  3. Entwicklung
  4. Synology Chat ...
Synology Chat ...
chatsynologysynology diskstationadaptermessage handler
184 Beiträge 19 Kommentatoren 43.1k Aufrufe 16 Beobachtet
  • GlasfaserG Glasfaser
    @dslraser sagte in Synology Chat ...:
    {"code":117},"success":false}
    Diese Meldung sagt aus ... vom Chatserver , das der Inhalt Bild fehlt .
    ist leer .
    Was kommt hiermit als Ausgabe
    <block xmlns="https://developers.google.com/blockly/xml" type="request" id="jGRe=jAvY7pi~/M7zdOV" x="338" y="88">
     <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="true"></mutation>
     <field name="WITH_STATEMENT">TRUE</field>
     <field name="LOG"></field>
     <value name="URL">
       <shadow type="text" id="Kcq}@/lN.7+@VX{.Sl1~">
         <field name="TEXT">Hier dein Link</field>
       </shadow>
     </value>
     <statement name="STATEMENT">
       <block type="debug" id="!N5up[B{T/LTTi-_ecn9">
         <value name="TEXT">
           <shadow xmlns="http://www.w3.org/1999/xhtml" type="text" id="J`/`lk[1@05UD[2~T+TL">
           </shadow>
           <block type="variables_get" id="Hh~k_N+@YbO%UvlA/@bU">
             <field name="VAR" id="%3Mff6CD,)5FpTyqT-?!">result</field>
           </block>
         </value>
         <next>
           <block type="debug" id="?da:0)J$|KrxbYk`B}(B">
             <value name="TEXT">
               </shadow>
               <block type="variables_get" id="+W;=rb#yQo|PE}[-2UtT">
                 <field name="VAR" id="k/Bs#bIB:Ff8L9lv4^-d">stdout</field>
               </block>
             </value>
             <next>
               <block type="debug" id="RXN$G!=O`P9nhNpVu#(N">
                 <value name="TEXT">
                   <shadow xmlns="http://www.w3.org/1999/xhtml" type="text" id="Lbpbr1oEFz|ETX~l$^Cs">
                   </shadow>
                   <block type="variables_get" id=",4pl9#rI2/9w19HTHk~o">
                     <field name="VAR" id="Cjr.[GB6284iu*rOZxn}">stderr</field>
                   </block>
                 </value>
                 <next>
                   <block type="debug" id=";K*88rm67)kSl|OR`?4:">
                     <value name="TEXT">
                       <shadow xmlns="http://www.w3.org/1999/xhtml" type="text" id="y:/8xVy;=1lXAoSk~x)4">
                       </shadow>
                       <block type="variables_get" id="@Rs4BpAt%r]mmn4Aj_::">
                         <field name="VAR" id="_qJ[C$+4||[A|G%Qg~xD">error</field>
                       </block>
                     </value>
                   </block>
                 </next>
               </block>
             </next>
           </block>
         </next>
       </block>
     </statement>
    </block>
    dslraserD Offline
    dslraserD Offline
    dslraser
    #89
    @glasfaser sagte in Synology Chat ...:
    Damit schmiert mir die ganze JS-Instanz ab...
    • dslraserD dslraser
      GlasfaserG Offline
      GlasfaserG Offline
      #90
      @dslraser
      Ist dann sowas enthalten im Log
      �J�)ԃ�hp1�@�S$t�i�@皙�Q2�BH@�461Hh
      1�4�J�S
      k(��Gz�[�P�%����4PEJ�@✍��<�1Q��
      .j5#8�<���G�>�%#c��/Z�i<�z�c@���<⣐�b�#Rs���h
      C�(�<�)��~���g�V�"��'�1�?ZkR�1L�g�=s���F��R�o�1@
      9����������HǠ��'���zӍ0��@�JM�0h�KL�S���"�>���9�
      6�@��ך3��6��?���K����:����$]�WN��eFp����&\q�@����i�U�5Z"��PV�
      H�i���
      H�i��#ja��0�f�E<�i��#4ʐ�$t�m����R*$<��r(�����Wk�[�횭(��n����(��q3R/��R���+ץ<��)�^j3��;�m��h=)9ݜҚJB�N�ɧ�AA��ݏji'84�N�i�n\�4�I{z��A�6y��g�Ӕ��iO_ZpA���<�܌�4�rzSB�I h�(&�N(Ƞ��qG}���zRP:�uQ@j(8� ��s�c�zs}�A�K�Pf��E(P �Z��r8�4gҀ��3Q���֞��5�(h�P?����♌����f�p)ꅎR�4�IS�6XR�����N;�R~\Te�@ A�'��dSI�8=(A �A9�
      �i+)>��h��ihGJ(Q@.i)}�1��H�4�@��8�E4�h4
      &��- '�\R�E �@-��1IR�`c��E����&��sN$���@4��
      &h'�]ԡ��ih���4�Ӂy�zSM%'���ڀHh�9�@i)3K�J1K֓4��M5!釭4�����d����]�1�*՚zӕ�9���ܛ�Ac�
      [4�;��G#6�l�Yj����EV�0�
      �EԲ'<�z�MJ�TԈA�ڀ,�r��rW�r�hpi�j jE�@�L�@�"�e7�q����A�Q:�4�ER�n �b�;�����R�m(�R�m(�R�R�QN�J(�
        @dslraser
        1�4�J�S
        H�i���
        dslraserD Offline
        dslraserD Offline
        dslraser
        #91
        nein
          @dslraser
          1�4�J�S
          H�i���
          dslraserD Offline
          dslraserD Offline
          dslraser
          #92
          @glasfaser
          sowas kommt zuerst
          TypeError: Converting circular structure to JSON
            nein
            GlasfaserG Offline
            GlasfaserG Offline
            #93
            @dslraser
            Komisch , das ist ein normaler Result .
