  4. ZigBee neue Version 1.4.4
    6.0k
neue versionzigbeezigbee neue version 1.4.0
302 Beiträge 35 Kommentatoren 79.2k Aufrufe 36 Beobachtet
  • amg_666A amg_666
    @arteck Muss ich das verstehen? Ich glaube ich muss das nicht verstehen :-)
    Raspi neu gestartet (sudo shutdown -r 0), zigbee update angestoßen, update lief durch...
    Danke für den Support.
    $ ./iobroker upgrade zigbee
    Update zigbee from @1.4.2 to @1.4.4
    host.iomaster Adapter "system.adapter.zigbee.0" is stopped.
    NPM version: 6.14.10
    npm install iobroker.zigbee@1.4.4 --loglevel error --prefix "/opt/iobroker" (System call)
    ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)':../src/serialport.cpp:78:69: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);        ^~~~~~~~~~~~~../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)':../src/serialport.cpp:135:71: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);        ^~~~~~~~~~~~~~~../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)':../src/serialport.cpp:175:70: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);        ^~~~~~~~~~~~~~../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)':../src/serialport.cpp:215:70: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);        ^~~~~~~~~~~~~~
    ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)':../src/serialport.cpp:270:68: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);        ^~~~~~~~~~~~
    ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)':../src/serialport.cpp:314:68: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);        ^~~~~~~~~~~~
    ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)':../src/serialport.cpp:363:76: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);        ^~~~~~~~~~~~~~~~~~~~../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)':../src/serialport.cpp:409:70: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);        ^~~~~~~~~~~~~~../src/serialport.cpp: At global scope:../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of 'ToParityEnum' [-Wparentheses] SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {                            ^../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of 'ToStopBitEnum' [-Wparentheses] SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {                              ^In file included from ../../../nan/nan.h:56,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.20.1/include/node/node.h:737:43: warning: cast between incompatible function types from 'void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)' {aka 'void (*)(v8::Local<v8::Object>)'} to 'node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)'} [-Wcast-function-type]       (node::addon_register_func) (regfunc),                          \                                           ^/home/iobroker/.cache/node-gyp/12.20.1/include/node/node.h:771:3: note: in expansion of macro 'NODE_MODULE_X'   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)   ^~~~~~~~~~~~~../src/serialport.cpp:483:1: note: in expansion of macro 'NODE_MODULE' NODE_MODULE(serialport, init); ^~~~~~~~~~~
    ../src/serialport_unix.cpp: In function 'int setup(int, OpenBaton*)':../src/serialport_unix.cpp:176:60: warning: '%s' directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]     snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);                                                            ^~~~~~~~~~~~~~~~~~~~~~~~~../src/serialport_unix.cpp:176:13: note: 'snprintf' output 20 or more bytes (assuming 1043) into a destination of size 1024     snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);     ~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    ../src/serialport_unix.cpp: In function 'void EIO_Open(uv_work_t*)':
    ../src/serialport_unix.cpp:86:60: warning: '%s' directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]     snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);                                                            ^~~~~~~~~~~~~~~~~~~~~~~~~~~../src/serialport_unix.cpp:86:13: note: 'snprintf' output 22 or more bytes (assuming 1045) into a destination of size 1024     snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);     ~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    Update "system.adapter.zigbee.0"
    upload [250] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/smart9_ts0043.png img/smart9_ts0043.png image/png
    upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_LCT002.png img/philips_hue_LCT002.png image/png
    upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lifecontrol_water-sensor.png img/lifecontrol_water-sensor.png image/png
    upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/hue_go.png img/hue_go.png image/png
    upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/gledopto_spot.png img/gledopto_spot.png image/png
    upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/flair_viyu_e27_rgbw.png img/flair_viyu_e27_rgbw.png image/png
    upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ecozy.png img/ecozy.png image/png
    upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ctrl_ln1.png img/ctrl_ln1.png image/png
    upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/bitron_902010_24.png img/bitron_902010_24.png image/png
    upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZS232000178.png img/ZS232000178.png image/png
    upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Paulmann_79809.png img/Paulmann_79809.png image/png
    upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/HG06104A.png img/HG06104A.png image/png
    upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/FLOALT.panel.WS.png img/FLOALT.panel.WS.png image/png
    upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Eurotronic_Spirit_04.png img/Eurotronic_Spirit_04.png image/png
    upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_R8_8.png img/DIYRuZ_R8_8.png image/png
    upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_Geiger.png img/DIYRuZ_Geiger.png image/png
    upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_FreePad_LeTV_8.png img/DIYRuZ_FreePad_LeTV_8.png image/png
    upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_FreePad.png img/DIYRuZ_FreePad.png image/png
    upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_Flower.png img/DIYRuZ_Flower.png image/png
    upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_CO2.png img/DIYRuZ_CO2.png image/png
    upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ.png img/DIYRuZ.png image/png
    upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DGNWG05LM.png img/DGNWG05LM.png image/png
    upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Bitron_AV201021A.png img/Bitron_AV201021A.png image/png
    upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/BW-IS5.png img/BW-IS5.png image/png
    upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/BW-IS3.png img/BW-IS3.png image/png
    upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/AV2010_32.png img/AV2010_32.png image/png
    upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw2.png img/86sw2.png image/png
    upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw1.png img/86sw1.png image/png
    upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86plug.png img/86plug.png image/png
    upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/14147206L.png img/14147206L.png image/png
    upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/admin.js admin.js application/javascript
    upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/adapter-settings.js adapter-settings.js application/javascript
    Adapter "zigbee" updated
    host.iomaster Adapter "system.adapter.zigbee.0" is started
    process exited with code 0
    arteckA Offline
    arteckA Offline
    arteck
    @amg_666 ich vermute da lief noch ein zombie process .. deshalb der neustart.. schön
    • M Mr.X
      Hi, habe folgende Ledvance Smart+ "Kerzenlampen" mit E14 Sockel.
