  4. Zigbee startet nicht mehr
    5.8k
32 Beiträge 5 Kommentatoren 2.7k Aufrufe 5 Beobachtet
  • David G.D David G.
    Nodejs hab ich nicht bewusst upgedatet.
    Bin nach dieser Anleitung vorgegangen.
    https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye?_=1638334513500
    Hier der Log vom rebuild.
    Hat nichts gebracht......
    Last login: Tue Nov 30 23:11:41 2021 from 192.168.99.77
    Wi-Fi is currently blocked by rfkill.
    Use raspi-config to set the country before use.
    pi@iobroker:~ $ iobroker rebuild zigbee --install
    npm install --loglevel error --production (System call1) in "/opt/iobroker/node_modules/iobroker.zigbee"
    Traceback (most recent call last):
      File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py", line 47, in <module>
        import gyp
      File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 10, in <module>
        import gyp.input
      File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 7, in <module>
        import ast
    ImportError: No module named ast
    gyp ERR! configure error
    gyp ERR! stack Error: `gyp` failed with exit code: 1
    gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
    gyp ERR! stack     at ChildProcess.emit (events.js:400:28)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:282:12)
    gyp ERR! System Linux 5.10.63-v7l+
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@serialport/bindings
    gyp ERR! node -v v14.18.1
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! @serialport/bindings@9.2.5 install: `prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the @serialport/bindings@9.2.5 install script.
    npm ERR!     /home/iobroker/.npm/_logs/2021-12-01T04_53_18_917Z-debug.log
    Rebuild zigbee done
    pi@iobroker:~ $
    EDIT:
    Hab grad mal ganz frech die Instanz und den Adapter gelöscht.
    Hab ja ein Backup von Zigbee.
    Beim neuen installieren bricht er nun mit einem Fehler ab:
    ERROR: Process exited with code 25
    weniger
    mehr
    $ iobroker add zigbee auto --host iobroker
    NPM version: 6.14.15
    npm install iobroker.zigbee@1.6.6 --loglevel error --prefix "/opt/iobroker" (System call)
    File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py", line 47, in <module> import gyp File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 10, in <module> import gyp.input File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 7, in <module> import astImportError: No module named ast
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@serialport/bindingsgyp ERR! node -v v14.18.1gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
    npm ERR! errno 1
    npm ERR!
    npm ERR! /home/iobroker/.npm/_logs/2021-12-01T06_09_25_754Z-debug.log
    host.iobroker Cannot install iobroker.zigbee@1.6.6: 1
    @david-g
    which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
    free -ht
      @david-g
      free -ht
      David G.D Online
      David G.D Online
      David G.
      @thomas-braun sagte in Zigbee startet nicht mehr:
      @david-g
      Last login: Wed Dec  1 07:21:43 2021 from 192.168.99.77
      pi@iobroker:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v14.18.1
      v14.18.1
      6.14.15
      OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
      Holen:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15,0 kB]
      OK:3 https://deb.nodesource.com/node_14.x bullseye InRelease
      Es wurden 15,0 kB in 1 s geholt (15,0 kB/s).
      Aktualisierung für 2 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
      OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      nodejs:
        Installiert:           14.18.1-deb-1nodesource1
        Installationskandidat: 14.18.2-deb-1nodesource1
        Versionstabelle:
           14.18.2-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages
       *** 14.18.1-deb-1nodesource1 100
           12.22.5~dfsg-2~11u1 500
      pi@iobroker:~ $
      pi@iobroker:~ $
      free -ht
      Last login: Wed Dec  1 07:37:08 2021 from 192.168.99.77
      pi@iobroker:~ $ free -ht
                    gesamt       benutzt     frei      gemns.  Puffer/Cache verfügbar
      Speicher:      3,7Gi       1,9Gi       610Mi        14Mi       1,2Gi       2,2Gi
      Swap:          999Mi       2,0Mi       997Mi
      Gesamt:        4,7Gi       1,9Gi       1,6Gi
      pi@iobroker:~ $
        @david-g
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v14.18.1
        v14.18.1
        6.14.15
        nodejs:
          Versionstabelle:
        pi@iobroker:~ $
        pi@iobroker:~ $
        free -ht
        pi@iobroker:~ $
        @david-g
        Swap: 999Mi
        Du hast 999MB Swap? Warum das?
        nodeJS auf die letzte Version bringen.
