  4. Zigbee: (12604) Device 'xxxxxxxx' announced itself
    6.3k
40 Beiträge 12 Kommentatoren 8.3k Aufrufe 11 Beobachtet
  • K kaifu
    @arteck
    Habe das gleiche Problem. Bei mir geht es um den 9290019758 (SML002). Die Warnung kommt genau seit dem letzten Update (Februar), davor problemlos.
    Hab deinen Vorschlag versucht. Der Sensor kann leider nicht neu angelernt werden und bleibt beim "announce"-Vorgang...
    Hast du noch eine Idee? Danke.
    zigbee.1	2021-04-13 12:22:57.929	warn	(12765) Device '0x001788010647b6f7' announced itself
    zigbee.1	2021-04-13 12:22:40.889	warn	(12765) Device '0x001788010647b6f7' announced itself
    zigbee.1	2021-04-13 12:20:54.806	warn	(12765) Device '0x001788010647b6f7' announced itself
    zigbee.1	2021-04-13 12:20:42.620	warn	(12765) Device '0x001788010647b6f7' announced itself
    zigbee.1	2021-04-13 12:20:25.563	info	(12765) Zigbee: stop joining
    zigbee.1	2021-04-13 12:20:21.357	warn	(12765) Device '0x001788010647b6f7' announced itself
    zigbee.1	2021-04-13 12:19:44.940	warn	(12765) Device '0x001788010647b6f7' announced itself
    zigbee.1	2021-04-13 12:19:24.292	info	(12765) Zigbee: allowing new devices to join.
    zigbee.1	2021-04-13 12:19:21.408	warn	(12765) Device '0x001788010647b6f7' announced itself
    zigbee.1	2021-04-13 12:19:15.803	warn	(12765) Device '0x001788010647b6f7' announced itself
    zigbee.1	2021-04-13 12:18:26.186	info	(12765) Zigbee: stop joining
    zigbee.1	2021-04-13 12:18:25.335	warn	(12765) Device '0x001788010647b6f7' announced itself
    zigbee.1	2021-04-13 12:18:19.007	warn	(12765) Device '0x001788010647b6f7' announced itself
    zigbee.1	2021-04-13 12:18:09.113	warn	(12765) Device '0x001788010647b6f7' announced itself
    zigbee.1	2021-04-13 12:17:58.721	warn	(12765) Device '0x001788010647b6f7' announced itself
    zigbee.1	2021-04-13 12:17:24.936	info	(12765) Zigbee: allowing new devices to join.
    zigbee.1	2021-04-13 12:15:51.931	warn	(12765) Device '0x001788010647b6f7' announced itself
    zigbee.1	2021-04-13 12:12:32.500	warn	(12765) Device '0x001788010647b6f7' announced itself
    zigbee.1	2021-04-13 12:08:44.497	warn	(12765) Device '0x001788010647b6f7' announced itself
    H4lunkE
    @kaifu
    Sind das nicht die bekannten Probleme mit den Hue Bewegungsmeldern? Hatte mit dem CC2652P und den Hue Indoor- und Outdoormeldern eigentlich nur solche Probleme. Manchmal nach Minuten, manchmal nach Tagen.
    K 1 Antwort Letzte Antwort
    • H H4lunkE
      @kaifu
      kaifu
      @h4lunke
      Nö, das Problem hatte ich eigentlich mit 2 verschiedenen Sticks gelöst (eigene Instanz an einem CC2531):
      im Forum aus 2020
      C 1 Antwort Letzte Antwort
      • K kaifu
        @h4lunke
        im Forum aus 2020
        cburghardt
        Ich kriege diese Meldung bei allen modkam zigbee Devices, egal ob sie direkt am Coordinator oder einem Router hängen. In der Shepherd DB sind sie korrekt aufgeführt.
        Ich hatte versucht sie neu anzulernen und auch bei offenem Anlernmodus aufzuwecken - kein Unterschied.
        Das Problem betrifft ausschließlich diese Geräte, somit vermute ich eher, dass es ein spezielles Verhalten der Firmware ist?
          Bibo*13
          gibt es denn mittlerweile einen Lösungsansatz für die Device announced itself Meldungen?
          Bei mir mir treten die jetzt über Wochen von den unterschiedlichsten Sensoren und auch Thermostaten auf.
          Es ist halt nervig. Ja ich könnte die Warnungen abstellen. Aber das ist doch nicht der Sinn davon.
          Für jeden Tipp der noch nicht hier gegeben wurde wäre ich sehr dankbar.
          • B Bibo*13
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            Die Untersuchung warum diese Meldungen verstärkt kommen ist aktuell wegen der herdsman Probleme zurück gestellt. das einzige was du tun kannst ist schauen ob ggf. das Funknetzwerk gestört wird, so das die Geräte sich vom Adapter abmelden.
            Bitte auch das Verhalten des "available" states betrachten.
            A.
            B S H U 4 Antworten Letzte Antwort
            • AsgothianA Asgothian
              A.
              Bibo*13
              @asgothian Ok. Danke. Dann schaun wir mal.
                A.
                S Nicht stören
                S Nicht stören
                stenmic
                @asgothian ein Lösung würde mich auch interessieren (nachdem die anderen Probleme gelöst sind)
                Habe dieses Phänomen auch und es tritt nur bei BWMs auf (HUE und Sonoff)
                  A.
                  hene42
                  @asgothian Hallo, bei mir das gleiche, HUE Bewegungsmelder.
