  3. Entwicklung
  4. Synology Chat ...
Synology Chat ...
chatsynologysynology diskstationadaptermessage handler
184 Beiträge 19 Kommentatoren 43.1k Aufrufe 16 Beobachtet
  • GlasfaserG Offline
    GlasfaserG Offline
    @ilovegym
    Ich habe mal was gebaut ... hänge aber noch daran , das er immer das alte Bild sendet, obwohl es aktualisiert wird .
    Vielleicht ein Grundbauststein:
     <variables>
       <variable id="^RM=2sJ}E,A{F?bz`_me">URL_Chat</variable>
       <variable id="yW]q[i/Yfz.,5Z+Vb.a,">URL_ioBroker</variable>
       <variable id="u^a{RwAvq(*-0PK`(`@4">URL_Snapshot</variable>
       <variable id="`=hGQ*[0C+pxdf]k]sV]">Nachricht</variable>
       <variable type="timeout" id="timeout">timeout</variable>
       <variable id=")2,KTR||]G~d7xyd!QUZ">send</variable>
       <variable type="timeout" id="timeout2">timeout2</variable>
       <variable id="s`TAk}2fZk|p^o$4+d@t">result</variable>
     </variables>
     <block type="variables_set" id="0jj@r*)y_VPw~)q+,3)N" x="163" y="188">
       <field name="VAR" id="^RM=2sJ}E,A{F?bz`_me">URL_Chat</field>
       <value name="VALUE">
         <block type="text" id="kB68_z,ak9jtsXj2XA[?">
           <field name="TEXT">http://xxxxxx.xxx.xxx.xx:5000/webapi/entry.cgi?api=SYNO.Chat.External&amp;method=incoming&amp;version=2&amp;token=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx&amp;payload={"text":"</field>
         </block>
       </value>
       <next>
         <block type="variables_set" id="Q8SV]H7m2;RCEIl!I32S">
           <field name="VAR" id="yW]q[i/Yfz.,5Z+Vb.a,">URL_ioBroker</field>
             <block type="text" id="Cw;l)b1L4K(P86t9=T}E">
               <field name="TEXT">http://xxxx.xxxx.xxx.xxx:8082/0_userdata.0/synology/bild.jpg</field>
             </block>
           </value>
           <next>
             <block type="variables_set" id="fT*7tvvXRtyOgN,6C,2?">
               <field name="VAR" id="u^a{RwAvq(*-0PK`(`@4">URL_Snapshot</field>
                 <block type="get_value" id="Y$5X7J(i,Ijul8Pt3.]=">
                   <field name="OID">synology.0.SurveillanceStation.cameras.Haustür.linkSnapshot</field>
                 </block>
               </value>
               <next>
                 <block type="variables_set" id="m/`Hepc#d!=l=Yu?E{!6">
                   <field name="VAR" id="`=hGQ*[0C+pxdf]k]sV]">Nachricht</field>
                     <block type="text" id="naz0gbDT{!MOKW]c|g8{">
                       <field name="TEXT">Es klingelt an der Haustuer</field>
                     </block>
                   </value>
                   <next>
                     <block type="on_ext" id="[.;w?/pK-.4zyW!UyYBl">
                       <value name="OID0">
                         <shadow type="field_oid" id="3VnM3u.?JEhM[^n/?X0p">
                         </shadow>
                       </value>
                       <statement name="STATEMENT">
                         <block type="procedures_callcustomnoreturn" id="J8Bxi=.l@zrRJkcGT150">
                           <mutation name="Bild_holen"></mutation>
                           <next>
                             <block type="timeouts_cleartimeout" id="1#Qx;^WXsqqn)X|6E2jF">
                               <next>
                                 <block type="timeouts_cleartimeout" id="]P6ccsD65Q=LsNc=*[+u">
                                   <field name="NAME">timeout2</field>
                                   <next>
                                     <block type="timeouts_settimeout" id=",Vl,JVw3kG.#VrRAqd:b">
                                       <field name="DELAY">2000</field>
                                       <field name="UNIT">ms</field>
                                         <block type="variables_set" id="56pX+FA.eu/bi!ML3mDH">
                                           <field name="VAR" id=")2,KTR||]G~d7xyd!QUZ">send</field>
                                             <block type="text_join" id="+TV37k{5`41$R(X3%khD">
                                               <mutation items="4"></mutation>
                                               <value name="ADD0">
                                                 <block type="variables_get" id="Mkg|x~Kc=E8N`_Gd55y.">
                                                 </block>
                                               </value>
                                               <value name="ADD1">
                                                 <block type="text_join" id="{ZtE{Zz7!b9OAowY)%1V">
                                                   <value name="ADD0">
                                                     <block type="variables_get" id="y!U|V20vIg%ipD-$G_XY">
                                                     </block>
                                                   </value>
                                                   <value name="ADD1">
                                                     <block type="text" id="G|.7zo{,tbQ8-Uo83p,)">
                                                       <field name="TEXT">", "file_url": "</field>
                                                     </block>
                                                   </value>
                                                 </block>
                                               </value>
                                               <value name="ADD2">
