  4. Test Adapter tvprogram
    6.0k
adaptertvprogramviswidget
929 Beiträge 51 Kommentatoren 333.3k Aufrufe 51 Beobachtet
  • ChaotC Offline
    ChaotC Offline
    Chaot
    #781
    @OliverIO
    Ich bin auch mit einer Fehlermeldung gesegnet. Dieist allerdings ausführlicher.
    Vielleicht hilft das weiter:
    host.ioBroker
    2022-01-02 08:34:00.754	error	instance system.adapter.tvprogram.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    tvprogram.0
    2022-01-02 08:33:59.647	error	Exception-Code: ERR_INVALID_ARG_TYPE: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received undefined
    tvprogram.0
    2022-01-02 08:33:59.647	error	TypeError [ERR_INVALID_ARG_TYPE]: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received undefined at Object.writeFile (fs.js:1491:5) at tvprogramclass.writeFile (/opt/iobroker/node_modules/iobroker.tvprogram/lib/tvprogramserver.js:805:12) at /opt/iobroker/node_modules/iobroker.tvprogram/lib/tvprogramserver.js:643:22 at ClientRequest.<anonymous> (/opt/iobroker/node_modules/iobroker.tvprogram/lib/tvprogramserver.js:757:13) at ClientRequest.emit (events.js:400:28) at TLSSocket.socketErrorListener (_http_client.js:475:9) at TLSSocket.emit (events.js:400:28) at emitErrorNT (internal/streams/destroy.js:106:8) at emitErrorCloseNT (internal/streams/destroy.js:74:3) at processTicksAndRejections (internal/process/task_queues.js:82:21)
    tvprogram.0
    2022-01-02 08:33:59.646	error	uncaught exception: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received undefined
    tvprogram.0
    2022-01-02 08:33:59.559	error	read ECONNRESET
    tvprogram.0
    2022-01-02 08:33:59.460	error	read ECONNRESET
    tvprogram.0
    2022-01-02 08:33:59.039	error	read ECONNRESET
    • LatziL Offline
      LatziL Offline
      Latzi
      #782
      Bei mir tritt der Fehler auch auf:
      2022-01-02 09:11:30.538 - error: tvprogram.0 (6958) read ECONNRESET
      2022-01-02 09:11:30.786 - error: tvprogram.0 (6958) read ECONNRESET
      2022-01-02 09:11:30.933 - error: tvprogram.0 (6958) read ECONNRESET
      2022-01-02 09:11:31.062 - error: tvprogram.0 (6958) read ECONNRESET
      2022-01-02 09:11:31.070 - error: tvprogram.0 (6958) uncaught exception: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received undefined
      2022-01-02 09:11:31.071 - error: tvprogram.0 (6958) TypeError [ERR_INVALID_ARG_TYPE]: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received undefined
      at /opt/iobroker/node_modules/iobroker.tvprogram/lib/tvprogramserver.js:619:22
      at ClientRequest. (/opt/iobroker/node_modules/iobroker.tvprogram/lib/tvprogramserver.js:757:13)
      2022-01-02 09:11:31.071 - error: tvprogram.0 (6958) Exception-Code: ERR_INVALID_ARG_TYPE: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received undefined
      2022-01-02 09:11:31.075 - error: tvprogram.0 (6958) read ECONNRESET
      2022-01-02 09:11:31.080 - error: tvprogram.0 (6958) uncaught exception: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received undefined
      2022-01-02 09:11:31.080 - error: tvprogram.0 (6958) TypeError [ERR_INVALID_ARG_TYPE]: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received undefined
      2022-01-02 09:11:31.081 - error: tvprogram.0 (6958) Exception-Code: ERR_INVALID_ARG_TYPE: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received undefined
      2022-01-02 09:11:31.092 - info: tvprogram.0 (6958) cleaned everything up...
