  4. [Neuer Adapter] EuSec
adaptercamerasdoorbelleufyeufycamsecurity
1.2k Beiträge 160 Kommentatoren 619.5k Aufrufe 147 Beobachtet
  • C chiroptera
    @bropat Habe eben gerade Fehler im Log entdeckt, die irgend etwas mit der Push Benachrichtigung zu tun haben.
    2021-11-24 18:27:01.034 - info: eufy-security.0 (3593) Push notification connection closed
    2021-11-24 18:27:01.035 - info: eufy-security.0 (3593) Disconnect from station T8010N23204602E6
    2021-11-24 18:27:01.038 - info: eufy-security.0 (3593) terminating
    2021-11-24 18:27:01.040 - info: eufy-security.0 (3593) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-11-24 18:27:01.043 - info: eufy-security.0 (3593) Disconnected from station T8010N23204602E6
    2021-11-24 18:27:02.055 - info: host.ioBroker stopInstance system.adapter.eufy-security.0 killing pid 3593
    2021-11-24 18:27:02.489 - info: host.ioBroker instance system.adapter.eufy-security.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-11-24 18:27:02.693 - info: host.ioBroker instance system.adapter.web.0 started with pid 12859
    2021-11-24 18:27:04.153 - info: host.ioBroker instance system.adapter.eufy-security.0 started with pid 12870
    2021-11-24 18:27:04.950 - info: web.0 (12859) starting. Version 3.4.9 in /opt/iobroker/node_modules/iobroker.web, node: v12.22.5, js-controller: 3.3.18
    2021-11-24 18:27:05.350 - info: web.0 (12859) socket.io server listening on port 8082
    2021-11-24 18:27:05.372 - info: web.0 (12859) Connect extension "eufy-security/build/lib/web.js"
    2021-11-24 18:27:05.379 - info: web.0 (12859) http server listening on port 8082
    2021-11-24 18:27:05.963 - debug: eufy-security.0 (12870) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2021-11-24 18:27:06.198 - debug: eufy-security.0 (12870) Objects client ready ... initialize now
    2021-11-24 18:27:06.200 - debug: eufy-security.0 (12870) Objects create System PubSub Client
    2021-11-24 18:27:06.208 - debug: eufy-security.0 (12870) Objects create User PubSub Client
    2021-11-24 18:27:06.210 - debug: eufy-security.0 (12870) Objects client initialize lua scripts
    2021-11-24 18:27:06.237 - debug: eufy-security.0 (12870) Objects connected to redis: 127.0.0.1:9001
    2021-11-24 18:27:06.243 - silly: eufy-security.0 (12870) redis psubscribe cfg.o.system.user.*
    2021-11-24 18:27:06.252 - debug: eufy-security.0 (12870) objectDB connected
    2021-11-24 18:27:06.255 - debug: eufy-security.0 (12870) Redis States: Use Redis connection: 127.0.0.1:9000
    2021-11-24 18:27:06.275 - debug: eufy-security.0 (12870) States create System PubSub Client
    2021-11-24 18:27:06.277 - debug: eufy-security.0 (12870) States create User PubSub Client
    2021-11-24 18:27:06.291 - debug: eufy-security.0 (12870) States connected to redis: 127.0.0.1:9000
    2021-11-24 18:27:06.292 - debug: eufy-security.0 (12870) statesDB connected
    2021-11-24 18:27:06.359 - warn: web.0 (12859) State "web.0.info.connection" has no existing object, this might lead to an error in future versions
    2021-11-24 18:27:06.542 - info: eufy-security.0 (12870) starting. Version 0.7.1 in /opt/iobroker/node_modules/iobroker.eufy-security, node: v12.22.5, js-controller: 3.3.18