                                                 <block type="variables_get" id="v/9SP;]`*blX7Qt=h~Eu">
                                                 </block>
                                               </value>
                                               <value name="ADD3">
                                                 <block type="text" id="z1]{?Af3zI_+#txN*=UR">
                                                   <field name="TEXT">"}</field>
                                                 </block>
                                               </value>
                                             </block>
                                           </value>
                                           <next>
                                             <block type="timeouts_settimeout" id="dUpl:*/S.GOlt6yy5+E?">
                                               <field name="DELAY">1000</field>
                                                 <block type="request" id="939:VQbG=f:Lt(8,--UH">
                                                   <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="true"></mutation>
                                                   <field name="WITH_STATEMENT">TRUE</field>
                                                   <field name="LOG"></field>
                                                   <value name="URL">
                                                     <shadow type="text" id="1o%c{S``+)7HEh-A%)U^">
                                                     </shadow>
                                                     <block type="variables_get" id="vAPQA_YY6uy)ow09^`*K">
                                                     </block>
                                                   </value>
                                                     <block type="debug" id="qZVJ(@5Ef)}jneJ%Q)_N">
                                                       <value name="TEXT">
                                                         <shadow type="text" id="S=pA)VcRi34L-{?F`HMz">
                                                         </shadow>
                                                         <block type="variables_get" id="N_1)-!F8nh][M#5EAmb6">
                                                           <field name="VAR" id="s`TAk}2fZk|p^o$4+d@t">result</field>
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </statement>
                                                   <next>
                                                     <block type="debug" id="v:z{{P}3]9(0mcj`VrK7">
                                                       <value name="TEXT">
                                                         <shadow type="text">
                                                         </shadow>
                                                         <block type="variables_get" id="/5v?Iwot|ODZ)QhG%957">
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </statement>
                                             </block>
                                           </next>
                                         </block>
                                       </statement>
                                     </block>
                                   </next>
                                 </block>
                               </next>
                             </block>
                           </next>
                         </block>
                       </statement>
                     </block>
                   </next>
                 </block>
               </next>
             </block>
           </next>
         </block>
       </next>
     </block>
     <block type="procedures_defcustomnoreturn" id="Fh|~ouZqovH}}ZEi:0P{" x="638" y="338">
       <mutation statements="false"></mutation>
       <field name="NAME">Bild_holen</field>
       <field name="SCRIPT">DQoNCg0KcmVxdWVzdCgNCg0KICB7DQoNCiAgICB1cmw6IFVSTF9TbmFwc2hvdCAsDQoNCiAgICBlbmNvZGluZzogbnVsbCwNCg0KICB9LA0KDQogIChlcnJvciwgcmVzcG9uc2UsIGJvZHkpID0+IHsNCg0KICAgIGlmICghZXJyb3IgJiYgYm9keSkgew0KDQogICAgICB3cml0ZUZpbGUoIjBfdXNlcmRhdGEuMCIsICIvc3lub2xvZ3kvYmlsZC5qcGciLCBib2R5KTsNCg0KICAgIH0NCg0KICB9DQoNCik7DQo=</field>
     </block>
    </xml>
    var URL_Chat, URL_ioBroker, URL_Snapshot, Nachricht, timeout, send, timeout2, result;
    // Beschreibe diese Funktion …
    async function Bild_holen() {
        request(
            url: URL_Snapshot ,
            encoding: null,
          (error, response, body) => {
            if (!error && body) {
              writeFile("0_userdata.0", "/synology/bild.jpg", body);
    URL_Chat = 'http://deineIP:5000/webapi/entry.cgi?api=SYNO.Chat.External&method=incoming&version=2&token=deintoken&payload={"text":"';
    URL_ioBroker = 'http://IPvomioBroker:8082/0_userdata.0/synology/bild.jpg';
    URL_Snapshot = getState("synology.0.SurveillanceStation.cameras.Haustür.linkSnapshot").val;
    Nachricht = 'Es klingelt an der Haustuer';
    on({id: 'default', change: "ne"}, async function (obj) {
      var value = obj.state.val;
      await Bild_holen();
      (function () {if (timeout) {clearTimeout(timeout); timeout = null;}})();
      (function () {if (timeout2) {clearTimeout(timeout2); timeout2 = null;}})();
      timeout = setTimeout(async function () {
        send = [URL_Chat,String(Nachricht) + '", "file_url": "',URL_ioBroker,'"}'].join('');
