  4. Aktualisierungen der Adapter funktionieren nicht
adapter update error
44 Beiträge 5 Kommentatoren 5.0k Aufrufe 3 Beobachtet
  • Guido SpoltmannG Guido Spoltmann
    @wendy2702
    Karte raus aus dem PI, neu formatiert.....Karte rein, Nodejs & ioborker installiert.
    pi@raspberrypi:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
    /usr/bin/nodejs
    v12.20.0
    /usr/bin/node
    v12.20.0
    /usr/bin/npm
    6.14.8
    nodejs:
      Installed: 12.20.0-1nodesource1
      Candidate: 12.20.0-1nodesource1
      Version table:
     *** 12.20.0-1nodesource1 500
            500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
            100 /var/lib/dpkg/status
         10.21.0~dfsg-1~deb10u1+rpi1 500
    pi@raspberrypi:~ $
      Finalizing installation (4/4)
    Enabling autostart...
    Autostart enabled!
        ioBroker was installed successfully
        Open http://192.168.178.76:8081 in a browser and start configuring!
    You need to re-login before doing anything else on the console!
    pi@raspberrypi:~ $
    Jetzt sollte im Browser http://192.168.178.76:8081 der Admin Bereich starten.
    Es kommt aber leider nichts, das bedeutet das die Browserseite weiß bleibt.
    ipconfig
    pi@raspberrypi:~ $ ifconfig
    eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
            inet 192.168.178.76  netmask 255.255.255.0  broadcast 192.168.178.255
            inet6 2a06:6a40:101:e901:b10f:1e7b:f0aa:14ad  prefixlen 128  scopeid 0x0<global>
            inet6 2a06:6a40:101:e901:cff0:e657:543a:991d  prefixlen 64  scopeid 0x0<global>
            inet6 fe80::b10f:1e7b:f0aa:14ad  prefixlen 64  scopeid 0x20<link>
            ether dc:a6:32:99:b7:1c  txqueuelen 1000  (Ethernet)
            RX packets 295892  bytes 95501656 (91.0 MiB)
            RX errors 0  dropped 0  overruns 0  frame 0
            TX packets 20830  bytes 1712023 (1.6 MiB)
            TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
    lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
            inet 127.0.0.1  netmask 255.0.0.0
            inet6 ::1  prefixlen 128  scopeid 0x10<host>
            loop  txqueuelen 1000  (Local Loopback)
            RX packets 0  bytes 0 (0.0 B)
            TX packets 0  bytes 0 (0.0 B)
    wlan0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
            ether dc:a6:32:99:b7:1d  txqueuelen 1000  (Ethernet)
    route:
    pi@raspberrypi:~ $ route
    Kernel IP routing table
    Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
    default         fritz.box       0.0.0.0         UG    202    0        0 eth0
    192.168.178.0   0.0.0.0         255.255.255.0   U     202    0        0 eth0
    pi@raspberrypi:~ $
    resolv.conf
    pi@raspberrypi:~ $ cat /etc/resolv.conf
    # Generated by resolvconf
    domain fritz.box
    nameserver 192.168.178.1
    nameserver fd00::464e:6dff:fe26:9597
    pi@raspberrypi:~ $
    Sind wahrscheinlich wieder mehrere Fehler.
    LG
    Guido
    @Guido-Spoltmann sagte in Aktualisierungen der Adapter funktionieren nicht:
    was steht denn in der Browserkonsole (F12)
    Guido SpoltmannG 1 Antwort Letzte Antwort
      Guido SpoltmannG Offline
      Guido Spoltmann
      schrieb am zuletzt editiert von Guido Spoltmann
      @Homoran
      Die Website ist nicht erreichbar192.168.178.76 hat die Verbindung abgelehnt.
