stack     at Result.setName (/usr/lib/node_modules/npm/node_modules/npm-package-arg/lib/npa.js:129:17)
            39 verbose stack     at new Result (/usr/lib/node_modules/npm/node_modules/npm-package-arg/lib/npa.js:120:10)
            39 verbose stack     at resolve (/usr/lib/node_modules/npm/node_modules/npm-package-arg/lib/npa.js:57:15)
            39 verbose stack     at npa (/usr/lib/node_modules/npm/node_modules/npm-package-arg/lib/npa.js:51:10)
            39 verbose stack     at /usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:542:50
            • K kimukao
              #224
              @kimukao
              Das geht noch weiter.
              'Bild Runter'-Taste
                @kimukao
                'Bild Runter'-Taste
                kimukao
                #225
                @thomas-braun ah.. ok.. so sieht's im weiteren Verlauf aus:
                39 verbose stack     at Array.map (<anonymous>)
                39 verbose stack     at Arborist.[add] (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:539:28)
                39 verbose stack     at Arborist.[applyUserRequestsToNode] (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:510:23)
                39 verbose stack     at Arborist.[applyUserRequests] (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:447:43)
                40 verbose cwd /opt/iobroker
                41 verbose Linux 5.15.61-v7l+
                42 verbose node v16.17.0
                43 verbose npm  v8.15.0
                44 error builtins is not a function
                45 verbose exit 1
                46 timing npm Completed in 3800ms
                47 verbose unfinished npm timer reify 1662463682151
                48 verbose unfinished npm timer reify:loadTrees 1662463682178
                49 verbose unfinished npm timer idealTree:userRequests 1662463685671
                50 verbose code 1
                51 error A complete log of this run can be found in:
                51 error     /home/iobroker/.npm/_logs/2022-09-06T11_28_01_889Z-debug-0.log
                (END)
                • K kimukao
                  45 verbose exit 1
                  50 verbose code 1
                  (END)
                  #226
                  Keine Ahnung was das für ein Fehler ist und wo man den beheben könnte.
                    kimukao
                    #227
                    @thomas-braun Oje. Würde dann nur eine Neuinstallation des iobrokers samt Einspielung eines Backups helfen? Oder liegt der Hund woanders begraben?
                    • K kimukao
                      #228
                      @kimukao
                      Ich weiß es nicht.
                        @kimukao
                        Ich weiß es nicht.
                        kimukao
                        #229
                        Ich weiß es nicht.
                        Trotzdem vielen Dank für die Hilfe. Dann hoffe ich, dass noch jemand eine Idee hat bevor ich alles platt mache...
                        • Thomas BraunT Online
                          #230
                          @kimukao
                          Ich hab keinen Plan von JavaScript, aber hier:
                          https://flaviocopes.com/is-not-a-function/
                          schreibt jemand, dass da im Code irgendwo ein Semikolon fehlt.
                          Ich weiß nur nicht ob das beim Backitup dann zu suchen wäre oder doch woanders.
                          Andere Adapter lassen sich updaten?
                          K 2 Antworten Letzte Antwort
                            @kimukao
                            kimukao
                            #231
                            @thomas-braun Leider lässt sich kein einziger Adapter updaten
                              @kimukao
                              kimukao
                              #232
                              @thomas-braun Hab's mal durchprobiert. Interessant ist, dass jedes Mal vor dem Hinweis "exited with code 0" eine words.js Datei auftaucht. Hier am Beispiel des Discovery Adapters (lässt sich beliebig auf alle anderen Adapter übertragen):
                              $ iobroker upgrade discovery@3.0.5
                              Update discovery from @3.0.3 to @3.0.5
                              NPM version: 8.15.0
                              Installing iobroker.discovery@3.0.5... (System call)
                              upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
                              upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
                              upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
                              upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
                              upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
                              upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                              upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                              Process exited with code 0
                              Bedeutet das, dass das Einfügen eines Semikolons in die .js Dateien helfen würde? Wenn ja, wie mache ich das denn?
                              • K kimukao
                                NPM version: 8.15.0
                                #233
                                @kimukao
                                Mach es mit --debug-Option.
                                Sonst sieht man da genau gar nichts.
                                  @kimukao
                                  kimukao
                                  #234
                                  iobroker upgrade admin@6.2.20 --debug
                                  This upgrade of "admin" will at least introduce the following changes:
                                  -> 6.2.20:
                                  Corrected GUI issues
                                  -> 6.2.19:
                                  Corrected some issues
                                  -> 6.2.18:
                                  Corrected GUI bugs on custom settings
                                  -> 6.2.17:
                                  Corrected GUI bug on intro tab
                                  -> 6.2.16:
                                  Corrected many GUI issues
                                  Added `stable` flag for repositories
                                  Added reset button for repositories
                                  Improved `writeFile` function for socket communication
                                  -> 6.2.14:
                                  Fix for OAuth2 authentication response success page
                                  -> 6.2.13:
                                  Corrected JSON config
                                  BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                                  Would you like to upgrade admin from @5.3.8 to @6.2.20 now? [(y)es, (n)o]: y
                                  Update admin from @5.3.8 to @6.2.20
                                  host.raspberrypi Adapter "system.adapter.admin.0" is stopped.
                                  NPM version: 8.15.0
                                  Installing iobroker.admin@6.2.20... (System call)
                                  npm ERR!     /home/iobroker/.npm/_logs/2022-09-06T13_14_32_531Z-debug-0.log
                                  upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                                  upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                  upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                  upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                  upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                  upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                  upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                  upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                  upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                  upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                  upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                  upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
                                  upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
                                  upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json jsonConfig.json application/json
                                  upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
                                  host.raspberrypi Adapter "system.adapter.admin.0" is started
                                  • K kimukao
                                    -> 6.2.20:
                                    -> 6.2.19:
                                    -> 6.2.18:
                                    -> 6.2.17:
                                    -> 6.2.16:
                                    -> 6.2.14:
                                    -> 6.2.13:
                                    NPM version: 8.15.0
                                    #235
                                    @kimukao
                                    Ich kann dir nicht helfen.
                                      @kimukao
                                      kimukao
                                      #236
                                      @thomas-braun Trotzdem danke, dass Du Dir so viel Zeit für mich genommen hast. Jemand anderes eine Idee?
                                      • mickymM Offline
                                        mickymM Offline
                                        mickym
                                        #237
                                        Wenn gar nichts mehr geht - und bevor ihr neu installiert - dann probiert halt meine Radikalmethode. ;) -
                                        K mickymM 2 Antworten Letzte Antwort
                                        • mickymM mickym
                                          kimukao
                                          #238
                                          @mickym die da wäre..? Machst mich neugierig
