  3. Entwicklung
  4. Synology Chat ...
    6.1k
Synology Chat ...
chatsynologysynology diskstationadaptermessage handler
184 Beiträge 19 Kommentatoren 42.4k Aufrufe 16 Beobachtet
  • GlasfaserG Glasfaser
    @wrod
    Beispiel :
    <block xmlns="https://developers.google.com/blockly/xml" type="on_ext" id="[.;w?/pK-.4zyW!UyYBl" x="163" y="88">
      <value name="OID0">
        <shadow type="field_oid" id="3VnM3u.?JEhM[^n/?X0p">
          <field name="oid">0_userdata.0.Test123</field>
        </shadow>
      </value>
      <statement name="STATEMENT">
        <block type="variables_set" id="*dQxDuFmm[ppsJg3%3!V">
          <field name="VAR" id="`=hGQ*[0C+pxdf]k]sV]">Nachricht</field>
          <value name="VALUE">
            <block type="text" id="+_Bx+X)YJc^_8RSz74zE">
              <field name="TEXT">Hier dein Text , ioBroker 2021</field>
            </block>
          </value>
          <next>
            <block type="variables_set" id="u^*rT,0CM,T_]XeGow}h">
              <field name="VAR" id="0;mm8IOdOmH_wz;%[zPo">Syno_URL</field>
                <block type="text" id="K]+z|W)qG[s?viD8cP}Q">
                  <field name="TEXT">192.168.xxx.xxx</field>
                </block>
              </value>
              <next>
                <block type="variables_set" id=",|/0@uFO[kJp[pSjyfW~">
                  <field name="VAR" id=",O#!.RmBLV$D$25E`o7/">Syno_Port</field>
                    <block type="text" id="YmIhCu8+dV@OO0U[PWx#">
                      <field name="TEXT">5000</field>
                    </block>
                  </value>
                  <next>
                    <block type="variables_set" id="Z}%_nt.Jz``.b})ifYmx">
                      <field name="VAR" id="Eg)M29q*/71]Q#lGjYO;">Chat_token</field>
                        <block type="text" id="[^9?/_`o:[u8zr_:o:`T">
                          <field name="TEXT">xxxxxxxxxxxxxxxxxxxxx</field>
                        </block>
                      </value>
                      <next>
                        <block type="timeouts_cleartimeout" id="1#Qx;^WXsqqn)X|6E2jF">
                          <next>
                            <block type="timeouts_cleartimeout" id="]P6ccsD65Q=LsNc=*[+u">
                              <field name="NAME">timeout2</field>
                              <next>
                                <block type="timeouts_settimeout" id=",Vl,JVw3kG.#VrRAqd:b">
                                  <field name="DELAY">1000</field>
                                  <field name="UNIT">ms</field>
                                    <block type="variables_set" id="0jj@r*)y_VPw~)q+,3)N">
                                      <field name="VAR" id=")2,KTR||]G~d7xyd!QUZ">send</field>
                                        <block type="text_join" id="Q^/K[ogSU%663c!lHXyf">
                                          <mutation items="9"></mutation>
                                          <value name="ADD0">
                                            <block type="text" id="Xp!K%fv+S+C7_K~7ka^c">
                                              <field name="TEXT">http://</field>
                                            </block>
                                          </value>
                                          <value name="ADD1">
                                            <block type="variables_get" id="U#z.iPhHMr!oaBW_.L}$">
                                            </block>
                                          </value>
                                          <value name="ADD2">
                                            <block type="text" id="|ITd9=%HnJAhhwgaz3|-">
                                              <field name="TEXT">:</field>
                                            </block>
                                          </value>
                                          <value name="ADD3">
                                            <block type="variables_get" id="_E?oZ@h{l{gD!e{A..FQ">
                                            </block>
                                          </value>
                                          <value name="ADD4">
                                            <block type="text" id="_^c23]w8ve_wLo_pG;lU">
                                              <field name="TEXT">/webapi/entry.cgi?api=SYNO.Chat.External&amp;method=incoming&amp;version=2&amp;token="</field>
                                            </block>
                                          </value>
                                          <value name="ADD5">
                                            <block type="variables_get" id="p//Pgq^!$p27`+=TYO0t">
                                            </block>
                                          </value>
                                          <value name="ADD6">
