  4. Installation
Installation
78 Beiträge 8 Kommentatoren 9.4k Aufrufe 5 Beobachtet
  • BBTownB BBTown
    @medoc
    ist es denn ggf. kein jungfräulicher raspi?
    läuft da bereits etwas drauf?
    Medoc
    @bbtown sagte in Installation:
    @medoc
    der raspi ist alt, die karte eine jungfrau
    old & grumpy, tasmota, solar, pixelschubser (html & css), basic, c++ & php, ansonsten try and error - wisk(e)y liebhaber
    • M Medoc
      @thomas-braun ```
      pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
      iobroker.js-controller@3.3.11 preinstall /opt/iobroker/node_modules/iobroker.js-controller
      node lib/preinstallCheck.js
      NPM version: 6.14.12
      iobroker.js-controller@3.3.11 install /opt/iobroker/node_modules/iobroker.js-controller
      node iobroker.js setup first
      object _design/custom created
      object _design/system updated
      esbuild@0.11.23 postinstall /opt/iobroker/node_modules/esbuild
      node install.js
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/chokidar/node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      • iobroker.js-controller@3.3.11
        added 13 packages from 12 contributors, removed 3 packages and updated 6 packages in 88.888s
      26 packages are looking for funding
      run npm fund for details
      pi@raspberrypi:/opt/iobroker $ iobroker restart
      GlasfaserG Offline
      GlasfaserG Offline
      @medoc sagte in Installation:
      Wie kommt er denn jetzt an BETA !
      Zeige mal :
      iobroker version
      M Thomas BraunT 2 Antworten Letzte Antwort
        @medoc
        Dann schau was da läuft.
        sudo ss -tunlp
        Medoc
        @thomas-braun sagte in Installation:
        @medoc
        sudo ss -tunlp
        Netid   State    Recv-Q   Send-Q     Local Address:Port      Peer Address:Port
        udp     UNCONN   0        0                0.0.0.0:631            0.0.0.0:*      users:(("cups-browsed",pid=482,fd=7))
        udp     UNCONN   0        0                0.0.0.0:51325          0.0.0.0:*      users:(("avahi-daemon",pid=383,fd=14))
        udp     UNCONN   0        0            224.0.0.251:5353           0.0.0.0:*      users:(("chromium-browse",pid=917,fd=162))
        udp     UNCONN   0        0                0.0.0.0:5353           0.0.0.0:*      users:(("avahi-daemon",pid=383,fd=12))
        udp     UNCONN   0        0                0.0.0.0:68             0.0.0.0:*      users:(("dhcpcd",pid=415,fd=13))
        udp     UNCONN   0        0                      *:5353                 *:*      users:(("avahi-daemon",pid=383,fd=13))
        udp     UNCONN   0        0                      *:57202                *:*      users:(("avahi-daemon",pid=383,fd=15))
        tcp     LISTEN   0        511            127.0.0.1:9000           0.0.0.0:*      users:(("node",pid=3124,fd=24))
        tcp     LISTEN   0        511            127.0.0.1:9001           0.0.0.0:*      users:(("node",pid=3124,fd=19))
        tcp     LISTEN   0        5              127.0.0.1:631            0.0.0.0:*      users:(("cupsd",pid=412,fd=7))
        tcp     LISTEN   0        511                    *:8081                 *:*      users:(("node",pid=3449,fd=27))
        tcp     LISTEN   0        5                  [::1]:631               [::]:*      users:(("cupsd",pid=412,fd=6))
        tcp     LISTEN   0        511                    *:8089                 *:*      users:(("node",pid=3442,fd=27))
        pi@raspberrypi:~ $
        Thomas BraunT M 2 Antworten Letzte Antwort
        • GlasfaserG Glasfaser
          Zeige mal :
          iobroker version
          Medoc
          @glasfaser sagte in Installation:
          Zeige mal :
          iobroker version
          pi@raspberrypi:~ $ iobroker version
          3.3.11
          pi@raspberrypi:~ $
            Zeige mal :
            iobroker version
            @glasfaser
            Das kommt wohl von mir:
            hatte nicht daran gedacht das die Version dann aus npm kommt.
              @glasfaser
              GlasfaserG Offline
              GlasfaserG Offline
              Schlingel ;)
              • M Medoc
                @medoc
                sudo ss -tunlp
                pi@raspberrypi:~ $
                @medoc
                Da läuft schon node/iobroker auf 8081
                Und es läuft auch ein kompletter Desktop/X-Server. Mach den aus.
                Siehe den 'Kleinen Linuxwerkzeugkasten' aus meiner Signatur.
                • M Medoc
                  @medoc
                  sudo ss -tunlp
                  pi@raspberrypi:~ $
                  Medoc
                  also erstmal danke an alle beteiligten.
                  falls jemand einen tip hat, wie ich den 8081 wieder frei bekomme, wäre ich dankbar
                  gruß medoc
                  und bleibt gesund
                    @medoc
                    Medoc
                    @medoc
                    spätestens jetzt verstehe ich nur bahnhof
                    • M Medoc
                      @medoc
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @medoc
                      Mit welchen Browser öffnest du :
                      http://192.168.188.100:8081
                        @medoc
                        Medoc
                        @glasfaser
                        chrome
                        • M Medoc
                          @glasfaser
                          chrome
                          GlasfaserG Offline
                          GlasfaserG Offline
                          @medoc
                          Schonmal einen anderen getestet !?
                            @medoc
                            Medoc
                            @glasfaser
                            werde ich tun, nach dem mein backup durch ist.
                            ich berichte dann
                            • M Medoc
                              @glasfaser
                              ich berichte dann
                              GlasfaserG Offline
                              GlasfaserG Offline
                              Verstehe nicht , die ein Baustelle ist doch noch offen und jetzt kloppst du ein Backup rein !
                                Medoc
                                @glasfaser
                                wie ist der weg richtiger?
                                ich nahm an das wäre gelöst.
                                • M Medoc
                                  @da_woody
                                  "er" heist Medoc, ist knapp 70, und verrsucht sich halt an was neuem
                                  @medoc said in Installation:
                                  @da_woody
                                  das ist guter Wein und meist schönes Wetter, und das Alter ist noch sehr jung
                                  • M Medoc
                                    @da_woody
                                    da_WoodyD Offline
                                    da_WoodyD Offline
                                    @medoc er, der @Medoc braucht nicht gleich eingeschnappt sein. ist ok, wenn du dich an neuem probierst mit 70. chapeau, aber auch dann kann man auf hinweise reagieren und sich nicht stur stellen... ;)
                                    haselchenH M 2 Antworten Letzte Antwort
                                    • da_WoodyD da_Woody
                                      haselchenH Offline
                                      haselchenH Offline
                                      haselchen
                                      @da_woody
                                      Woody, was da los?
                                      Is bei Dir noch Weihnachten? 🤔
                                        ist ne sehr schöne Gegend.
                                          Medoc
                                          @da_woody sagte in Installation:
                                          der alte mann ist weder eingeschnappt,noch stellt er sich stur ;)
                                          ich habe lediglich das backup wieder eingespielt, und siehe, alles klappt wie es soll.
