  3. Entwicklung
  4. Synology Chat ...
Synology Chat ...
chatsynologysynology diskstationadaptermessage handler
184 Beiträge 19 Kommentatoren 43.1k Aufrufe 16 Beobachtet
  • GlasfaserG Glasfaser
    @ilovegym
    Ich habe mal was gebaut ... hänge aber noch daran , das er immer das alte Bild sendet, obwohl es aktualisiert wird .
    Vielleicht ein Grundbauststein:
     <variables>
       <variable id="^RM=2sJ}E,A{F?bz`_me">URL_Chat</variable>
       <variable id="yW]q[i/Yfz.,5Z+Vb.a,">URL_ioBroker</variable>
       <variable id="u^a{RwAvq(*-0PK`(`@4">URL_Snapshot</variable>
       <variable id="`=hGQ*[0C+pxdf]k]sV]">Nachricht</variable>
       <variable type="timeout" id="timeout">timeout</variable>
       <variable id=")2,KTR||]G~d7xyd!QUZ">send</variable>
       <variable type="timeout" id="timeout2">timeout2</variable>
       <variable id="s`TAk}2fZk|p^o$4+d@t">result</variable>
     </variables>
     <block type="variables_set" id="0jj@r*)y_VPw~)q+,3)N" x="163" y="188">
       <field name="VAR" id="^RM=2sJ}E,A{F?bz`_me">URL_Chat</field>
       <value name="VALUE">
         <block type="text" id="kB68_z,ak9jtsXj2XA[?">
           <field name="TEXT">http://xxxxxx.xxx.xxx.xx:5000/webapi/entry.cgi?api=SYNO.Chat.External&amp;method=incoming&amp;version=2&amp;token=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx&amp;payload={"text":"</field>
         </block>
       </value>
       <next>
         <block type="variables_set" id="Q8SV]H7m2;RCEIl!I32S">
           <field name="VAR" id="yW]q[i/Yfz.,5Z+Vb.a,">URL_ioBroker</field>
             <block type="text" id="Cw;l)b1L4K(P86t9=T}E">
               <field name="TEXT">http://xxxx.xxxx.xxx.xxx:8082/0_userdata.0/synology/bild.jpg</field>
             </block>
           </value>
           <next>
             <block type="variables_set" id="fT*7tvvXRtyOgN,6C,2?">
               <field name="VAR" id="u^a{RwAvq(*-0PK`(`@4">URL_Snapshot</field>
                 <block type="get_value" id="Y$5X7J(i,Ijul8Pt3.]=">
                   <field name="OID">synology.0.SurveillanceStation.cameras.Haustür.linkSnapshot</field>
                 </block>
               </value>
               <next>
                 <block type="variables_set" id="m/`Hepc#d!=l=Yu?E{!6">
                   <field name="VAR" id="`=hGQ*[0C+pxdf]k]sV]">Nachricht</field>
                     <block type="text" id="naz0gbDT{!MOKW]c|g8{">
                       <field name="TEXT">Es klingelt an der Haustuer</field>
                     </block>
                   </value>
                   <next>
                     <block type="on_ext" id="[.;w?/pK-.4zyW!UyYBl">
                       <value name="OID0">
                         <shadow type="field_oid" id="3VnM3u.?JEhM[^n/?X0p">
                         </shadow>
                       </value>
                       <statement name="STATEMENT">
                         <block type="procedures_callcustomnoreturn" id="J8Bxi=.l@zrRJkcGT150">
                           <mutation name="Bild_holen"></mutation>
                           <next>
                             <block type="timeouts_cleartimeout" id="1#Qx;^WXsqqn)X|6E2jF">
                               <next>
                                 <block type="timeouts_cleartimeout" id="]P6ccsD65Q=LsNc=*[+u">
                                   <field name="NAME">timeout2</field>
                                   <next>
                                     <block type="timeouts_settimeout" id=",Vl,JVw3kG.#VrRAqd:b">
                                       <field name="DELAY">2000</field>
                                       <field name="UNIT">ms</field>
                                         <block type="variables_set" id="56pX+FA.eu/bi!ML3mDH">
                                           <field name="VAR" id=")2,KTR||]G~d7xyd!QUZ">send</field>
                                             <block type="text_join" id="+TV37k{5`41$R(X3%khD">
                                               <mutation items="4"></mutation>
                                               <value name="ADD0">
                                                 <block type="variables_get" id="Mkg|x~Kc=E8N`_Gd55y.">
                                                 </block>
                                               </value>
                                               <value name="ADD1">
                                                 <block type="text_join" id="{ZtE{Zz7!b9OAowY)%1V">
                                                   <value name="ADD0">
                                                     <block type="variables_get" id="y!U|V20vIg%ipD-$G_XY">
                                                     </block>
                                                   </value>
                                                   <value name="ADD1">
                                                     <block type="text" id="G|.7zo{,tbQ8-Uo83p,)">
                                                       <field name="TEXT">", "file_url": "</field>
                                                     </block>
                                                   </value>
                                                 </block>
                                               </value>
                                               <value name="ADD2">
                                                 <block type="variables_get" id="v/9SP;]`*blX7Qt=h~Eu">
                                                 </block>
                                               </value>
                                               <value name="ADD3">
