  4. ZigBee neue Version 1.4.4
    6.7k
neue versionzigbeezigbee neue version 1.4.0
302 Beiträge 35 Kommentatoren 80.8k Aufrufe 36 Beobachtet
  • gelberlemmyG gelberlemmy
    @asgothian anbei das Log
    2021-02-23 16:37:06.461  - info: zigbee.0 (2009) Zigbee: allowing new devices to join.
    2021-02-23 16:38:07.715  - info: zigbee.0 (2009) Zigbee: stop joining
    2021-02-23 16:38:26.224  - info: zigbee.0 (2009) Zigbee: allowing new devices to join.
    2021-02-23 16:39:27.519  - info: zigbee.0 (2009) Zigbee: stop joining
    2021-02-23 16:39:36.055  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
    2021-02-23 16:39:36.082  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
    2021-02-23 16:39:36.079  - info: zigbee.0 (2009) Got terminate signal TERMINATE_YOURSELF
    2021-02-23 16:39:36.082  - info: zigbee.0 (2009) cleaned everything up...
    2021-02-23 16:39:36.087  - info: zigbee.0 (2009) Zigbee: disabling joining new devices.
    2021-02-23 16:39:36.501  - info: zigbee.0 (2009) terminating
    2021-02-23 16:39:36.502  - info: zigbee.0 (2009) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-02-23 16:39:36.687  - info: zwave2.0 (1901) Node 7 is now awake
    2021-02-23 16:39:37.139  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-02-23 16:39:39.157  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 3557
    2021-02-23 16:39:42.319  - info: zigbee.0 (3557) starting. Version 1.4.4 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.15.4, js-controller: 3.2.16
    2021-02-23 16:39:42.447  - info: zigbee.0 (3557) Starting Zigbee  npm ...
    2021-02-23 16:39:43.334  - info: zigbee.0 (3557) Installed Version: iobroker.zigbee@1.4.4
    2021-02-23 16:39:45.559  - info: zwave2.0 (1901) Node 7 interview completed, all values are updated
    2021-02-23 16:39:46.652  - info: zwave2.0 (1901) Node 7 is now asleep
    2021-02-23 16:40:00.066  - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 started with pid 3573
    2021-02-23 16:40:02.246  - info: netatmo-crawler.0 (3573) starting. Version 0.3.9 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v14.15.4, js-controller: 3.2.16
    2021-02-23 16:40:02.306  - info: netatmo-crawler.0 (3573) Getting data for stationid:70:ee:50:5f:37:56
    2021-02-23 16:40:03.350  - info: netatmo-crawler.0 (3573) Getting data for stationid:70:ee:50:36:ef:d2
    2021-02-23 16:40:04.196  - info: netatmo-crawler.0 (3573) Terminated (NO_ERROR): Without reason
    2021-02-23 16:40:04.736  - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 terminated with code 0 (NO_ERROR)
    2021-02-23 16:40:07.603  - info: octoprint.0 (1588) OctoPrint API not connected
    2021-02-23 16:40:11.422  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
    2021-02-23 16:40:11.430  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
    2021-02-23 16:40:11.430  - info: zigbee.0 (3557) Got terminate signal TERMINATE_YOURSELF
    2021-02-23 16:40:11.432  - info: zigbee.0 (3557) cleaned everything up...
    2021-02-23 16:40:11.435  - info: zigbee.0 (3557) Zigbee: disabling joining new devices.
    2021-02-23 16:40:11.437  - warn: zigbee.0 (3557) Failed to stop zigbee during startup
    2021-02-23 16:40:11.438  - info: zigbee.0 (3557) terminating
    2021-02-23 16:40:11.439  - info: zigbee.0 (3557) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-02-23 16:40:11.440  - error: zigbee.0 (3557) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2021-02-23 16:40:11.441  - error: zigbee.0 (3557) unhandled promise rejection: Cannot read property 'getEntries' of null
    2021-02-23 16:40:11.445  - error: zigbee.0 (3557) TypeError: Cannot read property 'getEntries' of null
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    #101
    @gelberlemmy
    Das Log besagt das du den Zigbee Adapter gestartet hast
    dann aber nach 17 sekunden von hand wieder angehalten hast.
    Da stellt sich die Frage warum Du das getan hast.
    A.
    gelberlemmyG 1 Antwort Letzte Antwort
    • AsgothianA Asgothian
      @gelberlemmy
      A.
      gelberlemmyG Offline
      gelberlemmy
      #102
      @asgothian hmmm. Also am Ende habe ich den Adapter angehalten, da er ja nicht grün geworden ist. Also läuft er aktuell nicht. Aber zwischendurch habe ich auch ab und an einmal den Adapter angehalten und neu gestartet, da er halt nicht grün wird und er die ganzen Error ausspuckt. Auch das ich die Einstellung speichere und er mir beim Verlassen sagt, dass die Änderungen verworfen werden. Aber trotzdem die Einstellungen behält.
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        #103
        @gelberlemmy
        Mach bitte folgendes:
        • zigbee adapter anhalten
        • zigbee stick abstöpseln
        • 60 sekunden warten
        • zigbee stick einstecken
        auf der Konsole verifizieren das der serielle Port verfügbar ist.
        • im ioBroker: Log löschen
        • zigbee Adapter auf debug stellen
        • zigbee Adapter starten
        • config Seite des Adapters aufrufen, Konfiguration eintragen (screenshot machen von den Einstellungen)
        • mit save & exit die Konfiguration beenden
        Log und screenshot posten.
        A.
        gelberlemmyG 2 Antworten Letzte Antwort
          @gelberlemmy
          A.
          gelberlemmy
          #104
          @asgothian alles klar. Danke.werde mich morgen einmal dran machen..👍
            arteckA Offline
            arteckA Offline
            arteck
            #105
            @gelberlemmy und nicht so hektisch vorgehen.... sachte.. stoppen... warten.. starten... gut Ding will weile haben..
            @Asgothian kansnt du mal verifizieren ... bei löschen der Geräte bekomm ich auch ein Timeout.. mit Meldung ..
            gelberlemmyG AsgothianA 2 Antworten Letzte Antwort
            • arteckA arteck
              gelberlemmy
              #106
              @arteck sagte in ZigBee neue Version 1.4.4:
              Moin ja mach ich. Habe mich getraut heute Morgen den Adapter wieder zu starten. Zumindest läuft der Adapter wieder. Ich bin nachher gespannt.
              • arteckA arteck
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                #107
                Beim löschen welcher Geräte ?
                A.
