  4. Test Adapter e3dc-rscp v0.0.x GitHub
    5.8k
batterye3dcelectricityenergyphotovoltaicrscp
470 Beiträge 38 Kommentatoren 139.1k Aufrufe 37 Beobachtet
    ArnoD
    schrieb am zuletzt editiert von ArnoD
    #181
    0.0.16-beta installiert.
    Es werden keine States unter WB angelegt.
    LOG Silly:
    2021-12-05 10:42:52.016 - debug: e3dc-rscp.0 (16517) Sending request TAG_WB_REQ_CONNECTED_DEVICES
    2021-12-05 10:42:52.016 - silly: e3dc-rscp.0 (16517) OUT: magic: >E3DC< is OK - ctrl: >0011< is OK - Version 1, with CRC - seconds: 1638697371 - nseconds: 0 - length: 7
    TAG_WB_REQ_CONNECTED_DEVICES - type: 0x00 - None - length: 0
    CRC32
    2021-12-05 10:42:52.016 - silly: e3dc-rscp.0 (16517) E3 DC 00 11 9B 89 AC 61 00 00 00 00 00 00 00 00 -- .......a........
    07 00 1C 10 04 0E 00 00 00 43 81 74 59 -- .........C.tY
    2021-12-05 10:42:52.017 - silly: e3dc-rscp.0 (16517) Successfully written data to socket
    2021-12-05 10:42:52.034 - silly: e3dc-rscp.0 (16517) Received response
    2021-12-05 10:42:52.035 - silly: e3dc-rscp.0 (16517) TAG_WB_CONNECTED_DEVICES
    2021-12-05 10:42:52.035 - silly: e3dc-rscp.0 (16517) IN: magic: >E3DC< is OK - ctrl: >0011< is OK - Version 1, with CRC - seconds: 1638697373 - nseconds: 84939000 - length: 18
    TAG_WB_CONNECTED_DEVICES - type: 0x0E - Container - length: 11
    TAG_WB_INDEX - type: 0x06 - Int32 - length: 4 value: 0
    no CRC32
    2021-12-05 10:42:52.035 - silly: e3dc-rscp.0 (16517) E3 DC 00 11 9D 89 AC 61 00 00 00 00 F8 10 10 05 -- .......a........
    12 00 1C 10 84 0E 0E 0B 00 01 00 04 0E 06 04 00 -- ................
    00 00 00 00 07 AF BA 54 00 00 00 00 00 00 00 00 -- .......T........
    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -- ................
    2021-12-05 10:42:52.036 - silly: e3dc-rscp.0 (16517) processTree: path = , tree = [ {TAG_WB_CONNECTED_DEVICES(Container) = [ {TAG_WB_INDEX(Int32) = 0}, ]}, ]
    2021-12-05 10:42:52.036 - silly: e3dc-rscp.0 (16517) processTree: path = , tree = [ {TAG_WB_INDEX(Int32) = 0}, ]
    2021-12-05 10:42:52.036 - silly: e3dc-rscp.0 (16517) Message queue is empty
    Uli ich kann diesen Tag "TAG_WB_REQ_CONNECTED_DEVICES" auch nicht in der Tag liste finden. Habe dort nur "TAG_WB_DEVICE_CONNECTED" finden können. Bist du sicher das es so richtig ist ?
    git-kickG 1 Antwort Letzte Antwort
    • A ArnoD
      LOG Silly:
      CRC32
      no CRC32
      git-kickG Offline
      git-kickG Offline
      git-kick
      #182
      @arnod
      Danke für das Log, das hilft!
      Das Tag TAG_WB_REQ_CONNECTED_DEVICES habe ich aus dem RscpGUI (rxhan) abgekupfert.
      Aber da kommt ja (anders als erwartet) ein Container zurück, den muss ich erstmal auflösen und den größten Index-Wert abspeichern.
      Also ihr braucht WB erstmal nicht weiter testen bis zum nächsten Bugfix.
      • git-kickG git-kick
        @arnod
        git-kickG Offline
        git-kickG Offline
        git-kick
        #183
        Hier der Fix:
        https://github.com/git-kick/ioBroker.e3dc-rscp/tree/v0.0.16-beta2
        @arnod, kannst du bitte nochmal testen? Jetzt sollte ein WB_0 angelegt werden, nachdem der WB_CONNECTED_DEVICES Container eingetroffen ist.
        (Bin nicht sicher, ob dieser Weg der "blinden Entwicklung" uns hinreichend voranbringt - sagt Bescheid, wenn Euch das zu lästig wird.)
        A 1 Antwort Letzte Antwort
        • A ArnoD
          Eventuell sollten wir mal ein paar Werte vergleichen, die nicht schlüssig sind, um zu sehen, ob das bei allen so ist.
