  4. Test Adapter OpenKNX 0.6.x
    1.0k
    6.1k
587 Beiträge 74 Kommentatoren 205.3k Aufrufe 73 Beobachtet
  • C ChrisChros
    @killroy2
    ich habe heute meinem Pi neu starten müssen. Dabei habe ich festgestellt das ich folgende Einträge im Log vorfinde:
    2023-02-03 20:47:43.877  - error: openknx.0 (630) [error] 2023-02-03 19:47:43.875 (idle): Incomplete/unparseable UDP packet: Error: Invalid data for GA 3/1/14
        at fsm.event (/opt/iobroker/node_modules/iobroker.openknx/main.js:583:35)
        at fsm.<anonymous> (/opt/iobroker/node_modules/machina/lib/webpack:/src/emitter.js:27:1)
        at arrayEach (/opt/iobroker/node_modules/lodash/lodash.js:530:11)
        at Function.forEach (/opt/iobroker/node_modules/lodash/lodash.js:9410:14)
        at fsm.emit (/opt/iobroker/node_modules/machina/lib/webpack:/src/emitter.js:25:1)
        at fsm.emitEvent (/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/FSM.js:673:10)
        at fsm._onEnter (/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/FSM.js:579:14)
        at fsm.transition (/opt/iobroker/node_modules/machina/lib/webpack:/src/BehavioralFsm.js:175:1)
        at fsm.Fsm.<computed> [as transition] (/opt/iobroker/node_modules/machina/lib/webpack:/src/Fsm.js:80:1)
        at fsm.inbound_TUNNELING_REQUEST_L_Data.ind (/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/FSM.js:368:16): 06100420001704a3b4002900bce01133190e03008007df
    2023-02-03 20:47:43.892  - info: host.raspberrypi "system.adapter.openknx.0" disabled
    2023-02-03 20:47:43.899  - info: host.raspberrypi stopInstance system.adapter.openknx.0 (force=false, process=true)
    2023-02-03 20:47:43.917  - info: openknx.0 (630) Got terminate signal TERMINATE_YOURSELF
    2023-02-03 20:47:43.922  - info: openknx.0 (630) terminating
    2023-02-03 20:47:43.925  - info: openknx.0 (630) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-02-03 20:47:44.003  - info: host.raspberrypi stopInstance system.adapter.openknx.0 send kill signal
    2023-02-03 20:47:44.513  - info: host.raspberrypi instance system.adapter.openknx.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-02-03 20:47:49.621  - info: host.raspberrypi "system.adapter.openknx.0" enabled
    2023-02-03 20:47:49.866  - info: host.raspberrypi instance system.adapter.openknx.0 started with pid 2394
    2023-02-03 20:47:52.196  - info: openknx.0 (2394) starting. Version 0.5.2 in /opt/iobroker/node_modules/iobroker.openknx, node: v16.19.0, js-controller: 4.0.24
    2023-02-03 20:47:52.234  - info: openknx.0 (2394) Connecting to knx gateway:  10.10.20.2:3671 minimum send delay: 50ms debug level: info
    2023-02-03 20:47:52.235  - info: openknx.0 (2394) /opt/iobroker/node_modules/iobroker.js-controller
    2023-02-03 20:47:53.059  - info: openknx.0 (2394) Connected!
    2023-02-03 20:47:53.273  - info: openknx.0 (2394) Found 939 valid KNX objects of 941 objects in adapter.
    Der Adapter ist zu diesem Zeitpunkt nicht richtig gestartet und von Status gelb. Sobald ich den Adapter neu starte läuft er ohne Probleme.
    Woran kann das liegen?
    killroy2
    #461
    @chrischros kannst du bitte noch die Zeilen zu openknx.0 davor posten?
    C 1 Antwort Letzte Antwort
    • K killroy2
      ChrisChros
      schrieb am zuletzt editiert von ChrisChros
      #462
      @killroy2 hier die Einträge vom Herunterfahren und Neustart des RaspberryPi:
      2023-02-03 17:43:10.806  - info: host.raspberrypi stopInstance system.adapter.openknx.0 (force=false, process=true)
      2023-02-03 17:43:10.883  - info: openknx.0 (676) Got terminate signal TERMINATE_YOURSELF
      2023-02-03 17:43:10.927  - info: host.raspberrypi stopInstance system.adapter.openknx.0 send kill signal
      2023-02-03 17:43:10.932  - info: openknx.0 (676) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2023-02-03 17:43:11.642  - warn: openknx.0 (676) Could not perform strict object check of state openknx.0.Schalten.Stromwert.KG_-_HWR_-_Trockner_-_Stromwert: DB closed
      2023-02-03 17:43:11.643  - warn: openknx.0 (676) get state error: Connection is closed.
