  4. Adapter startet nicht nach update, javascript und systeminfo
71 Beiträge 8 Kommentatoren 4.4k Aufrufe 5 Beobachtet
  • SMSS Offline
    SMSS Offline
    SMS
    Hi ,
    Dachte ich aktualisiere mal den JS controller von 3.1.6 auf 3.2.16. Leider funktionieren jetzt die Adapter javascript und systeminfo nicht mehr.
    Im LOG steht bei javascript:
    javascript.2	2021-02-22 10:05:38.823	error	(3272) ReplyError: Error scan NOT SUPPORTED at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12) at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302
    javascript.2	2021-02-22 10:05:38.822	error	(3272) Error: Error scan NOT SUPPORTED
    javascript.2	2021-02-22 10:05:38.822	error	(3272) An error happened which is most likely from one of your scripts, but the originating script could not be detected.
    javascript.2	2021-02-22 10:05:38.772	info	(3272) requesting all objects
    javascript.2	2021-02-22 10:05:38.771	info	(3272) requesting all states
    javascript.2	2021-02-22 10:05:38.646	info	(3272) starting. Version 4.8.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.20.2, js-controller: 3.2.16
    bei systeminfo:
    systeminfo.2	2021-02-22 09:58:18.654	warn	(2020) Terminated (UNCAUGHT_EXCEPTION): Without reason
    systeminfo.2	2021-02-22 09:58:18.653	info	(2020) terminating
    systeminfo.2	2021-02-22 09:58:18.635	error	(2020) Error scan NOT SUPPORTED
    systeminfo.2	2021-02-22 09:58:18.634	error	(2020) ReplyError: Error scan NOT SUPPORTED at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12) at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302
    systeminfo.2	2021-02-22 09:58:18.633	error	(2020) uncaught exception: Error scan NOT SUPPORTED
    systeminfo.2	2021-02-22 09:58:18.607	warn	(2020) adapter.objects.getObjectList is deprecated, and will be removed in the future. Please use adapter.getObjectList/Async. Report this to Developer!
    systeminfo.2	2021-02-22 09:58:18.574	info	(2020) starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.systeminfo, node: v12.20.2, js-controller: 3.2.16
    Folgendes habe ich schon gemacht:
    "iobroker update" und dann "iobroker upgrade self"
    danach "curl -sL https://iobroker.net/fix.sh | bash -"
    zu guter letzt mal ein "sudo apt-get update" und "sudo apt-get full-upgrade"
    Naja, vermutlich irgendwie die falsche Reihenfolge !? Dachte ich fange mit den updates an einem Slave an wo es nicht so schlimm ist wenn was nicht funktioniert. Und schon ist es passiert ...😞
    Danke!
    ostseereiterO Meister MopperM HomoranH 3 Antworten Letzte Antwort
    • SMSS SMS
      Hi ,
      bei systeminfo:
      Danke!
      ostseereiterO Offline
      ostseereiter
      @sms
      ich mache wenn überhaupt ein update gemacht werden muss dann so
      update js controller
      apt-get update && apt-get upgrade -y
      cd /opt/iobroker
      iobroker stop
      ps auxww|grep io
      ps auxww|grep backup
      sudo iobroker update
      sudo iobroker upgrade self
      sudo iobroker start
      da der JS Controller wohl immer noch irgendwo Probleme macht werde ich mein System noch nicht machen.
      Gruß OSR
      Plattform
      Linux x64 CPUs2 AMD G-T56N Processor 1646 MHz 8GB RAM
      FredFF 1 Antwort Letzte Antwort
      • SMSS SMS
        Hi ,
        bei systeminfo:
        Danke!
        Meister MopperM Offline
        Meister Mopper
        @sms sagte in Adapter startet nicht nach update, javascript und systeminfo:
        Genau das soll man ja gemäß Anleitung nicht tun, wenn man von 3.1.x kommt. Dann immer erst den master ...
        Proxmox und HA ...