                                                 <block type="text" id="z1]{?Af3zI_+#txN*=UR">
                                                   <field name="TEXT">"}</field>
                                                 </block>
                                               </value>
                                             </block>
                                           </value>
                                           <next>
                                             <block type="timeouts_settimeout" id="dUpl:*/S.GOlt6yy5+E?">
                                               <field name="DELAY">1000</field>
                                                 <block type="request" id="939:VQbG=f:Lt(8,--UH">
                                                   <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="true"></mutation>
                                                   <field name="WITH_STATEMENT">TRUE</field>
                                                   <field name="LOG"></field>
                                                   <value name="URL">
                                                     <shadow type="text" id="1o%c{S``+)7HEh-A%)U^">
                                                     </shadow>
                                                     <block type="variables_get" id="vAPQA_YY6uy)ow09^`*K">
                                                     </block>
                                                   </value>
                                                     <block type="debug" id="qZVJ(@5Ef)}jneJ%Q)_N">
                                                       <value name="TEXT">
                                                         <shadow type="text" id="S=pA)VcRi34L-{?F`HMz">
                                                         </shadow>
                                                         <block type="variables_get" id="N_1)-!F8nh][M#5EAmb6">
                                                           <field name="VAR" id="s`TAk}2fZk|p^o$4+d@t">result</field>
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </statement>
                                                   <next>
                                                     <block type="debug" id="v:z{{P}3]9(0mcj`VrK7">
                                                       <value name="TEXT">
                                                         <shadow type="text">
                                                         </shadow>
                                                         <block type="variables_get" id="/5v?Iwot|ODZ)QhG%957">
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </statement>
                                             </block>
                                           </next>
                                         </block>
                                       </statement>
                                     </block>
                                   </next>
                                 </block>
                               </next>
                             </block>
                           </next>
                         </block>
                       </statement>
                     </block>
                   </next>
                 </block>
               </next>
             </block>
           </next>
         </block>
       </next>
     </block>
     <block type="procedures_defcustomnoreturn" id="Fh|~ouZqovH}}ZEi:0P{" x="638" y="338">
       <mutation statements="false"></mutation>
       <field name="NAME">Bild_holen</field>
       <field name="SCRIPT">DQoNCg0KcmVxdWVzdCgNCg0KICB7DQoNCiAgICB1cmw6IFVSTF9TbmFwc2hvdCAsDQoNCiAgICBlbmNvZGluZzogbnVsbCwNCg0KICB9LA0KDQogIChlcnJvciwgcmVzcG9uc2UsIGJvZHkpID0+IHsNCg0KICAgIGlmICghZXJyb3IgJiYgYm9keSkgew0KDQogICAgICB3cml0ZUZpbGUoIjBfdXNlcmRhdGEuMCIsICIvc3lub2xvZ3kvYmlsZC5qcGciLCBib2R5KTsNCg0KICAgIH0NCg0KICB9DQoNCik7DQo=</field>
     </block>
    </xml>
    var URL_Chat, URL_ioBroker, URL_Snapshot, Nachricht, timeout, send, timeout2, result;
    // Beschreibe diese Funktion …
    async function Bild_holen() {
        request(
            url: URL_Snapshot ,
            encoding: null,
          (error, response, body) => {
            if (!error && body) {
              writeFile("0_userdata.0", "/synology/bild.jpg", body);
    URL_Chat = 'http://deineIP:5000/webapi/entry.cgi?api=SYNO.Chat.External&method=incoming&version=2&token=deintoken&payload={"text":"';
    URL_ioBroker = 'http://IPvomioBroker:8082/0_userdata.0/synology/bild.jpg';
    URL_Snapshot = getState("synology.0.SurveillanceStation.cameras.Haustür.linkSnapshot").val;
    Nachricht = 'Es klingelt an der Haustuer';
    on({id: 'default', change: "ne"}, async function (obj) {
      var value = obj.state.val;
      await Bild_holen();
      (function () {if (timeout) {clearTimeout(timeout); timeout = null;}})();
      (function () {if (timeout2) {clearTimeout(timeout2); timeout2 = null;}})();
      timeout = setTimeout(async function () {
        send = [URL_Chat,String(Nachricht) + '", "file_url": "',URL_ioBroker,'"}'].join('');
        timeout2 = setTimeout(async function () {
          try {
            require("request")(send, async function (error, response, result) {
              console.log(result);
            }).on("error", function (e) {console.error(e);});
          } catch (e) { console.error(e); }
          console.log(send);
        }, 1000);
      }, 2000);
    XBiTX Offline
    XBiTX Offline
    XBiT
    @glasfaser
    da wollte ich mal mitspielen aber bekomme nicht mal dein Blockly importiert...😢
    sollte es laufen ist es echt gut ohne 3rd Anbieter alle Meldungen zu erhalten.
