  4. Alpha Testing: OCPP Wallbox Adapter
    6.3k
ocppwallboxadapter
448 Beiträge 49 Kommentatoren 152.5k Aufrufe 47 Beobachtet
  • SoeniS Soeni
    @foxriver76 Entschuldige bitte die verspätete Rückmeldung, bin erst heute dazu gekommen.
    Adapterversion: v0.9.1
    Log nach neustart des Adapters (Ich denke das meinst du nach Anmelden):
    ocpp.0
    	2023-01-18 20:57:44.252	info	Received Status Notification from "/.1": Finishing
    ocpp.0
    	2023-01-18 20:57:44.192	info	Received Status Notification from "/.0": Available
    ocpp.0
    	2023-01-18 20:57:43.983	info	Received boot notification from "/"
    ocpp.0
    	2023-01-18 20:57:43.953	warn	Could not request states of "/": you must provide a joi schema
    ocpp.0
    	2023-01-18 20:57:43.946	info	Requesting StatusNotification from "/"
    ocpp.0
    	2023-01-18 20:57:43.944	info	New device connected: "/"
    ocpp.0
    	2023-01-18 20:57:43.858	info	New valid connection from "/" (http/ocpp1.6)
    ocpp.0
    	2023-01-18 20:57:37.834	info	Server listening on port 9220
    ocpp.0
    	2023-01-18 20:57:37.705	info	Starting OCPP Server
    ocpp.0
    	2023-01-18 20:57:37.641	info	starting. Version 0.9.1 (non-npm: foxriver76/ioBroker.ocpp) in /opt/iobroker/node_modules/iobroker.ocpp, node: v16.14.2, js-controller: 4.0.23
    SoeniS Offline
    SoeniS Offline
    Soeni
    #301
    Hier noch mal das Log mit Einstellung alles:
    ocpp.0
    	2023-01-18 21:01:53.638	info	Received Status Notification from "/.1": Finishing
    ocpp.0
    	2023-01-18 21:01:53.638	debug	{"connectorId":1,"errorCode":"NoError","status":"Finishing","timestamp":"2023-01-18T20:01:53.000Z","commandOcpp":"StatusNotification"}
    ocpp.0
    	2023-01-18 21:01:53.484	info	Received Status Notification from "/.0": Available
    ocpp.0
    	2023-01-18 21:01:53.483	debug	{"connectorId":0,"errorCode":"NoError","status":"Available","timestamp":"2023-01-18T20:01:53.000Z","commandOcpp":"StatusNotification"}
    ocpp.0
    	2023-01-18 21:01:53.285	info	Received boot notification from "/"
    ocpp.0
    	2023-01-18 21:01:53.284	debug	{"chargePointVendor":"go-e","chargePointModel":"go-eCharger","chargePointSerialNumber":"114962","firmwareVersion":"055.0","commandOcpp":"BootNotification"}
    ocpp.0
    	2023-01-18 21:01:53.174	warn	Could not request states of "/": you must provide a joi schema
    ocpp.0
    	2023-01-18 21:01:53.158	info	Requesting StatusNotification from "/"
    ocpp.0
    	2023-01-18 21:01:53.155	info	New device connected: "/"
    ocpp.0
    	2023-01-18 21:01:52.955	info	New valid connection from "/" (http/ocpp1.6)
    ocpp.0
    	2023-01-18 21:01:52.952	debug	Connection from "/" with credentials "undefined", protocol: "http", OCPP: ocpp1.6
    ocpp.0
    	2023-01-18 21:01:44.331	info	Server listening on port 9220
    ocpp.0
    	2023-01-18 21:01:44.208	info	Starting OCPP Server
    ocpp.0
    	2023-01-18 21:01:44.156	info	starting. Version 0.9.1 (non-npm: foxriver76/ioBroker.ocpp) in /opt/iobroker/node_modules/iobroker.ocpp, node: v16.14.2, js-controller: 4.0.23
    ocpp.0
    	2023-01-18 21:01:43.862	debug	States connected to redis: 127.0.0.1:9000
    ocpp.0
    	2023-01-18 21:01:43.829	debug	States create User PubSub Client
    ocpp.0
    	2023-01-18 21:01:43.827	debug	States create System PubSub Client
    ocpp.0
    	2023-01-18 21:01:43.807	debug	Redis States: Use Redis connection: 127.0.0.1:9000
    ocpp.0
    	2023-01-18 21:01:43.766	debug	Objects connected to redis: 127.0.0.1:9001
    ocpp.0
    	2023-01-18 21:01:43.759	debug	Objects client initialize lua scripts
    ocpp.0