                                            <block type="text" id="zG0}^=D_TXDv9Tjx8afb">
                                              <field name="TEXT">"&amp;payload={"text":"</field>
                                            </block>
                                          </value>
                                          <value name="ADD7">
                                            <block type="variables_get" id="];FJ@4Io`JJ?oyGqhlTU">
                                            </block>
                                          </value>
                                          <value name="ADD8">
                                            <block type="text" id="G|.7zo{,tbQ8-Uo83p,)">
                                              <field name="TEXT">"}</field>
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                      <next>
                                        <block type="timeouts_settimeout" id="dUpl:*/S.GOlt6yy5+E?">
                                            <block type="request" id="939:VQbG=f:Lt(8,--UH">
                                              <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="true"></mutation>
                                              <field name="WITH_STATEMENT">TRUE</field>
                                              <field name="LOG"></field>
                                              <value name="URL">
                                                <shadow type="text" id="1o%c{S``+)7HEh-A%)U^">
                                                </shadow>
                                                <block type="variables_get" id="vAPQA_YY6uy)ow09^`*K">
                                                </block>
                                              </value>
                                                <block type="debug" id="qZVJ(@5Ef)}jneJ%Q)_N">
                                                  <value name="TEXT">
                                                    <shadow type="text" id="S=pA)VcRi34L-{?F`HMz">
                                                    </shadow>
                                                    <block type="variables_get" id="N_1)-!F8nh][M#5EAmb6">
                                                      <field name="VAR" id="s`TAk}2fZk|p^o$4+d@t">result</field>
                                                    </block>
                                                  </value>
                                                </block>
                                              </statement>
                                              <next>
                                                <block type="debug" id="v:z{{P}3]9(0mcj`VrK7">
                                                  <value name="TEXT">
                                                    <shadow type="text">
                                                    </shadow>
                                                    <block type="variables_get" id="/5v?Iwot|ODZ)QhG%957">
                                                    </block>
                                                  </value>
                                                </block>
                                              </next>
                                            </block>
                                          </statement>
                                        </block>
                                      </next>
                                    </block>
                                  </statement>
                                </block>
                              </next>
                            </block>
                          </next>
                        </block>
                      </next>
                    </block>
                  </next>
                </block>
              </next>
            </block>
          </next>
        </block>
      </statement>
    </block>
    Entweder vorgegeben , oder aus einem Datenpunkt
    Tschaeens
    schrieb am zuletzt editiert von Tschaeens
    #41
    @glasfaser
    Hast du vielleicht eine Idee, warum keine Umlaute (ä, ö) oder zum Beispiel Grad Celcius als Zeichen nicht gehen. Dann kommt im Log immer ein Fehler?
    Liebe Grüße
    GlasfaserG 2 Antworten Letzte Antwort
    • T Tschaeens
      @glasfaser
      Liebe Grüße
      GlasfaserG Offline
      GlasfaserG Offline
      Glasfaser
      #42
      @tschaeens sagte in Synology Chat ...:
      Weil der Text noch :
      encodeURIComponent()
      Die Methode encodeURIComponent() kodiert eine Komponente des Uniform Resource Identifier (URI) indem jedes Vorkommen bestimmter Zeichen durch ein, zwei, drei oder vier Escape-Sequenzen ersetzt werden, die der UTF8-Kodierung des Zeichens entsprechen. Vier Escape-Sequenzen werden nur bei Zeichen bestehend aus zwei "Surrogate"-Zeichen verwendet.