      2022-01-02 09:11:31.095 - info: tvprogram.0 (6958) terminating
      2022-01-02 09:11:31.096 - warn: tvprogram.0 (6958) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2022-01-02 09:11:31.785 - error: host.Pi4-Server instance system.adapter.tvprogram.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2022-01-02 09:11:31.791 - info: host.Pi4-Server Restart adapter system.adapter.tvprogram.0 because enabled
      • LatziL Latzi
        OliverIOO Offline
        OliverIOO Offline
        OliverIO
        #783
        @latzi
        Das war schon vor einer Weile mal so.
        Die Fehlermeldung sagt das der Server der die tv Daten liefert aktuell nicht reagiert.
        Ich habe gerade die Webseite des Dienstes ausprobiert. Da funktioniert es.
        Könntet ihr nochmal probieren?
        Nicht das die api geändert wurde
        Meine Adapter und Widgets
        Links im Profil
        • OliverIOO OliverIO
          @latzi
          ChaotC Offline
          ChaotC Offline
          Chaot
          #784
          @oliverio Da könntest du Recht haben.
          Bis 11:30 Uhr noch ein paar Fehler:
          tvprogram.0 2022-01-02 11:24:17.135	error	read ECONNRESET
          tvprogram.0 2022-01-02 11:24:17.128	error	read ECONNRESET
          tvprogram.0 2022-01-02 11:24:17.051	error	read ECONNRESET
          tvprogram.0 2022-01-02 11:24:16.932	error	read ECONNRESET
          tvprogram.0 2022-01-02 10:24:23.011	error	read ECONNRESET
          tvprogram.0 2022-01-02 10:24:22.996	error	read ECONNRESET
          tvprogram.0 2022-01-02 10:24:22.995	error	read ECONNRESET
          tvprogram.0 2022-01-02 10:24:22.922	error	read ECONNRESET
          tvprogram.0 2022-01-02 10:24:22.828	error	read ECONNRESET
          tvprogram.0 2022-01-02 10:24:22.689	error	read ECONNRESET
          und dann plötzlich Ruhe.
          Auch jetzt, nach einem manuellen Neustart des Adapters keine Fehlermeldung.
          Eventuell war die Gegenstelle weg oder hat Mist ausgeliefert.
          • ChaotC Chaot
            OliverIOO Offline
            OliverIOO Offline
            OliverIO
            #785
            @chaot
            so gerade mal direkt am iobroker probiert.
            läuft wieder normal.
            so wie es aussieht war die quelle eine Zeitlang weg
            ich schreib mir mal auf, die Fehlermeldung zu verbessern.
            Links im Profil
              @chaot
              Tschaeens
              #786
              @oliverio
              geht bei mir auch wieder. Danke dir fürs Drüberschauen!
              Lieben Gruß
                markusk1407
                #787
                Hallo!
                Ich habe eben den Adapter installiert und er funktioniert soweit problemlos. Meine Schwierigkeit liegt eher darin das Script (für Harmony) mit einzubauen. Wie soll es ausgelöst werden? In den Widgets, die mit dem Adapter kommen, gibt es ja keine Möglichkeit.
                LG
                Markus
                • M markusk1407
                  Hallo!
                  LG
                  Markus
                  OliverIOO Offline
                  OliverIOO Offline
                  OliverIO
                  #788
                  @markusk1407
                  Was möchtest du den genau machen?
                  Links im Profil
                    @markusk1407
                    markusk1407
                    #789
                    @oliverio Da steht doch, das man mit dem Script beim Druck auf das Sendersymbol über Harmony direkt den Sender wählen kann. Aber wie bekomme ich denn Programmübersicht (TV-Programm-Adapter), Script und Harmony-Adapter im Vis zusammen?
                    • M markusk1407
                      OliverIOO Offline
                      OliverIOO Offline
                      OliverIO
                      #790
                      @markusk1407
                      Es gibt den datenpunkt selectchannel.