    • XBiTX XBiT
      @glasfaser
      GlasfaserG Offline
      GlasfaserG Offline
      @xbit
      Versuche nochmal .. habe gerade es neu im Spoiler gesetzt
      XBiTX 2 Antworten Letzte Antwort
        @xbit
        XBiTX Offline
        XBiTX Offline
        XBiT
        @glasfaser
        Danke geht jetzt 👍
          @xbit
          XBiTX Offline
          XBiTX Offline
          XBiT
          @glasfaser
          Habe es mal verunstaltet :-) aber es geht... und bekomme auch immer das neue Bild....
          Sollte ja auch mit dem Datenpunkt "synology.0.SurveillanceStation.cameras.XXXX.linkSnapshot" gehen nur bei mir geht der gerade nicht :D
            <variables>
              <variable id="0;mm8IOdOmH_wz;%[zPo">Syno_URL</variable>
              <variable id=",O#!.RmBLV$D$25E`o7/">Syno_Port</variable>
              <variable id="Eg)M29q*/71]Q#lGjYO;">Chat_token</variable>
            </variables>
            <block type="on_ext" id="[.;w?/pK-.4zyW!UyYBl" x="163" y="88">
              <value name="OID0">
                  <field name="oid">0_userdata.0.Testbutton</field>
                </shadow>
              </value>
                <block type="variables_set" id="u^*rT,0CM,T_]XeGow}h">
                  <field name="VAR" id="0;mm8IOdOmH_wz;%[zPo">Syno_URL</field>
                    <block type="text" id="K]+z|W)qG[s?viD8cP}Q">
                      <field name="TEXT">192.168.X.XXX</field>
                    </block>
                  </value>
                  <next>
                    <block type="variables_set" id=",|/0@uFO[kJp[pSjyfW~">
                      <field name="VAR" id=",O#!.RmBLV$D$25E`o7/">Syno_Port</field>
                        <block type="text" id="YmIhCu8+dV@OO0U[PWx#">
                          <field name="TEXT">5000</field>
                        </block>
                      </value>
                      <next>
                        <block type="variables_set" id="Z}%_nt.Jz``.b})ifYmx">
                          <field name="VAR" id="Eg)M29q*/71]Q#lGjYO;">Chat_token</field>
                            <block type="text" id="[^9?/_`o:[u8zr_:o:`T">
                              <field name="TEXT">XXXX</field>
                            </block>
                          </value>
                          <next>
                                </block>
                              </value>
                              <next>
                                    <block type="text" id="N]=+,oldD=_C5-KIA*6[">
                                      <field name="TEXT">http://192.168.X.XXX/action/snapshot</field>
                                    </block>
                                  </value>
                                  <next>
                                          <field name="TEXT">http://192.168.X.XXX:8082/0_userdata.0/synology/bild.jpg</field>
                                        </block>
                                      </value>
                                      <next>
                                          <next>
                                              <next>
                                                  <next>
                                                        <block type="variables_set" id="0jj@r*)y_VPw~)q+,3)N">
                                                            <block type="text_join" id="Q^/K[ogSU%663c!lHXyf">
                                                              <mutation items="11"></mutation>
                                                              <value name="ADD0">
        <block type="text" id="Xp!K%fv+S+C7_K~7ka^c">
        <field name="TEXT">http://</field>
        </block>
                                                              </value>
                                                              <value name="ADD1">
        <block type="variables_get" id="U#z.iPhHMr!oaBW_.L}$">
        </block>
                                                              </value>
                                                              <value name="ADD2">
        <block type="text" id="|ITd9=%HnJAhhwgaz3|-">
        <field name="TEXT">:</field>
        </block>
                                                              </value>
                                                              <value name="ADD3">
        <block type="variables_get" id="_E?oZ@h{l{gD!e{A..FQ">
        </block>
                                                              </value>
                                                              <value name="ADD4">
        <block type="text" id="_^c23]w8ve_wLo_pG;lU">
        <field name="TEXT">/webapi/entry.cgi?api=SYNO.Chat.External&amp;method=incoming&amp;version=2&amp;token="</field>
        </block>
                                                              </value>
                                                              <value name="ADD5">
        <block type="variables_get" id="p//Pgq^!$p27`+=TYO0t">
        </block>
                                                              </value>
                                                              <value name="ADD6">
        <block type="text" id="zG0}^=D_TXDv9Tjx8afb">
        <field name="TEXT">"&amp;payload={"text":"</field>
        </block>
                                                              </value>
                                                              <value name="ADD7">
        <block type="variables_get" id="];FJ@4Io`JJ?oyGqhlTU">
        </block>
                                                              </value>
                                                              <value name="ADD8">
        </block>
                                                              </value>
