  4. Javascript terminated with code 7 - Ursache?
    1.0k
    6.1k
25 Beiträge 5 Kommentatoren 6.3k Aufrufe
  • N Offline
    N Offline
    Nordlicht
    Moin,
    vor etwa 1 Stunde fing die Logdatei an Fehler auszuwerfen die ich nicht in ihrer Entstehung zuordnen kann.
    ioBrokerVM 2017-01-28 12:41:33.798 error host.ioBrokerVM instance system.adapter.hm-rega.0 terminated with code 7 (Adapter already running)
    ioBrokerVM 2017-01-28 12:41:27.503 error host.ioBrokerVM instance system.adapter.scenes.0 terminated with code 7 (Adapter already running)
    ioBrokerVM 2017-01-28 12:41:11.382 error host.ioBrokerVM instance system.adapter.javascript.1 terminated with code 7 (Adapter already running)
    ioBrokerVM 2017-01-28 12:41:03.493 error host.ioBrokerVM instance system.adapter.hm-rega.0 terminated with code 7 (Adapter already running)
    ioBrokerVM 2017-01-28 12:40:57.176 error host.ioBrokerVM instance system.adapter.scenes.0 terminated with code 7 (Adapter already running)
    ioBrokerVM 2017-01-28 12:40:40.879 error host.ioBrokerVM instance system.adapter.javascript.1 terminated with code 7 (Adapter already running)
    ioBrokerVM 2017-01-28 12:40:33.184 error host.ioBrokerVM instance system.adapter.hm-rega.0 terminated with code 7 (Adapter already running)
    ioBrokerVM 2017-01-28 12:40:26.882 error host.ioBrokerVM instance system.adapter.scenes.0 terminated with code 7 (Adapter already running)
    ioBrokerVM 2017-01-28 12:40:10.397 error host.ioBrokerVM instance system.adapter.javascript.1 terminated with code 7 (Adapter already running)
    ioBrokerVM 2017-01-28 12:40:02.887 error host.ioBrokerVM instance system.adapter.hm-rega.0 terminated with code 7 (Adapter already running)
    ioBrokerVM 2017-01-28 12:39:56.594 error host.ioBrokerVM instance system.adapter.scenes.0 terminated with code 7 (Adapter already running)
    ioBrokerVM 2017-01-28 12:39:39.891 error host.ioBrokerVM instance system.adapter.javascript.1 terminated with code 7 (Adapter already running)
    host.ioBrokerVM 2017-01-28 12:39:32.592 error instance system.adapter.hm-rega.0 terminated with code 7 (Adapter already running)
    host.ioBrokerVM 2017-01-28 12:39:26.277 error instance system.adapter.scenes.0 terminated with code 7 (Adapter already running)
    host.ioBrokerVM 2017-01-28 12:39:09.384 error instance system.adapter.javascript.1 terminated with code 7 (Adapter already running)
    host.ioBrokerVM 2017-01-28 12:39:02.266 error instance system.adapter.hm-rega.0 terminated with code 7 (Adapter already running)
    host.ioBrokerVM 2017-01-28 12:38:55.981 error instance system.adapter.scenes.0 terminated with code 7 (Adapter already running)
    host.ioBrokerVM 2017-01-28 12:38:38.828 error instance system.adapter.javascript.1 terminated with code 7 (Adapter already running)
    host.ioBrokerVM 2017-01-28 12:38:31.951 error instance system.adapter.hm-rega.0 terminated with code 7 (Adapter already running)
    host.ioBrokerVM 2017-01-28 12:38:25.689 error instance system.adapter.scenes.0 terminated with code 7 (Adapter already running)
    host.ioBrokerVM 2017-01-28 12:38:08.302 error instance system.adapter.javascript.1 terminated with code 7 (Adapter already running)
    host.ioBrokerVM 2017-01-28 12:38:01.617 error instance system.adapter.hm-rega.0 terminated with code 7 (Adapter already running)
    host.ioBrokerVM 2017-01-28 12:37:55.363 error instance system.adapter.scenes.0 terminated with code 7 (Adapter already running)
    host.ioBrokerVM 2017-01-28 12:37:37.744 error instance system.adapter.javascript.1 terminated with code 7 (Adapter already running)
    host.ioBrokerVM 2017-01-28 12:37:31.309 error instance system.adapter.hm-rega.0 terminated with code 7 (Adapter already runnin
    Zuerst kamen im ständigen Wechsel diese Fehler:
    Inzwischen "beschränken" sich die Fehler auf:
    Was läuft hier schief und wie kann ich es wieder beheben?
    Neustart von CCU und ioBroker sind mehrfach durchgeführt worden.
    Änderungen am System als solches wurden keine durchgeführt.
    Thomas
      Code 7 zeigt an, dass der Adapter doppelt läuft.
      Eigentlich sollte diese Fehlermeldung nach einem reboot des Hosts verschwunden sein. Was diesem reboot (des RasPi) bei einer VM entspricht weiss ich jedoch nicht.
      Alternativ muss du dir in der Konsole (z.B. mit top) die laufenden prozesse anzeigen lassen. Dort müssten dann zwei Prozesse für javascript laufen. Einer davon muss gekillt werden.
      Rainer
      • N Offline
        N Offline
        Nordlicht
        @Homoran:
        Code 7 zeigt an, dass der Adapter doppelt läuft. `
        Danke Rainer. Mit Code 7 konnte ich so gar nichts anfangen. Somit war die Ursache unbekannt.
        Wieso und warum das jetzt mit dieser Art Dauerschleife so war wird wahrscheinlich ein Geheimnis bleiben 8-)
        Jetzt läufts normal. Hake ich es einfach als "Samstag-Mittags-Anomalie" ab.
        Ich dachte schon ich habe zu viele Scripte laufen oder ich muss mehrere Java-Instanzen installieren um eventuell Entlastung zu schaffen.
        Weiß nicht was ioBroker so verträgt oder ab wann mehrere Instanzen von Java empfehlenswert sind. Bei 17 Skripten denke ich mal noch nicht….
        Thomas
          @Nordlicht:
          Danke Rainer. Mit Code 7 konnte ich so gar nichts anfangen. `
          naja ;-)
          @Nordlicht:
          terminated with code 7 (Adapter already running) `
          Mehrere Instanzen sind z.B. auch sinnvoll, wenn du viel testest.
          Dann nimmst du javascript.0 für den produktiven EInsatz und javascript.1 zum testen.
          Rainer
          • N Offline
            N Offline
            Nordlicht
            @Homoran:
            Ja, was das bedeutet war mir schon klar….. aber nicht warum..... nach mehreren Neustarts (auch des Rechners).
            Jetzt passt es ja, danke!
            Thomas
            • L Offline
              LJSven
              Ich habe das gleiche Problem - manche (auch schonmal 3-6) Adapter werden im Log angezeigt unter "terminated with code 7 (Adapter already running)" - wenn ich aber mit "top" überprüfe, sehe ich immer nur eine Instanz laufen.
              Woran kann das liegen? Muss ich da was machen?
              • apollon77A Offline
                Also wenn DU diesen Fehler bekommst und eine Instanz läuft dann ist das der Grund! Der Controller will, warum auch immer, den Adapter neu starten, kann er aber nicht weil er noch läuft.
                Also in dem Fall die laufenden Prozesse killen.
                Wenn es häufiger vorkommt dann muss man überlegen woran es liegt und suchen. In dem Fall beenden sich die prozesse nicht wie Sie sollen
                • L Offline
                  LJSven
                  Und genau da fängt mein Problem an. Ich weiß überhaupt nicht, wo ich suchen soll. Es sind ja immer unterschiedliche Instanzen. Das passiert, wenn der Raspi neustartet - wenn ich einen Reboot vom iobroker mache, sind es vllt. gar keine Instanz die doppelt versucht wird zu starten. Den ioBroker habe ich schon neu installiert (anschließend zwar das Backup, weil ich nciht weiß, wie es sonst wieder auf dem Ursprung hinbekomme.)
                  Kann mir jemand helfen?
                  • DutchmanD Offline
                    DutchmanD Offline
                    Dutchman
                    Da du neu installiert hast, ioBroker läuft nicht zufällig doppelt ?
                      Dann braucht es jetzt mal mehr Details!
                      Stoppe mal ioBroker (kein reboot!)
                      Dann prüfst Du mit psauxww|grep io. das alles auch wirklich beendet ist und keine ioBroker-Prozesse mehr laufen.
                      Dann ioBroker starten
                      Dann mal das log vom neustart posten bitte
                      • L Offline
                        LJSven
                        @Dutchman:
                        Da du neu installiert hast, ioBroker läuft nicht zufällig doppelt ? `
                        Nein, habe komplett formatiert.
                        • L Offline
                          LJSven
                          Das kommt bei mir bei dem Befehl:
                          root@raspberrypi:~# ps auxww|grep io.
                          root        10  0.0  0.0      0     0 ?        S    04:00   0:00 [migration/0]
                          root        13  0.0  0.0      0     0 ?        S    04:00   0:00 [migration/1]
                          root        18  0.0  0.0      0     0 ?        S    04:00   0:00 [migration/2]
                          root        23  0.0  0.0      0     0 ?        S    04:00   0:00 [migration/3]
                          root        40  0.0  0.0      0     0 ?        I<   04:00   0:00 [rpciod]
                          root        41  0.0  0.0      0     0 ?        I<   04:00   0:00 [xprtiod]
                          root        45  0.0  0.0      0     0 ?        I<   04:00   0:00 [nfsiod]
                          root        58  0.0  0.0      0     0 ?        I<   04:00   0:00 [DWC Notificatio]
                          message+   298  0.0  0.3   6508  3388 ?        Ss   04:00   0:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation
                          root     15488  0.0  0.0   4776   544 pts/0    S+   10:07   0:00 grep io.