        timeout2 = setTimeout(async function () {
          try {
            require("request")(send, async function (error, response, result) {
              console.log(result);
            }).on("error", function (e) {console.error(e);});
          } catch (e) { console.error(e); }
          console.log(send);
        }, 1000);
      }, 2000);
    ? XBiTX W 3 Antworten Letzte Antwort
    • GlasfaserG Glasfaser
      @ilovegym
       <variables>
       </variables>
           </block>
         </value>
         <next>
               </block>
             </value>
             <next>
                   </block>
                 </value>
                 <next>
                       </block>
                     </value>
                     <next>
                         <value name="OID0">
                           </shadow>
                         </value>
                             <next>
                                 <next>
                                     <next>
                                                 <value name="ADD0">
                                                   </block>
                                                 </value>
                                                 <value name="ADD1">
                                                     <value name="ADD0">
                                                       </block>
                                                     </value>
                                                     <value name="ADD1">
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                                 <value name="ADD2">
                                                   </block>
                                                 </value>
                                                 <value name="ADD3">
                                                   </block>
                                                 </value>
                                               </block>
                                             </value>
                                             <next>
                                                     <value name="URL">
                                                       </shadow>
                                                       </block>
                                                     </value>
                                                         <value name="TEXT">
                                                           </shadow>
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </statement>
                                                     <next>
                                                         <value name="TEXT">
                                                           </shadow>
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </statement>
                                               </block>
                                             </next>
                                           </block>
                                         </statement>
                                       </block>
                                     </next>
                                   </block>
                                 </next>
                               </block>
                             </next>
                           </block>
                         </statement>
                       </block>
                     </next>
                   </block>
                 </next>
               </block>
             </next>
           </block>
         </next>
       </block>
       </block>
      </xml>
          request(
              url: URL_Snapshot ,
              encoding: null,
        await Bild_holen();
            try {
            console.log(send);
          }, 1000);
        }, 2000);
      @glasfaser sieht schon prima aus, bin bis jetzt nur zum Text verschicken gekommen, mit dem Bild hatte ich auch probleme..
        GlasfaserG Offline
        GlasfaserG Offline
        @ilovegym sagte in Synology Chat ...:
        ich habe es extra schon per writeFile. geschrieben .
        Das Bild ist auch aktuell , aber ich komme gerade nicht auf den Blöden Fehler warum er immer das erstellte ( alte ) Bild nimmt .
        ? HomoranH 2 Antworten Letzte Antwort
          @glasfaser mal das alte Bild löschen lassen..?
          Ich mach das bei meinen Camera Scripten immer so: ( alle in Javascript )
          sendTo('telegram.0', {text: '/tmp/snap.jpg', caption: '🔔Es hat jemand geklingelt !🔔'});
          exec((['sudo cp /tmp/snap.jpg /mnt/photo/maindoor/maindoor-',formatDate(new Date(), "JJJJ_MM_TT_SS_mm_ss"),'.jpg'].join('')));
          exec((['sudo rm /tmp/snap.jpg'] ));
          Edit: nicht alles copiert.. ;-)
            @glasfaser sagte in Synology Chat ...:
            ist zu dem Zeitpunkt des holens denn wirklich das neue Bild schon geschrieben?
              GlasfaserG Offline
              GlasfaserG Offline
              Ja , ich habe auch schon mehere timeout im Testscript eingebaut gehabt.
              Es wird geholt und geschrieben .
              Das Bild ist immer aktuell im Ordner 0_userdata.0
                @glasfaser hmm ich lass die immer nach /tmp schreiben.. wird es denn auch angelegt_
                  GlasfaserG Offline
                  GlasfaserG Offline
                  Ja .