                • arteckA arteck
                  was ist neu
                  @Ilya : man kann externe konverter einbinmden für DIY Geräte
                  @Asgothian verbesserung des Pingprozesses - hier ist auch ein Button in den Objecten dazugekommen
                  @arteck Geräte können diert aus dem Converter gezogen werden auch wenn diese bei uns definiert sind
                  @Asgothian automatisches Löschen nicht gebrauchter Datenpunkte wenn man dem Ausschluss Tab nutzt
                  so uns nu lassen die Spiele beginnen
                  @Nachtrag da es hier zu vielen Fragen kommt
                  nach dem Update und nach dem Adapter start sind ALLE Geräte erstmal mit einer Link Quality von 10 in der Kacheln.. nach dem sich die Geräte gemeldet haben (Router) geht die Link Quality auf das was das Gerät lifert. bleibt die Link Quality auf 10 meldet sich das Gerät nicht, dass kann mehre Stunden dauern..also Geduld
                  ausser
                  die batteriebenen Geräte .. diese müssen sich erst melden. das dauert da sich diese selten Melden vor allem Aqara bzw. Xiaomi .. man kann es selbst antrigern per drücken des Knopfes am Gerät. erst dann sieht man die richtige Link Quality..
                  gelberlemmy
                  #108
                  @arteck habe einfach jetzt versucht beim laufenden Adapter ein Gerät anzulernen. Findet aber nix. Werde nachher einmal die Prozedur wie beschrieben machen
                  • K Kueppert
                    @asgothian @arteck soll ich ggf nen Github-Issue bei Koenkk aufmachen hierzu?
                    Kueppert
                    #109
                    @kueppert sagte in ZigBee neue Version 1.4.4:
                    bitte vergesst mich nicht. Wenn das ne längere Sache ist, schicke ich lieber die FB wieder zurück und schaue mich nach was anderem um...
                    • K Kueppert
                      AsgothianA Offline
                      AsgothianA Offline
                      Asgothian
                      #110
                      @kueppert Vergessen haben wir dich nicht, allerdings Buddel ich gerade an anderen Problemen, und werde mich der FB erst in einiger Zeit annehmen können.
                      A.
                        @gelberlemmy
                        A.
                        gelberlemmy
                        #111
                        @asgothian so habe es erledigt. Anbei die Bilder und das LOG. Auch jetzt wieder, dass er beim Speichern sagt, das die gemachten Änderungen verloren gehen, bleiben aber erhalten. Ich hatte voher wahlweise auch den Port aus dem Dropdown Menu genommen "ttyACM0". Habe mich aber an die Anleitung von Matthias Kleine in seinem Youtube Video gehalten und den Adapter wie im Screenshot zu sehen eingetragen. Ich hoffe es klärt sich auf. Danke noch einmal für Eure Arbeit und Hilfe.
                        2021-02-24 20_23_56-instances - ioBroker.jpg 2021-02-24 20_23_04-instances - ioBroker.jpg 2021-02-24 20_22_22-instances - ioBroker.jpg 2021-02-24 20_16_58-pi@raspberrypi_ ~.jpg 2021-02-24 20_14_38-pi@raspberrypi_ ~.jpg
                        zigbee.0	2021-02-24 20:24:21.900	debug	(27030) system.adapter.admin.0: logging true
                        zigbee.0	2021-02-24 20:23:42.273	error	at /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
                        zigbee.0	2021-02-24 20:23:42.273	error	at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
                        zigbee.0	2021-02-24 20:23:42.273	error	at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)
                        zigbee.0	2021-02-24 20:23:42.273	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12)
                        zigbee.0	2021-02-24 20:23:42.273	error	at new Promise (<anonymous>)
                        zigbee.0	2021-02-24 20:23:42.273	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71
                        zigbee.0	2021-02-24 20:23:42.273	error	at Generator.next (<anonymous>)
                        zigbee.0	2021-02-24 20:23:42.273	error	at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32)
                        zigbee.0	2021-02-24 20:23:42.273	error	(27030) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
                        zigbee.0	2021-02-24 20:23:42.272	error	(27030) Failed to start Zigbee
                        zigbee.0	2021-02-24 20:23:42.269	debug	(27030) zigbee-herdsman:adapter:zStack:znp:log Opening SerialPort with /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100KFN-if00 and {"baudRate":115200,"rtscts":
                        zigbee.0	2021-02-24 20:23:42.268	debug	(27030) zigbee-herdsman:controller:log Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"panID":6745,"extendedPanID":[220,221,221,2
                        zigbee.0	2021-02-24 20:23:42.267	debug	(27030) zigbee-herdsman:adapter Path '/dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100KFN-if00' is valid for 'ZStackAdapter'
                        zigbee.0	2021-02-24 20:23:42.064	info	(27030) Installed Version: iobroker.zigbee@1.4.4
                        zigbee.0	2021-02-24 20:23:42.040	debug	(27030) Starting zigbee-herdsman...
                        zigbee.0	2021-02-24 20:23:42.039	info	(27030) Starting Zigbee npm ...
