  4. [How-to] Node.js ioBroker richtig updaten-2021/22 Edition
    apollon77A
812 Beiträge 97 Kommentatoren 504.6k Aufrufe 83 Beobachtet
  • M marlan99
    @homoran äähm, ich hatte vorher node.js 14 am laufen und das update gemäss erstem post hier auf node-js 16 gemacht ?
    Oder ich verstehe deine Frage nicht ?
    curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash -
    sudo apt install -y nodejs
    nun sieht es so aus:
    pi@iobroker-slave:~ $ node -v
    v16.16.0
    pi@iobroker-slave:~ $ npm -v
    8.11.0
    Thomas BraunT
    Thomas BraunT
    #641
    @marlan99
    Zeig mal den output zu
    uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      @marlan99
      M
      M
      marlan99
      #642
      @thomas-braun said in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
      pi@iobroker-slave:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
      ln: failed to create symbolic link '/usr/bin/nodejs': File exists
      pi@iobroker-slave:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      armv7l
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v16.16.0
      v16.16.0
      8.11.0
      pi
      /home/pi
      Hit:1 http://archive.raspberrypi.org/debian buster InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
      Hit:3 https://repos.influxdata.com/debian buster InRelease
      Hit:4 https://deb.nodesource.com/node_16.x buster InRelease
      Reading package lists... Done
      Building dependency tree
      1 package can be upgraded. Run 'apt list --upgradable' to see it.
      nodejs:
        Installed: 16.16.0-deb-1nodesource1
        Candidate: 16.16.0-deb-1nodesource1
        Version table:
       *** 16.16.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
              100 /var/lib/dpkg/status
           10.24.0~dfsg-1~deb10u1 500
      • M marlan99
        host.iobroker-slave
        2022-07-21 15:24:20.079	info	Rebuild for adapter system.adapter.mbus.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
        host.iobroker-slave
        2022-07-21 15:24:20.079	error	instance system.adapter.mbus.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        host.iobroker-slave
        2022-07-21 15:24:20.079	error	Caught by controller[0]: }
        host.iobroker-slave
        2022-07-21 15:24:20.079	error	Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
        host.iobroker-slave
        2022-07-21 15:24:20.078	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:981:32) {
        host.iobroker-slave
        2022-07-21 15:24:20.078	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10)
        host.iobroker-slave
        2022-07-21 15:24:20.078	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1105:14)
        host.iobroker-slave
        2022-07-21 15:24:20.078	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/node-mbus/index.js:7:40)
        host.iobroker-slave
        2022-07-21 15:24:20.075	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/node-mbus/node_modules/bindings/bindings.js:112:48)
        host.iobroker-slave
        2022-07-21 15:24:20.075	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:102:18)
        host.iobroker-slave
        2022-07-21 15:24:20.075	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1005:19)
        host.iobroker-slave
        2022-07-21 15:24:20.074	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:822:12)
        host.iobroker-slave
        2022-07-21 15:24:20.074	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:981:32)
        host.iobroker-slave
        2022-07-21 15:24:20.074	error	Caught by controller[0]: at Object.Module._extensions..node (node:internal/modules/cjs/loader:1189:18)
        host.iobroker-slave
        2022-07-21 15:24:20.074	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
        host.iobroker-slave
        2022-07-21 15:24:20.074	error	Caught by controller[0]: NODE_MODULE_VERSION 93. Please try re-compiling or re-installing
        host.iobroker-slave
        2022-07-21 15:24:20.074	error	Caught by controller[0]: NODE_MODULE_VERSION 83. This version of Node.js requires
        host.iobroker-slave
        2022-07-21 15:24:20.074	error	Caught by controller[0]: was compiled against a different Node.js version using
        host.iobroker-slave
        2022-07-21 15:24:20.074	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/node-mbus/build/Release/mbus.node'
        host.iobroker-slave
        2022-07-21 15:24:20.073	error	Caught by controller[0]: ^
        host.iobroker-slave
        2022-07-21 15:24:20.073	error	Caught by controller[0]: throw e;
        host.iobroker-slave
        2022-07-21 15:24:20.073	error	Caught by controller[0]: /opt/iobroker/node_modules/node-mbus/node_modules/bindings/bindings.js:121
        Dies ist mein output im log
        apollon77A
        apollon77A
        #643
        @marlan99 sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
        Naja in dem Fall meckert er über das native node_mbus und nicht über serialport ...
        also (blöd das der rebuild net tut)
        cd /opt/iobroker/node_modules/node-mbus/
        npm rebuild
        oder wenn das nicht tat "npm install"
        PS: Bzw kannst gern mal das volle ipbroker log aller drei rebuild versuche posten. Welcher jscontroller ist eim EInsatz?
        • apollon77A apollon77
          npm rebuild
          #644
          @apollon77 sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
          Hat er ja schon gemacht. War die Ausführung korrekt?
          habe ich auch wie Eingangs erwähnt versucht das Problem manuell zu lösen und im Verzeichnis
          den Befehl:
          ausgeführt
            den Befehl:
            ausgeführt
            apollon77A
            apollon77A
            #645
            @homoran Da ist ein node_modules am Ende zuviel ...