    	2023-01-18 21:01:43.647	debug	Objects create User PubSub Client
    ocpp.0
    	2023-01-18 21:01:43.645	debug	Objects create System PubSub Client
    ocpp.0
    	2023-01-18 21:01:43.642	debug	Objects client ready ... initialize now
    ocpp.0
    	2023-01-18 21:01:43.551	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
    • foxriver76F foxriver76
      @fl4sh-0 Es gibt noch MeterValuesAlignedDataMaxLength und das gleiche für MeterValuesSampledDataMaxLength evtl. lässt sampled Data mehr Punkte zu als aligned data?
      fL4sH 0
      #302
      @foxriver76 said in Alpha Testing: OCPP Wallbox Adapter:
      Da hast du recht, danke für den Hinweis. MeterValuesAlignedDataMaxLength lässt nur 4 Werte zu und MeterValuesSampledDataMaxLength lässt 22 Werte zu. Beide States sind leider schreibgeschützt.
        @frank11 Nein, bitte keine Datenpunkte im Adapter selbst anlegen. Was genau fehlt dir?
        frank11
        #303
        @foxriver76 authList fehlt. Obwohl "Local Auth List Management" laut SupportedFeatureProfiles unterstützt wird.
        • F frank11
          foxriver76F Offline
          foxriver76F Offline
          foxriver76
          #304
          @frank11 Zeig mal bitte das Log, er schreibt da die unterstützen Profile rein und auch wenn er States löscht, weil nicht unterstützt.
          Videotutorials & mehr
            frank11
            #305
            @foxriver76 Das einzig interessante ist:
            ocpp.0
            2023-01-19 09:52:38.871 info Supported profiles by client "/21178121966125" are "Core,Local Auth List Management,Reservation,Smart Charging,Remote Trigger"
            Oder muss ich irgendwo noch Debugging einschalten?
            • F frank11
              ocpp.0
              foxriver76F Offline
              foxriver76F Offline
              foxriver76
              #306
              @frank11 Schreibt er auch Removing LocalAuthListManagement functionality as unsupported?
              Es kann sein, dass ich es abfange, allerdings scheint deine WB OCPP1.6 etwas unsauber zu implementieren wie auch schon an der Configuration gesehen.
              Lt. Standard RemoteTrigger statt wie bei dir Remote Trigger etc.
              Version ist die 0.12.0?
              • J Jrlohni
                @foxriver76 Das heißt ich soll die besser übers Terminal im ioBroker Ordner installieren? Wie in deinen ersten Beiträgen? Habe es jetzt normal über die Adapterinstallation in ioBroker gemacht (gestern).
                foxriver76F Offline
                foxriver76F Offline
                foxriver76
                #307
                @jrlohni Vorzugsweise im Admin Tab Adapter, Expertenmodus auf die Katze "von NPM installieren"
                J 1 Antwort Letzte Antwort
                  frank11
                  #308
                  @foxriver76 Ach verdammt, die Einträge hab ich übersehen:
                  ocpp.0
                  2023-01-19 09:52:39.035 info Removing LocalAuthListManagement functionality as unsupported
                  ocpp.0
                  2023-01-19 09:52:38.994 info Removing SmartCharging functionality as unsupported
                  Also auch kein SmartCharging! :-(
                  Ja, habe gerade auf 0.12.0 upgedatet weil ich ja eh die Instanz neu starten musste.
                  foxriver76F 2 Antworten Letzte Antwort
                  • F frank11
                    ocpp.0
                    ocpp.0
                    foxriver76F Offline
                    foxriver76F Offline
                    foxriver76
                    #309
                    @frank11 ich baue das ein, dass er das trotzdem erkennt.
