  4. Test eCharts Adapter
echarts
666 Beiträge 109 Kommentatoren 263.4k Aufrufe 84 Beobachtet
  • RK62R RK62
    @heinzie Das ist genau die Stelle wo bei mir für den ioBroker-Container der massive Speicherhunger von 5GB entsteht und das System für eine Minute stehen bleibt bevor die Installation dann weiterläuft. Da hilft wohl nur RAM nachschieben (ich habe 10 GB Speicher verbaut) oder ein Issue in Github aufmachen (https://github.com/ioBroker/ioBroker.echarts/issues).
    2023-06-20 23:14:51.685 - info: host.z-iobroker iobroker upload [28] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/asset-manifest.json asset-manifest.json application/json
    2023-06-20 23:14:52.018 - info: host.z-iobroker instance system.adapter.echarts.0 started with pid 954
    2023-06-20 23:14:53.480 - info: host.z-iobroker iobroker upload [20] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/chart/static/js/main.eb0afecd.js.LICENSE.txt chart/static/js/main.eb0afecd.js.LICENSE.txt text/plain
    2023-06-20 23:14:53.506 - info: host.z-iobroker iobroker upload [19] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/chart/static/js/main.eb0afecd.js.map chart/static/js/main.eb0afecd.js.map application/json
    2023-06-20 23:14:55.188 - info: echarts.0 (954) starting. Version 1.5.1 in /opt/iobroker/node_modules/iobroker.echarts, node: v18.16.0, js-controller: 4.0.24
    2023-06-20 23:15:15.885 - info: admin.0 (200) <== Disconnect system.user.admin from ::ffff:192.168.64.1 admin
    2023-06-20 23:15:18.736 - info: admin.0 (200) ==> Connected system.user.admin from ::ffff:192.168.64.1
    ==== Speicherbedarf steigt von 1 auf 5-6 GB ====
    2023-06-20 23:16:20.624 - info: host.z-iobroker iobroker upload [18] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/echarts.png echarts.png image/png
    2023-06-20 23:16:20.920 - info: host.z-iobroker iobroker upload [17] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
    2023-06-20 23:16:21.152 - info: host.z-iobroker iobroker upload [16] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/manifest.json manifest.json application/json
    heinzie
    schrieb am zuletzt editiert von heinzie
    #522
    @rk62 sagte in Test eCharts Adapter:
    Danke, ich habe jetzt auch mal den Speicher erhöht und es läuft sofort ohne Probleme.
    Obwohl hier nur 65.21 MB angegeben werden
    RK62R 1 Antwort Letzte Antwort
    • H heinzie
      RK62R Offline
      RK62R Offline
      RK62
      #523
      @heinzie Prima! Die Installation braucht temporär den Speicher. Die 65MB ist der Speicher für den Betrieb des Adapters.
      H 1 Antwort Letzte Antwort
      • RK62R RK62
        heinzie
        #524
        ok, da kann ich problemlos mit leben. Nochmals Danke für die Hilfe.
        • Z Offline
          Z Offline
          zolpetol
          #525
          Nach etwas längerer Zeit will ich ein neues Diagramm mit E-Charts erstellen, bei Anwahl es TAB kommt die Meldung "File tab.html not found".
          Habe alle Updates gemacht und gegoogelt, keine Lösung.
          Hat jemand einen Tipp - danke!
          RK62R H 2 Antworten Letzte Antwort
          • Z zolpetol
            RK62R Offline
            RK62R Offline
            RK62
            #526
            @zolpetol Ja, etwas hochblättern, so bis 20.06. / 19:16
            Z 1 Antwort Letzte Antwort
            • RK62R RK62
              Z Offline
              Z Offline
              zolpetol
              #527
              @rk62
              Danke, leider hilft das nicht. Das Symbol wird wieder korrekt dargestellt, es kommt aber immer noch die Meldung. Auch ein Downgrade auf 1.14.14 hat keine Änderung gebracht.
              • Z zolpetol
                @rk62
                RK62R Offline
                RK62R Offline
                RK62
                #528
                @zolpetol Ist die Installation denn im Log ohne Fehler zu Ende gekommen und das System neu gestartet?
                  #529
                  @zolpetol
                  die Idee ist vielleicht gar nicht so falsch.
                  in den letzten Tagen gab es Meldungen, dass sich eCharts beim Update einen großen Schluck vom RAM gönnt.
                  Da kam es auch schon zu Problemen beim Update
                    @zolpetol
                    Z Offline
                    Z Offline
                    zolpetol
                    #530
                    @homoran @RK62
                    Ich habe keine Fehler im Log gesehen und die virtuelle Maschine wurde neu gestartet - leider keine Änderung
                    • Z zolpetol
                      heinzie
                      #531
                      @zolpetol sagte in Test eCharts Adapter:
                      War bei mir der gleiche Fehler. Das einzige was funktioniert hat, war die Vergrößerung des Speichers.
                      • H heinzie
                        Z Offline
                        Z Offline
                        zolpetol
                        #532
                        @heinzie
                        Ich habe den Speicher jetzt von 8 GB auf 10 GB vergrößert, neu gestartet und es hat sich nichts geändert.