                          Log vom Neustart:
                          2018-06-28 10:07:18.784 - info: host.raspberrypi received SIGTERM
                          2018-06-28 10:07:24.788 - info: host.raspberrypi received SIGTERM
                          2018-06-28 10:07:28.905 - info: host.raspberrypi force terminating
                          2018-06-28 10:07:28.907 - info: Adapter admin still running
                          2018-06-28 10:07:28.908 - info: Adapter discovery still running
                          2018-06-28 10:07:28.909 - info: Adapter javascript still running
                          2018-06-28 10:07:28.909 - info: Adapter sonos still running
                          2018-06-28 10:07:28.909 - info: Adapter fritzdect still running
                          2018-06-28 10:07:28.910 - info: Adapter sonoff still running
                          2018-06-28 10:07:28.911 - info: Adapter cloud still running
                          2018-06-28 10:07:28.911 - info: Adapter geofency still running
                          2018-06-28 10:07:28.911 - info: Adapter rpi2 still running
                          2018-06-28 10:07:28.912 - info: Adapter scenes still running
                          2018-06-28 10:07:28.912 - info: Adapter web still running
                          2018-06-28 10:07:28.913 - info: Adapter fritzbox still running
                          2018-06-28 10:07:28.913 - info: Adapter sayit still running
                          2018-06-28 10:07:28.914 - info: Adapter lgtv11 still running
                          2018-06-28 10:07:28.915 - info: Adapter history still running
                          2018-06-28 10:07:28.916 - info: Adapter email still running
                          2018-06-28 10:07:28.916 - info: Adapter parser still running
                          2018-06-28 10:07:28.917 - info: Adapter telegram still running
                          2018-06-28 10:07:28.917 - info: Adapter text2command still running
                          2018-06-28 10:07:28.918 - info: Adapter mqtt still running
                          2018-06-28 10:07:28.918 - info: Adapter simple-api still running
                          2018-06-28 10:07:28.918 - info: Adapter mihome still running
                          2018-06-28 10:08:37.567 - info: host.raspberrypi iobroker.js-controller version 1.4.2 js-controller starting
                          2018-06-28 10:08:37.592 - info: host.raspberrypi Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
                          2018-06-28 10:08:37.594 - info: host.raspberrypi hostname: raspberrypi, node: v6.14.3
                          2018-06-28 10:08:37.598 - info: host.raspberrypi ip addresses: 192.168.178.44 fe80::ba6f:5d66:56f0:9b94
                          2018-06-28 10:08:37.951 - info: host.raspberrypi inMem-states listening on port 9000
                          2018-06-28 10:08:38.753 - info: host.raspberrypi inMem-objects listening on port 9001
                          2018-06-28 10:08:38.800 - info: host.raspberrypi InMemoryDB connected
                          2018-06-28 10:08:38.869 - info: host.raspberrypi 38 instances found
                          2018-06-28 10:08:38.984 - info: host.raspberrypi starting 33 instances
                          2018-06-28 10:08:39.129 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 15506
                          2018-06-28 10:08:43.022 - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 15512
                          2018-06-28 10:08:46.201 - info: admin.0 starting. Version 3.4.7 in /opt/iobroker/node_modules/iobroker.admin, node: v6.14.3
                          2018-06-28 10:08:46.297 - info: admin.0 requesting all states
                          2018-06-28 10:08:46.307 - info: admin.0 requesting all objects
                          2018-06-28 10:08:46.311 - info: admin.0 Request actual repository...
                          2018-06-28 10:08:48.012 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 15522
                          2018-06-28 10:08:48.563 - info: discovery.0 starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.discovery, node: v6.14.3
                          2018-06-28 10:08:48.777 - info: admin.0 received all states
                          2018-06-28 10:08:51.025 - info: host.raspberrypi instance system.adapter.sonos.0 started with pid 15532
                          2018-06-28 10:08:52.168 - info: admin.0 received all objects
                          2018-06-28 10:08:52.547 - info: admin.0 http server listening on port 8081
                          2018-06-28 10:08:52.548 - info: admin.0 Use link "http://localhost:8081" to configure.
                          2018-06-28 10:08:53.207 - info: host.raspberrypi Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
                          2018-06-28 10:08:55.064 - info: host.raspberrypi instance system.adapter.fritzdect.0 started with pid 15538
                          2018-06-28 10:08:57.638 - debug: javascript.0 objectDB connected
                          2018-06-28 10:08:57.769 - debug: javascript.0 statesDB connected
                          2018-06-28 10:08:57.967 - info: javascript.0 starting. Version 3.6.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v6.14.3
                          2018-06-28 10:08:58.004 - info: javascript.0 requesting all states
                          2018-06-28 10:08:58.013 - info: javascript.0 requesting all objects
                          2018-06-28 10:08:58.201 - info: admin.0 Repository received successfully.
                          2018-06-28 10:08:59.880 - info: host.raspberrypi instance system.adapter.sonoff.0 started with pid 15548
                          2018-06-28 10:09:00.782 - info: sonos.0 starting. Version 1.6.2 in /opt/iobroker/node_modules/iobroker.sonos, node: v6.14.3
                          2018-06-28 10:09:01.226 - info: sonos.0 http sonos server listening on port 8083
                          2018-06-28 10:09:01.299 - info: javascript.0 received all states
                          2018-06-28 10:09:02.116 - info: fritzdect.0 starting. Version 0.1.1 in /opt/iobroker/node_modules/iobroker.fritzdect, node: v6.14.3
                          2018-06-28 10:09:02.160 - info: fritzdect.0 entered ready
                          2018-06-28 10:09:04.269 - info: sonoff.0 starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.sonoff, node: v6.14.3
                          2018-06-28 10:09:04.511 - info: sonoff.0 Starting MQTT authenticated server on port 1883
                          2018-06-28 10:09:06.809 - info: javascript.0 received all objects
                          2018-06-28 10:09:07.336 - info: host.raspberrypi instance system.adapter.cloud.0 started with pid 15572
                          2018-06-28 10:09:08.077 - info: fritzdect.0 Talking to FritzBox with firmware: 06.93
                          2018-06-28 10:09:08.590 - info: fritzdect.0 create Devices 3
                          2018-06-28 10:09:08.600 - info: fritzdect.0 setting up Thermostat/DECT3xx object Wohnzimmer Heizung
                          2018-06-28 10:09:08.648 - info: fritzdect.0 setting up Switch/DECT2xx object Galerie TV
                          2018-06-28 10:09:08.671 - info: fritzdect.0 setting up Switch/DECT2xx object Deko
                          2018-06-28 10:09:08.534 - info: vis.0 starting. Version 1.1.4 in /opt/iobroker/node_modules/iobroker.vis, node: v6.14.3
                          2018-06-28 10:09:08.873 - info: javascript.0 Start javascript script.js.common.Sonstige.Anwesenheit
                          2018-06-28 10:09:09.087 - info: vis.0 vis license is OK.
                          2018-06-28 10:09:10.851 - info: fritzdect.0 Comet ID: 109710237552 identified for command (targettemp) : 0
                          2018-06-28 10:09:08.992 - info: javascript.0 script.js.common.Sonstige.Anwesenheit: registered 3 subscriptions and 0 schedules
                          2018-06-28 10:09:08.994 - info: javascript.0 Start javascript script.js.common.Sonstige.Heizungssteuerung
                          2018-06-28 10:09:09.092 - info: javascript.0 script.js.common.Sonstige.Heizungssteuerung: Heizung - Mai bis September aus! Aussentemperatur beträgt 22
                          2018-06-28 10:09:09.102 - info: javascript.0 script.js.common.Sonstige.Heizungssteuerung: registered 2 subscriptions and 2 schedules
                          2018-06-28 10:09:09.104 - info: javascript.0 Start javascript script.js.common.Sonstige.Dekobeleuchtung
                          2018-06-28 10:09:09.154 - info: javascript.0 script.js.common.Sonstige.Dekobeleuchtung: registered 0 subscriptions and 1 schedule
                          2018-06-28 10:09:09.156 - info: javascript.0 Start javascript script.js.common.Sonstige.Text-To-Speech
                          2018-06-28 10:09:09.169 - info: javascript.0 script.js.common.Sonstige.Text-To-Speech: registered 1 subscription and 0 schedules
                          2018-06-28 10:09:09.172 - info: javascript.0 Start javascript script.js.common.Dreambox_EG.Sender.Sky_Sport_2
                          2018-06-28 10:09:09.289 - info: javascript.0 script.js.common.Dreambox_EG.Sender.Sky_Sport_2: registered 0 subscriptions and 0 schedules
                          2018-06-28 10:09:09.291 - info: javascript.0 Start javascript script.js.common.Dreambox_EG.Sender.Eurosport_HD_2
                          2018-06-28 10:09:09.312 - info: javascript.0 script.js.common.Dreambox_EG.Sender.Eurosport_HD_2: registered 0 subscriptions and 0 schedules
                          2018-06-28 10:09:09.314 - info: javascript.0 Start javascript script.js.common.Dreambox_EG.Standby_Off
                          2018-06-28 10:09:09.327 - info: javascript.0 script.js.common.Dreambox_EG.Standby_Off: registered 1 subscription and 0 schedules
                          2018-06-28 10:09:09.329 - info: javascript.0 Start javascript script.js.common.Dreambox_EG.Standby_On
                          2018-06-28 10:09:09.340 - info: javascript.0 script.js.common.Dreambox_EG.Standby_On: registered 1 subscription and 0 schedules
                          2018-06-28 10:09:09.342 - info: javascript.0 Start javascript script.js.common.Dreambox_EG.Sender.Sky_Bundesliga
                          2018-06-28 10:09:09.358 - info: javascript.0 script.js.common.Dreambox_EG.Sender.Sky_Bundesliga: registered 0 subscriptions and 0 schedules
                          2018-06-28 10:09:09.360 - info: javascript.0 Start javascript script.js.common.Dreambox_EG.Sender.Sky_Sport_1