              #646
              @homoran Da ist ein node_modules am Ende zu viel ...
              • M
                M
                marlan99
                schrieb am zuletzt editiert von marlan99
                #647
                hierbei bekomme ich folgenden Output:
                js-controller version : 4.0.23
                npm rebuild
                pi@iobroker-slave:/opt/iobroker/node_modules/node-mbus $ npm rebuild
                npm ERR! code 1
                npm ERR! path /opt/iobroker/node_modules/node-mbus
                npm ERR! command failed
                npm ERR! command sh -c node-gyp rebuild
                npm ERR! node:internal/modules/cjs/loader:936
                npm ERR!   throw err;
                npm ERR!   ^
                npm ERR!
                npm ERR! Error: Cannot find module 'object-assign'
                npm ERR! Require stack:
                npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/render-template.js
                npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/plumbing.js
                npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/index.js
                npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/npmlog/log.js
                npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/lib/node-gyp.js
                npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js
                npm ERR!     at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
                npm ERR!     at Function.Module._load (node:internal/modules/cjs/loader:778:27)
                npm ERR!     at Module.require (node:internal/modules/cjs/loader:1005:19)
                npm ERR!     at require (node:internal/modules/cjs/helpers:102:18)
                npm ERR!     at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/render-template.js:4:20)
                npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1105:14)
                npm ERR!     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10)
                npm ERR!     at Module.load (node:internal/modules/cjs/loader:981:32)
                npm ERR!     at Function.Module._load (node:internal/modules/cjs/loader:822:12)
                npm ERR!     at Module.require (node:internal/modules/cjs/loader:1005:19) {
                npm ERR!   code: 'MODULE_NOT_FOUND',
                npm ERR!   requireStack: [
                npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/render-template.js',
                npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/plumbing.js',
                npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/index.js',
                npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/npmlog/log.js',
                npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/lib/node-gyp.js',
                npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js'
                npm ERR!   ]
                npm ERR! }
                npm ERR!     /home/iobroker/.npm/_logs/2022-07-21T13_44_59_646Z-debug-0.log
                bei "npm install" dann diesen output:
                pi@iobroker-slave:/opt/iobroker/node_modules/node-mbus $ npm install
                > node-mbus@2.0.0 install
                > node-gyp rebuild
                  throw err;
                Require stack:
                  requireStack: [
                npm ERR! code 1
                npm ERR!     /home/iobroker/.npm/_logs/2022-07-21T13_45_14_702Z-debug-0.log
                apollon77A Thomas BraunT 2 Antworten Letzte Antwort
                • M marlan99
                  npm rebuild
                  npm ERR! code 1
                  npm ERR!   throw err;
                  npm ERR!   ^
                  npm ERR!
                  npm ERR!   ]
                  npm ERR! }
                  > node-gyp rebuild
                    throw err;
                  Require stack:
                    requireStack: [
                  npm ERR! code 1
                  apollon77A
                  apollon77A
                  #648
                  @marlan99 ok, dann 'back to node js installarions prüfung mit Thomas Braun " ... da ist was broken in deiner installation von nodejs/npm
                  • M marlan99
                    npm rebuild
                    npm ERR! code 1
                    npm ERR!   throw err;
                    npm ERR!   ^
                    npm ERR!
                    npm ERR!   ]
                    npm ERR! }
                    > node-gyp rebuild
                      throw err;
                    Require stack:
                      requireStack: [
                    npm ERR! code 1
                    Thomas BraunT
                    Thomas BraunT
                    #649
                    @marlan99
                    Mal npm irgendwie manuell angepackt?
                    Per npm -g i npm oder so?
                    apt policy npm node-gyp
                      @marlan99
                      M
                      M
                      marlan99
                      #650
                      @thomas-braun wenn ich richtig verstehe soll ich die beiden Befehle ausführen? Manuell habe ich nie was verändert. Das gesamte System wurde mit node.js 12 aufgesetzt, einmal vor Monaten auf node.js 14 updated (null Probleme) und heute auf node.js 16.
                      Habe soeben node.js nochmal komplett neu installiert und habe dieselben Fehlermeldung wie oben.
                      Hier der output mit npm -g i npm
                      pi@iobroker-slave:/opt/iobroker/node_modules/node-mbus $ npm -g i npm
                      npm WARN config global `--global`, `--local` are deprecated. Use `--location=global` instead.
                      npm ERR! code EACCES
                      npm ERR! syscall rename
                      npm ERR! path /usr/lib/node_modules/npm
                      npm ERR! dest /usr/lib/node_modules/.npm-qUIFSsiV
                      npm ERR! errno -13
                      npm ERR! Error: EACCES: permission denied, rename '/usr/lib/node_modules/npm' -> '/usr/lib/node_modules/.npm-qUIFSsiV'
                      npm ERR!  [Error: EACCES: permission denied, rename '/usr/lib/node_modules/npm' -> '/usr/lib/node_modules/.npm-qUIFSsiV'] {
                      npm ERR!   errno: -13,
                      npm ERR!   code: 'EACCES',
                      npm ERR!   syscall: 'rename',
                      npm ERR!   path: '/usr/lib/node_modules/npm',
                      npm ERR!   dest: '/usr/lib/node_modules/.npm-qUIFSsiV'
                      npm ERR! }
                      npm ERR!