                      Auf den reagierst du und sendest an den Fernseher (harmony?) den Befehl zum umschalten.
                      https://github.com/oweitman/ioBroker.tvprogram#provided-datapoints
                      Links im Profil
                        @markusk1407
                        markusk1407
                        #791
                        @oliverio Ich checks nicht so richtig 😕 also muss ich einen button selber anlegen, der dann das entsprechende Programm an den Datenpunkt sendet?
                        • M markusk1407
                          OliverIOO Offline
                          OliverIOO Offline
                          OliverIO
                          #792
                          @markusk1407
                          Nein, ich zitiere aus der Hilfe
                          selectchannel
                          This datapoint is used to recognize a channel switch command with a click on the channel logo or the switch icon in the detail view.
                          Sobald du auf ein Senderlogo in den widgets timetable und control drückst wird vom widget der datenpunkt selectchannel mit einem senderkürzel beschrieben. bspw pro7 oder sat1
                          du erstellst dann im javascript adapter mit javascript oder mit blockly ein skript, das auf Anderungen dieses datenpunkts reagiert, du wertest aus, was im datenpunkt drin steht und sendest dann an deinen fernseher den befehl der ihn umschalten lässt.
                          var selectChannelDP = "tvprogram.0.tv1.selectchannel";
                          on(selectChannelDP, function (obj) {
                              if (obj.state.val=="pro7") {
                                  console.log("Schalte meinen Fernseher auf Programm "+obj.state.val);
                                  //Hier der Befehl zum Fernseher schalten
                              if (obj.state.val=="sat1") {
                              //Hier weitere Sendermappings wie oben einfügen
                          Welche Senderkürzel es gibt, kann aus der folgenden Datei entnommen werden, welche es auch unter
                          /opt/iobroker/iobroker-data/tvprogram/channels.json
                          Die Datei müsste vorhanden sein, sobald der Adapter einmal startet wurde.
                          Das senderkürzel steht hier unter channelId
                          wie dein Fernseher zu schalten ist, weiß ich nicht, da das vom jeweiligen Modell und Senderplatz bei dir abhängt. Wenn du Harmony erwähnst, dann schaue mal unter der Hilfe des harmony Adapters, wie dort Sender geschaltet werden können.
                                  "id": 1,
                                  "channelId": "ard",
                                  "name": "Das Erste",
                                  "slug": "das-erste",
                                  "order": 1
                                  "id": 6,
                                  "channelId": "zdf",
                                  "name": "ZDF",
                                  "slug": "zdf",
                                  "order": 4
                                  "id": 22,
                                  "channelId": "rtl",
                                  "name": "RTL",
                                  "slug": "rtl",
                                  "order": 6
                                  "id": 7,
                                  "channelId": "sat1",
                                  "name": "Sat.1",
                                  "slug": "sat-1",
                                  "order": 8
                                  "id": 11,
                                  "channelId": "pro7",
                                  "name": "ProSieben",
                                  "slug": "prosieben",
                                  "order": 10
                                  "id": 30,
                                  "channelId": "vox",
                                  "name": "VOX",
                                  "slug": "vox",
                                  "order": 12
                                  "id": 32,
                                  "channelId": "zdfneo",
                                  "name": "ZDF Neo",
                                  "slug": "zdf-neo",
                                  "order": 14
                                  "id": 24,
                                  "channelId": "one",
                                  "name": "One",
                                  "slug": "one",
                                  "order": 16
                                  "id": 13,
                                  "channelId": "bayern3",
                                  "name": "BR",
                                  "slug": "br",
                                  "order": 18
                                  "id": 16,
                                  "channelId": "hessen3",
                                  "name": "HR",
                                  "slug": "hr",
                                  "order": 20
                                  "id": 12,
                                  "channelId": "mdr",
                                  "name": "MDR",
                                  "slug": "mdr",
                                  "order": 22
                                  "id": 4,
                                  "channelId": "radiobremen",
                                  "name": "Radio Bremen",
                                  "slug": "radio-bremen",
                                  "order": 24
                                  "id": 18,
                                  "channelId": "nord3",
                                  "name": "NDR",
                                  "slug": "ndr",
                                  "order": 25
                                  "id": 19,
                                  "channelId": "rbb",
                                  "name": "RBB",
                                  "slug": "rbb",
                                  "order": 26
                                  "id": 33,
                                  "channelId": "sw3",
                                  "name": "SWR",
                                  "slug": "swr",
                                  "order": 28
                                  "id": 41,
                                  "channelId": "sw3.sr",
                                  "name": "SR",
                                  "slug": "sr",
                                  "order": 28
                                  "id": 43,
                                  "channelId": "west3",
                                  "name": "WDR",
                                  "slug": "wdr",
