  4. Installation
Installation
78 Beiträge 8 Kommentatoren 9.4k Aufrufe 5 Beobachtet
  • M Medoc
    @thomas-braun sagte in Installation:
    @medoc
    nodeJS sauber?
    which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
    pi@raspberrypi:/opt/iobroker $ which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v12.22.1
    v12.22.1
    6.14.12
    nodejs:
      Installiert:           12.22.1-1nodesource1
      Installationskandidat: 12.22.1-1nodesource1
      Versionstabelle:
     *** 12.22.1-1nodesource1 500
            500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
            100 /var/lib/dpkg/status
         10.24.0~dfsg-1~deb10u1 500
    @medoc
    cd /opt/iobroker
    sudo -H -u iobroker npm install iobroker.js-controller
    iobroker restart
      @medoc
      cd /opt/iobroker
      iobroker restart
      Medoc
      @thomas-braun ```
      pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
      iobroker.js-controller@3.3.11 preinstall /opt/iobroker/node_modules/iobroker.js-controller
      node lib/preinstallCheck.js
      NPM version: 6.14.12
      iobroker.js-controller@3.3.11 install /opt/iobroker/node_modules/iobroker.js-controller
      node iobroker.js setup first
      object _design/custom created
      object _design/system updated
      esbuild@0.11.23 postinstall /opt/iobroker/node_modules/esbuild
      node install.js
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/chokidar/node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      • iobroker.js-controller@3.3.11
        added 13 packages from 12 contributors, removed 3 packages and updated 6 packages in 88.888s
      26 packages are looking for funding
      run npm fund for details
      pi@raspberrypi:/opt/iobroker $ iobroker restart
      old & grumpy, tasmota, solar, pixelschubser (html & css), basic, c++ & php, ansonsten try and error - wisk(e)y liebhaber
      M GlasfaserG 2 Antworten Letzte Antwort
      • M Medoc
        @thomas-braun ```
        node install.js
        Medoc
        Die Website ist nicht erreichbar
        192.168.188.100 hat die Verbindung abgelehnt.
        • M Medoc
          @medoc
          iobroker list adapters
          iobroker list instances
          iobroker status
            @medoc
            iobroker status
            Medoc
            iobroker status
            pi@raspberrypi:/opt/iobroker $ iobroker list adapters
            pi@raspberrypi:/opt/iobroker $ iobroker list instances
            + instance is alive
            pi@raspberrypi:/opt/iobroker $ iobroker status
            Objects type: file
            States  type: file
            BBTownB Thomas BraunT 2 Antworten Letzte Antwort
            • M Medoc
              iobroker status
              + instance is alive
              Objects type: file
              States  type: file
              BBTownB Offline
              BBTownB Offline
              BBTown
              @medoc wie sicher bist Du denn, dass die IP stimmt?
              was sagt denn
              ifconfig
              ioBroker auf NUC (VM debian v13 (Trixie ), node v22.22.0 npm v10.9.4, js-controller v7.2.2 jsonl/jsonl / HomeMatic CCU-2 (Wired und Funk) / Philips HUE / echo.DOT / Broadlink RM pro / SONOS
              M Thomas BraunT 2 Antworten Letzte Antwort
              • M Medoc
                iobroker status
                + instance is alive
                Objects type: file
                States  type: file
                @medoc
                Keine Ahnung. Mach die Kiste platt und installier es nochmal per Installationseinzeiler.
                €dit:
                Kann es sein, dass die IP
                192.168.178.100:8081
                lautet? Das wäre so eine typische Fritzbox-Range.
