  4. Test eCharts Adapter
    2.8k
    4.9k
    4.1k
echarts
666 Beiträge 109 Kommentatoren 242.4k Aufrufe 84 Beobachtet
  • H heinzie
    @rk62 sagte in Test eCharts Adapter:
    @heinzie Kannst Du versuchen aber nach meinem Wissen macht der das gleiche wie ein Update über die Oberfläche. Auf jeden Fall das Installationslog nachverfolgen ob er sauber zu Ende gekommen ist.
    Habe ich probiert, geht leider auch nicht.
    So sieht der Installationslog aus:
    $ iobroker upgrade echarts@1.5.1 --debug
    Update echarts from @1.0.12 to @1.5.1
    NPM version: 9.5.1Installing iobroker.echarts@1.5.1... (System call)
    added 2 packages, removed 11 packages, and changed 15 packages in 28s135 packages are looking for funding run `npm fund` for details
    upload [17] echarts /opt/iobroker/node_modules/iobroker.echarts/www/asset-manifest.json asset-manifest.json application/json
    upload [16] echarts /opt/iobroker/node_modules/iobroker.echarts/www/favicon.ico favicon.ico image/vnd.microsoft.icon
    upload [15] echarts /opt/iobroker/node_modules/iobroker.echarts/www/index.html index.html text/html
    upload [14] echarts /opt/iobroker/node_modules/iobroker.echarts/www/manifest.json manifest.json application/json
    upload [12] echarts /opt/iobroker/node_modules/iobroker.echarts/www/preview/favicon.ico preview/favicon.ico image/vnd.microsoft.icon
    upload [11] echarts /opt/iobroker/node_modules/iobroker.echarts/www/preview/index.html preview/index.html text/html
    upload [10] echarts /opt/iobroker/node_modules/iobroker.echarts/www/preview/manifest.json preview/manifest.json application/json
    upload [9] echarts /opt/iobroker/node_modules/iobroker.echarts/www/preview/static/css/main.f7b2c82f.css preview/static/css/main.f7b2c82f.css text/css
    upload [8] echarts /opt/iobroker/node_modules/iobroker.echarts/www/preview/static/css/main.f7b2c82f.css.map preview/static/css/main.f7b2c82f.css.map application/json
    upload [7] echarts /opt/iobroker/node_modules/iobroker.echarts/www/preview/static/js/main.1b04901d.js preview/static/js/main.1b04901d.js application/javascript
    upload [6] echarts /opt/iobroker/node_modules/iobroker.echarts/www/preview/static/js/main.1b04901d.js.LICENSE.txt preview/static/js/main.1b04901d.js.LICENSE.txt text/plain
    upload [5] echarts /opt/iobroker/node_modules/iobroker.echarts/www/preview/static/js/main.1b04901d.js.map preview/static/js/main.1b04901d.js.map application/json
    upload [4] echarts /opt/iobroker/node_modules/iobroker.echarts/www/static/css/main.f7b2c82f.css static/css/main.f7b2c82f.css text/css
    upload [3] echarts /opt/iobroker/node_modules/iobroker.echarts/www/static/css/main.f7b2c82f.css.map static/css/main.f7b2c82f.css.map application/json
    upload [2] echarts /opt/iobroker/node_modules/iobroker.echarts/www/static/js/main.eb0afecd.js static/js/main.eb0afecd.js application/javascript
    upload [1] echarts /opt/iobroker/node_modules/iobroker.echarts/www/static/js/main.eb0afecd.js.LICENSE.txt static/js/main.eb0afecd.js.LICENSE.txt text/plain
    upload [0] echarts /opt/iobroker/node_modules/iobroker.echarts/www/static/js/main.eb0afecd.js.map static/js/main.eb0afecd.js.map application/json
    Update "system.adapter.echarts.0"
    upload [28] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/asset-manifest.json asset-manifest.json application/json
    upload [20] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/chart/static/js/main.eb0afecd.js.LICENSE.txt chart/static/js/main.eb0afecd.js.LICENSE.txt text/plain
    upload [19] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/chart/static/js/main.eb0afecd.js.map chart/static/js/main.eb0afecd.js.map application/json
    ERROR: Process exited with code null
    RK62R Offline
    RK62R Offline
    RK62
    #521
    @heinzie Das ist genau die Stelle wo bei mir für den ioBroker-Container der massive Speicherhunger von 5GB entsteht und das System für eine Minute stehen bleibt bevor die Installation dann weiterläuft. Da hilft wohl nur RAM nachschieben (ich habe 10 GB Speicher verbaut) oder ein Issue in Github aufmachen (https://github.com/ioBroker/ioBroker.echarts/issues).
