  4. Probleme beim Installieren von MQTT-Client
91 Beiträge 5 Kommentatoren 11.3k Aufrufe 2 Beobachtet
  • Berges01B Berges01
    @alcalzone said in Probleme beim Installieren von MQTT-Client:
    @berges01 sagte in Probleme beim Installieren von MQTT-Client:
    does not start any instances on this host
    Der Hostname hat sich geändert und die Instanzen sind noch dem alten Hostnamen zugeordnet. Daher wird nichts gestartet.
    @apollon77 @Homoran ich bin hier grad ein bisschen eingerostet - habt ihr ggf. das richtige Kommando parat? War das iobroker host this?
    laut Hilfe müsste es so aussehen :
    iobroker host <hostname> Set host to given hostname
    "hostnahme = Neuer Name", meine Vermutung.
    Dann währe der Befehl :
    iobroker host Strommix-Smart
    Das tippe ich aber erst nach OK ein !
    #82
    @berges01
    iobroker host this
    Berges01B 1 Antwort Letzte Antwort
      @berges01
      iobroker host this
      Berges01B Offline
      Berges01B Offline
      Berges01
      #83
      @thomas-braun said in Probleme beim Installieren von MQTT-Client:
      iobroker host this
      berges01@Strommix-Smart:~$ iobroker host this
      Host "DESKTOP-61ND8BH(SmartHome)" successfully renamed to "Strommix-Smart".
      The host for instance "system.adapter.admin.0" was changed from "Strommix-Smart" to "Strommix-Smart".
      The host for instance "system.adapter.alexa2.0" was changed from "Strommix-Smart" to "Strommix-Smart".
      The host for instance "system.adapter.backitup.0" was changed from "Strommix-Smart" to "Strommix-Smart".
      The host for instance "system.adapter.cloud.0" was changed from "Strommix-Smart" to "Strommix-Smart".
      The host for instance "system.adapter.devices.0" was changed from "Strommix-Smart" to "Strommix-Smart".
      The host for instance "system.adapter.info.0" was changed from "Strommix-Smart" to "Strommix-Smart".
      The host for instance "system.adapter.iot.0" was changed from "Strommix-Smart" to "Strommix-Smart".
      The host for instance "system.adapter.javascript.0" was changed from "Strommix-Smart" to "Strommix-Smart".
      The host for instance "system.adapter.mqtt.0" was changed from "Strommix-Smart" to "Strommix-Smart".
      The host for instance "system.adapter.netatmo.0" was changed from "Strommix-Smart" to "Strommix-Smart".
      The host for instance "system.adapter.ping.0" was changed from "Strommix-Smart" to "Strommix-Smart".
      The host for instance "system.adapter.socketio.0" was changed from "Strommix-Smart" to "Strommix-Smart".
      The host for instance "system.adapter.tr-064.0" was changed from "Strommix-Smart" to "Strommix-Smart".
      The host for instance "system.adapter.vis.0" was changed from "Strommix-Smart" to "Strommix-Smart".
      The host for instance "system.adapter.web.0" was changed from "Strommix-Smart" to "Strommix-Smart".
      The host for instance "system.adapter.whatsapp-cmb.0" was changed from "Strommix-Smart" to "Strommix-Smart".
      The host for instance "system.adapter.zwave2.0" was changed from "Strommix-Smart" to "Strommix-Smart".
      F.B.
        iobroker host this
        #84
        @berges01
        iobroker restart
        Thomas BraunT Berges01B 2 Antworten Letzte Antwort
          @berges01
          iobroker restart
          #85
          Notiz an mich selbst:
          Den host change sieht man im log file
          2021-05-17 07:52:44.827  - info: host.Strommix-Smart All instances are stopped.
          2021-05-17 07:52:44.898  - info: host.Strommix-Smart terminated
          2021-05-17 07:53:02.319  - info: host.DESKTOP-61ND8BH(SmartHome) iobroker.js-controller version 3.2.16 js-controller starting
          2021-05-17 07:53:02.320  - info: host.DESKTOP-61ND8BH(SmartHome) Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
          2021-05-17 07:53:02.321  - info: host.DESKTOP-61ND8BH(SmartHome) hostname: DESKTOP-61ND8BH(SmartHome), node: v12.22.1
            @berges01
            iobroker restart
            Berges01B Offline
            Berges01B Offline
            Berges01
            #86
            iobroker restart
            AHHHHHHH
            Schau an da is er wieder !
            Instanzen sind da aber noch nicht aktiv.