        SMSS 1 Antwort Letzte Antwort
        • wendy2702W Offline
          wendy2702W Offline
          wendy2702
          Hast du ein Backup von allen installationen?
          • SMSS SMS
            Hi ,
            bei systeminfo:
            Danke!
            Da wirst du wohl nicht mehr umhinkommen, alle deine Scripte zu testen
            (wenn die anderen Punkte abgearbeitet sind)
            • ostseereiterO ostseereiter
              @sms
              cd /opt/iobroker
              iobroker stop
              ps auxww|grep io
              sudo iobroker start
              FredFF Offline
              FredFF Offline
              FredF
              Most Active Forum Testing
              @ostseereiter sagte in Adapter startet nicht nach update, javascript und systeminfo:
              @sms
              cd /opt/iobroker
              iobroker stop
              ps auxww|grep io
              sudo iobroker start
              OT: Bitte beachten:
              Alle ioBroker Befehle werden ohne sudo ausgeführt!
              • FredFF FredF
                @sms
                cd /opt/iobroker
                iobroker stop
                ps auxww|grep io
                sudo iobroker start
                OT: Bitte beachten:
                @ostseereiter
                @fredf sagte in Adapter startet nicht nach update, javascript und systeminfo:
                OT: Bitte beachten:
                korrekt!
                Aber der apt Befehl 😂
                Ist da jemand als root unterwegs?
                  @ostseereiter
                  OT: Bitte beachten:
                  korrekt!
                  Das würde dann auch die geäußerte Zurückhaltung bei Updates erklären.
                  Wenn man es grundsätzlich falsch handhabt (per root shell), dann kommt da auch nix stabiles bei raus.
                  ostseereiterO 1 Antwort Letzte Antwort
                    SMSS Offline
                    SMSS Offline
                    SMS
                    @meister-mopper
                    laut: https://forum.iobroker.net/topic/26759/js-controller-2-jetzt-für-alle-im-stable
                    ... Reihenfolge: Slave-Systeme zuerst aktualisieren! Master zuletzt!
                    @wendy2702
                    Ich hatte mal gefragt ob auch auf den Slaves backitup laufen muss, leider darauf keine Antwort bekommen. Da habe ich es ausprobiert und das backup vom Slave war genauso groß wie das des Masters. Daraufhin mache ich nur backups vom Master
                    @Homoran
                    welche anderen Punkte?
                    Thomas BraunT HomoranH wendy2702W 3 Antworten Letzte Antwort
                    • SMSS SMS
                      @meister-mopper
                      @wendy2702
                      @Homoran
                      @sms @Meister-Mopper
                      Hängt von den verwendeten Versionen ab.
                      Aus dem Change Log:
                      ACHTUNG: MULTIHOST-SYSTEME REIHENFOLGEN BEACHTEN!
                      Bei einem Multi-Host-System, welches auf js-controller 2.2 oder 3.1 läuft ist es beim Update auf Version 3.2 nötig, zuerst das Master-System zu aktualisieren. Der Master muss dann wieder gestartet werden. Die Slaves werden danach aktualisiert!
                      Bei Updates von Master/Slave-Systemen mit js-controller 1.5 oder früher auf die 3.2 müssen zwingend zuerst die Slaves und der Master als letztes aktualisiert werden. Beim Slave Update muss der alte master aber noch laufen. Die Slaves bleiben nach dem Update offline und können sich nicht zum Master verbinden und werden erst wieder funktionieren wenn auch der Master auf die 3.2 aktualisiert wurde!
                      • SMSS SMS
                        @meister-mopper
                        @wendy2702
                        @Homoran
                        Das gilt für die v2 und ist von 2019! inzwischen sind wir auch bei der V3.2!
                        Da gilt jetzt
                        https://forum.iobroker.net/topic/41029/js-controller-3-2-jetzt-im-latest
                        Dann ist das an mir vorbeigegangen, diese Frage habe ich schon gefühlt 1000x beantwortet
                        Im Masterbackup ist die Konfiguration der Instanzen des Slaves mit enthalten.