                          2018-06-28 10:09:09.377 - info: javascript.0 script.js.common.Dreambox_EG.Sender.Sky_Sport_1: registered 0 subscriptions and 0 schedules
                          2018-06-28 10:09:09.380 - info: javascript.0 Start javascript script.js.common.Dreambox_EG.Standby_Toggle
                          2018-06-28 10:09:09.390 - info: javascript.0 script.js.common.Dreambox_EG.Standby_Toggle: registered 1 subscription and 0 schedules
                          2018-06-28 10:09:09.429 - info: javascript.0 Start javascript script.js.common.Dreambox_EG.Szene_Fussball_Bundesliga_Sky
                          2018-06-28 10:09:09.452 - info: javascript.0 script.js.common.Dreambox_EG.Szene_Fussball_Bundesliga_Sky: registered 1 subscription and 0 schedules
                          2018-06-28 10:09:09.472 - info: javascript.0 Start javascript script.js.common.Dreambox_OG.Standby_Off
                          2018-06-28 10:09:09.482 - info: javascript.0 script.js.common.Dreambox_OG.Standby_Off: registered 1 subscription and 0 schedules
                          2018-06-28 10:09:09.484 - info: javascript.0 Start javascript script.js.common.Dreambox_OG.Standby_On
                          2018-06-28 10:09:09.539 - info: javascript.0 script.js.common.Dreambox_OG.Standby_On: request: http://root:LJSven300878@192.168.178.220:88/web/powerstate?newstate=4
                          2018-06-28 10:09:09.541 - info: javascript.0 script.js.common.Dreambox_OG.Standby_On: registered 0 subscriptions and 0 schedules
                          2018-06-28 10:09:09.555 - info: javascript.0 Start javascript script.js.common.Dreambox_OG.Sender.Eurosport_HD_2
                          2018-06-28 10:09:09.597 - info: javascript.0 script.js.common.Dreambox_OG.Sender.Eurosport_HD_2: registered 0 subscriptions and 0 schedules
                          2018-06-28 10:09:09.622 - info: javascript.0 Start javascript script.js.common.Dreambox_OG.Sender.Sky_Bundesliga
                          2018-06-28 10:09:09.633 - info: javascript.0 script.js.common.Dreambox_OG.Sender.Sky_Bundesliga: registered 0 subscriptions and 0 schedules
                          2018-06-28 10:09:09.635 - info: javascript.0 Start javascript script.js.common.Dreambox_OG.Key_EXIT
                          2018-06-28 10:09:09.648 - info: javascript.0 script.js.common.Dreambox_OG.Key_EXIT: registered 1 subscription and 0 schedules
                          2018-06-28 10:09:09.650 - info: javascript.0 Start javascript script.js.common.Sonstige.Alles_Aus_-_Schaltung
                          2018-06-28 10:09:09.662 - info: javascript.0 script.js.common.Sonstige.Alles_Aus_-_Schaltung: registered 2 subscriptions and 0 schedules
                          2018-06-28 10:09:09.665 - info: javascript.0 Start javascript script.js.common.Sonstige.Astro-Tageszeit
                          2018-06-28 10:09:09.756 - info: javascript.0 script.js.common.Sonstige.Astro-Tageszeit: es wird Nacht: false
                          2018-06-28 10:09:09.790 - warn: javascript.0 Cannot calculate "night" for 52.0882309, 7.0213161
                          2018-06-28 10:09:09.792 - warn: javascript.0 Cannot calculate "nightEnd" for 52.0882309, 7.0213161
                          2018-06-28 10:09:09.822 - warn: javascript.0 Cannot calculate "night" for 52.0882309, 7.0213161
                          2018-06-28 10:09:10.133 - info: javascript.0 script.js.common.Sonstige.Astro-Tageszeit: registered 0 subscriptions and 10 schedules
                          2018-06-28 10:09:10.137 - info: javascript.0 Start javascript script.js.common.Dreambox_EG.Standby_Status_DB_EG
                          2018-06-28 10:09:10.470 - info: javascript.0 script.js.common.Dreambox_EG.Standby_Status_DB_EG: registered 0 subscriptions and 1 schedule
                          2018-06-28 10:09:10.472 - info: javascript.0 Start javascript script.js.common.Sonstige.Dreambox_OG_Standby-Prüfung
                          2018-06-28 10:09:10.482 - info: javascript.0 script.js.common.Sonstige.Dreambox_OG_Standby-Prüfung: registered 1 subscription and 0 schedules
                          2018-06-28 10:09:10.485 - info: javascript.0 Start javascript script.js.common.Bad.Bad_Sonos_Automation
                          2018-06-28 10:09:10.495 - info: javascript.0 script.js.common.Bad.Bad_Sonos_Automation: registered 1 subscription and 0 schedules
                          2018-06-28 10:09:10.498 - info: javascript.0 Start javascript script.js.common.Sonstige.Telegram_Button
                          2018-06-28 10:09:10.511 - debug: javascript.0 sendTo "send" to system.adapter.telegram.0 from system.adapter.javascript.0
                          2018-06-28 10:09:10.514 - info: javascript.0 script.js.common.Sonstige.Telegram_Button: registered 0 subscriptions and 0 schedules
                          2018-06-28 10:09:10.538 - info: javascript.0 Start javascript script.js.common.Sonstige.Bewegungsmelder_Script
                          2018-06-28 10:09:10.548 - info: javascript.0 script.js.common.Sonstige.Bewegungsmelder_Script: registered 1 subscription and 0 schedules
                          2018-06-28 10:09:10.550 - info: javascript.0 Start javascript script.js.common.Sensoren.RF-Bridge
                          2018-06-28 10:09:10.562 - info: javascript.0 script.js.common.Sensoren.RF-Bridge: registered 1 subscription and 0 schedules
                          2018-06-28 10:09:10.564 - info: javascript.0 Start javascript script.js.common.Sensoren.Kontakte.Terrassentür
                          2018-06-28 10:09:10.574 - info: javascript.0 script.js.common.Sensoren.Kontakte.Terrassentür: registered 1 subscription and 0 schedules
                          2018-06-28 10:09:10.576 - info: javascript.0 Start javascript script.js.common.Dreambox_OG.Dreambox_Auto_Power
                          2018-06-28 10:09:10.586 - info: javascript.0 script.js.common.Dreambox_OG.Dreambox_Auto_Power: registered 2 subscriptions and 0 schedules
                          2018-06-28 10:09:10.588 - info: javascript.0 Start javascript script.js.common.Sensoren.BWM.BWM_Bad
                          2018-06-28 10:09:10.598 - info: javascript.0 script.js.common.Sensoren.BWM.BWM_Bad: registered 1 subscription and 0 schedules
                          2018-06-28 10:09:10.600 - info: javascript.0 Start javascript script.js.common.Sonstige.OG_Flur_Nachtlicht
                          2018-06-28 10:09:10.613 - info: javascript.0 script.js.common.Sonstige.OG_Flur_Nachtlicht: registered 1 subscription and 0 schedules
                          2018-06-28 10:09:10.616 - info: javascript.0 Start javascript script.js.common.Sonstige.EG_Wohnzimmer_Nachtschaltung
                          2018-06-28 10:09:10.632 - info: javascript.0 script.js.common.Sonstige.EG_Wohnzimmer_Nachtschaltung: registered 1 subscription and 1 schedule
                          2018-06-28 10:09:10.635 - info: javascript.0 Start javascript script.js.common.Sonstige.EG_HWR_Gateway
                          2018-06-28 10:09:10.646 - info: javascript.0 script.js.common.Sonstige.EG_HWR_Gateway: registered 1 subscription and 0 schedules
                          2018-06-28 10:09:10.648 - info: javascript.0 Start javascript script.js.common.Sonstige.TOTAL_Überprüfung_Türen
                          2018-06-28 10:09:10.657 - info: javascript.0 script.js.common.Sonstige.TOTAL_Überprüfung_Türen: registered 1 subscription and 0 schedules
                          2018-06-28 10:09:10.659 - info: javascript.0 Start javascript script.js.common.Testfenster
                          2018-06-28 10:09:10.668 - info: javascript.0 script.js.common.Testfenster: registered 1 subscription and 0 schedules
                          2018-06-28 10:09:10.670 - info: javascript.0 Start javascript script.js.common.Sonstige.TOTAL_Alarmanlage
                          2018-06-28 10:09:10.680 - info: javascript.0 script.js.common.Sonstige.TOTAL_Alarmanlage: registered 1 subscription and 0 schedules
                          2018-06-28 10:09:10.683 - info: javascript.0 Start javascript script.js.common.Sonstige.LaufendeProzesse
                          2018-06-28 10:09:10.702 - info: javascript.0 script.js.common.Sonstige.LaufendeProzesse: registered 0 subscriptions and 1 schedule
                          2018-06-28 10:09:10.705 - info: javascript.0 Start javascript script.js.common.Sonstige.Aktuellen_Tag_vom_Jahr
                          2018-06-28 10:09:10.720 - info: javascript.0 script.js.common.Sonstige.Aktuellen_Tag_vom_Jahr: registered 0 subscriptions and 1 schedule
                          2018-06-28 10:09:10.721 - info: javascript.0 Start javascript script.js.common.Sonstige.Verpasster_Anruf
                          2018-06-28 10:09:10.730 - info: javascript.0 script.js.common.Sonstige.Verpasster_Anruf: registered 1 subscription and 0 schedules
                          2018-06-28 10:09:11.118 - info: fritzdect.0 Comet ID: 109710237552 identified for command (mode) : 1
                          2018-06-28 10:09:11.252 - info: host.raspberrypi instance system.adapter.geofency.0 started with pid 15582
                          2018-06-28 10:09:13.957 - error: javascript.0 script.js.common.Dreambox_OG.Standby_On: Error: connect EHOSTUNREACH 192.168.178.220:88
                          2018-06-28 10:09:17.538 - error: cloud.0 no connection to states DB: Connection timeout
                          2018-06-28 10:09:18.784 - error: geofency.0 no connection to objects DB
                          2018-06-28 10:09:23.967 - info: sonoff.0 Client [Highboard-Long] connected with secret 1530173363906_663
                          2018-06-28 10:09:24.041 - info: host.raspberrypi instance system.adapter.rpi2.0 started with pid 15599
                          2018-06-28 10:09:24.093 - info: host.raspberrypi instance system.adapter.scenes.0 started with pid 15605
                          2018-06-28 10:09:24.281 - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once
                          2018-06-28 10:09:24.644 - info: sonoff.0 Client [Highboard-Small] connected with secret 1530173364622_304
                          2018-06-28 10:09:24.846 - debug: javascript.0 system.adapter.admin.0: logging true
                          2018-06-28 10:09:27.204 - info: cloud.0 starting. Version 2.6.2 in /opt/iobroker/node_modules/iobroker.cloud, node: v6.14.3
                          2018-06-28 10:09:27.304 - info: geofency.0 starting. Version 0.3.2 in /opt/iobroker/node_modules/iobroker.geofency, node: v6.14.3
                          2018-06-28 10:09:27.322 - info: geofency.0 Adapter got 'Ready' Signal - initiating Main function...