      https://www.w3schools.com/jsref/jsref_encodeuricomponent.asp
      Klingelt%20jemand%20an%20der%20Haust%C3%BCr
      22%20%C2%B0C
      warum%20keine%20Umlaute%20(%C3%A4%2C%20%C3%B6)%20und%20kein%2022%20%C2%B0C
      geht hiermit :
       <variables>
         <variable id="$Tar!(b_)qw:24xtP(vj">url</variable>
         <variable id="`=hGQ*[0C+pxdf]k]sV]">Nachricht</variable>
         <variable id="0;mm8IOdOmH_wz;%[zPo">Syno_URL</variable>
         <variable id=",O#!.RmBLV$D$25E`o7/">Syno_Port</variable>
         <variable id="Eg)M29q*/71]Q#lGjYO;">Chat_token</variable>
         <variable type="timeout" id="timeout">timeout</variable>
         <variable id=")2,KTR||]G~d7xyd!QUZ">send</variable>
         <variable type="timeout" id="timeout2">timeout2</variable>
         <variable id="s`TAk}2fZk|p^o$4+d@t">result</variable>
       </variables>
       <block type="procedures_defcustomreturn" id="B`%(UJ@(5HI^#[)t`k$:" x="163" y="38">
         <mutation statements="false">
           <arg name="url" varid="$Tar!(b_)qw:24xtP(vj"></arg>
         </mutation>
         <field name="NAME">encodeURI</field>
         <field name="SCRIPT">dXJsID0gZW5jb2RlVVJJQ29tcG9uZW50KHVybCk7DQpyZXR1cm4gdXJsOw==</field>
         <comment pinned="false" h="80" w="160">encode URL function</comment>
       </block>
       <block type="comment" id="sn%:SFkGbJ1*B^:BY`FW" x="162" y="63">
         <field name="COMMENT">// https://forum.iobroker.net/topic/47210/synology-chat/41</field>
         <next>
           <block type="on_ext" id="[.;w?/pK-.4zyW!UyYBl">
             <value name="OID0">
               </shadow>
             </value>
               <block type="comment" id="uRZ3rr;n#Cb)oaDZB3$)">
                 <field name="COMMENT">encodeURIComponent hinzugefügt</field>
                 <next>
                       <block type="procedures_callcustomreturn" id="GD%^L~Wq_LIL_y86c}(2">
                         <mutation name="encodeURI">
                           <arg name="url"></arg>
                         </mutation>
                         <value name="ARG0">
                             <field name="TEXT">warum keine Umlaute (ä, ö) und kein 22 °C</field>
                           </block>
                         </value>
                       </block>
                     </value>
                     <next>
                             <field name="TEXT">192.168.xxx.xx</field>
                           </block>
                         </value>
                         <next>
                               </block>
                             </value>
                             <next>
                                     <field name="TEXT">xxxxxxxxxxxxxxxxx</field>
                                   </block>
                                 </value>
                                 <next>
                                     <next>
                                         <next>
                                                     <value name="ADD0">
                                                       </block>
                                                     </value>
                                                     <value name="ADD1">
                                                       </block>
                                                     </value>
                                                     <value name="ADD2">
                                                       </block>
                                                     </value>
                                                     <value name="ADD3">
                                                       </block>
                                                     </value>
                                                     <value name="ADD4">
                                                       </block>
                                                     </value>
                                                     <value name="ADD5">
                                                       </block>
                                                     </value>
                                                     <value name="ADD6">
                                                       </block>
                                                     </value>
                                                     <value name="ADD7">
                                                       </block>
                                                     </value>
                                                     <value name="ADD8">
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                                 <next>
                                                         <value name="URL">
                                                           </shadow>
                                                           </block>
                                                         </value>
                                                             <value name="TEXT">
                                                               </shadow>
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </statement>
                                                         <next>
                                                             <value name="TEXT">
                                                               </shadow>
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </statement>
                                                   </block>
                                                 </next>
                                               </block>
                                             </statement>
                                           </block>
                                         </next>
                                       </block>
                                     </next>
                                   </block>
                                 </next>
                               </block>
                             </next>
                           </block>
                         </next>
                       </block>
                     </next>
                   </block>
                 </next>
               </block>
             </statement>
           </block>
         </next>
       </block>
      </xml>
      • T Tschaeens
        @glasfaser
        Liebe Grüße
        GlasfaserG Offline
        GlasfaserG Offline
        Glasfaser
        #43
        oder zum Beispiel
        mit der Änderung oben , können jetzt auch Emoji mit versendet werden
        • W wrod
          @glasfaser Danke! Es läuft!
          W Offline
          W Offline
          wrod
          #44
          @wrod Danke.
          Es sieht nun so aus.
          Immer wenn ein anderer Vorgang (etwa ein anderes Skript) ein eigens erzeugtes Objekt "Nachrichtentext" ändert, wird dieser an mich versendet. Dann wird dieser wieder auf "false" gesetzt.