    2021-11-24 18:27:06.596 - silly: eufy-security.0 (12870) States system redis pmessage system.adapter.eufy-security.0.logLevel/system.adapter.eufy-security.0.logLevel:{"val":"silly","ack":true,"ts":1637778426581,"q":0,"from":"system.adapter.eufy-security.0","lc":1637778426581}
    2021-11-24 18:27:06.678 - debug: eufy-security.0 (12870) Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
    2021-11-24 18:27:06.694 - debug: eufy-security.0 (12870) Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
    2021-11-24 18:27:06.713 - debug: eufy-security.0 (12870) Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
    2021-11-24 18:27:06.778 - debug: eufy-security.0 (12870) Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
    2021-11-24 18:27:06.792 - debug: eufy-security.0 (12870) Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
    2021-11-24 18:27:06.800 - debug: eufy-security.0 (12870) Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
    2021-11-24 18:27:06.808 - debug: eufy-security.0 (12870) Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
    2021-11-24 18:27:06.825 - debug: eufy-security.0 (12870) Load previous login_hash: ["8609c239e93f00b21848ad9ed250ab90"]
    2021-11-24 18:27:06.826 - debug: eufy-security.0 (12870) Load previous api_base: ["https://security-app-eu.eufylife.com/v1"]
    2021-11-24 18:27:06.826 - debug: eufy-security.0 (12870) Load previous token: [{"token":"4fedfe0fb2387730a6c76d406439ca76aa222efa797a81fd","tokenExpiration":1638023496000}]
    2021-11-24 18:27:06.829 - debug: eufy-security.0 (12870) [HTTPApi.authenticate] Authenticate and get an access token [{"token":"4fedfe0fb2387730a6c76d406439ca76aa222efa797a81fd","tokenExpiration":"2021-11-27T14:31:36.000Z"}]
    2021-11-24 18:27:06.831 - debug: eufy-security.0 (12870) [HTTPApi.request] Request: [{"method":"get","endpoint":"app/trust_device/list","baseUrl":"https://security-app-eu.eufylife.com/v1","token":"4fedfe0fb2387730a6c76d406439ca76aa222efa797a81fd","headers":{"app_version":"v2.8.0_887","os_type":"android","os_version":"30","phone_model":"IOBROKER","country":"US","language":"de","openudid":"9a7a15b4545b53a4","uid":"","net_type":"wifi","mnc":"02","mcc":"262","sn":"eb207381bd72","Model_type":"PHONE","timezone":"GMT+00:00"}}]
    2021-11-24 18:27:07.018 - debug: eufy-security.0 (12870) [HTTPApi.listTrustDevice] Response: [""]
    2021-11-24 18:27:07.019 - error: eufy-security.0 (12870) Status return code not 200 [{"status":204,"statusText":"No Content"}]
    2021-11-24 18:27:07.020 - debug: eufy-security.0 (12870) [EufySecurity.saveCloudToken] Save cloud token and token expiration [{"token":"4fedfe0fb2387730a6c76d406439ca76aa222efa797a81fd","tokenExpiration":"2021-11-27T14:31:36.000Z"}]
    2021-11-24 18:27:07.023 - debug: eufy-security.0 (12870) [PushNotificationService._open] Login with previous push credentials... [{"fidResponse":{"name":"projects/348804314802/installations/doVTOqkGSoCceZiGgvpEFW","fid":"doVTOqkGSoCceZiGgvpEFW","refreshToken":"2_fDNPBWCmQrGqlSAIOI-6AQmz7HaWxBO8XIy6pRQ3G6KxS9NFlTxqUQPIhonMQ_jR","authToken":{"token":"eyJhbGciOiJFUzI1NiIsInR5cCI6IkpXVCJ9.eyJhcHBJZCI6IjE6MzQ4ODA0MzE0ODAyOmFuZHJvaWQ6NDQwYTY3NzNiMzYyMGRhNyIsImV4cCI6MTYzODI4MjQ2MCwiZmlkIjoiZG9WVE9xa0dTb0NjZVppR2d2cEVGVyIsInByb2plY3ROdW1iZXIiOjM0ODgwNDMxNDgwMn0.AB2LPV8wRAIgf5w1XDqZFbm9OwyI_LB3f3BALGDAmVxIRic6pg3QrhQCIGPRVAMwok4xqcclOAbvBxwk3ZTPb1SfYi1KAlHAoXT-","expiresIn":"604800s","expiresAt":1