      2023-02-03 17:43:12.147  - info: host.raspberrypi instance system.adapter.openknx.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2023-02-03 17:44:10.924  - info: host.raspberrypi instance system.adapter.openknx.0 started with pid 630
      2023-02-03 17:44:13.847  - info: openknx.0 (630) starting. Version 0.5.2 in /opt/iobroker/node_modules/iobroker.openknx, node: v16.19.0, js-controller: 4.0.24
      2023-02-03 17:44:13.917  - info: openknx.0 (630) Connecting to knx gateway:  10.10.20.2:3671 minimum send delay: 50ms debug level: info
      2023-02-03 17:44:13.919  - info: openknx.0 (630) /opt/iobroker/node_modules/iobroker.js-controller
      2023-02-03 17:44:14.234  - error: openknx.0 (630) [error] 2023-02-03 16:44:14.182 (idle): Incomplete/unparseable UDP packet: Error: Invalid data for GA 1/5/4
          at fsm.inbound_TUNNELING_REQUEST_L_Data.ind (/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/FSM.js:368:16): 061002080008a300
      2023-02-03 17:44:14.343  - error: openknx.0 (630) [error] 2023-02-03 16:44:14.340 (idle): Incomplete/unparseable UDP packet: Error: Invalid data for GA 4/4/73
          at fsm.inbound_TUNNELING_REQUEST_L_Data.ind (/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/FSM.js:368:16): 06100420001504a301002900bce011fe2449010081
      Und hier noch die Einstellung von der GA 1/5/4 die er oben als erstes bemängelt:
        "_id": "openknx.0.Schalten.Stromwert.KG_-_HWR_-_Trockner_-_Stromwert",
        "type": "state",
        "common": {
          "desc": "Basetype: 16-bit unsigned value",
          "min": 0,
          "max": 65535,
          "name": "KG - HWR - Trockner - Stromwert",
          "read": true,
          "role": "state",
          "type": "number",
          "unit": "mA",
          "write": true
        "native": {
          "address": "1/5/4",
          "answer_groupValueResponse": false,
          "autoread": true,
          "bitlength": 16,
          "dpt": "DPT7.012",
          "valuetype": "basic"
        "from": "system.adapter.openknx.0",
        "user": "system.user.admin",
        "ts": 1645349968666,
        "acl": {
          "object": 1636,
          "state": 1636,
          "owner": "system.user.admin",
      Aber ich glaube daran liegt es nicht, denn nachdem der Adapter manuell neu gestartet wird funktioniert ja alles wie gewohnt.
      Gruß Chris
      • K Offline
        killroy2
        schrieb am zuletzt editiert von killroy2
        #463
        @chrischros said in Test Adapter OpenKNX 0.2.x:
        1/5/4
        ist Zufall, weil es vermutlich deine erste Adresse ist.
        Ich verstehe noch nicht genau was hier passiert, die Meldung "Invalid data for GA" sollte eigentlich nie kommen. Das wäre der Fall wenn ein Event kommt noch vor Connect abgeschlossen ist. Ich muss in die Lib analysieren ob die Annahme wirklich zutrifft..
        • N Offline
          N Offline
          Nobody 0
          #464
          ich habe ein Verständnis Problem mit dem Wert den ich per KNX abhole.
          Ich habe einen Hager KNX Energie Zähler den ich gerne auslesen möchte. Hier die Daten aus der ETS, es sollten etwa 150W Verbrauch angezeigt werden,
          Im ioBroker wird mir aber dieser Wert angezeigt:
          Das steht in der xml Export Datei:
          <?xml version="1.0" encoding="utf-8" standalone="yes"?>
          <GroupAddress-Export xmlns="http://knx.org/xml/ga-export/01">
            <GroupAddress Name="Summe Leistung W" Address="1/4/0" DPTs="DPST-13-10" />
          </GroupAddress-Export>
          Was mache ich Falsch das ich hier den Korrekten wert Angezeigt bekomme.
          Danke für eure Hilfe.
          • N Nobody 0
            mane444
            #465
            @nobody-0 sagte in Test Adapter OpenKNX 0.2.x:
            DPST-13-10
            Du hast hier scheinbar einen Fehler in der Zuordnung von Datentyp und Gruppenadresse.
            Bei deinem ersten Screenshot zeigst du die aktuelle Leistung Gruppe 1/4/0 Datentyp: 14.056.
            Was du ausliest ist der Zählerstand in Wh Gruppe 1/4/0 Datentyp 13.010.
            Lese mal mit der ETS die Gruppenwerte aus und vergleiche dann.