          Jetzt brauche ich noch Skripts, die auf Abfrage das Objekt "Nachrichtentext" sinnvoll befüllen.
          Gibt es dazu elegante Möglichkeiten, insbesondere für eine Abfrage mehrerer Objekte auf das Überschreiten von Grenzwerten, also etwa
          Wenn <Objekt_X> überschreitet <Grenzwert_X> dann setze Erzeuge Variable <Text> aus <Konstante_X> und ggf <Variable_X> und befülle Objekt <Nachrichtentext>; mit
          • <Objekt A> <Grenzwert A> <Konstante A> <Variable A>
          • <Objekt B> <Grenzwert B> <Konstante C> <Variable C>
          • <Objekt n> <Grenzwert n> <Konstante n> <Variable n>
          Das wäre ja wohl eine Schleife oder Liste in Form von
          Für jedes Elemente in Liste x prüfe und setze.
          Das Skript müsste dann aber wohl ständig abfragen. Lässt sich das auch über eine Liste/Schleife lösen im Sinne von
          Wenn eines der folgenden Elemente sich ändert, dann prüfe?
          Dank im Voraus
          • W wrod
            @wrod Danke.
            Dank im Voraus
            GlasfaserG Offline
            GlasfaserG Offline
            Glasfaser
            #45
            @wrod sagte in Synology Chat ...:
            Das würde jetzt diesen Thread "Synology Chat"dafür sprengen .
            @all
            Ich habe nochmal das Blockly verkürzt .
             <variables>
               <variable id="D5Tj,(Y%B2Tp[@g/2DPn">Debug_URL</variable>
               <variable id="/j={Oe4(A3y)y{F~G67H">Debug_send_Result</variable>
             </variables>
             <block type="procedures_defcustomreturn" id="B`%(UJ@(5HI^#[)t`k$:" x="488" y="-512">
               </mutation>
             </block>
             <block type="procedures_defcustomnoreturn" id="c4Zobeu@zHx7@T7RCR[+" x="488" y="-487">
               <mutation statements="false"></mutation>
               <field name="NAME">Chat_senden</field>
               <field name="SCRIPT">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</field>
             </block>
             <block type="comment" id="dh?Nq_).+o*LRx@ZBJ/P" x="488" y="-463">
               <field name="COMMENT">https://forum.iobroker.net/topic/47210/synology-chat/44</field>
               <next>
                 <block type="comment" id="]-LvUJjLlh6nbfULNnAm">
                   <field name="COMMENT">Synology Chat Daten</field>
                   <next>
                         </block>
                       </value>
                       <next>
                             </block>
                           </value>
                           <next>
                                   <field name="TEXT">Hier dein Token</field>
                                 </block>
                               </value>
                               <next>
                                 <block type="comment" id="#X/LLHHf]+a]HP9ULZZA">
                                   <field name="COMMENT">Debugmodus an/aus</field>
                                   <next>
                                     <block type="variables_set" id="]Dg;,gKp,/]Sb1cUFi?n">
                                       <field name="VAR" id="D5Tj,(Y%B2Tp[@g/2DPn">Debug_URL</field>
                                         <block type="logic_boolean" id="0~lqDtIM29hgH2or)}mL">
                                         </block>
                                       </value>
                                       <next>
                                         <block type="variables_set" id="W=GM=?`a~14E-J+QXSAQ">
                                           <field name="VAR" id="/j={Oe4(A3y)y{F~G67H">Debug_send_Result</field>
                                             <block type="logic_boolean" id="*JUO/RsrY?M/l53;H_pF">
                                             </block>
                                           </value>
                                           <next>
                                             <block type="comment" id="[gDu2J;3btcPa(EESlU!">
                                               <field name="COMMENT">Ab hier Trigger</field>
                                               <next>
                                                 <block type="on_ext" id="9h_zLLHz{65UPzm^$7}e">
                                                   <value name="OID0">
                                                     <shadow type="field_oid" id="NgekYWG@PsA7G02OF}rj">
                                                     </shadow>
                                                   </value>
                                                     <block type="controls_if" id="mSYXDpsYHKUM+j9uSS2s">
                                                       <value name="IF0">
                                                         <block type="logic_compare" id="55HN]QCkz$?W=xUf*cx_">
                                                           <field name="OP">EQ</field>
                                                           <value name="A">
                                                             <block type="on_source" id="l[/NtLhpCNaa5/@gH6X-">
                                                             </block>
                                                           </value>
                                                           <value name="B">
                                                             <block type="logic_boolean" id="),*:R)Nryc!rExr_0IK=">
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                       <statement name="DO0">
                                                               </mutation>
                                                               <value name="ARG0">
        <field name="TEXT">Ich bin ein kleiner 🐧</field>
        </block>
                                                               </value>
                                                             </block>