638282461613}},"checkinResponse":{"statsOk":true,"timeMs":"1637677661901","androidId":"3665856936539641979","securityToken":"5677464626826698121","versionInfo":"o5d_uoi7I1oTQKri541rkWUV5h_T1Bc","deviceDataVersionInfo":"ABFEt1WyLAfufWjl_YfAHRzJw8p4OqL3HnB62dHxYgqYJcT1qfCOD-RSNgSrmrRNUAzFe9hukmSs0DwQVZOv3NhVto8u6gYgKxWm1oPEq2o8_JQ1qi4Wu1WE3S27Abni4-PY3NiPsLPNSUNA2gpUcPJ54u8NLOiz3iRrv80oOr2FJbSHiVLNQWaIy7HTsBI_bM4ssyhHvg650YqORbNb3RYKxw0paEOR6G-AJuvvtDxetKp1FHUb2GbJvXJP81333PwKZHgwi6Yl1XypVozIU7QsTyLRT2t33XLFOhY19dlg_oicXquu140nKWsM2iARWRMsCdsZRP1ECA2Cn5dYoWDby6zpUEfTMWMW7kt9BhqX3lOTaylf1cg"},"gcmResponse":{"token":"doVTOqkGSoCceZiGgvpEFW:APA91bFUX0eB4o11CSnzwECz4YXKN8TjS9R_MToey3tCqEDe1e2abRbMWri6UgRKtxNq8FwJ9SNG_4dqstIo5MiEyeQGcpg2oE9G5jfXcX6G0_Jqw_Ua_GIVS3JhZKvhtB47yRgt_vMM"}}]
    2021-11-24 18:27:07.027 - debug: eufy-security.0 (12870) [HTTPApi.request] Request: [{"method":"post","endpoint":"family/get_invites","baseUrl":"https://security-app-eu.eufylife.com/v1","token":"4fedfe0fb2387730a6c76d406439ca76aa222efa797a81fd","data":{"num":100,"orderby":"","own":false,"page":0,"transaction":"1637778427026"},"headers":{"app_version":"v2.8.0_887","os_type":"android","os_version":"30","phone_model":"IOBROKER","country":"US","language":"de","openudid":"9a7a15b4545b53a4","uid":"","net_type":"wifi","mnc":"02","mcc":"262","sn":"eb207381bd72","Model_type":"PHONE","timezone":"GMT+00:00"}}]
    2021-11-24 18:27:07.204 - debug: eufy-security.0 (12870) [HTTPApi.getInvites] Response: [""]
    2021-11-24 18:27:07.205 - error: eufy-security.0 (12870) Status return code not 200 [{"status":204,"statusText":"No Content"}]
    2021-11-24 18:27:07.206 - debug: eufy-security.0 (12870) [HTTPApi.request] Request: [{"method":"post","endpoint":"app/get_hub_list","baseUrl":"https://security-app-eu.eufylife.com/v1","token":"4fedfe0fb2387730a6c76d406439ca76aa222efa797a81fd","headers":{"app_version":"v2.8.0_887","os_type":"android","os_version":"30","phone_model":"IOBROKER","country":"US","language":"de","openudid":"9a7a15b4545b53a4","uid":"","net_type":"wifi","mnc":"02","mcc":"262","sn":"eb207381bd72","Model_type":"PHONE","timezone":"GMT+00:00"}}]
    2021-11-24 18:27:07.310 - debug: eufy-security.0 (12870) [HTTPApi.updateDeviceInfo] Stations - Response: [""]
    2021-11-24 18:27:07.311 - error: eufy-security.0 (12870) Status return code not 200 [{"status":204,"statusText":"No Content"}]
    2021-11-24 18:27:07.312 - debug: eufy-security.0 (12870) [HTTPApi.request] Request: [{"method":"post","endpoint":"app/get_devs_list","baseUrl":"https://security-app-eu.eufylife.com/v1","token":"4fedfe0fb2387730a6c76d406439ca76aa222efa797a81fd","headers":{"app_version":"v2.8.0_887","os_type":"android","os_version":"30","phone_model":"IOBROKER","country":"US","language":"de","openudid":"9a7a15b4545b53a4","uid":"","net_type":"wifi","mnc":"02","mcc":"262","sn":"eb207381bd72","Model_type":"PHONE","timezone":"GMT+00:00"}}]
    2021-11-24 18:27:07.480 - debug: eufy-security.0 (12870) [HTTPApi.updateDeviceInfo] Devices - Response: [""]
    2021-11-24 18:27:07.482 - error: eufy-security.0 (12870) Status return code not 200 [{"status":204,"statusText":"No Content"}]
    2021-11-24 18:27:07.774 - debug: eufy-security.0 (12870) [PushClient.handleParsedMessage] Login response: GCM -> logged in -> waiting for push messages...