    2023-06-20 23:14:51.685 - info: host.z-iobroker iobroker upload [28] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/asset-manifest.json asset-manifest.json application/json
    2023-06-20 23:14:52.018 - info: host.z-iobroker instance system.adapter.echarts.0 started with pid 954
    2023-06-20 23:14:53.480 - info: host.z-iobroker iobroker upload [20] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/chart/static/js/main.eb0afecd.js.LICENSE.txt chart/static/js/main.eb0afecd.js.LICENSE.txt text/plain
    2023-06-20 23:14:53.506 - info: host.z-iobroker iobroker upload [19] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/chart/static/js/main.eb0afecd.js.map chart/static/js/main.eb0afecd.js.map application/json
    2023-06-20 23:14:55.188 - info: echarts.0 (954) starting. Version 1.5.1 in /opt/iobroker/node_modules/iobroker.echarts, node: v18.16.0, js-controller: 4.0.24
    2023-06-20 23:15:15.885 - info: admin.0 (200) <== Disconnect system.user.admin from ::ffff:192.168.64.1 admin
    2023-06-20 23:15:18.736 - info: admin.0 (200) ==> Connected system.user.admin from ::ffff:192.168.64.1
    ==== Speicherbedarf steigt von 1 auf 5-6 GB ====
    2023-06-20 23:16:20.624 - info: host.z-iobroker iobroker upload [18] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/echarts.png echarts.png image/png
    2023-06-20 23:16:20.920 - info: host.z-iobroker iobroker upload [17] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
    2023-06-20 23:16:21.152 - info: host.z-iobroker iobroker upload [16] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/manifest.json manifest.json application/json
    H 1 Antwort Letzte Antwort
    • RK62R RK62
      heinzie
      schrieb am zuletzt editiert von heinzie
      #522
      Danke, ich habe jetzt auch mal den Speicher erhöht und es läuft sofort ohne Probleme.
      Obwohl hier nur 65.21 MB angegeben werden
      RK62R 1 Antwort Letzte Antwort
      • H heinzie
        RK62R Offline
        RK62R Offline
        RK62
        #523
        @heinzie Prima! Die Installation braucht temporär den Speicher. Die 65MB ist der Speicher für den Betrieb des Adapters.
        • RK62R RK62
          heinzie
          #524
          ok, da kann ich problemlos mit leben. Nochmals Danke für die Hilfe.
          • Z Offline
            Z Offline
            zolpetol
            #525
            Nach etwas längerer Zeit will ich ein neues Diagramm mit E-Charts erstellen, bei Anwahl es TAB kommt die Meldung "File tab.html not found".
            Habe alle Updates gemacht und gegoogelt, keine Lösung.
            Hat jemand einen Tipp - danke!
            RK62R H 2 Antworten Letzte Antwort
            • Z zolpetol
              RK62R Offline
              RK62R Offline
              RK62
              #526
              @zolpetol Ja, etwas hochblättern, so bis 20.06. / 19:16
              Z 1 Antwort Letzte Antwort
              • RK62R RK62
                Z Offline
                Z Offline
                zolpetol
                #527
                @rk62
                Danke, leider hilft das nicht. Das Symbol wird wieder korrekt dargestellt, es kommt aber immer noch die Meldung. Auch ein Downgrade auf 1.14.14 hat keine Änderung gebracht.
                • Z zolpetol
                  @rk62
                  RK62R Offline
                  RK62R Offline
                  RK62
                  #528
                  @zolpetol Ist die Installation denn im Log ohne Fehler zu Ende gekommen und das System neu gestartet?
                    #529
                    @zolpetol
                    die Idee ist vielleicht gar nicht so falsch.
                    in den letzten Tagen gab es Meldungen, dass sich eCharts beim Update einen großen Schluck vom RAM gönnt.
                    Da kam es auch schon zu Problemen beim Update
                      @zolpetol
                      Z Offline
                      Z Offline
                      zolpetol
                      #530
                      @homoran @RK62
                      Ich habe keine Fehler im Log gesehen und die virtuelle Maschine wurde neu gestartet - leider keine Änderung
                      • Z zolpetol
                        heinzie
                        #531
                        @zolpetol sagte in Test eCharts Adapter:
                        War bei mir der gleiche Fehler. Das einzige was funktioniert hat, war die Vergrößerung des Speichers.
                        • H heinzie
                          Z Offline
                          Z Offline
                          zolpetol
                          #532
                          @heinzie
                          Ich habe den Speicher jetzt von 8 GB auf 10 GB vergrößert, neu gestartet und es hat sich nichts geändert.
                          RK62R S 2 Antworten Letzte Antwort
                          • Ro75R Online
                            Ro75R Online
                            Ro75
                            #533
                            Das ist jetzt zwar Offtopic. Aber genau das gleiche Problem hatte ich früher bei der Nutzung von eCharts auch. Es wurde schlimmer je mehr Charts ich verwendete. Seither verwende ich die Charts vom Materialdesign - mein Problem ist seither weg. Und davor hatte ich Flot eingesetz. Wie gesagt Offtopic.