                        Voraussetzung ist natürlich eine korrekte Multihost-Installation
                        Die der anderen Helfenden
                        • SMSS SMS
                          @meister-mopper
                          @wendy2702
                          @Homoran
                          wendy2702W Offline
                          wendy2702W Offline
                          wendy2702
                          @sms Du hast leider in die Falsche Anleitung geschaut:
                          https://forum.iobroker.net/topic/42385/js-controller-3-2-jetzt-im-stable
                          Bist ja beim JS Controller mit der 3.x
                          Ja. Viel Möglichkeiten hast du aus meiner Sicht eh nicht mehr ohne Backup vom Slave.
                          ich würde dann jetzt mal den Master upgrade und schauen woe es danach aussieht.
                          EDIT: @Homoran war schneller
                            Da gilt jetzt
                            wendy2702W Offline
                            wendy2702W Offline
                            wendy2702
                            @homoran sagte in Adapter startet nicht nach update, javascript und systeminfo:
                            Wie stellt man dann einen Slave wieder her wenn nur dieser ein Problem hatte?
                            • wendy2702W wendy2702
                              @wendy2702 sagte in Adapter startet nicht nach update, javascript und systeminfo:
                              Gute Frage!
                              Weiß ich nicht ;-) Ich war immer der Meinung dass nach der erfolgreichen Neuverbindung dies "automatisch" passiert.
                              Mit einem iobroker upload all sollte es aber IMHO erledigt werden
                              "Schlimmstenfalls" müsste ein erneutes Restore auf dem Master das erledigen
                              SMSS wendy2702W 2 Antworten Letzte Antwort
                                Gute Frage!
                                SMSS Offline
                                SMSS Offline
                                SMS
                                leider finde ich keine anderen Punkte außer die Frage nach einem backup ...
                                Ich habe ein backup vom Master, welches heute Nacht um 1:30Uhr gemacht wurde. Sprich wenn ich das auf dem Master über den Adapter backitup aufspiele sollte es wieder funktionieren?
                                  Gute Frage!
                                  wendy2702W Offline
                                  wendy2702W Offline
                                  wendy2702
                                  @homoran OK.
                                  Ich habe bisher immer einzelne Backups Master und Slave gesichert und meine Rechner auch damit einzeln wieder hergestellt.
                                  @apollon77 : Weisst du das--> Reicht es bei Master-Slave ein Backup vom Master zu haben um einen Slave wieder herstellen zu können und wenn ja, wie stelle ich dann einen Slave richtig wieder her?
                                    SMSS Offline
                                    SMSS Offline
                                    SMS
                                    @wendy2702
                                    naja, die Anleitung wurde mir auf der host Seite angeboten, allerdings stimmt dass das ein alter Eintrag war ...
                                    • SMSS SMS
                                      wendy2702W Offline
                                      wendy2702W Offline
                                      wendy2702
                                      @sms Auch wenn die Frage nicht am mich geht.
                                      Glaube da sind wir uns aktuell nicht hundert prozent sicher.
                                      Ich würde, bevor ich das mache erstmal den Master auf den neuen JS updaten, Backup Einspielen kann man immer noch.
                                      Aber nur meine Meinung
                                      • SMSS SMS
                                        @wendy2702
                                        klar, der kann ja nicht allzuweit in die Zukunft sehen 😂
                                        Ich habe es immer anders herum gemacht:
                                        restore auf dem Master und die Slaves wurden auch wieder hergestellt
                                        doch: js-controller auf dem Master upgraden
                                        wendy2702W SMSS 2 Antworten Letzte Antwort
                                          wendy2702W Offline
                                          wendy2702W Offline
                                          wendy2702
                                          @homoran Hm,
                                          aber wenn der Master doch noch Fehlerfrei läuft, warum dann da ein restore machen?
                                          Oder skippt der Restore Prozess alles auf dem Master was noch vorhanden ist?