                                  "order": 30
                                  "id": 39,
                                  "channelId": "rtl2",
                                  "name": "RTL 2",
                                  "slug": "rtl-2",
                                  "order": 32
                                  "id": 35,
                                  "channelId": "kaka",
                                  "name": "Kabel 1",
                                  "slug": "kabel-1",
                                  "order": 34
                                  "id": 38,
                                  "channelId": "srtl",
                                  "name": "Super RTL",
                                  "slug": "super-rtl",
                                  "order": 36
                                  "id": 8,
                                  "channelId": "tele5",
                                  "name": "Tele 5",
                                  "slug": "tele-5",
                                  "order": 38
                                  "id": 25,
                                  "channelId": "pro7maxx",
                                  "name": "Pro7 Maxx",
                                  "slug": "pro7-maxx",
                                  "order": 40
                                  "id": 3,
                                  "channelId": "rtlnitro",
                                  "name": "Nitro",
                                  "slug": "nitro",
                                  "order": 42
                                  "id": 10,
                                  "channelId": "sixx",
                                  "name": "Sixx",
                                  "slug": "sixx",
                                  "order": 44
                                  "id": 26,
                                  "channelId": "3sat",
                                  "name": "3sat",
                                  "slug": "3sat",
                                  "order": 46
                                  "id": 9,
                                  "channelId": "kika",
                                  "name": "Kinderkanal",
                                  "slug": "kinderkanal",
                                  "order": 48
                                  "id": 37,
                                  "channelId": "arte",
                                  "name": "Arte",
                                  "slug": "arte",
                                  "order": 50
                                  "id": 23,
                                  "channelId": "phoenix",
                                  "name": "Phoenix",
                                  "slug": "phoenix",
                                  "order": 52
                                  "id": 34,
                                  "channelId": "tagesschau24",
                                  "name": "tagesschau24",
                                  "slug": "tagesschau24",
                                  "order": 54
                                  "id": 36,
                                  "channelId": "info",
                                  "name": "ZDF Info",
                                  "slug": "zdf-info",
                                  "order": 56
                                  "id": 14,
                                  "channelId": "ntv",
                                  "name": "ntv",
                                  "slug": "ntv",
                                  "order": 58
                                  "id": 5,
                                  "channelId": "alpha",
                                  "name": "ARD-alpha",
                                  "slug": "ard-alpha",
                                  "order": 60
                                  "id": 2,
                                  "channelId": "dmax",
                                  "name": "DMAX",
                                  "slug": "dmax",
                                  "order": 62
                                  "id": 28,
                                  "channelId": "welt",
                                  "name": "WELT",
                                  "slug": "welt",
                                  "order": 64
                                  "id": 27,
                                  "channelId": "disney",
                                  "name": "Disney Channel",
                                  "slug": "disney-channel",
                                  "order": 66
                                  "id": 15,
                                  "channelId": "comedycentral",
                                  "name": "Comedy Central",
                                  "slug": "comedy-central",
                                  "order": 68
                                  "id": 31,
                                  "channelId": "orf1",
                                  "name": "ORF 1",
                                  "slug": "orf-1",
                                  "order": 70
                                  "id": 21,
                                  "channelId": "orf2",
                                  "name": "ORF 2",
                                  "slug": "orf-2",
                                  "order": 72
                                  "id": 17,
                                  "channelId": "mtv",
                                  "name": "MTV",
                                  "slug": "mtv",
                                  "order": 74
                                  "id": 29,
                                  "channelId": "eurosp",
                                  "name": "Eurosport",
                                  "slug": "eurosport",
                                  "order": 78
                                  "id": 20,
                                  "channelId": "sport1de",
                                  "name": "Sport1",
                                  "slug": "sport1",
                                  "order": 80
                                  "id": 40,
                                  "channelId": "anixehd",
                                  "name": "Anixe HD Serie",
                                  "slug": "anixe-hd-serie",
                                  "order": 82
                          Links im Profil
                          • K Offline
                            Klaus18
                            #793
                            Adapter TVprogram läuft, allerdings sind die Widgets in Vis nicht vorhanden. Habe mehrere Male neu installiert. ioBroker läuft auf einem Mac mit Node 16.3.1 und NPM 8.1.2. Wie komme ich an die Widgets ???