    2021-11-24 18:27:07.776 - debug: eufy-security.0 (12870) [HTTPApi.request] Request: [{"method":"post","endpoint":"/apppush/register_push_token","baseUrl":"https://security-app-eu.eufylife.com/v1","token":"4fedfe0fb2387730a6c76d406439ca76aa222efa797a81fd","data":{"is_notification_enable":true,"token":"doVTOqkGSoCceZiGgvpEFW:APA91bE9gHz60Zm9cz3gdyD38hwNxrLB32tBr02OLa4CbbwOmQVt9gVJepnPNxRsPFJck6xgyLw7PwzUuVO6M21fh4OY-Jt51ehC3Uq_6UDXL4BjFPIh99kSEykP4U4Lw0A_OcOhsqwn","transaction":"1637778427776"},"headers":{"app_version":"v2.8.0_887","os_type":"android","os_version":"30","phone_model":"IOBROKER","country":"US","language":"de","openudid":"9a7a15b4545b53a4","uid":"","net_type":"wifi","mnc":"02","mcc":"262","sn":"eb207381bd72","Model_type":"PHONE","timezone":"GMT+00:00"}}]
    2021-11-24 18:27:07.796 - debug: eufy-security.0 (12870) [PushClient.handleParsedMessage] IqStanza: Not implemented [{"tag":7,"object":{"type":"SET","id":"","extension":{"id":12,"data":{"type":"Buffer","data":[]}}}}]
    2021-11-24 18:27:07.908 - debug: eufy-security.0 (12870) [HTTPApi.registerPushToken] Response: [""]
    2021-11-24 18:27:07.909 - error: eufy-security.0 (12870) Status return code not 200 [{"status":204,"statusText":"No Content"}]
    2021-11-24 18:27:07.910 - debug: eufy-security.0 (12870) [HTTPApi.request] Request: [{"method":"post","endpoint":"/app/review/app_push_check","baseUrl":"https://security-app-eu.eufylife.com/v1","token":"4fedfe0fb2387730a6c76d406439ca76aa222efa797a81fd","data":{"app_type":"eufySecurity","transaction":"1637778427910"},"headers":{"app_version":"v2.8.0_887","os_type":"android","os_version":"30","phone_model":"IOBROKER","country":"US","language":"de","openudid":"9a7a15b4545b53a4","uid":"","net_type":"wifi","mnc":"02","mcc":"262","sn":"eb207381bd72","Model_type":"PHONE","timezone":"GMT+00:00"}}]
    2021-11-24 18:27:08.016 - debug: eufy-security.0 (12870) [HTTPApi.checkPushToken] Response: [""]
    2021-11-24 18:27:08.017 - error: eufy-security.0 (12870) Status return code not 200 [{"status":204,"statusText":"No Content"}]
    2021-11-24 18:27:08.018 - info: eufy-security.0 (12870) Push notification connection closed
    chiroptera
    locito09
    schrieb am zuletzt editiert von locito09
    #261
    @chiroptera
    Aktualisiere den adapter auf die Version 0.7.4
    Siehe Zeile 43 im Log, das Thema hatten wir oben schon mal
    C M 2 Antworten Letzte Antwort
    • D4RKKN1GHT84D D4RKKN1GHT84
      @chrille1507 Direkt in App deaktiviert?? Hab ich gemacht aber kommt leider immernoch....
      C Online
      C Online
      Chrille1507
      #262
      @d4rkkn1ght84 Ja genau. Ich habe es in der App deaktiviert, 10 Minuten gewartet und dann funktionierte es auf Anhieb.
      • Ron ColdR Offline
        Ron ColdR Offline
        Ron Cold
        #263
        Bei mir verschwindet beim Versuch mich anzumelden das "Passwort Fenster" wenn ich in das Feld klicke. Ist das jemand bekannt? Mache ich einen Fehler?Bild vor und nach dem Klick im Anhang.Bildschirmfoto 2021-11-26 um 15.35.53.png Bildschirmfoto 2021-11-26 um 15.37.40.png
        L 1 Antwort Letzte Antwort
        • Ron ColdR Ron Cold
          locito09
          #264
          @ron-cold
          Wurde weiter oben schon mal besprochen
          Lösung:
          Copy paste
          Ron ColdR 1 Antwort Letzte Antwort
          • L locito09
            @ron-cold
            Lösung:
            Copy paste
            Ron ColdR Offline
            Ron ColdR Offline
            Ron Cold
            #265
            @locito09 leider verschwindet bei der 0.7.4 auch per Copy Paste das PW - den Post hatte ich schon gelesen.
