  4. Probleme beim Installieren von MQTT-Client
91 Beiträge 5 Kommentatoren 11.3k Aufrufe 2 Beobachtet
  • Berges01B Berges01
    @thomas-braun said in Probleme beim Installieren von MQTT-Client:
    @berges01
    Quark.
    iobroker logs --watch
    funktioniert immer.
    2021-05-17 07:52:44.299  - info: info.0 (9571) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-05-17 07:52:44.303  - info: backitup.0 (10999) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-05-17 07:52:44.781  - info: host.Strommix-Smart instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2021-05-17 07:52:44.781  - info: host.Strommix-Smart instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2021-05-17 07:52:44.821  - info: host.Strommix-Smart instance system.adapter.info.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2021-05-17 07:52:44.826  - info: host.Strommix-Smart instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2021-05-17 07:52:44.827  - info: host.Strommix-Smart All instances are stopped.
    2021-05-17 07:52:44.898  - info: host.Strommix-Smart terminated
    2021-05-17 07:53:02.319  - info: host.DESKTOP-61ND8BH(SmartHome) iobroker.js-controller version 3.2.16 js-controller starting
    2021-05-17 07:53:02.320  - info: host.DESKTOP-61ND8BH(SmartHome) Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-05-17 07:53:02.321  - info: host.DESKTOP-61ND8BH(SmartHome) hostname: DESKTOP-61ND8BH(SmartHome), node: v12.22.1
    2021-05-17 07:53:02.321  - info: host.DESKTOP-61ND8BH(SmartHome) ip addresses: 192.168.2.50 2003:f0:3f44:2700:c600:adff:fe01:e510 fe80::c600:adff:fe01:e510
    2021-05-17 07:53:02.623  - info: host.DESKTOP-61ND8BH(SmartHome) connected to Objects and States
    2021-05-17 07:53:02.658  - info: host.DESKTOP-61ND8BH(SmartHome) added notifications configuration of host
    2021-05-17 07:53:02.861  - info: host.DESKTOP-61ND8BH(SmartHome) Delete host system.host.Strommix-Smart
    2021-05-17 07:53:02.901  - info: host.DESKTOP-61ND8BH(SmartHome) 17 instances found
    2021-05-17 07:53:02.905  - warn: host.DESKTOP-61ND8BH(SmartHome) does not start any instances on this host
    AlCalzoneA Offline
    AlCalzoneA Offline
    AlCalzone
    #80
    @berges01 sagte in Probleme beim Installieren von MQTT-Client:
    Der Hostname hat sich geändert und die Instanzen sind noch dem alten Hostnamen zugeordnet. Daher wird nichts gestartet.
    @apollon77 @Homoran ich bin hier grad ein bisschen eingerostet - habt ihr ggf. das richtige Kommando parat? War das iobroker host this?
    Berges01B 1 Antwort Letzte Antwort
    • AlCalzoneA AlCalzone
      Berges01B Offline
      Berges01B Offline
      Berges01
      #81
      @alcalzone said in Probleme beim Installieren von MQTT-Client:
      laut Hilfe müsste es so aussehen :
      iobroker host <hostname> Set host to given hostname
      "hostnahme = Neuer Name", meine Vermutung.
      Dann währe der Befehl :
      iobroker host Strommix-Smart
      Das tippe ich aber erst nach OK ein !
      F.B.
        #82
        @berges01
        iobroker host this
          @berges01
          iobroker host this
          Berges01B Offline
          Berges01B Offline
          Berges01
          #83
          iobroker host this
          berges01@Strommix-Smart:~$ iobroker host this
          Host "DESKTOP-61ND8BH(SmartHome)" successfully renamed to "Strommix-Smart".
          The host for instance "system.adapter.admin.0" was changed from "Strommix-Smart" to "Strommix-Smart".
          The host for instance "system.adapter.alexa2.0" was changed from "Strommix-Smart" to "Strommix-Smart".
          The host for instance "system.adapter.backitup.0" was changed from "Strommix-Smart" to "Strommix-Smart".
          The host for instance "system.adapter.cloud.0" was changed from "Strommix-Smart" to "Strommix-Smart".
          The host for instance "system.adapter.devices.0" was changed from "Strommix-Smart" to "Strommix-Smart".
          The host for instance "system.adapter.info.0" was changed from "Strommix-Smart" to "Strommix-Smart".
          The host for instance "system.adapter.iot.0" was changed from "Strommix-Smart" to "Strommix-Smart".
          The host for instance "system.adapter.javascript.0" was changed from "Strommix-Smart" to "Strommix-Smart".
          The host for instance "system.adapter.mqtt.0" was changed from "Strommix-Smart" to "Strommix-Smart".
          The host for instance "system.adapter.netatmo.0" was changed from "Strommix-Smart" to "Strommix-Smart".
          The host for instance "system.adapter.ping.0" was changed from "Strommix-Smart" to "Strommix-Smart".
          The host for instance "system.adapter.socketio.0" was changed from "Strommix-Smart" to "Strommix-Smart".
          The host for instance "system.adapter.tr-064.0" was changed from "Strommix-Smart" to "Strommix-Smart".
          The host for instance "system.adapter.vis.0" was changed from "Strommix-Smart" to "Strommix-Smart".
          The host for instance "system.adapter.web.0" was changed from "Strommix-Smart" to "Strommix-Smart".
          The host for instance "system.adapter.whatsapp-cmb.0" was changed from "Strommix-Smart" to "Strommix-Smart".