      Versuchen Sie Folgendes:
      Verbindung prüfen
      Proxy und Firewall prüfen
      ERR_CONNECTION_REFUSED
      Bild Console:
      Platform linux
      Betriebssystem linux
      Architektur arm
      CPUs 4
      Geschwindigkeit 600 MHz
      Modell ARMv7 Processor rev 3 (v7l)
      RAM 3.73 GB
      Node.js v12.20.0
      NPM 6.14.8
      Festplatte Größe 26.51 GB
        @Homoran
        Verbindung prüfen
        Bild Console:
        @Guido-Spoltmann dann hast du ein Problem in deinem Netz
          Guido Spoltmann
          @Homoran
          OK, Internet geht, zugriff via Putty geht auch......wie könnte man den das Problem ausfindig machen?
          Habe nur eine Fritzbox, einen unifi Switch, der Pi (war) an dem Switch und hängt jetzt direkt an der Fritzbox....
          Platform linux
          Architektur arm
          CPUs 4
          RAM 3.73 GB
          Node.js v12.20.0
          NPM 6.14.8
            @Homoran
            @Guido-Spoltmann
            iobroker list instances
              @Guido-Spoltmann
              Guido Spoltmann
              @Thomas-Braun sagte in Aktualisierungen der Adapter funktionieren nicht:
              pi@raspberrypi:~ $ iobroker list instances
              internal/modules/cjs/loader.js:818
                throw err;
              Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                  at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
                  at Function.Module._load (internal/modules/cjs/loader.js:667:27)
                  at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
                  at internal/main/run_main_module.js:17:47 {
                code: 'MODULE_NOT_FOUND',
                requireStack: []
              Platform linux
              Architektur arm
              CPUs 4
              RAM 3.73 GB
              Node.js v12.20.0
              NPM 6.14.8
                  throw err;
                  requireStack: []
                @Guido-Spoltmann
                Das ist nicht gut...
                iobroker -v
                iobroker status
                cd /opt/iobroker
                npm i iobroker.js-controller@3.1.6 --production
                Guido SpoltmannG wendy2702W 2 Antworten Letzte Antwort
                  @Guido-Spoltmann
                  iobroker -v
                  iobroker status
                  cd /opt/iobroker
                  Guido Spoltmann
                  Hab ich mir schon fast gedacht....
                  pi@raspberrypi:~ $ iobroker -v
                    throw err;
                    requireStack: []
                  pi@raspberrypi:~ $ iobroker status
                    throw err;
                    requireStack: []
                  pi@raspberrypi:~ $ cd /opt/iobroker
                  pi@raspberrypi:/opt/iobroker $ npm i iobroker.js-controller@3.1.6 --production
                  npm ERR! code EAI_AGAIN
                  npm ERR! errno EAI_AGAIN
                  npm ERR! request to https://registry.npmjs.org/iobroker.js-controller failed, reason: getaddrinfo EAI_AGAIN registry.npmjs.org
                  npm ERR!     /home/iobroker/.npm/_logs/2020-12-27T12_42_34_286Z-debug.log
                  Platform linux
                  Architektur arm
                  CPUs 4
                  RAM 3.73 GB
                  Node.js v12.20.0
                  NPM 6.14.8
                      throw err;
                      requireStack: []
                      throw err;
                      requireStack: []
                    @Guido-Spoltmann Immer noch ein Knoten in deinem lokalen Netz, würde ich sagen.
                        throw err;
                        requireStack: []
                        throw err;
                        requireStack: []
                      @Guido-Spoltmann
                      ping npmjs.org
                      traceroute npmjs.org
                        @Guido-Spoltmann
                        ping npmjs.org
                        Guido Spoltmann
                        pi@raspberrypi:/opt/iobroker $ ping npmjs.org
                        ping: npmjs.org: Temporary failure in name resolution
                        pi@raspberrypi:/opt/iobroker $ traceroute npmjs.org
                        Cannot handle "host" cmdline arg `npmjs.org' on position 1 (argc 1)
                        Platform linux
                        Architektur arm
                        CPUs 4
                        RAM 3.73 GB
                        Node.js v12.20.0
                        NPM 6.14.8
                          @Guido-Spoltmann
                          Tjoar...
                          Ohne DNS auch keine Namensauflösung. Hast du da irgendwas in der Fritzbox umgefummelt?
                            @Guido-Spoltmann
                            Tjoar...