            Danke trotzdem für den Hinweis ;)
            Hat vllt. noch jemand eine Idee?
            C 1 Antwort Letzte Antwort
              chiroptera
              #266
              @ron-cold "Verschwindet" bei Copy&Paste zwar, wird aber auf diese Weise trotzdem gespeichert :-)
              • L locito09
                @chiroptera
                chiroptera
                #267
                @locito09 said in [Neuer Adapter] Eufy-Security:
                Scheint in der Tat geholfen zu haben - danke :-)
                • C chiroptera
                  Ron ColdR Offline
                  Ron ColdR Offline
                  Ron Cold
                  #268
                  @chiroptera leider wohl nicht
                    Mike Hellracer
                    #269
                    Hat jemand wenn es klingelt auf der VIS schon ein Popup hinbekommen mit LiveView hinbekommen?
                    • nitram-remN Offline
                      nitram-remN Offline
                      nitram-rem
                      #270
                      ich habe mir vorgenommen meine Eufy mit Signal zu verklöppeln und dafür Node-red zu verwenden. Dazu habe ich Eufy-Security Adapter installiert und den Signal-CLI. Signal geht schon, also ich kann eine Message verschicken. Jetzt würde ich gerne das Bild noch mit dazu nehmen wenn ein Alarm kommt. Dazu habe ich das Bild liegen unter dem Objekt Punkt: last_event_pic_url. Ich kann das Bild anzeigen wenn ich eine URL in den Browser schmeiße: http://192.xxx.xxx.xxx:8082/eufy-security.0/T8010N23203011B4/last_event/T8114P0220420BB2.jpeg Allerdings funktioniert das so nicht mit der Signal CLI. Da kann ich laut Doku mit dem parameter -a einen lokalen Pfad mitgeben um das Bild dann zu übertragen. Frage ist nun wo ist der lokale Pfad des Eufy Security Adapters oder wie kann ich die Datei herunterladen, lokal abspeichern, dann raus pushen und wieder löschen?
                      Martin
                      • L locito09
                        @chiroptera
                        Maddog20102002
                        schrieb am zuletzt editiert von Maddog20102002
                        #271
                        @locito09 Wie kann ich auf 0.7.4 updaten?
                        Über normale adaptersuche bekomme ich nur 0.7.0
                        bin nicht so fit wie man einen adapter direkt von Github installiert
                        • JohGreJ Offline
                          JohGreJ Offline
                          JohGre
                          schrieb am zuletzt editiert von JohGre
                          #272
                          Hi, habe aktuell seit 2 Tagen folgendes Problem. Adapter ist grün jedoch werden mir keine Bilder mehr in
                          eufy-security.0.TRxxx.cameras.Txxx.last_event_pic_html
                          angezeigt. Zwischendurch kommt immer wieder mal die Fehlermeldung.