                          2018-06-28 10:09:27.375 - info: geofency.0 http server listening on port 7999
                          2018-06-28 10:09:27.611 - info: cloud.0 Connecting with https://iobroker.net:10555 with "***********@trackquiz.com_a**********************"
                          2018-06-28 10:09:27.682 - info: rpi2.0 starting. Version 0.3.2 in /opt/iobroker/node_modules/iobroker.rpi2, node: v6.14.3
                          2018-06-28 10:09:27.683 - info: scenes.0 starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.scenes, node: v6.14.3
                          2018-06-28 10:09:30.751 - info: cloud.0 Trying to connect as system.user.admin
                          2018-06-28 10:09:32.943 - error: cloud.0 Cloud says: timeout
                          2018-06-28 10:09:33.958 - info: cloud.0 Connection changed: io server disconnect
                          2018-06-28 10:09:34.550 - info: rpi2.0 GPIO ports are not configured
                          2018-06-28 10:09:43.058 - info: host.raspberrypi instance system.adapter.web.0 started with pid 15655
                          2018-06-28 10:09:46.491 - info: web.0 starting. Version 2.3.5 in /opt/iobroker/node_modules/iobroker.web, node: v6.14.3
                          2018-06-28 10:09:47.495 - info: web.0 socket.io server listening on port 8082
                          2018-06-28 10:09:47.510 - info: web.0 http server listening on port 8082
                          2018-06-28 10:09:49.749 - info: vis-google-fonts.0 starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.vis-google-fonts, node: v6.14.3
                          2018-06-28 10:09:50.437 - info: host.raspberrypi instance system.adapter.vis-google-fonts.0 terminated while should be started once
                          2018-06-28 10:09:55.047 - info: host.raspberrypi instance system.adapter.fritzbox.0 started with pid 15675
                          2018-06-28 10:09:58.241 - info: fritzbox.0 starting. Version 0.2.1 in /opt/iobroker/node_modules/iobroker.fritzbox, node: v6.14.3
                          2018-06-28 10:09:58.300 - info: fritzbox.0 try to connect: 192.168.178.1
                          2018-06-28 10:09:58.402 - info: fritzbox.0 adapter connected to fritzbox: 192.168.178.1
                          2018-06-28 10:09:59.047 - info: host.raspberrypi instance system.adapter.sayit.0 started with pid 15685
                          2018-06-28 10:10:01.866 - info: sayit.0 starting. Version 1.6.8 in /opt/iobroker/node_modules/iobroker.sayit, node: v6.14.3
                          2018-06-28 10:10:01.901 - info: sayit.0 Upload announce mp3 files
                          2018-06-28 10:10:02.094 - info: sayit.0 All files uploaded
                          2018-06-28 10:10:03.047 - info: host.raspberrypi instance system.adapter.lgtv11.0 started with pid 15698
                          2018-06-28 10:10:05.682 - info: lgtv11.0 starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.lgtv11, node: v6.14.3
                          2018-06-28 10:10:05.717 - info: lgtv11.0 Ready. Configured LG TV IP: 192.168.178.20, Port: , Pairing Key: 789905
                          2018-06-28 10:10:07.048 - info: host.raspberrypi instance system.adapter.history.0 started with pid 15708
                          2018-06-28 10:10:09.684 - info: history.0 starting. Version 1.8.4 in /opt/iobroker/node_modules/iobroker.history, node: v6.14.3
                          2018-06-28 10:10:09.822 - info: history.0 enabled logging of javascript.0.Stromzähler.Hausstrom.Aktuell_Tag (Count=1), Alias=false
                          2018-06-28 10:10:09.830 - info: history.0 enabled logging of mihome.0.devices.gateway_7811dcfd6e12.illumination (Count=2), Alias=false
                          2018-06-28 10:10:09.833 - info: history.0 enabled logging of mihome.0.devices.sensor_motion_aq2_158d000200d283.lux (Count=3), Alias=false
                          2018-06-28 10:10:15.103 - info: host.raspberrypi instance scheduled system.adapter.yr.0 0 * * * *
                          2018-06-28 10:10:15.158 - info: host.raspberrypi instance system.adapter.yr.0 started with pid 15718
                          2018-06-28 10:10:18.393 - info: yr.0 starting. Version 1.0.6 in /opt/iobroker/node_modules/iobroker.yr, node: v6.14.3
                          2018-06-28 10:10:18.914 - info: yr.0 got weather data from yr.no
                          2018-06-28 10:10:18.988 - info: javascript.0 script.js.common.Sonstige.Heizungssteuerung: Heizung - Aussentemperatur liegt bei: 22
                          2018-06-28 10:10:19.028 - info: fritzdect.0 Comet ID: 109710237552 identified for command (targettemp) : 0
                          2018-06-28 10:10:19.055 - info: fritzdect.0 Comet ID: 109710237552 identified for command (mode) : 1
                          2018-06-28 10:10:23.042 - info: host.raspberrypi instance system.adapter.email.0 started with pid 15728
                          2018-06-28 10:10:24.094 - info: host.raspberrypi instance system.adapter.yr.0 terminated with code 0 (OK)
                          2018-06-28 10:10:25.743 - info: email.0 starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.email, node: v6.14.3
                          2018-06-28 10:10:27.043 - info: host.raspberrypi instance system.adapter.parser.0 started with pid 15738
                          2018-06-28 10:10:27.681 - info: cloud.0 Trying to connect as system.user.admin
                          2018-06-28 10:10:27.836 - info: cloud.0 Adapter redirected temporally to "https://iobroker.net:10560" in one minute. Reason: command from server
                          2018-06-28 10:10:27.840 - info: cloud.0 Connection changed: io client disconnect
                          2018-06-28 10:10:29.782 - info: parser.0 starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.parser, node: v6.14.3
                          2018-06-28 10:10:31.044 - info: host.raspberrypi instance system.adapter.telegram.0 started with pid 15748
                          2018-06-28 10:10:35.048 - info: host.raspberrypi instance system.adapter.text2command.0 started with pid 15790
                          2018-06-28 10:10:37.520 - info: telegram.0 starting. Version 1.2.4 in /opt/iobroker/node_modules/iobroker.telegram, node: v6.14.3
                          2018-06-28 10:10:37.900 - info: text2command.0 starting. Version 1.2.2 in /opt/iobroker/node_modules/iobroker.text2command, node: v6.14.3
                          2018-06-28 10:10:38.194 - info: telegram.0 getMe: {"id":556776579,"is_bot":true,"first_name":"SperberBot","username":"SperberBot"}
                          2018-06-28 10:10:39.044 - info: host.raspberrypi instance system.adapter.mqtt.0 started with pid 15804
                          2018-06-28 10:10:41.807 - info: mqtt.0 starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.mqtt, node: v6.14.3
                          2018-06-28 10:10:42.604 - info: mqtt.0 Starting MQTT ' authenticated server on port 1884
                          2018-06-28 10:10:43.035 - info: host.raspberrypi instance system.adapter.simple-api.0 started with pid 15814
                          2018-06-28 10:10:45.697 - info: simple-api.0 starting. Version 1.6.3 in /opt/iobroker/node_modules/iobroker.simple-api, node: v6.14.3
                          2018-06-28 10:10:45.790 - info: simple-api.0 simpleAPI server listening on port 8087
                          2018-06-28 10:10:45.792 - info: simple-api.0 Allow states only when user is owner: false
                          2018-06-28 10:10:45.804 - info: simple-api.0 http server listening on port 8087
                          2018-06-28 10:10:47.029 - info: host.raspberrypi instance system.adapter.mihome.0 started with pid 15824
                          2018-06-28 10:10:49.803 - info: mihome.0 starting. Version 1.0.7 in /opt/iobroker/node_modules/iobroker.mihome, node: v6.14.3
                          2018-06-28 10:10:49.952 - info: mihome.0 Change connection status: false
                          2018-06-28 10:10:50.019 - debug: javascript.0 sendTo "send" to system.adapter.telegram.0 from system.adapter.javascript.0
                          2018-06-28 10:10:50.091 - info: mihome.0 Change connection status: true
                          2018-06-28 10:10:50.101 - debug: javascript.0 sendTo "send" to system.adapter.telegram.0 from system.adapter.javascript.0
                          2018-06-28 10:11:27.870 - info: cloud.0 Trying to connect as system.user.admin
                          2018-06-28 10:11:28.031 - info: cloud.0 Connection changed: connect
                          Ist das das was du meintest mit Log nach dem Neustart?
                            Ja, aber in dem Log siegt alles sauber aus … nicht mit Error 7 ... wann kommt das denn?
                            • L Offline
                              LJSven
                              Auf jeden Fall nach einem Reboot des Raspberry. Ich mache jede Nacht um 4 Uhr den Befehl
                              sudo reboot
                              via Crontab.
                                warum auch immer Du das tust :-)
                                dann schick halt mal log von danach vom start von iobroker bis zu dem wo das kommt
                                • L Offline
                                  LJSven
                                  Hier mal der Reboot Prozess
                                  2018-06-28 04:00:00.132 - info: host.raspberrypi instance system.adapter.yr.0 started with pid 23968
                                  2018-06-28 04:00:03.753 - info: yr.0 starting. Version 1.0.6 in /opt/iobroker/node_modules/iobroker.yr, node: v6.14.3
                                  2018-06-28 04:00:04.401 - info: yr.0 got weather data from yr.no
                                  2018-06-28 04:00:04.511 - info: javascript.0 script.js.common.Sonstige.Heizungssteuerung: Heizung - Aussentemperatur liegt bei: 15
                                  2018-06-28 04:00:04.532 - info: fritzdect.0 Comet ID: 109710237552 identified for command (targettemp) : 0
                                  2018-06-28 04:00:04.582 - info: fritzdect.0 Comet ID: 109710237552 identified for command (mode) : 1
                                  2018-06-28 04:00:04.691 - info: host.raspberrypi received SIGTERM
                                  2018-06-28 04:00:09.642 - info: host.raspberrypi instance system.adapter.yr.0 terminated with code 0 (OK)
                                  2018-06-28 04:00:10.713 - info: host.raspberrypi received SIGTERM
                                  2018-06-28 04:00:14.769 - info: host.raspberrypi force terminating
                                  2018-06-28 04:00:14.771 - info: Adapter admin still running
                                  2018-06-28 04:00:14.772 - info: Adapter discovery still running
                                  2018-06-28 04:00:14.773 - info: Adapter javascript still running
                                  2018-06-28 04:00:14.774 - info: Adapter sonos still running
                                  2018-06-28 04:00:14.775 - info: Adapter fritzdect still running
                                  2018-06-28 04:00:14.777 - info: Adapter sonoff still running
                                  2018-06-28 04:00:14.778 - info: Adapter cloud still running
                                  2018-06-28 04:00:14.779 - info: Adapter geofency still running
                                  2018-06-28 04:00:14.780 - info: Adapter rpi2 still running
                                  2018-06-28 04:00:14.781 - info: Adapter scenes still running
                                  2018-06-28 04:00:14.782 - info: Adapter web still running
                                  2018-06-28 04:00:14.783 - info: Adapter fritzbox still running
                                  2018-06-28 04:00:14.783 - info: Adapter sayit still running
                                  2018-06-28 04:00:14.784 - info: Adapter lgtv11 still running
                                  2018-06-28 04:00:14.785 - info: Adapter history still running
                                  2018-06-28 04:00:14.787 - info: Adapter email still running
                                  2018-06-28 04:00:14.788 - info: Adapter parser still running
                                  2018-06-28 04:00:14.789 - info: Adapter telegram still running
                                  2018-06-28 04:00:14.790 - info: Adapter text2command still running
                                  2018-06-28 04:00:14.791 - info: Adapter mqtt still running
                                  2018-06-28 04:00:14.792 - info: Adapter simple-api still running
                                  2018-06-28 04:00:14.792 - info: Adapter mihome still running
                                  2018-06-28 04:00:33.851 - info: host.raspberrypi iobroker.js-controller version 1.4.2 js-controller starting
                                  2018-06-28 04:00:33.876 - info: host.raspberrypi Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
                                  2018-06-28 04:00:33.878 - info: host.raspberrypi hostname: raspberrypi, node: v6.14.3
                                  2018-06-28 04:00:33.882 - info: host.raspberrypi ip addresses: 192.168.178.44 fe80::ba6f:5d66:56f0:9b94
                                  2018-06-28 04:00:34.318 - info: host.raspberrypi inMem-states listening on port 9000
                                  2018-06-28 04:00:35.229 - info: host.raspberrypi inMem-objects listening on port 9001
                                  2018-06-28 04:00:35.284 - info: host.raspberrypi InMemoryDB connected
                                  2018-06-28 04:00:35.353 - info: host.raspberrypi 38 instances found
                                  2018-06-28 04:00:35.514 - info: host.raspberrypi starting 33 instances
                                  2018-06-28 04:00:35.688 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 541
                                  2018-06-28 04:00:39.570 - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 548
                                  2018-06-28 04:00:43.548 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 554
                                  2018-06-28 04:00:44.626 - info: admin.0 starting. Version 3.4.7 in /opt/iobroker/node_modules/iobroker.admin, node: v6.14.3
                                  2018-06-28 04:00:44.733 - info: admin.0 requesting all states
                                  2018-06-28 04:00:44.635 - info: discovery.0 starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.discovery, node: v6.14.3
                                  2018-06-28 04:00:44.746 - info: admin.0 requesting all objects
                                  2018-06-28 04:00:44.751 - info: admin.0 Request actual repository...
                                  2018-06-28 04:00:47.162 - info: admin.0 received all states
                                  2018-06-28 04:00:47.573 - info: host.raspberrypi instance system.adapter.sonos.0 started with pid 568
                                  2018-06-28 04:00:58.619 - info: admin.0 received all objects
                                  2018-06-28 04:00:59.443 - info: admin.0 http server listening on port 8081
                                  2018-06-28 04:00:59.445 - info: admin.0 Use link "http://localhost:8081" to configure.