              Automatisierer 0
              #466
              Re: Test Adapter OpenKNX 0.2.x
              Ich habe vom proprietären KNX-Adapter auf den OpenKNX adapter umgestellt.
              Mein Feedback:
              Ich habe noch nie eine so problemlose Umstellung erlebt!
              Alles hat super geklappt (wie in der Beschreibung angegeben)
              Und der Adapter funktioiert bis jetzt bestens und problemos!
              VIELEN DANK FÜR DEN SUPER ADAPTER
              Ein kleiner Punkt verwirrt mich:
              Nach dem erfolgreichen einlesen des XML Files kann man nur rechts unten den Button CLOSE drücken.
              Ich hätte mir eigentlich erwartet, dass ich den Button "SAVE" oder "SAVE AND CLOSE" drücken muss.
                Automatisierer 0
                #467
                Frage zur Verfügbarkeit der Version 0.5.2 (2023-01-02):
                Ich habe die Version 0.2.5 intalliert
                Es soll ja bereits die Version 0.5.2 (2023-01-02) geben.
                Diese wird wir aber in der 2. Spalte "Available" nicht angezeigt.
                Auch nicht, wenn ich auf Beta-Repository umstelle.
                Wie kann ich die Version 0.5.2 installieren?
                • A Automatisierer 0
                  Tontechniker
                  #468
                  @automatisierer-0 Hallo! den kann man zur Zeit nur über "Adapter", "Expertenmodus", "Katze", "Benutzerdefiniert" und diesen Link:
                  https://github.com/iobroker-community-adapters/ioBroker.openknx.git
                  bei "URL" eintragen und mit "Install" installieren. Melde dich, wenn du Probleme damit hast!
                  Hans
                  Hant0rH 1 Antwort Letzte Antwort
                  • T Tontechniker
                    Hans
                    Hant0rH Offline
                    Hant0rH Offline
                    Hant0r
                    #469
                    @tontechniker Danke dir für die Erklärung.
                    Wieso muss man das denn so umständlich machen und wird nicht, wie andere Adapter, über den "normalen Weg" angeboten?
                    • Hant0rH Hant0r
                      Tontechniker
                      schrieb am zuletzt editiert von Tontechniker
                      #470
                      @hant0r Das liegt daran, dass dies noch keine offizielle Version ist (Testversion!). 0.2.5 ist die vom Entwickler freigegebene Version. Er hat aber schon angekündigt, dass die 0.5.2, wenn keine Probleme im Dauertest auftauchen, die offizielle Version 1.0.0 wird und dann unter "Adapter" abrufbar ist.
                      • T Tontechniker
                        Hant0rH Offline
                        Hant0rH Offline
                        Hant0r
                        #471
                        @tontechniker danke dir.
                        Also kann man bedenkenlos auf diese Version gehen?!
                        Habe gerade erst alles auf openknx gewechselt - ohne Probleme - Respekt und danke dafür @killroy2
                        • Hant0rH Hant0r
                          Tontechniker
                          #472
                          @hant0r Bei mir läuft die 0.5.2 schon seit einigen Wochen ohne Probleme!
                          Hans
                            Sam 0
                            #473
                            Hi, kann mir villeicht jemand sagen ob es möglich ist zwischen Leseanfrage und Schreibtelegramme zu unterscheiden?
                            K 1 Antwort Letzte Antwort
                              Automatisierer 0
                              #474
                              Es verwirrt mich:
                                Automatisierer 0
                                #475
                                Problem mit HVAC-Mode:
                                Ich habe die folgende Fehlermeldung im Log:
                                openknx.0
                                	2023-03-01 22:44:47.874	warn	[warn] "2023-03-01T21:44:47.874Z" 'DPT1.fromBuffer: buf should be 1 byte (got 2 bytes)' 2
                                openknx.0
                                	2023-03-01 22:44:47.695	warn	[warn] "2023-03-01T21:44:47.695Z" 'DPT1.fromBuffer: buf should be 1 byte (got 2 bytes)' 2
                                openknx.0
                                	2023-03-01 22:44:47.645	warn	[warn] "2023-03-01T21:44:47.645Z" 'DPT1.fromBuffer: buf should be 1 byte (got 2 bytes)' 2
                                openknx.0
                                	2023-03-01 22:44:47.592	warn	[warn] "2023-03-01T21:44:47.592Z" 'DPT1.fromBuffer: buf should be 1 byte (got 2 bytes)' 2
                                openknx.0
                                	2023-03-01 22:44:47.269	warn	[warn] "2023-03-01T21:44:47.269Z" 'DPT1.fromBuffer: buf should be 1 byte (got 2 bytes)' 2
                                openknx.0
                                	2023-03-01 22:44:46.822	warn	[warn] "2023-03-01T21:44:46.822Z" 'DPT1.fromBuffer: buf should be 1 byte (got 2 bytes)' 2
                                Der Datenpunt sieht folgendermaßen aus:
                                  "_id": "openknx.0.Heizung_und_Temp_(HZ).Gar__Wkst_.HZ_-_GH_-_El_Radiator_Beide_-_Betriebsartvorwahl_(Komfort_Nacht_Frost)",
                                  "type": "state",
                                  "common": {
                                    "desc": "Basetype: 1-byte",
                                    "name": "HZ - GH - El.Radiator Beide - Betriebsartvorwahl (Komfort/Nacht/Frost)",
                                    "read": true,
                                    "role": "state",
                                    "type": "number",
                                    "write": true
                                  "native": {
                                    "address": "6/4/35",
                                    "autoread": true,
                                    "bitlength": 8,
                                    "dpt": "DPT20.102",
                                  "ts": 1677706626491,
                                  "acl": {
                                    "object": 1636,
                                    "state": 1636,
                                Hier die Projektierung in der ETS:
                                Frage:
                                Wo ist das Problem ?
