  4. Installation
Installation
78 Beiträge 8 Kommentatoren 9.4k Aufrufe 5 Beobachtet
  • M Medoc
    @thomas-braun ```
    pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
    iobroker.js-controller@3.3.11 preinstall /opt/iobroker/node_modules/iobroker.js-controller
    node lib/preinstallCheck.js
    NPM version: 6.14.12
    iobroker.js-controller@3.3.11 install /opt/iobroker/node_modules/iobroker.js-controller
    node iobroker.js setup first
    object _design/custom created
    object _design/system updated
    esbuild@0.11.23 postinstall /opt/iobroker/node_modules/esbuild
    node install.js
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    • iobroker.js-controller@3.3.11
      added 13 packages from 12 contributors, removed 3 packages and updated 6 packages in 88.888s
    26 packages are looking for funding
    run npm fund for details
    pi@raspberrypi:/opt/iobroker $ iobroker restart
    GlasfaserG Offline
    GlasfaserG Offline
    @medoc sagte in Installation:
    Wie kommt er denn jetzt an BETA !
    Zeige mal :
    iobroker version
    M Thomas BraunT 2 Antworten Letzte Antwort
      @medoc
      Dann schau was da läuft.
      sudo ss -tunlp
      Medoc
      @thomas-braun sagte in Installation:
      @medoc
      sudo ss -tunlp
      Netid   State    Recv-Q   Send-Q     Local Address:Port      Peer Address:Port
      udp     UNCONN   0        0                0.0.0.0:631            0.0.0.0:*      users:(("cups-browsed",pid=482,fd=7))
      udp     UNCONN   0        0                0.0.0.0:51325          0.0.0.0:*      users:(("avahi-daemon",pid=383,fd=14))
      udp     UNCONN   0        0            224.0.0.251:5353           0.0.0.0:*      users:(("chromium-browse",pid=917,fd=162))
      udp     UNCONN   0        0                0.0.0.0:5353           0.0.0.0:*      users:(("avahi-daemon",pid=383,fd=12))
      udp     UNCONN   0        0                0.0.0.0:68             0.0.0.0:*      users:(("dhcpcd",pid=415,fd=13))
      udp     UNCONN   0        0                      *:5353                 *:*      users:(("avahi-daemon",pid=383,fd=13))
      udp     UNCONN   0        0                      *:57202                *:*      users:(("avahi-daemon",pid=383,fd=15))
      tcp     LISTEN   0        511            127.0.0.1:9000           0.0.0.0:*      users:(("node",pid=3124,fd=24))
      tcp     LISTEN   0        511            127.0.0.1:9001           0.0.0.0:*      users:(("node",pid=3124,fd=19))
      tcp     LISTEN   0        5              127.0.0.1:631            0.0.0.0:*      users:(("cupsd",pid=412,fd=7))
      tcp     LISTEN   0        511                    *:8081                 *:*      users:(("node",pid=3449,fd=27))
      tcp     LISTEN   0        5                  [::1]:631               [::]:*      users:(("cupsd",pid=412,fd=6))
      tcp     LISTEN   0        511                    *:8089                 *:*      users:(("node",pid=3442,fd=27))
      pi@raspberrypi:~ $
      old & grumpy, tasmota, solar, pixelschubser (html & css), basic, c++ & php, ansonsten try and error - wisk(e)y liebhaber
      Thomas BraunT M 2 Antworten Letzte Antwort
      • GlasfaserG Glasfaser
        Zeige mal :
        iobroker version
        Medoc
        @glasfaser sagte in Installation:
        Zeige mal :
        iobroker version
        pi@raspberrypi:~ $ iobroker version
        3.3.11
        pi@raspberrypi:~ $
          Zeige mal :
          iobroker version
          @glasfaser
          Das kommt wohl von mir:
          hatte nicht daran gedacht das die Version dann aus npm kommt.
            @glasfaser
            GlasfaserG Offline
            GlasfaserG Offline
            Schlingel ;)
            • M Medoc
              @medoc
              sudo ss -tunlp
              pi@raspberrypi:~ $
              @medoc
              Da läuft schon node/iobroker auf 8081
              Und es läuft auch ein kompletter Desktop/X-Server. Mach den aus.
              Siehe den 'Kleinen Linuxwerkzeugkasten' aus meiner Signatur.
              • M Medoc
                @medoc
                sudo ss -tunlp
                pi@raspberrypi:~ $
                Medoc
                also erstmal danke an alle beteiligten.
                falls jemand einen tip hat, wie ich den 8081 wieder frei bekomme, wäre ich dankbar
                gruß medoc
                und bleibt gesund
                  @medoc
                  Medoc
                  @medoc
                  spätestens jetzt verstehe ich nur bahnhof
                  • M Medoc
                    @medoc
                    GlasfaserG Offline
                    GlasfaserG Offline
                    @medoc
                    Mit welchen Browser öffnest du :
                    http://192.168.188.100:8081
                      @medoc
                      Medoc
                      @glasfaser
                      chrome
                      • M Medoc
                        @glasfaser
                        chrome
                        GlasfaserG Offline
                        GlasfaserG Offline
                        @medoc
                        Schonmal einen anderen getestet !?
                          @medoc
                          Medoc
                          @glasfaser
                          werde ich tun, nach dem mein backup durch ist.
                          ich berichte dann
                          • M Medoc
                            @glasfaser
                            ich berichte dann
                            GlasfaserG Offline
                            GlasfaserG Offline
                            Verstehe nicht , die ein Baustelle ist doch noch offen und jetzt kloppst du ein Backup rein !
                              Medoc
                              @glasfaser
                              wie ist der weg richtiger?
                              ich nahm an das wäre gelöst.
                              • M Medoc
                                @da_woody
                                "er" heist Medoc, ist knapp 70, und verrsucht sich halt an was neuem
                                @medoc said in Installation:
                                @da_woody
                                das ist guter Wein und meist schönes Wetter, und das Alter ist noch sehr jung
                                • M Medoc
                                  @da_woody
                                  da_WoodyD Offline
                                  da_WoodyD Offline
                                  @medoc er, der @Medoc braucht nicht gleich eingeschnappt sein. ist ok, wenn du dich an neuem probierst mit 70. chapeau, aber auch dann kann man auf hinweise reagieren und sich nicht stur stellen... ;)
                                  haselchenH M 2 Antworten Letzte Antwort
                                  • da_WoodyD da_Woody
                                    haselchenH Offline
                                    haselchenH Offline
                                    haselchen
                                    @da_woody
                                    Woody, was da los?
                                    Is bei Dir noch Weihnachten? 🤔
                                      ist ne sehr schöne Gegend.
                                        Medoc
                                        @da_woody sagte in Installation:
                                        der alte mann ist weder eingeschnappt,noch stellt er sich stur ;)
                                        ich habe lediglich das backup wieder eingespielt, und siehe, alles klappt wie es soll.
                                          Medoc
                                          wundersammer weise läuft der admin jetzt wieder auf port 8081
                                          M HomoranH 2 Antworten Letzte Antwort