      Die werden als Spots erkannt. Kachel zeigt auch die falsche Lampe an. also das Bilchen.
      ON/OFF und Brightness gehen, aber die Farbtemperatur ändert sich nicht.
      Auch kann ich die nicht über eine angelegte Gruppe gemeinsam steuern.
      Adapter war vorhin auf 1.4 und habe ist nun auf 1.4.4. Bei beiden Versionen gleichen Bild.
      All das ging mit "ähnlichen" Osram Birnen, aber die haben voll laut gefiept, wenn sie gedimmt waren.
      Mr.X
      @mr-x sagte in ZigBee neue Version 1.4.4:
      Kann sich jemand hieraus einen Reim machen?
      • arteckA arteck
        was ist neu
        @Ilya : man kann externe konverter einbinmden für DIY Geräte
        @Asgothian verbesserung des Pingprozesses - hier ist auch ein Button in den Objecten dazugekommen
        @arteck Geräte können diert aus dem Converter gezogen werden auch wenn diese bei uns definiert sind
        @Asgothian automatisches Löschen nicht gebrauchter Datenpunkte wenn man dem Ausschluss Tab nutzt
        so uns nu lassen die Spiele beginnen
        @Nachtrag da es hier zu vielen Fragen kommt
        nach dem Update und nach dem Adapter start sind ALLE Geräte erstmal mit einer Link Quality von 10 in der Kacheln.. nach dem sich die Geräte gemeldet haben (Router) geht die Link Quality auf das was das Gerät lifert. bleibt die Link Quality auf 10 meldet sich das Gerät nicht, dass kann mehre Stunden dauern..also Geduld
        ausser
        die batteriebenen Geräte .. diese müssen sich erst melden. das dauert da sich diese selten Melden vor allem Aqara bzw. Xiaomi .. man kann es selbst antrigern per drücken des Knopfes am Gerät. erst dann sieht man die richtige Link Quality..
        Holzlenkrad
        @arteck sagte in ZigBee neue Version 1.4.4:
        Das Feature zum pullen der aktuellen Datenpunkte ist cool, danke dafür!
        Kannst du einbauen, dass das in bestimmten Intervallen automatisch gemacht wird? Oder ist das nicht sinnvoll?
        In jedem Fall finde ich aber dass es automatisch gemacht werden sollte, wenn Geräte über Zigbee-Gruppen geschaltet werden. Danach stimmen die Datenpunkte der Geräte der Gruppen leider nie (Tradfri Lampen bei mir).
        Übrigens, kannst du dir noch mal den TS0121_plug angucken? Da wird weiterhin nur ein Endpoint (von zwei) verwendet.
        • H Holzlenkrad
          arteckA Offline
          arteckA Offline
          arteck
          @holzlenkrad sagte in ZigBee neue Version 1.4.4:
          die Geräte melden sich immer automatisch .. damit kannst du es manuell antrigern..
          an den Gruppen sind wir noch dran.. steht auf der Liste
          was meinst du damit ?
          H 1 Antwort Letzte Antwort
          • arteckA arteck
            Holzlenkrad
            schrieb am zuletzt editiert von Holzlenkrad
            Ne, ich habe durchaus auch Geräte, die melden ihren Status gar nicht, wenn ich ihn nicht abfrage. Z.B. die genannten Tradfri-Lampen, wenn sie über Gruppen oder Fernbedienung geschaltet werden :(
            Dieser Zwischenstecker BW-SHP13 bzw. TS0121 hat ja zwei Switches eingebaut. Einen für die Steckdose (Nr. 1) und einen für die USB-Ports (Nr.2). Leider kann man derzeit nur den ersten Switch schalten.
            • amg_666A amg_666
              @thomas-braun Eben, bei meinem Windows PC hätt ich sowas garnicht erst gepostet sondern gleich aus/eingeschaltet....
              klassisch
              @amg_666 sagte in ZigBee neue Version 1.4.4:
              Mein Win PC hat den zigbee Adapter ohne Probs und ohne Neustart oder Power reset upgedatet.
              Und auch der "refresh" button funktioniert bei ikea Floalt Panels.
              Herzlichen Dank dafür, kann ich sehr gut gebrauchen! Die Symfonisk rotary encoder arbeiten gut mit den Floalt, aber bisher halt undercover.
              • H Holzlenkrad
                arteckA Offline
                arteckA Offline
                arteck
                hast du es mit dem Tab "Ausschliessen" versucht...
                • arteckA arteck
                  Holzlenkrad
                  Ja, so funktioniert es. Danke.
                  Fügst du denn für neue Hardware gar keine eigene Beschreibungen mehr hinzu, sodass man die Funktion "Ausschliessen" dann immer nutzen soll? Oder pflegst du den Zwischenstecker noch irgendwann ein?
                  • H Holzlenkrad
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    Wie es bei genau diesem Zwischenstecker ist ist noch offen. Generell wollen wir möglichst wenig Geräte explizit bei uns definieren. Sofern die States bei in beiden Fällen vergleichbar sind (die die in beiden Fällen existieren) würde ich hier eher die vorhandene Definition im Adapter eliminieren wollen so das ein Eintrag in die Ausschlussliste nicht notwendig wird.
                    A.
                    • K Offline
                      klassisch
                      beim pingen auf ein ikea Floalt L1529 bekomme ich eine Warnmeldung
                      	warn	(3444) Failed to read state '"color_temp_startup"'of '0xbc33acfffed57c9d' after query with '{"code":134}'
                      Der stat color_temp_startup steht auch nicht in der Objektliste
                      • K klassisch
                        AsgothianA Offline
                        AsgothianA Offline
                        Asgothian
                        @klassisch
                        Damit wirst Du (erst einmal) leben müssen. Die Implementierung des Floalt im Zigbee-Herdsman gibt an das das Panel diesen Parameter unterstützt, daher versucht die Funktion diesen auszulesen. Die Meldung "Code:134" kommt vom Gerät selber, und bedeutet "unsupported attribute", i.e. das Panel meldet das es diesen Wert nicht unterstützt.
