  4. Test Adapter renault v0.0.x für myRenault und myDacia
387 Beiträge 59 Kommentatoren 96.8k Aufrufe 56 Beobachtet
  • T tombox
    @jey-cee Ein Update auf 0.0.9 reicht damit der Adapter wieder funktioniert
    Es muss kein API key oder ähnliches eingegeben werden
    Batterystatus is zu finden unter
    renault.0.VIN.battery-status
    Jey CeeJ Online
    Jey CeeJ Online
    Jey Cee
    #101
    @tombox sagte in Test Adapter renault v0.0.x für myRenault und myDacia:
    Das hab ich ja gemacht und hab trotzdem die Meldung bekommen. Ergo reicht ein Update alleine nicht.
    Hier auch mal noch das Log vom Start:
    renault.0
    2022-03-17 14:04:30.518	info	{"error":"access_denied","error_description":"Unauthorized"}
    renault.0
    2022-03-17 14:04:30.518	info	Error: Request failed with status code 403
    renault.0
    2022-03-17 14:04:30.518	info	Feature not found. Ignore battery-inhibition-status for updates.
    renault.0
    2022-03-17 14:04:30.445	warn	State "renault.0.VF1AGVYA050017538.general.vehicleDetails.URL.https://www.youtube.com/watch?v=5di-Asr2r90.url" has no existing object, this might lead to an error in future versions
    renault.0
    2022-03-17 14:04:30.395	info	{"error":"access_denied","error_description":"Unauthorized"}
    renault.0
    2022-03-17 14:04:30.395	info	Error: Request failed with status code 403
    renault.0
    2022-03-17 14:04:30.394	info	Feature not found. Ignore battery-status for updates.
    renault.0
    2022-03-17 14:04:30.356	error	Error: Invalid ID: renault.0.VF1AGVYA050017538.general.vehicleDetails.URL.https://www.youtube.com/watch?v=5di-Asr2r90.url
    renault.0
    2022-03-17 14:04:30.341	info	State value to set for "renault.0.VF1AGVYA050017538.general.vehicleDetails.gearbox.group" has to be type "number" but received type "string"
    renault.0
    2022-03-17 14:04:30.341	info	State value to set for "renault.0.VF1AGVYA050017538.general.vehicleDetails.model.group" has to be type "number" but received type "string"
    renault.0
    2022-03-17 14:04:30.340	info	State value to set for "renault.0.VF1AGVYA050017538.general.vehicleDetails.radioType.group" has to be type "number" but received type "string"
    renault.0
    2022-03-17 14:04:30.339	info	State value to set for "renault.0.VF1AGVYA050017538.general.vehicleDetails.battery.group" has to be type "number" but received type "string"
    renault.0
    2022-03-17 14:04:30.339	info	State value to set for "renault.0.VF1AGVYA050017538.general.vehicleDetails.navigationAssistanceLevel.group" has to be type "number" but received type "string"
    renault.0
    2022-03-17 14:04:30.338	info	State value to set for "renault.0.VF1AGVYA050017538.general.vehicleDetails.radioCode" has to be type "number" but received type "string"
    renault.0
    2022-03-17 14:04:30.337	error	Error: Invalid ID: renault.0.VF1AGVYA050017538.general.vehicleDetails.URL.https://www.youtube.com/watch?v=5di-Asr2r90
    renault.0
    2022-03-17 14:04:30.325	info	State value to set for "renault.0.VF1AGVYA050017538.general.vehicleDetails.engineRatio" has to be type "number" but received type "string"
    renault.0
    2022-03-17 14:04:28.349	info	starting. Version 0.0.9 (non-npm: TA2k/ioBroker.renault#dace9333463b5d5fbae8e62996bdde38a08c7d96) in /opt/iobroker/node_modules/iobroker.renault, node: v12.22.10, js-controller: 4.0.21
    Persönlicher Support
    Spenden -> paypal.me/J3YC33
    • T tombox
      @stephan74 Bräuchte den debug log via privat nachricht . Unter Instanzen in Experteneinstellung die log level von info auf debug setzen
      Stephan74
      #102
      @tombox das debug protokoll habe ich dir im privaten Chat rübergeschickt.
      • S Stephan74
        tombox
        #103
        @stephan74 @Jey-Cee Habe noch was gefunden bitte nochmal via github installieren
        • T tombox
          guergen
          schrieb am zuletzt editiert von guergen
          #104
          @tombox Hab hier die Version 0.0.9 laufen....:
          Grade nochmal von Git installiert, es kommen zwar immer noch jede Menge Fehler, aber die Daten scheint er sich zu holen:
          • G guergen
            tombox
            #105
            @guergen Ja am anfang probiert er alle schnittstellen durch die für das Fahrzeug daten liefern können
            G 1 Antwort Letzte Antwort
            • ? Offline
              #106
              ZOE Adapter bringt auch Error "403".