                    @ilovegym
                     <variables>
                     </variables>
                         </block>
                       </value>
                       <next>
                             </block>
                           </value>
                           <next>
                                 </block>
                               </value>
                               <next>
                                     </block>
                                   </value>
                                   <next>
                                       <value name="OID0">
                                         </shadow>
                                       </value>
                                           <next>
                                               <next>
                                                   <next>
                                                               <value name="ADD0">
        </block>
                                                               </value>
                                                               <value name="ADD1">
        <value name="ADD0">
        </block>
        </value>
        <value name="ADD1">
        </block>
        </value>
        </block>
                                                               </value>
                                                               <value name="ADD2">
        </block>
                                                               </value>
                                                               <value name="ADD3">
        </block>
                                                               </value>
                                                             </block>
                                                           </value>
                                                           <next>
        <value name="URL">
        </shadow>
        </block>
        </value>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </statement>
        <next>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </next>
        </block>
                                                               </statement>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </statement>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </next>
                                             </block>
                                           </next>
                                         </block>
                                       </statement>
                                     </block>
                                   </next>
                                 </block>
                               </next>
                             </block>
                           </next>
                         </block>
                       </next>
                     </block>
                     </block>
                    </xml>
                        request(
                            url: URL_Snapshot ,
                            encoding: null,
                      await Bild_holen();
                          try {
                          console.log(send);
                        }, 1000);
                      }, 2000);
                    XBiTX Offline
                    XBiTX Offline
                    XBiT
                    @glasfaser
                    da wollte ich mal mitspielen aber bekomme nicht mal dein Blockly importiert...😢
                    sollte es laufen ist es echt gut ohne 3rd Anbieter alle Meldungen zu erhalten.
                    • XBiTX XBiT
                      @glasfaser
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @xbit
                      Versuche nochmal .. habe gerade es neu im Spoiler gesetzt
                      XBiTX 2 Antworten Letzte Antwort
                        @xbit
                        XBiTX Offline
                        XBiTX Offline
                        XBiT
                        @glasfaser
                        Danke geht jetzt 👍
                          @xbit
                          XBiTX Offline
                          XBiTX Offline
                          XBiT
                          @glasfaser
                          Habe es mal verunstaltet :-) aber es geht... und bekomme auch immer das neue Bild....
                          Sollte ja auch mit dem Datenpunkt "synology.0.SurveillanceStation.cameras.XXXX.linkSnapshot" gehen nur bei mir geht der gerade nicht :D
                            <variables>
                              <variable id="0;mm8IOdOmH_wz;%[zPo">Syno_URL</variable>
                              <variable id=",O#!.RmBLV$D$25E`o7/">Syno_Port</variable>
                              <variable id="Eg)M29q*/71]Q#lGjYO;">Chat_token</variable>
                            </variables>
                            <block type="on_ext" id="[.;w?/pK-.4zyW!UyYBl" x="163" y="88">
                              <value name="OID0">
                                  <field name="oid">0_userdata.0.Testbutton</field>
                                </shadow>
                              </value>
                                <block type="variables_set" id="u^*rT,0CM,T_]XeGow}h">
                                  <field name="VAR" id="0;mm8IOdOmH_wz;%[zPo">Syno_URL</field>
                                    <block type="text" id="K]+z|W)qG[s?viD8cP}Q">
                                      <field name="TEXT">192.168.X.XXX</field>
                                    </block>
                                  </value>
                                  <next>
                                    <block type="variables_set" id=",|/0@uFO[kJp[pSjyfW~">
                                      <field name="VAR" id=",O#!.RmBLV$D$25E`o7/">Syno_Port</field>
                                        <block type="text" id="YmIhCu8+dV@OO0U[PWx#">
                                          <field name="TEXT">5000</field>
                                        </block>
                                      </value>
                                      <next>
                                        <block type="variables_set" id="Z}%_nt.Jz``.b})ifYmx">
                                          <field name="VAR" id="Eg)M29q*/71]Q#lGjYO;">Chat_token</field>
                                            <block type="text" id="[^9?/_`o:[u8zr_:o:`T">
                                              <field name="TEXT">XXXX</field>
                                            </block>
                                          </value>
                                          <next>
                                                </block>
                                              </value>
                                              <next>
