  4. Probleme beim Installieren von MQTT-Client
91 Beiträge 5 Kommentatoren 11.3k Aufrufe 2 Beobachtet
  • AlCalzoneA AlCalzone
    @berges01 sagte in Probleme beim Installieren von MQTT-Client:
    does not start any instances on this host
    Der Hostname hat sich geändert und die Instanzen sind noch dem alten Hostnamen zugeordnet. Daher wird nichts gestartet.
    @apollon77 @Homoran ich bin hier grad ein bisschen eingerostet - habt ihr ggf. das richtige Kommando parat? War das iobroker host this?
    Berges01B Offline
    Berges01B Offline
    Berges01
    #81
    @alcalzone said in Probleme beim Installieren von MQTT-Client:
    laut Hilfe müsste es so aussehen :
    iobroker host <hostname> Set host to given hostname
    "hostnahme = Neuer Name", meine Vermutung.
    Dann währe der Befehl :
    iobroker host Strommix-Smart
    Das tippe ich aber erst nach OK ein !
    F.B.
    • Berges01B Berges01
      #82
      @berges01
      iobroker host this
      Berges01B 1 Antwort Letzte Antwort
        @berges01
        iobroker host this
        Berges01B Offline
        Berges01B Offline
        Berges01
        #83
        @thomas-braun said in Probleme beim Installieren von MQTT-Client:
        iobroker host this
        berges01@Strommix-Smart:~$ iobroker host this
        Host "DESKTOP-61ND8BH(SmartHome)" successfully renamed to "Strommix-Smart".
        The host for instance "system.adapter.admin.0" was changed from "Strommix-Smart" to "Strommix-Smart".
        The host for instance "system.adapter.alexa2.0" was changed from "Strommix-Smart" to "Strommix-Smart".
        The host for instance "system.adapter.backitup.0" was changed from "Strommix-Smart" to "Strommix-Smart".
        The host for instance "system.adapter.cloud.0" was changed from "Strommix-Smart" to "Strommix-Smart".
        The host for instance "system.adapter.devices.0" was changed from "Strommix-Smart" to "Strommix-Smart".
        The host for instance "system.adapter.info.0" was changed from "Strommix-Smart" to "Strommix-Smart".
        The host for instance "system.adapter.iot.0" was changed from "Strommix-Smart" to "Strommix-Smart".
        The host for instance "system.adapter.javascript.0" was changed from "Strommix-Smart" to "Strommix-Smart".
        The host for instance "system.adapter.mqtt.0" was changed from "Strommix-Smart" to "Strommix-Smart".
        The host for instance "system.adapter.netatmo.0" was changed from "Strommix-Smart" to "Strommix-Smart".
        The host for instance "system.adapter.ping.0" was changed from "Strommix-Smart" to "Strommix-Smart".
        The host for instance "system.adapter.socketio.0" was changed from "Strommix-Smart" to "Strommix-Smart".
        The host for instance "system.adapter.tr-064.0" was changed from "Strommix-Smart" to "Strommix-Smart".
        The host for instance "system.adapter.vis.0" was changed from "Strommix-Smart" to "Strommix-Smart".
        The host for instance "system.adapter.web.0" was changed from "Strommix-Smart" to "Strommix-Smart".
        The host for instance "system.adapter.whatsapp-cmb.0" was changed from "Strommix-Smart" to "Strommix-Smart".
        The host for instance "system.adapter.zwave2.0" was changed from "Strommix-Smart" to "Strommix-Smart".
        F.B.
          iobroker host this
          #84
          @berges01
          iobroker restart
          Thomas BraunT Berges01B 2 Antworten Letzte Antwort
            @berges01
            iobroker restart
            #85
            Notiz an mich selbst:
            Den host change sieht man im log file
            2021-05-17 07:52:44.827  - info: host.Strommix-Smart All instances are stopped.
            2021-05-17 07:52:44.898  - info: host.Strommix-Smart terminated
            2021-05-17 07:53:02.319  - info: host.DESKTOP-61ND8BH(SmartHome) iobroker.js-controller version 3.2.16 js-controller starting
            2021-05-17 07:53:02.320  - info: host.DESKTOP-61ND8BH(SmartHome) Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
            2021-05-17 07:53:02.321  - info: host.DESKTOP-61ND8BH(SmartHome) hostname: DESKTOP-61ND8BH(SmartHome), node: v12.22.1
              @berges01
              iobroker restart
              Berges01B Offline
              Berges01B Offline
              Berges01
              #86
              iobroker restart
              AHHHHHHH
              Schau an da is er wieder !
              Instanzen sind da aber noch nicht aktiv.