                                  2018-06-28 04:00:59.586 - info: host.raspberrypi instance system.adapter.fritzdect.0 started with pid 575
                                  2018-06-28 04:01:00.142 - info: host.raspberrypi Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
                                  2018-06-28 04:01:03.254 - error: sonos.0 no connection to objects DB
                                  2018-06-28 04:01:04.617 - info: host.raspberrypi instance system.adapter.sonoff.0 started with pid 589
                                  2018-06-28 04:01:04.917 - debug: javascript.0 objectDB connected
                                  2018-06-28 04:01:05.835 - debug: javascript.0 statesDB connected
                                  2018-06-28 04:01:05.901 - info: sonos.0 starting. Version 1.6.2 in /opt/iobroker/node_modules/iobroker.sonos, node: v6.14.3
                                  2018-06-28 04:01:06.179 - info: javascript.0 starting. Version 3.6.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v6.14.3
                                  2018-06-28 04:01:06.199 - info: sonos.0 http sonos server listening on port 8083
                                  2018-06-28 04:01:06.227 - info: javascript.0 requesting all states
                                  2018-06-28 04:01:06.245 - info: javascript.0 requesting all objects
                                  2018-06-28 04:01:08.553 - info: admin.0 Repository received successfully.
                                  2018-06-28 04:01:09.747 - info: javascript.0 received all states
                                  2018-06-28 04:01:09.471 - info: fritzdect.0 starting. Version 0.1.1 in /opt/iobroker/node_modules/iobroker.fritzdect, node: v6.14.3
                                  2018-06-28 04:01:09.536 - info: fritzdect.0 entered ready
                                  2018-06-28 04:01:09.751 - info: sonoff.0 starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.sonoff, node: v6.14.3
                                  2018-06-28 04:01:10.414 - info: sonoff.0 Starting MQTT authenticated server on port 1883
                                  2018-06-28 04:01:11.607 - info: host.raspberrypi instance system.adapter.cloud.0 started with pid 613
                                  2018-06-28 04:01:14.059 - info: vis.0 starting. Version 1.1.4 in /opt/iobroker/node_modules/iobroker.vis, node: v6.14.3
                                  2018-06-28 04:01:14.501 - info: vis.0 vis license is OK.
                                  2018-06-28 04:01:14.642 - info: javascript.0 received all objects
                                  2018-06-28 04:01:15.252 - info: javascript.0 Start javascript script.js.common.Sonstige.Anwesenheit
                                  2018-06-28 04:01:15.388 - info: fritzdect.0 Talking to FritzBox with firmware: 06.93
                                  2018-06-28 04:01:15.590 - info: host.raspberrypi instance system.adapter.geofency.0 started with pid 623
                                  2018-06-28 04:01:15.886 - info: fritzdect.0 create Devices 3
                                  2018-06-28 04:01:15.890 - info: fritzdect.0 setting up Thermostat/DECT3xx object Wohnzimmer Heizung
                                  2018-06-28 04:01:16.520 - info: fritzdect.0 setting up Switch/DECT2xx object Galerie TV
                                  2018-06-28 04:01:16.539 - info: fritzdect.0 setting up Switch/DECT2xx object Deko
                                  2018-06-28 04:01:18.497 - info: cloud.0 starting. Version 2.6.2 in /opt/iobroker/node_modules/iobroker.cloud, node: v6.14.3
                                  2018-06-28 04:01:19.087 - info: cloud.0 Connecting with https://iobroker.net:10555 with "i************"
                                  2018-06-28 04:01:19.594 - info: host.raspberrypi instance system.adapter.rpi2.0 started with pid 633
                                  2018-06-28 04:01:20.048 - info: cloud.0 Trying to connect as system.user.admin
                                  2018-06-28 04:01:20.190 - info: geofency.0 starting. Version 0.3.2 in /opt/iobroker/node_modules/iobroker.geofency, node: v6.14.3
                                  2018-06-28 04:01:20.270 - info: geofency.0 Adapter got 'Ready' Signal - initiating Main function...
                                  2018-06-28 04:01:20.346 - info: geofency.0 http server listening on port 7999
                                  2018-06-28 04:01:15.322 - info: javascript.0 script.js.common.Sonstige.Anwesenheit: registered 3 subscriptions and 0 schedules
                                  2018-06-28 04:01:15.325 - info: javascript.0 Start javascript script.js.common.Sonstige.Heizungssteuerung
                                  2018-06-28 04:01:15.394 - info: javascript.0 script.js.common.Sonstige.Heizungssteuerung: Heizung - Mai bis September aus! Aussentemperatur beträgt 15
                                  2018-06-28 04:01:15.402 - info: javascript.0 script.js.common.Sonstige.Heizungssteuerung: registered 2 subscriptions and 2 schedules
                                  2018-06-28 04:01:15.407 - info: javascript.0 Start javascript script.js.common.Sonstige.Dekobeleuchtung
                                  2018-06-28 04:01:16.488 - info: javascript.0 script.js.common.Sonstige.Dekobeleuchtung: registered 0 subscriptions and 1 schedule
                                  2018-06-28 04:01:16.490 - info: javascript.0 Start javascript script.js.common.Sonstige.Text-To-Speech
                                  2018-06-28 04:01:16.503 - info: javascript.0 script.js.common.Sonstige.Text-To-Speech: registered 1 subscription and 0 schedules
                                  2018-06-28 04:01:16.506 - info: javascript.0 Start javascript script.js.common.Dreambox_EG.Sender.Sky_Sport_2
                                  2018-06-28 04:01:16.571 - info: javascript.0 script.js.common.Dreambox_EG.Sender.Sky_Sport_2: registered 0 subscriptions and 0 schedules
                                  2018-06-28 04:01:16.573 - info: javascript.0 Start javascript script.js.common.Dreambox_EG.Sender.Eurosport_HD_2
                                  2018-06-28 04:01:16.593 - info: javascript.0 script.js.common.Dreambox_EG.Sender.Eurosport_HD_2: registered 0 subscriptions and 0 schedules
                                  2018-06-28 04:01:16.595 - info: javascript.0 Start javascript script.js.common.Dreambox_EG.Standby_Off
                                  2018-06-28 04:01:16.608 - info: javascript.0 script.js.common.Dreambox_EG.Standby_Off: registered 1 subscription and 0 schedules
                                  2018-06-28 04:01:16.610 - info: javascript.0 Start javascript script.js.common.Dreambox_EG.Standby_On
                                  2018-06-28 04:01:16.620 - info: javascript.0 script.js.common.Dreambox_EG.Standby_On: registered 1 subscription and 0 schedules
                                  2018-06-28 04:01:16.622 - info: javascript.0 Start javascript script.js.common.Dreambox_EG.Sender.Sky_Bundesliga
                                  2018-06-28 04:01:16.636 - info: javascript.0 script.js.common.Dreambox_EG.Sender.Sky_Bundesliga: registered 0 subscriptions and 0 schedules
                                  2018-06-28 04:01:16.638 - info: javascript.0 Start javascript script.js.common.Dreambox_EG.Sender.Sky_Sport_1
                                  2018-06-28 04:01:16.663 - info: javascript.0 script.js.common.Dreambox_EG.Sender.Sky_Sport_1: registered 0 subscriptions and 0 schedules
                                  2018-06-28 04:01:16.665 - info: javascript.0 Start javascript script.js.common.Dreambox_EG.Standby_Toggle
                                  2018-06-28 04:01:16.676 - info: javascript.0 script.js.common.Dreambox_EG.Standby_Toggle: registered 1 subscription and 0 schedules
                                  2018-06-28 04:01:16.684 - info: javascript.0 Start javascript script.js.common.Dreambox_EG.Szene_Fussball_Bundesliga_Sky
                                  2018-06-28 04:01:16.696 - info: javascript.0 script.js.common.Dreambox_EG.Szene_Fussball_Bundesliga_Sky: registered 1 subscription and 0 schedules
                                  2018-06-28 04:01:16.700 - info: javascript.0 Start javascript script.js.common.Dreambox_OG.Standby_Off
                                  2018-06-28 04:01:16.710 - info: javascript.0 script.js.common.Dreambox_OG.Standby_Off: registered 1 subscription and 0 schedules
                                  2018-06-28 04:01:16.712 - info: javascript.0 Start javascript script.js.common.Dreambox_OG.Standby_On
                                  2018-06-28 04:01:16.726 - info: javascript.0 script.js.common.Dreambox_OG.Standby_On: request: http://root:LJSven300878@192.168.178.220:88/web/powerstate?newstate=4
                                  2018-06-28 04:01:16.728 - info: javascript.0 script.js.common.Dreambox_OG.Standby_On: registered 0 subscriptions and 0 schedules
                                  2018-06-28 04:01:16.729 - info: javascript.0 Start javascript script.js.common.Dreambox_OG.Sender.Eurosport_HD_2
                                  2018-06-28 04:01:16.745 - info: javascript.0 script.js.common.Dreambox_OG.Sender.Eurosport_HD_2: registered 0 subscriptions and 0 schedules
                                  2018-06-28 04:01:16.746 - info: javascript.0 Start javascript script.js.common.Dreambox_OG.Sender.Sky_Bundesliga
                                  2018-06-28 04:01:16.759 - info: javascript.0 script.js.common.Dreambox_OG.Sender.Sky_Bundesliga: registered 0 subscriptions and 0 schedules
                                  2018-06-28 04:01:16.760 - info: javascript.0 Start javascript script.js.common.Dreambox_OG.Key_EXIT
                                  2018-06-28 04:01:16.775 - info: javascript.0 script.js.common.Dreambox_OG.Key_EXIT: registered 1 subscription and 0 schedules
                                  2018-06-28 04:01:16.777 - info: javascript.0 Start javascript script.js.common.Sonstige.Alles_Aus_-_Schaltung
                                  2018-06-28 04:01:16.787 - info: javascript.0 script.js.common.Sonstige.Alles_Aus_-_Schaltung: registered 2 subscriptions and 0 schedules
                                  2018-06-28 04:01:16.789 - info: javascript.0 Start javascript script.js.common.Sonstige.Astro-Tageszeit
                                  2018-06-28 04:01:16.818 - info: javascript.0 script.js.common.Sonstige.Astro-Tageszeit: es wird Nacht: false
                                  2018-06-28 04:01:16.827 - warn: javascript.0 Cannot calculate "night" for 52.0882309, 7.0213161
                                  2018-06-28 04:01:16.835 - warn: javascript.0 Cannot calculate "nightEnd" for 52.0882309, 7.0213161
                                  2018-06-28 04:01:16.844 - warn: javascript.0 Cannot calculate "night" for 52.0882309, 7.0213161
                                  2018-06-28 04:01:20.402 - info: javascript.0 script.js.common.Sonstige.Astro-Tageszeit: registered 0 subscriptions and 10 schedules
