  5. Abfrage mit Axios
Abfrage mit Axios
javascript
25 Beiträge 6 Kommentatoren 3.7k Aufrufe 5 Beobachtet
  • cashC Offline
    cashC Offline
    cash
    Ich möchte gerne eine WLAN Lampe steuern. Das ganze per Axios aber irgendwie verstehe ich einfach nicht wie es geht.
    Wer kann mir helfen oder ein Beispiel zeigen?
    Hier mein Code:
    function func_test(){
        const axios = require('axios').default;
        URL = "http://192.168.178.75:9123/elgato/lights";
        //--header 'Content-Type: application/json' \
        //--data-raw '{"lights":[{"brightness":10,"temperature":162,"on":1}],"numberOfLights":1}'
        //--data-raw '{"lights":[{"on":0}],"numberOfLights":1}'
        axios({
            method: 'post',
            url: 'http://192.168.178.75:9123/elgato/lights',
            headers: {'Content-Type':'application/x-www-form-urlencoded'} ,
            data: {
                    "numberOfLights":1
        .then(function (response) {
            console.log(response);
            console.log(response.status);
            console.log(response.headers);
        .catch(function (error) {
            console.log(error);
    	    if (error.response) {
            // The request was made and the server responded with a status code
            // that falls out of the range of 2xx
            console.log(error.response.data);
            console.log(error.response.status);
            console.log(error.response.headers);
            } else if (error.request) {
                log('else-if');
            // The request was made but no response was received
            // `error.request` is an instance of XMLHttpRequest in the browser and an instance of
            // http.ClientRequest in node.js
            console.log(error.request);
            } else {
                // Something happened in setting up the request that triggered an Error
                log('else');
                console.log('Error', error.message);
        .then(function () {
            // always executed
    Log:
    javascript.2	2021-02-02 10:07:29.291	info	(9965) script.js.Büro.Videolicht: {'content-type':'application/json; charset=utf-8','content-length':'0','connection':'keep-alive'}
    javascript.2	2021-02-02 10:07:29.291	info	(9965) script.js.Büro.Videolicht: 404
    javascript.2	2021-02-02 10:07:29.291	info	(9965) script.js.Büro.Videolicht: {'message':'Request failed with status code 404','name':'Error','stack':'Error: Request failed with status code 404\n at createError (/opt/iobroker/node_modules/a
    javascript.2	2021-02-02 10:07:29.268	info	(9965) script.js.Büro.Videolicht: registered 2 subscriptions and 0 schedules
    AlCalzoneA H 2 Antworten Letzte Antwort
    • cashC cash
      Hier mein Code:
          axios({
              method: 'post',
              data: {
                      "numberOfLights":1
              console.log(error);
                  log('else-if');
              } else {
                  log('else');
          .then(function () {
              // always executed
      Log:
      AlCalzoneA Offline
      AlCalzoneA Offline
      AlCalzone
      @cash sagte in Abfrage mit Axios:
      Das heißt die angeforderte Adresse stimmt nicht.
      Warum sudo böse ist: https://forum.iobroker.net/post/17109
      cashC 1 Antwort Letzte Antwort
      • cashC cash
        Hier mein Code:
            axios({
                method: 'post',
                data: {
                        "numberOfLights":1
                console.log(error);
                    log('else-if');
                } else {
                    log('else');
            .then(function () {
                // always executed
        Log:
        homecineplexx
        @cash said in Abfrage mit Axios:
        vor allem definierst du oben die URL und dann im axios part gibst sie nochmals ein. also wenns eh die gleiche ist, kannst ja gleich URL hinschreiben
        • H homecineplexx
          cashC Offline
          cashC Offline
          cash
          @homecineplexx das war copy & paste aus verschiedenen Scripten. Ist also für die Abfrage eher nebensächlich
          • AlCalzoneA AlCalzone
            cashC Offline
            cashC Offline
            cash
            @alcalzone das kann nicht sein. Wenn ich die Adresse im Brwoser eingebe bekomme ich eine Antwort. Wenn ich das gleiche mit get mache bekomme ich eine Antwort (Script mit Ergebnis im nächsten Post).
