  4. Zigbee startet nicht mehr
32 Beiträge 5 Kommentatoren 2.5k Aufrufe 5 Beobachtet
  • David G.D David G.
    @thomas-braun sagte in Zigbee startet nicht mehr:
    @david-g
    iobroker add zigbee
    liefert?
    pi@iobroker:~ $ iobroker add zigbee
    NPM version: 6.14.15
    npm install iobroker.zigbee@1.5.6 --loglevel error --prefix "/opt/iobroker" (System call)
    Traceback (most recent call last):
      File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py", line 47, in <module>
        import gyp
      File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 10, in <module>
        import gyp.input
      File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 7, in <module>
        import ast
    ImportError: No module named ast
    gyp ERR! configure error
    gyp ERR! stack Error: `gyp` failed with exit code: 1
    gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
    gyp ERR! stack     at ChildProcess.emit (events.js:400:28)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:282:12)
    gyp ERR! System Linux 5.10.63-v7l+
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/@serialport/bindings
    gyp ERR! node -v v14.18.2
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
        import gyp
        import gyp.input
        import ast
    gyp ERR! cwd /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@serialport/bindings
    gyp ERR! not ok
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! @serialport/bindings@9.0.4 install: `prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the @serialport/bindings@9.0.4 install script.
    npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR!     /home/iobroker/.npm/_logs/2021-12-01T20_54_28_658Z-debug.log
    host.iobroker Cannot install iobroker.zigbee@1.5.6: 1
    pi@iobroker:~ $
    Anbei das erwähnte log aus Zeile 51.
    @david-g
    Mach den Cache mal leer:
    cd /opt/iobroker
    npm cache clean --force
      @david-g
      cd /opt/iobroker
      David G.D Online
      David G.D Online
      David G.
      Leider nichts
      pi@iobroker:~ $ cd /opt/iobroker
      pi@iobroker:/opt/iobroker $ npm cache clean --force      npm WARN using --force I sure hope you know what you are doing.
      pi@iobroker:/opt/iobroker $ iobroker add zigbee
          import gyp
          import gyp.input
          import ast
      gyp ERR! not ok
          import gyp
          import gyp.input
          import ast
      gyp ERR! not ok
      npm ERR! errno 1
      npm ERR!
      npm ERR!     /home/iobroker/.npm/_logs/2021-12-01T21_26_11_036Z-debug.log
      Auch ein
      npm rebuild
      hat nichts gebracht.
        Leider nichts
            import gyp
            import gyp.input
            import ast
        gyp ERR! not ok
            import gyp
            import gyp.input
            import ast
        gyp ERR! not ok
        npm ERR! errno 1
        npm ERR!
        Auch ein
        npm rebuild
        @david-g
        cd /opt/iobroker
        npm ls
          @david-g
          cd /opt/iobroker
          npm ls
          David G.D Online
          David G.D Online
          David G.
          Sprengt leider, was ich hier posten darf.
          Hab es als txt angegangen.
          npm ls.txt
            npm ls.txt
            @david-g
            Da stimmt was mit irgendeinem vis-Zeug nicht.
            Mir fällt aber nix mehr dazu ein. Außer ZigBee komplett rauswerfen und nach einem Neustart noch mal ins System ziehen.
              @david-g
              David G.D Online
              David G.D Online
              David G.
              Okay,
              danke für deine Unterstützung.
              Zigbee hatte ich schonmal komplett runter geworfen (Instanz gelöscht und Adapter über den Papierkorb gelöscht).
              Ggf werde ich am Wochenende das System neu aufsetzen.
              Mal sehen, ob ich sql und nut wieder konfiguriert bekomme. Da hatte ich was Probleme mit 😅
              EDIT:
              Das System läuft jetzt wieder.
              Mache ca alle 3 Monate ein Image auf eine SD-Karte.
              Hab ich zurück auf meine SSD gespielt und das Backup durchlaufen lassen.
              Hätte den Fehler zwar gerne gefunden, auch um zu sehen woran es nun lag, jedoch war es mir jetzt wichtiger, dass das System wieder läuft.
              • arteckA arteck
                @bananajoe es kommt drauf an welche version man hat .. das ist also richtig
                @David-G dir hats den serialport zerhauen
                machmal
                adapter stop
                dann in der console
                rm -R /opt/iobroker/node_modules/zigbee-herdsman
                rm -R /opt/iobroker/node_modules/zigbee-herdsman-converters
                rm -R /opt/iobroker/node_modules/@serialport
                rm -R /opt/iobroker/node_modules/serialport
                rm -R /opt/iobroker/node_modules/iobroker.zigbee
                zurück zum Admin und dann adapter von GIT installieren https://github.com/ioBroker/ioBroker.zigbee/wiki/GIT-install
                adapter starten .. warten
                und nix anderes .. sonst sind die Geräte aus iobroker weg.. nur das was ich geschrieben habe
                Philipp.Schlegel
                @arteck
                Hi, tatsächlich trifft mich dasselbe Problem. Der FI flog raus, sofortiger Shutdown, nach Neustart startet der Adapter nicht mehr vollständig. LOG sieht für mich ebenso nach fehlerhaftem Serialport aus:
                zigbee.0	2021-12-02 08:04:51.703	error	Error herdsman start
                zigbee.0	2021-12-02 08:04:51.702	error	Failed to start Zigbee
                zigbee.0	2021-12-02 08:04:51.702	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                zigbee.0	2021-12-02 08:04:51.465	info	Installed Version: ioBroker/ioBroker.zigbee#5149bcb2392471287f6a60f855ffe690d74da714
                zigbee.0	2021-12-02 08:04:51.419	info	Starting Zigbee npm ...
