  4. Test Adapter Sprinkle Control 0.2.x mit neuen Funktionen
    6.6k
bodenfeuchte-sensorengartenbewässerungsprinkle controlwetterabhängig
314 Beiträge 43 Kommentatoren 79.9k Aufrufe 42 Beobachtet
  • sigi234S sigi234
    @dirk-peter sagte in Test Adapter Sprinkle Control mit neuen Funktionen:
    @martybr - 0.2.4 ist on, - hoffe das ich nichts übersehen habe, Dirk Peter
    sprinklecontrol.0
    2021-08-15 18:00:36.206	info	State value to set for "sprinklecontrol.0.sprinkle.Ventil_6.triggerPoint" has to be type "string" but received type "boolean"
    sprinklecontrol.0
    2021-08-15 18:00:36.206	info	State value to set for "sprinklecontrol.0.sprinkle.Ventil_5.triggerPoint" has to be type "string" but received type "boolean"
    sprinklecontrol.0
    2021-08-15 18:00:36.204	info	State value to set for "sprinklecontrol.0.sprinkle.Ventil_4.triggerPoint" has to be type "string" but received type "boolean"
    sprinklecontrol.0
    2021-08-15 18:00:36.203	info	State value to set for "sprinklecontrol.0.sprinkle.Ventil_3.triggerPoint" has to be type "string" but received type "boolean"
    sprinklecontrol.0
    2021-08-15 18:00:36.202	info	State value to set for "sprinklecontrol.0.sprinkle.Ventil_2.triggerPoint" has to be type "string" but received type "boolean"
    sprinklecontrol.0
    2021-08-15 18:00:36.201	info	State value to set for "sprinklecontrol.0.sprinkle.Ventil_1.triggerPoint" has to be type "string" but received type "boolean"
    sprinklecontrol.0
    2021-08-15 18:00:35.165	info	setSoilMoistPct - analog: Ventil_1 .pst: 100
    sprinklecontrol.0
    2021-08-15 18:00:35.165	warn	Ventil_1: analog soil moisture sensor at 100 % => The range of values has been exceeded
    sprinklecontrol.0
    2021-08-15 18:00:35.165	info	setSoilMoistPct, Ventil_1 => analog, newVal: 20
    sprinklecontrol.0
    2021-08-15 18:00:35.164	info	filter analog: Ventil_1, state: 20
    sprinklecontrol.0
    2021-08-15 18:00:33.223	info	#1.0 => Set ID: Ventil_6(5) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":true,"autoOn":true,"autoOnID":"sprinklecontrol.0.sprinkle.Ventil_6.autoOn","objectName":"Ventil_6","objectID":"sprinklecontrol.0.sprinkle.Ventil_6.runningTime","idState":"0_userdata.0.Garten.Ventil_6","updateStateTimerID":null,"sprinkleID":5,"wateringTime":10,"wateringAdd":200,"wateringInterval":0,"pipeFlow":700,"methodControlSM":"calculation","triggerSM":"","inGreenhouse":false,"analogZPct":null,"analogOHPct":null,"soilMoisture":{"val":4,"pct":50,"bool":null,"min":0.08,"maxIrrigation":8,"maxRain":10,"triggersIrrigation":4,"pctTriggerIrrigation":50}}
    sprinklecontrol.0
    2021-08-15 18:00:33.223	info	#1.0 => Set ID: Ventil_5(4) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":true,"autoOn":true,"autoOnID":"sprinklecontrol.0.sprinkle.Ventil_5.autoOn","objectName":"Ventil_5","objectID":"sprinklecontrol.0.sprinkle.Ventil_5.runningTime","idState":"0_userdata.0.Garten.Ventil_5","updateStateTimerID":null,"sprinkleID":4,"wateringTime":10,"wateringAdd":200,"wateringInterval":0,"pipeFlow":700,"methodControlSM":"calculation","triggerSM":"","inGreenhouse":false,"analogZPct":null,"analogOHPct":null,"soilMoisture":{"val":4,"pct":50,"bool":null,"min":0.08,"maxIrrigation":8,"maxRain":10,"triggersIrrigation":4,"pctTriggerIrrigation":50}}
    sprinklecontrol.0
    2021-08-15 18:00:33.222	info	#1.0 => Set ID: Ventil_4(3) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":true,"autoOn":true,"autoOnID":"sprinklecontrol.0.sprinkle.Ventil_4.autoOn","objectName":"Ventil_4","objectID":"sprinklecontrol.0.sprinkle.Ventil_4.runningTime","idState":"0_userdata.0.Garten.Ventil_4","updateStateTimerID":null,"sprinkleID":3,"wateringTime":10,"wateringAdd":200,"wateringInterval":0,"pipeFlow":700,"methodControlSM":"calculation","triggerSM":"","inGreenhouse":false,"analogZPct":null,"analogOHPct":null,"soilMoisture":{"val":4,"pct":50,"bool":null,"min":0.08,"maxIrrigation":8,"maxRain":10,"triggersIrrigation":4,"pctTriggerIrrigation":50}}
    sprinklecontrol.0