                        zigbee.0	2021-02-24 20:23:42.039	info	(27030) Try to reconnect. 1 attempts left
                        zigbee.0	2021-02-24 20:23:32.036	error	at rejected (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/startZnp.js:25:65)
                        zigbee.0	2021-02-24 20:23:32.036	error	at Generator.throw (<anonymous>)
                        zigbee.0	2021-02-24 20:23:32.036	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/startZnp.js:172:23
                        zigbee.0	2021-02-24 20:23:32.036	error	(27030) Error: Coordinator failed to start, probably the panID is already in use, try a different panID or channel
                        zigbee.0	2021-02-24 20:23:32.034	error	(27030) Failed to start Zigbee
                        zigbee.0	2021-02-24 20:22:50.938	debug	(27030) sendTo "getChannels" to system.adapter.admin.0 from system.adapter.zigbee.0
                        zigbee.0	2021-02-24 20:22:32.250	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
                        zigbee.0	2021-02-24 20:22:32.249	debug	(27030) zigbee-herdsman:adapter:zStack:znp:AREQ <-- ZDO - stateChangeInd - {"state":8}
                        zigbee.0	2021-02-24 20:22:32.249	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 1 - 2 - 5 - 192 - [8] - 140
                        zigbee.0	2021-02-24 20:22:32.249	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,1,69,192,8,140]
                        zigbee.0	2021-02-24 20:22:32.248	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,1,69,192,8,140]
                        zigbee.0	2021-02-24 20:22:32.038	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
                        zigbee.0	2021-02-24 20:22:32.037	debug	(27030) zigbee-herdsman:adapter:zStack:znp:AREQ <-- APP_CNF - bdbComissioningNotifcation - {"status":1}
                        zigbee.0	2021-02-24 20:22:32.036	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 3 - 2 - 15 - 128 - [1,2,4] - 203
                        zigbee.0	2021-02-24 20:22:32.035	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,3,79,128,1,2,4,203]
                        zigbee.0	2021-02-24 20:22:32.034	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser <-- [79,128,1,2,4,203]
                        zigbee.0	2021-02-24 20:22:32.031	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,3]
                        zigbee.0	2021-02-24 20:22:32.030	debug	(27030) zigbee-herdsman:adapter:zStack:znp:SRSP <-- APP_CNF - bdbStartCommissioning - {"status":0}
                        zigbee.0	2021-02-24 20:22:32.029	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 1 - 3 - 15 - 5 - [0] - 107
                        zigbee.0	2021-02-24 20:22:32.028	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,1,111,5,0,107,254,3]
                        zigbee.0	2021-02-24 20:22:32.027	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,1,111,5,0,107,254,3]
                        zigbee.0	2021-02-24 20:22:28.598	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,1,47,5,4,47]
                        zigbee.0	2021-02-24 20:22:28.597	debug	(27030) zigbee-herdsman:adapter:zStack:znp:SREQ --> APP_CNF - bdbStartCommissioning - {"mode":4}
                        zigbee.0	2021-02-24 20:22:28.596	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
                        zigbee.0	2021-02-24 20:22:28.596	debug	(27030) zigbee-herdsman:adapter:zStack:znp:SRSP <-- APP_CNF - bdbSetChannel - {"status":0}
                        zigbee.0	2021-02-24 20:22:28.595	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 1 - 3 - 15 - 8 - [0] - 102
                        zigbee.0	2021-02-24 20:22:28.594	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,1,111,8,0,102]
                        zigbee.0	2021-02-24 20:22:28.594	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,1,111,8,0,102]
                        zigbee.0	2021-02-24 20:22:28.590	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,5,47,8,0,0,0,0,0,34]
                        zigbee.0	2021-02-24 20:22:28.589	debug	(27030) zigbee-herdsman:adapter:zStack:znp:SREQ --> APP_CNF - bdbSetChannel - {"isPrimary":0,"channel":0}
                        zigbee.0	2021-02-24 20:22:28.589	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
                        zigbee.0	2021-02-24 20:22:28.588	debug	(27030) zigbee-herdsman:adapter:zStack:znp:SRSP <-- APP_CNF - bdbSetChannel - {"status":0}
                        zigbee.0	2021-02-24 20:22:28.588	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 1 - 3 - 15 - 8 - [0] - 102
                        zigbee.0	2021-02-24 20:22:28.587	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,1,111,8,0,102]
                        zigbee.0	2021-02-24 20:22:28.586	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,1,111,8,0,102]
                        zigbee.0	2021-02-24 20:22:28.582	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,5,47,8,1,0,8,0,0,43]
                        zigbee.0	2021-02-24 20:22:28.581	debug	(27030) zigbee-herdsman:adapter:zStack:znp:SREQ --> APP_CNF - bdbSetChannel - {"isPrimary":1,"channel":2048}
                        zigbee.0	2021-02-24 20:22:28.580	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
                        zigbee.0	2021-02-24 20:22:28.580	debug	(27030) zigbee-herdsman:adapter:zStack:znp:SRSP <-- SYS - osalNvWrite - {"status":0}
                        zigbee.0	2021-02-24 20:22:28.579	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 1 - 3 - 1 - 9 - [0] - 105
                        zigbee.0	2021-02-24 20:22:28.578	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,1,97,9,0,105]
                        zigbee.0	2021-02-24 20:22:28.578	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,1,97,9,0,105]
                        zigbee.0	2021-02-24 20:22:28.561	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,20,33,9,98,0,0,16,1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13,77]
                        zigbee.0	2021-02-24 20:22:28.561	debug	(27030) zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - osalNvWrite - {"id":98,"configid":98,"len":16,"offset":0,"value":{"type":"Buffer","data":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]}}
                        zigbee.0	2021-02-24 20:22:28.560	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
                        zigbee.0	2021-02-24 20:22:28.559	debug	(27030) zigbee-herdsman:adapter:zStack:znp:SRSP <-- SYS - osalNvWrite - {"status":0}
                        zigbee.0	2021-02-24 20:22:28.559	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 1 - 3 - 1 - 9 - [0] - 105
                        zigbee.0	2021-02-24 20:22:28.558	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,1,97,9,0,105]
                        zigbee.0	2021-02-24 20:22:28.557	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,1,97,9,0,105]
                        zigbee.0	2021-02-24 20:22:28.542	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,12,33,9,45,0,0,8,220,221,221,221,221,221,221,221,0]
                        zigbee.0	2021-02-24 20:22:28.541	debug	(27030) zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - osalNvWrite - {"id":45,"len":8,"offset":0,"value":{"type":"Buffer","data":[220,221,221,221,221,221,221,221]}}
                        zigbee.0	2021-02-24 20:22:28.540	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
                        zigbee.0	2021-02-24 20:22:28.539	debug	(27030) zigbee-herdsman:adapter:zStack:znp:SRSP <-- SYS - osalNvWrite - {"status":0}
