  4. Installation
Installation
78 Beiträge 8 Kommentatoren 9.4k Aufrufe 5 Beobachtet
  • M Medoc
    das wars, offensichtlich ist der port 8081 blockiert.
    auf 8089 läuft es
    @medoc
    Dann schau was da läuft.
    sudo ss -tunlp
    • M Medoc
      auf 8089 läuft es
      BBTownB Offline
      BBTownB Offline
      BBTown
      @medoc
      ist es denn ggf. kein jungfräulicher raspi?
      läuft da bereits etwas drauf?
      • BBTownB BBTown
        @medoc
        Medoc
        @bbtown sagte in Installation:
        @medoc
        der raspi ist alt, die karte eine jungfrau
        old & grumpy, tasmota, solar, pixelschubser (html & css), basic, c++ & php, ansonsten try and error - wisk(e)y liebhaber
        • M Medoc
          @thomas-braun ```
          pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
          iobroker.js-controller@3.3.11 preinstall /opt/iobroker/node_modules/iobroker.js-controller
          node lib/preinstallCheck.js
          NPM version: 6.14.12
          iobroker.js-controller@3.3.11 install /opt/iobroker/node_modules/iobroker.js-controller
          node iobroker.js setup first
          object _design/custom created
          object _design/system updated
          esbuild@0.11.23 postinstall /opt/iobroker/node_modules/esbuild
          node install.js
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/chokidar/node_modules/fsevents):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
          • iobroker.js-controller@3.3.11
            added 13 packages from 12 contributors, removed 3 packages and updated 6 packages in 88.888s
          26 packages are looking for funding
          run npm fund for details
          pi@raspberrypi:/opt/iobroker $ iobroker restart
          GlasfaserG Offline
          GlasfaserG Offline
          @medoc sagte in Installation:
          Wie kommt er denn jetzt an BETA !
          Zeige mal :
          iobroker version
          M Thomas BraunT 2 Antworten Letzte Antwort
            @medoc
            sudo ss -tunlp
            Medoc
            @thomas-braun sagte in Installation:
            @medoc
            sudo ss -tunlp
            Netid   State    Recv-Q   Send-Q     Local Address:Port      Peer Address:Port
            udp     UNCONN   0        0                0.0.0.0:631            0.0.0.0:*      users:(("cups-browsed",pid=482,fd=7))
            udp     UNCONN   0        0                0.0.0.0:51325          0.0.0.0:*      users:(("avahi-daemon",pid=383,fd=14))
            udp     UNCONN   0        0            224.0.0.251:5353           0.0.0.0:*      users:(("chromium-browse",pid=917,fd=162))
            udp     UNCONN   0        0                0.0.0.0:5353           0.0.0.0:*      users:(("avahi-daemon",pid=383,fd=12))
            udp     UNCONN   0        0                0.0.0.0:68             0.0.0.0:*      users:(("dhcpcd",pid=415,fd=13))
            udp     UNCONN   0        0                      *:5353                 *:*      users:(("avahi-daemon",pid=383,fd=13))
            udp     UNCONN   0        0                      *:57202                *:*      users:(("avahi-daemon",pid=383,fd=15))
            tcp     LISTEN   0        511            127.0.0.1:9000           0.0.0.0:*      users:(("node",pid=3124,fd=24))
            tcp     LISTEN   0        511            127.0.0.1:9001           0.0.0.0:*      users:(("node",pid=3124,fd=19))
            tcp     LISTEN   0        5              127.0.0.1:631            0.0.0.0:*      users:(("cupsd",pid=412,fd=7))
            tcp     LISTEN   0        511                    *:8081                 *:*      users:(("node",pid=3449,fd=27))
            tcp     LISTEN   0        5                  [::1]:631               [::]:*      users:(("cupsd",pid=412,fd=6))
            tcp     LISTEN   0        511                    *:8089                 *:*      users:(("node",pid=3442,fd=27))
            pi@raspberrypi:~ $
            Thomas BraunT M 2 Antworten Letzte Antwort
            • GlasfaserG Glasfaser
              Zeige mal :
              iobroker version
              Medoc
              @glasfaser sagte in Installation:
              Zeige mal :
              iobroker version
              pi@raspberrypi:~ $ iobroker version
              3.3.11
              pi@raspberrypi:~ $
                Zeige mal :
                iobroker version
                @glasfaser
                Das kommt wohl von mir:
                hatte nicht daran gedacht das die Version dann aus npm kommt.
                  @glasfaser
                  GlasfaserG Offline
                  GlasfaserG Offline
                  Schlingel ;)
                  • M Medoc
                    @medoc
                    sudo ss -tunlp
                    pi@raspberrypi:~ $
                    @medoc
                    Da läuft schon node/iobroker auf 8081
                    Und es läuft auch ein kompletter Desktop/X-Server. Mach den aus.
                    Siehe den 'Kleinen Linuxwerkzeugkasten' aus meiner Signatur.
                    • M Medoc
                      @medoc
                      sudo ss -tunlp
                      pi@raspberrypi:~ $
                      Medoc
                      also erstmal danke an alle beteiligten.
                      falls jemand einen tip hat, wie ich den 8081 wieder frei bekomme, wäre ich dankbar
                      gruß medoc
                      und bleibt gesund
                        @medoc
                        Medoc
                        @medoc
                        spätestens jetzt verstehe ich nur bahnhof
                        • M Medoc
                          @medoc
                          GlasfaserG Offline
                          GlasfaserG Offline
                          @medoc
                          Mit welchen Browser öffnest du :
                          http://192.168.188.100:8081
                            @medoc
                            Medoc
                            @glasfaser
                            chrome
                            • M Medoc
                              @glasfaser
                              chrome
                              GlasfaserG Offline
                              GlasfaserG Offline
                              @medoc
                              Schonmal einen anderen getestet !?
                                @medoc
                                Medoc
                                @glasfaser
                                werde ich tun, nach dem mein backup durch ist.
                                ich berichte dann
                                • M Medoc
                                  @glasfaser
                                  ich berichte dann
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  Verstehe nicht , die ein Baustelle ist doch noch offen und jetzt kloppst du ein Backup rein !
                                    Medoc
                                    @glasfaser
                                    wie ist der weg richtiger?
                                    ich nahm an das wäre gelöst.
                                    • M Medoc
                                      @da_woody
                                      "er" heist Medoc, ist knapp 70, und verrsucht sich halt an was neuem
                                      @medoc said in Installation:
                                      @da_woody
                                      das ist guter Wein und meist schönes Wetter, und das Alter ist noch sehr jung
                                      • M Medoc
                                        @da_woody
                                        da_WoodyD Offline
                                        da_WoodyD Offline
                                        @medoc er, der @Medoc braucht nicht gleich eingeschnappt sein. ist ok, wenn du dich an neuem probierst mit 70. chapeau, aber auch dann kann man auf hinweise reagieren und sich nicht stur stellen... ;)
                                        haselchenH M 2 Antworten Letzte Antwort
                                        • da_WoodyD da_Woody
                                          haselchenH Offline
                                          haselchenH Offline
                                          haselchen
                                          @da_woody
                                          Woody, was da los?
                                          Is bei Dir noch Weihnachten? 🤔