                                                    <block type="text" id="N]=+,oldD=_C5-KIA*6[">
                                                      <field name="TEXT">http://192.168.X.XXX/action/snapshot</field>
                                                    </block>
                                                  </value>
                                                  <next>
                                                          <field name="TEXT">http://192.168.X.XXX:8082/0_userdata.0/synology/bild.jpg</field>
                                                        </block>
                                                      </value>
                                                      <next>
                                                          <next>
                                                              <next>
        <next>
        <block type="variables_set" id="0jj@r*)y_VPw~)q+,3)N">
        <block type="text_join" id="Q^/K[ogSU%663c!lHXyf">
        <mutation items="11"></mutation>
        <value name="ADD0">
        <block type="text" id="Xp!K%fv+S+C7_K~7ka^c">
        <field name="TEXT">http://</field>
        </block>
        </value>
        <value name="ADD1">
        <block type="variables_get" id="U#z.iPhHMr!oaBW_.L}$">
        </block>
        </value>
        <value name="ADD2">
        <block type="text" id="|ITd9=%HnJAhhwgaz3|-">
        <field name="TEXT">:</field>
        </block>
        </value>
        <value name="ADD3">
        <block type="variables_get" id="_E?oZ@h{l{gD!e{A..FQ">
        </block>
        </value>
        <value name="ADD4">
        <block type="text" id="_^c23]w8ve_wLo_pG;lU">
        <field name="TEXT">/webapi/entry.cgi?api=SYNO.Chat.External&amp;method=incoming&amp;version=2&amp;token="</field>
        </block>
        </value>
        <value name="ADD5">
        <block type="variables_get" id="p//Pgq^!$p27`+=TYO0t">
        </block>
        </value>
        <value name="ADD6">
        <block type="text" id="zG0}^=D_TXDv9Tjx8afb">
        <field name="TEXT">"&amp;payload={"text":"</field>
        </block>
        </value>
        <value name="ADD7">
        <block type="variables_get" id="];FJ@4Io`JJ?oyGqhlTU">
        </block>
        </value>
        <value name="ADD8">
        </block>
        </value>
        <value name="ADD9">
        </block>
        </value>
        <value name="ADD10">
        </block>
        </value>
        </block>
        </value>
        <next>
        <value name="URL">
        </shadow>
        </block>
        </value>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </statement>
        <next>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </next>
        </block>
                                                              </next>
                                                            </block>
                                                          </next>
                                                        </block>
                                                      </next>
                                                    </block>
                                                  </next>
                                                </block>
                                              </next>
                                            </block>
                                          </next>
                                        </block>
                                      </next>
                                    </block>
                                  </next>
                                </block>
                              </statement>
                            </block>
                            <block type="procedures_defcustomnoreturn" id="Fh|~ouZqovH}}ZEi:0P{" x="513" y="337">
                            </block>
                          </xml>
                            @ilovegym
                             <variables>
                             </variables>
                                 </block>
                               </value>
                               <next>
                                     </block>
                                   </value>
                                   <next>
                                         </block>
                                       </value>
                                       <next>
                                             </block>
                                           </value>
                                           <next>
                                               <value name="OID0">
                                                 </shadow>
                                               </value>
                                                   <next>
                                                       <next>
                                                           <next>
        <value name="ADD0">
        </block>
        </value>
        <value name="ADD1">
        <value name="ADD0">
        </block>
        </value>
        <value name="ADD1">
        </block>
        </value>
        </block>
        </value>
        <value name="ADD2">
        </block>
        </value>
        <value name="ADD3">
        </block>
        </value>
        </block>
        </value>
        <next>
        <value name="URL">
        </shadow>
        </block>
        </value>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </statement>
        <next>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </next>
        </block>
                                                               </statement>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </statement>
                                             </block>
                                           </next>
                                         </block>
                                       </next>
                                     </block>
                                   </next>
                                 </block>
                               </next>
                             </block>
                             </block>
                            </xml>
                                request(
                                    url: URL_Snapshot ,
                                    encoding: null,
                              await Bild_holen();
                                  try {
                                  console.log(send);
                                }, 1000);
                              }, 2000);
                            W Offline
                            W Offline
                            wrod
                            @glasfaser said in Synology Chat ...:
                            Wie muss das Script denn aussehen, wenn man einfach eine Nachricht ohne Bild schicken will?
