  4. Adapter: DasWetter
    6.7k
Adapter: DasWetter
1.7k Beiträge 249 Kommentatoren 705.0k Aufrufe 133 Beobachtet
  • NegaleinN Negalein
    @Feuersturm sagte in Adapter: DasWetter:
    oder z.B. in vis1 verwenden kann?
    mein Widget
    [{"tpl":"tplImage","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"{daswetter.0.location_1.ForecastDaily.Day_1.symbol_URL}","stretch":true,"refreshOnWakeUp":true,"refreshOnViewChange":true},"style":{"left":"53px","top":"111px","width":"200px","height":"200px","z-index":"100"},"widgetSet":"basic"}]
    basic Image
    und als Quelle {daswetter.0.location_1.ForecastDaily.Day_1.symbol_URL}
    FeuersturmF Offline
    FeuersturmF Offline
    Feuersturm
    #1321
    @Negalein sagte in Adapter: DasWetter:
    basic Image
    Danke. Leider wird bei mir mit diesem Widget und der Quelle nichts angezeigt.
    • FeuersturmF Feuersturm
      @Merlin123 Kannst du mir sagen, wie ich mir die Wetter icons anzeigen lassen kann oder z.B. in vis1 verwenden kann?
      Merlin123M Offline
      Merlin123M Offline
      Merlin123
      schrieb am zuletzt editiert von Merlin123
      #1322
      @Feuersturm Ich nutze aktuell Vis2 und nehme als Bildquelle au h ein Bind auf den DP mit der URL des Bildes
      z.B. {daswetter.0.location_1.ForecastDaily.Day_1.Moon_symbol_URL}
      Als Widget hab ich die Inventwo Widgets.
      Beta-Tester
      • FeuersturmF Offline
        FeuersturmF Offline
        Feuersturm
        #1323
        @negalein Es funktioniert :) War mein Fehler, wenn man den Vis Editor auf dem falschen Testsystem startet wo nicht die korrekte Instanz von daswetter installiert ist :-D
        • Merlin123M Merlin123
          @1Topf Boah.... Ja... Du hast recht....
          Ich habe nach der aktuellen Mondphase gegoogelt und da steht
          Abnehmender Halbmond
          Jo... wenn man dann die Seite anklickt steht da:
          "Abnehmender Halbmond Erleuchtung: 98%"
          was eigentlich fast Vollmond ist. Da muss man erstmal drauf kommen....
          aber: Wieso wird der Vollmond dunkel dargestellt? Hätte da was helleres erwartet....
          1Topf1 Offline
          1Topf1 Offline
          1Topf
          #1324
          @Merlin123 sagte in Adapter: DasWetter:
          Ja, eigentlich sollte der Neumond dunkel dargestellt werden und der Vollmond hell.
            #1325
            Hast du den Browser auf den Dark-Mode gesetzt? Das kann u. U. zu solchen Falschfarben führen.
            • Merlin123M Offline
              Merlin123M Offline
              Merlin123
              #1326
              Hab jetzt mal versucht andere Icons einzubinden, aber die zeigt er aktuell noch nicht an, obwohl die URL richtig aussieht.
              @thomas-braun Jup. Aber bei Bildern sollte das eigentlich egal sein.....wenn ich das Icon mal via WinSCP anzeigen lasse, sieht es auch aus wie auf meinem Screenshot.
              Beta-Tester
              NegaleinN 1Topf1 2 Antworten Letzte Antwort
                NegaleinN Offline
                NegaleinN Offline
                Negalein
                #1327
                eigene Icons?
                Das mach ich mit dem Image8 Widget.
                ° Fixer ---> iob fix
                  1Topf1 Offline
                  1Topf1 Offline
                  1Topf
                  #1328
                  Du mußt ein Adapter Upload machen.
                  Merlin123M 1 Antwort Letzte Antwort
                  • Rene_HMR Rene_HM
                    @stefu87_CH @rumpeltec Wenn so häufig abgerufen wird, erklärt das auch den 429 - Status.
                    Die Frage ist nur, warum wird das update-Intervall nicht eingehalten. Kann es sein, dass aufgrund der Versuche mit dem Adapter noch irgendetwas bei euch im Hintergrund läuft? Im Adapter selbst läuft eigentlich nur ein s.g. intervall mit der eingestellten Zeit. Den Rest macht das System selbst. Beim Beenden des Adapters räume ich das intervall auf. Also sollte eigentlich alles drin sein, was notwendig ist.
                    -> velleicht die Systeme bei euch mal neu starten?