                                                           </value>
                                                           <next>
                                                             <block type="timeouts_settimeout" id="ht3)ckT6?(PDbQipm{_z">
        <block type="procedures_callcustomnoreturn" id="[EP#gKV7fF}Y+8x8zkZ^">
        <mutation name="Chat_senden"></mutation>
        </block>
                                                               </statement>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </statement>
                                                       <statement name="ELSE">
                                                         <block type="timeouts_cleartimeout" id="TKEEXDr0Qo(}RX.!blS5">
                                                         </block>
                                                       </statement>
                                                     </block>
                                                   </statement>
                                                 </block>
                                               </next>
                                             </block>
                                           </next>
                                         </block>
                                       </next>
                                     </block>
                                   </next>
                                 </block>
                               </next>
                             </block>
                           </next>
                         </block>
                       </next>
                     </block>
                   </next>
                 </block>
               </next>
             </block>
            </xml>
            @dslraser
            kann man das schon Produktiv übernehmen , was meinst du oder eher noch eine Testphase !
            Beispiel :
            https://forum.iobroker.net/topic/40424/alexa-ansagen-i-telegram-i-email-i-alias-i-visu-i-html?_=1640618730944
            Das einzigste was mich stört , ich finde keinen Butten um eine ( Test ) -Nachricht im Syn Chat zu löschen !?
            dslraserD GlasfaserG 4 Antworten Letzte Antwort
              @all
               <variables>
               </variables>
                 </mutation>
               </block>
               </block>
                 <next>
                     <next>
                           </block>
                         </value>
                         <next>
                               </block>
                             </value>
                             <next>
                                   </block>
                                 </value>
                                 <next>
                                     <next>
                                           </block>
                                         </value>
                                         <next>
                                               </block>
                                             </value>
                                             <next>
                                                 <next>
                                                     <value name="OID0">
                                                       </shadow>
                                                     </value>
                                                         <value name="IF0">
                                                             <value name="A">
                                                               </block>
                                                             </value>
                                                             <value name="B">
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </value>
        </mutation>
        <value name="ARG0">
        </block>
        </value>
                                                               </block>
                                                             </value>
                                                             <next>
        </block>
        </statement>
                                                               </block>
                                                             </next>
                                                           </block>
                                                         </statement>
                                                           </block>
                                                         </statement>
                                                       </block>
                                                     </statement>
                                                   </block>
                                                 </next>
                                               </block>
                                             </next>
                                           </block>
                                         </next>
                                       </block>
                                     </next>
                                   </block>
                                 </next>
                               </block>
                             </next>
                           </block>
                         </next>
                       </block>
                     </next>
                   </block>
                 </next>
               </block>
              </xml>
              @dslraser
              Beispiel :
              dslraserD Offline
              dslraserD Offline
              dslraser
              #46
              @glasfaser sagte in Synology Chat ...:
              Ich habe bisher hier nur mitgelesen. Ich habe das Blockly noch nicht probiert, aber auf jeden Fall interessant.
