  4. Adapter startet nicht nach update, javascript und systeminfo
71 Beiträge 8 Kommentatoren 4.4k Aufrufe 5 Beobachtet
  • wendy2702W Online
    wendy2702W Online
    Hast du ein Backup von allen installationen?
    • SMSS SMS
      Hi ,
      Dachte ich aktualisiere mal den JS controller von 3.1.6 auf 3.2.16. Leider funktionieren jetzt die Adapter javascript und systeminfo nicht mehr.
      Im LOG steht bei javascript:
      javascript.2	2021-02-22 10:05:38.823	error	(3272) ReplyError: Error scan NOT SUPPORTED at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12) at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302
      javascript.2	2021-02-22 10:05:38.822	error	(3272) Error: Error scan NOT SUPPORTED
      javascript.2	2021-02-22 10:05:38.822	error	(3272) An error happened which is most likely from one of your scripts, but the originating script could not be detected.
      javascript.2	2021-02-22 10:05:38.772	info	(3272) requesting all objects
      javascript.2	2021-02-22 10:05:38.771	info	(3272) requesting all states
      javascript.2	2021-02-22 10:05:38.646	info	(3272) starting. Version 4.8.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.20.2, js-controller: 3.2.16
      bei systeminfo:
      systeminfo.2	2021-02-22 09:58:18.654	warn	(2020) Terminated (UNCAUGHT_EXCEPTION): Without reason
      systeminfo.2	2021-02-22 09:58:18.653	info	(2020) terminating
      systeminfo.2	2021-02-22 09:58:18.635	error	(2020) Error scan NOT SUPPORTED
      systeminfo.2	2021-02-22 09:58:18.634	error	(2020) ReplyError: Error scan NOT SUPPORTED at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12) at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302
      systeminfo.2	2021-02-22 09:58:18.633	error	(2020) uncaught exception: Error scan NOT SUPPORTED
      systeminfo.2	2021-02-22 09:58:18.607	warn	(2020) adapter.objects.getObjectList is deprecated, and will be removed in the future. Please use adapter.getObjectList/Async. Report this to Developer!
      systeminfo.2	2021-02-22 09:58:18.574	info	(2020) starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.systeminfo, node: v12.20.2, js-controller: 3.2.16
      Folgendes habe ich schon gemacht:
      "iobroker update" und dann "iobroker upgrade self"
      danach "curl -sL https://iobroker.net/fix.sh | bash -"
      zu guter letzt mal ein "sudo apt-get update" und "sudo apt-get full-upgrade"
      Naja, vermutlich irgendwie die falsche Reihenfolge !? Dachte ich fange mit den updates an einem Slave an wo es nicht so schlimm ist wenn was nicht funktioniert. Und schon ist es passiert ...😞
      Danke!
      @sms sagte in Adapter startet nicht nach update, javascript und systeminfo:
      Da wirst du wohl nicht mehr umhinkommen, alle deine Scripte zu testen
      (wenn die anderen Punkte abgearbeitet sind)
      • ostseereiterO ostseereiter
        @sms
        ich mache wenn überhaupt ein update gemacht werden muss dann so
        update js controller
        apt-get update && apt-get upgrade -y
        cd /opt/iobroker
        iobroker stop
        ps auxww|grep io
        ps auxww|grep backup
        sudo iobroker update
        sudo iobroker upgrade self
        sudo iobroker start
        da der JS Controller wohl immer noch irgendwo Probleme macht werde ich mein System noch nicht machen.
        FredFF Online
        FredFF Online
        FredF
        Most Active Forum Testing
        @ostseereiter sagte in Adapter startet nicht nach update, javascript und systeminfo:
        @sms
        cd /opt/iobroker
        iobroker stop
        ps auxww|grep io
        sudo iobroker start
        OT: Bitte beachten:
        Alle ioBroker Befehle werden ohne sudo ausgeführt!
        • FredFF FredF
          @sms
          cd /opt/iobroker
          iobroker stop
          ps auxww|grep io
          sudo iobroker start
          OT: Bitte beachten:
          @ostseereiter
          @fredf sagte in Adapter startet nicht nach update, javascript und systeminfo:
          OT: Bitte beachten:
          korrekt!
