  3. Entwicklung
  4. Synology Chat ...
    6.1k
Synology Chat ...
chatsynologysynology diskstationadaptermessage handler
184 Beiträge 19 Kommentatoren 42.4k Aufrufe 16 Beobachtet
  • GlasfaserG Glasfaser
    @dslraser
    Ich kann dir das Test Blockscript schicken wo ich noch am Basteln bin funktioniert aber , wenn es reicht !?
     <variables>
       <variable id="0;mm8IOdOmH_wz;%[zPo">Syno_URL</variable>
       <variable id=",O#!.RmBLV$D$25E`o7/">Syno_Port</variable>
       <variable id="Eg)M29q*/71]Q#lGjYO;">Chat_token</variable>
       <variable id="`=hGQ*[0C+pxdf]k]sV]">Nachricht</variable>
       <variable id="u^a{RwAvq(*-0PK`(`@4">URL_Snapshot</variable>
       <variable id="yW]q[i/Yfz.,5Z+Vb.a,">URL_ioBroker</variable>
       <variable type="timeout" id="timeout">timeout</variable>
       <variable id=")2,KTR||]G~d7xyd!QUZ">send</variable>
       <variable type="timeout" id="timeout1">timeout1</variable>
       <variable id="s`TAk}2fZk|p^o$4+d@t">result</variable>
     </variables>
     <block type="procedures_defcustomnoreturn" id=")M6lvmD#MPU2;=lc,6D:" x="713" y="-112">
       <mutation statements="false"></mutation>
       <field name="NAME">loesche Bild</field>
       <field name="SCRIPT">dW5saW5rKCcwX3VzZXJkYXRhLjAnLCAnc3lub2xvZ3kvYmlsZC5qcGcnLChlKT0+ew0KDQogICAgaWYoZSkgbG9nKGUpDQoNCn0pDQoNCg==</field>
     </block>
     <block type="procedures_defcustomnoreturn" id="Fh|~ouZqovH}}ZEi:0P{" x="713" y="-87">
       <field name="NAME">Bild_holen</field>
       <field name="SCRIPT">DQoNCg0KcmVxdWVzdCgNCg0KICB7DQoNCiAgICB1cmw6IFVSTF9TbmFwc2hvdCAsDQoNCiAgICBlbmNvZGluZzogbnVsbCwNCg0KICB9LA0KDQogIChlcnJvciwgcmVzcG9uc2UsIGJvZHkpID0+IHsNCg0KICAgIGlmICghZXJyb3IgJiYgYm9keSkgew0KDQogICAgICB3cml0ZUZpbGUoIjBfdXNlcmRhdGEuMCIsICIvc3lub2xvZ3kvYmlsZC5qcGciLCBib2R5KTsNCg0KICAgIH0NCg0KICB9DQoNCik7DQo=</field>
     </block>
     <block type="on_ext" id="[.;w?/pK-.4zyW!UyYBl" x="-262" y="63">
       <value name="OID0">
         <shadow type="field_oid" id="3VnM3u.?JEhM[^n/?X0p">
           <field name="oid">0_userdata.0.Testbutton</field>
         </shadow>
       </value>
       <statement name="STATEMENT">
         <block type="variables_set" id="u^*rT,0CM,T_]XeGow}h">
           <field name="VAR" id="0;mm8IOdOmH_wz;%[zPo">Syno_URL</field>
           <value name="VALUE">
             <block type="text" id="K]+z|W)qG[s?viD8cP}Q">
               <field name="TEXT">192.168.xxx.x</field>
             </block>
           </value>
           <next>
             <block type="variables_set" id=",|/0@uFO[kJp[pSjyfW~">
               <field name="VAR" id=",O#!.RmBLV$D$25E`o7/">Syno_Port</field>
                 <block type="text" id="YmIhCu8+dV@OO0U[PWx#">
                   <field name="TEXT">5000</field>
                 </block>
               </value>
               <next>
                 <block type="variables_set" id="Z}%_nt.Jz``.b})ifYmx">
                   <field name="VAR" id="Eg)M29q*/71]Q#lGjYO;">Chat_token</field>
                     <block type="text" id="[^9?/_`o:[u8zr_:o:`T">
                       <field name="TEXT">hier dein Token</field>
                     </block>
                   </value>
                   <next>
                     <block type="variables_set" id="m/`Hepc#d!=l=Yu?E{!6">
                       <field name="VAR" id="`=hGQ*[0C+pxdf]k]sV]">Nachricht</field>
                         <block type="text" id="naz0gbDT{!MOKW]c|g8{">
                           <field name="TEXT">Es klingelt an der Haustuer</field>
                         </block>
                       </value>
                       <next>
                         <block type="variables_set" id="fT*7tvvXRtyOgN,6C,2?">
                           <field name="VAR" id="u^a{RwAvq(*-0PK`(`@4">URL_Snapshot</field>
                             <block type="text" id="N]=+,oldD=_C5-KIA*6[">
                               <field name="TEXT">Hier habe ich ein direktlink von meiner Hikvision Snapshot</field>
                             </block>
                           </value>
                           <next>
                             <block type="procedures_callcustomnoreturn" id="J8Bxi=.l@zrRJkcGT150">
                               <mutation name="Bild_holen"></mutation>
                               <next>
                                 <block type="variables_set" id="Q8SV]H7m2;RCEIl!I32S">
                                   <field name="VAR" id="yW]q[i/Yfz.,5Z+Vb.a,">URL_ioBroker</field>
                                     <block type="text" id="Cw;l)b1L4K(P86t9=T}E">
                                       <field name="TEXT">http://192.168.xxxxxxx:8082/0_userdata.0/synology/bild.jpg</field>
                                     </block>
                                   </value>
                                   <next>
                                     <block type="timeouts_cleartimeout" id="1#Qx;^WXsqqn)X|6E2jF">
                                       <next>
                                         <block type="timeouts_cleartimeout" id="]P6ccsD65Q=LsNc=*[+u">