                            • W wrod
                              GlasfaserG Offline
                              GlasfaserG Offline
                              @wrod
                              Beispiel :
                              <block xmlns="https://developers.google.com/blockly/xml" type="on_ext" id="[.;w?/pK-.4zyW!UyYBl" x="163" y="88">
                                <value name="OID0">
                                    <field name="oid">0_userdata.0.Test123</field>
                                  </shadow>
                                </value>
                                  <block type="variables_set" id="*dQxDuFmm[ppsJg3%3!V">
                                      <block type="text" id="+_Bx+X)YJc^_8RSz74zE">
                                        <field name="TEXT">Hier dein Text , ioBroker 2021</field>
                                      </block>
                                    </value>
                                    <next>
                                            <field name="TEXT">192.168.xxx.xxx</field>
                                          </block>
                                        </value>
                                        <next>
                                              </block>
                                            </value>
                                            <next>
                                                    <field name="TEXT">xxxxxxxxxxxxxxxxxxxxx</field>
                                                  </block>
                                                </value>
                                                <next>
                                                    <next>
                                                        <next>
        <mutation items="9"></mutation>
        <value name="ADD0">
        </block>
        </value>
        <value name="ADD1">
        </block>
        </value>
        <value name="ADD2">
        </block>
        </value>
        <value name="ADD3">
        </block>
        </value>
        <value name="ADD4">
        </block>
        </value>
        <value name="ADD5">
        </block>
        </value>
        <value name="ADD6">
        </block>
        </value>
        <value name="ADD7">
        </block>
        </value>
        <value name="ADD8">
        </block>
        </value>
        </block>
        </value>
        <next>
        <value name="URL">
        </shadow>
        </block>
        </value>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </statement>
        <next>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </next>
                                                              </block>
                                                            </statement>
                                                          </block>
                                                        </next>
                                                      </block>
                                                    </next>
                                                  </block>
                                                </next>
                                              </block>
                                            </next>
                                          </block>
                                        </next>
                                      </block>
                                    </next>
                                  </block>
                                </statement>
                              </block>
                              Entweder vorgegeben , oder aus einem Datenpunkt
                              • W Offline
                                W Offline
                                wrod
                                @glasfaser Danke! Es läuft!
                                W 1 Antwort Letzte Antwort
                                  @wrod
                                  Beispiel :
                                    <value name="OID0">
                                      </shadow>
                                    </value>
                                          </block>
                                        </value>
                                        <next>
                                              </block>
                                            </value>
                                            <next>
                                                  </block>
                                                </value>
                                                <next>
                                                      </block>
                                                    </value>
                                                    <next>
                                                        <next>
                                                            <next>
        <value name="ADD0">
        </block>
        </value>
        <value name="ADD1">
        </block>
        </value>
        <value name="ADD2">
        </block>
        </value>
        <value name="ADD3">
        </block>
        </value>
        <value name="ADD4">
        </block>
        </value>
        <value name="ADD5">
        </block>
        </value>
        <value name="ADD6">
        </block>
        </value>
        <value name="ADD7">
        </block>
        </value>
        <value name="ADD8">
        </block>
        </value>
        </block>
        </value>
        <next>
        <value name="URL">
        </shadow>
        </block>
        </value>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </statement>
        <next>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </statement>
                                                              </block>
                                                            </next>
                                                          </block>
                                                        </next>
                                                      </block>
                                                    </next>
                                                  </block>
                                                </next>
                                              </block>
                                            </next>
                                          </block>
                                        </next>
                                      </block>
                                    </statement>
                                  </block>
                                  Tschaeens
                                  schrieb am zuletzt editiert von Tschaeens
                                  @glasfaser
                                  Hast du vielleicht eine Idee, warum keine Umlaute (ä, ö) oder zum Beispiel Grad Celcius als Zeichen nicht gehen. Dann kommt im Log immer ein Fehler?
                                  Liebe Grüße
                                  • T Tschaeens
                                    @glasfaser
                                    Liebe Grüße
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    @tschaeens sagte in Synology Chat ...:
                                    Weil der Text noch :
                                    encodeURIComponent()
                                    Die Methode encodeURIComponent() kodiert eine Komponente des Uniform Resource Identifier (URI) indem jedes Vorkommen bestimmter Zeichen durch ein, zwei, drei oder vier Escape-Sequenzen ersetzt werden, die der UTF8-Kodierung des Zeichens entsprechen. Vier Escape-Sequenzen werden nur bei Zeichen bestehend aus zwei "Surrogate"-Zeichen verwendet.