                                  2018-06-28 04:01:20.406 - info: javascript.0 Start javascript script.js.common.Dreambox_EG.Standby_Status_DB_EG
                                  2018-06-28 04:01:21.240 - info: javascript.0 script.js.common.Dreambox_EG.Standby_Status_DB_EG: registered 0 subscriptions and 1 schedule
                                  2018-06-28 04:01:21.242 - info: javascript.0 Start javascript script.js.common.Sonstige.Dreambox_OG_Standby-Prüfung
                                  2018-06-28 04:01:21.252 - info: javascript.0 script.js.common.Sonstige.Dreambox_OG_Standby-Prüfung: registered 1 subscription and 0 schedules
                                  2018-06-28 04:01:21.254 - info: javascript.0 Start javascript script.js.common.Bad.Bad_Sonos_Automation
                                  2018-06-28 04:01:21.264 - info: javascript.0 script.js.common.Bad.Bad_Sonos_Automation: registered 1 subscription and 0 schedules
                                  2018-06-28 04:01:21.266 - info: javascript.0 Start javascript script.js.common.Sonstige.Telegram_Button
                                  2018-06-28 04:01:21.279 - debug: javascript.0 sendTo "send" to system.adapter.telegram.0 from system.adapter.javascript.0
                                  2018-06-28 04:01:21.282 - info: javascript.0 script.js.common.Sonstige.Telegram_Button: registered 0 subscriptions and 0 schedules
                                  2018-06-28 04:01:21.299 - info: javascript.0 Start javascript script.js.common.Sonstige.Bewegungsmelder_Script
                                  2018-06-28 04:01:21.312 - info: javascript.0 script.js.common.Sonstige.Bewegungsmelder_Script: registered 1 subscription and 0 schedules
                                  2018-06-28 04:01:21.314 - info: javascript.0 Start javascript script.js.common.Sensoren.RF-Bridge
                                  2018-06-28 04:01:21.325 - info: javascript.0 script.js.common.Sensoren.RF-Bridge: registered 1 subscription and 0 schedules
                                  2018-06-28 04:01:21.327 - info: javascript.0 Start javascript script.js.common.Sensoren.Kontakte.Terrassentür
                                  2018-06-28 04:01:21.337 - info: javascript.0 script.js.common.Sensoren.Kontakte.Terrassentür: registered 1 subscription and 0 schedules
                                  2018-06-28 04:01:21.338 - info: javascript.0 Start javascript script.js.common.Dreambox_OG.Dreambox_Auto_Power
                                  2018-06-28 04:01:21.348 - info: javascript.0 script.js.common.Dreambox_OG.Dreambox_Auto_Power: registered 2 subscriptions and 0 schedules
                                  2018-06-28 04:01:21.350 - info: javascript.0 Start javascript script.js.common.Sensoren.BWM.BWM_Bad
                                  2018-06-28 04:01:21.359 - info: javascript.0 script.js.common.Sensoren.BWM.BWM_Bad: registered 1 subscription and 0 schedules
                                  2018-06-28 04:01:21.361 - info: javascript.0 Start javascript script.js.common.Sonstige.OG_Flur_Nachtlicht
                                  2018-06-28 04:01:21.371 - info: javascript.0 script.js.common.Sonstige.OG_Flur_Nachtlicht: registered 1 subscription and 0 schedules
                                  2018-06-28 04:01:21.373 - info: javascript.0 Start javascript script.js.common.Sonstige.EG_Wohnzimmer_Nachtschaltung
                                  2018-06-28 04:01:21.391 - info: javascript.0 script.js.common.Sonstige.EG_Wohnzimmer_Nachtschaltung: registered 1 subscription and 1 schedule
                                  2018-06-28 04:01:21.393 - info: javascript.0 Start javascript script.js.common.Sonstige.EG_HWR_Gateway
                                  2018-06-28 04:01:21.403 - info: javascript.0 script.js.common.Sonstige.EG_HWR_Gateway: registered 1 subscription and 0 schedules
                                  2018-06-28 04:01:21.405 - info: javascript.0 Start javascript script.js.common.Sonstige.TOTAL_Überprüfung_Türen
                                  2018-06-28 04:01:21.414 - info: javascript.0 script.js.common.Sonstige.TOTAL_Überprüfung_Türen: registered 1 subscription and 0 schedules
                                  2018-06-28 04:01:21.416 - info: javascript.0 Start javascript script.js.common.Testfenster
                                  2018-06-28 04:01:21.425 - info: javascript.0 script.js.common.Testfenster: registered 1 subscription and 0 schedules
                                  2018-06-28 04:01:21.427 - info: javascript.0 Start javascript script.js.common.Sonstige.TOTAL_Alarmanlage
                                  2018-06-28 04:01:21.437 - info: javascript.0 script.js.common.Sonstige.TOTAL_Alarmanlage: registered 1 subscription and 0 schedules
                                  2018-06-28 04:01:21.439 - info: javascript.0 Start javascript script.js.common.Sonstige.LaufendeProzesse
                                  2018-06-28 04:01:21.460 - info: javascript.0 script.js.common.Sonstige.LaufendeProzesse: registered 0 subscriptions and 1 schedule
                                  2018-06-28 04:01:21.463 - info: javascript.0 Start javascript script.js.common.Sonstige.Aktuellen_Tag_vom_Jahr
                                  2018-06-28 04:01:21.474 - info: javascript.0 script.js.common.Sonstige.Aktuellen_Tag_vom_Jahr: registered 0 subscriptions and 1 schedule
                                  2018-06-28 04:01:21.476 - info: javascript.0 Start javascript script.js.common.Sonstige.Verpasster_Anruf
                                  2018-06-28 04:01:21.485 - info: javascript.0 script.js.common.Sonstige.Verpasster_Anruf: registered 1 subscription and 0 schedules
                                  2018-06-28 04:01:23.229 - info: sonoff.0 Client [Highboard-Small] connected with secret 1530151283172_9015
                                  2018-06-28 04:01:23.438 - info: fritzdect.0 Comet ID: 109710237552 identified for command (targettemp) : 0
                                  2018-06-28 04:01:23.738 - info: host.raspberrypi instance system.adapter.scenes.0 started with pid 646
                                  2018-06-28 04:01:23.758 - info: fritzdect.0 Comet ID: 109710237552 identified for command (mode) : 1
                                  2018-06-28 04:01:24.285 - info: rpi2.0 starting. Version 0.3.2 in /opt/iobroker/node_modules/iobroker.rpi2, node: v6.14.3
                                  2018-06-28 04:01:24.400 - error: cloud.0 Cloud says: timeout
                                  2018-06-28 04:01:24.677 - error: javascript.0 script.js.common.Dreambox_OG.Standby_On: Error: connect EHOSTUNREACH 192.168.178.220:88
                                  2018-06-28 04:01:25.408 - info: cloud.0 Connection changed: io server disconnect
                                  2018-06-28 04:01:26.511 - info: sonoff.0 Client [Highboard-Long] connected with secret 1530151286502_3470
                                  2018-06-28 04:01:28.160 - info: scenes.0 starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.scenes, node: v6.14.3
                                  2018-06-28 04:01:30.264 - info: rpi2.0 GPIO ports are not configured
                                  2018-06-28 04:01:47.603 - info: host.raspberrypi instance system.adapter.web.0 started with pid 696
                                  2018-06-28 04:01:57.064 - info: vis-google-fonts.0 starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.vis-google-fonts, node: v6.14.3
                                  2018-06-28 04:01:58.399 - info: host.raspberrypi instance system.adapter.vis-google-fonts.0 terminated while should be started once
                                  2018-06-28 04:01:59.618 - info: host.raspberrypi instance system.adapter.fritzbox.0 started with pid 712
                                  2018-06-28 04:02:03.619 - info: host.raspberrypi instance system.adapter.sayit.0 started with pid 721
                                  2018-06-28 04:02:06.776 - warn: vis.0 Reconnection to DB.
                                  2018-06-28 04:02:06.783 - warn: vis.0 Reconnection to DB.
                                  2018-06-28 04:02:06.886 - info: vis.0 starting. Version 1.1.4 in /opt/iobroker/node_modules/iobroker.vis, node: v6.14.3
                                  2018-06-28 04:02:07.056 - info: vis.0 starting. Version 1.1.4 in /opt/iobroker/node_modules/iobroker.vis, node: v6.14.3
                                  2018-06-28 04:02:07.624 - info: host.raspberrypi instance system.adapter.lgtv11.0 started with pid 731
                                  2018-06-28 04:02:07.813 - info: web.0 starting. Version 2.3.5 in /opt/iobroker/node_modules/iobroker.web, node: v6.14.3
                                  2018-06-28 04:02:07.872 - info: fritzbox.0 starting. Version 0.2.1 in /opt/iobroker/node_modules/iobroker.fritzbox, node: v6.14.3
                                  2018-06-28 04:02:08.140 - info: sayit.0 starting. Version 1.6.8 in /opt/iobroker/node_modules/iobroker.sayit, node: v6.14.3
                                  2018-06-28 04:02:07.941 - info: fritzbox.0 try to connect: 192.168.178.1
                                  2018-06-28 04:02:08.057 - info: fritzbox.0 adapter connected to fritzbox: 192.168.178.1
                                  2018-06-28 04:02:08.183 - info: sayit.0 Upload announce mp3 files
                                  2018-06-28 04:02:17.909 - error: lgtv11.0 no connection to objects DB
                                  2018-06-28 04:02:24.253 - error: cloud.0 Cloud says: timeout
                                  2018-06-28 04:02:12.320 - info: host.raspberrypi instance system.adapter.history.0 started with pid 745
                                  2018-06-28 04:02:26.428 - info: host.raspberrypi instance scheduled system.adapter.yr.0 0 * * * *
                                  2018-06-28 04:02:26.472 - info: host.raspberrypi instance system.adapter.yr.0 started with pid 755
                                  2018-06-28 04:02:26.786 - warn: geofency.0 Reconnection to DB.
                                  2018-06-28 04:02:26.829 - warn: scenes.0 Reconnection to DB.
                                  2018-06-28 04:02:26.836 - warn: rpi2.0 Reconnection to DB.
                                  2018-06-28 04:02:26.856 - warn: sonos.0 Reconnection to DB.
                                  2018-06-28 04:02:26.852 - warn: geofency.0 Reconnection to DB.
                                  2018-06-28 04:02:26.892 - info: cloud.0 Trying to connect as system.user.admin
                                  2018-06-28 04:02:26.867 - warn: rpi2.0 Reconnection to DB.
                                  2018-06-28 04:02:26.886 - warn: scenes.0 Reconnection to DB.
                                  2018-06-28 04:02:26.911 - warn: sonos.0 Reconnection to DB.
                                  2018-06-28 04:02:07.103 - info: vis.0 vis license is OK.
                                  2018-06-28 04:02:28.521 - info: vis.0 vis license is OK.