                                           <field name="NAME">timeout1</field>
                                           <next>
                                             <block type="timeouts_settimeout" id=",Vl,JVw3kG.#VrRAqd:b">
                                               <field name="DELAY">4000</field>
                                               <field name="UNIT">ms</field>
                                                 <block type="variables_set" id="0jj@r*)y_VPw~)q+,3)N">
                                                   <field name="VAR" id=")2,KTR||]G~d7xyd!QUZ">send</field>
                                                     <block type="text_join" id="Q^/K[ogSU%663c!lHXyf">
                                                       <mutation items="11"></mutation>
                                                       <value name="ADD0">
                                                         <block type="text" id="Xp!K%fv+S+C7_K~7ka^c">
                                                           <field name="TEXT">http://</field>
                                                         </block>
                                                       </value>
                                                       <value name="ADD1">
                                                         <block type="variables_get" id="U#z.iPhHMr!oaBW_.L}$">
                                                         </block>
                                                       </value>
                                                       <value name="ADD2">
                                                         <block type="text" id="|ITd9=%HnJAhhwgaz3|-">
                                                           <field name="TEXT">:</field>
                                                         </block>
                                                       </value>
                                                       <value name="ADD3">
                                                         <block type="variables_get" id="_E?oZ@h{l{gD!e{A..FQ">
                                                         </block>
                                                       </value>
                                                       <value name="ADD4">
                                                         <block type="text" id="_^c23]w8ve_wLo_pG;lU">
                                                           <field name="TEXT">/webapi/entry.cgi?api=SYNO.Chat.External&amp;method=incoming&amp;version=2&amp;token="</field>
                                                         </block>
                                                       </value>
                                                       <value name="ADD5">
                                                         <block type="variables_get" id="p//Pgq^!$p27`+=TYO0t">
                                                         </block>
                                                       </value>
                                                       <value name="ADD6">
                                                         <block type="text" id="zG0}^=D_TXDv9Tjx8afb">
                                                           <field name="TEXT">"&amp;payload={"text":"</field>
                                                         </block>
                                                       </value>
                                                       <value name="ADD7">
                                                         <block type="variables_get" id="];FJ@4Io`JJ?oyGqhlTU">
                                                         </block>
                                                       </value>
                                                       <value name="ADD8">
                                                         <block type="text" id="G|.7zo{,tbQ8-Uo83p,)">
                                                           <field name="TEXT">", "file_url": "</field>
                                                         </block>
                                                       </value>
                                                       <value name="ADD9">
                                                         <block type="variables_get" id="v/9SP;]`*blX7Qt=h~Eu">
                                                         </block>
                                                       </value>
                                                       <value name="ADD10">
                                                         <block type="text" id="z1]{?Af3zI_+#txN*=UR">
                                                           <field name="TEXT">"}</field>
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                   <next>
                                                     <block type="timeouts_settimeout" id="dUpl:*/S.GOlt6yy5+E?">
                                                       <field name="DELAY">1000</field>
                                                         <block type="request" id="939:VQbG=f:Lt(8,--UH">