              EDIT: nur zur Info, hier reicht Wert ( = wahr kann weg wenn Du auf wahr triggern möchtest, sonst nicht Wertnehmen)
                @all
                 <variables>
                 </variables>
                   </mutation>
                 </block>
                 </block>
                   <next>
                       <next>
                             </block>
                           </value>
                           <next>
                                 </block>
                               </value>
                               <next>
                                     </block>
                                   </value>
                                   <next>
                                       <next>
                                             </block>
                                           </value>
                                           <next>
                                                 </block>
                                               </value>
                                               <next>
                                                   <next>
                                                       <value name="OID0">
                                                         </shadow>
                                                       </value>
                                                           <value name="IF0">
                                                               <value name="A">
        </block>
                                                               </value>
                                                               <value name="B">
        </block>
                                                               </value>
                                                             </block>
                                                           </value>
        </mutation>
        <value name="ARG0">
        </block>
        </value>
        </block>
                                                               </value>
                                                               <next>
        </block>
        </statement>
        </block>
                                                               </next>
                                                             </block>
                                                           </statement>
                                                             </block>
                                                           </statement>
                                                         </block>
                                                       </statement>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </next>
                                             </block>
                                           </next>
                                         </block>
                                       </next>
                                     </block>
                                   </next>
                                 </block>
                               </next>
                             </block>
                           </next>
                         </block>
                       </next>
                     </block>
                   </next>
                 </block>
                </xml>
                @dslraser
                Beispiel :
                dslraserD Offline
                dslraserD Offline
                dslraser
                #47
                @glasfaser
                Ich habe mir jetzt mal Chat auf der Syno und auf den Handy installiert.
                Könntest Du, oder auch wer anders, mal eine Anleitung für „DAU‘s“ (also für mich) erstellen welche Einstellungen auf der Syno für einen Bot (ich habe den bei mir Haus) genannt, gemacht werden müssen um mit dem Bot interagieren zu können.
                Ich bekomme bisher mit Deinem Blockly nur eine 404 Meldung.
                 {"error":{"code":404,"errors":"bot type error"},"success":false}
                GlasfaserG W 2 Antworten Letzte Antwort
                • dslraserD dslraser
                  @glasfaser
                  GlasfaserG Offline
                  GlasfaserG Offline
                  Glasfaser
                  #48
                  @dslraser
                  Bin kein guter Bescheiber .... aber hier in Bildern :
                  token=%22meintoken%22
                  dein token rein ohne die %22 in der URL am Anfang und am Ende
                  ja ich weiß , ist nur ein TESTSCRIPT ....
                  W 1 Antwort Letzte Antwort
                    @glasfaser
                    W Offline
                    W Offline
                    wrod
                    #49
                    @dslraser
                    Ich probiere es mal:
                    • In Synology Chat oben rechts auf Deinen User gehen (hier "A"):
                    • Dort "Einbindung" wählen:
                    • Dann "Eingehende Webhooks": ee734841-0448-49e7-b000-415fad3e9fda-grafik.png
                    • Dort "Erstellen" und einen Absendernamen und Kanal wählen bzw. einen neuen erstellen (z.B. "iobroker_an_user_x"). Im Webhook-Link sind dann die URL und der Token enthalten, den das Script braucht.
                    Das sollte es sein.
                      @dslraser
                      W Offline
                      W Offline
                      wrod
                      #50
                      @glasfaser ich habe die %22 mit kopiert. Geht offenkundig auch.
                      • W wrod
                        @dslraser
                        Das sollte es sein.
                        W Offline
                        W Offline
                        wrod
                        #51
                        @wrod Oh, @Glasfaser war schneller - wie im echten Leben. Bin wohl aus Kupfer.
                        • W wrod
                          GlasfaserG Offline
                          GlasfaserG Offline
                          Glasfaser
                          #52
                          @wrod
                          Nimm mal den Screenshot mit der URL raus ....
                          SONST bin ich gleich auf deinem Rechner !!!!
                          HomoranH dslraserD 2 Antworten Letzte Antwort
                            @wrod
                            #53
                            @wrod
                            Hab mal alle Screens entfernt, war der schnellste Weg - Post war etwas chaotisch formatiert
                              @wrod
                              dslraserD Offline
                              dslraserD Offline
                              dslraser
                              #54
                              @glasfaser
                              Nachrichten kommen jetzt an. Aber es dauert jedes Mal genau 31 Sekunden bei mir. Warum ist das so langsam ? Braucht die Syno so lange um die Bestätigung zu senden ? (in Deiner Funktion wird da glaube ich drauf gewartet, oder ?)