                        Es ist denkbar das in der Zukunft bestimmte Meldungen heraus gefiltert und dann nicht als Warnungen ausgegeben werden.
                        A.
                        • AsgothianA Asgothian
                          @klassisch
                          A.
                          Mr.X
                          Funktioniert bei allen die Gruppenbildung?
                          Mit meinen Ledvance Smart+ "Kerzenlampen" mit E14 Sockel. geht das nicht.
                          und umwege über eine Gruppe in Alexa führt zu Diskolicht und/oder zu einzelnen Aussetzern.
                          • Wieger DanielW Offline
                            Wieger Daniel
                            schrieb am zuletzt editiert von Wieger Daniel
                            sorry das ich euch hier evtl jetzt nerve :/
                            Mein setup: Mini PC mit Proxmox, iobroker in ner VM, CC26XXX Board
                            Alle Adapter und das System selbst aktuell.
                            Da der SOnoff Mini in der Stable Version als ??? angezeigt wurde und somit nicht erkant wurde, habe ich mir nun die Beta 1.4.4 geladen.
                            Der Sonof wird erkannt.
                            ABER...
                            Ohne an der Hardware etwas geändert zu (der Sonof kam dazu!) sind nun einige meiner Lampen (Tradfri + Osram) nicht mehr erreichbar.
                            Ein anlernen war möglich, danach aber nicht mehr erreichbar.
                            Die Lampen wurden dort angelernt wo sie jetzt auch sind. - 1 Lampe ist ungefähr 3m vom Koordinator entfernt.
                            Ja ich weis, der Screenshot bzw die Sendequalität ist nicht unbedingt korrekt, allerdings hatte ich mit 1.3.1 keine "Empfangsprobeme" und nun werden mir viele Geräte Orange und rot angezeigt?!
                            Schalter Katze + Bett sowie die Lampe Katze liegen nebeneinander. Lampe funktioniert nicht - nicht erreichbar, Schalter aber schon?
                            Platzl Licht ist eine Osram und macht Probleme (seit dem Update) liegt ca 6 Meter entfernt vom Koordinator
                            Aromastudio Platzl ist eine Tradfri und liegt ungefähr 8 Meter NACH der Platzl Licht (ca 14Meter vom Koordinator entfernt) und macht derzeit keine Problem.. :(
                            evtl noch zu erwähnen: Gestern noch mit 1.3.1 war Kanal 11 mit 10% der beste kanal - alle andren lagen bei 50-80%
                            Heute nach dem Update habe gar keinen Kanal mehr unter 70% - in einer 300 Einwohner Gemeinde mit alterdurchschnitt 70+
                            Ich wäre dankbar, für hilfe um dieses Problem lösen zu können :)
                            Wieger DanielW 1 Antwort Letzte Antwort
                            • arteckA arteck
                              was ist neu
                              ausser
                              mickymM Offline
                              mickymM Offline
                              mickym
                              Ich möchte dieses Mal über eine sehr positive Erfahrung bzgl. des Adapter Updates berichten - zumindest kurz was man nach der Installation sagen kann.
                              Vielleicht auch für den einen oder anderen ein paar Tipps.
                              Ich bin grundsätzlich ein Anhänger - meist nur "Stable" Versionen einzusetzen. Ich habe mich nun aber entschlossen, da mein node-red Adapter teilweise ein anderes Verhalten, als bei anderen Usern hier an Board an den Tag legt, doch auf die nodejs- Version 14 hochzurüsten, auch wenn das offiziell noch nicht empfohlen wird.
                              Gut also die NodeJS Version hochgezogen - alle starteten bis auf den zigbee - Adapter. :(
                              2021-02-16 22:59:11.022 - error: host.MWHome Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:121
                              2021-02-16 22:59:11.023 - error: host.MWHome Caught by controller[0]: throw e;
                              2021-02-16 22:59:11.023 - error: host.MWHome Caught by controller[0]: ^
                              2021-02-16 22:59:11.024 - error: host.MWHome Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/Release/bindings.node'
                              2021-02-16 22:59:11.026 - error: host.MWHome Caught by controller[0]: was compiled against a different Node.js version using
                              2021-02-16 22:59:11.027 - error: host.MWHome Caught by controller[0]: NODE_MODULE_VERSION 72. This version of Node.js requires
                              2021-02-16 22:59:11.028 - error: host.MWHome Caught by controller[0]: NODE_MODULE_VERSION 83. Please try re-compiling or re-installing
                              2021-02-16 22:59:11.029 - error: host.MWHome Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                              2021-02-16 22:59:11.031 - error: host.MWHome Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1122:18)
                              2021-02-16 22:59:11.037 - error: host.MWHome Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:928:32)
                              2021-02-16 22:59:11.037 - error: host.MWHome Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:769:14)
                              2021-02-16 22:59:11.038 - error: host.MWHome Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:952:19)
                              2021-02-16 22:59:11.044 - error: host.MWHome Caught by controller[0]: at require (internal/modules/cjs/helpers.js:88:18)
                              2021-02-16 22:59:11.044 - error: host.MWHome Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48)
                              2021-02-16 22:59:11.045 - error: host.MWHome Caught by controller[0]: at Object. (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/lib/linux.js:2:36)
                              2021-02-16 22:59:11.046 - error: host.MWHome Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1063:30)
                              2021-02-16 22:59:11.047 - error: host.MWHome Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1092:10)
                              2021-02-16 22:59:11.047 - error: host.MWHome Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:928:32)
                              2021-02-16 22:59:11.048 - error: host.MWHome instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                              2021-02-16 22:59:11.049 - info: host.MWHome Adapter system.adapter.zigbee.0 needs rebuild and will be restarted afterwards.
                              2021-02-16 22:59:11.050 - info: host.MWHome system.adapter.zigbee.0 will be rebuilt
                              2021-02-16 22:59:11.063 - warn: host.MWHome adapter "zigbee" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
                              2021-02-16 22:59:11.064 - info: host.MWHome iobroker rebuild zigbee
                              So nun an alle die das absichtlich oder unabsichtlich nachmachen also nodejs hochziehen - lasst Eurem System mal ca. 10-15 Minuten Zeit.