              F.B.
                iobroker restart
                AHHHHHHH
                #87
                @berges01
                Dann schau nochmal per
                iobroker list instances
                iobroker start admin
                  @berges01
                  Berges01B Offline
                  Berges01B Offline
                  Berges01
                  #88
                  berges01@Strommix-Smart:~$ iobroker list instances
                  + system.adapter.admin.0                  : admin                 : Strommix-Smart                           -  enabled, port: 8081, bind: 192.168.2.50, run as: admin
                  + system.adapter.alexa2.0                 : alexa2                : Strommix-Smart                           -  enabled
                  + system.adapter.backitup.0               : backitup              : Strommix-Smart                           -  enabled
                  + system.adapter.cloud.0                  : cloud                 : Strommix-Smart                           -  enabled
                    system.adapter.devices.0                : devices               : Strommix-Smart                           - disabled
                  + system.adapter.info.0                   : info                  : Strommix-Smart                           -  enabled
                  + system.adapter.iot.0                    : iot                   : Strommix-Smart                           -  enabled
                  + system.adapter.javascript.0             : javascript            : Strommix-Smart                           -  enabled
                  + system.adapter.mqtt.0                   : mqtt                  : Strommix-Smart                           -  enabled, port: 1883, bind: 0.0.0.0
                  + system.adapter.netatmo.0                : netatmo               : Strommix-Smart                           -  enabled
                  + system.adapter.ping.0                   : ping                  : Strommix-Smart                           -  enabled
                  + system.adapter.socketio.0               : socketio              : Strommix-Smart                           -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                    system.adapter.vis.0                    : vis                   : Strommix-Smart                           -  enabled
                  + system.adapter.web.0                    : web                   : Strommix-Smart                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : Strommix-Smart                           -  enabled
                  + system.adapter.zwave2.0                 : zwave2                : Strommix-Smart                           -  enabled
                  + instance is alive
                  code_text
                  F.B.
                    + instance is alive
                    code_text
                    Berges01B Offline
                    Berges01B Offline
                    Berges01
                    schrieb am zuletzt editiert von Berges01
                    #89
                    @berges01 said in Probleme beim Installieren von MQTT-Client:
                    + instance is alive
                    code_text
                    Adapter alle grün
                    z-wave wieder da und 2 Nodes funktionieren (mehr hatte dauert aber wenn 2 gehen)
                    Blockly alle da
                    Das scheind Gut gegangen zu sein !
                    Dann ist das jetzt auf einem Debian Server ohne Desktop.
                    Oh mann was machte ich nur ohne EUCH ?
                    Erst mal DANKE (Organisiert ein User-Treffen und ich werfe eine Runde Freibier) !!!
                    F.B.
                      @berges01
                      iobroker start web
                      berges01@Strommix-Smart:~$ iobroker start admin
                      berges01@Strommix-Smart:~$ iobroker start web
                      The adapter "web.0" was started.
                      und nix
                      berges01@Strommix-Smart:~$ ^C
                        system.adapter.alexa2.0                 : alexa2                : Strommix-Smart                           - disabled
                        system.adapter.cloud.0                  : cloud                 : Strommix-Smart                           - disabled
                        system.adapter.info.0                   : info                  : Strommix-Smart                           - disabled
                        system.adapter.iot.0                    : iot                   : Strommix-Smart                           - disabled
                        system.adapter.javascript.0             : javascript            : Strommix-Smart                           - disabled
                        system.adapter.mqtt.0                   : mqtt                  : Strommix-Smart                           - disabled, port: 1883, bind: 0.0.0.0
                        system.adapter.netatmo.0                : netatmo               : Strommix-Smart                           - disabled
                        system.adapter.ping.0                   : ping                  : Strommix-Smart                           - disabled
                        system.adapter.socketio.0               : socketio              : Strommix-Smart                           - disabled, port: 8084, bind: 0.0.0.0, run as: admin
                        system.adapter.tr-064.0                 : tr-064                : Strommix-Smart                           - disabled
                        system.adapter.vis.0                    : vis                   : Strommix-Smart                           - disabled
                        system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : Strommix-Smart                           - disabled
                        system.adapter.zwave2.0                 : zwave2                : Strommix-Smart                           - disabled
                      + instance is alive
                      berge
                      #90
                      wieso denn das?
                      da gehört 0.0.0.0 rein
                      das kommt dann wohl schon aus dem Backup.
                      Jetzt wo du wieder an den admin kommst, dort unbedingt in der Konfig 0.0.0.0 eingeben!
                      https://www.iobroker.net/#de/adapters/adapterref/iobroker.admin/README.md
                      (ist schon was älter, gilt aber immer noch)
                        wieso denn das?
                        Berges01B Offline
                        Berges01B Offline
                        Berges01
                        #91
                        @homoran said in Probleme beim Installieren von MQTT-Client:
                        wieso denn das?
                        Erledigt !
                        Danke !
                        F.B.
