  4. Test Adapter Z-Wave2 v2.2.x - Eine neue Ära beginnt...
adaptersecurity s2testz-wave 2
49 Beiträge 11 Kommentatoren 7.5k Aufrufe 14 Beobachtet
  • AlCalzoneA AlCalzone
    @esmax666 Ich würde es gezielt nur bei denen machen, die Probleme haben.
    Esmax666
    #41
    @alcalzone
    ok mache ich, ich hääte noch ein frage.
    was heisst das genau ?
    Gerät ist dead? muss neu kaufen ?
    3ead093c-13df-4c48-ab35-08feb9d9bffc-grafik.png 32d59793-4c3f-4fb3-8687-2406d0aacd81-grafik.png
    zwave2.0
    	24906	2021-10-22 20:38:41.117	error	Node 26 interview failed: The node is dead
    hat jemand schon sowas bekommen ?
    2021-10-22T18:39:56.942Z CNTRLR   [Node 026] Beginning interview - last completed stage: None
    2021-10-22T18:40:01.105Z SERIAL « 0x010700132801019e5d                                                 (9 bytes)
    2021-10-22T18:40:01.109Z SERIAL » [ACK]        (0x06)
    2021-10-22T18:40:01.112Z DRIVER « [REQ] [SendData]
                                        callback id:     40
                                        transmit status: NoAck
    2021-10-22T18:40:01.119Z CNTRLR   [Node 026] Node 26 did not respond after 1 attempts, it is presumed dead
    2021-10-22T18:40:01.121Z CNTRLR   [Node 026] ping failed: Failed to send the command after 1 attempts (Status No
                                      Ack) (ZW0020)
    2021-10-22T18:40:01.121Z CNTRLR » [Node 026] querying node info...
    2021-10-22T18:40:01.121Z CNTRLR » [Node 026] pinging the node...
    2021-10-22T18:40:01.127Z SERIAL » 0x010800131a01002529f3                                              (10 bytes)
    2021-10-22T18:40:01.128Z DRIVER » [Node 026] [REQ] [SendData]
                                      │ transmit options: 0x25
                                      │ callback id:      41
                                      └─[NoOperationCC]
    2021-10-22T18:40:01.131Z SERIAL « [ACK]        (0x06)
    2021-10-22T18:40:01.139Z SERIAL « 0x0104011301e8                                                       (6 bytes)
    2021-10-22T18:40:01.139Z SERIAL » [ACK]        (0x06)
    2021-10-22T18:40:01.140Z DRIVER « [RES] [SendData]
                                        was sent: true
    2021-10-22T18:40:05.237Z SERIAL « 0x010700132901019b59                                                 (9 bytes)
    2021-10-22T18:40:05.241Z SERIAL » [ACK]        (0x06)
    2021-10-22T18:40:05.243Z DRIVER « [REQ] [SendData]
                                        callback id:     41
    2021-10-22T18:40:05.248Z CNTRLR   [Node 026] Node 26 did not respond after 1 attempts, it is presumed dead
    2021-10-22T18:40:05.250Z CNTRLR   [Node 026] ping failed: Failed to send the command after 1 attempts (Status No
                                      Ack) (ZW0020)
    2021-10-22T18:40:05.250Z CNTRLR   [Node 026] Interview attempt (1/5) failed, node is dead.
    • nodoeN Offline
      nodoeN Offline
      nodoe
      #42
      ich habe versucht mein Danalock V3 zu includieren. Nach mehreren Versuchen hat das auch geklappt, allerdings sind die icon für S2 Authenticated und S2 Unauthenticated grau:
      Unter Door_Lock findet sich kein Eintrag wie targetMode o.ä., so dass ich das Schloss im iobroker nicht öffnen oder schließen kann:
      Per Smartlock-App funktioniert es. Habt Ihr eine Idee, woran das liegen kann?
      Vielen Dank und schöne Grüße!
      • E Esmax666
        @alcalzone
        zwave2.0
                                            callback id:     40
                                          Ack) (ZW0020)
                                          │ callback id:      41
                                          └─[NoOperationCC]
                                            was sent: true
                                            callback id:     41
                                          Ack) (ZW0020)
        AlCalzoneA Offline
        AlCalzoneA Offline
        AlCalzone
        #43
        @esmax666 sagte in Test Adapter Z-Wave2 v2.2.x - Eine neue Ära beginnt...:
        Gerät ist dead
        Das heißt, dass es nicht antwortet. Kann mehrere Gründe haben:
        1. schlechter Empfang -> Probier mal Netzwerk heilen
        2. kein Strom -> Verkabelung checken
        @nodoe
        Das kann normal sein, z.B. wenn nur S2 Access Control (die höchste Klasse) angefragt wurde.
        Komisch - currentMode ist da. Lade mal die Ansicht im Admin neu. Wenn das nicht tut, neu interviewen.