                            Guido Spoltmann
                            @Thomas-Braun
                            Hi nein es läuft hie auch alles, habe 4 Teenies die mich sofort informiert hätten das das Internet nicht geht.
                            pi@raspberrypi:/opt/iobroker $ cat /etc/resolv.conf
                            domain fritz.box
                            Platform linux
                            Architektur arm
                            CPUs 4
                            RAM 3.73 GB
                            Node.js v12.20.0
                            NPM 6.14.8
                              @Thomas-Braun
                              domain fritz.box
                              @Guido-Spoltmann
                              ping 104.16.22.35
                                @Guido-Spoltmann
                                ping 104.16.22.35
                                Guido Spoltmann
                                ping 104.16.22.35
                                pi@raspberrypi:/opt/iobroker $ ping 104.16.22.35
                                PING 104.16.22.35 (104.16.22.35) 56(84) bytes of data.
                                64 bytes from 104.16.22.35: icmp_seq=1 ttl=58 time=10.4 ms
                                64 bytes from 104.16.22.35: icmp_seq=2 ttl=58 time=9.59 ms
                                64 bytes from 104.16.22.35: icmp_seq=3 ttl=58 time=9.53 ms
                                64 bytes from 104.16.22.35: icmp_seq=4 ttl=58 time=9.33 ms
                                64 bytes from 104.16.22.35: icmp_seq=5 ttl=58 time=8.94 ms
                                64 bytes from 104.16.22.35: icmp_seq=6 ttl=58 time=9.68 ms
                                64 bytes from 104.16.22.35: icmp_seq=7 ttl=58 time=9.41 ms
                                64 bytes from 104.16.22.35: icmp_seq=8 ttl=58 time=9.49 ms
                                64 bytes from 104.16.22.35: icmp_seq=9 ttl=58 time=9.28 ms
                                64 bytes from 104.16.22.35: icmp_seq=10 ttl=58 time=9.39 ms
                                64 bytes from 104.16.22.35: icmp_seq=11 ttl=58 time=23.2 ms
                                64 bytes from 104.16.22.35: icmp_seq=12 ttl=58 time=22.3 ms
                                64 bytes from 104.16.22.35: icmp_seq=13 ttl=58 time=9.21 ms
                                64 bytes from 104.16.22.35: icmp_seq=14 ttl=58 time=9.29 ms
                                64 bytes from 104.16.22.35: icmp_seq=15 ttl=58 time=9.27 ms
                                64 bytes from 104.16.22.35: icmp_seq=16 ttl=58 time=9.45 ms
                                64 bytes from 104.16.22.35: icmp_seq=17 ttl=58 time=30.4 ms
                                64 bytes from 104.16.22.35: icmp_seq=18 ttl=58 time=9.33 ms
                                64 bytes from 104.16.22.35: icmp_seq=19 ttl=58 time=25.3 ms
                                64 bytes from 104.16.22.35: icmp_seq=20 ttl=58 time=8.86 ms
                                64 bytes from 104.16.22.35: icmp_seq=21 ttl=58 time=9.44 ms
                                64 bytes from 104.16.22.35: icmp_seq=22 ttl=58 time=9.70 ms
                                ^C
                                --- 104.16.22.35 ping statistics ---
                                22 packets transmitted, 22 received, 0% packet loss, time 54ms
                                rtt min/avg/max/mdev = 8.855/12.307/30.355/6.268 ms
                                Platform linux
                                Architektur arm
                                CPUs 4
                                RAM 3.73 GB
                                Node.js v12.20.0
                                NPM 6.14.8
                                  ping 104.16.22.35
                                  ^C
                                  @Guido-Spoltmann Gut, also raus kommst du. Nur die Namensauflösung tickt nicht sauber.
                                  Ich vermute ja immer noch eine Einstellung in der Fritzbox.
                                  Kannst du die mal durchstarten?
                                    Guido Spoltmann
                                    @Thomas-Braun
                                    So Neustart ist erledigt...