                                  2018-06-28 04:02:32.143 - error: lgtv11.0 no connection to states DB: Connection timeout
                                  2018-06-28 04:02:42.249 - error: yr.0 no connection to objects DB
                                  2018-06-28 04:02:42.327 - error: history.0 no connection to objects DB
                                  2018-06-28 04:02:52.768 - info: host.raspberrypi instance system.adapter.email.0 started with pid 805
                                  2018-06-28 04:02:52.863 - info: host.raspberrypi instance system.adapter.parser.0 started with pid 811
                                  2018-06-28 04:02:52.931 - info: host.raspberrypi instance system.adapter.telegram.0 started with pid 817
                                  2018-06-28 04:02:52.984 - info: host.raspberrypi instance system.adapter.text2command.0 started with pid 823
                                  2018-06-28 04:02:53.148 - info: host.raspberrypi instance system.adapter.mqtt.0 started with pid 829
                                  2018-06-28 04:02:53.258 - info: host.raspberrypi instance system.adapter.simple-api.0 started with pid 835
                                  2018-06-28 04:02:53.357 - info: host.raspberrypi instance system.adapter.mihome.0 started with pid 841
                                  2018-06-28 04:02:54.094 - warn: javascript.0 Reconnection to DB.
                                  2018-06-28 04:02:54.979 - warn: discovery.0 Reconnection to DB.
                                  2018-06-28 04:02:55.004 - warn: fritzbox.0 Reconnection to DB.
                                  2018-06-28 04:02:55.040 - warn: sayit.0 Reconnection to DB.
                                  2018-06-28 04:02:55.013 - warn: discovery.0 Reconnection to DB.
                                  2018-06-28 04:02:55.080 - warn: sayit.0 Reconnection to DB.
                                  2018-06-28 04:02:55.116 - warn: cloud.0 Reconnection to DB.
                                  2018-06-28 04:02:55.118 - warn: fritzdect.0 Reconnection to DB.
                                  2018-06-28 04:02:55.162 - warn: admin.0 Reconnection to DB.
                                  2018-06-28 04:02:55.127 - warn: cloud.0 Reconnection to DB.
                                  2018-06-28 04:02:55.071 - warn: fritzbox.0 Reconnection to DB.
                                  2018-06-28 04:02:55.279 - warn: fritzdect.0 Reconnection to DB.
                                  2018-06-28 04:02:55.234 - warn: admin.0 Reconnection to DB.
                                  2018-06-28 04:02:55.678 - warn: javascript.0 Reconnection to DB.
                                  2018-06-28 04:02:55.938 - error: geofency.0 already running
                                  2018-06-28 04:02:56.071 - error: rpi2.0 already running
                                  2018-06-28 04:02:56.141 - error: cloud.0 already running
                                  2018-06-28 04:02:56.633 - error: host.raspberrypi instance system.adapter.cloud.0 terminated with code 7 (Adapter already running)
                                  2018-06-28 04:02:56.563 - info: sonos.0 starting. Version 1.6.2 in /opt/iobroker/node_modules/iobroker.sonos, node: v6.14.3
                                  2018-06-28 04:02:56.634 - info: host.raspberrypi Restart adapter system.adapter.cloud.0 because enabled
                                  2018-06-28 04:02:56.702 - error: host.raspberrypi instance system.adapter.geofency.0 terminated with code 7 (Adapter already running)
                                  2018-06-28 04:02:56.704 - info: host.raspberrypi Restart adapter system.adapter.geofency.0 because enabled
                                  2018-06-28 04:02:56.787 - error: host.raspberrypi instance system.adapter.rpi2.0 terminated with code 7 (Adapter already running)
                                  2018-06-28 04:02:56.789 - info: host.raspberrypi Restart adapter system.adapter.rpi2.0 because enabled
                                  2018-06-28 04:02:56.939 - info: scenes.0 starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.scenes, node: v6.14.3
                                  2018-06-28 04:02:57.378 - error: sayit.0 already running
                                  2018-06-28 04:02:57.383 - error: discovery.0 already running
                                  2018-06-28 04:02:57.399 - error: admin.0 already running
                                  2018-06-28 04:02:57.441 - error: fritzbox.0 already running
                                  2018-06-28 04:02:57.691 - warn: vis.0 Reconnection to DB.
                                  2018-06-28 04:02:57.698 - warn: vis.0 Reconnection to DB.
                                  2018-06-28 04:02:57.753 - info: sonos.0 starting. Version 1.6.2 in /opt/iobroker/node_modules/iobroker.sonos, node: v6.14.3
                                  2018-06-28 04:02:57.856 - info: sonos.0 http sonos server listening on port 8083
                                  2018-06-28 04:02:57.934 - error: sonos.0 uncaught exception: listen EADDRINUSE :::8083
                                  2018-06-28 04:02:57.946 - error: sonos.0 Error: listen EADDRINUSE :::8083
                                  at Object.exports._errnoException (util.js:1020:11)
                                  at exports._exceptionWithHostPort (util.js:1043:20)
                                  at Server._listen2 (net.js:1271:14)
                                  at listen (net.js:1307:10)
                                  at Server.listen (net.js:1403:5)
                                  at main (/opt/iobroker/node_modules/iobroker.sonos/sonos.js:1923:16)
                                  at Socket. (/opt/iobroker/node_modules/iobroker.sonos/sonos.js:197:13)
                                  at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:319:9)
                                  at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:244:12)
                                  at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                                  at Manager.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
                                  at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:345:8)
                                  at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                                  at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
                                  at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:251:12)
                                  at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:335:16)
                                  2018-06-28 04:02:57.952 - info: sonos.0 terminating
                                  2018-06-28 04:02:58.213 - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
                                  2018-06-28 04:02:58.222 - debug: javascript.0 system.adapter.admin.0: logging false
                                  2018-06-28 04:02:58.373 - info: scenes.0 starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.scenes, node: v6.14.3
                                  2018-06-28 04:02:58.415 - info: sonos.0 terminating
                                  2018-06-28 04:02:59.061 - info: history.0 starting. Version 1.8.4 in /opt/iobroker/node_modules/iobroker.history, node: v6.14.3
                                  2018-06-28 04:02:59.086 - info: vis.0 starting. Version 1.1.4 in /opt/iobroker/node_modules/iobroker.vis, node: v6.14.3
                                  2018-06-28 04:02:59.138 - info: lgtv11.0 starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.lgtv11, node: v6.14.3
                                  2018-06-28 04:02:59.194 - info: lgtv11.0 Ready. Configured LG TV IP: 192.168.178.20, Port: , Pairing Key: 789905
                                  2018-06-28 04:02:59.364 - info: lgtv11.0 starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.lgtv11, node: v6.14.3
                                  2018-06-28 04:02:59.387 - info: lgtv11.0 Ready. Configured LG TV IP: 192.168.178.20, Port: , Pairing Key: 789905
                                  2018-06-28 04:02:58.216 - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
                                  2018-06-28 04:02:58.244 - error: host.raspberrypi instance system.adapter.discovery.0 terminated with code 7 (Adapter already running)
                                  2018-06-28 04:02:58.266 - info: host.raspberrypi Restart adapter system.adapter.discovery.0 because enabled
                                  2018-06-28 04:02:58.292 - error: host.raspberrypi instance system.adapter.fritzbox.0 terminated with code 7 (Adapter already running)
                                  2018-06-28 04:02:58.294 - info: host.raspberrypi Restart adapter system.adapter.fritzbox.0 because enabled
                                  2018-06-28 04:02:58.332 - error: host.raspberrypi instance system.adapter.sayit.0 terminated with code 7 (Adapter already running)
                                  2018-06-28 04:02:58.333 - info: host.raspberrypi Restart adapter system.adapter.sayit.0 because enabled
                                  2018-06-28 04:02:59.231 - info: vis.0 vis license is OK.
                                  2018-06-28 04:03:03.381 - error: Caught by controller[0]: { Error: listen EADDRINUSE :::8083
                                  2018-06-28 04:03:03.382 - error: Caught by controller[0]: at Object.exports._errnoException (util.js:1020:11)
                                  2018-06-28 04:03:03.382 - error: Caught by controller[0]: at exports._exceptionWithHostPort (util.js:1043:20)
                                  2018-06-28 04:03:03.383 - error: Caught by controller[0]: at Server._listen2 (net.js:1271:14)
                                  2018-06-28 04:03:03.383 - error: Caught by controller[0]: at listen (net.js:1307:10)
                                  2018-06-28 04:03:03.384 - error: Caught by controller[0]: at Server.listen (net.js:1403:5)
                                  2018-06-28 04:03:03.384 - error: Caught by controller[0]: at main (/opt/iobroker/node_modules/iobroker.sonos/sonos.js:1923:16)
                                  2018-06-28 04:03:03.384 - error: Caught by controller[0]: at Socket. (/opt/iobroker/node_modules/iobroker.sonos/sonos.js:197:13)
                                  2018-06-28 04:03:03.385 - error: Caught by controller[0]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:319:9)
                                  2018-06-28 04:03:03.385 - error: Caught by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:244:12)
                                  2018-06-28 04:03:03.386 - error: Caught by controller[0]: at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                                  2018-06-28 04:03:03.386 - error: Caught by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
                                  2018-06-28 04:03:03.386 - error: Caught by controller[0]: at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:345:8)
                                  2018-06-28 04:03:03.387 - error: Caught by controller[0]: at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                                  2018-06-28 04:03:03.387 - error: Caught by controller[0]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
                                  2018-06-28 04:03:03.388 - error: Caught by controller[0]: at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:251:12)
                                  2018-06-28 04:03:03.388 - error: Caught by controller[0]: at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:335:16)
                                  2018-06-28 04:03:03.388 - error: Caught by controller[0]: code: 'EADDRINUSE',
                                  2018-06-28 04:03:03.389 - error: Caught by controller[0]: errno: 'EADDRINUSE',
                                  2018-06-28 04:03:03.389 - error: Caught by controller[0]: syscall: 'listen',
                                  2018-06-28 04:03:03.390 - error: Caught by controller[0]: address: '::',
                                  2018-06-28 04:03:03.390 - error: Caught by controller[0]: port: 8083 }
                                  2018-06-28 04:03:03.391 - error: host.raspberrypi instance system.adapter.sonos.0 terminated with code 0 (OK)
                                  2018-06-28 04:03:03.391 - info: host.raspberrypi Restart adapter system.adapter.sonos.0 because enabled
                                  2018-06-28 04:03:03.442 - info: history.0 enabled logging of javascript.0.Stromzähler.Hausstrom.Aktuell_Tag (Count=1), Alias=false
                                  2018-06-28 04:03:03.582 - info: vis.0 starting. Version 1.1.4 in /opt/iobroker/node_modules/iobroker.vis, node: v6.14.3
                                  2018-06-28 04:03:04.445 - info: parser.0 starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.parser, node: v6.14.3
                                  2018-06-28 04:03:03.453 - info: history.0 enabled logging of mihome.0.devices.gateway_7811dcfd6e12.illumination (Count=2), Alias=false
                                  2018-06-28 04:03:03.457 - info: history.0 enabled logging of mihome.0.devices.sensor_motion_aq2_158d000200d283.lux (Count=3), Alias=false
                                  2018-06-28 04:03:08.867 - error: text2command.0 no connection to objects DB
                                  2018-06-28 04:03:10.327 - info: email.0 starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.email, node: v6.14.3
                                  2018-06-28 04:03:10.349 - info: mihome.0 starting. Version 1.0.7 in /opt/iobroker/node_modules/iobroker.mihome, node: v6.14.3
                                  2018-06-28 04:03:10.281 - info: simple-api.0 starting. Version 1.6.3 in /opt/iobroker/node_modules/iobroker.simple-api, node: v6.14.3
                                  2018-06-28 04:03:10.783 - info: vis.0 vis license is OK.
