  4. Installation
Installation
78 Beiträge 8 Kommentatoren 9.4k Aufrufe 5 Beobachtet
  • M Medoc
    @bbtown
    es befindet sich hier alles auf der 188
    @medoc
    Das komplettte Log der Installation wäre hilfreich, vermute ich.
    Das riecht nach 'Netzwerkgefummel'.
    Vielleicht hilft auch
    iobroker logs
    weiter.
      @medoc
      iobroker logs
      weiter.
      Medoc
      schrieb am zuletzt editiert von Medoc
      i:/opt/iobroker $ iobroker logs
      2021-06-03 14:19:01.403  - info: host.raspberrypi iobroker.js-controller version 3.2.16 js-controller starting
      2021-06-03 14:19:01.427  - info: host.raspberrypi Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
      2021-06-03 14:19:01.429  - info: host.raspberrypi hostname: raspberrypi, node: v12.22.1
      2021-06-03 14:19:01.431  - info: host.raspberrypi ip addresses: 192.168.188.100 fe80::d55f:5969:c95d:9c05
      2021-06-03 14:19:02.124  - info: host.raspberrypi connected to Objects and States
      2021-06-03 14:19:02.331  - info: host.raspberrypi added notifications configuration of host
      2021-06-03 14:19:03.465  - info: host.raspberrypi no instances found
      2021-06-03 14:32:32.368  - info: host.raspberrypi received SIGTERM
      2021-06-03 14:32:32.657  - info: host.raspberrypi terminated
      2021-06-03 14:32:49.241  - info: host.raspberrypi iobroker.js-controller version 3.2.16 js-controller starting
      2021-06-03 14:32:49.271  - info: host.raspberrypi Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
      2021-06-03 14:32:49.275  - info: host.raspberrypi hostname: raspberrypi, node: v12.22.1
      2021-06-03 14:32:49.278  - info: host.raspberrypi ip addresses: fe80::d55f:5969:c95d:9c05
      2021-06-03 14:32:50.288  - info: host.raspberrypi connected to Objects and States
      2021-06-03 14:32:50.483  - info: host.raspberrypi added notifications configuration of host
      2021-06-03 14:32:52.441  - info: host.raspberrypi no instances found
      2021-06-03 14:58:44.221  - info: host.raspberrypi received SIGTERM
      2021-06-03 14:58:44.287  - info: host.raspberrypi terminated
      2021-06-03 14:59:46.357  - info: host.raspberrypi iobroker.js-controller version 3.2.16 js-controller starting
      2021-06-03 14:59:46.375  - info: host.raspberrypi Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
      2021-06-03 14:59:46.377  - info: host.raspberrypi hostname: raspberrypi, node: v12.22.1
      2021-06-03 14:59:46.379  - info: host.raspberrypi ip addresses: 192.168.188.100 fe80::d55f:5969:c95d:9c05
      2021-06-03 14:59:47.044  - info: host.raspberrypi connected to Objects and States
      2021-06-03 14:59:47.165  - info: host.raspberrypi added notifications configuration of host
      2021-06-03 14:59:48.719  - info: host.raspberrypi no instances found
      2021-06-03 15:12:58.118  - info: host.raspberrypi received SIGTERM
      2021-06-03 15:12:58.177  - info: host.raspberrypi terminated
      2021-06-03 15:13:03.268  - info: host.raspberrypi iobroker.js-controller version 3.3.11 js-controller starting
      2021-06-03 15:13:03.286  - info: host.raspberrypi Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
      2021-06-03 15:13:03.288  - info: host.raspberrypi hostname: raspberrypi, node: v12.22.1
      2021-06-03 15:13:03.290  - info: host.raspberrypi ip addresses: 192.168.188.100 fe80::d55f:5969:c95d:9c05
      2021-06-03 15:13:03.938  - info: host.raspberrypi connected to Objects and States
      2021-06-03 15:13:04.035  - info: host.raspberrypi added notifications configuration of host
      2021-06-03 15:13:05.522  - info: host.raspberrypi no instances found
      2021-06-03 15:13:05.525  - info: host.raspberrypi no instances found
      2021-06-03 15:18:10.015  - info: host.raspberrypi received SIGTERM
      2021-06-03 15:18:10.070  - info: host.raspberrypi terminated
      2021-06-03 15:18:14.783  - info: host.raspberrypi iobroker.js-controller version 3.3.11 js-controller starting
      2021-06-03 15:18:14.806  - info: host.raspberrypi Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
      2021-06-03 15:18:14.809  - info: host.raspberrypi hostname: raspberrypi, node: v12.22.1
      2021-06-03 15:18:14.811  - info: host.raspberrypi ip addresses: 192.168.188.100 fe80::d55f:5969:c95d:9c05
      2021-06-03 15:18:15.433  - info: host.raspberrypi connected to Objects and States
      2021-06-03 15:18:15.509  - info: host.raspberrypi added notifications configuration of host
      2021-06-03 15:18:16.667  - info: host.raspberrypi no instances found
      2021-06-03 15:18:16.670  - info: host.raspberrypi no instances found
      pi@raspberrypi:/opt/iobroker $
      old & grumpy, tasmota, solar, pixelschubser (html & css), basic, c++ & php, ansonsten try and error - wisk(e)y liebhaber
      Thomas BraunT BBTownB 2 Antworten Letzte Antwort
      • M Medoc
        @medoc
        iobroker install admin
        iobroker add admin
        • M Medoc
          BBTownB Offline
          BBTownB Offline
          BBTown
          schrieb am zuletzt editiert von BBTown
          @medoc
          Du könntest versuchen eine weitere admin-Instanz hinzuzufügen und über einen anderen Port den Zugriff zu probieren. Womöglich ist der Port 8081 nicht erreichbar?
          [EDIT]
          falls der zuvor von @Thomas-Braun aufgeführte Vorschlag nicht funktioniert
          iobroker add admin --port 8089
          der Zugriff wäre dann per
          http://192.168.188.100:8089
          @Thomas-Braun wie lautet noch der Befehl um zu prüfen ob ggf. ein Port bereits belegt ist?
          • BBTownB BBTown
            @medoc
            [EDIT]
            @bbtown @Medoc
            sudo ss -tunlp
              @bbtown @Medoc
              sudo ss -tunlp
              Medoc
              das wars, offensichtlich ist der port 8081 blockiert.
              auf 8089 läuft es
              • M Medoc
                auf 8089 läuft es
                @medoc
                Dann schau was da läuft.
                sudo ss -tunlp
                • M Medoc
                  auf 8089 läuft es
                  BBTownB Offline
                  BBTownB Offline
                  BBTown
                  @medoc
                  ist es denn ggf. kein jungfräulicher raspi?
                  läuft da bereits etwas drauf?
                  • BBTownB BBTown
                    @medoc
                    Medoc
                    @bbtown sagte in Installation:
                    @medoc
                    der raspi ist alt, die karte eine jungfrau
                    • M Medoc
                      @thomas-braun ```
                      pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                      iobroker.js-controller@3.3.11 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                      node lib/preinstallCheck.js
                      NPM version: 6.14.12
                      iobroker.js-controller@3.3.11 install /opt/iobroker/node_modules/iobroker.js-controller
                      node iobroker.js setup first
                      object _design/custom created
                      object _design/system updated
                      esbuild@0.11.23 postinstall /opt/iobroker/node_modules/esbuild
                      node install.js
                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/chokidar/node_modules/fsevents):
                      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
                      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                      • iobroker.js-controller@3.3.11
                        added 13 packages from 12 contributors, removed 3 packages and updated 6 packages in 88.888s
                      26 packages are looking for funding
                      run npm fund for details
                      pi@raspberrypi:/opt/iobroker $ iobroker restart
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @medoc sagte in Installation:
                      Wie kommt er denn jetzt an BETA !