                      npm ERR! The operation was rejected by your operating system.
                      npm ERR! It is likely you do not have the permissions to access this file as the current user
                      npm ERR!
                      npm ERR! If you believe this might be a permissions issue, please double-check the
                      npm ERR! permissions of the file and its containing directories, or try running
                      npm ERR! the command again as root/Administrator.
                      npm ERR!     /home/iobroker/.npm/_logs/2022-07-21T14_13_53_258Z-debug-0.log
                      und hier der output vom Befehl apt policy npm node-gyp
                      pi@iobroker-slave:/opt/iobroker/node_modules/node-mbus $ apt policy npm node-gyp
                      npm:
                        Installed: (none)
                        Candidate: 5.8.0+ds6-4+deb10u2
                        Version table:
                           5.8.0+ds6-4+deb10u2 500
                      node-gyp:
                        Installed: (none)
                        Candidate: 3.8.0-6
                        Version table:
                           3.8.0-6 500
                      • M marlan99
                        npm ERR! errno -13
                        npm ERR! }
                        npm ERR!
                        npm ERR!
                        npm:
                          Installed: (none)
                          Version table:
                        node-gyp:
                          Installed: (none)
                          Candidate: 3.8.0-6
                          Version table:
                             3.8.0-6 500
                        #651
                        @marlan99 was machst du auf dem Slave?
                        bei richtiger Konfiguration des Multihost läuft alles über den Master
                          M
                          M
                          marlan99
                          #652
                          @homoran der heisst nur so. Sorry wenn das verwirrt.
                          Sind beides unabhängige ioBroker Instanzen auf je einem raspberry pi am laufen. Die handvoll Objekte welche ich auf dem anderen ioBroker benötige tausche ich via mqtt aus.
                          "Mein" Master ist ebenfalls bereits auf node.js 16 updated und dort laufen alle Adapter (auch der zigbee :-) )
                          der zweite Raspi hier (mit namen slave) hat nur eine handvoll Adapter drauf und hier kann nur der mbus nicht mehr gestartet werden
                          • M marlan99
                            npm ERR! errno -13
                            npm ERR! }
                            npm ERR!
                            npm ERR!
                            npm:
                              Installed: (none)
                              Version table:
                            node-gyp:
                              Installed: (none)
                              Candidate: 3.8.0-6
                              Version table:
                                 3.8.0-6 500
                            #653
                            das sollzest du ja auch gar nicht machen! ist böse!
                            Deswegen hat @thomas-braun ja gefragt ob du das vielleicht mal benutzt hattest
                              M
                              M
                              marlan99
                              #654
                              @homoran uups 👼
                              • M
                                M
                                marlan99
                                #655
                                nächster Versuch nun den Adapter komplett zu deinstallieren um ihn danach wieder erneut zu installieren ist nun ebenfalls fehlgeschlagen:
                                $ iobroker add mbus auto --host iobroker-slave
                                NPM version: 8.11.0
                                Installing iobroker.mbus@2.4.0... (System call)
                                host.iobroker-slave Cannot install iobroker.mbus@2.4.0: 1
                                ERROR: Process exited with code 25
                                • M marlan99
                                  NPM version: 8.11.0
                                  #656
                                  @marlan99 und mit --debug?
                                  aber die Frage ob npm richtig installiert ist, ist ja noch offen.
                                    M
                                    M
                                    marlan99
                                    #657
                                    @homoran habe soeben meinen test raspi verwendet um den mbus Adapter mit node.js 16 und npm 8.11 zu installieren.
                                    Läuft hier ohne Probleme (ok habe keinen serial Adapter dran, aber der Adapter lässt sich ohne Fehler starten.
                                    Aus meiner Sicht klar ein Installationsproblem auf meinem "slave".
                                    Ich werde den mal aus dem Backup neu aufsetzen. Da wird ja gemäss info heute auch bereits die node.js 16 verwendet
                                    • M
                                      M
                                      marlan99
                                      #658
                                      Hier noch die Ausgabe der Installation mit --debug
                                      pi@iobroker-slave:~ $ iobroker add mbus auto --debug
                                      NPM version: 8.11.0
                                      npm ERR! code 1
                                      npm ERR!   throw err;
                                      npm ERR!   ^
                                      npm ERR!
                                      npm ERR!   ]
                                      npm ERR! }
                                      npm ERR!     /home/iobroker/.npm/_logs/2022-07-21T14_54_53_188Z-debug-0.log
                                      • M marlan99
                                        #659
                                        aus meiner auch!
                                        das wird schneller gehen als den Fehler zu suchen.
                                          aus meiner auch!
                                          M
                                          M
                                          marlan99
                                          #660
                                          @homoran system komplett neu aufgesetzt und backup eingespielt. Läuft alles wie es soll.
                                          Keine Ahnung was das Problem war, aber jetzt ist es nicht mehr da.
                                          Danke euch allen für den Support heute Nachmittag
                                          84.0k
                                          1.4m