                            • K Klaus18
                              OliverIOO Offline
                              OliverIOO Offline
                              OliverIO
                              #794
                              @klaus18
                              Hast du in vis im Suchfeld auch einmal nach tvprogram gefiltert?
                              Wenn du die Widgets einfügen konntest die aber in vis runtime nicht angezeigt werden dann versuche bitte mal in die Developer console deines Browsers zu kommen.
                              Bei chrome wäre das f12. Bei Safari weiß ich das leider nicht.
                              Dann die Seite aufrufen wo die Widgets angezeigt werden sollten.
                              Dort müsste unter einem reiter console Fehlermeldungen angezeigt werden. Diese müssten einen Hinweis darauf geben was nicht funktioniert.
                              Links im Profil
                              K 1 Antwort Letzte Antwort
                                @klaus18
                                Klaus18
                                #795
                                @oliverio In der Suchleiste von Vis ist tvprogram nicht aufgeführt. - Habe von stable installiert, versuchsweise auch im Expertenmodus. Dort kam dann der Hinweis: Keine Versionsinfo für Vis.
                                • OliverIOO Offline
                                  OliverIOO Offline
                                  OliverIO
                                  #796
                                  @klaus18
                                  ok, das ist zwar selten, aber versuche mal auf der console den folgenden befehl auszuführen.
                                  dadurch werden die vis-anteile der adapter dem vis nochmal bekannt gemacht.
                                  das sollte eigentlich nach jedem update laufen. scheint hier nicht funktioniert zu haben
                                  iob upload all
                                  Links im Profil
                                    @klaus18
                                    iob upload all
                                    Klaus18
                                    #797
                                    @oliverio Ergebnis in der Konsole: INFO: Directory "for tvprogram.admin" was not found! Nothing was uploaded or deleted.
                                    Cannot find io-package.json for "tvprogram"
                                    INFO: Directory "for tvprogram" was not found! Nothing was uploaded or deleted.
                                    • K Klaus18
                                      OliverIOO Offline
                                      OliverIOO Offline
                                      OliverIO
                                      #798
                                      @klaus18 sagte in Test Adapter tvprogram:
                                      hm, und der adapter läuft?
                                      wenn diese datei nicht existiert, dann kennt der iobroker einen adapter eigentlich nicht.
                                      mach mal bitte auf der konsole:
                                      npm -v
                                      wenn bei der ausgabe als versionsnummer da nicht 6 dran steht, dann verwendest du eine aktuell für iobroker nicht zulässige npm installation. ach da oben hast ja geschrieben 8.1.2
                                      vergleiche auch
                                      Links im Profil
                                      K apollon77A 2 Antworten Letzte Antwort
                                      -1
                                        npm -v
                                        vergleiche auch
                                        Klaus18
                                        #799
                                        @oliverio erst einmal vielen Dank! Jetzt habe ich wenigstens einen Ansatz, was ich tun kann.
                                          markusk1407
                                          #800
                                          @oliverio Vielen Dank für deine Hilfe! Im Script stimmte die OID nicht zum Senden an den Receiver.