    2021-08-15 18:00:33.222	info	#1.0 => Set ID: Ventil_3(2) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":true,"autoOn":true,"autoOnID":"sprinklecontrol.0.sprinkle.Ventil_3.autoOn","objectName":"Ventil_3","objectID":"sprinklecontrol.0.sprinkle.Ventil_3.runningTime","idState":"0_userdata.0.Garten.Ventil_3","updateStateTimerID":null,"sprinkleID":2,"wateringTime":10,"wateringAdd":200,"wateringInterval":0,"pipeFlow":700,"methodControlSM":"calculation","triggerSM":"","inGreenhouse":false,"analogZPct":null,"analogOHPct":null,"soilMoisture":{"val":4,"pct":50,"bool":null,"min":0.08,"maxIrrigation":8,"maxRain":10,"triggersIrrigation":4,"pctTriggerIrrigation":50}}
    sprinklecontrol.0
    2021-08-15 18:00:33.221	info	#1.0 => Set ID: Ventil_2(1) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":true,"autoOn":true,"autoOnID":"sprinklecontrol.0.sprinkle.Ventil_2.autoOn","objectName":"Ventil_2","objectID":"sprinklecontrol.0.sprinkle.Ventil_2.runningTime","idState":"0_userdata.0.Garten.Ventil_2","updateStateTimerID":null,"sprinkleID":1,"wateringTime":10,"wateringAdd":200,"wateringInterval":0,"pipeFlow":700,"methodControlSM":"calculation","triggerSM":"","inGreenhouse":false,"analogZPct":null,"analogOHPct":null,"soilMoisture":{"val":4,"pct":50,"bool":null,"min":0.08,"maxIrrigation":8,"maxRain":10,"triggersIrrigation":4,"pctTriggerIrrigation":50}}
    sprinklecontrol.0
    2021-08-15 18:00:33.221	info	#1.0 => Set ID: Ventil_1(0) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":true,"autoOn":true,"autoOnID":"sprinklecontrol.0.sprinkle.Ventil_1.autoOn","objectName":"Ventil_1","objectID":"sprinklecontrol.0.sprinkle.Ventil_1.runningTime","idState":"0_userdata.0.Garten.Ventil_1","updateStateTimerID":null,"sprinkleID":0,"wateringTime":10,"wateringAdd":200,"wateringInterval":0,"pipeFlow":1100,"methodControlSM":"analog","triggerSM":"0_userdata.0.Bewaesserungssensor.Sensor1","inGreenhouse":false,"analogZPct":2,"analogOHPct":5,"soilMoisture":{"val":null,"pct":null,"bool":null,"min":0.08,"maxIrrigation":8,"maxRain":10,"triggersIrrigation":4,"pctTriggerIrrigation":50}}
    sprinklecontrol.0
    2021-08-15 18:00:33.143	info	starting. Version 0.2.4 in C:/Program Files/iobroker/Home/node_modules/iobroker.sprinklecontrol, node: v12.22.5, js-controller: 3.3.15
    Dirk PeterD Offline
    Dirk PeterD Offline
    Dirk Peter
    #81
    @sigi234 sagte in Test Adapter Sprinkle Control mit neuen Funktionen:
    Kann ich mir nicht erklären. Schreibe eindeutig in 'string', habe eine issues im js-controller eröffnet.
    M sigi234S 2 Antworten Letzte Antwort
    • Dirk PeterD Dirk Peter
      MartyBr
      #82
      @dirk-peter
      Das Log sieht bei mir sauber aus:
      sprinklecontrol.0
      2021-08-15 20:40:10.340	info	setSoilMoistPct - analog: Rasen_West .pst: 77
      sprinklecontrol.0
      2021-08-15 20:40:10.339	info	setSoilMoistPct, Rasen_West => analog, newVal: 77
      sprinklecontrol.0
      2021-08-15 20:40:10.339	info	setSoilMoistPct - analog: Rasen_West .pst: 77
      sprinklecontrol.0
      sprinklecontrol.0
      sprinklecontrol.0
      2021-08-15 20:40:10.338	info	setSoilMoistPct, Rasen_West => analog, newVal: 77
      sprinklecontrol.0
      2021-08-15 20:40:10.338	info	setSoilMoistPct - analog: Rasen_West .pst: 77
      sprinklecontrol.0
      sprinklecontrol.0
      sprinklecontrol.0
      sprinklecontrol.0
      sprinklecontrol.0
      2021-08-15 20:40:10.337	info	setSoilMoistPct, Rasen_West => analog, newVal: 77
      sprinklecontrol.0
      2021-08-15 20:31:44.667	info	setSoilMoistPct - analog: Hecke_und_Rosen .pst: 98
      sprinklecontrol.0
      2021-08-15 20:31:44.667	info	setSoilMoistPct, Hecke_und_Rosen => analog, newVal: 98
      sprinklecontrol.0
      2021-08-15 20:31:44.667	info	filter analog: Hecke_und_Rosen, state: 98
      sprinklecontrol.0
      2021-08-15 20:31:44.667	info	setSoilMoistPct - analog: Rasen_Ost .pst: 98
      sprinklecontrol.0
      2021-08-15 20:31:44.667	info	setSoilMoistPct, Rasen_Ost => analog, newVal: 98