            F.B.
              iobroker restart
              AHHHHHHH
              #87
              @berges01
              Dann schau nochmal per
              iobroker list instances
              iobroker start admin
                @berges01
                Berges01B Offline
                Berges01B Offline
                Berges01
                #88
                berges01@Strommix-Smart:~$ iobroker list instances
                + system.adapter.admin.0                  : admin                 : Strommix-Smart                           -  enabled, port: 8081, bind: 192.168.2.50, run as: admin
                + system.adapter.alexa2.0                 : alexa2                : Strommix-Smart                           -  enabled
                + system.adapter.backitup.0               : backitup              : Strommix-Smart                           -  enabled
                + system.adapter.cloud.0                  : cloud                 : Strommix-Smart                           -  enabled
                  system.adapter.devices.0                : devices               : Strommix-Smart                           - disabled
                + system.adapter.info.0                   : info                  : Strommix-Smart                           -  enabled
                + system.adapter.iot.0                    : iot                   : Strommix-Smart                           -  enabled
                + system.adapter.javascript.0             : javascript            : Strommix-Smart                           -  enabled
                + system.adapter.mqtt.0                   : mqtt                  : Strommix-Smart                           -  enabled, port: 1883, bind: 0.0.0.0
                + system.adapter.netatmo.0                : netatmo               : Strommix-Smart                           -  enabled
                + system.adapter.ping.0                   : ping                  : Strommix-Smart                           -  enabled
                + system.adapter.socketio.0               : socketio              : Strommix-Smart                           -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                  system.adapter.vis.0                    : vis                   : Strommix-Smart                           -  enabled
                + system.adapter.web.0                    : web                   : Strommix-Smart                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : Strommix-Smart                           -  enabled
                + system.adapter.zwave2.0                 : zwave2                : Strommix-Smart                           -  enabled
                + instance is alive
                code_text
                F.B.
                  + instance is alive
                  code_text
                  Berges01B Offline
                  Berges01B Offline
                  Berges01
                  schrieb am zuletzt editiert von Berges01
                  #89
                  @berges01 said in Probleme beim Installieren von MQTT-Client:
                  + instance is alive
                  code_text
                  Adapter alle grün
                  z-wave wieder da und 2 Nodes funktionieren (mehr hatte dauert aber wenn 2 gehen)
                  Blockly alle da
                  Das scheind Gut gegangen zu sein !
                  Dann ist das jetzt auf einem Debian Server ohne Desktop.
                  Oh mann was machte ich nur ohne EUCH ?
                  Erst mal DANKE (Organisiert ein User-Treffen und ich werfe eine Runde Freibier) !!!
                  F.B.
                    @berges01
                    iobroker start web
                    berges01@Strommix-Smart:~$ iobroker start admin
                    berges01@Strommix-Smart:~$ iobroker start web
                    The adapter "web.0" was started.
                    und nix
                    berges01@Strommix-Smart:~$ ^C
                      system.adapter.alexa2.0                 : alexa2                : Strommix-Smart                           - disabled
                      system.adapter.cloud.0                  : cloud                 : Strommix-Smart                           - disabled
                      system.adapter.info.0                   : info                  : Strommix-Smart                           - disabled
                      system.adapter.iot.0                    : iot                   : Strommix-Smart                           - disabled
                      system.adapter.javascript.0             : javascript            : Strommix-Smart                           - disabled
                      system.adapter.mqtt.0                   : mqtt                  : Strommix-Smart                           - disabled, port: 1883, bind: 0.0.0.0
                      system.adapter.netatmo.0                : netatmo               : Strommix-Smart                           - disabled
                      system.adapter.ping.0                   : ping                  : Strommix-Smart                           - disabled
                      system.adapter.socketio.0               : socketio              : Strommix-Smart                           - disabled, port: 8084, bind: 0.0.0.0, run as: admin
                      system.adapter.tr-064.0                 : tr-064                : Strommix-Smart                           - disabled
                      system.adapter.vis.0                    : vis                   : Strommix-Smart                           - disabled
                      system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : Strommix-Smart                           - disabled
                      system.adapter.zwave2.0                 : zwave2                : Strommix-Smart                           - disabled
                    + instance is alive
                    berge
                    #90
                    wieso denn das?
                    da gehört 0.0.0.0 rein
                    das kommt dann wohl schon aus dem Backup.
                    Jetzt wo du wieder an den admin kommst, dort unbedingt in der Konfig 0.0.0.0 eingeben!
                    https://www.iobroker.net/#de/adapters/adapterref/iobroker.admin/README.md
                    (ist schon was älter, gilt aber immer noch)
                      wieso denn das?
                      Berges01B Offline
                      Berges01B Offline
                      Berges01
                      #91
                      @homoran said in Probleme beim Installieren von MQTT-Client:
                      wieso denn das?
                      Erledigt !
                      Danke !
                      F.B.