                                    Habe jetzt nochmal die letzten Befehle in Putty eingetragen:
                                    PING npmjs.org(2606:4700::6810:1a23 (2606:4700::6810:1a23)) 56 data bytes
                                    64 bytes from 2606:4700::6810:1a23 (2606:4700::6810:1a23): icmp_seq=1 ttl=57 tim        e=9.73 ms
                                    64 bytes from 2606:4700::6810:1a23 (2606:4700::6810:1a23): icmp_seq=2 ttl=57 tim        e=9.47 ms
                                    64 bytes from 2606:4700::6810:1a23 (2606:4700::6810:1a23): icmp_seq=3 ttl=57 tim        e=9.08 ms
                                    64 bytes from 2606:4700::6810:1a23 (2606:4700::6810:1a23): icmp_seq=4 ttl=57 tim        e=9.29 ms
                                    64 bytes from 2606:4700::6810:1a23 (2606:4700::6810:1a23): icmp_seq=5 ttl=57 tim        e=9.33 ms
                                    64 bytes from 2606:4700::6810:1a23 (2606:4700::6810:1a23): icmp_seq=6 ttl=57 time=32.2 ms
                                    64 bytes from 2606:4700::6810:1a23 (2606:4700::6810:1a23): icmp_seq=7 ttl=57 time=39.2 ms
                                    64 bytes from 2606:4700::6810:1a23 (2606:4700::6810:1a23): icmp_seq=8 ttl=57 time=9.58 ms
                                    64 bytes from 2606:4700::6810:1a23 (2606:4700::6810:1a23): icmp_seq=9 ttl=57 time=9.51 ms
                                    64 bytes from 2606:4700::6810:1a23 (2606:4700::6810:1a23): icmp_seq=10 ttl=57 time=9.27 ms
                                    64 bytes from 2606:4700::6810:1a23 (2606:4700::6810:1a23): icmp_seq=11 ttl=57 time=9.20 ms
                                    64 bytes from 2606:4700::6810:1a23 (2606:4700::6810:1a23): icmp_seq=12 ttl=57 time=36.5 ms
                                    ^C
                                    --- npmjs.org ping statistics ---
                                    12 packets transmitted, 12 received, 0% packet loss, time 25ms
                                    rtt min/avg/max/mdev = 9.079/16.029/39.242/11.600 ms
                                    traceroute to npmjs.org (104.16.20.35), 30 hops max, 60 byte packets
                                     1  fritz.box (192.168.178.1)  0.392 ms  0.350 ms  0.295 ms
                                     2  185.113.144.6 (185.113.144.6)  4.897 ms  4.829 ms  4.719 ms
                                     3  185.113.144.2 (185.113.144.2)  4.658 ms  4.552 ms  4.622 ms
                                     4  185.113.144.1 (185.113.144.1)  4.555 ms  4.445 ms  4.381 ms
                                     5  ae0-408.dus10.core-backbone.com (81.95.15.37)  9.165 ms  9.097 ms  9.078 ms
                                     6  ae15-2029.fra30.core-backbone.com (81.95.15.70)  12.090 ms  10.177 ms  9.994 ms
                                     7  core-backbone.cloudflare.com (80.255.9.34)  10.854 ms  10.597 ms  10.815 ms
                                     8  104.16.20.35 (104.16.20.35)  10.522 ms  10.632 ms  10.632 ms
                                    Sieht besser aus oder?
                                    Platform linux
                                    Architektur arm
                                    CPUs 4
                                    RAM 3.73 GB
                                    Node.js v12.20.0
                                    NPM 6.14.8
                                    • wendy2702W Online
                                      wendy2702W Online
                                      wendy2702
                                      Kannst das auch mal an einem PC in einem Browser eingeben und schauen ob die Seite erreichbar ist.
                                      Klappt das liegt es wohl am PI.
                                      Klappt es nicht: Netzwerk bzw. Fritzbox
                                      • wendy2702W wendy2702
                                        Guido Spoltmann
                                        @wendy2702 sagte in Aktualisierungen der Adapter funktionieren nicht:
                                        Platform linux
                                        Architektur arm
                                        CPUs 4
                                        RAM 3.73 GB
                                        Node.js v12.20.0
                                        NPM 6.14.8
                                          @Guido-Spoltmann Dann sollte es ja jetzt funktionieren.