                            Ro75.
                            • Z zolpetol
                              @heinzie
                              RK62R Offline
                              RK62R Offline
                              RK62
                              #534
                              @zolpetol Der Speicher wird für die Installation benötigt, nicht für den Betrieb. Also andere Docker-Container runter fahren, System möglichst entlasten, eCharts installieren und Installationslog prüfen.
                              Wenn das nicht funktioniert, solltest Du ein Issue in Github aufmachen (https://github.com/ioBroker/ioBroker.echarts/issues).
                              • Z zolpetol
                                @heinzie
                                sen
                                #535
                                @zolpetol
                                Mein erster Beitrag nach Jahren des Lesens und Lernens.
                                An alle Entwickler und Supporter meinen Dank, ohne euch hätte ich aufgegeben!
                                Kann mich @zolpetol nur anschließen, habe alles probiert und viel Zeit investiert alles ohne Erfolg.
                                Erst eine Erhöhung des Arbeitsspeichers auf genau 10 Gbyte hat das Installationsproblem gelöst!
                                Für mich dank Proxmox recht einfach.
                                • RK62R RK62
                                  Z Offline
                                  Z Offline
                                  zolpetol
                                  #536
                                  @rk62
                                  Danke an RK62!
                                  Habe jetzt einige virtuelle Maschinen runtergefahren, Echarts neu installiert und jetzt funktioniert es.
                                    deifel
                                    #537
                                    ich nutze seit ein paar Tagen Echarts und finde es grundsätzlich wirklich klasse! Vielen Dank an dieser Stelle.
                                    Allerdings bekomme ich bei einem ganz einfachen Chart-Anspruch das Ganze nicht ans Laufen und vermute mal, dass es sich entweder um einen Bug oder eine Einstellung handelt, die ich nach stundenlangem Suchen nicht finden konnte.
                                    Ich möchte ein ganz normales Balkendiagramm für die Regentagesmenge erstellen.
                                    Die Daten sind im IOBroker im History-Adapter gespeichert und zeitlich auch korrekt.
                                    Die Werte werden um 2355 Uhr auf 0 gesetzt. Ich möchte also einen Balken je Tag haben.
                                    Mit Flot klappt das auch - die Tage stimmen.
                                    Bei Echarts bin ich eigenartigerweise immer einen Tag voraus versetzt.
                                    Im Beispiel sieht man, dass bereits Werte für den 29.07. drin stehen, obwohl das erst morgen ist und wenn ich mit die Daten im History-Adapter anschaue, dann ist alles korrekt.
                                    In Echarts habe ich unter Intervalle "1 Tag" gesetzt. Stelle ich hier testweise auf "1 Stunde" um, dann stimmen die Werte bzw. er geht nicht mehr in den Folgetag (aber stündlich bringt mir natürlich nichts).
                                    Kann mir jemand sagen, an was das liegt? Mache ich da was falsch oder ist das tatsächlich einfach so (falsch)?
                                    Danke und Grüße
                                    • D deifel
                                      Danke und Grüße
                                      #538
                                      @deifel sagte in Test eCharts Adapter:
                                      dann darfst du nur einen Wert pro Tag in den Datenpunkt schreiben
                                      das verschobene Datum ist ein Bug
                                        sigi234S Online
                                        sigi234S Online
                                        sigi234
                                        #539
                                        @homoran sagte in Test eCharts Adapter:
                                        Wobei dieser leider schon sehr lange besteht.
                                        https://github.com/ioBroker/ioBroker.echarts/issues/279
                                        Immer Daten sichern!
                                        • BluefoxB Bluefox
                                          Aktuelle Test Version 0.4.2
                                          Veröffentlichungsdatum 01.11.2020
                                          Github Link https://github.com/ioBroker/ioBroker.echarts
                                          Hallo Community,
                                          ich möchte für den Test mein neuen Adapter abgeben: echarts.
                                          Die Entwicklung hat mehr als ein Jahr gedauert (seit 21 Okt 2019) und ich habe sehr viel Zeit in diesen Adapter inverstiert.
                                          Der Adapter ist als Ersatz für flot gedacht und alle Presets aus flot werden beim Start automatisch einmalig übernommen.
                                          Ich denke, dass Adapter selbst erklärend ist. Man kann im Vis die Charts benutzen oder auch irgendwo als iframe: http://IP:8082/echarts/index.html?preset=echarts.0.PRESETID.
                                          Die Issues, wie immer, bitte ich auf github erstellen: https://github.com/ioBroker/ioBroker.echarts/issues
                                          flkontaktF Online
                                          flkontaktF Online
                                          flkontakt
                                          #540
                                          @bluefox Hallo, siehe Bild, ich habe unter Markierungen einen Text eingetragen, dieser wird an 3 Positionen dargestellt. Mir würde an 1 Position reichen, kann ich das entsprechend einstellen? Danke!!!