                                    https://www.w3schools.com/jsref/jsref_encodeuricomponent.asp
                                    Klingelt%20jemand%20an%20der%20Haust%C3%BCr
                                    22%20%C2%B0C
                                    warum%20keine%20Umlaute%20(%C3%A4%2C%20%C3%B6)%20und%20kein%2022%20%C2%B0C
                                    geht hiermit :
                                     <variables>
                                       <variable id="$Tar!(b_)qw:24xtP(vj">url</variable>
                                     </variables>
                                     <block type="procedures_defcustomreturn" id="B`%(UJ@(5HI^#[)t`k$:" x="163" y="38">
                                         <arg name="url" varid="$Tar!(b_)qw:24xtP(vj"></arg>
                                       </mutation>
                                       <field name="NAME">encodeURI</field>
                                       <field name="SCRIPT">dXJsID0gZW5jb2RlVVJJQ29tcG9uZW50KHVybCk7DQpyZXR1cm4gdXJsOw==</field>
                                       <comment pinned="false" h="80" w="160">encode URL function</comment>
                                     </block>
                                     <block type="comment" id="sn%:SFkGbJ1*B^:BY`FW" x="162" y="63">
                                       <field name="COMMENT">// https://forum.iobroker.net/topic/47210/synology-chat/41</field>
                                       <next>
                                           <value name="OID0">
                                             </shadow>
                                           </value>
                                             <block type="comment" id="uRZ3rr;n#Cb)oaDZB3$)">
                                               <field name="COMMENT">encodeURIComponent hinzugefügt</field>
                                               <next>
                                                     <block type="procedures_callcustomreturn" id="GD%^L~Wq_LIL_y86c}(2">
                                                       <mutation name="encodeURI">
                                                         <arg name="url"></arg>
                                                       </mutation>
                                                       <value name="ARG0">
                                                           <field name="TEXT">warum keine Umlaute (ä, ö) und kein 22 °C</field>
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                   <next>
                                                           <field name="TEXT">192.168.xxx.xx</field>
                                                         </block>
                                                       </value>
                                                       <next>
                                                             </block>
                                                           </value>
                                                           <next>
        <field name="TEXT">xxxxxxxxxxxxxxxxx</field>
        </block>
                                                               </value>
                                                               <next>
        <next>
        <next>
        <value name="ADD0">
        </block>
        </value>
        <value name="ADD1">
        </block>
        </value>
        <value name="ADD2">
        </block>
        </value>
        <value name="ADD3">
        </block>
        </value>
        <value name="ADD4">
        </block>
        </value>
        <value name="ADD5">
        </block>
        </value>
        <value name="ADD6">
        </block>
        </value>
        <value name="ADD7">
        </block>
        </value>
        <value name="ADD8">
        </block>
        </value>
        </block>
        </value>
        <next>
        <value name="URL">
        </shadow>
        </block>
        </value>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </statement>
        <next>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </next>
        </block>
                                                               </next>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </next>
                                             </block>
                                           </statement>
                                         </block>
                                       </next>
                                     </block>
                                    </xml>
                                    • T Tschaeens
                                      @glasfaser
                                      Liebe Grüße
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      oder zum Beispiel
                                      mit der Änderung oben , können jetzt auch Emoji mit versendet werden
                                      • W wrod
                                        W Offline
                                        W Offline
                                        wrod
                                        @wrod Danke.
                                        Es sieht nun so aus.
                                        Immer wenn ein anderer Vorgang (etwa ein anderes Skript) ein eigens erzeugtes Objekt "Nachrichtentext" ändert, wird dieser an mich versendet. Dann wird dieser wieder auf "false" gesetzt.
                                        Jetzt brauche ich noch Skripts, die auf Abfrage das Objekt "Nachrichtentext" sinnvoll befüllen.
                                        Gibt es dazu elegante Möglichkeiten, insbesondere für eine Abfrage mehrerer Objekte auf das Überschreiten von Grenzwerten, also etwa
                                        Wenn <Objekt_X> überschreitet <Grenzwert_X> dann setze Erzeuge Variable <Text> aus <Konstante_X> und ggf <Variable_X> und befülle Objekt <Nachrichtentext>; mit
                                        • <Objekt A> <Grenzwert A> <Konstante A> <Variable A>
                                        • <Objekt B> <Grenzwert B> <Konstante C> <Variable C>
                                        • <Objekt n> <Grenzwert n> <Konstante n> <Variable n>
                                        Das wäre ja wohl eine Schleife oder Liste in Form von
                                        Für jedes Elemente in Liste x prüfe und setze.
                                        Das Skript müsste dann aber wohl ständig abfragen. Lässt sich das auch über eine Liste/Schleife lösen im Sinne von
                                        Wenn eines der folgenden Elemente sich ändert, dann prüfe?
                                        Dank im Voraus
                                        • W wrod
                                          @wrod Danke.