          Habe mal folgende Werte die für mich keinen Sinn ergeben:
          e3dc-rscp.0.EMS.SYS_SPECS.maxPvPower = 6 W
          Hier hätte ich 15000W was meiner installierten PV-Leistung entspricht erwartet
          e3dc-rscp.0.EMS.BALANCED_PHASES = 7
          Mit dem Wert kann ich nichts anfange, dachte immer ich hätte nur 3 Phasen :-) Weiß jemand mehr darüber?
          ArnoD
          #184
          @arnod sagte in Test Adapter e3dc-rscp v0.0.x GitHub:
          Mit dem Wert kann ich nichts anfange, dachte immer ich hätte nur 3 Phasen Weiß jemand mehr darüber?
          Habe jetzt in der Tag Liste nach Phases gesucht und folgendes unter dem Tag "TAG_PM_ACTIVE_PHASES" gefunden:
          //just the three lowest bits of activePhases are used to define / //what phase is switched on. If the lowest bit is 1 phase1 is active / //if the lowest bit is 0 phase 1 is inactive ... / static const unsigned char PHASE_1 = 1 / static const unsigned char PHASE_2 = 2 / static const unsigned char PHASE_3 = 4 / f.e. if active Phases = 7 -> all phases are active
          Demnach würde das Ganze so aussehn:
          1 = L1
          2 = L2
          3 = L1 und L2
          4 = L3
          5 = L1 und L3
          6 = L2 und L3
          7 = L1, L2, L3
          Das würde bei mir auch zutreffen mit 7
            Hier der Fix:
            ArnoD
            #185
            @ujok sagte in Test Adapter e3dc-rscp v0.0.x GitHub:
            Mach ich gleich.
            Das wird mir bestimmt nicht lästig, bin wirklich froh, dass du das machst.
              ArnoD
              #186
              Ok States werden jetzt angelegt:
              Im LOG sind mehrere Warnungen:
              2021-12-05 12:36:19.891  - info: e3dc-rscp.0 (23219) starting. Version 0.0.16-beta in /opt/iobroker/node_modules/iobroker.e3dc-rscp, node: v12.22.7, js-controller: 3.3.20
              2021-12-05 12:36:20.003  - info: e3dc-rscp.0 (23219) Connection to E3/DC is established
              2021-12-05 12:36:27.472  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_UNKNOWN_TAG (7) - tag TAG_PVI_REQ_TEMPERATURE_COUNT (0x2000101)
              2021-12-05 12:36:27.479  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DEVICE_ID (0xe000018)
              2021-12-05 12:36:27.480  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_BAT_CAPACITY (0xe000019)
              2021-12-05 12:36:27.483  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_USER_PARAM (0xe00001a)
              2021-12-05 12:36:27.485  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_MAX_CURRENT (0xe00001b)
              2021-12-05 12:36:27.486  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_PHASE_VOLTAGE (0xe00001c)
              2021-12-05 12:36:27.489  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DISPLAY_SPEECH (0xe00001d)
              2021-12-05 12:36:27.490  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DESIGN (0xe00001e)
              2021-12-05 12:36:27.494  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_CP_PEGEL (0xe000024)
              2021-12-05 12:36:27.497  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_PP_IN_A (0xe000025)
              2021-12-05 12:36:27.497  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_STATUS_DIODE (0xe000026)
              2021-12-05 12:36:27.498  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DIG_IN_1 (0xe000027)
              2021-12-05 12:36:27.498  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DIG_IN_2 (0xe000028)
              2021-12-05 12:36:34.538  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_UNKNOWN_TAG (7) - tag TAG_PVI_REQ_TEMPERATURE_COUNT (0x2000101)
              2021-12-05 12:36:34.540  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DEVICE_ID (0xe000018)
              2021-12-05 12:36:34.540  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_BAT_CAPACITY (0xe000019)
              2021-12-05 12:36:34.540  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_USER_PARAM (0xe00001a)
              2021-12-05 12:36:34.541  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_MAX_CURRENT (0xe00001b)
              2021-12-05 12:36:34.541  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_PHASE_VOLTAGE (0xe00001c)
              2021-12-05 12:36:34.541  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DISPLAY_SPEECH (0xe00001d)
              2021-12-05 12:36:34.541  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DESIGN (0xe00001e)
              2021-12-05 12:36:34.542  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_CP_PEGEL (0xe000024)
              2021-12-05 12:36:34.542  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_PP_IN_A (0xe000025)
              2021-12-05 12:36:34.542  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_STATUS_DIODE (0xe000026)
              2021-12-05 12:36:34.549  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DIG_IN_1 (0xe000027)
              2021-12-05 12:36:34.549  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DIG_IN_2 (0xe000028)
              2021-12-05 12:36:41.339  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_UNKNOWN_TAG (7) - tag TAG_PVI_REQ_TEMPERATURE_COUNT (0x2000101)