      sprinklecontrol.0
      2021-08-15 20:31:44.667	info	filter analog: Rasen_Ost, state: 98
      sprinklecontrol.0
      2021-08-15 20:31:44.667	info	setSoilMoistPct - analog: Rasen_Süd-Ost .pst: 98
      sprinklecontrol.0
      2021-08-15 20:31:44.667	info	setSoilMoistPct, Rasen_Süd-Ost => analog, newVal: 98
      sprinklecontrol.0
      2021-08-15 20:31:44.666	info	filter analog: Rasen_Süd-Ost, state: 98
      sprinklecontrol.0
      2021-08-15 20:31:44.666	info	setSoilMoistPct - analog: Rasen_Süd .pst: 98
      sprinklecontrol.0
      2021-08-15 20:31:44.666	info	setSoilMoistPct, Rasen_Süd => analog, newVal: 98
      sprinklecontrol.0
      2021-08-15 20:31:44.666	info	filter analog: Rasen_Süd, state: 98
      sprinklecontrol.0
      2021-08-15 20:31:44.664	info	setSoilMoistPct - analog: Rasen_Süd-West .pst: 98
      sprinklecontrol.0
      2021-08-15 20:31:44.663	info	setSoilMoistPct, Rasen_Süd-West => analog, newVal: 98
      sprinklecontrol.0
      2021-08-15 20:31:44.663	info	filter analog: Rasen_Süd-West, state: 98
      sprinklecontrol.0
      2021-08-15 20:31:44.663	info	setSoilMoistPct - analog: Rasen_West .pst: 98
      sprinklecontrol.0
      2021-08-15 20:31:44.663	info	setSoilMoistPct, Rasen_West => analog, newVal: 98
      sprinklecontrol.0
      2021-08-15 20:31:44.661	info	filter analog: Rasen_West, state: 98
      sprinklecontrol.0
      2021-08-15 20:31:42.668	info	#1.0 => Set ID: Hecke_und_Rosen(5) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":true,"autoOn":true,"autoOnID":"sprinklecontrol.0.sprinkle.Hecke_und_Rosen.autoOn","objectName":"Hecke_und_Rosen","objectID":"sprinklecontrol.0.sprinkle.Hecke_und_Rosen.runningTime","idState":"hm-rpc.1.OEQ0205713.6.STATE","updateStateTimerID":null,"sprinkleID":5,"wateringTime":40,"wateringAdd":100,"wateringInterval":0,"pipeFlow":700,"methodControlSM":"analog","triggerSM":"alias.0.Garten.Feuchtigkeitssensor.Rasen-Sensor1","inGreenhouse":false,"analogZPct":0,"analogOHPct":100,"soilMoisture":{"val":null,"pct":null,"bool":null,"min":0.08,"maxIrrigation":8,"maxRain":10,"triggersIrrigation":6.4,"pctTriggerIrrigation":80}}
      sprinklecontrol.0
      2021-08-15 20:31:42.668	info	#1.0 => Set ID: Rasen_Ost(4) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":false,"autoOn":true,"autoOnID":"sprinklecontrol.0.sprinkle.Rasen_Ost.autoOn","objectName":"Rasen_Ost","objectID":"sprinklecontrol.0.sprinkle.Rasen_Ost.runningTime","idState":"hm-rpc.1.OEQ0205713.4.STATE","updateStateTimerID":null,"sprinkleID":4,"wateringTime":30,"wateringAdd":100,"wateringInterval":0,"pipeFlow":700,"methodControlSM":"analog","triggerSM":"alias.0.Garten.Feuchtigkeitssensor.Rasen-Sensor1","inGreenhouse":false,"analogZPct":0,"analogOHPct":100,"soilMoisture":{"val":null,"pct":null,"bool":null,"min":0.08,"maxIrrigation":8,"maxRain":10,"triggersIrrigation":6.4,"pctTriggerIrrigation":80}}
      sprinklecontrol.0
      2021-08-15 20:31:42.667	info	#1.0 => Set ID: Rasen_Süd-Ost(3) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":false,"autoOn":true,"autoOnID":"sprinklecontrol.0.sprinkle.Rasen_Süd-Ost.autoOn","objectName":"Rasen_Süd-Ost","objectID":"sprinklecontrol.0.sprinkle.Rasen_Süd-Ost.runningTime","idState":"hm-rpc.1.OEQ0205713.5.STATE","updateStateTimerID":null,"sprinkleID":3,"wateringTime":30,"wateringAdd":100,"wateringInterval":0,"pipeFlow":700,"methodControlSM":"analog","triggerSM":"alias.0.Garten.Feuchtigkeitssensor.Rasen-Sensor1","inGreenhouse":false,"analogZPct":0,"analogOHPct":100,"soilMoisture":{"val":null,"pct":null,"bool":null,"min":0.08,"maxIrrigation":8,"maxRain":10,"triggersIrrigation":6.4,"pctTriggerIrrigation":80}}
      sprinklecontrol.0
