  4. [Gelöst] Email-Empfang Iobroker
    1.0k
    6.1k
iobrokerjavascriptmailistener2
101 Beiträge 7 Kommentatoren 16.4k Aufrufe 7 Beobachtet
  • liv-in-skyL liv-in-sky
    @Gargano dann sollte es stimmen
    hier ein beispiel von mir
    GarganoG Offline
    GarganoG Offline
    Gargano
    #61
    @liv-in-sky Ich habe nur die einfache Version genommen, hier der Code.
    // Quelle Original: https://github.com/chirag04/mail-listener2
    // Quelle Forum: https://forum.iobroker.net/topic/18501/emails-empfangen
    const EmailText = "javascript.0.Email.EmailText";
    const EmailEingang = "javascript.0.Email.Email_Eingang";
    createState(EmailEingang, {
        type: 'string',
        min: 0,
        def: 0,
        role: 'value'
    createState(EmailText, {
        type: 'string',
        min: 0,
        def: 0,
        role: 'value'
        var MailListener = require("mail-listener2");
        var mailListener = new MailListener({
          username: "xxxxx",    // HIER Email Adresse eintragen
          password: "yyyy",	      // HIER Passwort eintragen
          host: "imap.ionos.de",
          port: 993, // imap port
          tls: true,
          connTimeout: 10000, // Default by node-imap
          authTimeout: 5000, // Default by node-imap,
          debug: null, // Or your custom function with only one incoming argument. Default: null
          tlsOptions: { rejectUnauthorized: false },
          mailbox: "INBOX", // HIER Postfach eingeben z.B. INBOX
          searchFilter: ["UNSEEN"], // the search filter being used after an IDLE notification has been retrieved
          markSeen: true, // all fetched email willbe marked as seen and not fetched next time
          fetchUnreadOnStart: true, // use it only if you want to get all unread email on lib start. Default is `false`,
          mailParserOptions: {streamAttachments: false}, // options to be passed to mailParser lib.
          attachments: false, // download attachments as they are encountered to the project directory
          attachmentOptions: { directory: "attachments/" } // specify a download directory for attachments
        mailListener.start();
        mailListener.on("server:connected", function(){console.log("------- imapConnected");});
        mailListener.on("server:disconnected", function(){console.log("------- imapDisconnected");});
        mailListener.on("error", function(err){console.log("MailError "+err);});
        mailListener.on("mail", function(mail, seqno, attributes){
            log("Mail from: "+mail.from[0].address);
            log("Name: "+mail.from[0].name);
            log("Subject: "+mail.subject);
            log("Text: "+mail.text);
    //     setState(EmailEingang,mail.from[0].address);  	//setze Datenpunkt mit Email-Absender (als Trigger nutzbar)
    //     setState(EmailText,mail.text);			//setze Datenpunkt mit kompletten Email-Inhalt
        // mailListener.on("attachment", function(attachment){console.log(attachment.path);}); //wenn Anhänge verarbeitet werden sollen einkommentieren
    mail.from[0].address,mail.from[0].name,mail.subject funktioniert. nur mail.text nicht
    • GarganoG Gargano
          type: 'string',
          min: 0,
          def: 0,
          role: 'value'
          type: 'string',
          min: 0,
          def: 0,
          role: 'value'
            tls: true,
      liv-in-skyL Offline
      liv-in-skyL Offline
      liv-in-sky
      #62
      @Gargano
      das funktioniert bei mir. mail-listener4 aber sollte auch mit mail-listener2 funktionieren:
          type: 'string',
          min: 0,
          def: 0,
          role: 'value'
          type: 'string',
          min: 0,
          def: 0,
          role: 'value'
          var MailListener = require("mail-listener4");
          var maillistenerSetting =  {
           username: "xxxxx.de",    // hier Email Adresse eintragen
            password: "xxxxxxxx",	      // hier Passwort eintragen
            host: "imap.1und1.de",
            tls: true,
            markSeen: false, // all fetched email willbe marked as seen and not fetched next time
              maillistenerSetting
          mailListener.on("server:connected", function(){/*console.log("imapconconnected")*/;});
          mailListener.on("server:disconnected", function(){/*console.log("imapDisconnected");*/});
          mailListener.on("error", function(err){console.log(err);});
           //   log("Mail from: "+mail.from[0].address);
             // log("Name: "+mail.from[0].name);
             // log("Subject: "+mail.subject);
        @Gargano
            type: 'string',
            min: 0,
            def: 0,
            role: 'value'
            type: 'string',
            min: 0,
            def: 0,
            role: 'value'
              tls: true,
                maillistenerSetting
        GarganoG Offline
        GarganoG Offline
        Gargano
        #63
        @liv-in-sky Seltsam, bei mir geht es auch mit mail-listener4 nicht.
        Muß ich irgendetwas anderes noch eintragen außer in der Javascript Instanz ?
        • GarganoG Gargano
          liv-in-skyL Offline
          liv-in-skyL Offline
          liv-in-sky
          #64
          @Gargano
          nein nur da- hast du mein script getestet - ist anders als deines
          • GarganoG Gargano
            liv-in-skyL Offline
            liv-in-skyL Offline
            liv-in-sky
            #65
            @Gargano
            ich hatte bei deinem script einen fehler im log - ich nutze javascript version 4.10.5 - vielleicht macht das was aus
            GarganoG 3 Antworten Letzte Antwort
              @Gargano
              GarganoG Offline
              GarganoG Offline
              Gargano
              #66
              @liv-in-sky Welcher Fehler im Log war das ?