              2021-12-05 12:36:41.340  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DEVICE_ID (0xe000018)
              2021-12-05 12:36:41.341  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_BAT_CAPACITY (0xe000019)
              2021-12-05 12:36:41.341  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_USER_PARAM (0xe00001a)
              2021-12-05 12:36:41.341  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_MAX_CURRENT (0xe00001b)
              2021-12-05 12:36:41.341  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_PHASE_VOLTAGE (0xe00001c)
              2021-12-05 12:36:41.341  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DISPLAY_SPEECH (0xe00001d)
              2021-12-05 12:36:41.341  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DESIGN (0xe00001e)
              2021-12-05 12:36:41.342  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_CP_PEGEL (0xe000024)
              2021-12-05 12:36:41.342  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_PP_IN_A (0xe000025)
              2021-12-05 12:36:41.342  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_STATUS_DIODE (0xe000026)
              2021-12-05 12:36:41.342  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DIG_IN_1 (0xe000027)
              2021-12-05 12:36:41.342  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DIG_IN_2 (0xe000028)
              2021-12-05 12:36:48.181  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_UNKNOWN_TAG (7) - tag TAG_PVI_REQ_TEMPERATURE_COUNT (0x2000101)
              2021-12-05 12:36:48.182  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DEVICE_ID (0xe000018)
              2021-12-05 12:36:48.182  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_BAT_CAPACITY (0xe000019)
              2021-12-05 12:36:48.183  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_USER_PARAM (0xe00001a)
              2021-12-05 12:36:48.183  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_MAX_CURRENT (0xe00001b)
              2021-12-05 12:36:48.183  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_PHASE_VOLTAGE (0xe00001c)
              2021-12-05 12:36:48.183  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DISPLAY_SPEECH (0xe00001d)
              2021-12-05 12:36:48.183  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DESIGN (0xe00001e)
              2021-12-05 12:36:48.183  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_CP_PEGEL (0xe000024)
              2021-12-05 12:36:48.184  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_PP_IN_A (0xe000025)
              2021-12-05 12:36:48.184  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_STATUS_DIODE (0xe000026)
              2021-12-05 12:36:48.184  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DIG_IN_1 (0xe000027)
              2021-12-05 12:36:48.184  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DIG_IN_2 (0xe000028)
              git-kickG 2 Antworten Letzte Antwort
                ArnoD
                #187
                und hier das LOG auf silly eingestellt:
                Neues Textdokument.txt
                  ArnoD
                  #188
                  Habe jetzt das Auto mal angesteckt und es werden bereits einige Werte übertragen:
                  Nachtrag:
                  ohne PV-Leistung vom Dach kann ich jetzt nicht alles testen.
                  Die Leistungs Werte L1 bis L3 sind schon mal richtig.
                  Beim Tag ENERGY_ALL stimmt der Wert nicht, zeigt bei mir nur 4300 W an und das Auto wird aber mit 10330 W geladen.
                  (beim rscpgui wird hier Wh angegeben, denke aber das es auch nicht richtig ist)
                  Kann es sein das einige States doppelt angelegt wurden, einmal unter WB_0 und einmal unter WB
                  • A ArnoD
                    1 = L1
                    2 = L2
                    3 = L1 und L2
                    4 = L3
                    5 = L1 und L3
                    6 = L2 und L3
                    7 = L1, L2, L3
                    git-kickG Offline
                    git-kickG Offline
                    git-kick
                    #189
                    @arnod said in Test Adapter e3dc-rscp v0.0.x GitHub:
                    1 = L1
                    2 = L2
                    3 = L1 und L2
                    4 = L3
                    5 = L1 und L3
                    6 = L2 und L3
                    7 = L1, L2, L3
                    Danke @ArnoD, das baue ich gleich als Wertemenge für die ...PHASES Tags mit Wert 7 ein.
                    • A ArnoD
                      git-kickG Offline
                      git-kickG Offline
                      git-kick
                      #190
                      Das ist gut. Aber sehe ich das richtig, dass die Werte nicht unter WB_0 einsortiert werden, sondern daneben?
                      • A ArnoD
                        git-kickG Offline
                        git-kickG Offline
                        git-kick
                        schrieb am zuletzt editiert von git-kick
                        #191
                        Ok, dann sind die DIAG... tags anscheinend nicht für uns USER zugänglich (es gibt noch INSTALLER, PARTNER und drei E3DC-Level) - ich nehme die DIAG... Tags raus.