          Aber der apt Befehl 😂
          Ist da jemand als root unterwegs?
            @ostseereiter
            OT: Bitte beachten:
            korrekt!
            Das würde dann auch die geäußerte Zurückhaltung bei Updates erklären.
            Wenn man es grundsätzlich falsch handhabt (per root shell), dann kommt da auch nix stabiles bei raus.
            ostseereiterO 1 Antwort Letzte Antwort
              Genau das soll man ja gemäß Anleitung nicht tun, wenn man von 3.1.x kommt. Dann immer erst den master ...
              SMSS Offline
              SMSS Offline
              SMS
              @meister-mopper
              laut: https://forum.iobroker.net/topic/26759/js-controller-2-jetzt-für-alle-im-stable
              ... Reihenfolge: Slave-Systeme zuerst aktualisieren! Master zuletzt!
              @wendy2702
              Ich hatte mal gefragt ob auch auf den Slaves backitup laufen muss, leider darauf keine Antwort bekommen. Da habe ich es ausprobiert und das backup vom Slave war genauso groß wie das des Masters. Daraufhin mache ich nur backups vom Master
              @Homoran
              welche anderen Punkte?
              Thomas BraunT HomoranH wendy2702W 3 Antworten Letzte Antwort
              • SMSS SMS
                @meister-mopper
                @wendy2702
                @Homoran
                @sms @Meister-Mopper
                Hängt von den verwendeten Versionen ab.
                Aus dem Change Log:
                ACHTUNG: MULTIHOST-SYSTEME REIHENFOLGEN BEACHTEN!
                Bei einem Multi-Host-System, welches auf js-controller 2.2 oder 3.1 läuft ist es beim Update auf Version 3.2 nötig, zuerst das Master-System zu aktualisieren. Der Master muss dann wieder gestartet werden. Die Slaves werden danach aktualisiert!
                Bei Updates von Master/Slave-Systemen mit js-controller 1.5 oder früher auf die 3.2 müssen zwingend zuerst die Slaves und der Master als letztes aktualisiert werden. Beim Slave Update muss der alte master aber noch laufen. Die Slaves bleiben nach dem Update offline und können sich nicht zum Master verbinden und werden erst wieder funktionieren wenn auch der Master auf die 3.2 aktualisiert wurde!
                • SMSS SMS
                  @meister-mopper
                  @wendy2702
                  @Homoran
                  Das gilt für die v2 und ist von 2019! inzwischen sind wir auch bei der V3.2!
                  Da gilt jetzt
                  https://forum.iobroker.net/topic/41029/js-controller-3-2-jetzt-im-latest
                  Dann ist das an mir vorbeigegangen, diese Frage habe ich schon gefühlt 1000x beantwortet
                  Im Masterbackup ist die Konfiguration der Instanzen des Slaves mit enthalten.
                  Voraussetzung ist natürlich eine korrekte Multihost-Installation
                  Die der anderen Helfenden
                  • SMSS SMS
                    @meister-mopper
                    @wendy2702
                    @Homoran
                    wendy2702W Online
                    wendy2702W Online
                    @sms Du hast leider in die Falsche Anleitung geschaut:
                    https://forum.iobroker.net/topic/42385/js-controller-3-2-jetzt-im-stable
                    Bist ja beim JS Controller mit der 3.x
                    Ja. Viel Möglichkeiten hast du aus meiner Sicht eh nicht mehr ohne Backup vom Slave.
                    ich würde dann jetzt mal den Master upgrade und schauen woe es danach aussieht.
                    EDIT: @Homoran war schneller
                    SMSS 1 Antwort Letzte Antwort
                      Da gilt jetzt
                      wendy2702W Online
                      wendy2702W Online
                      @homoran sagte in Adapter startet nicht nach update, javascript und systeminfo:
                      Wie stellt man dann einen Slave wieder her wenn nur dieser ein Problem hatte?
                      • wendy2702W wendy2702
                        @wendy2702 sagte in Adapter startet nicht nach update, javascript und systeminfo:
                        Gute Frage!
                        Weiß ich nicht ;-) Ich war immer der Meinung dass nach der erfolgreichen Neuverbindung dies "automatisch" passiert.