                        zigbee.0	2021-02-24 20:22:28.539	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 1 - 3 - 1 - 9 - [0] - 105
                        zigbee.0	2021-02-24 20:22:28.538	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,1,97,9,0,105]
                        zigbee.0	2021-02-24 20:22:28.537	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,1,97,9,0,105]
                        zigbee.0	2021-02-24 20:22:28.522	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,6,33,9,131,0,0,2,89,26,236]
                        zigbee.0	2021-02-24 20:22:28.521	debug	(27030) zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - osalNvWrite - {"id":131,"len":2,"offset":0,"value":{"type":"Buffer","data":[89,26]}}
                        zigbee.0	2021-02-24 20:22:28.520	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
                        zigbee.0	2021-02-24 20:22:28.519	debug	(27030) zigbee-herdsman:adapter:zStack:znp:SRSP <-- SYS - osalNvWrite - {"status":0}
                        zigbee.0	2021-02-24 20:22:28.518	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 1 - 3 - 1 - 9 - [0] - 105
                        zigbee.0	2021-02-24 20:22:28.517	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,1,97,9,0,105]
                        zigbee.0	2021-02-24 20:22:28.516	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,1,97,9,0,105]
                        zigbee.0	2021-02-24 20:22:28.501	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,8,33,9,132,0,0,4,0,8,0,0,168]
                        zigbee.0	2021-02-24 20:22:28.500	debug	(27030) zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - osalNvWrite - {"id":132,"len":4,"offset":0,"value":{"type":"Buffer","data":[0,8,0,0]}}
                        zigbee.0	2021-02-24 20:22:28.499	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
                        zigbee.0	2021-02-24 20:22:28.498	debug	(27030) zigbee-herdsman:adapter:zStack:znp:SRSP <-- SYS - osalNvWrite - {"status":0}
                        zigbee.0	2021-02-24 20:22:28.497	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 1 - 3 - 1 - 9 - [0] - 105
                        zigbee.0	2021-02-24 20:22:28.496	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,1,97,9,0,105]
                        zigbee.0	2021-02-24 20:22:28.495	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,1,97,9,0,105]
                        zigbee.0	2021-02-24 20:22:28.480	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,5,33,9,143,0,0,1,1,162]
                        zigbee.0	2021-02-24 20:22:28.479	debug	(27030) zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - osalNvWrite - {"id":143,"len":1,"offset":0,"value":{"type":"Buffer","data":[1]}}
                        zigbee.0	2021-02-24 20:22:28.477	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
                        zigbee.0	2021-02-24 20:22:28.477	debug	(27030) zigbee-herdsman:adapter:zStack:znp:SRSP <-- SYS - osalNvWrite - {"status":0}
                        zigbee.0	2021-02-24 20:22:28.476	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 1 - 3 - 1 - 9 - [0] - 105
                        zigbee.0	2021-02-24 20:22:28.475	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,1,97,9,0,105]
                        zigbee.0	2021-02-24 20:22:28.474	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,1,97,9,0,105]
                        zigbee.0	2021-02-24 20:22:28.459	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,5,33,9,99,0,0,1,0,79]
                        zigbee.0	2021-02-24 20:22:28.458	debug	(27030) zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - osalNvWrite - {"id":99,"len":1,"offset":0,"value":{"type":"Buffer","data":[0]}}
                        zigbee.0	2021-02-24 20:22:28.457	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
                        zigbee.0	2021-02-24 20:22:28.456	debug	(27030) zigbee-herdsman:adapter:zStack:znp:SRSP <-- SYS - osalNvWrite - {"status":0}
                        zigbee.0	2021-02-24 20:22:28.455	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 1 - 3 - 1 - 9 - [0] - 105
                        zigbee.0	2021-02-24 20:22:28.454	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,1,97,9,0,105]
                        zigbee.0	2021-02-24 20:22:28.453	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,1,97,9,0,105]
                        zigbee.0	2021-02-24 20:22:28.438	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,5,33,9,135,0,0,1,0,171]
                        zigbee.0	2021-02-24 20:22:28.437	debug	(27030) zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - osalNvWrite - {"id":135,"len":1,"offset":0,"value":{"type":"Buffer","data":[0]}}
                        zigbee.0	2021-02-24 20:22:28.435	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
                        zigbee.0	2021-02-24 20:22:28.435	debug	(27030) zigbee-herdsman:adapter:zStack:znp:AREQ <-- SYS - resetInd - {"reason":0,"transportrev":2,"productid":1,"majorrel":2,"minorrel":7,"hwrev":1}
                        zigbee.0	2021-02-24 20:22:28.434	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 6 - 2 - 1 - 128 - [0,2,1,2,7,1] - 192
                        zigbee.0	2021-02-24 20:22:28.433	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,6,65,128,0,2,1,2,7,1,192]
                        zigbee.0	2021-02-24 20:22:28.432	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser <-- [7,1,192]
                        zigbee.0	2021-02-24 20:22:28.430	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,6,65,128,0,2,1,2]
                        zigbee.0	2021-02-24 20:22:28.429	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,6,65,128,0,2,1,2]
                        zigbee.0	2021-02-24 20:22:26.170	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,1,65,0,1,65]
                        zigbee.0	2021-02-24 20:22:26.170	debug	(27030) zigbee-herdsman:adapter:zStack:znp:AREQ --> SYS - resetReq - {"type":1}
                        zigbee.0	2021-02-24 20:22:26.169	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
                        zigbee.0	2021-02-24 20:22:26.169	debug	(27030) zigbee-herdsman:adapter:zStack:znp:SRSP <-- SYS - osalNvWrite - {"status":0}
                        zigbee.0	2021-02-24 20:22:26.168	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 1 - 3 - 1 - 9 - [0] - 105
                        zigbee.0	2021-02-24 20:22:26.168	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,1,97,9,0,105]
                        zigbee.0	2021-02-24 20:22:26.167	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,1,97,9,0,105]
                        zigbee.0	2021-02-24 20:22:26.157	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,5,33,9,3,0,0,1,2,45]
                        zigbee.0	2021-02-24 20:22:26.156	debug	(27030) zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - osalNvWrite - {"id":3,"len":1,"offset":0,"value":{"type":"Buffer","data":[2]}}
                        zigbee.0	2021-02-24 20:22:26.156	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
                        zigbee.0	2021-02-24 20:22:26.155	debug	(27030) zigbee-herdsman:adapter:zStack:znp:AREQ <-- SYS - resetInd - {"reason":0,"transportrev":2,"productid":1,"majorrel":2,"minorrel":7,"hwrev":1}
                        zigbee.0	2021-02-24 20:22:26.155	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 6 - 2 - 1 - 128 - [0,2,1,2,7,1] - 192