            das mit den Zeichen ist das Bild von der Cam was zurückkommt .
            Aber es darf nicht JS abschmieren dadurch .
              @dslraser
              setze mal ein Debug , was als Wert in URL_Snapshot geschrieben wird .
              Ich teste immer mit einem Dummy Link:
              Beispiel :
              https://upload.wikimedia.org/wikipedia/commons/a/aa/Sun920607.jpg
              GlasfaserG Offline
              GlasfaserG Offline
              #94
              Beispiel :
              Hast du mal , anstatt dem Cam Link , das hier gemacht !?
                Beispiel :
                dslraserD Offline
                dslraserD Offline
                dslraser
                #95
                Nichtmal das klappt...Ich habe gerade keine Idee was bei mir hier schief läuft.
                  Beispiel :
                  dslraserD Offline
                  dslraserD Offline
                  dslraser
                  #96
                  Stop, das geht...
                    GlasfaserG Offline
                    GlasfaserG Offline
                    #97
                    @dslraser
                    Also liegt das Bild auch nicht dann in
                    /0_userdata.0/synology/bild.jpg
                    Targe in der URL_ioBrocker auch den Link vom Bild ein , was ist dann
                    EDIT :
                    OK hat sich überschnitten
                      GlasfaserG Offline
                      GlasfaserG Offline
                      #98
                      @dslraser
                      Also gibt es Probleme beim Bild holen , von dem Syn Link .
                      Mhh ....
                      Vielleicht braucht er länger zum Bild holen , setze mal ein Timeout nach dem Bildholen , so das die anderen abläufe später kommen .
                        @dslraser
                        Mhh ....
                        GlasfaserG Offline
                        GlasfaserG Offline
                        #99
                        @dslraser
                        Hier die gekürzte Version "Chatnachricht mit Umlaute und Bildversand"
                         <variables>
                           <variable id="$Tar!(b_)qw:24xtP(vj">url</variable>
                           <variable id="0;mm8IOdOmH_wz;%[zPo">Syno_URL</variable>
                           <variable id=",O#!.RmBLV$D$25E`o7/">Syno_Port</variable>
                           <variable id="Eg)M29q*/71]Q#lGjYO;">Chat_token</variable>
                           <variable id="u^a{RwAvq(*-0PK`(`@4">URL_Snapshot</variable>
                           <variable id="yW]q[i/Yfz.,5Z+Vb.a,">URL_ioBroker</variable>
                           <variable id="`=hGQ*[0C+pxdf]k]sV]">Nachricht</variable>
                           <variable id="D5Tj,(Y%B2Tp[@g/2DPn">Debug_URL</variable>
                           <variable id="/j={Oe4(A3y)y{F~G67H">Debug_send_Result</variable>
                           <variable type="timeout" id="timeout">timeout</variable>
                         </variables>
                         <block type="procedures_defcustomnoreturn" id="Fh|~ouZqovH}}ZEi:0P{" x="488" y="-537">
                           <mutation statements="false"></mutation>
                           <field name="NAME">Bild_holen</field>
                           <field name="SCRIPT">DQoNCg0KcmVxdWVzdCgNCg0KICB7DQoNCiAgICB1cmw6IFVSTF9TbmFwc2hvdCAsDQoNCiAgICBlbmNvZGluZzogbnVsbCwNCg0KICB9LA0KDQogIChlcnJvciwgcmVzcG9uc2UsIGJvZHkpID0+IHsNCg0KICAgIGlmICghZXJyb3IgJiYgYm9keSkgew0KDQogICAgICB3cml0ZUZpbGUoIjBfdXNlcmRhdGEuMCIsICIvc3lub2xvZ3kvYmlsZC5qcGciLCBib2R5KTsNCg0KICAgIH0NCg0KICB9DQoNCik7DQo=</field>
                         </block>
                         <block type="procedures_defcustomreturn" id="B`%(UJ@(5HI^#[)t`k$:" x="488" y="-512">
                             <arg name="url" varid="$Tar!(b_)qw:24xtP(vj"></arg>
                           </mutation>
                           <field name="NAME">encodeURI</field>
                           <field name="SCRIPT">dXJsID0gZW5jb2RlVVJJQ29tcG9uZW50KHVybCk7DQpyZXR1cm4gdXJsOw==</field>
                           <comment pinned="false" h="80" w="160">encode URL function</comment>
                         </block>
                         <block type="procedures_defcustomnoreturn" id="c4Zobeu@zHx7@T7RCR[+" x="488" y="-487">
                           <field name="NAME">Chat_senden</field>
                           <field name="SCRIPT">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</field>
                         </block>
                         <block type="comment" id="dh?Nq_).+o*LRx@ZBJ/P" x="488" y="-463">
                           <field name="COMMENT">https://forum.iobroker.net/topic/47210/synology-chat/98</field>
                           <next>
                             <block type="comment" id="]-LvUJjLlh6nbfULNnAm">
                               <field name="COMMENT">Synology Chat Daten</field>
                               <next>
                                 <block type="variables_set" id="u^*rT,0CM,T_]XeGow}h">
                                   <field name="VAR" id="0;mm8IOdOmH_wz;%[zPo">Syno_URL</field>
                                   <value name="VALUE">