                        Mit einem iobroker upload all sollte es aber IMHO erledigt werden
                        "Schlimmstenfalls" müsste ein erneutes Restore auf dem Master das erledigen
                        SMSS wendy2702W 2 Antworten Letzte Antwort
                          Gute Frage!
                          SMSS Offline
                          SMSS Offline
                          SMS
                          leider finde ich keine anderen Punkte außer die Frage nach einem backup ...
                          Ich habe ein backup vom Master, welches heute Nacht um 1:30Uhr gemacht wurde. Sprich wenn ich das auf dem Master über den Adapter backitup aufspiele sollte es wieder funktionieren?
                            Gute Frage!
                            wendy2702W Online
                            wendy2702W Online
                            @homoran OK.
                            Ich habe bisher immer einzelne Backups Master und Slave gesichert und meine Rechner auch damit einzeln wieder hergestellt.
                            @apollon77 : Weisst du das--> Reicht es bei Master-Slave ein Backup vom Master zu haben um einen Slave wieder herstellen zu können und wenn ja, wie stelle ich dann einen Slave richtig wieder her?
                              SMSS Offline
                              SMSS Offline
                              SMS
                              @wendy2702
                              naja, die Anleitung wurde mir auf der host Seite angeboten, allerdings stimmt dass das ein alter Eintrag war ...
                              • SMSS SMS
                                wendy2702W Online
                                wendy2702W Online
                                @sms Auch wenn die Frage nicht am mich geht.
                                Glaube da sind wir uns aktuell nicht hundert prozent sicher.
                                Ich würde, bevor ich das mache erstmal den Master auf den neuen JS updaten, Backup Einspielen kann man immer noch.
                                Aber nur meine Meinung
                                • SMSS SMS
                                  @wendy2702
                                  klar, der kann ja nicht allzuweit in die Zukunft sehen 😂
                                  Ich habe es immer anders herum gemacht:
                                  restore auf dem Master und die Slaves wurden auch wieder hergestellt
                                  doch: js-controller auf dem Master upgraden
                                  wendy2702W SMSS 2 Antworten Letzte Antwort
                                    wendy2702W Online
                                    wendy2702W Online
                                    @homoran Hm,
                                    aber wenn der Master doch noch Fehlerfrei läuft, warum dann da ein restore machen?
                                    Oder skippt der Restore Prozess alles auf dem Master was noch vorhanden ist?
                                      @homoran Hm,
                                      damit das restore des slaves angestoßen wird
                                      auch wieder eine gute Frage.
                                      im log steht sonst etwas wie adapter xy does not exist, try to install. das müsste er jetzt ja nicht.
                                      Aber was wäre denn schlimm daran es nochmal drüber zu installieren?
                                      (Außer das die aktuellen Versionen einen höheren Contoller bräuchten ;-) )
                                        SMSS Offline
                                        SMSS Offline
                                        SMS
                                        @homoran OK
                                        Dann nochmal die Frage nach der richtigen Reihenfolge:
                                        iobroker stop
                                        iobroker update
                                        iobroker update self
                                        Ich würde in dem Zuge auch dem System ein update verpassen
                                        sudo apt-get update und dann sudo apt-get full-upgrade
                                        Dann ein reboot und iobroker sollte wieder starten. Danach das berühmte w wie warten ...
                                        Stimmt die Reihenfolge und vorallem die Befehle?
                                        HomoranH wendy2702W 2 Antworten Letzte Antwort
                                          wendy2702W Online
                                          wendy2702W Online
                                          Weiß nicht ob das schlimm wäre.
                                          Einen möglichen Punkt hast du selber erwähnt.
                                          Eine andere Möglichkeit wäre noch wenn man eine bestimmte Version eines Adapters behalten möchte, aus welchem Grund auch immer, wäre die dann wohl auch erstmal weg.
                                          Ich kenne es halt eigentlich so aus meinem Beruflichen Background das wir nie einen Restore auf einem System ausgeführt haben welches Fehlerfrei läuft. Hätten wir auch dem Kunden nur schwer erklären können das wir unter umständen eine ganze Stadt lahm legen bloss weil eine Strasse nicht geht. :-)