        Warum sudo böse ist: https://forum.iobroker.net/post/17109
        nodoeN 1 Antwort Letzte Antwort
          Aktuelle Test Version v2.2.5
          Veröffentlichungsdatum 2021-11-03
          Github Link https://github.com/AlCalzone/ioBroker.zwave2/
          Changelog
          Lange war's still, aber es ist viel passiert. Ich freue mich, die neue Generation meines Z-Wave Adapters vorstellen zu können. Diese enthält einen riesigen Berg an Neuerungen.
          Vorher aber noch eine Bitte: Wer bei der Übersetzung helfen möchte (alles außer Deutsch/Englisch) sei herzlich dazu eingeladen: ==> https://forum.iobroker.net/topic/44993/iobroker-übersetzen-ihr-könnt-helfen
          Zunächst zu den Breaking Changes:
          • BREAKING: Node.js v12.22.2 ist jetzt das Minimum
          • BREAKING: Die Handhabung von Endpunkten und Lifeline Associations wurde überarbeitet. Dies behebt Probleme mit automatischen Reports bei vielen Geräten, aber nach einem erneuten Interviews können sich die State IDs in ioBroker ändern. Hiervor wird seit geraumer Zeit per Admin-Meldung gewarnt. Bitte IDs in Skripten etc. unbedingt auf Alias umstellen.
            Außerdem kann es in Einzelfällen noch vorkommen, dass einige zuvor funktionierende Geräte nicht mehr korrekt berichten. Bitte für jedes Gerät, das davon betroffen ist, ein Issue erstellen.
          Jetzt zu den regulären Änderungen:
          • Das Gerätemanagement wurde von den Adaptereinstellungen auf einen extra Z-Wave Tab verschoben.
          • Einige Konfigurationsparameter bieten nun korrekt 0/1 als Option anstelle von 0/-1.
          • Ein Fehler wurde behoben, bei dem die Cache-Datei während eines Shutdowns beschädigt werden konnte
          • 🎉🎉🎉 Unterstützung für Security S2 🎉🎉🎉. Vielen Dank an @Harry94, der mir dafür ein Jahr lang ein Testgerät geliehen hat.
          • Der Z-Wave Tab enthält jetzt einen Reiter zum Anzeigen und Downloaden von Z-Wave Debug-Logs
          • Unterstützung für Geräte, die Supervision CC zum Senden von Befehlen verwenden
          • Unterstützung für das Zurücksetzen des Controllers auf die Werkseinstellungen
          • Unterstützung für die Änderung der Region/Frequenz des Controllers
          • Unterstützung für das Ersetzen ausgefallener Geräte unter Beibehaltung der Node ID
          • Einige Korrekturen für Firmware-Updates
          Update v2.1.0:
          Es geht Schlag auf Schlag... In Version 2.1 kann man jetzt Befehle an mehrere Geräte gleichzeitig absetzen. Bitte beachten, dass die entsprechenden Datenpunkte nur schreibbar sind und nicht mit dem tatsächlichen Zustand der Geräte aktualisiert werden.
          • Unterstützung für Broadcast-Kommandos (an alle Geräte) mit den Datenpunkten zwave2.0.Broadcast.*
          • Unterstützung für Multicast-Kommandos (Gruppen von Geräten) mit den Datenpunkten zwave2.0.Group_*.*.
            Die Gruppen können im Z-Wave Tab unter "Gruppen" verwaltet werden:
          Update v2.2.0:
          • Die Geräteliste enthält jetzt eine Aktivitätsanzeige und Statistiken für jedes Gerät:
          • Verbesserungen an der "Scene Actuator Configuration CC" und der "Scene Controller Configuration CC".
          • Diverse Korrekturen für Security S2 in Kombination mit Supervision CC
          • Workaround für einen Fehler in Z-Wave-Sticks mit Firmware 7.15 und höher, der zu fehlenden Fähigkeiten führte
          • Fix: Der Tab startet wieder auf "Geräte" statt auf "Gruppen"
          • Fix: Werte von sicheren Knoten werden nicht mehr unter Broadcast angeboten
          • Fix: Anzeige der generischen Geräteklasse, wenn die spezifische Geräteklasse "Unused" ist
          • Fix: Rollen bestehender Zustände werden nun beibehalten
          • Viele geänderte und neue Gerätekonfigurationsdateien, siehe hier und hier
          Update v2.2.1:
          • Fix: Absturz beim Entfernen von Geräten, die in einer Multicast-Gruppe enthalten sind
          • Fix: Schreibgeschützte "boolesche" Zustände werden jetzt mit Typ "switch" statt "button" angelegt
          • Korrupte "Multilevel Sensor CC" und "Meter CC" Reports werden jetzt herausgefiltert
          • Korrekturen bei der automatischen Zuweisung von Lifeline Associations
          • Kleine Korrekturen für die sichere Inklusion von Geräten
          • Neue und aktualisierte Konfigurationsdateien, siehe hier
          Updates v2.2.2-v2.2.4:
          • Fix: Für die meisten Geräte, die es nicht unterstützen, wird nicht mehr standardmäßig Supervision verwendet
          • Fix: Admin-UI unterstützt ältere Browser besser
          • Fix: Beim Verwalten mehrerer Instanzen überschreiben sich die Instanz-Konfigurationen nicht mehr gegenseitig
          • Kleinere Korrekturen und Stabilitätsverbesserungen
          Update v2.2.5:
          Stellt nur sicher, dass nicht ausversehen eine neue, inkompatible Version von zwave-js installiert wird.