                • BBTownB BBTown
                  was sagt denn
                  ifconfig
                  Medoc
                  @bbtown ```
                  pi@raspberrypi:/opt/iobroker $ ifconfig
                  eth0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
                  ether b8:27:eb:95:20:87 txqueuelen 1000 (Ethernet)
                  RX packets 0 bytes 0 (0.0 B)
                  RX errors 0 dropped 0 overruns 0 frame 0
                  TX packets 0 bytes 0 (0.0 B)
                  TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
                  lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
                  inet 127.0.0.1 netmask 255.0.0.0
                  inet6 ::1 prefixlen 128 scopeid 0x10<host>
                  loop txqueuelen 1000 (Lokale Schleife)
                  RX packets 21116 bytes 3279639 (3.1 MiB)
                  TX packets 21116 bytes 3279639 (3.1 MiB)
                  wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
                  inet 192.168.188.100 netmask 255.255.255.0 broadcast 192.168.188.255
                  inet6 fe80::d55f:5969:c95d:9c05 prefixlen 64 scopeid 0x20<link>
                  ether b8:27:eb:c0:75:d2 txqueuelen 1000 (Ethernet)
                  RX packets 22304 bytes 21211738 (20.2 MiB)
                  TX packets 19525 bytes 2260606 (2.1 MiB)
                  BBTownB 2 Antworten Letzte Antwort
                  • BBTownB BBTown
                    was sagt denn
                    ifconfig
                    @bbtown
                    Aber es müssten dennoch adapter und instances aufgeführt werden.
                    • M Medoc
                      @bbtown ```
                      BBTownB Offline
                      BBTownB Offline
                      BBTown
                      @medoc
                      editiere bitte deine posts / Ausgaben
                      • M Medoc
                        @bbtown ```
                        BBTownB Offline
                        BBTownB Offline
                        BBTown
                        @medoc
                        und wie lautet die IP von der aus Du auf ioBroker zugreifen willst?
                        Befindet sich der Rechner auch im Bereich 192.168.188.xxx ?
                          @medoc
                          €dit:
                          Medoc
                          @medoc
                          €dit:
                          platt gemacht mehrfach, und immer das selbe.
                          meine range läuft definitiv auf 188, da einem lte router nachgeschaltet.
                          hier in der gegend gibt es nur festnetz mit 1mbs
                          • BBTownB BBTown
                            @medoc
                            Medoc
                            @bbtown
                            es befindet sich hier alles auf der 188
                            • M Medoc
                              @bbtown
                              @medoc
                              Das komplettte Log der Installation wäre hilfreich, vermute ich.
                              Das riecht nach 'Netzwerkgefummel'.
                              Vielleicht hilft auch
                              iobroker logs
                              weiter.
                                @medoc
                                iobroker logs
                                weiter.
                                Medoc
                                schrieb am zuletzt editiert von Medoc
                                i:/opt/iobroker $ iobroker logs
                                2021-06-03 14:19:01.403  - info: host.raspberrypi iobroker.js-controller version 3.2.16 js-controller starting
                                2021-06-03 14:19:01.427  - info: host.raspberrypi Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
                                2021-06-03 14:19:01.429  - info: host.raspberrypi hostname: raspberrypi, node: v12.22.1
                                2021-06-03 14:19:01.431  - info: host.raspberrypi ip addresses: 192.168.188.100 fe80::d55f:5969:c95d:9c05
                                2021-06-03 14:19:02.124  - info: host.raspberrypi connected to Objects and States
                                2021-06-03 14:19:02.331  - info: host.raspberrypi added notifications configuration of host
                                2021-06-03 14:19:03.465  - info: host.raspberrypi no instances found
                                2021-06-03 14:32:32.368  - info: host.raspberrypi received SIGTERM
                                2021-06-03 14:32:32.657  - info: host.raspberrypi terminated
                                2021-06-03 14:32:49.241  - info: host.raspberrypi iobroker.js-controller version 3.2.16 js-controller starting
                                2021-06-03 14:32:49.271  - info: host.raspberrypi Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
                                2021-06-03 14:32:49.275  - info: host.raspberrypi hostname: raspberrypi, node: v12.22.1
                                2021-06-03 14:32:49.278  - info: host.raspberrypi ip addresses: fe80::d55f:5969:c95d:9c05
                                2021-06-03 14:32:50.288  - info: host.raspberrypi connected to Objects and States
                                2021-06-03 14:32:50.483  - info: host.raspberrypi added notifications configuration of host