                                     <block type="text" id="K]+z|W)qG[s?viD8cP}Q">
                                       <field name="TEXT">Deine IP</field>
                                     </block>
                                   </value>
                                   <next>
                                     <block type="variables_set" id=",|/0@uFO[kJp[pSjyfW~">
                                       <field name="VAR" id=",O#!.RmBLV$D$25E`o7/">Syno_Port</field>
                                         <block type="text" id="YmIhCu8+dV@OO0U[PWx#">
                                           <field name="TEXT">5000</field>
                                         </block>
                                       </value>
                                       <next>
                                         <block type="variables_set" id="Z}%_nt.Jz``.b})ifYmx">
                                           <field name="VAR" id="Eg)M29q*/71]Q#lGjYO;">Chat_token</field>
                                             <block type="text" id="[^9?/_`o:[u8zr_:o:`T">
                                               <field name="TEXT">Dein Token</field>
                                             </block>
                                           </value>
                                           <next>
                                             <block type="variables_set" id="fT*7tvvXRtyOgN,6C,2?">
                                               <field name="VAR" id="u^a{RwAvq(*-0PK`(`@4">URL_Snapshot</field>
                                                 <block type="text" id="N]=+,oldD=_C5-KIA*6[">
                                                   <field name="TEXT">Dein Snapshot Link</field>
                                                 </block>
                                               </value>
                                               <next>
                                                 <block type="variables_set" id="Q8SV]H7m2;RCEIl!I32S">
                                                   <field name="VAR" id="yW]q[i/Yfz.,5Z+Vb.a,">URL_ioBroker</field>
                                                     <block type="text" id="Cw;l)b1L4K(P86t9=T}E">
                                                       <field name="TEXT">http://192.168.xxx.xxx:8082/0_userdata.0/synology/bild.jpg</field>
                                                     </block>
                                                   </value>
                                                   <next>
                                                     <block type="variables_set" id="*dQxDuFmm[ppsJg3%3!V">
                                                       <field name="VAR" id="`=hGQ*[0C+pxdf]k]sV]">Nachricht</field>
                                                         <block type="procedures_callcustomreturn" id="GD%^L~Wq_LIL_y86c}(2">
                                                           <mutation name="encodeURI">
                                                             <arg name="url"></arg>
                                                           </mutation>
                                                           <value name="ARG0">
                                                             <block type="text" id="+_Bx+X)YJc^_8RSz74zE">
                                                               <field name="TEXT">Alarm an der  Haustür</field>
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                       <next>
                                                         <block type="comment" id="#X/LLHHf]+a]HP9ULZZA">
                                                           <field name="COMMENT">Debugmodus an/aus</field>
                                                           <next>
                                                             <block type="variables_set" id="]Dg;,gKp,/]Sb1cUFi?n">
                                                               <field name="VAR" id="D5Tj,(Y%B2Tp[@g/2DPn">Debug_URL</field>
        <block type="logic_boolean" id="0~lqDtIM29hgH2or)}mL">
        </block>
                                                               </value>
                                                               <next>
        <block type="variables_set" id="W=GM=?`a~14E-J+QXSAQ">
        <field name="VAR" id="/j={Oe4(A3y)y{F~G67H">Debug_send_Result</field>
        <block type="logic_boolean" id="*JUO/RsrY?M/l53;H_pF">
        </block>
        </value>
        <next>
        <block type="comment" id="[gDu2J;3btcPa(EESlU!">
        <field name="COMMENT">Ab hier Trigger</field>
        <next>
        <block type="on_ext" id="9h_zLLHz{65UPzm^$7}e">
        <value name="OID0">
        <shadow type="field_oid" id="NgekYWG@PsA7G02OF}rj">
        <field name="oid">0_userdata.0.Test123</field>
        </shadow>
        </value>
        <block type="controls_if" id="mSYXDpsYHKUM+j9uSS2s">
        <value name="IF0">
        <block type="on_source" id="l[/NtLhpCNaa5/@gH6X-">
        </block>
        </value>
        <statement name="DO0">
        <block type="procedures_callcustomnoreturn" id="eimW+=5+~Y|quii}_lBH">
        <mutation name="Bild_holen"></mutation>
        <next>