                              Die Ansteuerung des seriellen Ports wird bzw. für die neue nodejs Version neu kompiliert werden. Das erfolgt auch im HIntergrund - nur bekommt man davon erstmal nichts mit. :(
                              Nach dieser Zeit bekommt man zwar ein paar Warnungen von der Neukompilierung der "serialport_unix.cpp" aber das klappte gut:
                              2021-02-16 23:03:23.556 - info: host.MWHome "system.adapter.zigbee.0" disabled
                              2021-02-16 23:03:25.809 - info: host.MWHome "system.adapter.zigbee.0" enabled
                              2021-02-16 23:04:26.588 - info: host.MWHome iobroker npm-rebuild: ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen); ^~~~~~~~~~~~~
                              2021-02-16 23:04:26.594 - info: host.MWHome iobroker npm-rebuild: ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate); ^~~~~~~~~~~~~~~
                              2021-02-16 23:04:26.597 - info: host.MWHome iobroker npm-rebuild: ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose); ^~~~~~~~~~~~~~
                              2021-02-16 23:04:26.601 - info: host.MWHome iobroker npm-rebuild: ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush); ^~~~~~~~~~~~~~
                              2021-02-16 23:04:26.605 - info: host.MWHome iobroker npm-rebuild: ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:270:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet); ^~~~~~~~~~~~
                              2021-02-16 23:04:26.609 - info: host.MWHome iobroker npm-rebuild: ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:314:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet); ^~~~~~~~~~~~
                              2021-02-16 23:04:26.616 - info: host.MWHome iobroker npm-rebuild: ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate); ^~~~~~~~~~~~~~~~~~~~
                              2021-02-16 23:04:26.621 - info: host.MWHome iobroker npm-rebuild: ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain); ^~~~~~~~~~~~~~
                              2021-02-16 23:04:26.624 - info: host.MWHome iobroker npm-rebuild: ../src/serialport.cpp: At global scope:../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses] SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local& v8str)) { ^
                              2021-02-16 23:04:26.627 - info: host.MWHome iobroker npm-rebuild: ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses] SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) { ^
                              2021-02-16 23:04:26.642 - info: host.MWHome iobroker npm-rebuild: In file included from ../../../nan/nan.h:56, from ../src/./serialport.h:6, from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/14.15.5/include/node/node.h:758:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local, v8::Local, void*)’} [-Wcast-function-type] (node::addon_register_func) (regfunc), \ ^/home/iobroker/.cache/node-gyp/14.15.5/include/node/node.h:792:3: note: in expansion of macro ‘NODE_MODULE_X’ NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) ^~~~~~~~~~~~~../src/serialport.cpp:483:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(serialport, init); ^~~~~~~~~~~
                              2021-02-16 23:04:30.845 - info: host.MWHome iobroker npm-rebuild: ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:../src/serialport_unix.cpp:176:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=] snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path); ^~~~~~~~~~~~~~~~~~~~~~~~~../src/serialport_unix.cpp:176:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024 snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path); ~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                              2021-02-16 23:04:30.885 - info: host.MWHome iobroker npm-rebuild: ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:../src/serialport_unix.cpp:86:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=] snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path); ^~~~~~~~~~~~~~~~~~~~~~~~~~~../src/serialport_unix.cpp:86:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024 snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path); ~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                              2021-02-16 23:05:42.088 - info: host.MWHome iobroker npm-rebuild:
                              2021-02-16 23:05:42.094 - info: host.MWHome iobroker npm-rebuild: Rebuild zigbee done
                              2021-02-16 23:05:43.109 - info: host.MWHome iobroker npm-rebuild: exit 0
                              2021-02-16 23:05:43.225 - info: host.MWHome instance system.adapter.zigbee.0 started with pid 3857
                              2021-02-16 23:05:45.120 - info: zigbee.0 (3857) starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.15.5, js-controller: 3.1.6
                              2021-02-16 23:05:45.259 - info: zigbee.0 (3857) Starting Zigbee npm ...
                              2021-02-16 23:05:48.158 - info: zigbee.0 (3857) Coordinator firmware version: {"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20190608}}
                              2021-02-16 23:05:48.170 - info: zigbee.0 (3857) --> transmitPower : normal
                              2021-02-16 23:05:48.181 - info: zigbee.0 (3857) Currently 18 devices are joined:
                              2021-02-16 23:05:48.200 - info: zigbee.0 (3857) 0xec1bbdfffeebe96b (addr 33469): LED1649C5 - IKEA TRADFRI LED bulb E12/E14/E17 400 lumen, dimmable warm white, chandelier opal (Router)
                              2021-02-16 23:05:48.206 - info: zigbee.0 (3857) 0xec1bbdfffeeae2df (addr 64615): LED1649C5 - IKEA TRADFRI LED bulb E12/E14/E17 400 lumen, dimmable warm white, chandelier opal (Router)
                              2021-02-16 23:05:48.208 - info: zigbee.0 (3857) 0xec1bbdfffeeadb1a (addr 24824): LED1649C5 - IKEA TRADFRI LED bulb E12/E14/E17 400 lumen, dimmable warm white, chandelier opal (Router)
                              2021-02-16 23:05:48.210 - info: zigbee.0 (3857) 0xccccccfffe021ec0 (addr 44672): LED1732G11 - IKEA TRADFRI LED bulb E27 1000 lumen, dimmable, white spectrum, opal white (Router)
                              2021-02-16 23:05:48.212 - info: zigbee.0 (3857) 0x00158d000411b98e (addr 2879): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                              2021-02-16 23:05:48.215 - info: zigbee.0 (3857) 0x00158d00032c8aa8 (addr 7440): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
                              2021-02-16 23:05:48.216 - info: zigbee.0 (3857) 0x00158d000424453c (addr 15225): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                              2021-02-16 23:05:48.218 - info: zigbee.0 (3857) 0xccccccfffeb3e954 (addr 2130): E1746 - IKEA TRADFRI signal repeater (Router)
                              2021-02-16 23:05:48.220 - info: zigbee.0 (3857) 0x00158d0004282104 (addr 51621): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                              2021-02-16 23:05:48.221 - info: zigbee.0 (3857) 0x00158d0004221522 (addr 31393): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                              2021-02-16 23:05:48.223 - info: zigbee.0 (3857) 0x00158d0003f4bf3e (addr 9840): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                              2021-02-16 23:05:48.224 - info: zigbee.0 (3857) 0x00158d0003f13adf (addr 9610): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                              2021-02-16 23:05:48.226 - info: zigbee.0 (3857) 0x00158d000451a514 (addr 63466): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                              2021-02-16 23:05:48.227 - info: zigbee.0 (3857) 0x00158d00042006e1 (addr 30835): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                              2021-02-16 23:05:48.229 - info: zigbee.0 (3857) 0x00158d0004201088 (addr 27465): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                              2021-02-16 23:05:48.230 - info: zigbee.0 (3857) 0x00158d0004281fd5 (addr 6494): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                              2021-02-16 23:05:48.232 - info: zigbee.0 (3857) 0x00158d00053fbc8c (addr 48940): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                              2021-02-16 23:05:48.233 - info: zigbee.0 (3857) 0x00158d00032c9cc7 (addr 57813): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
                              2021-02-16 23:05:48.234 - info: zigbee.0 (3857) Zigbee started
                              Die Version 1.3.1 des Adapters wurde wieder gestartet.
