  4. Test Adapter Hoover hON
184 Beiträge 34 Kommentatoren 49.2k Aufrufe 31 Beobachtet
  • E e-i-k-e
    @jkalver sagte in Test Adapter Hoover hON:
    Hallo @tombox ,
    Ich habe den Adapter (v0.0.6) installiert.
    Beim Starten bekomme ich folgende Fehler:
    Missing step1 url
    "*/{"event":{"descriptor":"markup://aura:systemError","attributes":{"values":{"message":"[AuraClientInputException from server] Unexpected request input. Expected input format: \"Data in a request must be a valid JSON Object and must be in the expected format.\".","showOverride":false}},"eventDef":{"descriptor":"markup://aura:systemError","t":"APPLICATION","xs":"G","a":{"message":["message","aura://String","G",false],"error":["error","aura://String","G",false],"auraError":["auraError","aura://Object","I",false,null],"timestamp":["timestamp","aura://Integer","I",false],"showOverride":["showOverride","aura://Boolean","I",false,false]}}},"exceptionMessage":"[AuraClientInputException from server] Unexpected request input. Expected input format: \"Data in a request must be a valid JSON Object and must be in the expected format.\".","exceptionEvent":true}/ERROR/"
    Meine Konfig:
    aarch64
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v18.15.0
    v18.15.0
    9.5.0
    4.0.23
    Was mache ich falsch?
    Gruss
    Jens
    Ich habe das gleiche Problem.
    Was läuft hier falsch?
    Den Weinkühlschrank habe ich in der h0n entfernt und zwei Klimaanlagen hinzugefügt.
    hoover.0
    2023-05-05 22:21:18.153	error	"*/{\"event\":{\"descriptor\":\"markup://aura:systemError\",\"attributes\":{\"values\":{\"message\":\"[AuraClientInputException from server] Unexpected request input. Expected input format: \\\"Data in a request must be a valid JSON Object and must be in the expected format.\\\".\",\"showOverride\":false}},\"eventDef\":{\"descriptor\":\"markup://aura:systemError\",\"t\":\"APPLICATION\",\"xs\":\"G\",\"a\":{\"message\":[\"message\",\"aura://String\",\"G\",false],\"error\":[\"error\",\"aura://String\",\"G\",false],\"auraError\":[\"auraError\",\"aura://Object\",\"I\",false,null],\"timestamp\":[\"timestamp\",\"aura://Integer\",\"I\",false],\"showOverride\":[\"showOverride\",\"aura://Boolean\",\"I\",false,false]}}},\"exceptionMessage\":\"[AuraClientInputException from server] Unexpected request input. Expected input format: \\\"Data in a request must be a valid JSON Object and must be in the expected format.\\\".\",\"exceptionEvent\":true}/*ERROR*/"
    hoover.0
    2023-05-05 22:21:18.152	error	Missing step1 url
    hoover.0
    2023-05-05 22:21:16.200	info	starting login
    hoover.0
    2023-05-05 22:21:16.134	info	starting. Version 0.0.7 in /opt/iobroker/node_modules/iobroker.hoover, node: v18.16.0, js-controller: 5.0.1-alpha.0-20230418-efa3e809
    tombox
    #81
    @e-i-k-e kannst du mir den account bitte mal zusenden zum anschauen
    E 1 Antwort Letzte Antwort
    • T tombox
      e-i-k-e
      #82
      @tombox Ja. Schick dir gleich eine PN.
      A 1 Antwort Letzte Antwort
      • E e-i-k-e
        astrakid
        #83
        ich habe nun einne bakcofen, der ebenfalls über hOn gesteuert wird. der aufbau der objekte ist analog zu dem einer waschmaschine. da ich gerne einzelne parameter über iobroker starten würde (die app zickt bei mir rum, so muss ich mich jeden tag neu anmelden, was mit komplexen passwörtern etwas nervig ist), wäre eine idee, verschiedene aufrufe zu sammeln ("remote -> send"), um darüber steuerungen für einzelne teile zusammenzubauen.