      2021-08-15 20:31:42.666	info	#1.0 => Set ID: Rasen_Süd(2) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":false,"autoOn":true,"autoOnID":"sprinklecontrol.0.sprinkle.Rasen_Süd.autoOn","objectName":"Rasen_Süd","objectID":"sprinklecontrol.0.sprinkle.Rasen_Süd.runningTime","idState":"hm-rpc.1.OEQ0205713.7.STATE","updateStateTimerID":null,"sprinkleID":2,"wateringTime":30,"wateringAdd":100,"wateringInterval":0,"pipeFlow":700,"methodControlSM":"analog","triggerSM":"alias.0.Garten.Feuchtigkeitssensor.Rasen-Sensor1","inGreenhouse":false,"analogZPct":0,"analogOHPct":100,"soilMoisture":{"val":null,"pct":null,"bool":null,"min":0.08,"maxIrrigation":8,"maxRain":10,"triggersIrrigation":6.4,"pctTriggerIrrigation":80}}
      sprinklecontrol.0
      2021-08-15 20:31:42.666	info	#1.0 => Set ID: Rasen_Süd-West(1) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":false,"autoOn":true,"autoOnID":"sprinklecontrol.0.sprinkle.Rasen_Süd-West.autoOn","objectName":"Rasen_Süd-West","objectID":"sprinklecontrol.0.sprinkle.Rasen_Süd-West.runningTime","idState":"hm-rpc.1.OEQ0205713.2.STATE","updateStateTimerID":null,"sprinkleID":1,"wateringTime":30,"wateringAdd":100,"wateringInterval":0,"pipeFlow":700,"methodControlSM":"analog","triggerSM":"alias.0.Garten.Feuchtigkeitssensor.Rasen-Sensor1","inGreenhouse":false,"analogZPct":0,"analogOHPct":100,"soilMoisture":{"val":null,"pct":null,"bool":null,"min":0.08,"maxIrrigation":8,"maxRain":10,"triggersIrrigation":6.4,"pctTriggerIrrigation":80}}
      sprinklecontrol.0
      2021-08-15 20:31:42.665	info	#1.0 => Set ID: Rasen_West(0) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":false,"autoOn":true,"autoOnID":"sprinklecontrol.0.sprinkle.Rasen_West.autoOn","objectName":"Rasen_West","objectID":"sprinklecontrol.0.sprinkle.Rasen_West.runningTime","idState":"hm-rpc.1.OEQ0205713.1.STATE","updateStateTimerID":null,"sprinkleID":0,"wateringTime":30,"wateringAdd":100,"wateringInterval":0,"pipeFlow":700,"methodControlSM":"analog","triggerSM":"alias.0.Garten.Feuchtigkeitssensor.Rasen-Sensor1","inGreenhouse":false,"analogZPct":0,"analogOHPct":100,"soilMoisture":{"val":null,"pct":null,"bool":null,"min":0.08,"maxIrrigation":8,"maxRain":10,"triggersIrrigation":6.4,"pctTriggerIrrigation":80}}
      sprinklecontrol.0
      2021-08-15 20:31:42.638	info	starting. Version 0.2.4 in /opt/iobroker/node_modules/iobroker.sprinklecontrol, node: v12.22.4, js-controller: 3.3.15
      sprinklecontrol.0
      2021-08-15 20:31:38.677	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      sprinklecontrol.0
      2021-08-15 20:31:38.677	info	terminating
      sprinklecontrol.0
      2021-08-15 20:31:38.676	info	cleaned everything up...
      sprinklecontrol.0
      2021-08-15 20:31:38.675	info	Got terminate signal TERMINATE_YOURSELF
      sprinklecontrol.0
      2021-08-15 20:30:17.969	info	getTelegramUser:{"1234567890":{"firstName":"mmmmm","userName":"xxxxxxx"}}
      sprinklecontrol.0
      2021-08-15 20:05:30.506	info	setSoilMoistPct - analog: Rasen_West .pst: 100
      sprinklecontrol.0
      2021-08-15 20:05:30.505	info	setSoilMoistPct - analog: Rasen_West .pst: 100
      sprinklecontrol.0
      sprinklecontrol.0
      sprinklecontrol.0
      sprinklecontrol.0
      2021-08-15 20:05:30.505	info	setSoilMoistPct, Rasen_West => analog, newVal: 100
      sprinklecontrol.0
      sprinklecontrol.0
      sprinklecontrol.0
      sprinklecontrol.0
      Martin
      Intel NUCs mit Proxmox / Iobroker als VM unter Debian
      Raspeberry mit USB Leseköpfen für Smartmeter
      Homematic und Homematic IP
      Dirk PeterD 1 Antwort Letzte Antwort
      • sigi234S sigi234
        sprinklecontrol.0
        sprinklecontrol.0
        sprinklecontrol.0
        sprinklecontrol.0
        sprinklecontrol.0
        sprinklecontrol.0
        sprinklecontrol.0
        sprinklecontrol.0
        sprinklecontrol.0
        sprinklecontrol.0
        sprinklecontrol.0
        sprinklecontrol.0
        sprinklecontrol.0
        sprinklecontrol.0
        sprinklecontrol.0
        sprinklecontrol.0
        sprinklecontrol.0
        Dirk PeterD Offline
        Dirk PeterD Offline
        Dirk Peter
        #83
        Dein Sensor ist nicht richtig konfiguriert, der Wert ist über 100% und wurde auf 100% zurück gesetzt. Daher die Warnung.