                              Dann dachte ich mir, dann probierst doch mal die neueste Version aus (also diese hier 1.4.4), da diese eine Funktion enthält, mit der man den Status der Geräte pullen kann, da dies ein großer Kritikpunkt für mich war, dass IST-Zustand mit dem Zustand der Datenpunkte leider nicht immer übereinstimmte und das war für mich ein großer Schwachpunkt. Sprich laut Datenpunkt, war eine Lampe aus, aber bestimmte Lampen, haben sich automatisch nachdem der Strom zurückkam eingeschaltet. Also ist dieser Ping Button in dieser Version mit der man den aktuellen Zustand direkt abfragen kann eine erhebliche Verbesserung.. Auch wenn es sicher eine Zeit dauern wird, bis ich meine Logik umgestellt habe - hilft das in jedem Fall.
                              Gut also die neueste Version von GitHub installiert.
                              Die Installation bzw. das Update das zigbee Adapter erfolgte ohne Probleme, Warnungen oder Fehlermeldungen mit Exit Code 0.
                              2021-02-16 23:05:51.986 - info: host.MWHome Update repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
                              2021-02-16 23:06:38.686 - info: host.MWHome iobroker url "https://github.com/ioBroker/ioBroker.zigbee/tarball/master" zigbee
                              2021-02-16 23:06:40.485 - info: host.MWHome iobroker install https://github.com/ioBroker/ioBroker.zigbee/tarball/master
                              2021-02-16 23:06:41.108 - info: host.MWHome iobroker NPM version: 6.14.11
                              2021-02-16 23:06:41.110 - info: host.MWHome iobroker npm install https://github.com/ioBroker/ioBroker.zigbee/tarball/master --loglevel error --prefix "/opt/iobroker" (System call)
                              2021-02-16 23:08:40.954 - info: host.MWHome iobroker upload [300] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.js vis-network.min.js application/javascript
                              2021-02-16 23:09:23.484 - info: host.MWHome iobroker upload [250] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/sengled.png img/sengled.png image/png
                              2021-02-16 23:09:26.653 - info: host.MWHome iobroker upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/paulmann_rgbw_controller.png img/paulmann_rgbw_controller.png image/png
                              2021-02-16 23:09:29.923 - info: host.MWHome iobroker upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/konke_kpkey.png img/konke_kpkey.png image/png
                              2021-02-16 23:09:33.174 - info: host.MWHome iobroker upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/gledopto_spot.png img/gledopto_spot.png image/png
                              2021-02-16 23:09:33.771 - info: host.MWHome iobroker upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/flair_viyu_e27_rgbw.png img/flair_viyu_e27_rgbw.png image/png
                              2021-02-16 23:09:34.402 - info: host.MWHome iobroker upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ecozy.png img/ecozy.png image/png
                              2021-02-16 23:09:35.022 - info: host.MWHome iobroker upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ctrl_ln1.png img/ctrl_ln1.png image/png
                              2021-02-16 23:09:35.692 - info: host.MWHome iobroker upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/bitron_902010_24.png img/bitron_902010_24.png image/png
                              2021-02-16 23:09:36.276 - info: host.MWHome iobroker upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZS232000178.png img/ZS232000178.png image/png
                              2021-02-16 23:09:36.922 - info: host.MWHome iobroker upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Paulmann_79809.png img/Paulmann_79809.png image/png
                              2021-02-16 23:09:37.506 - info: host.MWHome iobroker upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/HG06104A.png img/HG06104A.png image/png
                              2021-02-16 23:09:38.155 - info: host.MWHome iobroker upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DGNWG05LM.png img/DGNWG05LM.png image/png
                              2021-02-16 23:09:38.220 - info: host.MWHome iobroker upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Bitron_AV201021A.png img/Bitron_AV201021A.png image/png
                              2021-02-16 23:09:38.286 - info: host.MWHome iobroker upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/BW-IS5.png img/BW-IS5.png image/png
                              2021-02-16 23:09:38.353 - info: host.MWHome iobroker upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/BW-IS3.png img/BW-IS3.png image/png
                              2021-02-16 23:09:38.417 - info: host.MWHome iobroker upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/AV2010_32.png img/AV2010_32.png image/png
                              2021-02-16 23:09:38.486 - info: host.MWHome iobroker upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw2.png img/86sw2.png image/png
                              2021-02-16 23:09:38.557 - info: host.MWHome iobroker upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw1.png img/86sw1.png image/png
                              2021-02-16 23:09:38.616 - info: host.MWHome iobroker upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86plug.png img/86plug.png image/png
                              2021-02-16 23:09:38.676 - info: host.MWHome iobroker upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/14147206L.png img/14147206L.png image/png
                              2021-02-16 23:09:38.734 - info: host.MWHome iobroker upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                              2021-02-16 23:09:38.797 - info: host.MWHome iobroker upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                              2021-02-16 23:09:38.859 - info: host.MWHome iobroker upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                              2021-02-16 23:09:38.919 - info: host.MWHome iobroker upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                              2021-02-16 23:09:38.980 - info: host.MWHome iobroker upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                              2021-02-16 23:09:39.042 - info: host.MWHome iobroker upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/it/translations.json i18n/it/translations.json application/json
                              2021-02-16 23:09:39.103 - info: host.MWHome iobroker upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                              2021-02-16 23:09:39.164 - info: host.MWHome iobroker upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/es/translations.json i18n/es/translations.json application/json
                              2021-02-16 23:09:39.225 - info: host.MWHome iobroker upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/en/translations.json i18n/en/translations.json application/json