              Ich glaube bei Renault klemmt es mal wieder.
                HumidorH Offline
                HumidorH Offline
                Humidor
                #107
                warum habt ihr 0.0.9 ? auf Github gibt es 0.2.x
                WICHTIG!!! WENN SIE VON EINER VERSION VOR 0.2.2 AKTUALISIEREN, MÜSSEN SIE ...
                BG
                • HumidorH Humidor
                  Jey CeeJ Online
                  Jey CeeJ Online
                  Jey Cee
                  #108
                  @humidor Weil es hier um den Renault Adapter und nicht um den ZOE2 Adapter geht.
                  • Jey CeeJ Jey Cee
                    HumidorH Offline
                    HumidorH Offline
                    Humidor
                    #109
                    @jey-cee Ahh, ok, das sind dann 2 verschiedene für das Gleiche...
                    BG
                    • T tombox
                      guergen
                      #110
                      @tombox Hier klappt das update scheinbar nicht:
                      Anschliessend bleibt die Update-Info auf "update" und folgendes steht in der Instanz-Liste:
                      Auch über die console geht es nicht iob stop-iob update-iob upgrade-iob start
                      • G guergen
                        tombox
                        #111
                        @guergen Ja mein Fehler habe jetzt 0.0.13 veröffentlicht
                        • T tombox
                          HumidorH Offline
                          HumidorH Offline
                          Humidor
                          schrieb am zuletzt editiert von Humidor
                          #112
                          @tombox hab mir gerade deinen Adapter geladen (danke! 🙏 )
                          in den Meldungen ist was aufgetaucht
                          im Objektbaum wurde sehr viel angelegt und ist aktuell, dh. der Adapter fkt. und hat eine Verbindung
                          was ich spontan nicht finde ist die "chargingPower" vom Zoe2 Adapter ?
                          gibt es wo eine Beschreibung aller DP ?
                          Interessant ist ein schnellerer Updatezyklus während einer Ladung, sonst sind die 10min völlig ausreichend. Wäre ein kürzerer Intervall für dich denkbar einzuarbeiten, oder ev. ein Trigger von Außen?
                          BG
                          T N 2 Antworten Letzte Antwort
                          • HumidorH Humidor
                            tombox
                            #113
                            @humidor remote.refresh sollte ein trigger sein
                            • T tombox
                              HumidorH Offline
                              HumidorH Offline
                              Humidor
                              #114
                              @tombox ok, werde ich probieren, was ist der min. Intervall?
                              BG
                              • HumidorH Humidor
                                tombox
                                #115
                                @humidor Du kannst manuell ausführen so oft du willst bzw renault das blockiert
                                • T tombox
                                  HumidorH Offline
                                  HumidorH Offline
                                  Humidor
                                  #116
                                  @tombox das frage ich ja, soweit ich weiß gibt es Tageslimits und Intervallimits, danns wirst blockiert....
                                  BG
                                  • HumidorH Humidor
                                    N Offline
                                    N Offline
                                    NoRitz
                                    #117
                                    @humidor said in Test Adapter renault v0.0.x für myRenault und myDacia:
                                    Tatsächlich werden diese Objekte erst während des Ladevorgangs angezeigt.
                                    Bin da auch drüber gestolpert und habe jetzt meine Zoe ans Kabel gehängt. Und siehe: Zwei neue Objekte erscheinen unter dem Ordner Batterie:
                                    F 1 Antwort Letzte Antwort
                                    • N NoRitz
                                      Farmer-cb
                                      #118
                                      Servus
                                      gibt es irgendwo eine beschreibung was bei dem
                                      • battery-status.plugStatus
                                      • battery-status.chargingStatus
                                      • battery-inhibition-status.batteryInhibitorStatus
                                      die Nummer für eine Bedeutung haben
                                      smartes Haus durch Digitalstrom, enocean, SPS S7-1215, Homematik, Shelly, Alexa, iobroker auf einem HP-mini mit Proxmox
                                      N 1 Antwort Letzte Antwort
                                      • F Farmer-cb
                                        Servus
                                        N Offline
                                        N Offline
                                        NoRitz
                                        #119
                                        @farmer-cb
                                        Weiß ich nicht. Ich hab die Werte schlicht beobachtet. PlugStatus ist nicht schwer:
                                        1= angeschlossen
                                        0= nicht
                                        chargin status
                                        1= lädt,
                                        -1 nicht.
                                        Auffällig, dass hier -1 statt 0 steht.
                                        Aber da gibt es ja noch die Möglichkeit, über Zeitplan zu laden. Evt ändert sich da der Wert,
                                        Da hilft einfach ausprobieren.
                                          akfmaster
                                          #120
                                          Wieso wirft der Adapter permanent Fehler im Protokoll?