                  Danke.
                  arteckA AsgothianA 2 Antworten Letzte Antwort
                  • H hene42
                    Danke.
                    arteckA Offline
                    arteckA Offline
                    arteck
                    @hene42 die hue bwm melden sich öffters vom Netz ab.. warum auch immer.. dann kommen die wieder.. ist bekannt
                    S A 2 Antworten Letzte Antwort
                    • H hene42
                      Danke.
                      AsgothianA Offline
                      AsgothianA Offline
                      Asgothian
                      @hene42
                      Kannst du bitte prüfen ob die Geräte über einen Router mit dem Koordinator verbunden sind.
                      A.
                      • arteckA arteck
                        S Nicht stören
                        S Nicht stören
                        stenmic
                        schrieb am zuletzt editiert von stenmic
                        @arteck es sind nicht nur die hue. Der Sonoff verhält sich auch so.
                        • arteckA arteck
                          A Online
                          A Online
                          Ahnungsbefreit
                          schrieb am zuletzt editiert von Ahnungsbefreit
                          @arteck das macht meiner auch. Die anderen BWM von Ikea und Lidl machen das nicht
                          • A Ahnungsbefreit
                            S Nicht stören
                            S Nicht stören
                            stenmic
                            @ahnungsbefreit wie ist der von Ikea von der Reaktionszeit. Bist du zufrieden.
                            A 1 Antwort Letzte Antwort
                            • S stenmic
                              A Online
                              A Online
                              Ahnungsbefreit
                              @stenmic Langsamer als die beiden anderen aber für eine einfache Lichtsteuerung reicht's
                              • H Offline
                                hene42
                                schrieb am zuletzt editiert von hene42
                                @asgothian said in Zigbee: (12604) Device 'xxxxxxxx' announced itself:
                                @hene42
                                A.
                                @asgothian Hallo, einer ist über Koordinator verbunden und einer direkt.
                                Danke.
                                  A.
                                  U Offline
                                  U Offline
                                  UnNamedGER
                                  Ich habe das selbe Problem mit einer Hue Lampe die bei mir an der Auffahrt ihre Dienste verrichtet und das "Announced itself" immer schön sichtbar macht indem sie mit voller Helligkeit leuchtet, obwohl sie gedimmt oder aus sein sollte
                                  A.
                                  Ich habe über Nacht versucht das Einschalten auf volle Helligkeit "abzufangen" indem ich nach einem geänderten "Available" state suche, leider taucht im log keine meiner Meldungen auf, die ich für den Fall eingestellt hatte
                                  (es ist die HueWhite_AuffahrtVorne, die ich zur besseren Sichtbarkeit etwas aus der mitte herrausgezogen habe)
                                  • U UnNamedGER
                                    A.
                                    arteckA Offline
                                    arteckA Offline
                                    arteck
                                    @unnamedger sagte in Zigbee: (12604) Device 'xxxxxxxx' announced itself:
                                    schreibst du auch was du gemacht hast oder sollen wir raten..
                                    U 1 Antwort Letzte Antwort
                                    • U UnNamedGER
                                      A.
                                      AsgothianA Offline
                                      AsgothianA Offline
                                      Asgothian
                                      @unnamedger
                                      • Wenn die Leuchte die Meldung mit "announced itself" mit "einschalten" quittiert, dann wurde die Leuchte zwischenzeitlich vom Strom getrennt, und dann neu eingeschaltet. Das ist prinzipiell erst einmal schlecht.
                                      • Es gibt für diese Leuchte (wahrscheinlich - es ist nicht klar welche Philips Leuchte das ist ) die Möglichkeit das Einschaltverhalten zu setzen. Dazu sind 2 Komponenten notwendig:
                                        -- der Payload, dokumentiert bei zigbee2mqtt.io (z.Bsp. hier)
                                        -- die Skriptfunktion SendTo mit sendToDevice, angewendet wie z.Bsp. hier
                                      damit kannst du dafür sorgen das die Lampe wenn sie wieder Strom bekommt mit genau der Helligkeit eingeschaltet wird die sie vorher hatte.
                                      A.
                                        @unnamedger
                                        A.
                                        arteckA Offline
                                        arteckA Offline
                                        arteck
                                        @asgothian sagte in Zigbee: (12604) Device 'xxxxxxxx' announced itself:
                                        Einschaltverhalten
                                        haben wir doch im Adapter meine oder (bin gerade nicht am Rechner)
                                        • arteckA arteck
                                          U Offline
                                          U Offline
                                          UnNamedGER
                                          schrieb am zuletzt editiert von UnNamedGER
                                          @arteck
                                          sorry, daran hatte ich nicht gedacht
                                          Für jeden Pups den das Script macht gibts einen Kommentar🙈
                                          Es ist eine HueWhite Ambiance
                                          das mit dem einschaltverhalten muss ich heute abend mal einstellen, das kannte ich noch nicht
                                          Da ich im moment alleine im haus bin sollte über nacht der Strom angeblieben sein, es ist auch das einzige Gerät, dass sich in der Nacht einige male neu angemeldet hat
                                          Danke für die Schnellen Antworten, wenn ich die Lampe dazu bringe nicht mehr dauernd auf volle Helligkeit zu gehen ist mir schon sehr geholfen