                          eufy-security.0  2021-11-27 18:01:44.831	error	Status return code not 200 [{"status":401,"statusText":"Unauthorized"}]
                          eufy-security.0  2021-11-27 18:01:44.828	error	Status return code 401, invalidate token [{"status":401,"statusText":"Unauthorized"}]
                          auch das wird bei jeder immer wieder gemeldet
                          eufy-security.0	2021-11-28 08:51:59.217	error	ffmpegPreviewImage - station: Txxxx device: Txxxx - Error [{}]
                          eufy-security.0	2021-11-28 08:51:59.216	error	ffmpegPreviewImage(): ffmpeg stderr:ffmpeg version 4.4-static https://johnvansickle.com/ffmpeg/ Copyright (c) 2000-2021 the FFmpeg developers built with gcc 8 (Debian 8.3.0-6) configuration: --enable-gpl --enable-version3 --enable-static --disable-debug --disable-ffplay --disable-indev=sndio --disable-outdev=sndio --cc=gcc --enable-fontconfig --enable-frei0r --enable-gnutls --enable-gmp --enable-libgme --enable-gray --enable-libaom --enable-libfribidi --enable-libass --enable-libvmaf --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-librubberband --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libvorbis --enable-libopus --enable-libtheora --enable-libvidstab --enable-libvo-amrwbenc --enable-libvpx --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libdav1d --enable-libxvid --enable-libzvbi --enable-libzimg libavutil 56. 70.100 / 56. 70.100 libavcodec 58.134.100 / 58.134.100 libavformat 58. 76.100 / 58. 76.100 libavdevice 58. 13.100 / 58. 13.100 libavfilter 7.110.100 / 7.110.100 libswscale 5. 9.100 / 5. 9.100 libswresample 3. 9.100 / 3. 9.100 libpostproc 55. 9.100 / 55. 9.100[hls @ 0x6ae8c80] Skip ('#EXT-X-VERSION:3')[hls @ 0x6ae8c80] Cannot get correct #EXTINF value of segment /opt/iobroker/iobroker-data/eufy-security.0/Txxxx/last_event/Txxxx0.ts, set to default value to 1ms.[hls @ 0x6ae8c80] Opening '/opt/iobroker/iobroker-data/eufy-security.0/Txxxx/last_event/Txxxx0.ts' for reading[aac @ 0x6af6480] More than one AAC RDB per ADTS frame is not implemented. Update your FFmpeg version to the newest one from Git. If the problem still occurs, it means that your file has a feature which has not been implemented.[aac @ 0x6af6480] Reserved bit set.[aac @ 0x6af6480] Number of scalefactor bands in group (46) exceeds limit (40).[aac @ 0x6af6480] channel element 1.11 is not allocated[aac @ 0x6af6480] Assuming an incorrectly encoded 7.1 channel layout instead of a spec-compliant 7.1(wide) layout, use -strict 1 to decode according to the specification instead.[aac @ 0x6af6480] Number of bands (13) exceeds limit (12).[aac @ 0x6af6480] channel element 1.11 is not allocated[aac @ 0x6af6480] Number of bands (13) exceeds limit (10).[hls @ 0x6ae8c80] decoding for stream 1 failed[hls @ 0x6ae8c80] Could not find codec parameters for stream 0 (Video: h264 ([27][0][0][0] / 0x001B), none): unspecified sizeConsider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options[hls @ 0x6ae8c80] Could not find codec parameters for stream 1 (Audio: aac (SSR) ([15][0][0][0] / 0x000F), 4.0, fltp): unspecified sample rateConsider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) optionsInput #0, hls, from '/opt/iobroker/iobroker-data/eufy-security.0/Txxxx/last_event/Txxxx.m3u8': Duration: 00:00:00.00, start: 1.400000, bitrate: 1232 kb/s Program 0 Metadata: variant_bitrate : 0 Stream #0:0: Video: h264 ([27][0][0][0] / 0x001B), none, 90k tbr, 90k tbn, 180k tbc Metadata: variant_bitrate : 0 Stream #0:1: Audio: aac (SSR) ([15][0][0][0] / 0x000F), 4.0, fltp Metadata: variant_bitrate : 0Output #0, image2, to '/opt/iobroker/iobroker-data/eufy-security.0/Txxxx/last_event/Txxxx.jpeg':Output file #0 does not contain any stream
                          eufy-security.0	2021-11-28 08:51:59.215	error	ffmpegPreviewImage(): ffmpeg output:
                          eufy-security.0	2021-11-28 08:51:59.213	error	ffmpegPreviewImage(): An error occurred: ffmpeg exited with code 1: Output #0, image2, to '/opt/iobroker/iobroker-data/eufy-security.0/Txxxx/last_event/Txxxx.jpeg':Output file #0 does not contain any stream
                          Kann ich da irgendwas in ffmpeg konfigurieren oder ist das ein EUFY-Problem
                          nuc i5: RaspberryMatic, ioBroker, pi-hole, SQL-Server, OMV-NAS, Influx-DB & Grafana, OpenHab, tasmoadmin
                          • Marko1974M Marko1974
                            @berndpehome
                            Habe es schon hinbekommen, beim Blockly muss der Pfad zur Datei und die Variable weg.
                            Wenn Bewegung, Sende Datenpunkt: Http:// xxxxxxxxxxx
                            Danach wird ein Link versendet. Im Telegram wird aber eine Vorschau des Bildes erstellt, somit erhalte ich ein Bild und den Link dazu.