        <block type="timeouts_settimeout" id="ht3)ckT6?(PDbQipm{_z">
        <field name="DELAY">2000</field>
        <field name="UNIT">ms</field>
        <block type="procedures_callcustomnoreturn" id="[EP#gKV7fF}Y+8x8zkZ^">
        <mutation name="Chat_senden"></mutation>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </statement>
        <statement name="ELSE">
        <block type="timeouts_cleartimeout" id="TKEEXDr0Qo(}RX.!blS5">
        </block>
        </statement>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </next>
        </block>
                                                               </next>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </next>
                                             </block>
                                           </next>
                                         </block>
                                       </next>
                                     </block>
                                   </next>
                                 </block>
                               </next>
                             </block>
                           </next>
                         </block>
                        </xml>
                          @Glasfaser
                          ich bin irgendwie zu blöd ein Bild zu versenden....
                          Mit Telegram läuft das so:
                          Der steuere Befehl erzeugt ein neues Bild, das dann auch da ist:
                          Der Dateipfad in diesem Beispiel ist:
                          /opt/iobroker/iobroker-data/synology_0/snapshotCam_8.jpg
                          Ich bekomme es aber nicht hin dieses Bild zu versenden. Ich habe mit Deinem Blockly von weiter oben und auch mit diesem Beispiel rumprobiert....
                          Wie stelle ich das an ?
                          GlasfaserG Offline
                          GlasfaserG Offline
                          #100
                          Was hälst du davon :
                          var fs = require('fs');
                          const bild = fs.readFileSync('/opt/iobroker/iobroker-data/synology_0/snapshotCam_8.jpg');
                              writeFile('0_userdata.0','/synology/snapshotCam_8.jpg', bild);
                          Anstatt der URL_Snapshot einfach das Bild in userdata.0 dann kopieren
                          • dslraserD Offline
                            dslraserD Offline
                            dslraser
                            #101
                            @glasfaser
                            probiere ich ! (Hast Du schon probiert ?)
                              @glasfaser
                              GlasfaserG Offline
                              GlasfaserG Offline
                              #102
                              @dslraser
                              Ja ... geht !
                              Edit :
                              Bild holen mit deinem Script .. kannst du ja mit im Blockly einsetzen und dann
                              Bei "bild holen" gegen "kopieren" ersetzen.
                                @dslraser
                                Ja ... geht !
                                Edit :
                                dslraserD Offline
                                dslraserD Offline
                                dslraser
                                #103
                                @glasfaser
                                das funktioniert ! 👍
                                Hier ein Testbild von der Gartencam
                                  @glasfaser
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  #104
                                  @dslraser
                                  Puhh 😰 👍
                                    @glasfaser
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    #105
                                    Ahh ... du nutzt schon das neu Blockly von mir ;)
                                    sehe ich am zuvielen Leerzeichen was zwischen "der .... Haustür" ist . ( ist mir gerade aufgefallen )
                                      dslraserD Offline
                                      dslraserD Offline
                                      dslraser
                                      #106
                                      Ja, fürn Garten zum testen
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        #107
                                        zum testen
                                        Jetzt fehlt nur noch ein Löschbutton im Chat .... dann wäre alles perfekt ....
                                        Mein Chat ist schon zugemüllt vom vielen testen ....
                                        dslraserD 3 Antworten Letzte Antwort
                                          zum testen
                                          dslraserD Offline
                                          dslraserD Offline
                                          dslraser
                                          #108
                                          zum testen
                                          Ja, das stimmt. Sieht jetzt so aus bei mir. (Trigger Kaminlampe ist nur zum testen)