                                                              <value name="ADD9">
        </block>
                                                              </value>
                                                              <value name="ADD10">
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                          <next>
        <value name="URL">
        </shadow>
        </block>
        </value>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </statement>
        <next>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </next>
        </block>
                                                              </statement>
                                                            </block>
                                                          </next>
                                                        </block>
                                                      </statement>
                                                    </block>
                                                  </next>
                                                </block>
                                              </next>
                                            </block>
                                          </next>
                                        </block>
                                      </next>
                                    </block>
                                  </next>
                                </block>
                              </next>
                            </block>
                          </next>
                        </block>
                      </next>
                    </block>
                  </next>
                </block>
              </statement>
            </block>
            <block type="procedures_defcustomnoreturn" id="Fh|~ouZqovH}}ZEi:0P{" x="513" y="337">
            </block>
          </xml>
            @ilovegym
             <variables>
             </variables>
                 </block>
               </value>
               <next>
                     </block>
                   </value>
                   <next>
                         </block>
                       </value>
                       <next>
                             </block>
                           </value>
                           <next>
                               <value name="OID0">
                                 </shadow>
                               </value>
                                   <next>
                                       <next>
                                           <next>
                                                       <value name="ADD0">
                                                         </block>
                                                       </value>
                                                       <value name="ADD1">
                                                           <value name="ADD0">
                                                             </block>
                                                           </value>
                                                           <value name="ADD1">
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                       <value name="ADD2">
                                                         </block>
                                                       </value>
                                                       <value name="ADD3">
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                   <next>
                                                           <value name="URL">
                                                             </shadow>
                                                             </block>
                                                           </value>
                                                               <value name="TEXT">
        </shadow>
        </block>
                                                               </value>
                                                             </block>
                                                           </statement>
                                                           <next>
                                                               <value name="TEXT">
        </shadow>
        </block>
                                                               </value>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </statement>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </statement>
                                             </block>
                                           </next>
                                         </block>
                                       </next>
                                     </block>
                                   </next>
                                 </block>
                               </statement>
                             </block>
                           </next>
                         </block>
                       </next>
                     </block>
                   </next>
                 </block>
               </next>
             </block>
             </block>
            </xml>
                request(
                    url: URL_Snapshot ,
                    encoding: null,
              await Bild_holen();
                  try {
                  console.log(send);
                }, 1000);
              }, 2000);
            W Offline
            W Offline
            wrod
            @glasfaser said in Synology Chat ...:
            Wie muss das Script denn aussehen, wenn man einfach eine Nachricht ohne Bild schicken will?