                                @glasfaser
                                GlasfaserG Offline
                                GlasfaserG Offline
                                Glasfaser
                                #55
                                @dslraser
                                Ja , das braucht solange ... keine Ahnung warum , habe mich noch nicht damit befasst .
                                Auch ohne Result ist es so ...
                                  @all
                                   <variables>
                                   </variables>
                                     </mutation>
                                   </block>
                                   </block>
                                     <next>
                                         <next>
                                               </block>
                                             </value>
                                             <next>
                                                   </block>
                                                 </value>
                                                 <next>
                                                       </block>
                                                     </value>
                                                     <next>
                                                         <next>
                                                               </block>
                                                             </value>
                                                             <next>
        </block>
        </value>
        <next>
        <next>
        <value name="OID0">
        </shadow>
        </value>
        <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </mutation>
        <value name="ARG0">
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </statement>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </next>
                                                               </block>
                                                             </next>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </next>
                                               </block>
                                             </next>
                                           </block>
                                         </next>
                                       </block>
                                     </next>
                                   </block>
                                  </xml>
                                  @dslraser
                                  Beispiel :
                                  dslraserD Offline
                                  dslraserD Offline
                                  dslraser
                                  #56
                                  @all
                                   <variables>
                                   </variables>
                                     </mutation>
                                   </block>
                                   </block>
                                     <next>
                                         <next>
                                               </block>
                                             </value>
                                             <next>
                                                   </block>
                                                 </value>
                                                 <next>
                                                       </block>
                                                     </value>
                                                     <next>
                                                         <next>
                                                               </block>
                                                             </value>
                                                             <next>
        </block>
        </value>
        <next>
        <next>
        <value name="OID0">
        </shadow>
        </value>
        <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </mutation>
        <value name="ARG0">
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </statement>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </next>
                                                               </block>
                                                             </next>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </next>
                                               </block>
                                             </next>
                                           </block>
                                         </next>
                                       </block>
                                     </next>
                                   </block>
                                  </xml>
                                  @dslraser
                                  Beispiel :
                                  Kurze Nachrichten gehen durch, aber wenn die Listen oder Nachrichten länger werden nicht.
                                  Längere Nachricht:
                                  {"error":{"code":410,"errors":"msg too long"},"success":false}
                                  Wieviel Zeichen dürfen die denn haben ?
                                    @all
                                     <variables>
                                     </variables>
                                       </mutation>
                                     </block>
                                     </block>
                                       <next>
                                           <next>
                                                 </block>
                                               </value>
                                               <next>
                                                     </block>
                                                   </value>
                                                   <next>
                                                         </block>
                                                       </value>
                                                       <next>
                                                           <next>
        </block>
                                                               </value>
                                                               <next>
        </block>
        </value>
        <next>
        <next>
        <value name="OID0">
        </shadow>
        </value>
        <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </mutation>
        <value name="ARG0">
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </statement>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </next>
        </block>
                                                               </next>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </next>
                                             </block>
                                           </next>
                                         </block>
                                       </next>
                                     </block>
                                    </xml>
                                    @dslraser
                                    Beispiel :
                                    Längere Nachricht:
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    Glasfaser
                                    #57
                                    @dslraser sagte in Synology Chat ...:
                                    Das habe ich noch nicht getestet .
                                    @glasfaser
                                    Nachtrag :
                                    Wenn ich die fertige URL im Browser eingebe dauert es auch so lange .
                                      @glasfaser
                                      Nachtrag :
                                      dslraserD Offline
                                      dslraserD Offline
                                      dslraser
                                      #58
                                      @glasfaser
                                      ich habe mal eine Lampe zum triggern genommen...
                                        oder zum Beispiel
                                        Tschaeens
                                        #59
                                        @glasfaser
                                        Vielen Dank für deinen Tip funzt super. Wie bekomme ich den per Blockly Emoji in die Nachricht?
                                        Lieben Gruß
                                        dslraserD GlasfaserG 2 Antworten Letzte Antwort
                                        • T Tschaeens
                                          @glasfaser
                                          Lieben Gruß
                                          dslraserD Offline
                                          dslraserD Offline
                                          dslraser
                                          #60
                                          @tschaeens
                                          rechte Maustaste in das Textfeld mit der Nachricht und Emoji einfügen (geht jedenfalls am Mac so)