                    Rumpeltec
                    schrieb am zuletzt editiert von Rumpeltec
                    #1329
                    @Rene_HM
                    Ich habe alles neu gestartet, Adapter angehalten, Datenpunkte mal komplett gelöscht und durch den Neustart des Adapter wieder neu anlegen lassen.
                    Es wird keine Symbolbeschreibung angezeigt. Selbst heute früh, nach nun mehreren Stunden Ruhe, ohne das ich immer wieder manuell Daten abgerufen habe, erhalte ich denselben 429 Fehler. Diesen aber nur in Bezug auf die Symbole, denn die Wetterdaten wurden ja aktualisiert.
                    Alternative Möglichkeit wäre nun noch, mal einen zweiten Account mit API anzulegen und damit die Daten abzurufen.
                    Nachtrag:
                    Neuen Account beim Anbieter angelegt, Adapter gelöscht und neu installiert. Nun funktioniert alles wie es soll.
                    • 1Topf1 1Topf
                      Merlin123M Offline
                      Merlin123M Offline
                      Merlin123
                      #1330
                      @1Topf hab schon die 4.3
                      @negalein teste ich mal. Ich nutze eigentlich die Inventwo Icons. Die Sonner zeigt er auch richtig an.
                      Beta-Tester
                      1Topf1 1 Antwort Letzte Antwort
                        Merlin123M Offline
                        Merlin123
                        #1331
                        Also ich verstehe es nicht....
                        Wenn ich eine Custom URL nehme und die mitgelieferten Icons wird das Bild angezeigt. Nehme ich "meine" Icons kann er das nicht anzeigen. Die Berechtigung für Directory und Files sind auf 777.
                        Sieht jemand vielleicht in den Screenshots, was ich falsch mache?
                        Unten das Bild, das eigentlich angezeigt werden müsste
                        Bonusfrage: Wo werden die Bilder eigentlich gecached? Ich habe jetzt "meine" Icons einfach mal in das Verzeichnis des Adapers kopiert, es werden aber die ursprünglichen Icons gezeigt. Hab extra mal nen anderen Browser probiert, das ist nicht das Problem.
                        Beta-Tester
                        • WG25W Offline
                          WG25W Offline
                          WG25
                          #1332
                          Moin!
                          Bei mir werden die Tageswerte nicht aktualisiert. In Day_1 stehen immer noch die Werte von Sonntag, in Day_2 die Werte von heute usw.
                          Ich bekomme auch keine Fehlermeldung beim Neustart des Adapters. Laut Statistik auf meteored.com habe ich noch nicht zu oft abgerufen.
                          Problem bekannt?
                          Merlin123M Pedder007P H 3 Antworten Letzte Antwort
                          • WG25W WG25
                            Moin!
                            Problem bekannt?
                            Merlin123M Offline
                            Merlin123M Offline
                            Merlin123
                            #1333
                            @Arne-Dieckmann Bei mir hat er es aktualisiert.... Vielleicht mal Log Level auf Debug und Adapter neu starten. Dann mal das Log prüfen
                            Beta-Tester
                              HomoranH Offline
                              HomoranH Offline
                              #1334
                              wie?
                              sind die in der vis registriert?
                              • WG25W WG25
                                Moin!
                                Problem bekannt?
                                Pedder007P Offline
                                Pedder007P Offline
                                Pedder007
                                schrieb am zuletzt editiert von Pedder007
                                #1335
                                @Arne-Dieckmann bei mir läuft alles.
                                Außer dem String/Date Formatproblem bei Sonne/Mond-in/out gibt es auch keine Fehlermeldungen im Log. Bin auf der 4.3.0.
                                Als icons nehme ich nun die 'galeria7', funktioniert einwandfrei, auch wenn ich die anderen Grafiken in 'galeria1' schöner fand ;-) ... Kosmetik ;-)
                                Bei mir wird auch defintiv regelmäßig aktualisiert, auch wenn meine Zugriffe in der Statistik auf Anschlag stehen:
                                Pedder
                                All @Proxmox/Trixie auf HP Elitedesk 800 G4; Zigbee: ZigStar (LAN), ~110Devices
                                Unifi, Motioneye/3Reolinks, PiHole, Bosch CS7800i via BBQKees/EMS-ESP, Fronius/BYD 11kWp via Modbus
                                Under construction: Smart-WoMo auf Raspi4
                                • WG25W Offline
                                  WG25W Offline
                                  WG25
                                  schrieb am zuletzt editiert von WG25
                                  #1336
                                  Der Abruf für Tage und Stunden findet statt und wird scheinbar auch positive beantwortet. Die Werte, die da als Antwort kommen, sind aber genau die von gestern. Vermutlich sind die Daten auf "daswetter" nicht korrekt.