            • W wrod
              GlasfaserG Offline
              GlasfaserG Offline
              @wrod
              Beispiel :
              <block xmlns="https://developers.google.com/blockly/xml" type="on_ext" id="[.;w?/pK-.4zyW!UyYBl" x="163" y="88">
                <value name="OID0">
                    <field name="oid">0_userdata.0.Test123</field>
                  </shadow>
                </value>
                  <block type="variables_set" id="*dQxDuFmm[ppsJg3%3!V">
                      <block type="text" id="+_Bx+X)YJc^_8RSz74zE">
                        <field name="TEXT">Hier dein Text , ioBroker 2021</field>
                      </block>
                    </value>
                    <next>
                            <field name="TEXT">192.168.xxx.xxx</field>
                          </block>
                        </value>
                        <next>
                              </block>
                            </value>
                            <next>
                                    <field name="TEXT">xxxxxxxxxxxxxxxxxxxxx</field>
                                  </block>
                                </value>
                                <next>
                                    <next>
                                        <next>
                                                    <mutation items="9"></mutation>
                                                    <value name="ADD0">
                                                      </block>
                                                    </value>
                                                    <value name="ADD1">
                                                      </block>
                                                    </value>
                                                    <value name="ADD2">
                                                      </block>
                                                    </value>
                                                    <value name="ADD3">
                                                      </block>
                                                    </value>
                                                    <value name="ADD4">
                                                      </block>
                                                    </value>
                                                    <value name="ADD5">
                                                      </block>
                                                    </value>
                                                    <value name="ADD6">
                                                      </block>
                                                    </value>
                                                    <value name="ADD7">
                                                      </block>
                                                    </value>
                                                    <value name="ADD8">
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                <next>
                                                        <value name="URL">
                                                          </shadow>
                                                          </block>
                                                        </value>
                                                            <value name="TEXT">
                                                              </shadow>
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </statement>
                                                        <next>
                                                            <value name="TEXT">
                                                              </shadow>
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </next>
                                                      </block>
                                                    </statement>
                                                  </block>
                                                </next>
                                              </block>
                                            </statement>
                                          </block>
                                        </next>
                                      </block>
                                    </next>
                                  </block>
                                </next>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </statement>
              </block>
              Entweder vorgegeben , oder aus einem Datenpunkt
              • W Offline
                W Offline
                wrod
                @glasfaser Danke! Es läuft!
                W 1 Antwort Letzte Antwort
                  @wrod
                  Beispiel :
                    <value name="OID0">
                      </shadow>
                    </value>
                          </block>
                        </value>
                        <next>
                              </block>
                            </value>
                            <next>
                                  </block>
                                </value>
                                <next>
                                      </block>
                                    </value>
                                    <next>
                                        <next>
                                            <next>
                                                        <value name="ADD0">
                                                          </block>
                                                        </value>
                                                        <value name="ADD1">
                                                          </block>
                                                        </value>
                                                        <value name="ADD2">
                                                          </block>
                                                        </value>
                                                        <value name="ADD3">
                                                          </block>
                                                        </value>
                                                        <value name="ADD4">
                                                          </block>
                                                        </value>
                                                        <value name="ADD5">
                                                          </block>
                                                        </value>
                                                        <value name="ADD6">
                                                          </block>
                                                        </value>
                                                        <value name="ADD7">
                                                          </block>
                                                        </value>
                                                        <value name="ADD8">
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                    <next>
                                                            <value name="URL">
                                                              </shadow>
                                                              </block>
                                                            </value>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
                                                              </block>
                                                            </statement>
                                                            <next>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
                                                              </block>
                                                            </next>
                                                          </block>
                                                        </statement>
                                                      </block>
                                                    </next>
                                                  </block>
                                                </statement>
                                              </block>
                                            </next>
                                          </block>
                                        </next>
                                      </block>
                                    </next>
                                  </block>
                                </next>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </statement>
                  </block>
                  Tschaeens
                  schrieb am zuletzt editiert von Tschaeens
                  @glasfaser
                  Hast du vielleicht eine Idee, warum keine Umlaute (ä, ö) oder zum Beispiel Grad Celcius als Zeichen nicht gehen. Dann kommt im Log immer ein Fehler?
                  Liebe Grüße
                  • T Tschaeens
                    @glasfaser
                    Liebe Grüße
                    GlasfaserG Offline
                    GlasfaserG Offline
                    @tschaeens sagte in Synology Chat ...:
                    Weil der Text noch :
                    encodeURIComponent()
                    Die Methode encodeURIComponent() kodiert eine Komponente des Uniform Resource Identifier (URI) indem jedes Vorkommen bestimmter Zeichen durch ein, zwei, drei oder vier Escape-Sequenzen ersetzt werden, die der UTF8-Kodierung des Zeichens entsprechen. Vier Escape-Sequenzen werden nur bei Zeichen bestehend aus zwei "Surrogate"-Zeichen verwendet.