                        RK62R S 2 Antworten Letzte Antwort
                        • Ro75R Online
                          Ro75R Online
                          Ro75
                          #533
                          Das ist jetzt zwar Offtopic. Aber genau das gleiche Problem hatte ich früher bei der Nutzung von eCharts auch. Es wurde schlimmer je mehr Charts ich verwendete. Seither verwende ich die Charts vom Materialdesign - mein Problem ist seither weg. Und davor hatte ich Flot eingesetz. Wie gesagt Offtopic.
                          Ro75.
                          • Z zolpetol
                            @heinzie
                            RK62R Offline
                            RK62R Offline
                            RK62
                            #534
                            @zolpetol Der Speicher wird für die Installation benötigt, nicht für den Betrieb. Also andere Docker-Container runter fahren, System möglichst entlasten, eCharts installieren und Installationslog prüfen.
                            Wenn das nicht funktioniert, solltest Du ein Issue in Github aufmachen (https://github.com/ioBroker/ioBroker.echarts/issues).
                            • Z zolpetol
                              @heinzie
                              sen
                              #535
                              @zolpetol
                              Mein erster Beitrag nach Jahren des Lesens und Lernens.
                              An alle Entwickler und Supporter meinen Dank, ohne euch hätte ich aufgegeben!
                              Kann mich @zolpetol nur anschließen, habe alles probiert und viel Zeit investiert alles ohne Erfolg.
                              Erst eine Erhöhung des Arbeitsspeichers auf genau 10 Gbyte hat das Installationsproblem gelöst!
                              Für mich dank Proxmox recht einfach.
                              • RK62R RK62
                                Z Offline
                                Z Offline
                                zolpetol
                                #536
                                @rk62
                                Danke an RK62!
                                Habe jetzt einige virtuelle Maschinen runtergefahren, Echarts neu installiert und jetzt funktioniert es.
                                  deifel
                                  #537
                                  ich nutze seit ein paar Tagen Echarts und finde es grundsätzlich wirklich klasse! Vielen Dank an dieser Stelle.
                                  Allerdings bekomme ich bei einem ganz einfachen Chart-Anspruch das Ganze nicht ans Laufen und vermute mal, dass es sich entweder um einen Bug oder eine Einstellung handelt, die ich nach stundenlangem Suchen nicht finden konnte.
                                  Ich möchte ein ganz normales Balkendiagramm für die Regentagesmenge erstellen.
                                  Die Daten sind im IOBroker im History-Adapter gespeichert und zeitlich auch korrekt.
                                  Die Werte werden um 2355 Uhr auf 0 gesetzt. Ich möchte also einen Balken je Tag haben.
                                  Mit Flot klappt das auch - die Tage stimmen.
                                  Bei Echarts bin ich eigenartigerweise immer einen Tag voraus versetzt.
                                  Im Beispiel sieht man, dass bereits Werte für den 29.07. drin stehen, obwohl das erst morgen ist und wenn ich mit die Daten im History-Adapter anschaue, dann ist alles korrekt.
                                  In Echarts habe ich unter Intervalle "1 Tag" gesetzt. Stelle ich hier testweise auf "1 Stunde" um, dann stimmen die Werte bzw. er geht nicht mehr in den Folgetag (aber stündlich bringt mir natürlich nichts).
                                  Kann mir jemand sagen, an was das liegt? Mache ich da was falsch oder ist das tatsächlich einfach so (falsch)?
                                  Danke und Grüße
                                  • D deifel
                                    Danke und Grüße
                                    #538
                                    @deifel sagte in Test eCharts Adapter:
                                    dann darfst du nur einen Wert pro Tag in den Datenpunkt schreiben
                                    das verschobene Datum ist ein Bug
                                      sigi234S Online
                                      sigi234S Online
                                      #539
                                      @homoran sagte in Test eCharts Adapter:
                                      Wobei dieser leider schon sehr lange besteht.
                                      https://github.com/ioBroker/ioBroker.echarts/issues/279
                                      • BluefoxB Bluefox
                                        Aktuelle Test Version 0.4.2
                                        Veröffentlichungsdatum 01.11.2020
                                        Github Link https://github.com/ioBroker/ioBroker.echarts
                                        Hallo Community,
                                        ich möchte für den Test mein neuen Adapter abgeben: echarts.
                                        Die Entwicklung hat mehr als ein Jahr gedauert (seit 21 Okt 2019) und ich habe sehr viel Zeit in diesen Adapter inverstiert.
                                        Der Adapter ist als Ersatz für flot gedacht und alle Presets aus flot werden beim Start automatisch einmalig übernommen.
                                        Ich denke, dass Adapter selbst erklärend ist. Man kann im Vis die Charts benutzen oder auch irgendwo als iframe: http://IP:8082/echarts/index.html?preset=echarts.0.PRESETID.
                                        Die Issues, wie immer, bitte ich auf github erstellen: https://github.com/ioBroker/ioBroker.echarts/issues
                                        flkontaktF Online
                                        flkontaktF Online
                                        flkontakt
                                        #540
                                        @bluefox Hallo, siehe Bild, ich habe unter Markierungen einen Text eingetragen, dieser wird an 3 Positionen dargestellt. Mir würde an 1 Position reichen, kann ich das entsprechend einstellen? Danke!!!
                                        • flkontaktF flkontakt
                                          BananaJoeB Offline
                                          BananaJoeB Offline
                                          BananaJoe
                                          #541
                                          @flkontakt schon mal das Feld neben den Textfeld angeklickt?
                                          flkontaktF 1 Antwort Letzte Antwort