        David G.D 2 Antworten Letzte Antwort
          @david-g
          Swap: 999Mi
          David G.D Online
          David G.D Online
          David G.
          Der war mir eine Zeit lang mal vollgelaufen als er kleiner war.
          War zum testen wie es sich verhält wenn er größer ist.
          Könnte ich mal wieder ändern....
            @david-g
            Swap: 999Mi
            David G.D Online
            David G.D Online
            David G.
            @david-g
            Erledigt
            Last login: Wed Dec  1 07:48:46 2021 from 192.168.99.77
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            v14.18.2
            v14.18.2
            6.14.15
            OK:2 https://deb.nodesource.com/node_14.x bullseye InRelease
            OK:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
            Aktualisierung für 1 Paket verfügbar. Führen Sie »apt list --upgradable« aus, um es anzuzeigen.
            nodejs:
              Installiert:           14.18.2-deb-1nodesource1
              Versionstabelle:
             *** 14.18.2-deb-1nodesource1 500
            pi@iobroker:~ $
            Bein installieren des Adapters kommt jetzt
            weniger
            mehr
            NPM version: 6.14.15npm install iobroker.zigbee@1.6.6 --loglevel error --prefix "/opt/iobroker" (System call)
            File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py", line 47, in <module> import gyp File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 10, in <module> import gyp.input File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 7, in <module> import astImportError: No module named astgyp ERR! configure error
            gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack at ChildProcess.emit (events.js:400:28)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:282:12)gyp ERR! System Linux 5.10.63-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@serialport/bindingsgyp ERR! node -v v14.18.2gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
            npm ERR! code ELIFECYCLEnpm ERR! errno 1
            npm ERR! @serialport/bindings@9.2.5 install: `prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the @serialport/bindings@9.2.5 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
            npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2021-12-01T06_54_07_681Z-debug.log
            • BananaJoeB BananaJoe
              Nachtrag: tja, aber da steht ganz klar was von bindings in deinem Logs.
              Ich hab bei mir mal geschaut ,den Pfad
              /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsmann
              gibt es bei mir gar nicht, der zigbee-herdsman Ordner liegt bei mir direkt im /opt/iobroker/node_modules Ordner
              arteckA Offline
              arteckA Offline
              arteck
              @bananajoe es kommt drauf an welche version man hat .. das ist also richtig
              @David-G dir hats den serialport zerhauen
              machmal
              adapter stop
              dann in der console
              rm -R /opt/iobroker/node_modules/zigbee-herdsman
              rm -R /opt/iobroker/node_modules/zigbee-herdsman-converters
              rm -R /opt/iobroker/node_modules/@serialport
              rm -R /opt/iobroker/node_modules/serialport
              rm -R /opt/iobroker/node_modules/iobroker.zigbee
              zurück zum Admin und dann adapter von GIT installieren https://github.com/ioBroker/ioBroker.zigbee/wiki/GIT-install
              adapter starten .. warten
              und nix anderes .. sonst sind die Geräte aus iobroker weg.. nur das was ich geschrieben habe
              David G.D P 2 Antworten Letzte Antwort
              • arteckA arteck
                machmal
                adapter stop
                dann in der console
                David G.D Online
                David G.D Online
                David G.
                @arteck sagte in Zigbee startet nicht mehr:
                machmal
                adapter stop
                Alle Adapter stop?
                Zigbee hab ich ja garnicht erst installiert.
                Darf ich danach ein vorher funktionierendes Backup einspielen, falls die Geräte weg sind?
                Falls nein, wäre nicht soooo schlimm.
                Bin mit Zigbee noch am Anfang.
                EDIT:
                Hab die Ordner jetzt mit den entsprechenden Befehlen gelöscht.