                    https://www.w3schools.com/jsref/jsref_encodeuricomponent.asp
                    Klingelt%20jemand%20an%20der%20Haust%C3%BCr
                    22%20%C2%B0C
                    warum%20keine%20Umlaute%20(%C3%A4%2C%20%C3%B6)%20und%20kein%2022%20%C2%B0C
                    geht hiermit :
                     <variables>
                       <variable id="$Tar!(b_)qw:24xtP(vj">url</variable>
                     </variables>
                     <block type="procedures_defcustomreturn" id="B`%(UJ@(5HI^#[)t`k$:" x="163" y="38">
                         <arg name="url" varid="$Tar!(b_)qw:24xtP(vj"></arg>
                       </mutation>
                       <field name="NAME">encodeURI</field>
                       <field name="SCRIPT">dXJsID0gZW5jb2RlVVJJQ29tcG9uZW50KHVybCk7DQpyZXR1cm4gdXJsOw==</field>
                       <comment pinned="false" h="80" w="160">encode URL function</comment>
                     </block>
                     <block type="comment" id="sn%:SFkGbJ1*B^:BY`FW" x="162" y="63">
                       <field name="COMMENT">// https://forum.iobroker.net/topic/47210/synology-chat/41</field>
                       <next>
                           <value name="OID0">
                             </shadow>
                           </value>
                             <block type="comment" id="uRZ3rr;n#Cb)oaDZB3$)">
                               <field name="COMMENT">encodeURIComponent hinzugefügt</field>
                               <next>
                                     <block type="procedures_callcustomreturn" id="GD%^L~Wq_LIL_y86c}(2">
                                       <mutation name="encodeURI">
                                         <arg name="url"></arg>
                                       </mutation>
                                       <value name="ARG0">
                                           <field name="TEXT">warum keine Umlaute (ä, ö) und kein 22 °C</field>
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                   <next>
                                           <field name="TEXT">192.168.xxx.xx</field>
                                         </block>
                                       </value>
                                       <next>
                                             </block>
                                           </value>
                                           <next>
                                                   <field name="TEXT">xxxxxxxxxxxxxxxxx</field>
                                                 </block>
                                               </value>
                                               <next>
                                                   <next>
                                                       <next>
        <value name="ADD0">
        </block>
        </value>
        <value name="ADD1">
        </block>
        </value>
        <value name="ADD2">
        </block>
        </value>
        <value name="ADD3">
        </block>
        </value>
        <value name="ADD4">
        </block>
        </value>
        <value name="ADD5">
        </block>
        </value>
        <value name="ADD6">
        </block>
        </value>
        <value name="ADD7">
        </block>
        </value>
        <value name="ADD8">
        </block>
        </value>
        </block>
                                                               </value>
                                                               <next>
        <value name="URL">
        </shadow>
        </block>
        </value>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </statement>
        <next>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        </block>
                                                               </next>
                                                             </block>
                                                           </statement>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </next>
                                             </block>
                                           </next>
                                         </block>
                                       </next>
                                     </block>
                                   </next>
                                 </block>
                               </next>
                             </block>
                           </statement>
                         </block>
                       </next>
                     </block>
                    </xml>
                    • T Tschaeens
                      @glasfaser
                      Liebe Grüße
                      GlasfaserG Offline
                      GlasfaserG Offline
                      oder zum Beispiel
                      mit der Änderung oben , können jetzt auch Emoji mit versendet werden
                      • W wrod
                        W Offline
                        W Offline
                        wrod
                        @wrod Danke.
                        Es sieht nun so aus.
                        Immer wenn ein anderer Vorgang (etwa ein anderes Skript) ein eigens erzeugtes Objekt "Nachrichtentext" ändert, wird dieser an mich versendet. Dann wird dieser wieder auf "false" gesetzt.
                        Jetzt brauche ich noch Skripts, die auf Abfrage das Objekt "Nachrichtentext" sinnvoll befüllen.
                        Gibt es dazu elegante Möglichkeiten, insbesondere für eine Abfrage mehrerer Objekte auf das Überschreiten von Grenzwerten, also etwa
                        Wenn <Objekt_X> überschreitet <Grenzwert_X> dann setze Erzeuge Variable <Text> aus <Konstante_X> und ggf <Variable_X> und befülle Objekt <Nachrichtentext>; mit
                        • <Objekt A> <Grenzwert A> <Konstante A> <Variable A>
                        • <Objekt B> <Grenzwert B> <Konstante C> <Variable C>
                        • <Objekt n> <Grenzwert n> <Konstante n> <Variable n>
                        Das wäre ja wohl eine Schleife oder Liste in Form von
                        Für jedes Elemente in Liste x prüfe und setze.
                        Das Skript müsste dann aber wohl ständig abfragen. Lässt sich das auch über eine Liste/Schleife lösen im Sinne von
                        Wenn eines der folgenden Elemente sich ändert, dann prüfe?
                        Dank im Voraus
                        • W wrod
                          @wrod Danke.
                          Dank im Voraus
                          GlasfaserG Offline
                          GlasfaserG Offline
                          @wrod sagte in Synology Chat ...:
                          Das würde jetzt diesen Thread "Synology Chat"dafür sprengen .
                          @all
                          Ich habe nochmal das Blockly verkürzt .