        • M MartyBr
          @dirk-peter
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          sprinklecontrol.0
          Dirk PeterD Offline
          Dirk PeterD Offline
          Dirk Peter
          #84
          @martybr schön, das freut mich. :)
            sigi234S Online
            sigi234S Online
            sigi234
            #85
            Was ist Falsch eingestellt?
            sprinklecontrol.0
            2021-08-15 21:23:32.441	info	setSoilMoistPct - analog: Ventil_6 .pst: 100
            sprinklecontrol.0
            2021-08-15 21:23:32.441	warn	Ventil_6: analog soil moisture sensor at 100 % => The range of values has been exceeded
            sprinklecontrol.0
            2021-08-15 21:23:32.441	info	setSoilMoistPct, Ventil_6 => analog, newVal: 20
            sprinklecontrol.0
            2021-08-15 21:23:32.440	info	filter analog: Ventil_6, state: 20
            sprinklecontrol.0
            2021-08-15 21:23:32.440	info	setSoilMoistPct - analog: Ventil_5 .pst: 100
            sprinklecontrol.0
            2021-08-15 21:23:32.439	warn	Ventil_5: analog soil moisture sensor at 100 % => The range of values has been exceeded
            sprinklecontrol.0
            2021-08-15 21:23:32.439	info	setSoilMoistPct, Ventil_5 => analog, newVal: 20
            sprinklecontrol.0
            2021-08-15 21:23:32.439	info	filter analog: Ventil_5, state: 20
            sprinklecontrol.0
            2021-08-15 21:23:32.439	info	setSoilMoistPct - analog: Ventil_4 .pst: 100
            sprinklecontrol.0
            2021-08-15 21:23:32.439	warn	Ventil_4: analog soil moisture sensor at 100 % => The range of values has been exceeded
            sprinklecontrol.0
            2021-08-15 21:23:32.439	info	setSoilMoistPct, Ventil_4 => analog, newVal: 20
            sprinklecontrol.0
            2021-08-15 21:23:32.438	info	filter analog: Ventil_4, state: 20
            sprinklecontrol.0
            2021-08-15 21:23:32.438	info	setSoilMoistPct - analog: Ventil_3 .pst: 100
            sprinklecontrol.0
            2021-08-15 21:23:32.438	warn	Ventil_3: analog soil moisture sensor at 100 % => The range of values has been exceeded
            sprinklecontrol.0
            2021-08-15 21:23:32.438	info	setSoilMoistPct, Ventil_3 => analog, newVal: 20
            sprinklecontrol.0
            2021-08-15 21:23:32.438	info	filter analog: Ventil_3, state: 20
            sprinklecontrol.0
            2021-08-15 21:23:32.437	info	setSoilMoistPct - analog: Ventil_2 .pst: 100
            sprinklecontrol.0
            2021-08-15 21:23:32.437	warn	Ventil_2: analog soil moisture sensor at 100 % => The range of values has been exceeded
            sprinklecontrol.0
            2021-08-15 21:23:32.437	info	setSoilMoistPct, Ventil_2 => analog, newVal: 20
            sprinklecontrol.0
            2021-08-15 21:23:32.437	info	filter analog: Ventil_2, state: 20
            sprinklecontrol.0
            2021-08-15 21:23:32.436	info	setSoilMoistPct - analog: Ventil_1 .pst: 100
            sprinklecontrol.0
            2021-08-15 21:23:32.436	warn	Ventil_1: analog soil moisture sensor at 100 % => The range of values has been exceeded
            sprinklecontrol.0
            2021-08-15 21:23:32.435	info	setSoilMoistPct, Ventil_1 => analog, newVal: 20
            sprinklecontrol.0
            2021-08-15 21:23:32.434	info	filter analog: Ventil_1, state: 20
            sprinklecontrol.0
            2021-08-15 21:23:30.316	info	#1.0 => Set ID: Ventil_6(5) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":true,"autoOn":true,"autoOnID":"sprinklecontrol.0.sprinkle.Ventil_6.autoOn","objectName":"Ventil_6","objectID":"sprinklecontrol.0.sprinkle.Ventil_6.runningTime","idState":"0_userdata.0.Garten.Ventil_6","updateStateTimerID":null,"sprinkleID":5,"wateringTime":10,"wateringAdd":200,"wateringInterval":0,"pipeFlow":700,"methodControlSM":"analog","triggerSM":"0_userdata.0.Bewaesserungssensor.Sensor6","inGreenhouse":false,"analogZPct":8,"analogOHPct":10,"soilMoisture":{"val":null,"pct":null,"bool":null,"min":0.08,"maxIrrigation":8,"maxRain":10,"triggersIrrigation":4,"pctTriggerIrrigation":50}}
            sprinklecontrol.0
            2021-08-15 21:23:30.315	info	#1.0 => Set ID: Ventil_5(4) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":true,"autoOn":true,"autoOnID":"sprinklecontrol.0.sprinkle.Ventil_5.autoOn","objectName":"Ventil_5","objectID":"sprinklecontrol.0.sprinkle.Ventil_5.runningTime","idState":"0_userdata.0.Garten.Ventil_5","updateStateTimerID":null,"sprinkleID":4,"wateringTime":10,"wateringAdd":200,"wateringInterval":0,"pipeFlow":700,"methodControlSM":"analog","triggerSM":"0_userdata.0.Bewaesserungssensor.Sensor5","inGreenhouse":false,"analogZPct":8,"analogOHPct":10,"soilMoisture":{"val":null,"pct":null,"bool":null,"min":0.08,"maxIrrigation":8,"maxRain":10,"triggersIrrigation":4,"pctTriggerIrrigation":50}}