                        zigbee.0	2021-02-24 20:22:26.154	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,6,65,128,0,2,1,2,7,1,192]
                        zigbee.0	2021-02-24 20:22:26.153	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser <-- [7,1,192]
                        zigbee.0	2021-02-24 20:22:26.152	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,6,65,128,0,2,1,2]
                        zigbee.0	2021-02-24 20:22:26.152	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,6,65,128,0,2,1,2]
                        zigbee.0	2021-02-24 20:22:24.617	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,1,65,0,1,65]
                        zigbee.0	2021-02-24 20:22:24.616	debug	(27030) zigbee-herdsman:adapter:zStack:znp:AREQ --> SYS - resetReq - {"type":1}
                        zigbee.0	2021-02-24 20:22:24.615	debug	(27030) zigbee-herdsman:adapter:zStack:startZnp Initialising coordinator
                        zigbee.0	2021-02-24 20:22:24.613	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
                        zigbee.0	2021-02-24 20:22:24.612	debug	(27030) zigbee-herdsman:adapter:zStack:znp:SRSP <-- SYS - osalNvRead - {"status":0,"len":2,"value":{"type":"Buffer","data":[88,26]}}
                        zigbee.0	2021-02-24 20:22:24.611	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 4 - 3 - 1 - 8 - [0,2,88,26] - 45
                        zigbee.0	2021-02-24 20:22:24.610	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,4,97,8,0,2,88,26,45]
                        zigbee.0	2021-02-24 20:22:24.609	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser <-- [45]
                        zigbee.0	2021-02-24 20:22:24.608	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,4,97,8,0,2,88,26]
                        zigbee.0	2021-02-24 20:22:24.607	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,4,97,8,0,2,88,26]
                        zigbee.0	2021-02-24 20:22:24.598	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,3,33,8,131,0,0,169]
                        zigbee.0	2021-02-24 20:22:24.597	debug	(27030) zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - osalNvRead - {"id":131,"len":2,"offset":0,"value":{"type":"Buffer","data":[89,26]}}
                        zigbee.0	2021-02-24 20:22:24.596	debug	(27030) zigbee-herdsman:adapter:zStack:startZnp Item 'panID' is invalid, got '{"type":"Buffer","data":[88,26]}', expected '{"type":"Buffer","data":[89,26]}'
                        zigbee.0	2021-02-24 20:22:24.595	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
                        zigbee.0	2021-02-24 20:22:24.594	debug	(27030) zigbee-herdsman:adapter:zStack:znp:SRSP <-- SYS - osalNvRead - {"status":0,"len":2,"value":{"type":"Buffer","data":[88,26]}}
                        zigbee.0	2021-02-24 20:22:24.593	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 4 - 3 - 1 - 8 - [0,2,88,26] - 45
                        zigbee.0	2021-02-24 20:22:24.592	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,4,97,8,0,2,88,26,45]
                        zigbee.0	2021-02-24 20:22:24.591	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser <-- [45]
                        zigbee.0	2021-02-24 20:22:24.590	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,4,97,8,0,2,88,26]
                        zigbee.0	2021-02-24 20:22:24.589	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,4,97,8,0,2,88,26]
                        zigbee.0	2021-02-24 20:22:24.579	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,3,33,8,131,0,0,169]
                        zigbee.0	2021-02-24 20:22:24.578	debug	(27030) zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - osalNvRead - {"id":131,"len":2,"offset":0,"value":{"type":"Buffer","data":[89,26]}}
                        zigbee.0	2021-02-24 20:22:24.577	debug	(27030) zigbee-herdsman:adapter:zStack:startZnp Item 'networkKey' is valid
                        zigbee.0	2021-02-24 20:22:24.576	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
                        zigbee.0	2021-02-24 20:22:24.575	debug	(27030) zigbee-herdsman:adapter:zStack:znp:SRSP <-- SYS - osalNvRead - {"status":0,"len":16,"value":{"type":"Buffer","data":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]}}
                        zigbee.0	2021-02-24 20:22:24.575	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 18 - 3 - 1 - 8 - [0,16,1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13] - 104
                        zigbee.0	2021-02-24 20:22:24.574	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,18,97,8,0,16,1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13,104]
                        zigbee.0	2021-02-24 20:22:24.573	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser <-- [5,7,9,11,13,15,0,2,4,6,8,10,12,13,104]
                        zigbee.0	2021-02-24 20:22:24.571	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,18,97,8,0,16,1,3]
                        zigbee.0	2021-02-24 20:22:24.571	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,18,97,8,0,16,1,3]
                        zigbee.0	2021-02-24 20:22:24.562	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,3,33,8,98,0,0,72]
                        zigbee.0	2021-02-24 20:22:24.562	debug	(27030) zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - osalNvRead - {"id":98,"configid":98,"len":16,"offset":0,"value":{"type":"Buffer","data":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]}}
                        zigbee.0	2021-02-24 20:22:24.561	debug	(27030) zigbee-herdsman:adapter:zStack:startZnp Item 'networkKeyDistribute' is valid
                        zigbee.0	2021-02-24 20:22:24.560	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
                        zigbee.0	2021-02-24 20:22:24.560	debug	(27030) zigbee-herdsman:adapter:zStack:znp:SRSP <-- SYS - osalNvRead - {"status":0,"len":1,"value":{"type":"Buffer","data":[0]}}
                        zigbee.0	2021-02-24 20:22:24.559	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 3 - 3 - 1 - 8 - [0,1,0] - 107
                        zigbee.0	2021-02-24 20:22:24.559	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,3,97,8,0,1,0,107]
                        zigbee.0	2021-02-24 20:22:24.558	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,3,97,8,0,1,0,107]
                        zigbee.0	2021-02-24 20:22:24.549	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,3,33,8,99,0,0,73]
                        zigbee.0	2021-02-24 20:22:24.549	debug	(27030) zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - osalNvRead - {"id":99,"len":1,"offset":0,"value":{"type":"Buffer","data":[0]}}
                        zigbee.0	2021-02-24 20:22:24.548	debug	(27030) zigbee-herdsman:adapter:zStack:startZnp Item 'channelList' is valid
                        zigbee.0	2021-02-24 20:22:24.548	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
                        zigbee.0	2021-02-24 20:22:24.547	debug	(27030) zigbee-herdsman:adapter:zStack:znp:SRSP <-- SYS - osalNvRead - {"status":0,"len":4,"value":{"type":"Buffer","data":[0,8,0,0]}}
                        zigbee.0	2021-02-24 20:22:24.547	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 6 - 3 - 1 - 8 - [0,4,0,8,0,0] - 99
                        zigbee.0	2021-02-24 20:22:24.546	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,6,97,8,0,4,0,8,0,0,99]
                        zigbee.0	2021-02-24 20:22:24.546	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser <-- [0,0,99]
                        zigbee.0	2021-02-24 20:22:24.545	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,6,97,8,0,4,0,8]