                           <variables>
                             <variable id="D5Tj,(Y%B2Tp[@g/2DPn">Debug_URL</variable>
                             <variable id="/j={Oe4(A3y)y{F~G67H">Debug_send_Result</variable>
                           </variables>
                           <block type="procedures_defcustomreturn" id="B`%(UJ@(5HI^#[)t`k$:" x="488" y="-512">
                             </mutation>
                           </block>
                           <block type="procedures_defcustomnoreturn" id="c4Zobeu@zHx7@T7RCR[+" x="488" y="-487">
                             <field name="NAME">Chat_senden</field>
                             <field name="SCRIPT">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</field>
                           </block>
                           <block type="comment" id="dh?Nq_).+o*LRx@ZBJ/P" x="488" y="-463">
                             <field name="COMMENT">https://forum.iobroker.net/topic/47210/synology-chat/44</field>
                             <next>
                               <block type="comment" id="]-LvUJjLlh6nbfULNnAm">
                                 <field name="COMMENT">Synology Chat Daten</field>
                                 <next>
                                       </block>
                                     </value>
                                     <next>
                                           </block>
                                         </value>
                                         <next>
                                                 <field name="TEXT">Hier dein Token</field>
                                               </block>
                                             </value>
                                             <next>
                                               <block type="comment" id="#X/LLHHf]+a]HP9ULZZA">
                                                 <field name="COMMENT">Debugmodus an/aus</field>
                                                 <next>
                                                   <block type="variables_set" id="]Dg;,gKp,/]Sb1cUFi?n">
                                                     <field name="VAR" id="D5Tj,(Y%B2Tp[@g/2DPn">Debug_URL</field>
                                                       <block type="logic_boolean" id="0~lqDtIM29hgH2or)}mL">
                                                       </block>
                                                     </value>
                                                     <next>
                                                       <block type="variables_set" id="W=GM=?`a~14E-J+QXSAQ">
                                                         <field name="VAR" id="/j={Oe4(A3y)y{F~G67H">Debug_send_Result</field>
                                                           <block type="logic_boolean" id="*JUO/RsrY?M/l53;H_pF">
                                                           </block>
                                                         </value>
                                                         <next>
                                                           <block type="comment" id="[gDu2J;3btcPa(EESlU!">
                                                             <field name="COMMENT">Ab hier Trigger</field>
                                                             <next>
                                                               <block type="on_ext" id="9h_zLLHz{65UPzm^$7}e">
        <value name="OID0">
        <shadow type="field_oid" id="NgekYWG@PsA7G02OF}rj">
        </shadow>
        </value>
        <block type="controls_if" id="mSYXDpsYHKUM+j9uSS2s">
        <value name="IF0">
        <block type="logic_compare" id="55HN]QCkz$?W=xUf*cx_">
        <field name="OP">EQ</field>
        <value name="A">
        <block type="on_source" id="l[/NtLhpCNaa5/@gH6X-">
        </block>
        </value>
        <value name="B">
        <block type="logic_boolean" id="),*:R)Nryc!rExr_0IK=">
        </block>
        </value>
        </block>
        </value>
        <statement name="DO0">
        </mutation>
        <value name="ARG0">
        <field name="TEXT">Ich bin ein kleiner 🐧</field>
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="timeouts_settimeout" id="ht3)ckT6?(PDbQipm{_z">
        <block type="procedures_callcustomnoreturn" id="[EP#gKV7fF}Y+8x8zkZ^">
        <mutation name="Chat_senden"></mutation>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </statement>
        <statement name="ELSE">
        <block type="timeouts_cleartimeout" id="TKEEXDr0Qo(}RX.!blS5">
        </block>
        </statement>
        </block>
        </statement>
                                                               </block>
                                                             </next>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </next>
                                               </block>
                                             </next>
                                           </block>
                                         </next>
                                       </block>
                                     </next>
                                   </block>
                                 </next>
                               </block>
                             </next>
                           </block>
                          </xml>
                          @dslraser
                          kann man das schon Produktiv übernehmen , was meinst du oder eher noch eine Testphase !
                          Beispiel :
                          https://forum.iobroker.net/topic/40424/alexa-ansagen-i-telegram-i-email-i-alias-i-visu-i-html?_=1640618730944
                          Das einzigste was mich stört , ich finde keinen Butten um eine ( Test ) -Nachricht im Syn Chat zu löschen !?