            sprinklecontrol.0
            2021-08-15 21:23:30.315	info	#1.0 => Set ID: Ventil_4(3) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":true,"autoOn":true,"autoOnID":"sprinklecontrol.0.sprinkle.Ventil_4.autoOn","objectName":"Ventil_4","objectID":"sprinklecontrol.0.sprinkle.Ventil_4.runningTime","idState":"0_userdata.0.Garten.Ventil_4","updateStateTimerID":null,"sprinkleID":3,"wateringTime":10,"wateringAdd":200,"wateringInterval":0,"pipeFlow":700,"methodControlSM":"analog","triggerSM":"0_userdata.0.Bewaesserungssensor.Sensor4","inGreenhouse":false,"analogZPct":8,"analogOHPct":10,"soilMoisture":{"val":null,"pct":null,"bool":null,"min":0.08,"maxIrrigation":8,"maxRain":10,"triggersIrrigation":4,"pctTriggerIrrigation":50}}
            sprinklecontrol.0
            2021-08-15 21:23:30.314	info	#1.0 => Set ID: Ventil_3(2) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":true,"autoOn":true,"autoOnID":"sprinklecontrol.0.sprinkle.Ventil_3.autoOn","objectName":"Ventil_3","objectID":"sprinklecontrol.0.sprinkle.Ventil_3.runningTime","idState":"0_userdata.0.Garten.Ventil_3","updateStateTimerID":null,"sprinkleID":2,"wateringTime":10,"wateringAdd":200,"wateringInterval":0,"pipeFlow":700,"methodControlSM":"analog","triggerSM":"0_userdata.0.Bewaesserungssensor.Sensor3","inGreenhouse":false,"analogZPct":8,"analogOHPct":10,"soilMoisture":{"val":null,"pct":null,"bool":null,"min":0.08,"maxIrrigation":8,"maxRain":10,"triggersIrrigation":4,"pctTriggerIrrigation":50}}
            sprinklecontrol.0
            2021-08-15 21:23:30.314	info	#1.0 => Set ID: Ventil_2(1) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":true,"autoOn":true,"autoOnID":"sprinklecontrol.0.sprinkle.Ventil_2.autoOn","objectName":"Ventil_2","objectID":"sprinklecontrol.0.sprinkle.Ventil_2.runningTime","idState":"0_userdata.0.Garten.Ventil_2","updateStateTimerID":null,"sprinkleID":1,"wateringTime":10,"wateringAdd":200,"wateringInterval":0,"pipeFlow":700,"methodControlSM":"analog","triggerSM":"0_userdata.0.Bewaesserungssensor.Sensor2","inGreenhouse":false,"analogZPct":8,"analogOHPct":10,"soilMoisture":{"val":null,"pct":null,"bool":null,"min":0.08,"maxIrrigation":8,"maxRain":10,"triggersIrrigation":4,"pctTriggerIrrigation":50}}
            sprinklecontrol.0
            2021-08-15 21:23:30.313	info	#1.0 => Set ID: Ventil_1(0) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":true,"autoOn":true,"autoOnID":"sprinklecontrol.0.sprinkle.Ventil_1.autoOn","objectName":"Ventil_1","objectID":"sprinklecontrol.0.sprinkle.Ventil_1.runningTime","idState":"0_userdata.0.Garten.Ventil_1","updateStateTimerID":null,"sprinkleID":0,"wateringTime":10,"wateringAdd":200,"wateringInterval":0,"pipeFlow":1100,"methodControlSM":"analog","triggerSM":"0_userdata.0.Bewaesserungssensor.Sensor1","inGreenhouse":false,"analogZPct":8,"analogOHPct":10,"soilMoisture":{"val":null,"pct":null,"bool":null,"min":0.08,"maxIrrigation":8,"maxRain":10,"triggersIrrigation":4,"pctTriggerIrrigation":50}}
            sprinklecontrol.0
            2021-08-15 21:23:30.287	info	starting. Version 0.2.4 in C:/Program Files/iobroker/Home/node_modules/iobroker.sprinklecontrol, node: v12.22.5, js-controller: 3.3.15
            Immer Daten sichern!
            • sigi234S sigi234
              sprinklecontrol.0
              sprinklecontrol.0
              sprinklecontrol.0
              sprinklecontrol.0
              sprinklecontrol.0
              sprinklecontrol.0
              sprinklecontrol.0
              sprinklecontrol.0
              sprinklecontrol.0
              sprinklecontrol.0
              sprinklecontrol.0
              sprinklecontrol.0
              sprinklecontrol.0
              sprinklecontrol.0
              sprinklecontrol.0
              sprinklecontrol.0
              sprinklecontrol.0
              sprinklecontrol.0
              sprinklecontrol.0
              sprinklecontrol.0
              sprinklecontrol.0
              sprinklecontrol.0
              sprinklecontrol.0
              sprinklecontrol.0
              sprinklecontrol.0
              sprinklecontrol.0
              sprinklecontrol.0
              sprinklecontrol.0
              sprinklecontrol.0
              sprinklecontrol.0
              sprinklecontrol.0
              Dirk PeterD Offline
              Dirk PeterD Offline
              Dirk Peter
              #86
              sprinklecontrol.0
              Du hast in deiner Konfiguration eine Bandbreite von 8 (Bodenfeuchte-Sensor bei 0%) bis 10 (Bodenfeuchte-Sensor bei 100%) eingestellt.
              Sprinkle Control liest aber einen Wert von 20 (Ventil_6 => analog, newVal: 20) aus. Daher die Warn-Meldung.