          WICHTIG:
          Um die Übersicht zu behalten (ich bekomme täglich >10 Issues gemeldet), alles was nicht unmittelbar mit V2 zu tun hat, als Issue in Github anlegen. Ansonsten geht's einfach unter...
          gelberlemmyG Offline
          gelberlemmy
          #44
          @alcalzone moin, ich habe die Version 2.3.0 installiert. nach der Installation bekomme ich jetzt eine Fehlermeldung und der Adapter läuft nicht mehr. Bin zurück auf 2.2.4. Auch das gleiche.
          Geschaut ob der Serial noch im Adapter ist. Über SSH geschaut. USB Stick vorhanden.
          PI neu gestartet. Keine verbesserung. Ein Issue auf Github erstellen ? Soll ich Dir einmal das LOG zukommen lassen?
          Anbei die Fehlermeldung:
          zwave2.0
          2021-10-25 20:43:36.834	info	starting. Version 2.3.0 in /opt/iobroker/node_modules/iobroker.zwave2, node: v14.18.1, js-controller: 3.3.18
          zwave2.0
          2021-10-25 20:43:31.294	info	Shutting down driver...
          zwave2.0
          2021-10-25 20:43:29.867	info	Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          zwave2.0
          2021-10-25 20:43:28.866	error	Restarting the adapter in a second...
          zwave2.0
          2021-10-25 20:43:28.865	error	Failed to initialize the driver: ZWaveError: The driver is not ready or has been destroyed (ZW0103) at Driver.ensureReady (/opt/iobroker/node_modules/zwave-js/src/lib/driver/Driver.ts:1764:10) at Driver.sendMessage (/opt/iobroker/node_modules/zwave-js/src/lib/driver/Driver.ts:2931:8) at ZWaveController.interview (/opt/iobroker/node_modules/zwave-js/src/lib/controller/Controller.ts:506:22) at Driver.initializeControllerAndNodes (/opt/iobroker/node_modules/zwave-js/src/lib/driver/Driver.ts:932:27) at Immediate.<anonymous> (/opt/iobroker/node_modules/zwave-js/src/lib/driver/Driver.ts:809:16) (ZW0100)
          gelberlemmyG 1 Antwort Letzte Antwort
          • gelberlemmyG gelberlemmy
            zwave2.0
            zwave2.0
            zwave2.0
            zwave2.0
            zwave2.0
            gelberlemmy
            #45
            @gelberlemmy sagte in Test Adapter Z-Wave2 v2.2.x - Eine neue Ära beginnt...:
            zwave2.0
            zwave2.0
            zwave2.0
            zwave2.0
            zwave2.0
            Habe jetzt einmal die Anleitung aus dem Adapter gelesen und geschaut, ober der Stick eine neue Serielle Adresse bekommen hat. War aber nicht der Fall. Das einzige was geholfen hat, den Haken zu setzen, damit der Controller nicht mit neu gestartet wird. Mit was für Einschränkungen muss ich da rechnen, da dies so in der Beschreibung steht ?
              zwave2.0
              zwave2.0
              zwave2.0
              zwave2.0
              zwave2.0
              AlCalzoneA Offline
              AlCalzoneA Offline
              AlCalzone
              #46
              @gelberlemmy
              Welchen Stick hast du denn?
              Es kann sein, dass in der Zukunft manche Controller-Funktionen nicht gehen ohne soft reset, z.B. Backup und Restore (kann der Adapter aber noch nicht).
              • AlCalzoneA Offline
                AlCalzoneA Offline
                AlCalzone
                #47
                Übrigens, hier gehts weiter: https://forum.iobroker.net/topic/48782/test-adapter-z-wave-2-v2-3-x
                  @gelberlemmy
                  gelberlemmy
                  #48
                  @alcalzone sagte in Test Adapter Z-Wave2 v2.2.x - Eine neue Ära beginnt...:
                  @gelberlemmy
                  Moin, ich habe den Z-Wave USB Stick (ZMEEUZB1).
                  Aber ich habe gesehen, dass Du ein Update diesbezüglich heraus gebracht hast. Werde ich gleich einmal testen
                    Gerät ist dead
                    @nodoe
                    nodoeN Offline
                    nodoeN Offline
                    nodoe
                    #49
                    @alcalzone
                    War heute erst wieder am Schloss. Wie immer im Leben: Heilen hilft, auch wenns lange dauert... Danke für den Tipp!!!