                                                           <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="true"></mutation>
                                                           <field name="WITH_STATEMENT">TRUE</field>
                                                           <field name="LOG"></field>
                                                           <value name="URL">
                                                             <shadow type="text" id="1o%c{S``+)7HEh-A%)U^">
                                                             </shadow>
                                                             <block type="variables_get" id="vAPQA_YY6uy)ow09^`*K">
                                                             </block>
                                                           </value>
                                                             <block type="debug" id="qZVJ(@5Ef)}jneJ%Q)_N">
                                                               <value name="TEXT">
        <shadow type="text" id="S=pA)VcRi34L-{?F`HMz">
        </shadow>
        <block type="variables_get" id="N_1)-!F8nh][M#5EAmb6">
        <field name="VAR" id="s`TAk}2fZk|p^o$4+d@t">result</field>
        </block>
                                                               </value>
                                                             </block>
                                                           </statement>
                                                           <next>
                                                             <block type="debug" id="v:z{{P}3]9(0mcj`VrK7">
                                                               <value name="TEXT">
        <shadow type="text">
        </shadow>
        <block type="variables_get" id="/5v?Iwot|ODZ)QhG%957">
        </block>
                                                               </value>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </statement>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </statement>
                                             </block>
                                           </next>
                                         </block>
                                       </next>
                                     </block>
                                   </next>
                                 </block>
                               </next>
                             </block>
                           </next>
                         </block>
                       </next>
                     </block>
                   </next>
                 </block>
               </next>
             </block>
           </next>
         </block>
       </statement>
     </block>
    </xml>
    Ich baue es gerade auf die gekürzte Version um .
    dslraserD Offline
    dslraserD Offline
    dslraser
    #81
    @glasfaser sagte in Synology Chat ...:
    Das ist wohl das Problem, ich nehme immer den Link vom Synology Adapter, aber damit kommt eine Fehlermeldung.
    • dslraserD dslraser
      GlasfaserG Offline
      GlasfaserG Offline
      Glasfaser
      #82
      @dslraser
      setze mal ein Debug , was als Wert in URL_Snapshot geschrieben wird .
      Ich teste immer mit einem Dummy Link:
      Beispiel :
      https://upload.wikimedia.org/wikipedia/commons/a/aa/Sun920607.jpg
      dslraserD GlasfaserG 2 Antworten Letzte Antwort
        @dslraser
        Beispiel :
        dslraserD Offline
        dslraserD Offline
        dslraser
        #83
        es wird genau der Link geschrieben der in dem DP steht. Wenn ich diese Link in den Browser eingebe, dann ist sofort das Bild zu sehen. Hast Du den Syno Adapter installiert ?
          GlasfaserG Offline
          GlasfaserG Offline
          Glasfaser
          #84
          @dslraser sagte in Synology Chat ...:
          Logo ... habe ich den .
          Auch mit diesem Link funktioniert es ....
          Oder versuche mal .
          Kopiere den Link daraus und trage Ihn ein , also nicht per wert holen
            Oder versuche mal .
            dslraserD Offline
            dslraserD Offline
            dslraser
            #85
            schon probiert, gleiche Fehlermeldung
              GlasfaserG Offline
              GlasfaserG Offline
              Glasfaser
              #86
              @dslraser
              is not in the cert's list:
              Kenn diese Meldung nicht ... hast du noch mehr im Log dazu stehen
                @dslraser
                dslraserD Offline
                dslraserD Offline
                dslraser
                #87
                @glasfaser
                nein, leider nur das
                EDIT: doch noch was, dieser Error Code
                {"error":{"code":117},"success":false}
                  @glasfaser
                  GlasfaserG Offline
                  GlasfaserG Offline
                  Glasfaser
                  #88
                  Diese Meldung sagt aus ... vom Chatserver , das der Inhalt Bild fehlt .
                  ist leer .