          The host for instance "system.adapter.zwave2.0" was changed from "Strommix-Smart" to "Strommix-Smart".
          F.B.
            iobroker host this
            #84
            @berges01
            iobroker restart
            Thomas BraunT Berges01B 2 Antworten Letzte Antwort
              @berges01
              iobroker restart
              #85
              Notiz an mich selbst:
              Den host change sieht man im log file
                @berges01
                iobroker restart
                Berges01B Offline
                Berges01B Offline
                Berges01
                #86
                iobroker restart
                AHHHHHHH
                Schau an da is er wieder !
                Instanzen sind da aber noch nicht aktiv.
                F.B.
                  iobroker restart
                  AHHHHHHH
                  #87
                  @berges01
                  Dann schau nochmal per
                  iobroker list instances
                  iobroker start admin
                    @berges01
                    Berges01B Offline
                    Berges01B Offline
                    Berges01
                    #88
                    berges01@Strommix-Smart:~$ iobroker list instances
                    + system.adapter.admin.0                  : admin                 : Strommix-Smart                           -  enabled, port: 8081, bind: 192.168.2.50, run as: admin
                    + system.adapter.alexa2.0                 : alexa2                : Strommix-Smart                           -  enabled
                    + system.adapter.backitup.0               : backitup              : Strommix-Smart                           -  enabled
                    + system.adapter.cloud.0                  : cloud                 : Strommix-Smart                           -  enabled
                      system.adapter.devices.0                : devices               : Strommix-Smart                           - disabled
                    + system.adapter.info.0                   : info                  : Strommix-Smart                           -  enabled
                    + system.adapter.iot.0                    : iot                   : Strommix-Smart                           -  enabled
                    + system.adapter.javascript.0             : javascript            : Strommix-Smart                           -  enabled
                    + system.adapter.mqtt.0                   : mqtt                  : Strommix-Smart                           -  enabled, port: 1883, bind: 0.0.0.0
                    + system.adapter.netatmo.0                : netatmo               : Strommix-Smart                           -  enabled
                    + system.adapter.ping.0                   : ping                  : Strommix-Smart                           -  enabled
                    + system.adapter.socketio.0               : socketio              : Strommix-Smart                           -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                      system.adapter.vis.0                    : vis                   : Strommix-Smart                           -  enabled
                    + system.adapter.web.0                    : web                   : Strommix-Smart                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : Strommix-Smart                           -  enabled
                    + system.adapter.zwave2.0                 : zwave2                : Strommix-Smart                           -  enabled
                    + instance is alive
                    code_text
                    F.B.
                      + instance is alive
                      code_text
                      Berges01B Offline
                      Berges01B Offline
                      Berges01
                      schrieb am zuletzt editiert von Berges01
                      #89
                      @berges01 said in Probleme beim Installieren von MQTT-Client:
                      + instance is alive
                      code_text
                      Adapter alle grün
                      z-wave wieder da und 2 Nodes funktionieren (mehr hatte dauert aber wenn 2 gehen)
                      Blockly alle da
                      Das scheind Gut gegangen zu sein !
                      Dann ist das jetzt auf einem Debian Server ohne Desktop.
                      Oh mann was machte ich nur ohne EUCH ?
                      Erst mal DANKE (Organisiert ein User-Treffen und ich werfe eine Runde Freibier) !!!
                      F.B.
                        @berges01
                        iobroker start web
                        berges01@Strommix-Smart:~$ iobroker start admin
                        berges01@Strommix-Smart:~$ iobroker start web
                        The adapter "web.0" was started.
                        und nix
                        berges01@Strommix-Smart:~$ ^C
                          system.adapter.alexa2.0                 : alexa2                : Strommix-Smart                           - disabled
                          system.adapter.cloud.0                  : cloud                 : Strommix-Smart                           - disabled
                          system.adapter.info.0                   : info                  : Strommix-Smart                           - disabled
                          system.adapter.iot.0                    : iot                   : Strommix-Smart                           - disabled
                          system.adapter.javascript.0             : javascript            : Strommix-Smart                           - disabled
                          system.adapter.mqtt.0                   : mqtt                  : Strommix-Smart                           - disabled, port: 1883, bind: 0.0.0.0
                          system.adapter.netatmo.0                : netatmo               : Strommix-Smart                           - disabled
                          system.adapter.ping.0                   : ping                  : Strommix-Smart                           - disabled
                          system.adapter.socketio.0               : socketio              : Strommix-Smart                           - disabled, port: 8084, bind: 0.0.0.0, run as: admin
                          system.adapter.tr-064.0                 : tr-064                : Strommix-Smart                           - disabled
                          system.adapter.vis.0                    : vis                   : Strommix-Smart                           - disabled
                          system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : Strommix-Smart                           - disabled
                          system.adapter.zwave2.0                 : zwave2                : Strommix-Smart                           - disabled
                        + instance is alive
                        berge
                        #90
                        wieso denn das?
                        da gehört 0.0.0.0 rein
                        das kommt dann wohl schon aus dem Backup.
                        Jetzt wo du wieder an den admin kommst, dort unbedingt in der Konfig 0.0.0.0 eingeben!
                        https://www.iobroker.net/#de/adapters/adapterref/iobroker.admin/README.md
                        (ist schon was älter, gilt aber immer noch)
                          wieso denn das?
                          Berges01B Offline
                          Berges01B Offline
                          Berges01
                          #91
                          @homoran said in Probleme beim Installieren von MQTT-Client:
                          wieso denn das?
                          Erledigt !
                          Danke !
                          F.B.