              MfG Dirk Peter
                sigi234S Online
                sigi234S Online
                sigi234
                #87
                Neue Meldung:
                web.0
                2021-08-15 22:41:10.258	info	State value to set for "sprinklecontrol.0.sprinkle.Ventil_3.runningTime" has to be type "string" but received type "number"
                • Dirk PeterD Offline
                  Dirk PeterD Offline
                  Dirk Peter
                  #88
                  @sigi234 Wie ich schon geschrieben habe, wird diese Meldung vom js-controller erzeugt um die Entwickler daran zu erinnern im richtigen Datentyp zu schreiben. Dies ist bei mir aber meines Wissens der Fall. Weswegen ich eine issues beim js-controller auf GitHub eröffnet habe. Du kannst es ja hier auf GitHub verfolgen.
                  MfG Dirk Peter
                  • sigi234S sigi234
                    Neue Meldung:
                    web.0
                    Dirk PeterD Offline
                    Dirk PeterD Offline
                    Dirk Peter
                    schrieb am zuletzt editiert von Dirk Peter
                    #89
                    @sigi234
                    web.0
                    Doch mein Fehler! Sollte mit dem nächsten update erledigt sein.
                    Dirk Peter
                      @sigi234
                      web.0
                      Dirk Peter
                      MartyBr
                      #90
                      @dirk-peter
                      Da scheint noch ein Fehler in der Auswertung der Bodenfeuchtigssensoren zu sein. Alle Ventile sind auf den gleichen Sensor konfiguriert. Der Sensor zeigte heute Morgen nach dem Regen 98% an. Trotzdem ist die Beregnung mit Ventil 2 aufsteigend gestartet.
                      Die Bodenfeuchtigkeit der Sensoren ist bei Ventil 1 richtig, die anderen Ventile zeigen nur 1% an.
                      Hier dazu Telegram:
                      SprinkleControl:
                      Rasen_West 98% (78%)
                      Rasen_Süd-West 1% (78%)
                         START => 30:00
                      Rasen_Süd 1% (78%)
                         START => 30:00
                      Rasen_Süd-Ost 1% (78%)
                         START => 30:00
                      Rasen_Ost 1% (78%)
                         START => 30:00
                      Hecke_und_Rosen 1% (78%)
                         START => 40:00
                      Hier das json der Konfiguration:
                      system.adapter.sprinklecontrol.0-5.json
                      Martin
                      Dirk PeterD 2 Antworten Letzte Antwort
                      • M MartyBr
                        @dirk-peter
                        Hier dazu Telegram:
                        SprinkleControl:
                           START => 30:00
                        Rasen_Süd 1% (78%)
                           START => 30:00
                           START => 30:00
                        Rasen_Ost 1% (78%)
                           START => 30:00
                           START => 40:00
                        Dirk PeterD Offline
                        Dirk PeterD Offline
                        Dirk Peter
                        #91
                        @martybr Hallo Martin,
                        jetzt habe ich den Fehler gefunden. Ich ging immer davon aus, dass man pro Bewässerungskreis einen separaten Bodenfeuchte-Sensor verwendet. Daher wurde beim 1. gefundenen Sensor die Suche abgebrochen. Du kannst es daran erkennen, das die Sensoren auf 1% stehen und die letzte Änderung ihres Wertes die Startzeit deines Adapters war. Ich schau mir mal an wie ich das umschreibe.
                        MfG Dirk Peter
                          @dieckfr
                          So wie du es haben willst, funktioniert es mit dem Adapter nicht. Da musst du noch eine Weile warten. Ab Version 0.2.2 sollte man dann mit festen Zeiten arbeiten können. Das heißt an festen Wochentagen bzw. im 2 oder 3 Tages-Rhythmus. Eine Wetterabhängigkeit wird danach bestimmt auch folgen. Deine 5 min Pause, sind aber nicht machbar. Dafür kannst du höchstens ein Dummy-Ventil (mit 5min) benutzen.
                          MfG Dirk Meter
                          dieckfrD Offline
                          dieckfrD Offline
                          dieckfr
                          #92
                          @dirk-peter
                          Hallo Dirk Peter, danke für Deine Antwort! Ich habe mich nun an der 2.4 versucht, aber scheitere immer noch kläglich...
                          Ich habe wie von Dir vorgeschlagen 3 Kreise angelegt, den mittleren als Dummy zur Pause. Anzahl Max Ventile auf 1.
                          Alle Kreise stehen auf festen Wochentagen.
                          Folgendes passiert:
                          1. Trotz On des Kreises in den Objekten, wird die Hardware nicht getriggert
                          2. Es wird nicht mit dem ersten Kreis angefangen, sondern mit Kreis 2 und 1-3 stehen auf wait.
                          Ich weiss echt nicht was ich falsch mache... Hier nochmal was ich gerne machen möchte :)
                          Start der Bewässerung: Es soll jeden Tag zu einer festen Zeit Bewässert werden, unabhängig von irgendwas.
                          Ablauf
                          2.1 Ventil1 20 min ein
                          2.2 5min Pause zum Druckaufbau der Pumpe
                          2.3 Ventil2 20min ein
                          Fertig 🙂
                          Im 2ten Schritt
                          Bewässerung abhängig von der Wettervorhersage
                          1.1 Nicht Bewässern wenn am Tag genug Regen war
                          1.2 Nicht Bewässern wenn am nächsten Tag genug Regen gemeldet ist
                          INFO: Ich möchte Nachts gegen 2-3 Uhr Bewässern, da stört das nie 🙂
                          Ist das irgendwie umsetzbar, also mit dem Adapter machbar? Hab ich nen Denkfehler?