                                2021-06-03 14:32:52.441  - info: host.raspberrypi no instances found
                                2021-06-03 14:58:44.221  - info: host.raspberrypi received SIGTERM
                                2021-06-03 14:58:44.287  - info: host.raspberrypi terminated
                                2021-06-03 14:59:46.357  - info: host.raspberrypi iobroker.js-controller version 3.2.16 js-controller starting
                                2021-06-03 14:59:46.375  - info: host.raspberrypi Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
                                2021-06-03 14:59:46.377  - info: host.raspberrypi hostname: raspberrypi, node: v12.22.1
                                2021-06-03 14:59:46.379  - info: host.raspberrypi ip addresses: 192.168.188.100 fe80::d55f:5969:c95d:9c05
                                2021-06-03 14:59:47.044  - info: host.raspberrypi connected to Objects and States
                                2021-06-03 14:59:47.165  - info: host.raspberrypi added notifications configuration of host
                                2021-06-03 14:59:48.719  - info: host.raspberrypi no instances found
                                2021-06-03 15:12:58.118  - info: host.raspberrypi received SIGTERM
                                2021-06-03 15:12:58.177  - info: host.raspberrypi terminated
                                2021-06-03 15:13:03.268  - info: host.raspberrypi iobroker.js-controller version 3.3.11 js-controller starting
                                2021-06-03 15:13:03.286  - info: host.raspberrypi Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
                                2021-06-03 15:13:03.288  - info: host.raspberrypi hostname: raspberrypi, node: v12.22.1
                                2021-06-03 15:13:03.290  - info: host.raspberrypi ip addresses: 192.168.188.100 fe80::d55f:5969:c95d:9c05
                                2021-06-03 15:13:03.938  - info: host.raspberrypi connected to Objects and States
                                2021-06-03 15:13:04.035  - info: host.raspberrypi added notifications configuration of host
                                2021-06-03 15:13:05.522  - info: host.raspberrypi no instances found
                                2021-06-03 15:13:05.525  - info: host.raspberrypi no instances found
                                2021-06-03 15:18:10.015  - info: host.raspberrypi received SIGTERM
                                2021-06-03 15:18:10.070  - info: host.raspberrypi terminated
                                2021-06-03 15:18:14.783  - info: host.raspberrypi iobroker.js-controller version 3.3.11 js-controller starting
                                2021-06-03 15:18:14.806  - info: host.raspberrypi Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
                                2021-06-03 15:18:14.809  - info: host.raspberrypi hostname: raspberrypi, node: v12.22.1
                                2021-06-03 15:18:14.811  - info: host.raspberrypi ip addresses: 192.168.188.100 fe80::d55f:5969:c95d:9c05
                                2021-06-03 15:18:15.433  - info: host.raspberrypi connected to Objects and States
                                2021-06-03 15:18:15.509  - info: host.raspberrypi added notifications configuration of host
                                2021-06-03 15:18:16.667  - info: host.raspberrypi no instances found
                                2021-06-03 15:18:16.670  - info: host.raspberrypi no instances found
                                Thomas BraunT BBTownB 2 Antworten Letzte Antwort
                                • M Medoc
                                  @medoc
                                  iobroker install admin
                                  iobroker add admin
                                  • M Medoc
                                    BBTownB Offline
                                    BBTownB Offline
                                    BBTown
                                    @medoc
                                    Du könntest versuchen eine weitere admin-Instanz hinzuzufügen und über einen anderen Port den Zugriff zu probieren. Womöglich ist der Port 8081 nicht erreichbar?
                                    [EDIT]
                                    falls der zuvor von @Thomas-Braun aufgeführte Vorschlag nicht funktioniert
                                    iobroker add admin --port 8089
                                    der Zugriff wäre dann per
                                    http://192.168.188.100:8089
                                    @Thomas-Braun wie lautet noch der Befehl um zu prüfen ob ggf. ein Port bereits belegt ist?
                                    • BBTownB BBTown
                                      @medoc
                                      [EDIT]
                                      @bbtown @Medoc
                                      sudo ss -tunlp
                                        @bbtown @Medoc
                                        sudo ss -tunlp
                                        Medoc
                                        das wars, offensichtlich ist der port 8081 blockiert.
                                        auf 8089 läuft es
                                        • M Medoc
                                          auf 8089 läuft es
                                          @medoc
                                          Dann schau was da läuft.
                                          sudo ss -tunlp