            Wenn ich eine sh Datei ausführe funktioniert es auch:
            #!/bin/bash
            curl --location --request PUT 'http://192.168.178.75:9123/elgato/lights' \
            --data-raw '{"lights":[{"brightness":55,"temperature":189,"on":1}],"numberOfLights":1}'
            cashC AlCalzoneA 2 Antworten Letzte Antwort
            • cashC cash
              #!/bin/bash
              cashC Offline
              cashC Offline
              cash
              So hier das Script womit ich es schaffe den Status zu holen:
              function func_elgato_status_neu(){
                  const axios = require('axios');
                  axios({
                      method: 'get',
                      baseURL: 'http://192.168.178.75:9123/elgato/lights',
                      timeout: 4500,
                       responseType: 'json'
                   .then((response) => {
                      if(debugging){
                          console.log('data:' +response.data);
                          console.log('Status: ' +response.status);
                          console.log('Header:' +response.headers);
                      if(response.status = 200){
                          //Umwandeln in String
                          var data_string = JSON.stringify(response.data)
                          //1. Split
                          var data_split= data_string.split("{");
                          //Unnötige Sachen entfernen
                          var data_replace = data_split[2].replace(/}|,|]|:/gi,'');
                          //mit 2. Split zum Ergebnis
                          var data_final = data_replace.split('"');
                          //Ergebnisse
                          var _Status = parseInt(data_final[2],10);
                          var _Helligkeit = parseInt(data_final[4],10);
                          var _Temperatur = parseInt(data_final[6],10);
                          if(_Status == 1){
                              if(logging){
                                  log('Elgato Key light air ist eingeschaltet');
                                  log('Helligkeit: '+_Helligkeit +' --- Temperatur: '+_Temperatur);
                          else{
                              if(logging){
                                  log('Elgato Key light air ist ausgeschaltet');
                                  //log('Helligkeit: '+_Helligkeit +' --- Temperatur: '+_Temperatur);
                          if(debugging){
                              log('Status: '+_Status);
                              log('Helligkeit: '+_Helligkeit);
                              log('Temperatur: '+_Temperatur);
                      else{
                          if(logging){
                              log('Hier stimmt etwas nicht. Elgato Key Light air Meldung: '+response.status)
                  .catch(
                      (error) => {
                          // handle error
                          log('Fehler bei der Abfrage der Elgator Key Light air: '+error,'warn');
              Ergebnis wenn Lampe an ist:
              javascript.2	2021-02-02 17:55:47.812	info	(9965) script.js.Büro.Videolicht: Helligkeit: 20 --- Temperatur: 173
              javascript.2	2021-02-02 17:55:47.811	info	(9965) script.js.Büro.Videolicht: Elgato Key light air ist eingeschaltet
              • cashC cash
                #!/bin/bash
                AlCalzoneA Offline
                AlCalzoneA Offline
                AlCalzone
                --request PUT
                In deinem Skript hast du post als Methode genutzt statt put 🤔
                cashC 3 Antworten Letzte Antwort
                  --request PUT
                  cashC Offline
                  cashC Offline
                  cash
                  @alcalzone ich Torfkopf 😠
                  Wenn ich dort ein put hinschreibe geht die Lampe tatsächlich an. Nur noch ein kleines Problem.
                  Der Response ist ein Fehler:
                  Im Log kommt:
                  javascript.2	2021-02-02 18:47:23.481	info	(9965) script.js.Büro.Videolicht: Error: TypeError: Converting circular structure to JSON
                  javascript.2	2021-02-02 18:47:23.480	warn	(9965) script.js.Büro.Videolicht: Unknown severity level "Converting circular structure to JSON" by log of [Error]
                  javascript.2	2021-02-02 18:47:23.480	info	(9965) script.js.Büro.Videolicht: else
                  javascript.2	2021-02-02 18:47:23.480	info	(9965) script.js.Büro.Videolicht: {}
                  Dazu habe ich den else Teil etwas angepasst neu dort:
                              log('else');
                              log('Error: '+error);
                    --request PUT
                    cashC Offline
                    cashC Offline
                    cash
                    @alcalzone hat sich erledigt. Ich habe das Script etwas angepasst. Vielen, vielen Dank für Deine Hilfe
                    Hier die Lösung für die Nachwelt falls jemand sich auch diese Lampe kauft und einbinden will:
                    function func_elgato_schalten(){
                        axios({
                            method: 'put',
                            data: {
                                    "lights":[{"on":1}],
                                    "numberOfLights":1
                            timeout: 4500,
                            if(debugging){
                                //1. Split
                                //Ergebnisse
                                if(_Status == 1){
                                    if(logging){
                                else{
                                    if(logging){
                                if(debugging){
                            else{
                                if(logging){
                        .catch(
                            (error) => {
                                // handle error
                                    log('else-if');
                                else {
                                    log('else');
                                    log('Error: ' +error);
                    Jetzt werde ich noch Felder anlegen wo die Temperatur und die Helligkeit abgelegt wird und ich so flexibel schalten kann.
                      --request PUT
                      cashC Offline
                      cashC Offline
                      cash
                      @alcalzone Ich habe doch noch eins. :
                      Ich denke irgendwie passt das nicht. Aber ich finde es sieht eigentlich richtig aus. Ich möchte:
                      data: {
                                      "numberOfLights":1
                      durch das ersetzen:
                      data: {
                                      "numberOfLights":1
                      so war es in der sh-Datei:
                      • cashC cash
                        data: {
                                        "numberOfLights":1
                        durch das ersetzen:
                        data: {
                                        "numberOfLights":1
                        cashC Offline
                        cashC Offline
                        cash
                        Ich bin echt doof. Ich habe wohl zuviel getestet, so dass ich einen Fehler an anderer Stelle übersehen habe. Funktioniert genau so
                        H 1 Antwort Letzte Antwort
                        • cashC cash
                          hwiedermann
                          @cash halli hallo. also habe ich es richtig verstanden, dass du nun den Stauts abfragen kannst? Werden die Werte in Datenobjekte geschrieben, wie bei iobroker üblich?