                          Vielen Dank im voraus!
                          • dieckfrD dieckfr
                            @dirk-peter
                            Folgendes passiert:
                            Ablauf
                            Fertig 🙂
                            Im 2ten Schritt
                            Dirk PeterD Offline
                            Dirk PeterD Offline
                            Dirk Peter
                            #93
                            @dieckfr
                            Festlegen der Reihenfolge:
                            • 1.) Anzahl Max Ventile auf 1
                            • 2.) Reihenfolge der Ventile festlegen (über den Wasserverbrauch, es wird immer mit dem größter Verbrauch begonnen)
                              z.B, Ventil 1 => 600 l/h; Ventil 2 => 500 l/h; Ventil 3 => 400 l/h
                            • Wettervorhersage aktivieren, Schwellwert ab dem nicht bewässert werden soll festlegen
                            Gruß Dirk Peter
                            • M MartyBr
                              @dirk-peter
                              Hier dazu Telegram:
                              SprinkleControl:
                                 START => 30:00
                              Rasen_Süd 1% (78%)
                                 START => 30:00
                                 START => 30:00
                              Rasen_Ost 1% (78%)
                                 START => 30:00
                                 START => 40:00
                              Dirk PeterD Offline
                              Dirk PeterD Offline
                              Dirk Peter
                              #94
                              @martybr
                              Habe auf GitHub eine Vorabversion 0.2.5, sollte damit funktionieren. Bitte testen.
                              Info: Du brauchst nicht den nächsten Regen bzw. Sonnenschein abwarten! Du kannst es auch erkennen wenn alle Objekte "sprinklecontrol.0.*.actualSoilMoisture" die auf den gleichen Sensor zeigen, die identischen Werte aufweisen über eine gewisse Zeit mit Wertänderungen.
                              MfG Dirk Peter
                              M 2 Antworten Letzte Antwort
                                @martybr
                                MfG Dirk Peter
                                MartyBr
                                #95
                                @dirk-peter
                                Ich habe die 0.2.5 installiert. Ich schaue mir die Werte und die Telegram Meldung morgen an und gebe dir dann Rückmeldung.
                                Martin
                                  @martybr
                                  MfG Dirk Peter
                                  MartyBr
                                  #96
                                  @dirk-peter
                                  Das scheint nun zu funktionieren. Hier die Meldungen von SprinkleControl:
                                  Gestern:
                                  SprinkleControl:
                                  Rasen_West 92.5% (80%)
                                  Rasen_Süd-West 92.5% (80%)
                                  Rasen_Süd 92.5% (80%)
                                  Rasen_Süd-Ost 92.5% (80%)
                                  Rasen_Ost 92.5% (80%)
                                  Hecke_und_Rosen 92.5% (80%)
                                  Heute:
                                  SprinkleControl:
                                  Rasen_West 92% (80%)
                                  Rasen_Süd-West 92% (80%)
                                  Rasen_Süd 92% (80%)
                                  Rasen_Süd-Ost 92% (80%)
                                  Rasen_Ost 92% (80%)
                                  Hecke_und_Rosen 92% (80%)
                                  Martin
                                  • M MartyBr
                                    @dirk-peter
                                    Gestern:
                                    SprinkleControl:
                                    Heute:
                                    SprinkleControl:
                                    Rasen_Süd 92% (80%)
                                    Rasen_Ost 92% (80%)
                                    Dirk PeterD Offline
                                    Dirk PeterD Offline
                                    Dirk Peter
                                    #97
                                    @martybr Schön, dann lade ich es am WE ins beta (latest). Danke für die Info.
                                    Schönes WE Dirk Peter
                                    M H 2 Antworten Letzte Antwort
                                      MartyBr
                                      #98
                                      @dirk-peter Dir auch. Bei uns soll es in den nächsten Tagen viel regnen, da habe ich ja Zeit das Verhalten zu beobachten.
                                      Danke noch einmal für die schnelle Behebung des Fehlers.
                                      Martin
                                        Habedere
                                        #99
                                        @dirk-peter
                                        Hallo Dirk,
                                        erst mal danke für den Adapter!
                                        Habe 4 Rainbird Ventile die ich über ein Relaisboard ansteuern kann...
                                        Evtl möchte ich mir noch einen SMT50 Feuchtesensor zulegen...
                                        Aktuell aber einfach nur täglich erst mal 16Minuten - außer wenn Regen gemeldet wird.
                                        Allerdings habe ich in den Einstellungen den Wetteradapter aktivieren können, habe aber keinen Schwellenwert. Woran könnte das liegen?
                                        • H Habedere
                                          @dirk-peter
                                          Hallo Dirk,
                                          Dirk PeterD Offline
                                          Dirk PeterD Offline
                                          Dirk Peter
                                          #100
                                          @habedere Hallo,
                                          der Schwellwert ist auf der Seite der Wettervorhersage und wird mit dieser aktiviert.
                                          Da der Schwellwert noch nicht altzulange vorhanden ist, liegt es vielleicht an deiner Version!
                                          MfG Dirk Peter
                                          H 1 Antwort Letzte Antwort