                              2021-02-16 23:09:39.293 - info: host.MWHome iobroker upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/de/translations.json i18n/de/translations.json application/json
                              2021-02-16 23:09:39.362 - info: host.MWHome iobroker upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/admin.js admin.js application/javascript
                              2021-02-16 23:09:39.428 - info: host.MWHome iobroker upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/adapter-settings.js adapter-settings.js application/javascript
                              2021-02-16 23:09:39.570 - info: host.MWHome iobroker Update "system.adapter.zigbee.0"
                              2021-02-16 23:09:39.612 - info: host.MWHome stopInstance system.adapter.zigbee.0 (force=false, process=true)
                              2021-02-16 23:09:39.614 - info: host.MWHome stopInstance system.adapter.zigbee.0 send kill signal
                              2021-02-16 23:09:39.624 - info: zigbee.0 (3857) Got terminate signal TERMINATE_YOURSELF
                              2021-02-16 23:09:39.626 - info: zigbee.0 (3857) cleaned everything up...
                              2021-02-16 23:09:39.628 - info: zigbee.0 (3857) Zigbee: disabling joining new devices.
                              2021-02-16 23:09:39.959 - info: zigbee.0 (3857) terminating
                              2021-02-16 23:09:39.961 - info: zigbee.0 (3857) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              2021-02-16 23:09:40.502 - info: host.MWHome instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2021-02-16 23:09:40.644 - info: host.MWHome iobroker exit 0
                              Es erfolgten nach einiger Zeit wieder die gleichen Fehlermeldungen - wie vorher. Es erfolgte erneut eine Rekompilierung der "serialport_unix.cpp" - und dann ein erfolgreicher Start der Version 1.4.4
                              2021-02-16 23:23:35.683 - info: host.MWHome iobroker npm-rebuild: ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen); ^~~~~~~~~~~~~
                              2021-02-16 23:23:35.692 - info: host.MWHome iobroker npm-rebuild: ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate); ^~~~~~~~~~~~~~~
                              2021-02-16 23:23:35.694 - info: host.MWHome iobroker npm-rebuild: ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose); ^~~~~~~~~~~~~~
                              2021-02-16 23:23:35.698 - info: host.MWHome iobroker npm-rebuild: ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush); ^~~~~~~~~~~~~~
                              2021-02-16 23:23:35.702 - info: host.MWHome iobroker npm-rebuild: ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:270:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet); ^~~~~~~~~~~~
                              2021-02-16 23:23:35.706 - info: host.MWHome iobroker npm-rebuild: ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:314:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet); ^~~~~~~~~~~~
                              2021-02-16 23:23:35.712 - info: host.MWHome iobroker npm-rebuild: ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate); ^~~~~~~~~~~~~~~~~~~~
                              2021-02-16 23:23:35.718 - info: host.MWHome iobroker npm-rebuild: ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain); ^~~~~~~~~~~~~~
                              2021-02-16 23:23:35.720 - info: host.MWHome iobroker npm-rebuild: ../src/serialport.cpp: At global scope:../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses] SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local& v8str)) { ^
                              2021-02-16 23:23:35.722 - info: host.MWHome iobroker npm-rebuild: ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses] SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) { ^
                              2021-02-16 23:23:35.727 - info: host.MWHome iobroker npm-rebuild: In file included from ../../../nan/nan.h:56, from ../src/./serialport.h:6, from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/14.15.5/include/node/node.h:758:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local, v8::Local, void*)’} [-Wcast-function-type] (node::addon_register_func) (regfunc), \ ^/home/iobroker/.cache/node-gyp/14.15.5/include/node/node.h:792:3: note: in expansion of macro ‘NODE_MODULE_X’ NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) ^~~~~~~~~~~~~../src/serialport.cpp:483:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(serialport, init); ^~~~~~~~~~~
                              2021-02-16 23:23:40.221 - info: host.MWHome iobroker npm-rebuild: ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:../src/serialport_unix.cpp:176:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=] snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path); ^~~~~~~~~~~~~~~~~~~~~~~~~../src/serialport_unix.cpp:176:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024 snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path); ~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                              2021-02-16 23:23:40.262 - info: host.MWHome iobroker npm-rebuild: ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:../src/serialport_unix.cpp:86:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=] snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path); ^~~~~~~~~~~~~~~~~~~~~~~~~~~../src/serialport_unix.cpp:86:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024 snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path); ~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                              2021-02-16 23:23:49.355 - info: host.MWHome iobroker npm-rebuild: ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen); ^~~~~~~~~~~~~
                              2021-02-16 23:23:49.363 - info: host.MWHome iobroker npm-rebuild: ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate); ^~~~~~~~~~~~~~~
                              2021-02-16 23:23:49.367 - info: host.MWHome iobroker npm-rebuild: ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose); ^~~~~~~~~~~~~~
                              2021-02-16 23:23:49.371 - info: host.MWHome iobroker npm-rebuild: ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush); ^~~~~~~~~~~~~~
                              2021-02-16 23:23:49.376 - info: host.MWHome iobroker npm-rebuild: ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:270:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet); ^~~~~~~~~~~~
                              2021-02-16 23:23:49.380 - info: host.MWHome iobroker npm-rebuild: ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:314:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet); ^~~~~~~~~~~~
                              2021-02-16 23:23:49.388 - info: host.MWHome iobroker npm-rebuild: ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate); ^~~~~~~~~~~~~~~~~~~~
                              2021-02-16 23:23:49.395 - info: host.MWHome iobroker npm-rebuild: ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain); ^~~~~~~~~~~~~~