                          wie genau schaltest du die Lampe nun?
                          • H hwiedermann
                            cashC Offline
                            cashC Offline
                            cash
                            @hwiedermann Nur um es deutlich zu machen: Wir sprechen hier über ein Elgato Keylight bzw Keylight air! Habe mittlerweile beide. In Javascript nutze ich aber nur die Air. Ich habe mir ein paar Datenpunkte angelegt. Diese lasse ich synchronisieren, d. h. ich lasse alle x Minuten (ich glaube 30 Minuten) die Daten abfragen. Damit ioBroker auch mitbekommt falls die Lampe per App gesteuert wird. Was ich aber eher selten mache und deshalb die 30 Minuten ok fand. Ich will halt das System nicht unnötig belasten. Theoretisch kann man das vermutlich im Sekunden bereich machen.
                            Ich kann nun die Lampe entweder mit ioBroker schalten oder mit der App am Mac, iphone oder ipad. Ich kann per ioBroker alles so einstellen wie in der App. Also hell, dunkel, Lichtfarbe oder eiinfach einschalten (was dann die gleichen Werte sind wie beim letzten ausschalten. Mehr oder weniger ist die Lösung ja hier im Thread vermerkt. Alles andere ist nur noch etwas feinarbeit…
                            • cashC cash
                              hwiedermann
                              @cash jau damit hast du genau das, was ich auch möchte.
                              ich bekomme das script aber bei mir nicht zum laufen, weil es vermutlich völlig an basics mangelt.
                              ich habe es kopiert, als JS eingefügt und die IP angepasst.
                              script gestartet.
                              es passiert nix
                              erst gab es noch nen complie error, habe dann via NPM axios nach installiert.
                              dennoch tut sich nix.
                              könntest du es bitte vllt. noch etwas "dümmer-freundlicher" erklären? Danke für deine Hilfe.
                              Wenn du die Elgatos hast, bist du Streamer? Hast du doch schon mit dem Websocket von OBS mal befasst?
                              • H hwiedermann
                                script gestartet.
                                es passiert nix
                                cashC Offline
                                cashC Offline
                                cash
                                @hwiedermann Bitte mal in Zeile 1 ein looging = true; und in 2 debugging = true;
                                Danach sollte Du im Log etwas sehen
                                Habe mich zwar mit OBS etwas beschäftigt. Mehr aber auch nicht. Bin kein Streamer nur ein Spielkind der sich mit technischen Quatsch beschäftigt :-) Nutze die Air hauptsächlich als Homeofficelampe, die halt automatisch geschaltet wird wenn ich arbeiten muss. Zusammen mit dem Keylight kann ich beides aber auch als Videolicht nutzen für Meetings.
                                Die Frage ist halt was Du willst. GGf wäre sonst eine Bashdatei einfacher für Dich. Etwas javscript Kenntnisse sollten schon vorhanden sein für die Lösung. Schreib mal was Du genau willst dann schauen wir weiter. Und wichtig Log-Ausgabe
                                • cashC cash
                                  hwiedermann
                                  @cash
                                  mein LOG bleibt nahezu leer.
                                  und hier mal das Script
                                  Ich finde den Fehler nicht?!
                                  Den Rest schreibe ich dir sonst mal via PN.
                                  cashC 4 Antworten Letzte Antwort
                                  • H hwiedermann
                                    @cash
                                    cashC Offline
                                    cashC Offline
                                    cash
                                    @hwiedermann sorry bitte noch ein var jeweils vor logging und debugging…
                                    • H hwiedermann
                                      @cash
                                      cashC Offline
                                      cashC Offline
                                      cash
                                      @hwiedermann was passiert eigentlich wenn Du: http://192.168.178.71:9123/elgato/lights im Browser eingibst? Natürlich IP anpassen. Die IP sollte natürlich fest vergeben werden.
                                      • H hwiedermann
                                        @cash
                                        cashC Offline
                                        cashC Offline
                                        cash
                                        @hwiedermann letzte Anmerkung. Das ist aber nicht das ganze Script oder? Ganz unten fehlt noch was… Sonst wird das Script nicht ausgeführt.
                                        • H hwiedermann
                                          @cash
                                          cashC Offline
                                          cashC Offline
                                          cash
                                          @hwiedermann ok, das Beispiel zeigt nicht das komplette Script sondern nur einen Ausschnitt. Bitte in die letzte Zeile also hinter } eine neue Zeile und dort noch func_elgato_schalten();
                                          WestWoodW 1 Antwort Letzte Antwort