                zigbee.0	2021-12-02 08:04:51.417	info	Try to reconnect. 1 attempts left
                zigbee.0	2021-12-02 08:04:41.415	error	Error herdsman start
                zigbee.0	2021-12-02 08:04:41.414	error	Failed to start Zigbee
                zigbee.0	2021-12-02 08:04:41.413	error	Starting zigbee-herdsman problem : "network commissioning timed out - most likely network with the same panId or extendedPanId already exists nearby"
                host.RaspberryPi4IoBroker-Main
                zigbee.0	2021-12-02 08:04:25.504	info	instance system.adapter.coronavirus-statistics.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                zigbee.0	2021-12-02 08:03:36.377	info	Installed Version: ioBroker/ioBroker.zigbee#5149bcb2392471287f6a60f855ffe690d74da714
                zigbee.0	2021-12-02 08:03:35.829	info	Starting Zigbee npm ...
                zigbee.0	2021-12-02 08:03:35.664	info	starting. Version 1.6.7 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.18.2, js-controller: 3.3.21
                zigbee.0	2021-12-02 08:03:35.632	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                An Deine beschriebenen Schritte des Löschens von iobroker.zigbee/serialport/@serialport/zigbee-herdsman-converters/zigbee-herdsman sowie Neuinstallation von GitHub habe ich schon versucht. Das Ergebnis ist immer analog dem Fehlerbild oben.
                Hat noch jemand eine Idee?
                Danke und beste Grüße!
                Phil
                • Thomas BraunT Online
                  @philipp-schlegel
                  Setz die beiden Werte mal neu.
                  P 1 Antwort Letzte Antwort
                    @philipp-schlegel
                    Philipp.Schlegel
                    Damit komme ich zu einer noch ausgiebigeren Fehlermeldung...
                    zigbee.0	2021-12-02 08:35:17.255	error	Error herdsman start
                    zigbee.0	2021-12-02 08:35:17.254	error	Failed to start Zigbee
                    zigbee.0	2021-12-02 08:35:17.253	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                    zigbee.0	2021-12-02 08:35:17.084	info	Installed Version: ioBroker/ioBroker.zigbee#5149bcb2392471287f6a60f855ffe690d74da714
                    zigbee.0	2021-12-02 08:35:17.063	info	Starting Zigbee npm ...
                    zigbee.0	2021-12-02 08:35:17.062	info	Try to reconnect. 1 attempts left
                    zigbee.0	2021-12-02 08:35:07.060	error	Error herdsman start
                    zigbee.0	2021-12-02 08:35:07.060	error	Failed to start Zigbee
                    zigbee.0	2021-12-02 08:35:07.059	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
                    zigbee.0	2021-12-02 08:35:07.057	error	Re-commissioning your network will require re-pairing of all devices!
                    zigbee.0	2021-12-02 08:35:07.056	error	If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
                    zigbee.0	2021-12-02 08:35:07.056	error	Please update configuration to prevent further issues.
                    zigbee.0	2021-12-02 08:35:07.055	error	- Channel List: configured=11, adapter=11
                    zigbee.0	2021-12-02 08:35:07.054	error	- Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
                    zigbee.0	2021-12-02 08:35:07.053	error	- Extended PAN ID: configured=adcaccbdcdddddda, adapter=00124b00219fb99b
                    zigbee.0	2021-12-02 08:35:07.052	error	- PAN ID: configured=601, adapter=601
                    zigbee.0	2021-12-02 08:35:07.051	error	Configuration is not consistent with adapter state/backup!
                    • P Philipp.Schlegel
                      @philipp-schlegel
                      Das muss übereinstimmen.
                      Und ich würde den Adapter nicht als git-Version betreiben.
                        @david-g
                        git-Versionen sind nie produktiv.
                        arteckA Offline
                        arteckA Offline
                        arteck
                        wobei bei Zigbee ist es bissel anders..
                        da sind die release Zeiten bissel anders
                        wir sehen zu dass es immer funktioniert..
                          @philipp-schlegel
                          Philipp.Schlegel
                          @thomas-braun TOP! Tausend Dank. Daran hing es tatsächlich.
