  4. Installation
Installation
78 Beiträge 8 Kommentatoren 9.4k Aufrufe 5 Beobachtet
  • M Medoc
    das wars, offensichtlich ist der port 8081 blockiert.
    auf 8089 läuft es
    BBTownB Offline
    BBTownB Offline
    BBTown
    #41
    @medoc
    ist es denn ggf. kein jungfräulicher raspi?
    läuft da bereits etwas drauf?
    ioBroker auf NUC (VM debian v13 (Trixie ), node v22.22.0 npm v10.9.4, js-controller v7.2.2 jsonl/jsonl / HomeMatic CCU-2 (Wired und Funk) / Philips HUE / echo.DOT / Broadlink RM pro / SONOS
    • BBTownB BBTown
      @medoc
      Medoc
      #42
      @bbtown sagte in Installation:
      @medoc
      der raspi ist alt, die karte eine jungfrau
      old & grumpy, tasmota, solar, pixelschubser (html & css), basic, c++ & php, ansonsten try and error - wisk(e)y liebhaber
      • M Medoc
        @thomas-braun ```
        pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
        iobroker.js-controller@3.3.11 preinstall /opt/iobroker/node_modules/iobroker.js-controller
        node lib/preinstallCheck.js
        NPM version: 6.14.12
        iobroker.js-controller@3.3.11 install /opt/iobroker/node_modules/iobroker.js-controller
        node iobroker.js setup first
        object _design/custom created
        object _design/system updated
        esbuild@0.11.23 postinstall /opt/iobroker/node_modules/esbuild
        node install.js
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/chokidar/node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
        • iobroker.js-controller@3.3.11
          added 13 packages from 12 contributors, removed 3 packages and updated 6 packages in 88.888s
        26 packages are looking for funding
        run npm fund for details
        pi@raspberrypi:/opt/iobroker $ iobroker restart
        GlasfaserG Offline
        GlasfaserG Offline
        Glasfaser
        #43
        @medoc sagte in Installation:
        Wie kommt er denn jetzt an BETA !
        Zeige mal :
        iobroker version
        M Thomas BraunT 2 Antworten Letzte Antwort
          @medoc
          Dann schau was da läuft.
          sudo ss -tunlp
          Medoc
          #44
          @thomas-braun sagte in Installation:
          @medoc
          sudo ss -tunlp
          Netid   State    Recv-Q   Send-Q     Local Address:Port      Peer Address:Port
          udp     UNCONN   0        0                0.0.0.0:631            0.0.0.0:*      users:(("cups-browsed",pid=482,fd=7))
          udp     UNCONN   0        0                0.0.0.0:51325          0.0.0.0:*      users:(("avahi-daemon",pid=383,fd=14))
          udp     UNCONN   0        0            224.0.0.251:5353           0.0.0.0:*      users:(("chromium-browse",pid=917,fd=162))
          udp     UNCONN   0        0                0.0.0.0:5353           0.0.0.0:*      users:(("avahi-daemon",pid=383,fd=12))
          udp     UNCONN   0        0                0.0.0.0:68             0.0.0.0:*      users:(("dhcpcd",pid=415,fd=13))
          udp     UNCONN   0        0                      *:5353                 *:*      users:(("avahi-daemon",pid=383,fd=13))
          udp     UNCONN   0        0                      *:57202                *:*      users:(("avahi-daemon",pid=383,fd=15))
          tcp     LISTEN   0        511            127.0.0.1:9000           0.0.0.0:*      users:(("node",pid=3124,fd=24))
          tcp     LISTEN   0        511            127.0.0.1:9001           0.0.0.0:*      users:(("node",pid=3124,fd=19))
          tcp     LISTEN   0        5              127.0.0.1:631            0.0.0.0:*      users:(("cupsd",pid=412,fd=7))
          tcp     LISTEN   0        511                    *:8081                 *:*      users:(("node",pid=3449,fd=27))
          tcp     LISTEN   0        5                  [::1]:631               [::]:*      users:(("cupsd",pid=412,fd=6))
          tcp     LISTEN   0        511                    *:8089                 *:*      users:(("node",pid=3442,fd=27))
          pi@raspberrypi:~ $
          Thomas BraunT M 2 Antworten Letzte Antwort
          • GlasfaserG Glasfaser
            Zeige mal :
            iobroker version
            Medoc
            #45
            @glasfaser sagte in Installation:
            Zeige mal :
            iobroker version
            pi@raspberrypi:~ $ iobroker version
            3.3.11
            pi@raspberrypi:~ $
              Zeige mal :
              iobroker version
              #46
              @glasfaser
              Das kommt wohl von mir:
              hatte nicht daran gedacht das die Version dann aus npm kommt.