                              2021-02-16 23:23:49.397 - info: host.MWHome iobroker npm-rebuild: ../src/serialport.cpp: At global scope:../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses] SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local& v8str)) { ^
                              2021-02-16 23:23:49.400 - info: host.MWHome iobroker npm-rebuild: ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses] SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) { ^
                              2021-02-16 23:23:49.403 - info: host.MWHome iobroker npm-rebuild: In file included from ../../../nan/nan.h:56, from ../src/./serialport.h:6, from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/14.15.5/include/node/node.h:758:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local, v8::Local, void*)’} [-Wcast-function-type] (node::addon_register_func) (regfunc), \ ^/home/iobroker/.cache/node-gyp/14.15.5/include/node/node.h:792:3: note: in expansion of macro ‘NODE_MODULE_X’ NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) ^~~~~~~~~~~~~../src/serialport.cpp:483:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(serialport, init); ^~~~~~~~~~~
                              2021-02-16 23:24:33.533 - info: host.MWHome iobroker npm-rebuild: ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:../src/serialport_unix.cpp:176:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=] snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path); ^~~~~~~~~~~~~~~~~~~~~~~~~../src/serialport_unix.cpp:176:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024 snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path); ~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                              2021-02-16 23:24:33.571 - info: host.MWHome iobroker npm-rebuild: ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:../src/serialport_unix.cpp:86:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=] snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path); ^~~~~~~~~~~~~~~~~~~~~~~~~~~../src/serialport_unix.cpp:86:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024 snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path); ~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                              2021-02-16 23:25:21.755 - info: host.MWHome iobroker npm-rebuild:
                              2021-02-16 23:25:21.757 - info: host.MWHome iobroker npm-rebuild: Rebuild zigbee done
                              2021-02-16 23:25:22.780 - info: host.MWHome iobroker npm-rebuild: exit 0
                              2021-02-16 23:25:22.903 - info: host.MWHome instance system.adapter.zigbee.0 started with pid 6011
                              2021-02-16 23:25:25.303 - info: zigbee.0 (6011) starting. Version 1.4.4 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.15.5, js-controller: 3.1.6
                              2021-02-16 23:25:25.434 - info: zigbee.0 (6011) Starting Zigbee npm ...
                              2021-02-16 23:25:25.594 - info: zigbee.0 (6011) Installed Version: https://github.com/ioBroker/ioBroker.zigbee/commit/master
                              2021-02-16 23:25:28.333 - info: zigbee.0 (6011) Coordinator firmware version: {"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20190608}}
                              2021-02-16 23:25:28.345 - info: zigbee.0 (6011) --> transmitPower : normal
                              2021-02-16 23:25:28.355 - info: zigbee.0 (6011) Currently 18 devices are joined:
                              2021-02-16 23:25:28.407 - info: zigbee.0 (6011) Configuring 0xccccccfffe021ec0 TRADFRI bulb E27 WS opal 1000lm
                              2021-02-16 23:25:28.419 - info: zigbee.0 (6011) 0xec1bbdfffeebe96b (addr 33469): LED1649C5 - IKEA TRADFRI LED bulb E12/E14/E17 400 lumen, dimmable warm white, chandelier opal (Router)
                              2021-02-16 23:25:28.427 - info: zigbee.0 (6011) 0xec1bbdfffeeae2df (addr 64615): LED1649C5 - IKEA TRADFRI LED bulb E12/E14/E17 400 lumen, dimmable warm white, chandelier opal (Router)
                              2021-02-16 23:25:28.429 - info: zigbee.0 (6011) 0xec1bbdfffeeadb1a (addr 24824): LED1649C5 - IKEA TRADFRI LED bulb E12/E14/E17 400 lumen, dimmable warm white, chandelier opal (Router)
                              2021-02-16 23:25:28.431 - info: zigbee.0 (6011) 0xccccccfffe021ec0 (addr 44672): LED1732G11 - IKEA TRADFRI LED bulb E27 1000 lumen, dimmable, white spectrum, opal white (Router)
                              2021-02-16 23:25:28.433 - info: zigbee.0 (6011) 0x00158d000411b98e (addr 2879): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                              2021-02-16 23:25:28.435 - info: zigbee.0 (6011) 0x00158d00032c8aa8 (addr 7440): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
                              2021-02-16 23:25:28.436 - info: zigbee.0 (6011) 0x00158d000424453c (addr 15225): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                              2021-02-16 23:25:28.438 - info: zigbee.0 (6011) 0xccccccfffeb3e954 (addr 2130): E1746 - IKEA TRADFRI signal repeater (Router)
                              2021-02-16 23:25:28.440 - info: zigbee.0 (6011) 0x00158d0004282104 (addr 51621): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                              2021-02-16 23:25:28.441 - info: zigbee.0 (6011) 0x00158d0004221522 (addr 31393): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                              2021-02-16 23:25:28.443 - info: zigbee.0 (6011) 0x00158d0003f4bf3e (addr 9840): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                              2021-02-16 23:25:28.445 - info: zigbee.0 (6011) 0x00158d0003f13adf (addr 9610): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                              2021-02-16 23:25:28.446 - info: zigbee.0 (6011) 0x00158d000451a514 (addr 63466): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                              2021-02-16 23:25:28.448 - info: zigbee.0 (6011) 0x00158d00042006e1 (addr 30835): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                              2021-02-16 23:25:28.450 - info: zigbee.0 (6011) 0x00158d0004201088 (addr 27465): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                              2021-02-16 23:25:28.451 - info: zigbee.0 (6011) 0x00158d0004281fd5 (addr 6494): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                              2021-02-16 23:25:28.453 - info: zigbee.0 (6011) 0x00158d00053fbc8c (addr 48940): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                              2021-02-16 23:25:28.454 - info: zigbee.0 (6011) 0x00158d00032c9cc7 (addr 57813): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
                              2021-02-16 23:25:28.455 - info: zigbee.0 (6011) Zigbee started
                              2021-02-16 23:25:52.899 - info: zigbee.0 (6011) DeviceConfigure successful 0xccccccfffe021ec0 TRADFRI bulb E27 WS opal 1000lm
                              Seitdem kann ich bislang also folgendes Feedback geben:
                              1. Version konnte dieses Mal ohne Fehler installiert werden.
                              2. Die Rekompilierung der "serialport_unix.cpp" muss man abwarten - erfolgte bei mir automatisch im Hintergrund.
                              3. Die Anbindung des Sticks über den seriellen Port an den Adapter hat sich in meinen Augen sehr verbessert - früher waren manchmal mehrfache Neustarts erforderlich.
                              4. Dieser PING Button ist es wert die neue Version zu installieren - auch wenn ich ihn noch nicht über meine Node Red Flows angesprochen habe.
                              5. Ich habe bislang keine Probleme mit Gruppen oder einzelnen Geräten, die vorher auch gingen. Das der State zwischen der Gruppe und dem Einzelgerät nicht übereinstimmt - das hatte ich von Beginn an und steht ja nun auf der Liste. Das wird wahrscheinlich generell schwierig - da ich auch schon oft den Fall hatte, dass nach dem Stromausfall sich nicht alle Lampen einer Gruppe gleich verhielten. Es kam durchaus vor, dass eine Lampe von 3en in einer Gruppe brannte, die anderen beiden nicht.
                              Eine generelle Anregung zu zukünftigen Verbesserungen hätte ich dennoch - ich hoffe man versteht das nicht als Kritik. Vielleicht könnte man dem Adapter ja generell beibringen - dass er aktiv die Zustände (states) setzt, die zuletzt in den Datenpunkten gespeichert waren (Vielleicht als Option). Bei Sensoren macht das natürlich keinen Sinn, aber bei Aktoren, wäre das in meinen Augen durchaus sinnvoll.
                              • mickymM mickym
                                AsgothianA Offline
                                AsgothianA Offline
                                Asgothian
                                @mickym sagte in ZigBee neue Version 1.4.4:
                                Bitte prüfe:
                                durch die Anpassungen der Geräteabfrage sollte der Adapter bei einem Gerät welches sich "Neu" wieder anmeldet den Status von verschiedenen States vom Gerät automatisch abfragen. Insbesondere sind das die Helligkeit sowie der an/aus Zustand von Lampen.
                                Das ganze findet dann statt wenn
                                • ein Gerät als Offline erkannt wurde (available = false)
                                • das Gerät das erste mal eine Meldung sendet (available geht auf true).
                                  Alle Lampen melden wenn sie Strom bekommen an das Netzwerk das sie "wieder da" sind.
                                A.
                                L mickymM 2 Antworten Letzte Antwort
                                  Bitte prüfe:
                                  A.
                                  legro
                                  @asgothian @arteck
                                  NUKI soll ja auch ZigBee beherrschen. Gibt es schon Bestrebungen dieses Türschloss zu unterstützen?
                                  Raspberry Pi 5 mit 8GB + 120GB SSD + Coordinator COD-m + ioBroker ..
                                  • L legro
                                    @asgothian @arteck
                                    @legro
                                    Zigbee ist zwar seitens nuki angekündigt gewesen, wird aber wohl jetzt doch nicht mehr umgesetzt. Irgendwelche Hardware-Limitationen, wenn ich das richtig gelesen habe.
                                    L 1 Antwort Letzte Antwort
                                      @legro
                                      legro
                                      @thomas-braun said in ZigBee neue Version 1.4.4:
                                      @legro
                                      Zigbee ist zwar seitens nuki angekündigt gewesen, wird aber wohl jetzt doch nicht mehr umgesetzt. ..
                                      Warten wir mal ab. Ich bin zuversichtlich, dass ich bald hier etwas tut.🙂
                                      • L legro
                                        @legro
                                        @legro
                                        Ich nicht:
                                        https://nuki.io/de/blog/nuki-news-de/nuki-sommer-update-2019/
                                        Aus dem nuki developer Forum:
                                        https://developer.nuki.io/t/zigbee-in-2-0/148/37
                                        It was mentioned already in last years blog post to the summer software 39 update that Zigbee is not doable with the current hardware in the quality that we wanted to do it. Therefore Zigbee is not supported and will - most likely - never be supported.
                                          @legro
                                          Ich nicht:
                                          legro
                                          schrieb am zuletzt editiert von legro
                                          Derzeit stehe ich in Kontakt mit NUKI. Die Signale, die ich erhalte, sind erfreulich andere.
                                          In den nächsten Tage soll ich offizielle und verbindliche Antworten erhalten. Dann sehen wir weiter.
                                          Was die Hardware betrifft, hast du wohl nicht ganz unrecht. Die verbaute Hardware wird wohl nur von ZigBee 3.0 unterstützt. Geräte, die 3.0 verstehen, sind jedoch kaum vorhanden. Mein Coordinator CC26X2R1 von Intel kann jedoch ZigBee 3.0.
                                          Derzeit ist ZigBee in der Tat definitiv in den NUKI 2.0 deaktiviert.