                  Was kommt hiermit als Ausgabe
                  <block xmlns="https://developers.google.com/blockly/xml" type="request" id="jGRe=jAvY7pi~/M7zdOV" x="338" y="88">
                   <value name="URL">
                     <shadow type="text" id="Kcq}@/lN.7+@VX{.Sl1~">
                       <field name="TEXT">Hier dein Link</field>
                     </shadow>
                   </value>
                     <block type="debug" id="!N5up[B{T/LTTi-_ecn9">
                       <value name="TEXT">
                         <shadow xmlns="http://www.w3.org/1999/xhtml" type="text" id="J`/`lk[1@05UD[2~T+TL">
                         </shadow>
                         <block type="variables_get" id="Hh~k_N+@YbO%UvlA/@bU">
                           <field name="VAR" id="%3Mff6CD,)5FpTyqT-?!">result</field>
                         </block>
                       </value>
                       <next>
                         <block type="debug" id="?da:0)J$|KrxbYk`B}(B">
                           <value name="TEXT">
                             </shadow>
                             <block type="variables_get" id="+W;=rb#yQo|PE}[-2UtT">
                               <field name="VAR" id="k/Bs#bIB:Ff8L9lv4^-d">stdout</field>
                             </block>
                           </value>
                           <next>
                             <block type="debug" id="RXN$G!=O`P9nhNpVu#(N">
                               <value name="TEXT">
                                 <shadow xmlns="http://www.w3.org/1999/xhtml" type="text" id="Lbpbr1oEFz|ETX~l$^Cs">
                                 </shadow>
                                 <block type="variables_get" id=",4pl9#rI2/9w19HTHk~o">
                                   <field name="VAR" id="Cjr.[GB6284iu*rOZxn}">stderr</field>
                                 </block>
                               </value>
                               <next>
                                 <block type="debug" id=";K*88rm67)kSl|OR`?4:">
                                   <value name="TEXT">
                                     <shadow xmlns="http://www.w3.org/1999/xhtml" type="text" id="y:/8xVy;=1lXAoSk~x)4">
                                     </shadow>
                                     <block type="variables_get" id="@Rs4BpAt%r]mmn4Aj_::">
                                       <field name="VAR" id="_qJ[C$+4||[A|G%Qg~xD">error</field>
                                     </block>
                                   </value>
                                 </block>
                               </next>
                             </block>
                           </next>
                         </block>
                       </next>
                     </block>
                   </statement>
                  </block>
                    ist leer .
                     <value name="URL">
                       </shadow>
                     </value>
                         <value name="TEXT">
                           </shadow>
                           </block>
                         </value>
                         <next>
                             <value name="TEXT">
                               </shadow>
                               </block>
                             </value>
                             <next>
                                 <value name="TEXT">
                                   </shadow>
                                   </block>
                                 </value>
                                 <next>
                                     <value name="TEXT">
                                       </shadow>
                                       </block>
                                     </value>
                                   </block>
                                 </next>
                               </block>
                             </next>
                           </block>
                         </next>
                       </block>
                     </statement>
                    </block>
                    dslraserD Offline
                    dslraserD Offline
                    dslraser
                    #89
                    Damit schmiert mir die ganze JS-Instanz ab...
                      GlasfaserG Offline
                      GlasfaserG Offline
                      Glasfaser
                      #90
                      @dslraser
                      Ist dann sowas enthalten im Log
                      �J�)ԃ�hp1�@�S$t�i�@皙�Q2�BH@�461Hh
                      1�4�J�S
                      k(��Gz�[�P�%����4PEJ�@✍��<�1Q��
                      .j5#8�<���G�>�%#c��/Z�i<�z�c@���<⣐�b�#Rs���h
                      C�(�<�)��~���g�V�"��'�1�?ZkR�1L�g�=s���F��R�o�1@
                      9����������HǠ��'���zӍ0��@�JM�0h�KL�S���"�>���9�
                      6�@��ך3��6��?���K����:����$]�WN��eFp����&\q�@����i�U�5Z"��PV�
                      H�i���
                      H�i��#ja��0�f�E<�i��#4ʐ�$t�m����R*$<��r(�����Wk�[�횭(��n����(��q3R/��R���+ץ<��)�^j3��;�m��h=)9ݜҚJB�N�ɧ�AA��ݏji'84�N�i�n\�4�I{z��A�6y��g�Ӕ��iO_ZpA���<�܌�4�rzSB�I h�(&�N(Ƞ��qG}���zRP:�uQ@j(8� ��s�c�zs}�A�K�Pf��E(P �Z��r8�4gҀ��3Q���֞��5�(h�P?����♌����f�p)ꅎR�4�IS�6XR�����N;�R~\Te�@ A�'��dSI�8=(A �A9�
                      �i+)>��h��ihGJ(Q@.i)}�1��H�4�@��8�E4�h4
                      &��- '�\R�E �@-��1IR�`c��E����&��sN$���@4��
                      &h'�]ԡ��ih���4�Ӂy�zSM%'���ڀHh�9�@i)3K�J1K֓4��M5!釭4�����d����]�1�*՚zӕ�9���ܛ�Ac�
                      [4�;��G#6�l�Yj����EV�0�
                      �EԲ'<�z�MJ�TԈA�ڀ,�r��rW�r�hpi�j jE�@�L�@�"�e7�q����A�Q:�4�ER�n �b�;�����R�m(�R�m(�R�R�QN�J(�
                        @dslraser
                        1�4�J�S
                        H�i���
                        dslraserD Offline
                        dslraserD Offline
                        dslraser
                        #91
                        nein
                          @dslraser
                          1�4�J�S
                          H�i���
                          dslraserD Offline
                          dslraserD Offline
                          dslraser
                          #92
                          @glasfaser
                          sowas kommt zuerst
                          TypeError: Converting circular structure to JSON
                            nein
                            GlasfaserG Offline
                            GlasfaserG Offline
                            Glasfaser
                            #93
                            @dslraser
                            Komisch , das ist ein normaler Result .
                            das mit den Zeichen ist das Bild von der Cam was zurückkommt .
                            Aber es darf nicht JS abschmieren dadurch .
                              @dslraser
                              Beispiel :
                              GlasfaserG Offline
                              GlasfaserG Offline
                              Glasfaser
                              #94
                              Beispiel :
                              Hast du mal , anstatt dem Cam Link , das hier gemacht !?
                                Beispiel :
                                dslraserD Offline
                                dslraserD Offline
                                dslraser
                                #95
                                Nichtmal das klappt...Ich habe gerade keine Idee was bei mir hier schief läuft.
                                  Beispiel :
                                  dslraserD Offline
                                  dslraserD Offline
                                  dslraser
                                  #96
                                  Stop, das geht...
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    Glasfaser
                                    #97
                                    @dslraser
                                    Also liegt das Bild auch nicht dann in
                                    Targe in der URL_ioBrocker auch den Link vom Bild ein , was ist dann
                                    EDIT :
                                    OK hat sich überschnitten
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      Glasfaser
                                      #98
                                      @dslraser
                                      Also gibt es Probleme beim Bild holen , von dem Syn Link .
                                      Mhh ....
                                      Vielleicht braucht er länger zum Bild holen , setze mal ein Timeout nach dem Bildholen , so das die anderen abläufe später kommen .
                                        @dslraser
                                        Mhh ....
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        Glasfaser
                                        #99
                                        @dslraser
                                        Hier die gekürzte Version "Chatnachricht mit Umlaute und Bildversand"
                                         <variables>
                                           <variable id="$Tar!(b_)qw:24xtP(vj">url</variable>
                                           <variable id="D5Tj,(Y%B2Tp[@g/2DPn">Debug_URL</variable>
                                           <variable id="/j={Oe4(A3y)y{F~G67H">Debug_send_Result</variable>
                                         </variables>
                                         <block type="procedures_defcustomnoreturn" id="Fh|~ouZqovH}}ZEi:0P{" x="488" y="-537">
                                         </block>
                                         <block type="procedures_defcustomreturn" id="B`%(UJ@(5HI^#[)t`k$:" x="488" y="-512">
                                             <arg name="url" varid="$Tar!(b_)qw:24xtP(vj"></arg>
                                           </mutation>
                                           <field name="NAME">encodeURI</field>
                                           <field name="SCRIPT">dXJsID0gZW5jb2RlVVJJQ29tcG9uZW50KHVybCk7DQpyZXR1cm4gdXJsOw==</field>
                                           <comment pinned="false" h="80" w="160">encode URL function</comment>
                                         </block>
                                         <block type="procedures_defcustomnoreturn" id="c4Zobeu@zHx7@T7RCR[+" x="488" y="-487">
                                           <field name="NAME">Chat_senden</field>
                                           <field name="SCRIPT">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</field>
                                         </block>
                                         <block type="comment" id="dh?Nq_).+o*LRx@ZBJ/P" x="488" y="-463">