                        zigbee.0	2021-02-24 20:22:24.544	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,6,97,8,0,4,0,8]
                        zigbee.0	2021-02-24 20:22:24.535	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,3,33,8,132,0,0,174]
                        zigbee.0	2021-02-24 20:22:24.535	debug	(27030) zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - osalNvRead - {"id":132,"len":4,"offset":0,"value":{"type":"Buffer","data":[0,8,0,0]}}
                        zigbee.0	2021-02-24 20:22:24.534	debug	(27030) zigbee-herdsman:adapter:zStack:startZnp Item 'hasConfigured' is valid
                        zigbee.0	2021-02-24 20:22:24.533	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
                        zigbee.0	2021-02-24 20:22:24.533	debug	(27030) zigbee-herdsman:adapter:zStack:znp:SRSP <-- SYS - osalNvRead - {"status":0,"len":1,"value":{"type":"Buffer","data":[85]}}
                        zigbee.0	2021-02-24 20:22:24.532	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 3 - 3 - 1 - 8 - [0,1,85] - 62
                        zigbee.0	2021-02-24 20:22:24.532	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,3,97,8,0,1,85,62]
                        zigbee.0	2021-02-24 20:22:24.531	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,3,97,8,0,1,85,62]
                        zigbee.0	2021-02-24 20:22:24.516	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,3,33,8,96,0,0,74]
                        zigbee.0	2021-02-24 20:22:24.515	debug	(27030) zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - osalNvRead - {"id":96,"offset":0,"len":1,"value":{"type":"Buffer","data":[85]}}
                        zigbee.0	2021-02-24 20:22:24.514	debug	(27030) zigbee-herdsman:adapter:zStack:startZnp Item 'hasConfigured' is valid
                        zigbee.0	2021-02-24 20:22:24.513	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
                        zigbee.0	2021-02-24 20:22:24.513	debug	(27030) zigbee-herdsman:adapter:zStack:znp:SRSP <-- SYS - osalNvRead - {"status":0,"len":1,"value":{"type":"Buffer","data":[85]}}
                        zigbee.0	2021-02-24 20:22:24.512	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 3 - 3 - 1 - 8 - [0,1,85] - 62
                        zigbee.0	2021-02-24 20:22:24.511	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,3,97,8,0,1,85,62]
                        zigbee.0	2021-02-24 20:22:24.511	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,3,97,8,0,1,85,62]
                        zigbee.0	2021-02-24 20:22:24.494	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,3,33,8,96,0,0,74]
                        zigbee.0	2021-02-24 20:22:24.492	debug	(27030) zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - osalNvRead - {"id":96,"offset":0,"len":1,"value":{"type":"Buffer","data":[85]}}
                        zigbee.0	2021-02-24 20:22:24.491	debug	(27030) zigbee-herdsman:adapter:zStack:adapter Detected znp version 'zStack3x0' ({"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210120})
                        zigbee.0	2021-02-24 20:22:24.490	debug	(27030) zigbee-herdsman:adapter:zStack:adapter Adapter concurrent: 16
                        zigbee.0	2021-02-24 20:22:24.490	debug	(27030) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
                          AsgothianA Offline
                          AsgothianA Offline
                          Asgothian
                          #112
                          @gelberlemmy
                          Der Adapter beschwert sich darüber das es bereits ein Netz mit der von Dir eingetragenen PAN_ID gibt:
                          Das ist die Ursache deines Problems. Ich verstehe nicht wieso ich das aus dem Log heraus suchen muss.
                          Alle weiteren Fehler entstehen bei wiederholten Startversuchen.
                          Abhilfemassnahme: Alle Zigbee-Router (Lampen, Steckdosen, etc) stromlos machen, zigbee Adapter Starten, danach die Lampen, Steckdosen etc. wieder einschalten und das Netz einmal öffnen (pairing starten).. dann sollten alle router geräte vom Adapter erkannt und im Netz angemeldet werden.
                          A.
                          gelberlemmyG 3 Antworten Letzte Antwort
                            @gelberlemmy
                            A.
                            gelberlemmy
                            #113
                            @asgothian danke. Aber leider verstehe ich nur ein Bruchteil aus diesen LOGS. Aktuell habe ich noch eine Hue Bridge auf Kanal 25 laufen. An dem Adapter für IOBroker ist aktuell kein Gerät angemeldet. Habe jetzt PAN ID,Channel und Erweiterte PAN ID geändert. Leider erfolglos. Alle anderen Router die einmal angemeldet waren, sind jetzt aktuell an der Hue Bridge. Auch die Geräte, die aktuell an der Hue Bridge sind stromlos machen ? Aber was hat das mit der Meldung des nicht Speicherns auf sich ?
                            Noch einmal Danke für das schauen.
                            Gruß André
                              @gelberlemmy
                              A.
                              gelberlemmy
                              #114
                              @asgothian jetzt habe ich auch noch einmal geschaut nach dem Ändern.
                              zigbee.0	2021-02-24 21:09:06.849	error	(29726) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
                              Was will er mir damit sagen ? Port ist verfügbar. Habe noch einmal danach stromlos, angesteckt, geschaut ob Ports da sind........
                                #115
                                @gelberlemmy
                                Irgendwas greift auf den serialport bereits zu.
                                Läuft da evtl. deconz im Hintergrund schon?
                                systemctl status deconz deconz-gui
                                  @gelberlemmy
                                  gelberlemmy
                                  schrieb am zuletzt editiert von gelberlemmy
                                  #116
                                  @thomas-braun nein. Habe jetzt einmal die andere Portbezeichnung aus dem Dropdown Menu genommen. Jetzt habe ich wieder den Fehler den @Asgothian mir aufgezeigt hat, trotz der Änderung der PAN ID und des Channels. Würde da noch einmal eine Neuinstallation nützen. Aktuell ist dort ja nichts angemeldet.
                                    #117
                                    @gelberlemmy
                                    Du kannst auch mal mit (ich glaube)
                                    lsof /PFAD/ZUM/DEVICE
                                    schauen was da zugreift.
                                      @gelberlemmy
                                      gelberlemmy
                                      #118
                                      @thomas-braun danke
                                      schaue ich einmal
                                        @gelberlemmy
                                        A.
                                        gelberlemmy
                                        #119
                                        @asgothian so jetzt ist der Adapter wieder grün. Habe den Haken unter Einstellungen "Zigbee-herdsman Debug-Info " ausversehen gesetzt. Aber das der dann gar nicht mehr läuft ? Jetzt ist der Adapter wieder grün. Kann aber keine Geräte anmelden. Aus dem LOG werde ich nicht schlau.