        ich fange einfach mal an:
          "macAddress": "id of the device set by adapter",
          "timestamp": "2022-05-10T08:16:35.010Z",
          "commandName": "startProgram",
          "programName": "PROGRAMS.TD.CARE_45",
          "transactionId": "2022-05-10T08:16:35.011Z",
          "applianceOptions": {
            "opt1": "anticrease",
            "opt2": "dryingManager",
            "opt3": "bestIroning",
            "opt4": "hybrid"
          "device": {
            "mobileOs": "ios",
            "mobileId": "2xxxxxx3-9xxE-4xx3-Axx8-1xxxxxxxxxx8",
            "osVersion": "15.5",
            "appVersion": "1.40.2",
            "deviceModel": "iPhone10,5"
          "attributes": {
            "prStr": "Care 45",
            "energyLabel": "0",
            "channel": "mobileApp",
            "origin": "lastProgram"
          "ancillaryParameters": {
            "dryTimeMM": "45",
            "energyLabel": "0",
            "functionalId": "8",
            "programFamily": "[dashboard]",
            "programRules": {
              "opt3": {
                "dryLevel": {
                  "2|3|4": {
                    "fixedValue": "0",
                    "typology": "fixed"
              "dryTime": {
                "dryTimeMM": {
                  "30": {
                    "fixedValue": "1",
                    "typology": "fixed"
                  "45": {
                    "fixedValue": "2",
                    "typology": "fixed"
                  "59": {
                    "fixedValue": "3",
                    "typology": "fixed"
                  "70": {
                    "fixedValue": "4",
                    "typology": "fixed"
                  "80": {
                    "fixedValue": "5",
                    "typology": "fixed"
                  "90": {
                    "fixedValue": "6",
                    "typology": "fixed"
                  "100": {
                    "fixedValue": "7",
                    "typology": "fixed"
                  "110": {
                    "fixedValue": "8",
                    "typology": "fixed"
                  "120": {
                    "fixedValue": "9",
                    "typology": "fixed"
                  "130": {
                    "fixedValue": "10",
                    "typology": "fixed"
                  "140": {
                    "fixedValue": "11",
                    "typology": "fixed"
                  "150": {
                    "fixedValue": "12",
                    "typology": "fixed"
                  "160": {
                    "fixedValue": "13",
                    "typology": "fixed"
                  "170": {
                    "fixedValue": "14",
                    "typology": "fixed"
                  "180": {
                    "fixedValue": "15",
                    "typology": "fixed"
                  "190": {
                    "fixedValue": "16",
                    "typology": "fixed"
                  "200": {
                    "fixedValue": "17",
                    "typology": "fixed"
                  "210": {
                    "fixedValue": "18",
                    "typology": "fixed"
                  "220": {
                    "fixedValue": "19",
                    "typology": "fixed"
              "dryLevel": {
                "opt3": {
                  "1": {
                    "fixedValue": "1",
                    "typology": "fixed"
            "remoteActionable": "1",
            "remoteVisible": "1",
            "suggestedLoadD": "2"
          "parameters": {
            "dryTime": "2",
            "dryingManager": "0",
            "hybrid": "1",
            "checkUpStatus": "0",
            "anticrease": "0",
            "delayTime": "0",
            "prCode": "54",
            "prPosition": "13",
            "dryLevel": "0",
            "bestIroning": "0",
            "onOffStatus": "1"
          "applianceType": "TD"
          @astrakid sagte in Test Adapter Hoover hON:
          Wie kann ich einen Waschvorgang pausieren und wieder fortsetzen? In der App gibt es die Funktion, im Adapter habe ich den Datenpunkt noch nicht gefunden auf die Schnelle...
          Moin,
          schon mal in ioBroker unter Objekte in die Suche pause eingegeben?
          Datenpunkte meine Haier Waschmaschine:
          Ob das dann geht, kann ich gerade nicht testen, nichts zum Waschen da :)
          VG
          Bernd
          astrakid
          #84
          @dp20eic sagte in Test Adapter Hoover hON:
          ich habe keine entsprechenden datenpunkte... nur einen aus der history...?!
          • A astrakid
            astrakid
            #85
            hi,
            ich bekomme neuerdings folgende fehlermeldung:
            AxiosError: Request failed with status code 301
            die app scheint nicht mehr zu funktionieren bei mir. neue URLs?
            ? 1 Antwort Letzte Antwort
            • A astrakid
              hi,
              #86
              Moin,
              bei mir auch, in zwei Installationen, habe ein issues aufgemacht.
              https://github.com/TA2k/ioBroker.hoover/issues/9
              VG
              Bernd
                tombox
                #87
                @astrakid bitte 0.1.0 testen
                ? A 3 Antworten Letzte Antwort
                • T tombox
                  #88
                  @tombox sagte in Test Adapter Hoover hON:
                  Moin,
                  nop, siehe neue Logs bei Github.
                  VG
                  Bernd
                  • Palm_ManiacP Offline
                    Palm_Maniac
                    #89
                    Der Fehler 301 tritt bei mir seit dem Update auf V0.1.0 auch auf. Nutze die Hoover Schnittstelle.