                        Die Meldung bzgl. TAG_PVI_REQ_TEMPERATURE_COUNT ist merkwürdig. Mein E3/DC antwortet hier einwandfrei (Wert 4). Option wäre hier, diese Meldung in den debug-Level zu verschieben. Aber eigentlich finde ich es in dieser Phasse ganz gut, wenn wir solche vom E3/DC gemeldeten Fehler auch zu sehen bekommen.
                        In deinem silly-Log sehe ich auch mehrmals, wie der Wert 4 ankommt. Lass uns weiter beobachten, ob der TAG_PVI_REQ_TEMPERATURE_COUNT Fehler wieder auftritt.
                          ArnoD
                          #192
                          Ja, die Werte werden zweimal angelegt, einmal unter WB_0 und einmal unter WB
                          • A ArnoD
                            git-kickG Offline
                            git-kickG Offline
                            git-kick
                            #193
                            In diesem Screenshot sieht es aber so aus, dass einige Werte unter WB sind und andere unter WB_0 - was korrekt wäre...
                            https://forum.iobroker.net/assets/uploads/files/1638706251081-wallbox1.png
                            Aber ein paar sind auch doppelt vorhanden. Kannst du bitte nochmal den Objektbaum löschen, den Adapter neu starten und dann den Objektbaum nochmal posten?
                            • A ArnoD
                              Nachtrag:
                              git-kickG Offline
                              git-kickG Offline
                              git-kick
                              #194
                              Ich denke hier habe ich die falsche Einheit eingetragen. ENERGY ist eindeutig Wh (oder kWh), nicht W. Also ich denke RscpGui liegt hier richtig.
                              Könnte 4,3 kWh geladen nicht stimmen? Eine knappe halbe Stunde mit 10330 W?
                                ArnoD
                                #195
                                Hier den Objektbaum WB:
                                und hier mit aufgeklapptem Objektbaum WB_0:
                                  ArnoD
                                  #196
                                  Ok habe die Werte jetzt noch mal angesehen.
                                  Also, wenn etwas einigermaßen stimmt dann Wh. Komme zwar nicht genau auf die Werte, aber annähernd.
                                    ArnoD
                                    #197
                                    Uli in IDLE_PERIODS_DISCHARGE sind keine Werte enthalten, ist das noch nicht so weit oder liegt es an der v0.0.16-beta2 ?
                                    • A ArnoD
                                      git-kickG Offline
                                      git-kickG Offline
                                      git-kick
                                      #198
                                      Bei mir sind (mit v0.0.16-beta3) alle Werte da, es gibt aber eine kleine Verzögerung beim ersten Öffnen der Tages-Ordner, bis die Werte angezeigt werden (max. etwa 1 Sekunde). Bist du sicher, dass die Werte dauerhaft nicht erscheinen? Wenn ja, bitte ich wieder um ein silly-log ab Adapter-Start 😇
                                        git-kickG Offline
                                        git-kickG Offline
                                        git-kick
                                        #199
                                        Neue WB bugfix Version:
                                        https://github.com/git-kick/ioBroker.e3dc-rscp/tree/v0.0.16-beta3
                                        Ich habe ein falsches (PVI) Anfragetag aus der WB-Anfrage entfernt - evtl. hilft das gegen die Doppel im Objektbaum (bin nicht sicher)
                                        Bitte auch die Werte
                                        "WB.WB_0.EXTERN_DATA_SUN",
                                        "WB.WB_0.EXTERN_DATA_NET",
                                        "WB.WB_0.EXTERN_DATA_ALL",
                                        "WB.WB_0.EXTERN_DATA_ALG",
                                        "WB.WB_0.EXTERN_RSP_PARAM_1",
                                        "WB.WB_0.EXTERN_RSP_PARAM_2"
                                        prüfen, denn die kommen alle in extra Containern, da habe ich das Handling jetzt eingebaut. Zudem sollten die ByteArray-Werte jetzt als hex dump (z.B. "FA AB 01 02") dargestellt werden.
                                        v0.0.16-beta3
                                        • WB inbound containers are now handled
                                        • ByteArray values are translated to "hex dump" strings
                                        • wrong PVI request tag was removed from WB get data frame
                                        P.S. das silly-log (txt-Datei) war sehr hilfreich, bitte bei WB-Fehlern wieder beilegen, dann habe ich viel bessere Karten bei der Fehlersuche ...
                                          v0.0.16-beta3
                                          ArnoD
                                          #200
                                          @ujok
                                          Habe die neue Version installiert.
                                          Bei den SYS_SPECS ist jetzt was durcheinander gekommen, da sieht die Beschriftung jetzt so aus:
