  4. Installation
Installation
78 Beiträge 8 Kommentatoren 9.4k Aufrufe 5 Beobachtet
    @medoc
    cd /opt/iobroker
    sudo -H -u iobroker npm install iobroker.js-controller
    iobroker restart
    Medoc
    @thomas-braun ```
    pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
    iobroker.js-controller@3.3.11 preinstall /opt/iobroker/node_modules/iobroker.js-controller
    node lib/preinstallCheck.js
    NPM version: 6.14.12
    iobroker.js-controller@3.3.11 install /opt/iobroker/node_modules/iobroker.js-controller
    node iobroker.js setup first
    object _design/custom created
    object _design/system updated
    esbuild@0.11.23 postinstall /opt/iobroker/node_modules/esbuild
    node install.js
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    • iobroker.js-controller@3.3.11
      added 13 packages from 12 contributors, removed 3 packages and updated 6 packages in 88.888s
    26 packages are looking for funding
    run npm fund for details
    pi@raspberrypi:/opt/iobroker $ iobroker restart
    old & grumpy, tasmota, solar, pixelschubser (html & css), basic, c++ & php, ansonsten try and error - wisk(e)y liebhaber
    M GlasfaserG 2 Antworten Letzte Antwort
    • M Medoc
      @thomas-braun ```
      node install.js
      Medoc
      Die Website ist nicht erreichbar
      192.168.188.100 hat die Verbindung abgelehnt.
      • M Medoc
        @medoc
        iobroker list adapters
        iobroker list instances
        iobroker status
          @medoc
          iobroker status
          Medoc
          @thomas-braun sagte in Installation:
          iobroker status
          pi@raspberrypi:/opt/iobroker $ iobroker list adapters
          pi@raspberrypi:/opt/iobroker $ iobroker list instances
          + instance is alive
          pi@raspberrypi:/opt/iobroker $ iobroker status
          Objects type: file
          States  type: file
          BBTownB Thomas BraunT 2 Antworten Letzte Antwort
          • M Medoc
            iobroker status
            + instance is alive
            Objects type: file
            States  type: file
            BBTownB Offline
            BBTownB Offline
            BBTown
            @medoc wie sicher bist Du denn, dass die IP stimmt?
            was sagt denn
            ifconfig
            M Thomas BraunT 2 Antworten Letzte Antwort
            • M Medoc
              iobroker status
              + instance is alive
              Objects type: file
              States  type: file
              @medoc
              Keine Ahnung. Mach die Kiste platt und installier es nochmal per Installationseinzeiler.
              €dit:
              Kann es sein, dass die IP
              192.168.178.100:8081
              lautet? Das wäre so eine typische Fritzbox-Range.
              • BBTownB BBTown
                was sagt denn
                ifconfig
                Medoc
                @bbtown ```
                pi@raspberrypi:/opt/iobroker $ ifconfig
                eth0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
                ether b8:27:eb:95:20:87 txqueuelen 1000 (Ethernet)
                RX packets 0 bytes 0 (0.0 B)
                RX errors 0 dropped 0 overruns 0 frame 0
                TX packets 0 bytes 0 (0.0 B)
                TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
                lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
                inet 127.0.0.1 netmask 255.0.0.0
                inet6 ::1 prefixlen 128 scopeid 0x10<host>
                loop txqueuelen 1000 (Lokale Schleife)
                RX packets 21116 bytes 3279639 (3.1 MiB)
                TX packets 21116 bytes 3279639 (3.1 MiB)
                wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
                inet 192.168.188.100 netmask 255.255.255.0 broadcast 192.168.188.255
                inet6 fe80::d55f:5969:c95d:9c05 prefixlen 64 scopeid 0x20<link>
                ether b8:27:eb:c0:75:d2 txqueuelen 1000 (Ethernet)
                RX packets 22304 bytes 21211738 (20.2 MiB)
                TX packets 19525 bytes 2260606 (2.1 MiB)
                BBTownB 2 Antworten Letzte Antwort
                • BBTownB BBTown
                  was sagt denn
                  ifconfig
                  @bbtown
                  Aber es müssten dennoch adapter und instances aufgeführt werden.
                  • M Medoc
                    @bbtown ```
                    BBTownB Offline
                    BBTownB Offline
                    BBTown
                    @medoc
                    editiere bitte deine posts / Ausgaben
                    • M Medoc
                      @bbtown ```
                      BBTownB Offline
                      BBTownB Offline
                      BBTown
                      @medoc
                      und wie lautet die IP von der aus Du auf ioBroker zugreifen willst?
                      Befindet sich der Rechner auch im Bereich 192.168.188.xxx ?
                        @medoc
                        €dit:
                        Medoc
                        @medoc
                        €dit:
                        platt gemacht mehrfach, und immer das selbe.
                        meine range läuft definitiv auf 188, da einem lte router nachgeschaltet.
                        hier in der gegend gibt es nur festnetz mit 1mbs
                        • BBTownB BBTown
                          @medoc
                          Medoc
                          @bbtown
                          es befindet sich hier alles auf der 188
                          • M Medoc
                            @bbtown
                            @medoc
                            Das komplettte Log der Installation wäre hilfreich, vermute ich.
                            Das riecht nach 'Netzwerkgefummel'.
                            Vielleicht hilft auch
                            iobroker logs
                            weiter.
                              @medoc
                              iobroker logs
                              weiter.
                              Medoc
                              schrieb am zuletzt editiert von Medoc
                              i:/opt/iobroker $ iobroker logs
                              2021-06-03 14:19:01.403  - info: host.raspberrypi iobroker.js-controller version 3.2.16 js-controller starting
                              2021-06-03 14:19:01.427  - info: host.raspberrypi Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
                              2021-06-03 14:19:01.429  - info: host.raspberrypi hostname: raspberrypi, node: v12.22.1
                              2021-06-03 14:19:01.431  - info: host.raspberrypi ip addresses: 192.168.188.100 fe80::d55f:5969:c95d:9c05
                              2021-06-03 14:19:02.124  - info: host.raspberrypi connected to Objects and States
                              2021-06-03 14:19:02.331  - info: host.raspberrypi added notifications configuration of host
                              2021-06-03 14:19:03.465  - info: host.raspberrypi no instances found
                              2021-06-03 14:32:32.368  - info: host.raspberrypi received SIGTERM
                              2021-06-03 14:32:32.657  - info: host.raspberrypi terminated
                              2021-06-03 14:32:49.241  - info: host.raspberrypi iobroker.js-controller version 3.2.16 js-controller starting
                              2021-06-03 14:32:49.271  - info: host.raspberrypi Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
                              2021-06-03 14:32:49.275  - info: host.raspberrypi hostname: raspberrypi, node: v12.22.1
                              2021-06-03 14:32:49.278  - info: host.raspberrypi ip addresses: fe80::d55f:5969:c95d:9c05
                              2021-06-03 14:32:50.288  - info: host.raspberrypi connected to Objects and States
                              2021-06-03 14:32:50.483  - info: host.raspberrypi added notifications configuration of host
                              2021-06-03 14:32:52.441  - info: host.raspberrypi no instances found
                              2021-06-03 14:58:44.221  - info: host.raspberrypi received SIGTERM
                              2021-06-03 14:58:44.287  - info: host.raspberrypi terminated
                              2021-06-03 14:59:46.357  - info: host.raspberrypi iobroker.js-controller version 3.2.16 js-controller starting
                              2021-06-03 14:59:46.375  - info: host.raspberrypi Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
                              2021-06-03 14:59:46.377  - info: host.raspberrypi hostname: raspberrypi, node: v12.22.1
                              2021-06-03 14:59:46.379  - info: host.raspberrypi ip addresses: 192.168.188.100 fe80::d55f:5969:c95d:9c05
                              2021-06-03 14:59:47.044  - info: host.raspberrypi connected to Objects and States
                              2021-06-03 14:59:47.165  - info: host.raspberrypi added notifications configuration of host
                              2021-06-03 14:59:48.719  - info: host.raspberrypi no instances found
                              2021-06-03 15:12:58.118  - info: host.raspberrypi received SIGTERM
                              2021-06-03 15:12:58.177  - info: host.raspberrypi terminated
                              2021-06-03 15:13:03.268  - info: host.raspberrypi iobroker.js-controller version 3.3.11 js-controller starting
                              2021-06-03 15:13:03.286  - info: host.raspberrypi Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
                              2021-06-03 15:13:03.288  - info: host.raspberrypi hostname: raspberrypi, node: v12.22.1
                              2021-06-03 15:13:03.290  - info: host.raspberrypi ip addresses: 192.168.188.100 fe80::d55f:5969:c95d:9c05
                              2021-06-03 15:13:03.938  - info: host.raspberrypi connected to Objects and States
                              2021-06-03 15:13:04.035  - info: host.raspberrypi added notifications configuration of host
                              2021-06-03 15:13:05.522  - info: host.raspberrypi no instances found
                              2021-06-03 15:13:05.525  - info: host.raspberrypi no instances found
                              2021-06-03 15:18:10.015  - info: host.raspberrypi received SIGTERM
                              2021-06-03 15:18:10.070  - info: host.raspberrypi terminated
                              2021-06-03 15:18:14.783  - info: host.raspberrypi iobroker.js-controller version 3.3.11 js-controller starting
                              2021-06-03 15:18:14.806  - info: host.raspberrypi Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
                              2021-06-03 15:18:14.809  - info: host.raspberrypi hostname: raspberrypi, node: v12.22.1
                              2021-06-03 15:18:14.811  - info: host.raspberrypi ip addresses: 192.168.188.100 fe80::d55f:5969:c95d:9c05
                              2021-06-03 15:18:15.433  - info: host.raspberrypi connected to Objects and States
                              2021-06-03 15:18:15.509  - info: host.raspberrypi added notifications configuration of host
                              2021-06-03 15:18:16.667  - info: host.raspberrypi no instances found
                              2021-06-03 15:18:16.670  - info: host.raspberrypi no instances found
                              Thomas BraunT BBTownB 2 Antworten Letzte Antwort
                              • M Medoc
                                @medoc
                                iobroker install admin
                                iobroker add admin
                                • M Medoc
                                  BBTownB Offline
                                  BBTownB Offline
                                  BBTown
                                  schrieb am zuletzt editiert von BBTown
                                  @medoc
                                  Du könntest versuchen eine weitere admin-Instanz hinzuzufügen und über einen anderen Port den Zugriff zu probieren. Womöglich ist der Port 8081 nicht erreichbar?
                                  [EDIT]
                                  falls der zuvor von @Thomas-Braun aufgeführte Vorschlag nicht funktioniert
                                  iobroker add admin --port 8089
                                  der Zugriff wäre dann per
                                  http://192.168.188.100:8089
                                  @Thomas-Braun wie lautet noch der Befehl um zu prüfen ob ggf. ein Port bereits belegt ist?
                                  • BBTownB BBTown
                                    @medoc
                                    [EDIT]
                                    @bbtown @Medoc
                                    sudo ss -tunlp
                                      @bbtown @Medoc
                                      sudo ss -tunlp
                                      Medoc
                                      das wars, offensichtlich ist der port 8081 blockiert.
                                      auf 8089 läuft es
                                      • M Medoc
                                        auf 8089 läuft es
                                        @medoc
                                        Dann schau was da läuft.
                                        sudo ss -tunlp
                                        • M Medoc
                                          auf 8089 läuft es
                                          BBTownB Offline
                                          BBTownB Offline
                                          BBTown
                                          @medoc
                                          ist es denn ggf. kein jungfräulicher raspi?
                                          läuft da bereits etwas drauf?