                          dslraserD GlasfaserG 4 Antworten Letzte Antwort
                            @all
                             <variables>
                             </variables>
                               </mutation>
                             </block>
                             </block>
                               <next>
                                   <next>
                                         </block>
                                       </value>
                                       <next>
                                             </block>
                                           </value>
                                           <next>
                                                 </block>
                                               </value>
                                               <next>
                                                   <next>
                                                         </block>
                                                       </value>
                                                       <next>
                                                             </block>
                                                           </value>
                                                           <next>
                                                               <next>
        <value name="OID0">
        </shadow>
        </value>
        <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </mutation>
        <value name="ARG0">
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </statement>
        </block>
        </statement>
        </block>
                                                               </next>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </next>
                                             </block>
                                           </next>
                                         </block>
                                       </next>
                                     </block>
                                   </next>
                                 </block>
                               </next>
                             </block>
                            </xml>
                            @dslraser
                            Beispiel :
                            dslraserD Offline
                            dslraserD Offline
                            dslraser
                            @glasfaser sagte in Synology Chat ...:
                            Ich habe bisher hier nur mitgelesen. Ich habe das Blockly noch nicht probiert, aber auf jeden Fall interessant.
                            EDIT: nur zur Info, hier reicht Wert ( = wahr kann weg wenn Du auf wahr triggern möchtest, sonst nicht Wertnehmen)
                              @all
                               <variables>
                               </variables>
                                 </mutation>
                               </block>
                               </block>
                                 <next>
                                     <next>
                                           </block>
                                         </value>
                                         <next>
                                               </block>
                                             </value>
                                             <next>
                                                   </block>
                                                 </value>
                                                 <next>
                                                     <next>
                                                           </block>
                                                         </value>
                                                         <next>
                                                               </block>
                                                             </value>
                                                             <next>
        <next>
        <value name="OID0">
        </shadow>
        </value>
        <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </mutation>
        <value name="ARG0">
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </statement>
        </block>
        </statement>
        </block>
        </next>
                                                               </block>
                                                             </next>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </next>
                                               </block>
                                             </next>
                                           </block>
                                         </next>
                                       </block>
                                     </next>
                                   </block>
                                 </next>
                               </block>
                              </xml>
                              @dslraser
                              Beispiel :
                              dslraserD Offline
                              dslraserD Offline
                              dslraser
                              @glasfaser
                              Ich habe mir jetzt mal Chat auf der Syno und auf den Handy installiert.
                              Könntest Du, oder auch wer anders, mal eine Anleitung für „DAU‘s“ (also für mich) erstellen welche Einstellungen auf der Syno für einen Bot (ich habe den bei mir Haus) genannt, gemacht werden müssen um mit dem Bot interagieren zu können.
                              Ich bekomme bisher mit Deinem Blockly nur eine 404 Meldung.
                               {"error":{"code":404,"errors":"bot type error"},"success":false}
                              GlasfaserG W 2 Antworten Letzte Antwort
                              • dslraserD dslraser
                                @glasfaser
                                GlasfaserG Offline
                                GlasfaserG Offline
                                @dslraser
                                Bin kein guter Bescheiber .... aber hier in Bildern :
                                token=%22meintoken%22
                                dein token rein ohne die %22 in der URL am Anfang und am Ende
                                ja ich weiß , ist nur ein TESTSCRIPT ....
                                  @glasfaser
                                  W Offline
                                  W Offline
                                  wrod
                                  @dslraser
                                  Ich probiere es mal:
                                  • In Synology Chat oben rechts auf Deinen User gehen (hier "A"):
                                  • Dort "Einbindung" wählen:
                                  • Dann "Eingehende Webhooks": ee734841-0448-49e7-b000-415fad3e9fda-grafik.png
                                  • Dort "Erstellen" und einen Absendernamen und Kanal wählen bzw. einen neuen erstellen (z.B. "iobroker_an_user_x"). Im Webhook-Link sind dann die URL und der Token enthalten, den das Script braucht.
                                  Das sollte es sein.
                                    @dslraser
                                    W Offline
                                    W Offline
                                    wrod
                                    @glasfaser ich habe die %22 mit kopiert. Geht offenkundig auch.
                                    • W wrod
                                      @dslraser
                                      Das sollte es sein.
                                      W Offline
                                      W Offline
                                      wrod
                                      @wrod Oh, @Glasfaser war schneller - wie im echten Leben. Bin wohl aus Kupfer.
                                      • W wrod
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        @wrod
                                        Nimm mal den Screenshot mit der URL raus ....
                                        SONST bin ich gleich auf deinem Rechner !!!!
                                        HomoranH dslraserD 2 Antworten Letzte Antwort
                                          @wrod
                                          HomoranH Offline
                                          HomoranH Offline
                                          @wrod
                                          Hab mal alle Screens entfernt, war der schnellste Weg - Post war etwas chaotisch formatiert