                                Was ist falsch?
                                T M K 3 Antworten Letzte Antwort
                                  openknx.0
                                  openknx.0
                                  openknx.0
                                  openknx.0
                                  openknx.0
                                  openknx.0
                                    "type": "state",
                                    "common": {
                                      "read": true,
                                      "role": "state",
                                      "type": "number",
                                      "write": true
                                    "native": {
                                      "autoread": true,
                                      "bitlength": 8,
                                      "dpt": "DPT20.102",
                                    "acl": {
                                      "object": 1636,
                                      "state": 1636,
                                  Frage:
                                  Was ist falsch?
                                  Tontechniker
                                  #476
                                  @automatisierer-0 Ich bin mir nicht sicher, ob der "DPT20.102" in der Software verfügbar ist. Da kann vermutlich nur
                                  killroy2 was zu sagen.
                                    openknx.0
                                    openknx.0
                                    openknx.0
                                    openknx.0
                                    openknx.0
                                    openknx.0
                                      "type": "state",
                                      "common": {
                                        "read": true,
                                        "role": "state",
                                        "type": "number",
                                        "write": true
                                      "native": {
                                        "autoread": true,
                                        "bitlength": 8,
                                        "dpt": "DPT20.102",
                                      "acl": {
                                        "object": 1636,
                                        "state": 1636,
                                    Frage:
                                    Was ist falsch?
                                    mane444
                                    #477
                                    @automatisierer-0 Ich hab bei mir auch HVAC Gruppenadressen, mit dem gleichen Datentyp und auch die restliche Datenpunkt-Konfiguration ist wie bei dir. Beim schalten bekomm ich keine Warnmeldung.
                                    Verbaut sind bei mir MDT Glastaster und Heizungsaktoren.
                                    Ich nehme an das du hier ein Gerät hast das auf den Bus 2 Bytes schreibt. Bekommst du die Warnung auch wenn du die Busadresse über die ETS steuerst?
                                    Was hast du für eine Adapterversion? Bei mir läuft 0.2.7
                                      Automatisierer 0
                                      #478
                                      @killroy2
                                      Hier eine Zusatzinfo zu Problem mit dem HVAC-Modus DPT20.102:
                                      Ich habe auf die neuerste Version V0.5.2 des Adapters umgestellt.
                                      Der Fehler tritt weiterhin auf.
                                      Der Datenpunkt hat das Attribut: "autoread": true
                                      Vielleicht hilft das weiter.
                                        @killroy2
                                        H Nicht stören
                                        H Nicht stören
                                        Hansi1234
                                        schrieb am zuletzt editiert von Hansi1234
                                        #479
                                        Guten Morgen zusammen.
                                        Ich habe folgende Fehlermeldungen im Log. Kann mir hier jemand helfen?
                                        [error] 3/5/2023, 7:47:39 AM.672 KNXUltimate-KNXEngine: Sending KNX packet: Send UDP Catch error: Not running object seqCounter:undefined
                                        EDIT:
                                        Falsches Forum. Sorry. Ich erstelle ein Tread im Node-Red Abteil. Danke
                                          mpl1338
                                          #480
                                          kann der Adapter Telegramme auf den Bus bestätigen? Ich habe etliche GAs die nur für IOBroker zwecke senden. Kann der Apadpter diese bestätigen? Ich habe sehr viele wiederholende Telegramme und würde dieses verhalten gerne abstellen.