                Allerdings gab es nur die mit serialport. Die anderen wurden vermutlich beim Löschen des Adapters entfernt.
                pi@iobroker:~ $ rm -R /opt/iobroker/node_modules/zigbee-herdsmann
                rm: das Entfernen von '/opt/iobroker/node_modules/zigbee-herdsmann' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
                pi@iobroker:~ $ rm -R /opt/iobroker/node_modules/zigbee-herdsman-converters
                rm: das Entfernen von '/opt/iobroker/node_modules/zigbee-herdsman-converters' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
                pi@iobroker:~ $ rm -R /opt/iobroker/node_modules/@serialport
                pi@iobroker:~ $ rm -R /opt/iobroker/node_modules/serialport
                pi@iobroker:~ $ rm -R /opt/iobroker/node_modules/iobroker.zigbee
                rm: das Entfernen von '/opt/iobroker/node_modules/iobroker.zigbee' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
                pi@iobroker:~ $
                Leider keine Besserung. Adapter lässt sich nicht installieren.
                Ist glaube auch von den Fehlern her gleich:
                $ iobroker url https://github.com/ioBroker/ioBroker.zigbee --host iobroker
                install ioBroker/ioBroker.zigbee#5149bcb2392471287f6a60f855ffe690d74da714
                NPM version: 6.14.15npm install ioBroker/ioBroker.zigbee#5149bcb2392471287f6a60f855ffe690d74da714 --loglevel error --prefix "/opt/iobroker" (System call)
                gyp ERR! configure error gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack at ChildProcess.emit (events.js:400:28)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:282:12)gyp ERR! System Linux 5.10.63-v7l+
                gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/@serialport/bindingsgyp ERR! node -v v14.18.2gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
                npm ERR! @serialport/bindings@9.2.7 install: `prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild`
                npm ERR!
                npm ERR! Failed at the @serialport/bindings@9.2.7 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2021-12-01T14_54_32_040Z-debug.log
                host.iobroker Cannot install ioBroker/ioBroker.zigbee#5149bcb2392471287f6a60f855ffe690d74da714: 1
                EDIT 2:
                Hab einen Adapter der jetzt regelmäßig abstürzt.
                Scheinbar hat der auch ein Problem mit den bindings
                TypeError: this.getSpecialValues is not a function at Object.formatBinding (/opt/iobroker/node_modules/iobroker.lovelace/lib/bindings.js:168:42) at /opt/iobroker/node_modules/iobroker.lovelace/lib/server.js:2582:50 at runNextTicks (internal/process/task_queues.js:60:5) at processImmediate (internal/timers.js:437:9)
                Mittlerweile hat sich die Fehlermeldung geändert:
                gyp ERR! System Linux 5.10.63-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/@serialport/bindingsgyp ERR! node -v v14.18.2gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
                npm ERR! npm ERR! Failed at the @serialport/bindings@9.2.7 install script.
                npm ERR! /home/iobroker/.npm/_logs/2021-12-01T18_42_47_410Z-debug.log
                  machmal
                  adapter stop
                  Alle Adapter stop?
                  EDIT:
                  pi@iobroker:~ $
                  npm ERR!
                  EDIT 2:
                  @david-g
                  Warum eigentlich die Version aus git?
                  Nimm was aus den Repos.
                    @david-g
                    David G.D Online
                    David G.D Online
                    David G.
                    Macht keinen Unterschied vom Fehlerbild.
                    Wollte nicht direkt nachdem ich mit Zigbee anfange so einen großen Versionssorung machen.
                      @david-g
                      Die Version aus git ist die 'böse', die kleine Kätzchen fressen kann.
                      Gerade als einstieg nimmt man eine Version aus stable. Testen kannst du dann später.
                      iobroker add zigbee
                      liefert?
                        @david-g
                        iobroker add zigbee
                        liefert?
                        David G.D Online
                        David G.D Online
                        David G.
                        Hab sie genommen weil einige hier im Forum die Produktiv nutzen und es scheinbar keine Probleme gibt.
                        Hoffe mal, mein Problem liegt nicht daran.
                          @david-g
                          git-Versionen sind nie produktiv.
                          David G.D arteckA 2 Antworten Letzte Antwort
                            @david-g
                            David G.D Online
                            David G.D Online
                            David G.
                            Okay, verstanden.
                            Jedoch wäre es schön jetzt wieder auf das ursprüngliche Thema zu kommen.
                            EDIT: Hab eben deinen Befehl übersehen. Teste ich grad.
                              @david-g
                              iobroker add zigbee
                              liefert?