                            @locito09 kannste einmal bitte den Pfad angeben...hab ffmpeg auch geupdatet...das mit dem pfad mit http:// davor hab ich noch nicht
                            locito09
                            #273
                            @marko1974
                            Für alle die den ffmpeg Fehler haben.
                            Ich habe festgestellt das wen die Kamera weniger als 30s aufnihmt der Fehler nicht mehr kommt.
                            Habe es bei mir so gelöst und seit dem kein fehler mehr im LOG.
                            Aufnahmelänge auf 28sek
                            Seit der Änderung läuft der Adapter schon über 2 Tage ohne Fehlermeldung
                            @bropat
                            Kannst du mit dem was anfangen und den Adapter fixen
                            • M Maddog20102002
                              locito09
                              #274
                              @maddog20102002
                              Erweiterten Modus einschalten (kopf Zeichen) benutzerdefinierte Installation , link von Github einfügen
                              cashC 1 Antwort Letzte Antwort
                              • L locito09
                                @maddog20102002
                                cashC Offline
                                cashC Offline
                                cash
                                #275
                                habe nun auch zwei Kameras und den Adapter installiert.
                                Hatte die App per 2 Faktor aktiviert. Beim Adapter start kam auch brav eine Mail mit der Nr nur als ich die Nr eingegeben habe sagte der Adapter falsche Zahl (hatte es kontrolliert passte aber. Hier scheint also noch etwas nicht rund zu laufen. Habe den Adapter dann ohne 2 Faktor in Betrieb genommen.
                                Ich habe noch eine Frage zur Solor Indoorcam P24. Gibt es keinen Datenpunkt um die Bewegungsverfolgung unter Bewekungserkennung in der App zu deaktiveren?
                                Ich habe die Kamera im Flur installiert und es nervt ein wenig wenn die Kamera einen dauernd verfolgt (obwohl sie das echt gut macht).
                                hollywootH C 2 Antworten Letzte Antwort
                                • cashC cash
                                  hollywootH Offline
                                  hollywootH Offline
                                  hollywoot
                                  schrieb am zuletzt editiert von hollywoot
                                  #276
                                  @cash sagte in [Neuer Adapter] Eufy-Security:
                                  Versuchs mal 'motionTracking' auf false zu setzen.
                                  • hollywootH hollywoot
                                    cashC Offline
                                    cashC Offline
                                    cash
                                    #277
                                    @hollywoot jau das ist der Datenpunkt. War ein wenig blind. Hast Du zufällig die Kamera?
                                    ich habe bei Amazon die SanDisk Extreme microSDXC UHS-I Speicherkarte 128 GB + Adapter & Rescue Pro Deluxe (Für Smartphones, Actionkameras und Drohnen, A2, C10, V30, U3, 160 MB/s Übertragung) gekauft. Die Karte wird erkannt und formatiert. Er nimmt auch anscheinend drauf auf aber ich kann nichts von der Karte abspielen.
                                    Hast Du eine Karte? Falls ja welche…
                                    hollywootH 1 Antwort Letzte Antwort
                                    • cashC cash
                                      hollywootH Offline
                                      hollywootH Offline
                                      hollywoot
                                      #278
                                      @cash
                                      Jo, ich hab die als Babyphone-Cam im Kinderzimmer in Benutzung. Karte habe ich eine 0815-SanDisk glaube ich drin. Also nichts besonderes...
                                      draexlerD 1 Antwort Letzte Antwort
                                        @cash
                                        draexlerD Offline
                                        draexlerD Offline
                                        draexler
                                        #279
                                        Hi, hat noch jemand folgendes Problem?
                                        Verbunden mit Host. -> ja
                                        Lebenszeichen -> ja
                                        Verbunden mit Gerät oder Dienst. -> nein
                                        Neustart des Adapters hat nichts geholfen.
                                        Der Adapter wird also nicht grün sonder hat ein gelbes Ausrufezeichen
                                        Version: 0.5.5
                                        Danke euch.
                                        • draexlerD draexler
                                          Lebenszeichen -> ja
                                          Version: 0.5.5
                                          Danke euch.
                                          hollywootH Offline
                                          hollywootH Offline
                                          hollywoot
                                          #280
                                          @draexler
                                          Warum machst du kein Update?
                                          Dadurch sollten so ziemlich alle hier besprochenen Probleme abgearbeitet sein.