                                          Dank im Voraus
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          @wrod sagte in Synology Chat ...:
                                          Das würde jetzt diesen Thread "Synology Chat"dafür sprengen .
                                          @all
                                          Ich habe nochmal das Blockly verkürzt .
                                           <variables>
                                             <variable id="D5Tj,(Y%B2Tp[@g/2DPn">Debug_URL</variable>
                                             <variable id="/j={Oe4(A3y)y{F~G67H">Debug_send_Result</variable>
                                           </variables>
                                           <block type="procedures_defcustomreturn" id="B`%(UJ@(5HI^#[)t`k$:" x="488" y="-512">
                                             </mutation>
                                           </block>
                                           <block type="procedures_defcustomnoreturn" id="c4Zobeu@zHx7@T7RCR[+" x="488" y="-487">
                                             <field name="NAME">Chat_senden</field>
                                             <field name="SCRIPT">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</field>
                                           </block>
                                           <block type="comment" id="dh?Nq_).+o*LRx@ZBJ/P" x="488" y="-463">
                                             <field name="COMMENT">https://forum.iobroker.net/topic/47210/synology-chat/44</field>
                                             <next>
                                               <block type="comment" id="]-LvUJjLlh6nbfULNnAm">
                                                 <field name="COMMENT">Synology Chat Daten</field>
                                                 <next>
                                                       </block>
                                                     </value>
                                                     <next>
                                                           </block>
                                                         </value>
                                                         <next>
        <field name="TEXT">Hier dein Token</field>
                                                               </block>
                                                             </value>
                                                             <next>
                                                               <block type="comment" id="#X/LLHHf]+a]HP9ULZZA">
        <field name="COMMENT">Debugmodus an/aus</field>
        <next>
        <block type="variables_set" id="]Dg;,gKp,/]Sb1cUFi?n">
        <field name="VAR" id="D5Tj,(Y%B2Tp[@g/2DPn">Debug_URL</field>
        <block type="logic_boolean" id="0~lqDtIM29hgH2or)}mL">
        </block>
        </value>
        <next>
        <block type="variables_set" id="W=GM=?`a~14E-J+QXSAQ">
        <field name="VAR" id="/j={Oe4(A3y)y{F~G67H">Debug_send_Result</field>
        <block type="logic_boolean" id="*JUO/RsrY?M/l53;H_pF">
        </block>
        </value>
        <next>
        <block type="comment" id="[gDu2J;3btcPa(EESlU!">
        <field name="COMMENT">Ab hier Trigger</field>
        <next>
        <block type="on_ext" id="9h_zLLHz{65UPzm^$7}e">
        <value name="OID0">
        <shadow type="field_oid" id="NgekYWG@PsA7G02OF}rj">
        </shadow>
        </value>
        <block type="controls_if" id="mSYXDpsYHKUM+j9uSS2s">
        <value name="IF0">
        <block type="logic_compare" id="55HN]QCkz$?W=xUf*cx_">
        <field name="OP">EQ</field>
        <value name="A">
        <block type="on_source" id="l[/NtLhpCNaa5/@gH6X-">
        </block>
        </value>
        <value name="B">
        <block type="logic_boolean" id="),*:R)Nryc!rExr_0IK=">
        </block>
        </value>
        </block>
        </value>
        <statement name="DO0">
        </mutation>
        <value name="ARG0">
        <field name="TEXT">Ich bin ein kleiner 🐧</field>
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="timeouts_settimeout" id="ht3)ckT6?(PDbQipm{_z">
        <block type="procedures_callcustomnoreturn" id="[EP#gKV7fF}Y+8x8zkZ^">
        <mutation name="Chat_senden"></mutation>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </statement>
        <statement name="ELSE">
        <block type="timeouts_cleartimeout" id="TKEEXDr0Qo(}RX.!blS5">
        </block>
        </statement>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
                                                               </block>
                                                             </next>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </next>
                                               </block>
                                             </next>
                                           </block>
                                          </xml>
                                          @dslraser
                                          kann man das schon Produktiv übernehmen , was meinst du oder eher noch eine Testphase !
                                          Beispiel :
                                          https://forum.iobroker.net/topic/40424/alexa-ansagen-i-telegram-i-email-i-alias-i-visu-i-html?_=1640618730944
                                          Das einzigste was mich stört , ich finde keinen Butten um eine ( Test ) -Nachricht im Syn Chat zu löschen !?
                                          dslraserD GlasfaserG 4 Antworten Letzte Antwort