                                        2021-02-24 21_25_50-instances - ioBroker.jpg 2021-02-24 21_21_48-instances - ioBroker.jpg
                                        zigbee.0	2021-02-24 21:33:01.283	debug	(30770) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
                                        zigbee.0	2021-02-24 21:33:01.282	debug	(30770) getBinding result: []
                                        zigbee.0	2021-02-24 21:33:01.244	debug	(30770) sendTo "getExclude" to system.adapter.admin.0 from system.adapter.zigbee.0
                                        zigbee.0	2021-02-24 21:33:01.236	debug	(30770) getExclude result: []
                                        zigbee.0	2021-02-24 21:33:01.111	debug	(30770) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.zigbee.0
                                        zigbee.0	2021-02-24 21:33:01.111	debug	(30770) getDevices result: [{"_id":"0x00124b00219fba18","icon":"img/unknown.png","paired":true,"info":{"type":"device","device":{"ID":1,"_type":"Coordinator","_ieeeAddr":"0x00124b00219fba18","_network
                                        zigbee.0	2021-02-24 21:33:01.098	debug	(30770) sendTo "listUart" to system.adapter.admin.0 from system.adapter.zigbee.0
                                        zigbee.0	2021-02-24 21:33:01.097	debug	(30770) List of ports: [{"comName":"/dev/ttyACM0"},{"comName":"/dev/ttyACM1"},{"comName":"/dev/ttyUSB0"},{"comName":"/dev/ttyACM2"},{"comName":"/dev/ttyAMA0"}]
                                        zigbee.0	2021-02-24 21:33:01.047	debug	(30770) sendTo "getMap" to system.adapter.admin.0 from system.adapter.zigbee.0
                                        zigbee.0	2021-02-24 21:33:01.046	debug	(30770) getMap result: {"lqis":[],"routing":[]}
                                        zigbee.0	2021-02-24 21:33:01.046	debug	(30770) Get map succeeded []
                                        zigbee.0	2021-02-24 21:33:01.046	debug	(30770) Routing table succeeded for 'Coordinator'
                                        zigbee.0	2021-02-24 21:33:01.045	debug	(30770) Routing for 'Coordinator': {"table":[]}
                                        zigbee.0	2021-02-24 21:33:01.038	debug	(30770) LQI succeeded for 'Coordinator'
                                        zigbee.0	2021-02-24 21:33:01.037	debug	(30770) sendTo "getGroups" to system.adapter.admin.0 from system.adapter.zigbee.0
                                        zigbee.0	2021-02-24 21:33:01.036	debug	(30770) getGroups result: {}
                                        zigbee.0	2021-02-24 21:33:01.035	debug	(30770) sendTo "getCoordinatorInfo" to system.adapter.admin.0 from system.adapter.zigbee.0
                                        zigbee.0	2021-02-24 21:33:01.034	debug	(30770) getCoorinatorInfo result: {"installSource":"iobroker.zigbee@1.4.4","channel":"14","port":"/dev/ttyACM0","type":"zStack3x0","revision":20210120,"version":"2-1.2.7.1."}
                                        zigbee.0	2021-02-24 21:33:01.023	debug	(30770) sendTo "getLibData" to system.adapter.admin.0 from system.adapter.zigbee.0
                                        zigbee.0	2021-02-24 21:32:59.264	debug	(30770) system.adapter.admin.0: logging true
                                        zigbee.0	2021-02-24 21:31:03.800	debug	(30770) sendTo "getExclude" to system.adapter.admin.0 from system.adapter.zigbee.0
                                        zigbee.0	2021-02-24 21:31:03.745	debug	(30770) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
                                        zigbee.0	2021-02-24 21:31:03.744	debug	(30770) getBinding result: []
                                        zigbee.0	2021-02-24 21:31:03.742	debug	(30770) getExclude result: []
                                        zigbee.0	2021-02-24 21:31:03.641	debug	(30770) sendTo "listUart" to system.adapter.admin.0 from system.adapter.zigbee.0
                                        zigbee.0	2021-02-24 21:31:03.640	debug	(30770) List of ports: [{"comName":"/dev/ttyACM0"},{"comName":"/dev/ttyACM1"},{"comName":"/dev/ttyUSB0"},{"comName":"/dev/ttyACM2"},{"comName":"/dev/ttyAMA0"}]
                                        zigbee.0	2021-02-24 21:31:03.530	debug	(30770) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.zigbee.0
                                        zigbee.0	2021-02-24 21:31:03.528	debug	(30770) getDevices result: [{"_id":"0x00124b00219fba18","icon":"img/unknown.png","paired":true,"info":{"type":"device","device":{"ID":1,"_type":"Coordinator","_ieeeAddr":"0x00124b00219fba18","_networ
                                        zigbee.0	2021-02-24 21:31:03.505	debug	(30770) sendTo "getMap" to system.adapter.admin.0 from system.adapter.zigbee.0
                                        zigbee.0	2021-02-24 21:31:03.504	debug	(30770) getMap result: {"lqis":[],"routing":[]}
                                        zigbee.0	2021-02-24 21:31:03.504	debug	(30770) Get map succeeded []
                                        zigbee.0	2021-02-24 21:31:03.503	debug	(30770) Routing table succeeded for 'Coordinator'
                                        zigbee.0	2021-02-24 21:31:03.502	debug	(30770) Routing for 'Coordinator': {"table":[]}
                                        zigbee.0	2021-02-24 21:31:03.496	debug	(30770) LQI succeeded for 'Coordinator'
                                        zigbee.0	2021-02-24 21:31:03.494	debug	(30770) sendTo "getGroups" to system.adapter.admin.0 from system.adapter.zigbee.0
                                        zigbee.0	2021-02-24 21:31:03.493	debug	(30770) getGroups result: {}
                                        zigbee.0	2021-02-24 21:31:03.493	debug	(30770) sendTo "getCoordinatorInfo" to system.adapter.admin.0 from system.adapter.zigbee.0
                                        zigbee.0	2021-02-24 21:31:03.492	debug	(30770) getCoorinatorInfo result: {"installSource":"iobroker.zigbee@1.4.4","channel":"14","port":"/dev/ttyACM0","type":"zStack3x0","revision":20210120,"version":"2-1.2.7.1."}
                                        zigbee.0	2021-02-24 21:31:03.486	debug	(30770) sendTo "getLibData" to system.adapter.admin.0 from system.adapter.zigbee.0
                                        zigbee.0	2021-02-24 21:30:49.362	debug	(30770) system.adapter.admin.0: logging false
                                        zigbee.0	2021-02-24 21:28:35.401	debug	(30770) system.adapter.admin.0: logging true
                                        zigbee.0	2021-02-24 21:28:27.651	debug	(30770) User stateChange zigbee.0.info.pairingMode {"val":false,"ack":false,"ts":1614198507640,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1614095083475}
                                        zigbee.0	2021-02-24 21:28:27.596	info	(30770) Zigbee: stop joining
                                        zigbee.0	2021-02-24 21:27:27.809	debug	(30770) system.adapter.admin.0: logging false
                                        zigbee.0	2021-02-24 21:27:26.333	debug	(30770) sendTo "letsPairing" to system.adapter.admin.0 from system.adapter.zigbee.0: Start pairing!
                                        zigbee.0	2021-02-24 21:27:26.331	info	(30770) Zigbee: allowing new devices to join.