                                  DasWetter_0: Meteored GetForecastDaily response: {"ok":true,"expiracion":1767603600000,"data":{"hash":"0c4bd471c213721742c35b66685ed54a","name":"Jork","url":"https://www.theweather.com/jork.htm","days":[{"start":1767481200000,"symbol":24,"temperature_min":-9.31,"temperature_max":-0.8,"wind_speed":18,"wind_gust":31,"wind_direction":"SW","rain":5.4,"rain_probability":70,"humidity":89,"pressure":1004,"snowline":0,"uv_index_max":0.3,"sun_in":1767512207000,"sun_mid":1767525973000,"sun_out":1767539756000,"moon_in":1767543870000,"moon_out":1767516774000,"moon_symbol":15,"moon_illumination":98.46},{"start":1767567600000,"symbol":24,"temperature_min":-5.71,"temperature_max":-2.04,"wind_speed":17,"wind_gust":28,"wind_direction":"SW","rain":1.4,"rain_probability":60,"humidity":89,"pressure":1009,"snowline":0,"uv_index_max":0.3,"sun_in":1767598584000,"sun_mid":1767612400000,"sun_out":1767626233000,"moon_in":1767635879000,"moon_out":1767604503000,"moon_symbol":16,"moon_illumination":94.31},{"start":1767654000000,"symbol":4,"temperature_min":-9.76,"temperature_max":-3.33,"wind_speed":12,"wind_gust":20,"wind_direction":"S","rain":0,"rain_probability":20,"humidity":93,"pressure":1011,"snowline":0,"uv_index_max":0.3,"sun_in":1767684959000,"sun_mid":1767698827000,"sun_out":1767712713000,"moon_in":1767727583000,"moon_out":1767691798000,"moon_symbol":17,"moon_illumination":88.02},{"start":1767740400000,"symbol":24,"temperature_min":-10.35,"temperature_max":0.09,"wind_speed":26,"wind_gust":45,"wind_direction":"S","rain":0.7,"rain_probability":70,"humidity":86,"pressure":1006,"snowline":0,"uv_index_max":0.3,"sun_in":1767771329000,"sun_mid":1767785253000,"sun_out":1767799195000,"moon_in":1767818949000,"moon_out":1767778859000,"moon_symbol":18,"moon_illumination":80.15},{"start":1767826800000,"symbol":20,"temperature_min":-1.7,"temperature_max":2.32,"wind_speed":26,"wind_gust":48,"wind_direction":"S","rain":2.3,"rain_probability":80,"humidity":92,"pressure":1002,"snowline":0,"uv_index_max":0.4,"sun_in":1767857696000,"sun_mid":1767871678000,"sun_out":1767885680000,"moon_in":1767910060000,"moon_out":1767865802000,"moon_symbol":19,"moon_illumination":71.21}]}}
                                  • Pedder007P Offline
                                    Pedder007P Offline
                                    Pedder007
                                    #1337
                                    Echt komisch, ich bin mir ziemlich sicher das bei mir wirklich aktualisiert wird. Da haben sich ein paar Daten seit gestern defintiv geändert, auch wenn man sich ja nicht jedes Detail der VIS merkt.
                                    Auch entspricht das, was ich draußen sehe, ziemlich genau den Daten die aktuell angezeigt werden.
                                    Ich habe nun aber zusätzlich mal einen Gesamt-Screenshoot gemacht (ist einfacher als den Objektbaum zu vergleichen) und werde das gegen Abend mal gegenchecken.
                                    Pedder
                                    • WG25W WG25
                                      Moin!
                                      Problem bekannt?
                                      hm_krause
                                      #1338
                                      @Arne-Dieckmann sagte in Adapter: DasWetter:
                                      Moin!
                                      Problem bekannt?
                                      ...leider bei mir genauso...
                                        mathy
                                        #1339
                                        Hab die Adapter-Instanz neu erstellt, dann wurde die Daten wieder aktualisiert für Montag. Bei mir standen auch noch die von Sonntag drinnen.
                                        WG25W 1 Antwort Letzte Antwort
                                          wie?
                                          Merlin123M Offline
                                          Merlin123M Offline
                                          Merlin123
                                          #1340
                                          @Homoran Wie kann ich die da registrieren? Die liegen nicht im VIS Verzeichnis, sondern unter
                                          /daswetter.admin/icons/luna-moon/16.png
                                          Beta-Tester