                @glasfaser
                GlasfaserG Offline
                GlasfaserG Offline
                Glasfaser
                #47
                Schlingel ;)
                • M Medoc
                  @medoc
                  sudo ss -tunlp
                  pi@raspberrypi:~ $
                  #48
                  @medoc
                  Da läuft schon node/iobroker auf 8081
                  Und es läuft auch ein kompletter Desktop/X-Server. Mach den aus.
                  Siehe den 'Kleinen Linuxwerkzeugkasten' aus meiner Signatur.
                  • M Medoc
                    @medoc
                    sudo ss -tunlp
                    pi@raspberrypi:~ $
                    Medoc
                    #49
                    also erstmal danke an alle beteiligten.
                    falls jemand einen tip hat, wie ich den 8081 wieder frei bekomme, wäre ich dankbar
                    gruß medoc
                    und bleibt gesund
                      @medoc
                      Medoc
                      #50
                      @medoc
                      spätestens jetzt verstehe ich nur bahnhof
                      • M Medoc
                        @medoc
                        GlasfaserG Offline
                        GlasfaserG Offline
                        Glasfaser
                        #51
                        @medoc
                        Mit welchen Browser öffnest du :
                        http://192.168.188.100:8081
                          @medoc
                          Medoc
                          #52
                          @glasfaser
                          chrome
                          • M Medoc
                            @glasfaser
                            chrome
                            GlasfaserG Offline
                            GlasfaserG Offline
                            Glasfaser
                            #53
                            @medoc
                            Schonmal einen anderen getestet !?
                              @medoc
                              Medoc
                              #54
                              @glasfaser
                              werde ich tun, nach dem mein backup durch ist.
                              ich berichte dann
                              • M Medoc
                                @glasfaser
                                ich berichte dann
                                GlasfaserG Offline
                                GlasfaserG Offline
                                Glasfaser
                                #55
                                Verstehe nicht , die ein Baustelle ist doch noch offen und jetzt kloppst du ein Backup rein !
                                  Medoc
                                  #56
                                  @glasfaser
                                  wie ist der weg richtiger?
                                  ich nahm an das wäre gelöst.
                                  • M Medoc
                                    @da_woody
                                    "er" heist Medoc, ist knapp 70, und verrsucht sich halt an was neuem
                                    #57
                                    @medoc said in Installation:
                                    @da_woody
                                    das ist guter Wein und meist schönes Wetter, und das Alter ist noch sehr jung
                                    • M Medoc
                                      @da_woody
                                      da_WoodyD Offline
                                      da_WoodyD Offline
                                      da_Woody
                                      #58
                                      @medoc er, der @Medoc braucht nicht gleich eingeschnappt sein. ist ok, wenn du dich an neuem probierst mit 70. chapeau, aber auch dann kann man auf hinweise reagieren und sich nicht stur stellen... ;)
                                      gruß vom Woody
                                      haselchenH M 2 Antworten Letzte Antwort
                                      • da_WoodyD da_Woody
                                        haselchenH Offline
                                        haselchenH Offline
                                        haselchen
                                        #59
                                        @da_woody
                                        Woody, was da los?
                                        Is bei Dir noch Weihnachten? 🤔
                                          #60
                                          ist ne sehr schöne Gegend.