                                        zigbee.0	2021-02-24 21:27:24.113	debug	(30770) sendTo "getExclude" to system.adapter.admin.0 from system.adapter.zigbee.0
                                        zigbee.0	2021-02-24 21:27:24.048	debug	(30770) getExclude result: []
                                        zigbee.0	2021-02-24 21:27:24.045	debug	(30770) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
                                        zigbee.0	2021-02-24 21:27:24.045	debug	(30770) getBinding result: []
                                        zigbee.0	2021-02-24 21:27:24.022	debug	(30770) sendTo "listUart" to system.adapter.admin.0 from system.adapter.zigbee.0
                                        zigbee.0	2021-02-24 21:27:24.021	debug	(30770) List of ports: [{"comName":"/dev/ttyACM0"},{"comName":"/dev/ttyACM1"},{"comName":"/dev/ttyUSB0"},{"comName":"/dev/ttyACM2"},{"comName":"/dev/ttyAMA0"}]
                                        zigbee.0	2021-02-24 21:27:23.868	debug	(30770) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.zigbee.0
                                        zigbee.0	2021-02-24 21:27:23.867	debug	(30770) getDevices result: [{"_id":"0x00124b00219fba18","icon":"img/unknown.png","paired":true,"info":{"type":"device","device":{"ID":1,"_type":"Coordinator","_ieeeAddr":"0x00124b00219fba18","_networ
                                        zigbee.0	2021-02-24 21:27:23.833	debug	(30770) sendTo "getMap" to system.adapter.admin.0 from system.adapter.zigbee.0
                                        zigbee.0	2021-02-24 21:27:23.831	debug	(30770) getMap result: {"lqis":[],"routing":[]}
                                        zigbee.0	2021-02-24 21:27:23.830	debug	(30770) Get map succeeded []
                                        zigbee.0	2021-02-24 21:27:23.829	debug	(30770) Routing table succeeded for 'Coordinator'
                                        zigbee.0	2021-02-24 21:27:23.827	debug	(30770) Routing for 'Coordinator': {"table":[]}
                                        zigbee.0	2021-02-24 21:27:23.812	debug	(30770) LQI succeeded for 'Coordinator'
                                        zigbee.0	2021-02-24 21:27:23.808	debug	(30770) sendTo "getGroups" to system.adapter.admin.0 from system.adapter.zigbee.0
                                        zigbee.0	2021-02-24 21:27:23.807	debug	(30770) getGroups result: {}
                                        zigbee.0	2021-02-24 21:27:23.805	debug	(30770) sendTo "getCoordinatorInfo" to system.adapter.admin.0 from system.adapter.zigbee.0
                                        zigbee.0	2021-02-24 21:27:23.803	debug	(30770) getCoorinatorInfo result: {"installSource":"iobroker.zigbee@1.4.4","channel":"14","port":"/dev/ttyACM0","type":"zStack3x0","revision":20210120,"version":"2-1.2.7.1."}
                                        zigbee.0	2021-02-24 21:27:23.788	debug	(30770) sendTo "getLibData" to system.adapter.admin.0 from system.adapter.zigbee.0
                                        zigbee.0	2021-02-24 21:27:04.643	debug	(30770) system.adapter.admin.0: logging true
                                        zigbee.0	2021-02-24 21:27:00.401	info	(30770) Zigbee started
                                        zigbee.0	2021-02-24 21:27:00.399	info	(30770) Currently no devices.
                                        zigbee.0	2021-02-24 21:27:00.391	info	(30770) --> transmitPower : high
                                        zigbee.0	2021-02-24 21:27:00.390	info	(30770) Unable to disable LED, unsupported function.
                                        zigbee.0	2021-02-24 21:27:00.388	debug	(30770) Zigbee network parameters: {"panID":6562,"extendedPanID":"0xaddddfddcddddddc","channel":14}
                                        zigbee.0	2021-02-24 21:27:00.380	info	(30770) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210120}}
                                        zigbee.0	2021-02-24 21:27:00.379	debug	(30770) zigbee-herdsman started
                                        zigbee.0	2021-02-24 21:26:58.607	debug	(30770) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2021_02_24-21_26_57.tar.gz success
                                        zigbee.0	2021-02-24 21:26:58.595	info	(30770) Installed Version: iobroker.zigbee@1.4.4
                                        zigbee.0	2021-02-24 21:26:58.047	debug	(30770) Starting zigbee-herdsman...
                                        zigbee.0	2021-02-24 21:26:58.045	info	(30770) Starting Zigbee npm ...
                                        zigbee.0	2021-02-24 21:26:57.990	debug	(30770) Using zigbee-herdsman with settings: {"network":{"panID":6562,"extendedPanID":[220,221,221,205,221,223,221,173],"channelList":[14],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"datab
                                        zigbee.0	2021-02-24 21:26:57.944	info	(30770) starting. Version 1.4.4 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.15.4, js-controller: 3.2.16
                                        zigbee.0	2021-02-24 21:26:57.402	debug	(30770) statesDB connected
                                        zigbee.0	2021-02-24 21:26:57.401	debug	(30770) States connected to redis: 127.0.0.1:9000
                                        zigbee.0	2021-02-24 21:26:57.362	debug	(30770) States create User PubSub Client
                                        zigbee.0	2021-02-24 21:26:57.360	debug	(30770) States create System PubSub Client
                                        zigbee.0	2021-02-24 21:26:57.287	debug	(30770) Redis States: Use Redis connection: 127.0.0.1:9000
                                        zigbee.0	2021-02-24 21:26:57.284	debug	(30770) objectDB connected
                                        zigbee.0	2021-02-24 21:26:57.269	debug	(30770) Objects connected to redis: 127.0.0.1:9001
                                        zigbee.0	2021-02-24 21:26:57.039	debug	(30770) Objects client initialize lua scripts
                                        zigbee.0	2021-02-24 21:26:57.037	debug	(30770) Objects create User PubSub Client
                                        zigbee.0	2021-02-24 21:26:57.035	debug	(30770) Objects create System PubSub Client
                                        zigbee.0	2021-02-24 21:26:56.928	debug	(30770) Objects client ready ... initialize now
                                        zigbee.0	2021-02-24 21:26:56.747	debug	(30770) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                        zigbee.0	2021-02-24 21:26:51.936	info	(30389) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        zigbee.0	2021-02-24 21:26:51.934	info	(30389) terminating
                                        zigbee.0	2021-02-24 21:26:51.596	info	(30389) Zigbee: disabling joining new devices.
                                        zigbee.0	2021-02-24 21:26:51.594	info	(30389) cleaned everything up...
                                        zigbee.0	2021-02-24 21:26:51.592	info	(30389) Got terminate signal TERMINATE_YOURSELF
                                        Danke für Euren Support André
                                          Mr.X
                                          #120
                                          Hallo zusammen (nochmal),
                                          ich habe das Problem, dass bei mir plötzlich die Gruppen nicht mehr funktionieren. Ist für mich aber Essentiell, da ich eine Leuchte mit 5 Birnen haben. Wie auch immer.
                                          ich habe Broker, JS-controller auf stand gebracht, 1.4.4 probiert und auch auf 1.4.1 down gegradet. Alle Gruppen im Adapter gelöscht und neue mit komplett neuem Namen vergeben. Es bleiben aber immer die Gruppen ohne Funktion.
                                          Woran könnte das liegen?