                              David G.D Online
                              David G.D Online
                              David G.
                              @david-g
                              iobroker add zigbee
                              liefert?
                              pi@iobroker:~ $ iobroker add zigbee
                              npm install iobroker.zigbee@1.5.6 --loglevel error --prefix "/opt/iobroker" (System call)
                                  import gyp
                                  import gyp.input
                                  import ast
                              gyp ERR! not ok
                                  import gyp
                                  import gyp.input
                                  import ast
                              gyp ERR! not ok
                              npm ERR! errno 1
                              npm ERR! @serialport/bindings@9.0.4 install: `prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild`
                              npm ERR!
                              npm ERR! Failed at the @serialport/bindings@9.0.4 install script.
                              npm ERR!     /home/iobroker/.npm/_logs/2021-12-01T20_54_28_658Z-debug.log
                              host.iobroker Cannot install iobroker.zigbee@1.5.6: 1
                              pi@iobroker:~ $
                              Anbei das erwähnte log aus Zeile 51.
                                @david-g
                                iobroker add zigbee
                                liefert?
                                    import gyp
                                    import gyp.input
                                    import ast
                                gyp ERR! not ok
                                    import gyp
                                    import gyp.input
                                    import ast
                                gyp ERR! not ok
                                npm ERR! errno 1
                                npm ERR!
                                pi@iobroker:~ $
                                @david-g
                                Mach den Cache mal leer:
                                cd /opt/iobroker
                                npm cache clean --force
                                  @david-g
                                  cd /opt/iobroker
                                  David G.D Online
                                  David G.D Online
                                  David G.
                                  Leider nichts
                                  pi@iobroker:~ $ cd /opt/iobroker
                                  pi@iobroker:/opt/iobroker $ npm cache clean --force      npm WARN using --force I sure hope you know what you are doing.
                                  pi@iobroker:/opt/iobroker $ iobroker add zigbee
                                      import gyp
                                      import gyp.input
                                      import ast
                                  gyp ERR! not ok
                                      import gyp
                                      import gyp.input
                                      import ast
                                  gyp ERR! not ok
                                  npm ERR! errno 1
                                  npm ERR!
                                  npm ERR!     /home/iobroker/.npm/_logs/2021-12-01T21_26_11_036Z-debug.log
                                  Auch ein
                                  npm rebuild
                                  hat nichts gebracht.
                                    Leider nichts
                                        import gyp
                                        import gyp.input
                                        import ast
                                    gyp ERR! not ok
                                        import gyp
                                        import gyp.input
                                        import ast
                                    gyp ERR! not ok
                                    npm ERR! errno 1
                                    npm ERR!
                                    Auch ein
                                    npm rebuild
                                    @david-g
                                    cd /opt/iobroker
                                    npm ls
                                      @david-g
                                      cd /opt/iobroker
                                      npm ls
                                      David G.D Online
                                      David G.D Online
                                      David G.
                                      Sprengt leider, was ich hier posten darf.
                                      Hab es als txt angegangen.
                                      npm ls.txt
                                        npm ls.txt
                                        @david-g
                                        Da stimmt was mit irgendeinem vis-Zeug nicht.
                                        Mir fällt aber nix mehr dazu ein. Außer ZigBee komplett rauswerfen und nach einem Neustart noch mal ins System ziehen.
                                          @david-g
                                          David G.D Online
                                          David G.D Online
                                          David G.
                                          Okay,
                                          danke für deine Unterstützung.
                                          Zigbee hatte ich schonmal komplett runter geworfen (Instanz gelöscht und Adapter über den Papierkorb gelöscht).
                                          Ggf werde ich am Wochenende das System neu aufsetzen.
                                          Mal sehen, ob ich sql und nut wieder konfiguriert bekomme. Da hatte ich was Probleme mit 😅
                                          EDIT:
                                          Das System läuft jetzt wieder.
                                          Mache ca alle 3 Monate ein Image auf eine SD-Karte.
                                          Hab ich zurück auf meine SSD gespielt und das Backup durchlaufen lassen.
                                          Hätte den Fehler zwar gerne gefunden, auch um zu sehen woran es nun lag, jedoch war es mir jetzt wichtiger, dass das System wieder läuft.