                                           <field name="COMMENT">https://forum.iobroker.net/topic/47210/synology-chat/98</field>
                                           <next>
                                             <block type="comment" id="]-LvUJjLlh6nbfULNnAm">
                                               <field name="COMMENT">Synology Chat Daten</field>
                                               <next>
                                                       <field name="TEXT">Deine IP</field>
                                                     </block>
                                                   </value>
                                                   <next>
                                                         </block>
                                                       </value>
                                                       <next>
                                                               <field name="TEXT">Dein Token</field>
                                                             </block>
                                                           </value>
                                                           <next>
        <field name="TEXT">Dein Snapshot Link</field>
        </block>
                                                               </value>
                                                               <next>
        <field name="TEXT">http://192.168.xxx.xxx:8082/0_userdata.0/synology/bild.jpg</field>
        </block>
        </value>
        <next>
        <block type="variables_set" id="*dQxDuFmm[ppsJg3%3!V">
        <block type="procedures_callcustomreturn" id="GD%^L~Wq_LIL_y86c}(2">
        <mutation name="encodeURI">
        <arg name="url"></arg>
        </mutation>
        <value name="ARG0">
        <block type="text" id="+_Bx+X)YJc^_8RSz74zE">
        <field name="TEXT">Alarm an der  Haustür</field>
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="comment" id="#X/LLHHf]+a]HP9ULZZA">
        <field name="COMMENT">Debugmodus an/aus</field>
        <next>
        <block type="variables_set" id="]Dg;,gKp,/]Sb1cUFi?n">
        <field name="VAR" id="D5Tj,(Y%B2Tp[@g/2DPn">Debug_URL</field>
        <block type="logic_boolean" id="0~lqDtIM29hgH2or)}mL">
        </block>
        </value>
        <next>
        <block type="variables_set" id="W=GM=?`a~14E-J+QXSAQ">
        <field name="VAR" id="/j={Oe4(A3y)y{F~G67H">Debug_send_Result</field>
        <block type="logic_boolean" id="*JUO/RsrY?M/l53;H_pF">
        </block>
        </value>
        <next>
        <block type="comment" id="[gDu2J;3btcPa(EESlU!">
        <field name="COMMENT">Ab hier Trigger</field>
        <next>
        <block type="on_ext" id="9h_zLLHz{65UPzm^$7}e">
        <value name="OID0">
        <shadow type="field_oid" id="NgekYWG@PsA7G02OF}rj">
        <field name="oid">0_userdata.0.Test123</field>
        </shadow>
        </value>
        <block type="controls_if" id="mSYXDpsYHKUM+j9uSS2s">
        <value name="IF0">
        <block type="on_source" id="l[/NtLhpCNaa5/@gH6X-">
        </block>
        </value>
        <statement name="DO0">
        <block type="procedures_callcustomnoreturn" id="eimW+=5+~Y|quii}_lBH">
        <next>
        <block type="timeouts_settimeout" id="ht3)ckT6?(PDbQipm{_z">
        <field name="DELAY">2000</field>
        <block type="procedures_callcustomnoreturn" id="[EP#gKV7fF}Y+8x8zkZ^">
        <mutation name="Chat_senden"></mutation>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </statement>
        <statement name="ELSE">
        <block type="timeouts_cleartimeout" id="TKEEXDr0Qo(}RX.!blS5">
        </block>
        </statement>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
                                                               </next>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </next>
                                             </block>
                                           </next>
                                         </block>
                                        </xml>
                                          @Glasfaser
                                          ich bin irgendwie zu blöd ein Bild zu versenden....
                                          Mit Telegram läuft das so:
                                          Der steuere Befehl erzeugt ein neues Bild, das dann auch da ist:
                                          Der Dateipfad in diesem Beispiel ist:
                                          /opt/iobroker/iobroker-data/synology_0/snapshotCam_8.jpg
                                          Ich bekomme es aber nicht hin dieses Bild zu versenden. Ich habe mit Deinem Blockly von weiter oben und auch mit diesem Beispiel rumprobiert....
                                          Wie stelle ich das an ?
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          Glasfaser
                                          #100
                                          Was hälst du davon :
                                          var fs = require('fs');
                                          const bild = fs.readFileSync('/opt/iobroker/iobroker-data/synology_0/snapshotCam_8.jpg');
                                              writeFile('0_userdata.0','/synology/snapshotCam_8.jpg', bild);
                                          Anstatt der URL_Snapshot einfach das Bild in userdata.0 dann kopieren