                    • T tombox
                      astrakid
                      #90
                      @tombox wie bei meinen vorschreibern: klappt nicht.
                      • T tombox
                        #91
                        Moin,
                        auf Anraten von @tombox habe ich die Version nochmals über github installiert
                        Anschließend wurde der Adapter gelb und die Fehlermeldung tauchte wieder im Log auf, siehe Github
                        Ich habe anschließend noch ein Upload aus ioBroker heraus angestoßen, danach ein Restart des Adapters und er wurde wieder Grün :)
                        Upload, z.B.: so:
                        VG
                        Bernd
                        Palm_ManiacP 1 Antwort Letzte Antwort
                          Moin,
                          Upload, z.B.: so:
                          VG
                          Bernd
                          Palm_Maniac
                          schrieb am zuletzt editiert von Palm_Maniac
                          #92
                          @dp20eic Ich habs mal nach deiner Anleitung versucht, brachte aber nichts. Der Adapter bleibt gelb und im Log steht weiterhin Fehlercode 301.
                          PS: Jetzt läuft auch die Vorgängerversion V0.0.7 nicht mehr, die vor dem Update perfekt funktionierte. Das hier steht im Log:
                          hoover.0 2023-06-06 16:01:03.789	error	""
                          hoover.0 2023-06-06 16:01:03.788	error	AxiosError: Request failed with status code 301
                          • Palm_ManiacP Palm_Maniac
                            #93
                            @palm_maniac sagte in Test Adapter Hoover hON:
                            Moin,
                            das ist seltsam, in beiden ioBroker Installationen, die ich betreibe, hat es genau so funktioniert 🤔
                            Hast Du mal mit einer zweiten Instanz versucht, ist das Passwort auch wirklich korrekt?
                            VG
                            Bernd
                            Installation debian:
                            Installation arch linux
                              Moin,
                              VG
                              Bernd
                              Palm_Maniac
                              #94
                              @dp20eic Die Zugangsdaten funktionieren in der App. Hab gerade mal ne neue Instanz versucht mit dem gleichen Ergebnis und Fehlercode. Alles erst seit dem Update von V0.0.7 auf V0.1.0.
                                #95
                                Moin,
                                ah, da könnte der Hund auch noch begraben liegen.
                                Bei mir ist es die hOn-APP bei Dir auch?
                                VG
                                Bernd
                                P.S.: Sollte es bei Dir der Hoover-Wiz sein, dann musst Du mal bei Github bei meinem Issues Deine Daten mit anhängen, sodass @tombox sich das anschauen kann, vielleicht haben sich die Logins der beiden APPs verändert und sind nicht mehr kompatibel.
                                  Moin,
                                  VG
                                  Bernd
                                  Palm_Maniac
                                  #96
                                  @dp20eic ja, ich nutze den Hover-Wizard Zugang, nicht hON. Hab mich mal an den Issue in Github rangehängt.
                                    tombox
                                    #97
                                    @palm_maniac für hover wizard brauch ich nochmal Zugangsdaten um das zu fixen
                                    Palm_ManiacP sigi234S 2 Antworten Letzte Antwort
                                    • T tombox
                                      Palm_Maniac
                                      #98
                                      @tombox Hab dir ne PN geschickt.
                                      • T tombox
                                        sigi234S Online
                                        sigi234S Online
                                        sigi234
                                        #99
                                        Hallo, geht bei mir auch nicht? [hover wizard]
                                        hoover.0
                                        2023-06-14 20:55:22.986	info	starting login
                                        hoover.0
                                        2023-06-14 20:55:22.975	info	starting. Version 0.1.1 (non-npm: TA2k/ioBroker.hoover#7deb12caf1e561fde36b85d4a8afd7016896095e) in C:/ioBroker/_iob_Test/node_modules/iobroker.hoover, node: v18.16.0, js-controller: 4.0.24
                                        hoover.0
                                        2023-06-14 20:55:23.746	error	AxiosError: Unsupported protocol javascript:
                                        hoover.0
                                        2023-06-14 20:55:23.746	error	Login step #3 failed
                                        Version: 0.1.1
                                        Immer Daten sichern!
                                        • A astrakid
                                          Dave83
                                          #100
                                          @astrakid said in Test Adapter Hoover hON:
                                          Hast du es erfolgreich schaffen können, deine Waschmaschine mit ioBroker zu automatisieren? Ich denke gerade darüber nach, ebenfalls dort ein Model zu kaufen. Preislich sind die sehr attraktiv. Über deine Rückmeldung würde ich mich freuen.
                                          Insgesamt, ist es schwierig, eine smarte Waschmaschine mit Unterstützung für ioBroker zu finden.