                                  2018-06-28 04:03:10.639 - info: simple-api.0 simpleAPI server listening on port 8087
                                  2018-06-28 04:03:10.643 - info: simple-api.0 Allow states only when user is owner: false
                                  2018-06-28 04:03:10.670 - info: simple-api.0 http server listening on port 8087
                                  2018-06-28 04:03:10.596 - info: mqtt.0 starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.mqtt, node: v6.14.3
                                  2018-06-28 04:03:12.819 - info: mihome.0 Change connection status: false
                                  2018-06-28 04:03:12.924 - info: yr.0 starting. Version 1.0.6 in /opt/iobroker/node_modules/iobroker.yr, node: v6.14.3
                                  2018-06-28 04:03:13.048 - debug: javascript.0 sendTo "send" to system.adapter.telegram.0 from system.adapter.javascript.0
                                  2018-06-28 04:03:13.110 - info: mihome.0 Change connection status: true
                                  2018-06-28 04:03:13.119 - debug: javascript.0 sendTo "send" to system.adapter.telegram.0 from system.adapter.javascript.0
                                  2018-06-28 04:03:13.173 - info: text2command.0 starting. Version 1.2.2 in /opt/iobroker/node_modules/iobroker.text2command, node: v6.14.3
                                  2018-06-28 04:03:13.539 - info: yr.0 got weather data from yr.no
                                  2018-06-28 04:03:13.653 - info: javascript.0 script.js.common.Sonstige.Heizungssteuerung: Heizung - Aussentemperatur liegt bei: 15
                                  2018-06-28 04:03:14.473 - info: mqtt.0 Starting MQTT ' authenticated server on port 1884
                                  2018-06-28 04:03:16.143 - info: fritzdect.0 Comet ID: 109710237552 identified for command (targettemp) : 0
                                  2018-06-28 04:03:16.240 - info: fritzdect.0 Comet ID: 109710237552 identified for command (mode) : 1
                                  2018-06-28 04:03:17.272 - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once
                                  2018-06-28 04:03:22.003 - info: host.raspberrypi instance system.adapter.yr.0 terminated with code 0 (OK)
                                  2018-06-28 04:03:23.466 - info: web.0 socket.io server listening on port 8082
                                  2018-06-28 04:03:23.483 - info: web.0 http server listening on port 8082
                                  2018-06-28 04:03:23.578 - error: web.0 websocket error
                                  2018-06-28 04:03:23.588 - error: web.0 Error: websocket error
                                  at WS.Transport.onError (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:64:13)
                                  at WebSocket.ws.onerror (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:150:10)
                                  at WebSocket.onError (/opt/iobroker/node_modules/ws/lib/EventTarget.js:109:16)
                                  at emitOne (events.js:96:13)
                                  at WebSocket.emit (events.js:188:7)
                                  at WebSocket.finalize (/opt/iobroker/node_modules/ws/lib/WebSocket.js:182:41)
                                  at Socket.emit (events.js:188:7)
                                  at onwriteError (_stream_writable.js:345:10)
                                  at onwrite (_stream_writable.js:363:5)
                                  2018-06-28 04:03:24.576 - warn: web.0 Reconnection to DB.
                                  2018-06-28 04:03:24.583 - warn: web.0 Reconnection to DB.
                                  2018-06-28 04:03:24.633 - info: web.0 starting. Version 2.3.5 in /opt/iobroker/node_modules/iobroker.web, node: v6.14.3
                                  2018-06-28 04:03:24.718 - info: web.0 starting. Version 2.3.5 in /opt/iobroker/node_modules/iobroker.web, node: v6.14.3
                                  2018-06-28 04:03:25.007 - info: web.0 socket.io server listening on port 8082
                                  2018-06-28 04:03:25.110 - info: web.0 socket.io server listening on port 8082
                                  2018-06-28 04:03:25.164 - error: host.raspberrypi instance system.adapter.web.0 terminated with code 1 ()
                                  2018-06-28 04:03:25.165 - info: host.raspberrypi Restart adapter system.adapter.web.0 because enabled
                                  2018-06-28 04:03:26.707 - info: host.raspberrypi instance system.adapter.cloud.0 started with pid 871
                                  2018-06-28 04:03:26.741 - info: host.raspberrypi instance system.adapter.geofency.0 started with pid 877
                                  2018-06-28 04:03:26.818 - info: host.raspberrypi instance system.adapter.rpi2.0 started with pid 883
                                  2018-06-28 04:03:29.710 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 889
                                  2018-06-28 04:03:29.742 - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 895
                                  2018-06-28 04:03:29.774 - info: host.raspberrypi instance system.adapter.fritzbox.0 started with pid 901
                                  2018-06-28 04:03:29.849 - info: host.raspberrypi instance system.adapter.sayit.0 started with pid 902
                                  2018-06-28 04:03:31.303 - info: geofency.0 starting. Version 0.3.2 in /opt/iobroker/node_modules/iobroker.geofency, node: v6.14.3
                                  2018-06-28 04:03:31.396 - info: geofency.0 Adapter got 'Ready' Signal - initiating Main function...
                                  2018-06-28 04:03:31.509 - info: geofency.0 http server listening on port 7999
                                  2018-06-28 04:03:31.434 - info: rpi2.0 starting. Version 0.3.2 in /opt/iobroker/node_modules/iobroker.rpi2, node: v6.14.3
                                  2018-06-28 04:03:34.365 - info: host.raspberrypi instance system.adapter.sonos.0 started with pid 921
                                  2018-06-28 04:03:35.418 - info: cloud.0 starting. Version 2.6.2 in /opt/iobroker/node_modules/iobroker.cloud, node: v6.14.3
                                  2018-06-28 04:03:36.617 - info: cloud.0 Connecting with https://iobroker.net:10555 with "i*************"
                                  2018-06-28 04:03:36.764 - info: sayit.0 starting. Version 1.6.8 in /opt/iobroker/node_modules/iobroker.sayit, node: v6.14.3
                                  2018-06-28 04:03:36.854 - info: sayit.0 Upload announce mp3 files
                                  2018-06-28 04:03:36.952 - info: discovery.0 starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.discovery, node: v6.14.3
                                  2018-06-28 04:03:37.222 - error: telegram.0 no connection to objects DB
                                  2018-06-28 04:03:37.866 - info: sayit.0 All files uploaded
                                  2018-06-28 04:03:38.444 - info: cloud.0 Trying to connect as system.user.admin
                                  2018-06-28 04:03:38.127 - info: fritzbox.0 starting. Version 0.2.1 in /opt/iobroker/node_modules/iobroker.fritzbox, node: v6.14.3
                                  2018-06-28 04:03:38.223 - info: fritzbox.0 try to connect: 192.168.178.1
                                  2018-06-28 04:03:38.426 - info: fritzbox.0 adapter connected to fritzbox: 192.168.178.1
                                  2018-06-28 04:03:38.818 - info: admin.0 starting. Version 3.4.7 in /opt/iobroker/node_modules/iobroker.admin, node: v6.14.3
                                  2018-06-28 04:03:38.890 - info: admin.0 requesting all states
                                  2018-06-28 04:03:38.900 - info: admin.0 requesting all objects
                                  2018-06-28 04:03:38.905 - info: admin.0 Request actual repository...
                                  2018-06-28 04:03:41.253 - info: telegram.0 starting. Version 1.2.4 in /opt/iobroker/node_modules/iobroker.telegram, node: v6.14.3
                                  2018-06-28 04:03:41.446 - info: admin.0 received all states
                                  2018-06-28 04:03:42.071 - info: telegram.0 getMe: {"id":556776579,"is_bot":true,"first_name":"SperberBot","username":"SperberBot"}
                                  2018-06-28 04:03:41.796 - info: sonos.0 starting. Version 1.6.2 in /opt/iobroker/node_modules/iobroker.sonos, node: v6.14.3
                                  2018-06-28 04:03:42.058 - info: sonos.0 http sonos server listening on port 8083
                                  2018-06-28 04:03:42.188 - error: cloud.0 Cloud says: timeout
                                  2018-06-28 04:03:43.202 - info: cloud.0 Connection changed: io server disconnect
                                  2018-06-28 04:03:44.272 - info: rpi2.0 GPIO ports are not configured
                                  2018-06-28 04:03:45.376 - info: admin.0 received all objects
                                  2018-06-28 04:03:45.732 - info: admin.0 http server listening on port 8081
                                  2018-06-28 04:03:45.733 - info: admin.0 Use link "http://localhost:8081" to configure.
                                  2018-06-28 04:03:46.274 - info: host.raspberrypi Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
                                  2018-06-28 04:03:49.154 - info: admin.0 Repository received successfully.
                                  2018-06-28 04:03:55.237 - info: host.raspberrypi instance system.adapter.web.0 started with pid 991
                                  2018-06-28 04:03:58.826 - info: web.0 starting. Version 2.3.5 in /opt/iobroker/node_modules/iobroker.web, node: v6.14.3
                                  2018-06-28 04:03:59.834 - info: web.0 socket.io server listening on port 8082
                                  2018-06-28 04:03:59.848 - info: web.0 http server listening on port 8082
                                  2018-06-28 04:04:36.733 - info: cloud.0 Trying to connect as system.user.admin
                                  2018-06-28 04:04:36.858 - info: cloud.0 Adapter redirected temporally to "https://iobroker.net:10560" in one minute. Reason: command from server
                                  2018-06-28 04:04:36.862 - info: cloud.0 Connection changed: io client disconnect
                                  2018-06-28 04:05:36.892 - info: cloud.0 Trying to connect as system.user.admin
                                  2018-06-28 04:05:37.020 - info: cloud.0 Connection changed: connect
                                  • apollon77A Offline
                                    aaaahhhh … now I see ...
                                    was läuft denn so neben ioBroker noch auf dem Host?
                                    Also was passiert ist das scheinbar bei einem Reboot und dann dem Start der ganzen Adapter (33 Stück bei dir!!) ich tippe die CPU an ihre grenzen stösst und damit das Starten der Adapter länger dauert. So lange das die nach dem Connect zur State/Objects-DB verlieren bzw der "20 Sekunden Keepalive-check" nicht klappt. Damit wird reconnected und das startet plötzlich die Adapter nochmal neu und dann kommen komische Dinge.
                                    Wie "am limit" ist denn das system lso als Raspi mit 33 Instanzen?
                                    • L Offline
                                      LJSven
                                      Ich habe das komplett neu aufgesetzt.
                                      Raspberry mit Stretch Lite & iobroker. Das ist alles. Anschließend habe ich ein Backup vom iobroker eingespielt. Sonst habe ich auf dem Raspberry nichts installiert.
                                      • L Offline
                                        LJSven
                                        Sind 33 Instanzen viel? Soll ich welche löschen?
                                          Kommt aufs ein System an.
                                          Wenn alles gut läuft wieviel Speicher hat das System so frei? Was sagt „top“?
                                          Gesendet vom Handy …