                    • F frank11
                      ocpp.0
                      ocpp.0
                      foxriver76F Offline
                      foxriver76F Offline
                      foxriver76
                      #310
                      @frank11 Bitte 0.12.1 testen
                        frank11
                        schrieb am zuletzt editiert von frank11
                        #311
                        @foxriver76 Wird noch nicht angeboten, ich schaue morgen nochmal.
                        authList fehlt immer noch.
                          Jrlohni
                          #312
                          @foxriver76 habe die 0.12.1 installiert und eingerichtet. Es tauchen schon deutlich mehr Werte auf! Allerdings klappt das dynamische Laden leider nicht mehr. Vorher konnte ich bei "chargeLimit" die Ampere eingeben und er hat sie anstandslos übernommen. Jetzt werden sie nicht mehr übernommen.
                          So sieht es vor dem anschließen des Autos aus:
                          Bildschirm­foto 2023-01-19 um 15.13.58.png Bildschirm­foto 2023-01-19 um 15.14.18.png
                          So sieht es nach dem Anschließen aus:
                          Bildschirm­foto 2023-01-19 um 16.04.03.png Bildschirm­foto 2023-01-19 um 16.04.26.png
                          Das sagt die Log dazu:
                          Falls die Debug Datei noch was bringt, bräuchte ich einmal Hilfe wo ich diese finde... :)
                          Grüße!
                          SoeniS foxriver76F F 3 Antworten Letzte Antwort
                          • J Jrlohni
                            Grüße!
                            SoeniS Offline
                            SoeniS Offline
                            Soeni
                            #313
                            Helfen die logs was?
                            • SoeniS Soeni
                              foxriver76F Offline
                              foxriver76F Offline
                              foxriver76
                              #314
                              @soeni Ich weiß nicht was in der Installation nicht stimmt. Das you most provide a valid joi scheme hatten wir weiter oben schon mal, glaube da war irgendeine Versionskonflikt mit einem anderen Adapter.
                              • J Jrlohni
                                Grüße!
                                foxriver76F Offline
                                foxriver76F Offline
                                foxriver76
                                #315
                                @jrlohni Evtl. lehnt die WB ab, da du von 3 phasigen auf 1 phasiges Laden wechselt. Die Möglichkeit ist neu und eigentlich die einzige Änderung zu vorher, dass wir die Anzahl an Phasen mitsenden.
                                Hast du diesen Punkt in der Config?
                                F J 2 Antworten Letzte Antwort
                                  frank11
                                  #316
                                  @foxriver76 Bei mir funktioniert zumindest jetzt das SmartCharging mit 0.12.1:
                                  • F frank11
                                    foxriver76F Offline
                                    foxriver76F Offline
                                    foxriver76
                                    #317
                                    @frank11 sagte in Alpha Testing: OCPP Wallbox Adapter:
                                    D. H. authList nicht da in connector 0?
                                      frank11
                                      #318
                                      @foxriver76 Leider nein:
                                      • F frank11
                                        foxriver76F Offline
                                        foxriver76F Offline
                                        foxriver76
                                        #319
                                        @frank11 dann log bitte ob er wieder deaktiviert hat
                                        • F frank11
                                          foxriver76F Offline
                                          foxriver76F Offline
                                          foxriver76
                                          schrieb am zuletzt editiert von foxriver76
                                          #320
                                          @frank11 ah ok du hast kein connector 0 😬
                                          Braucht der Adapter nochmal Anpassung