                @Gargano
                GarganoG Offline
                GarganoG Offline
                Gargano
                #67
                @liv-in-sky Ich hab mal Dein Script versucht, da funktioniert gar nichts. Es kommt keine Email an.
                  @Gargano
                  GarganoG Offline
                  GarganoG Offline
                  Gargano
                  #68
                  @liv-in-sky Ich hab die Version 4.10.8
                  • GarganoG Gargano
                    liv-in-skyL Offline
                    liv-in-skyL Offline
                    liv-in-sky
                    #69
                    @Gargano irgendwas mit "maillistener ist kein constructor"
                    -log ist leider schon gelöscht
                      GarganoG Offline
                      GarganoG Offline
                      Gargano
                      #70
                      @liv-in-sky
                      Mit deinem Script geht das Empfangen auch, dauert etwas bis es in den Objekten ist.
                      Beim mail_text steht dies drin : FEHLER beim Lesen oder leer
                      Was equivalent zu meinem Script bei mail.text = undefined ist.
                      Soweit also gleich.
                      Kann es sein, daß bei 1und1 etwas anders ist als bei gmail o.a. ?
                      • GarganoG Gargano
                        @liv-in-sky
                        Soweit also gleich.
                        liv-in-skyL Offline
                        liv-in-skyL Offline
                        liv-in-sky
                        #71
                        @Gargano
                        diesen fehler hatte ich mit mails, die im html format waren - daher node red, da ist dieses problem nicht
                        teste mal ein anderes, ohne html inhalt
                          @Gargano
                          GarganoG Offline
                          GarganoG Offline
                          Gargano
                          #72
                          @liv-in-sky Heureka, das wars. Email im Raw Format geht.
                          Danke für die Hilfe
                          • GarganoG Gargano
                            Danke für die Hilfe
                            liv-in-skyL Offline
                            liv-in-skyL Offline
                            liv-in-sky
                            #73
                            @Gargano gerne - aber die fritzbox sendet nur im html format - ode kann man das umstellen ?
                              GarganoG Offline
                              GarganoG Offline
                              Gargano
                              #74
                              @liv-in-sky Ich will da nichts umstellen, weil ich die originalen Emails anderweitig anschauen will.
                              Ich brauch das Script um Email Eingänge auf meinem LG-TV anzuzeigen, da brauch ich nur den Namen und Subject.
                              Mich hat nur der mail.text=undefined gestört und wollte wissen wieso, jetzt weis ich es.
                              • GarganoG Gargano
                                liv-in-skyL Offline
                                liv-in-skyL Offline
                                liv-in-sky
                                #75
                                @Gargano dafür hätte ich schon ein script gehabt :-)
                                https://forum.iobroker.net/topic/36558/html-tabelle-für-email-postfach
                                  Bert
                                  #76
                                  Hallo zusammen und frohe Weihnachten gehabt zu haben :-)
                                  Ich stehe grad etwas auf dem Schlauch und hoffe ihr könnt mir helfen.
                                  Habe die obigen Skripte ausprobiert und bekomme auch einen Absender angezeigt wenn eine Mail eintrifft, aber ich bekomme einfach keinen Text angezeigt!
                                  Im Log taucht eine Fehlermeldung auf:
                                  (14052) script.js.common.Mail_Listener: setForeignState: undefined is not a valid state value
                                  Könnt ihr mir da weiterhelfen?
                                  Danke schonmal im Vorraus ☺
                                  • sigi234S sigi234
                                    @liv-in-sky sagte in Email-Empfang Iobroker:
                                    @sigi234 falls du dich damit etwas auskennst, kannst ja mal kucken, ob diese daten dort drin sind
                                    Nein nur teilweise drinnen.
                                    Rocki
                                    #77
                                    @sigi234 sagte in Email-Empfang Iobroker:
                                    Hallo, nur mal eine Frage generell zu uPnp ... mir werden gar keine Daten angezeigt? An was könnte das liegen?
                                    Fritz 5590, Fritz DECT, Alexa, Synology DS718+, Docker + ioBroker
                                    liv-in-skyL R 2 Antworten Letzte Antwort
                                    • R Rocki
                                      liv-in-skyL Offline
                                      liv-in-skyL Offline
                                      liv-in-sky
                                      #78
                                      @rocki du musst den request button (datenpunkt) drücken, damit die daten geholt werden - muss man über script aktivieren
                                      R 1 Antwort Letzte Antwort
                                        Rocki
                                        #79
                                        OK, Danke :-) Bin noch ziemlich am Anfang ... Blokly habe ich nicht ... wo muss man was für ein Script muss ich wo einfügen/drücken? :-)
                                        • R Rocki
                                          liv-in-skyL Offline
                                          liv-in-skyL Offline
                                          liv-in-sky
                                          #80
                                          @rocki zum testen erstmal in den datenpunkten drücken und true reinschreinben und warten ob was kommt
                                          wenn du javascript adapter installiert hast, hast du auch blockly