                      Zeige mal :
                      iobroker version
                      M Thomas BraunT 2 Antworten Letzte Antwort
                        @medoc
                        sudo ss -tunlp
                        Medoc
                        @thomas-braun sagte in Installation:
                        @medoc
                        sudo ss -tunlp
                        Netid   State    Recv-Q   Send-Q     Local Address:Port      Peer Address:Port
                        udp     UNCONN   0        0                0.0.0.0:631            0.0.0.0:*      users:(("cups-browsed",pid=482,fd=7))
                        udp     UNCONN   0        0                0.0.0.0:51325          0.0.0.0:*      users:(("avahi-daemon",pid=383,fd=14))
                        udp     UNCONN   0        0            224.0.0.251:5353           0.0.0.0:*      users:(("chromium-browse",pid=917,fd=162))
                        udp     UNCONN   0        0                0.0.0.0:5353           0.0.0.0:*      users:(("avahi-daemon",pid=383,fd=12))
                        udp     UNCONN   0        0                0.0.0.0:68             0.0.0.0:*      users:(("dhcpcd",pid=415,fd=13))
                        udp     UNCONN   0        0                      *:5353                 *:*      users:(("avahi-daemon",pid=383,fd=13))
                        udp     UNCONN   0        0                      *:57202                *:*      users:(("avahi-daemon",pid=383,fd=15))
                        tcp     LISTEN   0        511            127.0.0.1:9000           0.0.0.0:*      users:(("node",pid=3124,fd=24))
                        tcp     LISTEN   0        511            127.0.0.1:9001           0.0.0.0:*      users:(("node",pid=3124,fd=19))
                        tcp     LISTEN   0        5              127.0.0.1:631            0.0.0.0:*      users:(("cupsd",pid=412,fd=7))
                        tcp     LISTEN   0        511                    *:8081                 *:*      users:(("node",pid=3449,fd=27))
                        tcp     LISTEN   0        5                  [::1]:631               [::]:*      users:(("cupsd",pid=412,fd=6))
                        tcp     LISTEN   0        511                    *:8089                 *:*      users:(("node",pid=3442,fd=27))
                        pi@raspberrypi:~ $
                        Thomas BraunT M 2 Antworten Letzte Antwort
                        • GlasfaserG Glasfaser
                          Zeige mal :
                          iobroker version
                          Medoc
                          @glasfaser sagte in Installation:
                          Zeige mal :
                          iobroker version
                          pi@raspberrypi:~ $ iobroker version
                          3.3.11
                          pi@raspberrypi:~ $
                            Zeige mal :
                            iobroker version
                            @glasfaser
                            Das kommt wohl von mir:
                            hatte nicht daran gedacht das die Version dann aus npm kommt.
                              @glasfaser
                              GlasfaserG Offline
                              GlasfaserG Offline
                              Schlingel ;)
                              • M Medoc
                                @medoc
                                sudo ss -tunlp
                                pi@raspberrypi:~ $
                                @medoc
                                Da läuft schon node/iobroker auf 8081
                                Und es läuft auch ein kompletter Desktop/X-Server. Mach den aus.
                                Siehe den 'Kleinen Linuxwerkzeugkasten' aus meiner Signatur.
                                • M Medoc
                                  @medoc
                                  sudo ss -tunlp
                                  pi@raspberrypi:~ $
                                  Medoc
                                  also erstmal danke an alle beteiligten.
                                  falls jemand einen tip hat, wie ich den 8081 wieder frei bekomme, wäre ich dankbar
                                  gruß medoc
                                  und bleibt gesund
                                    @medoc
                                    Medoc
                                    @medoc
                                    spätestens jetzt verstehe ich nur bahnhof
                                    • M Medoc
                                      @medoc
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      @medoc
                                      Mit welchen Browser öffnest du :
                                      http://192.168.188.100:8081
                                        @medoc
                                        Medoc
                                        @glasfaser
                                        chrome
                                        • M Medoc
                                          @glasfaser
                                          chrome
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          @medoc
                                          Schonmal einen anderen getestet !?
